'17 plate Tiguan. Steering wheel control module U0212
invernesspl
C?ID=345478
Hi.
I'm trying to resolve an issue with a 2017 Tiguan and not having much luck.
Currently have engine management, airbag, front assist warning lights lit up. I believe the root of the problem is the steering wheel control module. Scan is saying:
4714 - Steering Column Control Module
U0212 00 [039] - No Communications
I have checked all fuses having read through a few threads on here but all seem to be fine. These faults happened fairly soon after a major service at VW main dealer.
Any help would be much appreciated.
Sunday,12,September,2021,11:16:03:41168
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WVGZZZ5NZHW403044   License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 52 5F A5
VIN: WVGZZZ5NZHW403044   Mileage: 74213km-46113miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 JC    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3023
   Revision: B4H24---    CVN: DBFBCE1D4C6C0C4B
   Coding: 0119001203271D082000
   ASAM Dataset: EV_ECM20TDI01104L906026JC 004002
   ROD: EV_ECM20TDI01104L906026GQ_004.rod
   VCID: 74B1DFB81E3122ABB39-8020
   VINID: 9E65EAAAA15EA989C400300410DA7B269F
20169 - Exhaust Pressure Sensor 1
          P0471 00 [104] - Implausible Signal
                    Mileage: 73602 km
                    Date: 2021.08.30
                    Time: 10:21:07
                    Engine RPM: 0.00 /min
                    Coolant temperature: 90 °C
                    Intake air temperature: 71 °C
                    Voltage terminal 30: 12.960 V
                    Unlearning counter according OBD: 19
                    Exhaust mass flow of low-pressure EGR: calculated: 2.475
                    Differential pressure ratio: low-pressure EGR: 0.0 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 411.1 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 611.0 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 0.00 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 0.09 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 411.0 hPa
12002 - Particulate Filter; Differential Pressure Sensor
          P2453 00 [237] - Implausible Signal
                    Mileage: 73602 km
                    Date: 2021.08.30
                    Time: 10:21:07
                    Particle filter: air pressure sensor 1 bank 1: raw value: -143 hPa
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 0 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: 199 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -143 hPa
                    Outside temperature sensor 1: B1: raw value: 16.0 °C
                    Particle filter: soot mass measured: 0.00 g
                    Particle filter: soot mass calculated: 6.57 g
5158 - Diesel Particulate Filter; Differential Pressure Sensor
          P2456 00 [237] - Intermittent
                    Mileage: 73600 km
                    Date: 2021.08.30
                    Time: 10:17:53
                    Engine RPM: 1816.50 /min
                    Vehicle speed: 45 km/h
                    Intake air temperature: 86 °C
                    Voltage terminal 30: 14.760 V
                    Particle filter: soot mass measured: -2.82 g
                    Particle filter: soot mass calculated: 6.49 g
31489 - Differential Pressure Sensor for DPF
          P154B 00 [175] - Faulty
                    Mileage: 73614 km
                    Coolant temperature: 17 °C
                    Intake air temperature: 17 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 12.360 V
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
31490 - Differential Pressure Sensor for DPF
                    Mileage: 73614 km
          U0212 00 [047] - No Communications
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:10
                    Engine RPM: 1018.00 /min
                    Normed load value: 58.8 %
                    Vehicle speed: 5 km/h
                    Intake air temperature: 75 °C
                    Voltage terminal 30: 13.380 V
                    Limitation: accelerator pedal: 40.2 Nm
                    selected gear-Bits 0-7: 1
Readiness: 1 5 0 0 0
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 60277000000516
   Coding: 0AEE929A34200B6F4777070462C74950492CD0E2E046927D30605078C02A4200002F641A1B13111435351919323200
   VCID: 76B5E5B0084D30BB8DD-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 M    HW: 5NA 907 044 M
