Maps 2021 Caddy-2.0 TDI Style Original first scan. maps
Maps
OwnerTR
Turkey
C?ID=493252
Tuesday,14,September,2021,13:26:36:34165
VCDS Version: 21.9.0.1  HEX-V2 CB: 0.4555.4
Data version: 20210824 DS330.0
VIN: WV1ZZZSKZMX050719   License Plate:
Chassis Type: SK-VN3S (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 52 5F 6C 6D
          75 A5 D6 D7 811E 811F 8120 8121 C002 C003
VIN: WV1ZZZSKZMX050719   Mileage: 1649km-1024miles
Address 01: Engine (J623-DTRC)       Labels: None
   Part No SW: 05L 906 023 AA    HW: 05L 907 309 C
   Component: R4 2.0l TDI   H30 0672
   Revision: E3H30---    CVN: 0024DDC3746D3ABF66040229D51ED7E26604022943FB2DAA
   Coding: 012500320324050930000000000000000000000000000000
   Shop #: WSC 35110 377 00121
   ASAM Dataset: EV_ECM20TDI01105L906023AA 007002
   ROD: EV_ECM20TDI011_VN3S.rod
   VCID: 678BB270CFE58363068-8032
   VINID: 9E606AAAA8DBA9DA001401C124E091EE83
2813 - Accelerator Position Sensor (G79)
          P2122 00 [032] - Signal too Low
                    Reset counter: 9
                    Mileage: 1048 km
                    Date: 2021.07.20
                    Time: 16:03:21
                    Engine RPM: 0.00 /min
                    Coolant temperature: 36 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 12.040 V
                    Unlearning counter according OBD: 9
                    Accelerator pedal travel: raw value: 0.00 %
                    Accelerator pedal: sensor voltage 1: 0.0 mV
                    Accelerator pedal: sensor voltage 2: 0.0 mV
                    Accelerator pedal: switch positions-Bits 0-7: 8
                    Starter control: Interlock- or P/N-signal: False result
                    Starter control: Interlock- or P/N-signal-Test_Program_B TRUE UBYTE: 0
                    Limitation: torque: 185.0 Nm
                    Control Module temperature: 29.5 °C
2815 - Accelerator Position Sensor 2 (G185)
          P2127 00 [032] - Signal too Low
                    Reset counter: 9
                    Mileage: 1048 km
                    Date: 2021.07.20
                    Time: 16:03:21
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 906 555 F    HW: 0GC 300 045 F
   Component: GSG DQ381     H06 4161
   CVN: E8811639
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062.rod
   VCID: 3E253714F0FFE2AB95E-806A
   Subsystem 1 - Part No SW: 5WA 713 033 AN    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20210423000066799700
   Subsystem 2 - Part No SW: 7T0 713 052 D    HW: 7T0 713 052 D
   Component: ZSB_SB_mono    H01 0005
   Serial number: 03052104S00000005064
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810500002823512
   Part No SW: 5WA 614 517 BJ    HW: 5WA 614 517 N
   Component: ESC           H13 0131
   Serial number: 61201000001521  CVN: 76FDB284
   Coding: 340C2C9734252C6C427E50010ACC60066DB658F05AC8670820BCA23121CFF300001C38
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013055
   ROD: EV_Brake1ESCEPBMQB37W_013.rod
   VCID: 117FBCA891E12DD338C-8044 SFD
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 C    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003_VW38.rod
   VCID: 54F175BC6E7318FB53A-8000
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 727 N    HW: 5WA 907 727 N
   Component: Climatronic   H02 0340
   Coding: 023010010211020000100000111001110000111110100000100000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005067
   ROD: EV_ACClimaBHBVW38X_VN3S.rod
   VCID: 5BE39E8003ADD783920-800E
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527     HW: 5WA 907 527
   Component: E857           H01 0103
   Serial number: 00001160321131147514
131076 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Fault Frequency: 0
459533 - Databus
          U1123 00 [046] - Received Error Message
          [Databus_error_value_received_Botschaft_Airbag_02]
                    Mileage: 1649 km
                    Date: 2021.09.14
                    Time: 13:23:18
   Part No SW: 5WA 937 086 E    HW: 5WA 937 086 E
   Component: BCM 37W BOSCH 018 0159
   Serial number: BXJ53F070521940
   ASAM Dataset: EV_BCM37w 006001
   ROD: EV_BCM37w_006_VW38.rod
   VCID: 53F376A06B7D1FC34A0-8006 SFD
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           054 0206
   Serial number: S5Y21M04D27H05M04S13
   Subsystem 2 - Part No SW: 5H0 941 193 G    HW: 5H0 941 193 G
   Component: LiSi           H04 0513
   Serial number: TW571426042100010039
   Subsystem 3 - Part No SW: 5H0 925 200 P    HW: 5H0 925 200 P
   Component: DiETa          H06 0007
   Serial number: 92471UDL000IH
   Subsystem 4 - Part No SW: 5H0 959 561 AR    HW: 5H0 959 561 AR
   Component: -VW----LINDA-  502 0813
   Serial number: MW3LND16042100010087
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 FL    HW: 5Q1 953 549 D
   Serial number: 00000021042104221295
71168 - Front Left Ride-Height Sensor
          C1034 31 [040] - No Signal
          [Drehwinkelsensor vorn links: Leitungsunterbrechung]
                    Reset counter: 38
   Part No SW: 5WA 919 298 A    HW: 5WA 919 298
   Component: PLA 12K Kanal H04 0230
   Serial number: 000027022194560
   Coding: 8200026011
   ASAM Dataset: EV_EPHBO2CVW3800000 002028
   ROD: EV_EPHBO2CVW3800000_VW38.rod
   Part No SW: 5WA 907 572 B    HW: 5WA 907 572
   Component: ACC Bosch MQB H20 0395
   Coding: 0E0200070077404512474000000000044E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4DC760D84D5949331C4-8018
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 CH    HW: 1EA 959 655 CH
   Component: VW40Airbag    009 0166
   Serial number: V119WmE0404
   Coding: 88CC008000E0C00000000000000000005154000020AA00005C00F680002B0065
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X.rod
   VCID: 094F94C8F9B11513F0C-805C SFD
   Seat occupancy detection 1:
   Subsystem 1 - Part No SW: 2K7 959 760 B    HW: 2K7 959 760 B
   Component: wSBR F-SG      037 0166
   Serial number:         94DC4E023423
   Subsystem 2 - Part No SW: -----------    HW: 440 001 504 21
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ00000007AAC435B
   Subsystem 3 - Part No SW: -----------    HW: 440 001 904 21
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ000000D0499945E
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 4 - Part No SW: -----------    HW: 440 001 704 21
   Component: Side_Sens_B_D  00A 0149
   Serial number: I0PCJ9F0146E13031002
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 5 - Part No SW: -----------    HW: 440 001 604 21
   Component: Side_Sens_B_P  00A 0149
   Serial number: I0QCJA301778B5341006
   Subsystem 6 - Part No SW: -----------    HW: 440 001 604 21
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJB3016DC75E2500X
   Subsystem 7 - Part No SW: -----------    HW: 440 001 704 21
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJ9F0146E1274A00S
   Subsystem 8 - Part No SW: -----------    HW: 440 001 702 21
   Component: FrontSensor_P  00A 014A
   Serial number: 355CJ2A636E87201700O
9444359 - Safety belt switch - driver side
          B101C 07 [047] - Mechanical Failure
                    Mileage: 1646 km
                    Date: 2021.09.14
                    Time: 08:04:37
1075977 - Databus
          [NWD: 0x102 ESC_50 error value ESP_v_ref]
                    Mileage: 1647 km
                    Date: 2021.09.14
                    Time: 08:13:17
   Part No SW: 5H0 920 340 A    HW: 5H0 920 340 A
   Component: KOMBI         203 3460
   Coding: 04A41447639C00080180220B2000000800101C00
   ASAM Dataset: EV_DashBoardVDDMQB37W 003032
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: 2019E96C6A4BB45B872-8074 SFD
16711686 - Secure Onboard Communication
          U14FE 00 [008] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Fault Frequency: 22
                    Mileage: 1395 km
                    Date: 2021.08.21
                    Time: 12:11:43
16711687 - Secure Onboard Communication
          U14FF 00 [008] - Signature Generation Failed
          [SOK_signature_creation_failed]
                    Reset counter: 113
                    Mileage: 1412 km
                    Date: 2021.08.29
                    Time: 09:56:45
   Part No SW: 5WA 907 530 J    HW: 5WA 907 530 C
   Component: GW2020 High   752 7084
   Revision: --------    Serial number: 290160901174158
   Coding: 0000808D0700000000000000012303327301610902000100030100000001010000000000000000000000000000000000
   GVL: 3D000800020840CC80008002C800004004004000004000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 004008
   ROD: EV_GatewMQB2020_VW38.rod
   VCID: 4FFB7AD047557B236E8-801A SFD
   Generator:
   Component: 5-00-15-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 3034767205
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 7C0 907 155     HW: 7C0 907 155
   Component: U13DCAC        H05 0870
   Serial number: A075085
   Subsystem 4 - Part No SW: 3G0 959 442 M    HW: 3G0 959 442 M
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440036085213371
2097222 - No Communications with HVAC Control Module (J301)
          U0164 00 [040] - -
                    Reset counter: 29
                    Mileage: 1395 km
                    Date: 2021.08.21
                    Time: 16:56:50
2498675 - Ethernet Module for Information Electronics 1
          U1645 00 [040] - No Communication
          [Information_electronics_control_module_1_no_communication_vlan]
                    Reset counter: 38
                    Mileage: 1410 km
                    Date: 2021.08.29
                    Time: 07:43:56
8397569 - Quiescent Current
          U1406 00 [040] - Too High
                    Fault Frequency: 16
                    Mileage: 1395 km
                    Date: 2021.08.25
                    Time: 21:38:36
   Part No SW: 5WA 909 059 H    HW: 3Q0 909 059 B
   Component: EBKV          H06 0112
   Serial number: BPA085030521013
   Coding: 5402C500090000000027C58800006DDBB66DDBB600
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 014027
   ROD: EV_BrakeBoostG2BoschVW37W_014.rod
   VCID: 55F788B8658901F3A44-8000 SFD
107024 - Transmission Control Module
          U14E4 00 [032] - Received Malfunction Value
