Hi.
I'm trying to resolve an issue with a 2017 Tiguan and not having much luck.
Currently have engine management, airbag, front assist warning lights lit up. I believe the root of the problem is the steering wheel control module. Scan is saying:
4714 - Steering Column Control Module
U0212 00 [039] - No Communications
I have checked all fuses having read through a few threads on here but all seem to be fine. These faults happened fairly soon after a major service at VW main dealer.
Any help would be much appreciated.
Sunday,12,September,2021,11:16:03:41168
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
VIN: WVGZZZ5NZHW403044 License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 52 5F A5
VIN: WVGZZZ5NZHW403044 Mileage: 74213km-46113miles
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 JC HW: 04L 907 309 P
Component: R4 2.0l TDI H24 3023
Revision: B4H24--- CVN: DBFBCE1D4C6C0C4B
Coding: 0119001203271D082000
ASAM Dataset: EV_ECM20TDI01104L906026JC 004002
ROD: EV_ECM20TDI01104L906026GQ_004.rod
VCID: 74B1DFB81E3122ABB39-8020
VINID: 9E65EAAAA15EA989C400300410DA7B269F
20169 - Exhaust Pressure Sensor 1
P0471 00 [104] - Implausible Signal
Mileage: 73602 km
Date: 2021.08.30
Time: 10:21:07
Engine RPM: 0.00 /min
Coolant temperature: 90 °C
Intake air temperature: 71 °C
Voltage terminal 30: 12.960 V
Unlearning counter according OBD: 19
Exhaust mass flow of low-pressure EGR: calculated: 2.475
Differential pressure ratio: low-pressure EGR: 0.0 kg/h
Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 411.1 hPa
Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 611.0 hPa
Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 0.00 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 0.09 %
Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 411.0 hPa
12002 - Particulate Filter; Differential Pressure Sensor
P2453 00 [237] - Implausible Signal
Mileage: 73602 km
Date: 2021.08.30
Time: 10:21:07
Particle filter: air pressure sensor 1 bank 1: raw value: -143 hPa
Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 0 hPa
Par.fil: diff.pr.sens.1 bank 1: offset: 199 hPa
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -143 hPa
Outside temperature sensor 1: B1: raw value: 16.0 °C
Particle filter: soot mass measured: 0.00 g
Particle filter: soot mass calculated: 6.57 g
5158 - Diesel Particulate Filter; Differential Pressure Sensor
P2456 00 [237] - Intermittent
Mileage: 73600 km
Date: 2021.08.30
Time: 10:17:53
Engine RPM: 1816.50 /min
Vehicle speed: 45 km/h
Intake air temperature: 86 °C
Voltage terminal 30: 14.760 V
Particle filter: soot mass measured: -2.82 g
Particle filter: soot mass calculated: 6.49 g
31489 - Differential Pressure Sensor for DPF
P154B 00 [175] - Faulty
Mileage: 73614 km
Time: 00:00:00
Coolant temperature: 17 °C
Intake air temperature: 17 °C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 12.360 V
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
31490 - Differential Pressure Sensor for DPF
Mileage: 73614 km
Time: 00:00:00
U0212 00 [047] - No Communications
Mileage: 74001 km
Date: 2021.09.11
Time: 15:22:10
Engine RPM: 1018.00 /min
Normed load value: 58.8 %
Vehicle speed: 5 km/h
Intake air temperature: 75 °C
Voltage terminal 30: 13.380 V
Limitation: accelerator pedal: 40.2 Nm
Cruise Control System (CCS): status-Bits 0-7: 0
selected gear-Bits 0-7: 1
Readiness: 1 5 0 0 0
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 60277000000516
Coding: 0AEE929A34200B6F4777070462C74950492CD0E2E046927D30605078C02A4200002F641A1B13111435351919323200
VCID: 76B5E5B0084D30BB8DD-8022
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 M HW: 5NA 907 044 M
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000B00387115
Coding: 0012010420211001110510000010102A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 49CF5E4C29330F4330F-801C