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000B00387115
   Coding: 0012010420211001110510000010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   VCID: 49CF5E4C29330F4330F-801C
   Humidity sensor: exterior:
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 67
                    Reset counter: 29
                    Mileage: 73595 km
                    Date: 2021.08.30
                    Time: 10:04:08
                    Outside temperature: 18.0 °C
                    Voltage terminal 30: 11.7 V
                    System run time-Terminal 15 on: 242 s
                    Air quality status: Malfunction
329479 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [008] - Open or Short to Plus
                    Reset counter: 28
                    Mileage: 73855 km
                    Date: 2021.09.11
                    Time: 07:57:17
                    Voltage terminal 30: 14.7 V
                    Inside temperature: 23.3 °C
                    Outside temperature: 16.5 °C
                    Fresh air/recirculating air/back pressure door specified value: 636
                    Actual value for fresh air/recirculation air flow flap: 975
                    Actual value for fresh air/recirculation air flow flap: 100.0 %
   Part No SW: 5Q0 937 084 CE    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H34 0236
   Serial number: 02001703200110
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7DA7FA9C2D7B63E3CC7-8028
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 161214  033 0372
   Serial number: 00000001612120463584
   Component: RLHS  042 0105
   Serial number: S7Y17M02D07H02M24S24
   Coding: 00A8DD
   Serial number: 000000000ZY170042NPK
   Serial number: 00000000000068320510
   Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 001201177478011
   Coding: 0071451001
   ASAM Dataset: EV_EPHBO18VW3260000 007015
   ROD: EV_EPHBO18VW3260000.rod
   VCID: 372B28B44FC789B356B-8062
   Component: ACCCONTIMQB   H01 0233
   Coding: 2A0060C150FF8728749C8145004087
   VCID: 3E253D9060FDB8FB95D-806A
1076 - Databus
          [FAULT_TIMEOUT_GRA_ACC_01]
                    Reset counter: 244
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:09
                    Voltage terminal 15: 13.1 V
                    Control Module temperature: 43 °C
                    Velocity_vehicle_reference: 1.02 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.03 m/s²
1116 - Databus
          [FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
                    Reset counter: 244
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:43:23
                    Voltage terminal 15: 13.2 V
                    Control Module temperature: 41 °C
                    Velocity_vehicle_reference: 0.52 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.09 m/s²
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2HXP3N
   Coding: 98CCC0C00C0000005C5400CF008800000065
   VCID: 1079B3280AE97E8B371-8044
   Left seat belt tensioner:
   Serial number: 5NC857705C0025R00385
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 5NC857706C0025R01070
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 602 17
   Serial number: 35700000000AB99D412V
   Subsystem 4 - Part No SW: -----------    HW: 480 000 602 17
   Serial number: 35800000000B6854012A
   Subsystem 5 - Part No SW: -----------    HW: 480 400 602 17
   Serial number: 3510001B3247FF95C1DL
   Subsystem 6 - Part No SW: -----------    HW: 480 400 602 17
   Serial number: 3520001B3247FF96A33D
   Subsystem 7 - Part No SW: -----------    HW: 480 400 202 17
   Serial number: 3550001A5244A734D7DA
   Subsystem 8 - Part No SW: -----------    HW: 480 400 202 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001AB244A735F48A
   Subsystem 9 - Part No SW: -----------    HW: 480 400 202 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001AB244A735831$
   Subsystem 10 - Part No SW: -----------    HW: 480 400 202 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001AB244A734A42Y
   Subsystem 11 - Part No SW: -----------    HW: 480 000 102 17
   Serial number: I0M0000000023DA4112X
   Subsystem 12 - Part No SW: -----------    HW: 480 000 102 17
   Serial number: I0N00000000E85A4A028
          B1000 1B [137] - Resistance Too High
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:11
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170203500085
   Coding: 0C00