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
172400 - System Voltage
          P0562 00 [032] - Too Low
          [PSCUnderVoltageLevel1]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 21000111684009
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 323D132434A736CB616-8066
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 E    HW: 2Q0 907 686 E
   Component: HRE_Master    H25 0284
   Serial number: 00000574013398
   Coding: 569545D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
   ROD: EV_HREntryHellaGen3Mstr.rod
   VCID: 3C213D1CE6E3F0BBBBA-8068
   Subsystem 1 - Part No SW: 2Q0 907 685 E    HW: 2Q0 907 685 E
   Component: HRE_Slave      H25 0284
   Serial number: 00000575550677
   Part No SW: 5Q4 959 593 H    HW: 5Q4 959 593 H
   Component: TSG FS        010 0692
   Serial number: 0000441068811
   Coding: 00309320D000040100001020
   Shop #: WSC 35110 377 00141
   VCID: 4ACD6BC4BC375E0B396-801E
196726 - Motor for mirror fold-in
          B11F6 13 [008] - Open Circuit
                    Fault Frequency: 70
                    Reset counter: 113
                    Mileage: 1385 km
                    Date: 2021.08.20
                    Time: 08:42:59
   Part No SW: 5R3 907 146 A    HW: 5R3 907 146
   Component: BASGEN1MQB37  261 2040
   Serial number: 00839307
   Coding: 0000000100000000000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   VCID: 36352F34D8CF2AEB4DE-8062
   Part No SW: 5Q4 959 592 H    HW: 5Q4 959 592 H
   Component: TSG BFS       010 0691
   Serial number: 0000441254350
   Coding: 00301120D000040100801000
   Shop #: WSC 35110 377 00133
   VCID: 49CF54C8B931551330C-801C
   Part No SW: 5H0 035 869     HW: 5H0 035 869
   Component: MU-E-D-ER     099 1325
   Serial number: CVRV59X1AEB0032
   Coding: 63521000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUEIMQB37w 001003
   ROD: EV_MUEIMQB37w_SE38.rod
   VCID: 6C81CD5CD603A03B6BA-8038 SFD
1865 - Automotive Audio Bus (A2B)
          B1994 F5 [008] - Participant Error
          [a2b_bus_next_node_defect]
                    Reset counter: 22
                    Mileage: 1395 km
                    Date: 2021.08.25
                    Time: 21:38:06
                    Voltage terminal 30: 11.8 V
                    amount_of_nodes: 3
                    Node number: 0
                    Node name: Information electronics control module 1
                    Node status: OK
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 5WA 980 556 B    HW: 5WA 980 556 B
   Component: RV eCompact   H26 0254
   Serial number: FCLK20300321000
   Coding: 06037200E42800
   ASAM Dataset: EV_CamSysRVCCompaFicos 009020
   ROD: EV_CamSysRVCCompaFicos.rod
   VCID: 50F979AC5A6B64DB772-8004
   Part No SW: 5Q0 959 107 AA    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0272
   Revision: --------    Serial number: A2-C737-6331-9
   Coding: 4E00
   VCID: 77ABE2309F4513E3968-8022
   Part No SW: 5WA 035 286 A    HW: 5WA 035 286 A
   Component: OCU3HMQB37W   H12 0135
   Serial number: 0000000104VIHJ6
   Coding: 06359010106818008005460000500607
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 46D55FF4A82FBA6BDDE-8012 SFD
1644017 - Online Services
          B1915 F1 [008] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
                    Fault Frequency: 9
                    Reset counter: 28
                    Voltage terminal 30: 12.4 V
                    Remaining long term energy budget: 0 mAh
                    Remaining short term energy budget: 0 mAh
                    Wake up cycles counter: 0
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H06 3129
   Serial number: E57830711211130
   Coding: 000108900068C040409E00001020000002018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 6597B87835E99173344-8030
   Component: LED1R         H08 9202
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w.rod
   VCID: 47CB52F0AF25A363268-8012
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----(Elapsed Time: 01:31, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
adpmap-01-05L-906-023-AA_WV1ZZZSKZMX050719-20210914-1401.CSV
    SW:05L-906-023-AA   HW:05L-907-309-C ---  Engine
    Component:R4 2.0l TDI   H30 0672, Coding:012500320324050930000000000000000000000000000000
    EV_ECM20TDI01105L906023AA,007002,EV_ECM20TDI011_VN3S.rod
    Tuesday,14,September,2021,14:01:38:34165
    VCDS Version: Release 21.9.0  Data version: 20210824 DS330.0
IDE00263-Injector 1 correction value,8ZR5ETH ,7
IDE00264-Injector 2 correction value,8ZR3BXE ,7
IDE00265-Injector 3 correction value,8887B6B ,7
IDE00266-Injector 4 correction value,AZ87AF8 ,7
IDE01096-Particulate Filter Statistics,0 ,1
IDE01711-Blocking of particle filter regeneration,not active ,1
IDE01945-Engine run-in oil pressure,not active ,1
IDE02637-Adaptation for metering quantity measurement,4 ,1
IDE04158-Activation of start/stop function,active ,1
IDE04617-Protective function,OFF ,1
IDE07903-Adaptation of ash mass,0.49 g,2
IDE10309-Adaptation of oxidation catalytic converter ageing,34432 s,2
IDE12048-MAS13895-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor,79.69 °,4
IDE12048-MAS13896-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor wheel,0.00 °,4
IDE12080-MAS13895-Adaptation of correction angle of crankshaft position detection-Error angle sensor,-39.84 °,4
IDE12080-MAS13896-Adaptation of correction angle of crankshaft position detection-Error angle sensor wheel,0.00 °,4
IDE15783-Adaptation for aging coated particulate filter,244890.4375 s,4
Elapsed Time: 00:04
adpmap-02-0GC-906-555-F_WV1ZZZSKZMX050719-20210914-1401.CSV
    SW:0GC-906-555-F   HW:0GC-300-045-F ---  Auto Trans
    Component:GSG DQ381     H06 4161, Coding:0014
    EV_TCMDQ381062,001001,EV_TCMDQ381062.rod
    Tuesday,14,September,2021,14:01:45:34165
IDE00001-ENG252070-Production mode-Haltemagnet ausschalten,not activated ,3
IDE00001-ENG252086-Production mode-Longpush,not activated ,3
IDE00001-ENG252078-Production mode-NER aktiv halten,not activated ,3
IDE00001-ENG252050-Production mode-N-Haltephase deaktivieren,not activated ,3
IDE00001-ENG98860-Production mode-Production mode,not activated ,3
IDE00001-ENG252054-Production mode-P-Taste deaktivieren,not activated ,3
Elapsed Time: 00:01
adpmap-2B-2Q0-905-861-B_WV1ZZZSKZMX050719-20210914-1406.CSV
    SW:2Q0-905-861-B   HW:2Q0-905-861-B ---  Steer. Col. Lock
    Component:ELV-MQBB      H09 0040, Coding:8800000000000000
    EV_ELVMarqMQBA0,002004,EV_ELVMarqMQBA0_VW27.rod
    Tuesday,14,September,2021,14:06:32:34165
IDE07566-Steering column lock unlocked,unlock ,1
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,not tested ,1
Elapsed Time: 00:01
adpmap-03-5WA-614-517-BJ_WV1ZZZSKZMX050719-20210914-1401.CSV
    SW:5WA-614-517-BJ   HW:5WA-614-517-N ---  ABS Brakes
    Component:ESC           H13 0131, Coding:340C2C9734252C6C427E50010ACC60066DB658F05AC8670820BCA23121CFF300001C38
    EV_Brake1ESCEPBMQB37W,013055,EV_Brake1ESCEPBMQB37W_013.rod
    Tuesday,14,September,2021,14:01:49:34165
IDE15332-MAS17834-Vehicle curb weight-Curb weight of rear axle,500.0 kg,4
IDE15332-MAS17837-Vehicle curb weight-Curb weight of front axle,500.0 kg,4
MAS09595-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
MAS09595-IDE02939-Production mode-Activate/lock control,Deactivating ,3
MAS09595-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
MAS09595-MAS16682-Production mode-Production mode after-run monitoring,Deactivating ,3
MAS09595-MAS18521-Production mode-Production mode: recuperation,Deactivating ,3
MAS09595-Production mode-,not active ,3
Elapsed Time: 00:13
adpmap-3C-2Q0-907-686-E_WV1ZZZSKZMX050719-20210914-1406.CSV
    SW:2Q0-907-686-E   HW:2Q0-907-686-E ---  Lane Change
    Component:HRE_Master    H25 0284, Coding:569545D0
    EV_HREntryHellaGen3Mstr,001015,EV_HREntryHellaGen3Mstr.rod
    Tuesday,14,September,2021,14:06:36:34165
IDE00001-MAS15623-Production mode-Deactivation of lane change assistance and exit warning,not active ,3
IDE00001-MAS15624-Production mode-Deactivation of Cross traffic assistant rear and pre sense rear,not active ,3
IDE00001-MAS15840-Production mode-Deactivation of dynamic calibration and blinding recognition,not active ,3
IDE00820-Activating and deactivating all development messages,not activated ,3
IDE05982-lane change assist. control module calibration values,-10.24 °,2
IDE05983-lane change assist. control module 2 calibration values,-10.24 °,2
IDE06218-MAS04607-Test bench data for calibration: production-Body height left front wheel house edge,0.00 mm,25
IDE06218-MAS04608-Test bench data for calibration: production-Body height right front wheel house edge,0.00 mm,25
IDE06218-MAS04609-Test bench data for calibration: production-Body height left rear wheel house edge,0.00 mm,25
IDE06218-MAS04610-Test bench data for calibration: production-Body height right rear wheel house edge,0.00 mm,25
IDE06218-MAS04612-Test bench data for calibration: production-Transverse position: vehicle: front axle,0 mm,25
IDE06218-MAS04613-Test bench data for calibration: production-Transverse position: vehicle: rear axle,0 mm,25
IDE06218-MAS04614-Test bench data for calibration: production-X-coordinate: Doppler simulator: left,0 mm,25
IDE06218-MAS04615-Test bench data for calibration: production-Y-coordinate: Doppler simulator: left,0 mm,25
IDE06218-MAS04616-Test bench data for calibration: production-Z-coordinate: Doppler simulator: left,0.00 mm,25
IDE06218-MAS04617-Test bench data for calibration: production-X-coordinate: Doppler simulator: right,0 mm,25
IDE06218-MAS04618-Test bench data for calibration: production-Y-coordinate: Doppler simulator: right,0 mm,25
IDE06218-MAS04619-Test bench data for calibration: production-Z-coordinate: Doppler simulator: right,0.00 mm,25
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,NVEM Kopplung nicht aktiv oder nicht implementiert ,2
IDE80015-Analysis 15,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,42
ENG153885-Knockout_test_mode,00000000  ,1
Elapsed Time: 00:04
adpmap-05-5WA-959-436-C_WV1ZZZSKZMX050719-20210914-1402.CSV
    SW:5WA-959-436-C   HW:5WA-959-436-C ---  Acc/Start Auth.