Humidity sensor: exterior:
Rear A/C control head:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Fault Frequency: 67
Reset counter: 29
Mileage: 73595 km
Date: 2021.08.30
Time: 10:04:08
Outside temperature: 18.0 °C
Voltage terminal 30: 11.7 V
System run time-Terminal 15 on: 242 s
Air quality status: Malfunction
329479 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [008] - Open or Short to Plus
Reset counter: 28
Mileage: 73855 km
Date: 2021.09.11
Time: 07:57:17
Voltage terminal 30: 14.7 V
Inside temperature: 23.3 °C
Outside temperature: 16.5 °C
Fresh air/recirculating air/back pressure door specified value: 636
Actual value for fresh air/recirculation air flow flap: 975
Actual value for fresh air/recirculation air flow flap: 100.0 %
Part No SW: 5Q0 937 084 CE HW: 5Q0 937 084 CE
Component: BCM MQBAB M H34 0236
Serial number: 02001703200110
ROD: EV_BCMBOSCH_017.rod
VCID: 7DA7FA9C2D7B63E3CC7-8028
Wiper motor control module:
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 161214 033 0372
Serial number: 00000001612120463584
Component: RLHS 042 0105
Serial number: S7Y17M02D07H02M24S24
Coding: 00A8DD
Serial number: 000000000ZY170042NPK
Serial number: 00000000000068320510
Part No SW: 3Q0 919 294 A HW: 3Q0 919 294
Component: PDC 8 Kanal H07 0020
Serial number: 001201177478011
Coding: 0071451001
ASAM Dataset: EV_EPHBO18VW3260000 007015
ROD: EV_EPHBO18VW3260000.rod
VCID: 372B28B44FC789B356B-8062
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0233
Coding: 2A0060C150FF8728749C8145004087
VCID: 3E253D9060FDB8FB95D-806A
1076 - Databus
[FAULT_TIMEOUT_GRA_ACC_01]
Fault Frequency: 6
Reset counter: 244
Mileage: 74001 km
Date: 2021.09.11
Time: 15:22:09
Voltage terminal 15: 13.1 V
Control Module temperature: 43 °C
Velocity_vehicle_reference: 1.02 m/s
Longitudinal_acceleration_vehicle_reference: 1.03 m/s²
1116 - Databus
[FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
Reset counter: 244
Mileage: 74001 km
Date: 2021.09.11
Time: 15:43:23
Voltage terminal 15: 13.2 V
Control Module temperature: 41 °C
Velocity_vehicle_reference: 0.52 m/s
Longitudinal_acceleration_vehicle_reference: -0.09 m/s²
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2HXP3N
Coding: 98CCC0C00C0000005C5400CF008800000065
VCID: 1079B3280AE97E8B371-8044
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 5NC857705C0025R00385
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 5NC857706C0025R01070
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 602 17
Serial number: 35700000000AB99D412V
Subsystem 4 - Part No SW: ----------- HW: 480 000 602 17
Serial number: 35800000000B6854012A
Subsystem 5 - Part No SW: ----------- HW: 480 400 602 17
Serial number: 3510001B3247FF95C1DL
Subsystem 6 - Part No SW: ----------- HW: 480 400 602 17
Serial number: 3520001B3247FF96A33D
Subsystem 7 - Part No SW: ----------- HW: 480 400 202 17
Component: FrontSensor_D 000 6149
Serial number: 3550001A5244A734D7DA
Driver's side crash data pedestrian protection:
Subsystem 8 - Part No SW: ----------- HW: 480 400 202 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001AB244A735F48A
Passenger's side crash data pedestrian protection:
Subsystem 9 - Part No SW: ----------- HW: 480 400 202 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001AB244A735831$
Center pedestrian protection crash sensor:
Subsystem 10 - Part No SW: ----------- HW: 480 400 202 17
Component: PedP_Sensor_C 000 6149
Serial number: 2300001AB244A734A42Y
Driver's side crash data pedestrian protection 2:
Subsystem 11 - Part No SW: ----------- HW: 480 000 102 17
Component: PedPSensor_D2 001 0887
Serial number: I0M0000000023DA4112X
Passenger's side crash data pedestrian protection 2:
Subsystem 12 - Part No SW: ----------- HW: 480 000 102 17
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000E85A4A028