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41DF466C1103C703E8F-8014
   Part No SW: 5NA 920 951 A    HW: 5NA 920 951 A
   Component: KOMBI         309 8311
   Coding: 27A400006380060001886B031401000000000000
   VCID: 3FDB409467F7B1F39EB-806A
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005888040
   Coding: 030500045F087300FB07224C0A0F00010001050000000000000000000000
   GVL: 01D43C0000000000408C80000000480000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3B10D4B79741730EB-807A
   Generator:
   Subsystem 2 - Part No SW: 5QA 915 181 D    HW: 5QA 915 181 D
   Serial number: 9059452904
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
          [MFL (LIN#2) Timeout]
                    Reset counter: 244
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:12
                    Terminal 30 power supply: 13.1 V
                    Terminal 15: On
9175296 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
                    Reset counter: 29
                    Mileage: 73793 km
                    Date: 2021.09.11
                    Time: 07:23:17
                    Terminal 30 power supply: 14.5 V
                    Terminal 15: On
   Serial number: HA1-00010.01.17
   Coding: 0101
   VCID: 4ACD61402C35045B395-801E
   Serial number: 211016EJL21975
   Coding: 00310220D001048000001000
   VCID: 43D34C640B1FD513FA3-8016
   Serial number: 00000000000013227000
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D7527C052BEB23D47-8010
   Serial number: 060117EA518352
   Coding: 00310020DE01048000001000
   VCID: 42DD49601405DC1BF15-8016
   Serial number: 00000000000013045639
   Coding: 050000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730601FF00000051110101008808001F0100C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 313F16ACA1A3578318F-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL072UT
   Subsystem 2 - Part No SW: 5NA 919 866 AG    HW: -----------
   Component: ECE AS 2020  --- 1310
   Serial number: 06021712K10174
   Coding: 0003070600000401000213448050A90084000E000020
   VCID: 3B23348473EFADD3B23-806E
End----------(Elapsed Time: 01:39, VBatt start/end: 13.0V/13.4V)-----------
Sunday,12,September,2021,11:21:03:41168
VCDS Version: Release 21.9.0 (x64) Running on Windows 8.1 x64
                Address 15: Airbags       Labels: 5Q0-959-655.clb
Control Module Part Number: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
  Component and/or Version: AirbagVW21    003 0317
           Software Coding: 98CCC0C00C0000005C5400CF008800000065
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_AirbaVW20SMEVW37X 002154 (VW37)
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:11
Sunday,12,September,2021,11:22:16:41168
                Address 19: CAN Gateway       Labels: 3Q0-907-530-V1.clb
Control Module Part Number: 3Q0 907 530 C    HW: 3Q0 907 530 C
  Component and/or Version: GW MQB High   418 4286
           Software Coding: 030500045F087300FB07224C0A0F00010001050000000000000000000000
              ASAM Dataset: EV_GatewNF 013020 (VW37)
                    Reset counter: 244
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:12
                    Terminal 15: On
          B130E 00 [008] - -
                    Reset counter: 29
                    Mileage: 73793 km
                    Date: 2021.09.11
                    Time: 07:23:17
                    Terminal 15: On
Sunday,12,September,2021,11:24:15:41168
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 026 JC    HW: 04L 907 309 P
  Component and/or Version: R4 2.0l TDI   H24 3023
           Software Coding: 0119001203271D082000
              ASAM Dataset: EV_ECM20TDI01104L906026JC 004002 (VW37)
Fault Codes have been Erased
                    Mileage: 74213 km
                    Date: 2021.09.12
                    Time: 11:25:35
                    Coolant temperature: 34 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.220 V
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
tibcab
France
C?ID=82094
The errors shown in module 15 and 19 indeed point to a faulty Steering Wheel Control Module. I would tend to believe the rotary contact is defective and not the module itself since there are no errors logged in module 16.
The fact that steering wheel controls do not work and the airbag fault confirm this in my opinion.
invernesspl
C?ID=345478
The steering wheel controls (the steering wheel buttons) do all work, as do the indicators, wipers etc.
hmm......... second try (don't ask!!)