    Component:Kessy IOBOX   070 0706, Coding:
    EV_Kessy37w,003022,EV_Kessy37w_003_VW38.rod
    Tuesday,14,September,2021,14:02:05:34165
ENG253038-ENG258893-DevCod_ Search lights-Suchbeleuchtung_ZAT_bei_KL58_aktiv,activated ,5
ENG253038-ENG258265-DevCod_ Search lights-Suchbeleuchtung_ZAT_Beleuchtung_SES_Variante_aktiv,not activated ,5
ENG253038-ENG260629-DevCod_ Search lights-Suchbeleuchtung_ZAT_Normierung_aktiv,activated ,5
ENG253038-ENG259779-DevCod_ Search lights-Suchbeleuchtung_ZAT_OpenLoadErkennung_aktiv,not activated ,5
ENG253038-ENG260681-DevCod_ Search lights-Suchbeleuchtung_ZAT_SES_Mode,not activated ,5
ENG253096-DevCod_AutomatischeFunktionen,not activated ,6
ENG253395-ENG141964-DevCod_Fahrzeugkonfiguration-Steering alignment,Left ,5
ENG253395-ENG273785-DevCod_Fahrzeugkonfiguration-Transponding_Antennen_Strom_reduziert_aktiv,not active ,5
ENG253143-ENG258965-DevCod_Passive_EntryExit-Toggle-Datalogging_LFDebug_aktiv,not activated ,5
ENG253143-ENG258844-DevCod_Passive_EntryExit-Toggle-Gleichzeitiges_Senden_Innenraumantennen_aktiv,activated ,5
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,6
ENG129029-ENG259793-Easy_close_alignment-VIT_AktivTasteB_Zyklus,1.0 s,6
ENG253331-ENG258816-Par_Automatische_Funktionen-AutomatikFunktionen_Timeout,4320 min,10
ENG253331-ENG261186-Par_Automatische_Funktionen-AutomatikFunktionen_Zyklus_IDGeber_Abwesenheit,1000 ms,10
ENG253331-ENG260182-Par_Automatische_Funktionen-AutomatikFunktionen_Zyklus_IDGeber_Anwesenheit,300 ms,10
ENG253331-ENG259783-Par_Automatische_Funktionen-AutomatikFunktionen_Zyklus_IDGeberAbwesenheit_Beschleunigtes_Entry,1400 ms,10
ENG253220-IDE15282-Par_Bedienstellen-Door: driver control section: installation variant,0 ,36
ENG253220-IDE15283-Par_Bedienstellen-Door: front passenger control section: installation variant,0 ,36
ENG253220-IDE15284-Par_Bedienstellen-5th control section: installation variant,5 ,36
ENG253220-IDE15285-Par_Bedienstellen-Fuel filler cap control section: installation variant,5 ,36
ENG253220-IDE15286-Par_Bedienstellen-Rear driver side control section: installation variant,5 ,36
ENG253220-IDE15287-Par_Bedienstellen-Rear passenger side control section: installation variant,5 ,36
ENG253220-ENG259190-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_5teT,3600 min,36
ENG253220-ENG259838-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_BT,3600 min,36
ENG253220-ENG260574-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_FT,0 min,36
ENG253220-ENG261264-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HBFS,3600 min,36
ENG253220-ENG258369-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HFS,3600 min,36
ENG253220-ENG258148-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_Tank,3600 min,36
ENG253220-ENG261229-Par_Bedienstellen-Bedienstelle_Aktivierungsschwelle_Spielschutzzaehler,80 ,36
ENG253220-ENG259917-Par_Bedienstellen-Bedienstelle_Ausschaltzeit_Spielschutz_aktiv,1800 s,36
ENG253220-ENG261227-Par_Bedienstellen-Bedienstelle_Deaktivierung_SchwelleFahrendesFzg,20 km/h,36
ENG253220-ENG261134-Par_Bedienstellen-Bedienstelle_Deaktivierungsschwelle_Spielschutzzaehler,60 ,36
ENG253220-ENG258448-Par_Bedienstellen-Bedienstelle_MaxBetaetigung,120 s,36
ENG253220-ENG259922-Par_Bedienstellen-Bedienstelle_MaxKomfortUnterbrechung,10 ms,36
ENG253220-ENG261271-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_5teT,500 ms,36
ENG253220-ENG259320-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_BT,500 ms,36
ENG253220-ENG259918-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_FT,1500 ms,36
ENG253220-ENG260179-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HBFS,500 ms,36
ENG253220-ENG260090-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HFS,500 ms,36
ENG253220-ENG260565-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_Tank,500 ms,36
ENG253220-ENG261322-Par_Bedienstellen-Bedienstelle_MinBetaetigung_ToggleTaster,140 ms,36
ENG253220-ENG259707-Par_Bedienstellen-Bedienstelle_MinBetaetigung_Verriegelungssensor,100 ms,36
ENG253220-ENG258814-Par_Bedienstellen-Bedienstelle_Reaktivierung_SchwelleStehendesFzg,10 km/h,36
ENG253220-ENG258395-Par_Bedienstellen-Bedienstelle_Reduzierung_Zaehlerstand_Spielschutzzaehler,60 s,36
ENG253190-ENG258772-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Diagnose,71 ms,35
ENG253190-ENG258701-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Entry,10400 µs,35
ENG253190-ENG261026-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Exit,40400 µs,35
ENG253190-ENG258968-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Naeherung,20400 µs,35
ENG253190-ENG259906-Par_Näherungssensoren-Naeherungssensor_MaxPausenlaenge,10 ms,35
ENG253190-ENG260803-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Diagnose,42 ms,35
ENG253190-ENG259643-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Entry,6200 µs,35
ENG253190-ENG259840-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Exit,24200 µs,35
ENG253190-ENG259205-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Naeherung,12200 µs,35
ENG253190-ENG260098-Par_Näherungssensoren-Verzoegerung_PowerOn_Reset,1960 ms,35
ENG253285-ENG260495-Par_PassiveKomfort-Delay_Reichweitenbegrenzung_Start,0 ms,10
ENG253285-ENG260385-Par_PassiveKomfort-KomfortReichweitenbegr_Timout,75 s,10
ENG253285-ENG261013-Par_PassiveKomfort-PassiveKomfortFunktionen_MaxSignalisierungsdauer,60 s,10
ENG253285-ENG263587-Par_PassiveKomfort-PassiveKomfortFunktionen_Zeitfenster_fuer_Bedienhandlung,800 ms,10
ENG253285-ENG261279-Par_PassiveKomfort-Reichweitenbegrenzung_Zyklus,90 ms,10
ENG253106-ENG258919-Par_ScanStrategie_RetryHandling-anz_RetriesRegistering,1 Num,22
ENG253106-ENG259329-Par_ScanStrategie_RetryHandling-Erste_Warnschwelle_thermische_Überlast,45 °C,22
ENG253106-ENG259473-Par_ScanStrategie_RetryHandling-P2_Pause_zwischen_Transponding_Telegrammen,200 ms,22
ENG253106-ENG259392-Par_ScanStrategie_RetryHandling-Sperrzeit_LFTreiber_nach_thermischer_Ueberlast,5.0 s,22
ENG253106-ENG263515-Par_ScanStrategie_RetryHandling-t_CANSignalDelayAfterSleep,30 ms,22
ENG253106-ENG258479-Par_ScanStrategie_RetryHandling-t_LFDebug_Nachsignaslisierung,100 ms,22
ENG253106-ENG263591-Par_ScanStrategie_RetryHandling-Temperaturschaltschwelle_LF_Wavetable,100 °C,22
ENG253106-ENG276176-Par_ScanStrategie_RetryHandling-Timeout_Grundwert_RetryRegistering,52 ms,22
ENG253106-ENG276194-Par_ScanStrategie_RetryHandling-Timeout_Inkrementwert_RetryRegistering,7 ms,22
ENG253106-ENG261110-Par_ScanStrategie_RetryHandling-Verzoegerung_LFSenden_nach_Weckleitungziehen,0 ms,22
ENG253106-ENG260133-Par_ScanStrategie_RetryHandling-Zweite_Warnschwelle_thermische_Überlast,65 °C,22
ENG253086-MAS18911-Passive_Komfort-Convenience closing by locking using door handle active,activated ,5
ENG253086-ENG280093-Passive_Komfort-Noise_filter_aktiv,not activated ,5
ENG253086-ENG261176-Passive_Komfort-Passive_Komfort_Oeffnen_aktiv,not activated ,5
ENG253086-ENG259864-Passive_Komfort-Passive_Komfort_Togglen_aktiv,not activated ,5
ENG253352-ENG259594-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Abdimmen,1.0 ,30
ENG253352-ENG259617-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Aufdimmen,2.0 ,30
ENG253352-ENG261228-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ausschalten_KL15,10 min,30
ENG253352-ENG258605-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_0Prozent_Dimmkurve,0.0 %,30
ENG253352-ENG258785-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Deltawert_50Prozent_Dimmkurve,50.0 %,30
ENG253352-ENG263542-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Fehlerdimmwert,100 %,30
ENG253352-ENG260556-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Nennspannung,13.0 V,30
ENG253352-ENG258781-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_OffsetDimmwert,1.0 ,30
ENG253352-ENG259791-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Deltawert_100Prozent_Dimmkurve,100.0 %,30
ENG253287-ENG261242-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES1,10.0 %,32
ENG253287-ENG260274-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES2,3.0 %,32
ENG253287-ENG258981-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES1,5.0 %,32
ENG253287-ENG260137-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES2,2.0 %,32
ENG253287-ENG259846-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES1,80.0 %,32
ENG253287-ENG261362-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES2,20.0 %,32
ENG253287-ENG258809-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_1,0 %,32
ENG253287-ENG258501-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_2,0 %,32
ENG253287-ENG260497-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_1,80 %,32
ENG253287-ENG258157-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_2,100 %,32
ENG253287-ENG261138-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES1,100.0 %,32
ENG253287-ENG258211-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES2,30.0 %,32
ENG253287-ENG261183-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_faktor,0.1 ,32
ENG253287-ENG259175-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_Offset,2.0 Num,32
ENG253287-ENG261051-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Fall_OFF,740 ms,32
ENG253287-ENG260479-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_OFF,0 ms,32
ENG253287-ENG258704-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_ON,0 ms,32
ENG253287-ENG260922-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Rise_ON,100 ms,32
ENG253287-ENG260304-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Fall_OFF,1600 ms,32
ENG253287-ENG258413-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_OFF,0 ms,32
ENG253287-ENG260729-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_ON,0 ms,32
ENG253287-ENG258296-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Rise_ON,100 ms,32
ENG253287-ENG258477-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES1,15.0 %,32
ENG253287-ENG259506-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES2,4.0 %,32
ENG253287-ENG258902-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES1,5.0 %,32
ENG253287-ENG260830-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES2,2.0 %,32
Elapsed Time: 00:05
adpmap-5F-5H0-035-869_WV1ZZZSKZMX050719-20210914-1407.CSV
    SW:5H0-035-869   HW:5H0-035-869 ---  Information Electr.