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Mileage: 74001 km
Date: 2021.09.11
Time: 15:22:11
Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
Revision: FF034034 Serial number: 20170203500085
Coding: 0C00
ROD: EV_SMLSVALEOMQB.rod
VCID: 41DF466C1103C703E8F-8014
Part No SW: 5NA 920 951 A HW: 5NA 920 951 A
Component: KOMBI 309 8311
Coding: 27A400006380060001886B031401000000000000
VCID: 3FDB409467F7B1F39EB-806A
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005888040
Coding: 030500045F087300FB07224C0A0F00010001050000000000000000000000
GVL: 01D43C0000000000408C80000000480000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F3B10D4B79741730EB-807A
Generator:
Subsystem 2 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 9059452904
197169 - Controls in Steering Wheel
U108E 00 [009] - No Communications
[MFL (LIN#2) Timeout]
Reset counter: 244
Mileage: 74001 km
Date: 2021.09.11
Time: 15:22:12
Terminal 30 power supply: 13.1 V
Terminal 15: On
9175296 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] - -
[Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
Reset counter: 29
Mileage: 73793 km
Date: 2021.09.11
Time: 07:23:17
Terminal 30 power supply: 14.5 V
Terminal 15: On
Serial number: HA1-00010.01.17
Coding: 0101
VCID: 4ACD61402C35045B395-801E
Component: TSG FS 020 0041
Serial number: 211016EJL21975
Coding: 00310220D001048000001000
VCID: 43D34C640B1FD513FA3-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013227000
Coding: 0D0000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D7527C052BEB23D47-8010
Component: TSG BFS 020 0041
Serial number: 060117EA518352
Coding: 00310020DE01048000001000
VCID: 42DD49601405DC1BF15-8016
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013045639
Coding: 050000
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0751
Coding: 02730601FF00000051110101008808001F0100C601200100CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 313F16ACA1A3578318F-8064
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL072UT
Data carrier:
Subsystem 2 - Part No SW: 5NA 919 866 AG HW: -----------
Component: ECE AS 2020 --- 1310
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 06021712K10174
Coding: 0003070600000401000213448050A90084000E000020
VCID: 3B23348473EFADD3B23-806E
End----------(Elapsed Time: 01:39, VBatt start/end: 13.0V/13.4V)-----------
Sunday,12,September,2021,11:21:03:41168
VCDS Version: Release 21.9.0 (x64) Running on Windows 8.1 x64
Address 15: Airbags Labels: 5Q0-959-655.clb
Control Module Part Number: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component and/or Version: AirbagVW21 003 0317
Software Coding: 98CCC0C00C0000005C5400CF008800000065
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_AirbaVW20SMEVW37X 002154 (VW37)
Mileage: 74001 km
Date: 2021.09.11
Time: 15:22:11
Sunday,12,September,2021,11:22:16:41168
Address 19: CAN Gateway Labels: 3Q0-907-530-V1.clb
Control Module Part Number: 3Q0 907 530 C HW: 3Q0 907 530 C
Component and/or Version: GW MQB High 418 4286
Software Coding: 030500045F087300FB07224C0A0F00010001050000000000000000000000
ASAM Dataset: EV_GatewNF 013020 (VW37)
Reset counter: 244
Mileage: 74001 km
Date: 2021.09.11
Time: 15:22:12
Terminal 15: On
B130E 00 [008] - -
Reset counter: 29
Mileage: 73793 km
Date: 2021.09.11
Time: 07:23:17
Terminal 15: On
Sunday,12,September,2021,11:24:15:41168
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 026 JC HW: 04L 907 309 P
Component and/or Version: R4 2.0l TDI H24 3023
Software Coding: 0119001203271D082000
ASAM Dataset: EV_ECM20TDI01104L906026JC 004002 (VW37)
Fault Codes have been Erased
Mileage: 74213 km
Date: 2021.09.12
Time: 11:25:35
Coolant temperature: 34 °C
Intake air temperature: 26 °C
Voltage terminal 30: 12.220 V
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