@invernesspl : Hi. Interesting DTC-set!!
On the auto-scan for a late model Tiggy with a 3Q0 chassis, a correctly functioning CAN Gateway module should be reported like this (from here):
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb​
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C​
Component: GW MQB High 521 5388​
Serial number: 23101900840494​
Coding: 030500347F085900FB0322481E0F00010001070000000000000000000000​
Shop #: WSC 00066 790 00439​
ASAM Dataset: EV_GatewNF 013026​
VCID: F0ACB3792B58300BB3-80A4​
Generator:​
Component: 5-00-14-00-04​
Subsystem 2 - Part No SW: 5NA 959 442 A HW: 5NA 959 442 A
Component: E221__MFL-TAT H06 0025
Serial number: 2341918204601696FE2B
Coding: 280000
Battery Monitoring Control Module:​
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D​
Component: J367-BDMHella H10 9070​
Serial number: 9429356900​
No fault code found.​
So, notice that the multifunction steering wheel control module (called "J453" in WD) is a LIN slave to the hex19 module which means that it is directly connected to J533 (albeit, the LIN wires are routed via a separate module and these are ultimately connected to J533 through the slip-ring inside the steering wheel - as per @tibcab suggestion).
The DTC from your hex19 module is:
197169 - Controls in Steering Wheel​
U108E 00 [009] - No Communications​
[MFL (LIN#2) Timeout]​
Confirmed - Tested Since Memory Clear​
Freeze Frame:​
Fault Status: 00000001​
Fault Priority: 2​
Fault Frequency: 1​
Reset counter: 244​
Mileage: 74001 km​
Date: 2021.09.11
Time: 15:22:12
Notice the highlighted LIN#2 - this refers to the second LIN line on J533 ("LIN#1" is for J367 & Alternator) and "MFL" is J453
Also notice on your auto-scan that the same date-time stamp (colored above for hex19 module) appears on a bunch of DTC s on modules hex01, hex19, hex15 and hex13 -which strongly suggests a link related to the "controls in steering wheel" fault - which I guess may be different to a J453 module fault!
Are you saying that despite the confirmed DTC above, ALL switches/buttons on the steering-wheel/steering-column-stalks work OK?
If so, maybe keep cycling the ignition ON/OFF and re-check the Fault Frequency number on the 197169 error - does the number increase with each cycle? If not, try clearing all DTC s-does the 197169 error re-appear?
Also - does the multifunction LIN module appear as an "Extra" in the VCDS Open Controller screen for the hex19 module - similar to this MQB platform car?:
invernesspl
C?ID=345478
Generator:​
Coding: 280000
Freeze Frame:​
Fault Priority: 2​
Fault Frequency: 1​
Reset counter: 244​
Mileage: 74001 km​
Date: 2021.09.11
Time: 15:22:12
Hi Don,
That's really helpful and well explained! I'll go over to the car this afternoon and check what you have suggested, will report back.
Thanks 👍
invernesspl
C?ID=345478
Bit of an update, when I went over to the car, I discovered that now all buttons and horn are no longer working. I think this clearly points to the clock spring (if that's the correct name for it?)
I've called TPS and it's £225+vat, so not the cheapest, they say they sell loads of them for the newer tiguans, if it's a common failure surely VW should be aware of the issue?!
Anyway, has anyone ever replaced one? Any guidance would be appreciated.
Does the new clock spring require coding to the car of any sort or is it a straight swap?
Thanks 👍
Bruce
Near Philadelphia, PA, USA
We suggest you use the factory repair information to make this replacement. It may not need coding but there usually are basic settings and adaptations required. There is a process to getting it calibrated.
invernesspl
C?ID=345478
Hi Bruce,
Is the factory repair information available freely? I don't have Elsa Win unfortunately.
No, it's purchased on a subscription basis. However, the fees for a short (one hour or one day) subscription are very reasonable and you can download (or print to PDF) pretty much everything for a particular car in that time.