    Component:MU-E-D-ER     099 1325, Coding:
    EV_MUEIMQB37w,001003,EV_MUEIMQB37w_SE38.rod
    Tuesday,14,September,2021,14:07:04:34165
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248440-function_configuration_swap_fod,swap_active_fod_not_active ,1
Elapsed Time: 03:29
adpmap-6C-5WA-980-556-B_WV1ZZZSKZMX050719-20210914-1410.CSV
    SW:5WA-980-556-B   HW:5WA-980-556-B ---  Back-up Cam.
    Component:RV eCompact   H26 0254, Coding:06037200E42800
    EV_CamSysRVCCompaFicos,009020,EV_CamSysRVCCompaFicos.rod
    Tuesday,14,September,2021,14:10:36:34165
IDE00001-IDE15846-Production mode-Camera cleaning,not active ,3
IDE00001-MAS03384-Production mode-Blindness detection,not active ,3
IDE00001-MAS21952-Production mode-online calibration,not active ,3
IDE00820-Activating and deactivating all development messages,not activated ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,63 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,71 min,2
ENG153885-Knockout_test_mode,0 ,1
Elapsed Time: 00:02
adpmap-6D-5Q0-959-107-AA_WV1ZZZSKZMX050719-20210914-1410.CSV
    SW:5Q0-959-107-AA   HW:5Q0-959-107-H ---  Trunk Elect.
    Component:HDSG-Modul    H13 0272, Coding:4E00
    EV_DeckLidCONTIAU736,001017,EV_DeckLidCONTIAU736_VW27.rod
    Tuesday,14,September,2021,14:10:41:34165
IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
IDE00001-MAS10735-Production mode-Calibration,not active ,3
IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
IDE02158-Program opening stop,580 ,2
IDE03435-Detection area upper,20 ,2
IDE03776-Offset for maximum programmable opening stop,20 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,0 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,4 min,2
IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,100 ,4
IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,100 ,4
IDE09511-Minimum opening height of tailgate,300 ,2
IDE09512-Deactivation of tailgate,active ,1
IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active ,2
IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
IDE09520-Offset for opening height after basic setting,0 ,2
IDE10408-Opening height in production mode,60 %,2
IDE10695-Dectivation of the luggage compartment cover,not active ,1
IDE10703-Luggage compartment cover: tolerance of the block counter,20 ,2
IDE10704-Luggage compartment cover: maximum no. of block drives,7 ,2
IDE10705-Luggage compartment cover: number bloom drives,100 ,2
IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,2 ,4
IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,2 ,4
IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,30 ,4
IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,30 ,4
IDE10708-Luggage compartment cover: adjust. track tolerance,88 ,2
IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active ,1
ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,not active ,2
ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,active ,2
ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,active ,2
ENG131232-MAS08212-Ausstattungen aktivieren-Motor 2,not active ,2
ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,not active ,2
Elapsed Time: 00:05
adpmap-08-5WA-907-727-N_WV1ZZZSKZMX050719-20210914-1402.CSV
    SW:5WA-907-727-N   HW:5WA-907-727-N ---  Auto HVAC
    Component:Climatronic   H02 0340, Coding:023010010211020000100000111001110000111110100000100000000000
    EV_ACClimaBHBVW38X,005067,EV_ACClimaBHBVW38X_VN3S.rod
    Tuesday,14,September,2021,14:02:14:34165
IDE00001-ENG128289-Production mode-Air_condition_compressor_deactivate,not active ,3
IDE00001-ENG128290-Production mode-Battery_cooling_and_heating_deactivate,not active ,3
IDE00001-ENG128291-Production mode-ClearResetEmissionRelated-DiagnosticInformation_Mode$04,not active ,3
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,Do not store ,1
IDE01479-Gear ratio of engine - A/C compressor,1.3 ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01488-Auxiliary heating retrofit without CAN,not installed ,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01503-Running time of basic setting for compressor break-in,60 s,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE02371-Time until seat heating performance is reduced from stage 3 to stage 2,10 min,1
IDE02372-Time until seat heating performance is reduced from stage 2 to stage 1,0 min,1
IDE02744-Steering wheel heating,short_push ,1
IDE03176-Duration of compressor run in,60 s,1
IDE04074-Driving program,not installed ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,10
IDE04927-MAS12610-Window heater-Activation of wiper arm heater,-50.00 °C,10
IDE04927-ENG263527-Window heater-Config_heating_voltage_request,No_set_point_voltage ,10
IDE04927-ENG263525-Window heater-Heating_rear_window_activation_time,320 s,10
IDE04927-ENG263512-Window heater-Heating_rear_window_cutoff_temperature,35.00 °C,10
IDE04927-ENG263556-Window heater-Heating_rear_window_temperature_activation_time,active ,10
IDE04927-ENG263570-Window heater-Window_heating_front_activation_time_pause,320 s,10
IDE04927-ENG263505-Window heater-Window_heating_front_cutoff_temperature,35.00 °C,10
IDE04927-ENG263589-Window heater-Window_heating_front_maximum_temperature_activation_time,1200 s,10
IDE04927-ENG263529-Window heater-Window_heating_front_temperature_activation_time,active ,10
IDE06089-ENG263584-Seat heater level current consumption allocation-Config_seat_heating_high_voltage_request,Sollspannungsanforderung 14.7 ,17
IDE06089-ENG263533-Seat heater level current consumption allocation-Config_seat_heating_low_voltage_request,Keine Spannungsanforderung ,17
IDE06089-ENG263526-Seat heater level current consumption allocation-Seat_heating_correction_of_temperature_regulation_on_heat_flow,0.0 °C,17
IDE06089-ENG263552-Seat heater level current consumption allocation-Seat_heating_filter_constant_for_heat_flow,1 s,17
IDE06089-ENG263578-Seat heater level current consumption allocation-Seat_heating_offset_voltage,15.7 V,17
IDE06089-ENG263544-Seat heater level current consumption allocation-Seat_heating_stage_1_lower_threshold,22.0 °C,17
IDE06089-ENG263507-Seat heater level current consumption allocation-Seat_heating_stage_1_upper_threshold,23.0 °C,17
IDE06089-ENG263592-Seat heater level current consumption allocation-Seat_heating_stage_2_lower_threshold,22.0 °C,17
IDE06089-ENG263559-Seat heater level current consumption allocation-Seat_heating_stage_2_upper_threshold,23.0 °C,17
IDE06089-ENG263539-Seat heater level current consumption allocation-Seat_heating_stage_3_lower_threshold,35.5 °C,17
IDE06089-ENG263554-Seat heater level current consumption allocation-Seat_heating_stage_3_upper_threshold,36.0 °C,17
IDE06089-ENG263536-Seat heater level current consumption allocation-Seat_heating_stage_4_lower_threshold,35.5 °C,17
IDE06089-ENG263549-Seat heater level current consumption allocation-Seat_heating_stage_4_upper_threshold,36.0 °C,17
IDE06089-ENG263566-Seat heater level current consumption allocation-Seat_heating_stage_5_lower_threshold,52.5 °C,17
IDE06089-ENG263597-Seat heater level current consumption allocation-Seat_heating_stage_5_upper_threshold,53.0 °C,17
IDE06089-ENG263562-Seat heater level current consumption allocation-Seat_heating_stage_6_lower_threshold,52.5 °C,17
IDE06089-ENG263524-Seat heater level current consumption allocation-Seat_heating_stage_6_upper_threshold,53.0 °C,17
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1500 l/min,1
IDE06545-Blower voltage for production routines,6.0 V,1
IDE06593-Air recirculation for production routines,No effect ,1
IDE07108-A/C styles,Readout ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,70 s,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,41 s,2
IDE07301-Remote start function: activation of seat heating,Seat heater request driver side ,1
IDE07302-Remote start function: interior climate control status,Remote start function with last set value active ,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,25.0 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,32.0 °C,1
IDE07307-Remote start function: activation stage of seat heating,4 ,1
IDE07308-Remote start function: activation stage of seat ventilation,4 ,1
IDE07398-Blower logic with manual adjustment,Fan setting: absolute ,1
IDE07418-Additional filter,not installed ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE07951-Time until head area heater performance is reduced from stage 3 to stage 2,0 min,1
IDE07952-Time until head area heater performance is reduced from stage 2 to stage 1,0 min,1
IDE08356-ENG125698-Left seat backrest fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08356-ENG125700-Left seat backrest fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08356-ENG125697-Left seat backrest fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08356-ENG125699-Left seat backrest fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08356-ENG125701-Left seat backrest fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08356-ENG134731-Left seat backrest fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08356-ENG125695-Left seat backrest fan 1-Overvoltage_treshold,16 V,10
IDE08356-ENG125696-Left seat backrest fan 1-Undervoltage_treshold,9 V,10
IDE08357-ENG125698-Left seat backrest fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08357-ENG125700-Left seat backrest fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08357-ENG125697-Left seat backrest fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08357-ENG125699-Left seat backrest fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08357-ENG125701-Left seat backrest fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08357-ENG134731-Left seat backrest fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08357-ENG125695-Left seat backrest fan 2-Overvoltage_treshold,16 V,10
IDE08357-ENG125696-Left seat backrest fan 2-Undervoltage_treshold,9 V,10
IDE08358-ENG125698-Left seat cushion fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08358-ENG125700-Left seat cushion fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08358-ENG125697-Left seat cushion fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08358-ENG125699-Left seat cushion fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08358-ENG125701-Left seat cushion fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08358-ENG134731-Left seat cushion fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08358-ENG125695-Left seat cushion fan 1-Overvoltage_treshold,16 V,10
IDE08358-ENG125696-Left seat cushion fan 1-Undervoltage_treshold,9 V,10
IDE08359-ENG125698-Left seat cushion fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08359-ENG125700-Left seat cushion fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08359-ENG125697-Left seat cushion fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08359-ENG125699-Left seat cushion fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08359-ENG125701-Left seat cushion fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08359-ENG134731-Left seat cushion fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08359-ENG125695-Left seat cushion fan 2-Overvoltage_treshold,16 V,10
IDE08359-ENG125696-Left seat cushion fan 2-Undervoltage_treshold,9 V,10
IDE08360-ENG125698-Right seat backrest fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08360-ENG125700-Right seat backrest fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08360-ENG125697-Right seat backrest fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08360-ENG125699-Right seat backrest fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08360-ENG125701-Right seat backrest fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08360-ENG134731-Right seat backrest fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08360-ENG125695-Right seat backrest fan 1-Overvoltage_treshold,16 V,10
IDE08360-ENG125696-Right seat backrest fan 1-Undervoltage_treshold,9 V,10
IDE08361-ENG125698-Right seat backrest fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08361-ENG125700-Right seat backrest fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08361-ENG125697-Right seat backrest fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08361-ENG125699-Right seat backrest fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08361-ENG125701-Right seat backrest fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08361-ENG134731-Right seat backrest fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08361-ENG125695-Right seat backrest fan 2-Overvoltage_treshold,16 V,10
IDE08361-ENG125696-Right seat backrest fan 2-Undervoltage_treshold,9 V,10
IDE08362-ENG125698-Right seat cushion fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08362-ENG125700-Right seat cushion fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08362-ENG125697-Right seat cushion fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08362-ENG125699-Right seat cushion fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08362-ENG125701-Right seat cushion fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08362-ENG134731-Right seat cushion fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08362-ENG125695-Right seat cushion fan 1-Overvoltage_treshold,16 V,10
IDE08362-ENG125696-Right seat cushion fan 1-Undervoltage_treshold,9 V,10
IDE08363-ENG125698-Right seat cushion fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08363-ENG125700-Right seat cushion fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08363-ENG125697-Right seat cushion fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08363-ENG125699-Right seat cushion fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08363-ENG125701-Right seat cushion fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08363-ENG134731-Right seat cushion fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08363-ENG125695-Right seat cushion fan 2-Overvoltage_treshold,16 V,10
IDE08363-ENG125696-Right seat cushion fan 2-Undervoltage_treshold,9 V,10
IDE10118-Fan speed reduction for telephony,activated ,1
IDE10278-Behavior of compressor during moderate outside temperatures,not active ,1
IDE11935-Personalization,activated ,1
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE13371-Interior humidity sensor: sensitivity,Medium ,1
IDE13676-Remote start function: rear window defogger,activated ,1
IDE13677-Remote start function: seat climate control takeover,activated ,1
IDE14087-Time until seat heat recovery within the maximum level,120 min,1
IDE15635-Number of interruptions permitted during compressor run-in,0 ,1
IDE80009-Analysis 9,not activated ,1
IDE80010-Analysis 10,not activated ,1
IDE80011-Analysis 11,not activated ,1
IDE80251-MAS09644-Head area heater-Vent temperature,0 ,1
IDE80251-MAS10293-Head area heater-Fan speed,0 ,1
MAS01651-Display and control unit: rear,not installed ,1
MAS06414-Temperature tuning,normal tuning ,1
MAS06415-Blower adjustment,normal tuning ,1
MAS06416-Blower display in auto operation,not activated ,1
MAS06417-Amplified overshoots heater operation,not activated ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
MAS19885-Remote start function: rear windshield heater transfer,activated ,1
MAS19886-Interior temperature sensor: after-run time,180 s,2
ENG263483-AC_evaporator_temperature_offset,-0.70 K,1
ENG276128-air_recirculation_deactivate_at_open_sunroof,not activated ,1
ENG263479-Auto-Toggle,not activated ,1
ENG263474-ENG263585-Development_Messages_Mode_Activation-General_Messages,0 ,18
ENG263474-ENG263519-Development_Messages_Mode_Activation-LIN_1_Messages,0 ,18
ENG263474-ENG263517-Development_Messages_Mode_Activation-LIN_2_Messages,0 ,18
ENG263474-ENG263537-Development_Messages_Mode_Activation-LIN_3_Messages,0 ,18
ENG263474-ENG263573-Development_Messages_Mode_Activation-LIN_4_Messages,0 ,18
ENG263474-ENG263548-Development_Messages_Mode_Activation-LIN_5_Messages,0 ,18
ENG263474-ENG263518-Development_Messages_Mode_Activation-LIN_6_Messages,0 ,18
ENG263474-ENG263550-Development_Messages_Mode_Activation-LIN_7_Messages,0 ,18
ENG263474-ENG263508-Development_Messages_Mode_Activation-LIN_8_Messages,0 ,18
ENG263440-Entwicklungs-ID für Entwicklungszwecke freischalten,0 ,2
ENG263490-manuel_air_recirculation_deacivate_AUTO_mode,not activated ,1
ENG263452-OnBoardDiagnose für Entwicklungszwecke freischalten,not active ,1
ENG125614-Reset_Blower_1_Backrest_Left,not active ,1
ENG125615-Reset_Blower_1_Backrest_Right,not active ,1
ENG125613-Reset_Blower_1_Cushion_Left,not active ,1
ENG125616-Reset_Blower_1_Cushion_Right,not active ,1
ENG125623-Reset_Blower_2_Backrest_Left,not active ,1
ENG125624-Reset_Blower_2_Backrest_Right,not active ,1
ENG125621-Reset_Blower_2_Cushion_Left,not active ,1
ENG125622-Reset_Blower_2_Cushion_Right,not active ,1
ENG263461-Schedule-Link_Switsh,according_coding_brand ,1
ENG263450-seat_dependent_climatisation,not activated ,1
ENG263443-seatheatin_function_switch,AUTO_seatheating_function ,1
ENG263458-winterfunction,not installed ,1
Elapsed Time: 00:23
adpmap-09-5WA-937-086-E_WV1ZZZSKZMX050719-20210914-1402.CSV
    SW:5WA-937-086-E   HW:5WA-937-086-E ---  Cent. Elect.
    Component:BCM 37W BOSCH 018 0159, Coding:
    EV_BCM37w,006001,EV_BCM37w_006_VW38.rod
    Tuesday,14,September,2021,14:02:47:34165
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode,not active ,3
IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode,not active ,3
IDE00001-ENG263594-Production mode-pa_klemme_15_pmode,not active ,3
IDE00001-ENG263561-Production mode-pa_klemme_50_pmode,not active ,3
IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode,not active ,3
IDE00001-ENG260220-Production mode-Remotestart Pmode,not active ,3
IDE02455-ENG116601-Light function "Coming/Leaving Home"-Coming Home Verbaustatus,automatic ,2
IDE02455-ENG260981-Light function "Coming/Leaving Home"-Darstellung Coming-home Verlauf,not active ,2
IDE02455-ENG261352-Light function "Coming/Leaving Home"-Darstellung Leaving-home Verlauf,not active ,2
IDE02455-ENG115657-Light function "Coming/Leaving Home"-Leaving-Home Verbausstatus,Enabled ,2
IDE02455-ENG115863-Light function "Coming/Leaving Home"-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,2
IDE02455-ENG116602-Light function "Coming/Leaving Home"-Menuesteuerung Coming Home Werkseinstellung,active ,2
IDE02455-ENG116606-Light function "Coming/Leaving Home"-Menuesteuerung Leaving-home Freischaltung per BAP,active ,2
IDE02711-ENG112304-Rear wiper-Heckwischer,1Draht_Heckwischer ,8
IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart,Heckwischerstopp bei Wiederstart und Erststart ,8
IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS,10 s,8
IDE02711-ENG261056-Rear wiper-Modus_Heckintervall,statische Intervallpausenzeit ,8
IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp,OFF ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,not active ,8
IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,7
IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel,active ,7
IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit,0 ms,7
IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit,0 ms,7
IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit,10000 ms,7
IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init,0 ,7
IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit,0 ms,7
IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit,2000 ms,7
IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam,Low beam ,4
IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam,High Beam ,4
IDE06507-Button in center console,LED installed ,2
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,255 min,2
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,not active ,9
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,9
IDE08786-ENG259537-Assistance light functions-Maskierung_Regenlichtmenü,not active ,9
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE09767-ENG133381-Position lamps-Bedingungen zur Parklichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG133380-Position lamps-Bedingungen zur Standlichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG137034-Position lamps-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,7
IDE09767-ENG115862-Position lamps-Lichtwarnungsverhalten,klemmenabhaengig ,7
IDE09767-ENG115859-Position lamps-Parklicht ueber LSS aktiviert,One-sided ,7
IDE09767-ENG126816-Position lamps-Standlicht aus,active ,7
IDE09767-ENG115829-Position lamps-Standlichtreduzierung mit beidseitigem Parklicht,active ,7
IDE09767-ENG133383-Position lamps-Standlicht-Verfügbarkeit,24 s,7
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,old ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,old ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,old ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,old ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,old ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,old ,6
IDE12302-SFT271909-Identification of sub-bus participant-left tail lamp 1,old ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,old ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,old ,6
IDE12302-SFT271950-Identification of sub-bus participant-Rear lid opener control module,New ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater,old ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater,old ,6
IDE12302-SFT272009-Identification of sub-bus participant-Steering Column Switch,old ,6
IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions,New ,6
IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side,old ,6
IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side,old ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,old ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,old ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,old ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,old ,6
IDE12302-SFT272107-Identification of sub-bus participant-Antenna for short-range communication,old ,6
IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions,old ,6
IDE12302-SFT272139-Identification of sub-bus participant-Antenna 2 for short-range communication,old ,6
IDE12302-SFT272142-Identification of sub-bus participant-left tail lamp 2,old ,6
IDE12302-SFT272143-Identification of sub-bus participant-Right rear tail lamp 1,old ,6
IDE12302-SFT272144-Identification of sub-bus participant-Right rear tail lamp 2,old ,6
IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start,old ,6
IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2,old ,6
IDE13391-ENG246968-BAP function status-CHo_LHo_Nachlauf,0 ms,16
IDE13391-ENG115656-BAP function status-Coming Home Leuchten,Low beam ,16
IDE13391-ENG116604-BAP function status-Coming-home Einschaltereignis,Ignition On ,16
IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung,600 lx,16
IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung,1200 lx,16
IDE13391-ENG116603-BAP function status-Menueeinstellung Cominghome,10 seconds ,16
IDE13391-ENG258918-BAP function status-Menueeinstellung Cominghome bei Tag,10 seconds ,16
IDE13391-ENG259258-BAP function status-Menueeinstellung Leaving-home bei Tag,10 seconds ,16
IDE13391-ENG116607-BAP function status-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,16
IDE13391-ENG258405-BAP function status-Tagfahrlicht mit CHO bei Tag in Stellung AUTO,not active ,16
IDE13391-ENG259717-BAP function status-Tagfahrlicht mit LHO bei Tag in Stellung AUTO,not active ,16
IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light,Yes ,4
IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light,Yes ,4
IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL,Yes ,4
IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.,Yes ,4
MAS05894-IDE13022-Engine run on-Function activation,not active ,4
MAS05894-MAS13391-Engine run on-Delay time timer,1500 ms,4
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 1E ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,3500 lx,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,Medium ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,3800 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,3500 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS09325-IDE13878-Daytime running lamps-Activation: daytime running lights,Daytime running lamps ,8
MAS09325-MAS09335-Daytime running lamps-Daytime running lights/parking light,not active ,8
MAS09325-MAS16273-Daytime running lamps-Speed warning active: rear fog lamps,0 km/h,8
MAS09325-MAS21314-Daytime running lamps-Daytime running indicator lamp,not active ,8
MAS09325-ENG142193-Daytime running lamps-Geschwindigkeitsabhaengiges TFL,0 km/h,8
MAS09325-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,8
MAS09325-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,8
MAS09325-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO,active ,8
MAS09325-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,8
MAS09325-ENG142192-Daytime running lamps-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,8
MAS09325-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,8
MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode,active ,8
MAS12382-MAS07029-Dynamic turn signal control-Crash flashing,not active ,8
MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing,not active ,8
MAS12382-MAS07033-Dynamic turn signal control-Panic flashing,not active ,8
MAS12382-MAS07034-Dynamic turn signal control-Theft flashing,active ,8
MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing,active ,8
MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing,active ,8
MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing,active ,8
MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant,active ,8
MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking,active ,8
MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking,active ,8
MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung,active ,8
MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay,50 ms,8
MAS12382-ENG261058-Dynamic turn signal control-IPA_RPA_Blinkbestätugung,active ,8
MAS12382-ENG260850-Dynamic turn signal control-IPA_RPA_blinken_links,active ,8
MAS12382-ENG258687-Dynamic turn signal control-IPA_RPA_blinken_rechts,active ,8
MAS12382-ENG260708-Dynamic turn signal control-Multikollisions_blinken,not active ,8
MAS12382-ENG122209-Dynamic turn signal control-Notwarn_blinken_NBA_Phase_2,active ,8
MAS12382-ENG122211-Dynamic turn signal control-Richtungs_blinken_links,active ,8
MAS12382-ENG122210-Dynamic turn signal control-Richtungs_blinken_rechts,active ,8
MAS12382-ENG260812-Dynamic turn signal control-SWA_blinken_links,active ,8
MAS12382-ENG260466-Dynamic turn signal control-SWA_blinken_rechts,active ,8
MAS12382-ENG122214-Dynamic turn signal control-Warnblinken_Zuendung_AUS,active ,8
MAS12382-ENG122213-Dynamic turn signal control-Warnblinken_Zuendung_EIN,active ,8
MAS14140-IDE15905-Flashing function-Travel Assist,not active ,4
MAS14140-ENG154601-Flashing function-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,4
MAS14140-ENG259090-Flashing function-Hupen_durch_Fahrerassistenz,not active ,4
MAS14140-ENG259296-Flashing function-Innenlicht_durch_Fahrerassistenz,not active ,4
MAS14140-ENG142029-Flashing function-Warnblinken_durch_Fahrerassistenz,not active ,4
MAS20279-WFS transponder gateway coding,Transponder GW in Kessy OK box ,4
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,0 ,9
ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max,100 ms,270
ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray,0 ,270
ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld,0 ,270
ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung,6.0 m,270
ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID,not active ,270
ENG253358-ENG289605-Anpassungen_Exterior_Light-p_vip30_Dimmung_SalR,00 ,270
ENG253358-ENG289606-Anpassungen_Exterior_Light-p_vip30_Dimmung_TSG,00 ,270
ENG253358-ENG289607-Anpassungen_Exterior_Light-p_vip30_Dimmzeit,0 ms,270
ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation,active ,270
ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente,not active ,270
ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout,0.00 s,270
ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled,not active ,270
ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken,not active ,270
ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp,H7 ,8
ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung,active ,8
ENG253146-ENG141987-Aussenlicht-SG-Architektur-Bremslicht_ist_auch_Blinklicht,No ,8
ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1,FF ,8
ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2,FF ,8
ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3,FF ,8
ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1,FF ,8
ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2,FF ,8
ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3,FF ,8
ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich,not active ,8
ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,8
ENG253146-ENG115831-Aussenlicht-SG-Architektur-Schlusslicht mit Bremslichtfunktion,not active ,8
ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,8
ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv,not activated ,4
ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv,not activated ,4
ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv,not activated ,4
ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv,activated ,4
ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv,activated ,4
ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv,not activated ,4
ENG253240-ENG263541-Automatisierte Abschaltungen-Abschalt_verzögerungs_zeit,60 s,8
ENG253240-ENG263514-Automatisierte Abschaltungen-Abschalt_wunsch_entprellung,1.0 s,8
ENG253240-ENG259987-Automatisierte Abschaltungen-Abschaltung nur in P,Alle Fahrstufen ,8
ENG253240-ENG277086-Automatisierte Abschaltungen-Dauer für Ausführung des Abschaltwunsch an SPN,2.0 s,8
ENG253240-ENG277087-Automatisierte Abschaltungen-Dauer Hinweistext Komfortabschaltung,10.0 s,8
ENG253240-ENG259819-Automatisierte Abschaltungen-Signalisierungsdauer Automatische Abschaltung erfolgt,5.0 s,8
ENG253240-ENG258392-Automatisierte Abschaltungen-Stillstandsdrehzahlschwelle Verbrennungsmotor,400 ,8
ENG253240-ENG258639-Automatisierte Abschaltungen-Verfügbarkeit Komfortabschaltung,available. ,8
ENG253240-ENG258110-Automatisierte Abschaltungen-Zündungsabschaltung über Energiemanagement,available. ,8
ENG253240-ENG126843-Automatisierte Abschaltungen-ZV verriegeln bei Klemme 15 Ein,active ,8
ENG253018-Clamp_Control-,Driver door ,1
ENG253018-ENG261243-Clamp_Control-Immobilizer_Active_Zas,activated ,1
ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA,100 ,40
ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG,200 ,40
ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS,10 ,40
ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU,1 ,40
ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP,100 ,40
ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA,100 ,40
ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK,150 ,40
ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN,10 ,40
ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS,10 ,40
ENG253229-ENG258467-Define_Const-Dimm2Bin,50 %,4
ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld,1.00 s,4
ENG253229-ENG253468-Define_Const-Gamma,2.0 ,4
ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung,Standlicht/Fahrlicht_u_RLS ,5
ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle,20 ,5
ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle,100 ,5
ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert,100 ,5
ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-,05 ,5
ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function,Function only allowed for terminal 15 off ,6
ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv,not activated ,6
ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv,not_activated ,6
ENG253216-ENG277085-DevCod_Automatische_Verriegelung-Automatische_FunktionBeiAnnaeherung_Entfernung_aktiv,activated ,6
ENG253028-DevCod_Bedienstellen,not activated ,1
ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function,not active ,6
ENG253195-ENG260227-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_aktiv,activated ,6
ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante,not activated ,6
ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv,activated ,6
ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv,activated ,6
ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart,activated ,6
ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv,activated ,6
ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante,not activated ,6
ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv,activated ,6
ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv,not activated ,6
ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren,activated ,6
ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv,activated ,6
ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv,not activated ,6
ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv,not activated ,6
ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv,not activated ,6
ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv,activated ,6
ENG253102-ENG261158-DevCod_Dienste_Byte2-ServiceKey_Verfahren,not activated ,6
ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close,not activated ,6
ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit,not activated ,6
ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut,activated ,6
ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible,not activated ,6
ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer,activated ,6
ENG253296-ENG258524-DevCod_Fahrzeugkonfiguration_Byte1-Heckklappe_ohne_Vorraste,not activated ,6
ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer,activated ,6
ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen,activated ,6
ENG253296-ENG259616-DevCod_Fahrzeugkonfiguration_Byte1-Reaktivierung_all_Tueren_VK2,not activated ,6
ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut,installed ,6
ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv,activated ,6
ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv,not activated ,6
ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv,not activated ,6
ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv,not activated ,6
ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv,not activated ,6
ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering alignment,Left ,6
ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer,activated ,6
ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen,not activated ,6
ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schließverhinderung,activated ,6
ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante,not activated ,6
ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv,activated ,6
ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv,activated ,6
ENG253170-ENG258576-DevCod_Nutzerkonfigurationen-Verriegelung_Rueckmeldung,not activated ,6
ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function,not activated ,7
ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-ENG260696-DevCod_Passive_EntryExit_Toggle-FunkkommunikationFuerPassiveEntryExit_Wiederholung_aktiv,not activated ,7
ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren,activated ,7
ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer,not activated ,7
ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren,not activated ,7
ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv,activated ,7
ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart,not activated ,6
ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe,activated ,6
ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebetür,activated ,6
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,not installed ,6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,not active ,6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,limited ,6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,not installed ,6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,not active ,6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,not installed ,6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6
ENG253244-Diebstahlschutz.Modulsoftware-,not active ,6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,not active ,6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,not active ,6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,10_ms ,6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,active ,6
ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv,According to function requirements ,4
ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv,not activated ,4
ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv,activated ,4
ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv,not activated ,4
ENG253365-ENG258571-Dienste-GenerischeOrtung_aktiv,not activated ,4
ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv,not activated ,4
ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv,not activated ,4
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,3.0 %,21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,160 %,21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,160 %,21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,160 %,21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,90.0 %,21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,10.0 %,21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,5.0 %,21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,1.0 s,21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,10 min,21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,12 min,21
ENG253301-Direkteinstiegstasten,installed ,2
ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese,0 ,15
ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel,0 %,15
ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev,0 %,15
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,0.0 s,15
ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans,0.0 s,15
ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans,0.0 s,15
ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv,not activated ,4
ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln,not activated ,4
ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP,not activated ,4
ENG253250-ENG130581-Fahrlichthinweis-Fahrlicht_Hinweis_mehrfach,active ,4
ENG253250-ENG126818-Fahrlichthinweis-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,4
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,not installed ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,not installed ,6
ENG141682-ENG260711-Front_wiper-cp_tipwischen_Kl_15_aus,OFF ,6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,keine Abtaupostition ,6
ENG141682-ENG260480-Front_wiper-Frontwischer_typ,Direct ,6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,active ,6
ENG141682-ENG258360-Front_wiper-pa_2_Motorsystem,not active ,6
ENG141682-ENG259770-Front_wiper-Regensensor aktiv Fahrfreigabe,not active ,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,active ,6
ENG141682-ENG260083-Front_wiper-Spannungsanforderung_konfig_Frontwischer,Sollspannungsanforderung 13.5 ,6
ENG141682-ENG259232-Front_wiper-tipwischen_Kl_15_aus,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,active ,6
ENG141682-ENG122991-Front_wiper-Wischer stop bei Motorstart,immer Wischerstopp ,6
ENG171911-ENG263558-Funk-FFB Batteriewarnung unterdruecken,not active ,4
ENG171911-ENG141957-Funk-Radio freq.,MQB37w: 434 MHz RdW + NAR (2-kanalig) ,4
ENG253064-Funktion Cockpittaster 1,not coded/not installed ,1
ENG253329-Funktion Cockpittaster 2,not coded/not installed ,1
ENG253030-Funktion Cockpittaster 3,not coded/not installed ,1
ENG253338-Funktion Cockpittaster 4,not coded/not installed ,1
ENG253288-Grundparameter SPN-,10000 ms,30
ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection,1000 ms,30
ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection,3000 ms,30
ENG253288-ENG126950-Grundparameter SPN-duration_ZAT_debounce,50 ms,30
ENG253288-ENG260569-Grundparameter SPN-Speed_ threshold_for_start_wish_plausibilisation,10 km/h,30
ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,30
ENG253288-ENG126954-Grundparameter SPN-time_to_ZAT_Open_circuit_detection,1000 ms,30
ENG253288-ENG126951-Grundparameter SPN-time_to_ZAT_Short_circuit_fault_detection,60 s,30
ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff,1000 ms,30
ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff,500 ms,30
ENG253288-ENG253449-Grundparameter SPN-time_ZAT_one_switch_actuation_detection,3000 ms,30
ENG253178-ENG126630-Heckdeckelsteuerung-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
ENG253178-ENG125652-Heckdeckelsteuerung-Servoheck Schlossansteuerung,Always ,8
ENG253178-ENG126838-Heckdeckelsteuerung-Softtouch-Betaetigung senden,Always ,8
ENG253178-ENG142011-Heckdeckelsteuerung-trunk_lid_conrol_unit,not installed ,8
ENG141645-ENG260128-HW_Verbau-Kontaktfritten,OFF ,8
ENG141645-ENG152427-HW_Verbau-Rear window defogger,not installed ,8
ENG253080-IAA Nutzermanagement,not installed ,1
ENG253173-ENG259645-IDGeber_Suche-Innenraumsuche_Kl15_aktiv,activated ,4
ENG253173-ENG261236-IDGeber_Suche-Innenraumsuche_Kl15_Triggerung_aktiv,activated ,4
ENG253173-ENG260685-IDGeber_Suche-Innenraumsuche_Kl15_TuerenKlappenFenster_auch_vor_erstem_Anfahren,activated ,4
ENG253173-ENG258195-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_aktiv,activated ,4
ENG253173-ENG260525-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_aktiv,activated ,4
ENG253173-ENG258977-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_NFZ_aktiv,activated ,4
ENG253173-ENG258651-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_TriggerVariante,activated ,4
ENG253173-ENG261351-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Tueren_aktiv,activated ,4
ENG253070-MAS14172-Intelligente Heckleuchte-Parametierung-Brake light larger area,not active ,23
ENG253070-MAS14173-Intelligente Heckleuchte-Parametierung-Brake light smaller area,not active ,23
ENG253070-ENG259403-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Aktivierung,0.00 m,23
ENG253070-ENG260952-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Deaktivierung,0.00 m,23
ENG253070-ENG259366-Intelligente Heckleuchte-Parametierung-p_adaptive_helligkeitsanpassung,not active ,23
ENG253070-ENG260454-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_dauer,10 ms,23
ENG253070-ENG260199-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_schwelle,-16.00000 m/s²,23
ENG253070-ENG260962-Intelligente Heckleuchte-Parametierung-p_CHO_LHO_statisch,not active ,23
ENG253070-ENG259731-Intelligente Heckleuchte-Parametierung-p_LH_Diag_LED_def_inaktiv,not active ,23
ENG253070-ENG259241-Intelligente Heckleuchte-Parametierung-p_LH_Diag_Status_def_inaktiv,not active ,23
ENG253070-ENG260043-Intelligente Heckleuchte-Parametierung-p_LH_zusatzschlussl_def_deaktiv,not active ,23
ENG253070-ENG260406-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_dunkel,4000 lx,23
ENG253070-ENG260839-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_hoch,50000 lx,23
ENG253070-ENG258451-Intelligente Heckleuchte-Parametierung-p_SHL_Anim_LTM_Auto,not active ,23
ENG253070-ENG259407-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15aus,0 ,23
ENG253070-ENG260457-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15ein,0 ,23
ENG253070-ENG259766-Intelligente Heckleuchte-Parametierung-p_SHL_dynamisch,not active ,23
ENG253070-ENG258437-Intelligente Heckleuchte-Parametierung-p_v_BRL_Aktivierung,20 km/h,23
ENG253070-ENG258439-Intelligente Heckleuchte-Parametierung-p_v_BRL_Deaktivierung,10 km/h,23
ENG253070-ENG261315-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_aus,60 km/h,23
ENG253070-ENG259510-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_ein,75 km/h,23
ENG253039-MAS06614-Intelligente Heckleuchte-Verbau-Variant,0 ,4
ENG253039-SFT271909-Intelligente Heckleuchte-Verbau-left tail lamp 1,not installed ,4
ENG253039-SFT272142-Intelligente Heckleuchte-Verbau-left tail lamp 2,not installed ,4
ENG253039-SFT272143-Intelligente Heckleuchte-Verbau-Right rear tail lamp 1,not installed ,4
ENG253039-SFT272144-Intelligente Heckleuchte-Verbau-Right rear tail lamp 2,not installed ,4
ENG253039-ENG173995-Intelligente Heckleuchte-Verbau-APS_installed,not installed ,4
ENG253039-ENG260486-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_NSL_iSBBR,not active ,4
ENG253039-ENG260357-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_RFL_iSBBR,not active ,4
ENG253265-ENG260602-Interior_light_default_values-Default_value_active_profile,08 ,96
ENG253265-ENG258400-Interior_light_default_values-Default_value_ambient_color,01 ,96
ENG253265-ENG259067-Interior_light_default_values-Default_value_ambient_color_fod,01 ,96
ENG253265-ENG258906-Interior_light_default_values-Default_value_brightness_profile_1,100 %,96
ENG253265-ENG260896-Interior_light_default_values-Default_value_brightness_profile_2,100 %,96
ENG253265-ENG259361-Interior_light_default_values-Default_value_brightness_profile_3,100 %,96
ENG253265-ENG259248-Interior_light_default_values-Default_value_brightness_profile_4,100 %,96
ENG253265-ENG259191-Interior_light_default_values-Default_value_brightness_profile_5,100 %,96
ENG253265-ENG259315-Interior_light_default_values-Default_value_brightness_profile_6,100 %,96
ENG253265-ENG260148-Interior_light_default_values-Default_value_brightness_profile_7,100 %,96
ENG253265-ENG259491-Interior_light_default_values-Default_value_brightness_profile_8,0 %,96
ENG253265-ENG258409-Interior_light_default_values-Default_value_brightness_set_1,50 %,96
ENG253265-ENG260620-Interior_light_default_values-Default_value_brightness_set_2,50 %,96
ENG253265-ENG259395-Interior_light_default_values-Default_value_brightness_set_3,50 %,96
ENG253265-ENG260548-Interior_light_default_values-Default_value_brightness_set_4,50 %,96
ENG253265-ENG261071-Interior_light_default_values-Default_value_brightness_set_5,50 %,96
ENG253265-ENG259147-Interior_light_default_values-Default_value_brightness_set_6,50 %,96
ENG253265-ENG259714-Interior_light_default_values-Default_value_brightness_set_7,50 %,96
ENG253265-ENG260350-Interior_light_default_values-Default_value_brightness_set_8,50 %,96
ENG253265-ENG260494-Interior_light_default_values-Default_value_contour_color,11 ,96
ENG253265-ENG259828-Interior_light_default_values-Default_value_contour_color_fod,11 ,96
ENG253265-ENG258473-Interior_light_default_values-Default_value_door_contact,active ,96
ENG253265-ENG261059-Interior_light_default_values-Default_value_functional_ambient_lighting,active ,96
ENG253265-ENG258185-Interior_light_default_values-Default_value_play_of_colors,00 ,96
ENG253265-ENG260118-Interior_light_default_values-Status_functional_ambient_lighting_function_0,00 ,96
ENG253265-ENG260033-Interior_light_default_values-Status_functional_ambient_lighting_function_1,01 ,96
ENG253265-ENG260515-Interior_light_default_values-Status_functional_ambient_lighting_function_10,01 ,96
ENG253265-ENG261126-Interior_light_default_values-Status_functional_ambient_lighting_function_11,01 ,96
ENG253265-ENG260982-Interior_light_default_values-Status_functional_ambient_lighting_function_12,01 ,96
ENG253265-ENG258716-Interior_light_default_values-Status_functional_ambient_lighting_function_13,01 ,96
ENG253265-ENG258745-Interior_light_default_values-Status_functional_ambient_lighting_function_14,01 ,96
ENG253265-ENG258773-Interior_light_default_values-Status_functional_ambient_lighting_function_15,01 ,96
ENG253265-ENG261349-Interior_light_default_values-Status_functional_ambient_lighting_function_16,01 ,96
ENG253265-ENG258101-Interior_light_default_values-Status_functional_ambient_lighting_function_17,01 ,96
ENG253265-ENG258275-Interior_light_default_values-Status_functional_ambient_lighting_function_18,01 ,96
ENG253265-ENG258192-Interior_light_default_values-Status_functional_ambient_lighting_function_19,01 ,96
ENG253265-ENG260897-Interior_light_default_values-Status_functional_ambient_lighting_function_2,01 ,96
ENG253265-ENG260194-Interior_light_default_values-Status_functional_ambient_lighting_function_20,01 ,96
ENG253265-ENG258332-Interior_light_default_values-Status_functional_ambient_lighting_function_21,01 ,96
ENG253265-ENG259651-Interior_light_default_values-Status_functional_ambient_lighting_function_22,01 ,96
ENG253265-ENG261294-Interior_light_default_values-Status_functional_ambient_lighting_function_23,01 ,96
ENG253265-ENG259414-Interior_light_default_values-Status_functional_ambient_lighting_function_24,01 ,96
ENG253265-ENG258573-Interior_light_default_values-Status_functional_ambient_lighting_function_25,01 ,96
ENG253265-ENG258495-Interior_light_default_values-Status_functional_ambient_lighting_function_26,01 ,96
ENG253265-ENG260792-Interior_light_default_values-Status_functional_ambient_lighting_function_27,01 ,96
ENG253265-ENG261350-Interior_light_default_values-Status_functional_ambient_lighting_function_28,01 ,96
ENG253265-ENG259636-Interior_light_default_values-Status_functional_ambient_lighting_function_29,01 ,96
ENG253265-ENG259360-Interior_light_default_values-Status_functional_ambient_lighting_function_3,01 ,96
ENG253265-ENG260163-Interior_light_default_values-Status_functional_ambient_lighting_function_30,01 ,96
ENG253265-ENG260013-Interior_light_default_values-Status_functional_ambient_lighting_function_31,01 ,96
ENG253265-ENG260816-Interior_light_default_values-Status_functional_ambient_lighting_function_32,01 ,96
ENG253265-ENG258823-Interior_light_default_values-Status_functional_ambient_lighting_function_33,01 ,96
ENG253265-ENG258362-Interior_light_default_values-Status_functional_ambient_lighting_function_34,01 ,96
ENG253265-ENG258252-Interior_light_default_values-Status_functional_ambient_lighting_function_35,01 ,96
ENG253265-ENG261196-Interior_light_default_values-Status_functional_ambient_lighting_function_36,01 ,96
ENG253265-ENG260391-Interior_light_default_values-Status_functional_ambient_lighting_function_37,01 ,96
ENG253265-ENG259418-Interior_light_default_values-Status_functional_ambient_lighting_function_38,01 ,96
ENG253265-ENG259523-Interior_light_default_values-Status_functional_ambient_lighting_function_39,01 ,96
ENG253265-ENG258165-Interior_light_default_values-Status_functional_ambient_lighting_function_4,00 ,96
ENG253265-ENG259088-Interior_light_default_values-Status_functional_ambient_lighting_function_40,01 ,96
ENG253265-ENG258142-Interior_light_default_values-Status_functional_ambient_lighting_function_41,01 ,96
ENG253265-ENG259166-Interior_light_default_values-Status_functional_ambient_lighting_function_42,01 ,96
ENG253265-ENG258220-Interior_light_default_values-Status_functional_ambient_lighting_function_43,01 ,96
ENG253265-ENG259935-Interior_light_default_values-Status_functional_ambient_lighting_function_44,01 ,96
ENG253265-ENG260916-Interior_light_default_values-Status_functional_ambient_lighting_function_45,01 ,96
ENG253265-ENG258884-Interior_light_default_values-Status_functional_ambient_lighting_function_46,01 ,96
ENG253265-ENG260167-Interior_light_default_values-Status_functional_ambient_lighting_function_47,01 ,96
ENG253265-ENG259709-Interior_light_default_values-Status_functional_ambient_lighting_function_48,01 ,96
ENG253265-ENG258367-Interior_light_default_values-Status_functional_ambient_lighting_function_49,01 ,96
ENG253265-ENG261268-Interior_light_default_values-Status_functional_ambient_lighting_function_5,01 ,96
ENG253265-ENG260926-Interior_light_default_values-Status_functional_ambient_lighting_function_50,01 ,96
ENG253265-ENG258790-Interior_light_default_values-Status_functional_ambient_lighting_function_51,01 ,96
ENG253265-ENG259976-Interior_light_default_values-Status_functional_ambient_lighting_function_52,01 ,96
ENG253265-ENG260404-Interior_light_default_values-Status_functional_ambient_lighting_function_53,01 ,96
ENG253265-ENG258371-Interior_light_default_values-Status_functional_ambient_lighting_function_54,01 ,96
ENG253265-ENG259284-Interior_light_default_values-Status_functional_ambient_lighting_function_55,01 ,96
ENG253265-ENG260285-Interior_light_default_values-Status_functional_ambient_lighting_function_56,01 ,96
ENG253265-ENG258600-Interior_light_default_values-Status_functional_ambient_lighting_function_57,01 ,96
ENG253265-ENG260626-Interior_light_default_values-Status_functional_ambient_lighting_function_58,01 ,96
ENG253265-ENG260773-Interior_light_default_values-Status_functional_ambient_lighting_function_59,01 ,96
ENG253265-ENG259316-Interior_light_default_values-Status_functional_ambient_lighting_function_6,00 ,96
ENG253265-ENG261109-Interior_light_default_values-Status_functional_ambient_lighting_function_60,01 ,96
ENG253265-ENG258106-Interior_light_default_values-Status_functional_ambient_lighting_function_61,01 ,96
ENG253265-ENG260286-Interior_light_default_values-Status_functional_ambient_lighting_function_62,01 ,96
ENG253265-ENG260233-Interior_light_default_values-Status_functional_ambient_lighting_function_63,01 ,96
ENG253265-ENG260974-Interior_light_default_values-Status_functional_ambient_lighting_function_7,00 ,96
ENG253265-ENG259492-Interior_light_default_values-Status_functional_ambient_lighting_function_8,01 ,96
ENG253265-ENG260578-Interior_light_default_values-Status_functional_ambient_lighting_function_9,01 ,96
ENG253069-ENG259642-Interior_light_external_events-External_event_activation_69,not active ,16
ENG253069-ENG259453-Interior_light_external_events-External_event_activation_of_ready_to_drive_visualization,not active ,16
ENG253069-ENG258384-Interior_light_external_events-External_event_ready_to_drive_visualization_with_sound,not active ,16
ENG253344-ENG253469-Interior_light_functions_1_to_70-Light_function_1,not active ,9
ENG253344-ENG260993-Interior_light_functions_1_to_70-Light_function_10,not active ,9
ENG253344-ENG261210-Interior_light_functions_1_to_70-Light_function_11,not active ,9
ENG253344-ENG259885-Interior_light_functions_1_to_70-Light_function_12,not active ,9
ENG253344-ENG258428-Interior_light_functions_1_to_70-Light_function_13,not active ,9
ENG253344-ENG260468-Interior_light_functions_1_to_70-Light_function_14,not active ,9
ENG253344-ENG259544-Interior_light_functions_1_to_70-Light_function_15,not active ,9
ENG253344-ENG261129-Interior_light_functions_1_to_70-Light_function_16,not active ,9
ENG253344-ENG259775-Interior_light_functions_1_to_70-Light_function_17,not active ,9
ENG253344-ENG259446-Interior_light_functions_1_to_70-Light_function_18,not active ,9
ENG253344-ENG259229-Interior_light_functions_1_to_70-Light_function_19,not active ,9
ENG253344-ENG253470-Interior_light_functions_1_to_70-Light_function_2,active ,9
ENG253344-ENG259487-Interior_light_functions_1_to_70-Light_function_20,not active ,9
ENG253344-ENG259385-Interior_light_functions_1_to_70-Light_function_21,not active ,9
ENG253344-ENG259785-Interior_light_functions_1_to_70-Light_function_22,not active ,9
ENG253344-ENG258581-Interior_light_functions_1_to_70-Light_function_23,not active ,9
ENG253344-ENG260265-Interior_light_functions_1_to_70-Light_function_24,not active ,9
ENG253344-ENG261256-Interior_light_functions_1_to_70-Light_function_25,not active ,9
ENG253344-ENG260361-Interior_light_functions_1_to_70-Light_function_26,not active ,9
ENG253344-ENG259100-Interior_light_functions_1_to_70-Light_function_27,not active ,9
ENG253344-ENG260930-Interior_light_functions_1_to_70-Light_function_28,not active ,9
ENG253344-ENG259955-Interior_light_functions_1_to_70-Light_function_29,not active ,9
ENG253344-ENG253471-Interior_light_functions_1_to_70-Light_function_3,not active ,9
ENG253344-ENG259370-Interior_light_functions_1_to_70-Light_function_30,active ,9
ENG253344-ENG261130-Interior_light_functions_1_to_70-Light_function_31,active ,9
ENG253344-ENG258748-Interior_light_functions_1_to_70-Light_function_32,not active ,9
ENG253344-ENG260955-Interior_light_functions_1_to_70-Light_function_33,not active ,9
ENG253344-ENG259496-Interior_light_functions_1_to_70-Light_function_34,not active ,9
ENG253344-ENG258588-Interior_light_functions_1_to_70-Light_function_35,not active ,9
ENG253344-ENG259600-Interior_light_functions_1_to_70-Light_function_36,not active ,9
ENG253344-ENG259095-Interior_light_functions_1_to_70-Light_function_37,not active ,9
ENG253344-ENG260346-Interior_light_functions_1_to_70-Light_function_38,not active ,9
ENG253344-ENG259274-Interior_light_functions_1_to_70-Light_function_39,not active ,9
ENG253344-ENG260499-Interior_light_functions_1_to_70-Light_function_4,not active ,9
ENG253344-ENG258529-Interior_light_functions_1_to_70-Light_function_40,not active ,9
ENG253344-ENG258505-Interior_light_functions_1_to_70-Light_function_41,not active ,9
ENG253344-ENG258603-Interior_light_functions_1_to_70-Light_function_42,not active ,9
ENG253344-ENG259158-Interior_light_functions_1_to_70-Light_function_43,not active ,9
ENG253344-ENG260244-Interior_light_functions_1_to_70-Light_function_44,not active ,9
ENG253344-ENG260634-Interior_light_functions_1_to_70-Light_function_45,not active ,9
ENG253344-ENG258174-Interior_light_functions_1_to_70-Light_function_46,not active ,9
ENG253344-ENG260984-Interior_light_functions_1_to_70-Light_function_47,not active ,9
ENG253344-ENG258949-Interior_light_functions_1_to_70-Light_function_48,not active ,9
ENG253344-ENG259994-Interior_light_functions_1_to_70-Light_function_49,not active ,9
ENG253344-ENG258326-Interior_light_functions_1_to_70-Light_function_5,not active ,9
ENG253344-ENG259724-Interior_light_functions_1_to_70-Light_function_50,not active ,9
ENG253344-ENG259989-Interior_light_functions_1_to_70-Light_function_51,not active ,9
ENG253344-ENG259580-Interior_light_functions_1_to_70-Light_function_52,not active ,9
ENG253344-ENG258381-Interior_light_functions_1_to_70-Light_function_53,not active ,9
ENG253344-ENG259438-Interior_light_functions_1_to_70-Light_function_54,not active ,9
ENG253344-ENG261290-Interior_light_functions_1_to_70-Light_function_55,not active ,9
ENG253344-ENG259516-Interior_light_functions_1_to_70-Light_function_56,not active ,9
ENG253344-ENG261086-Interior_light_functions_1_to_70-Light_function_57,not active ,9
ENG253344-ENG260704-Interior_light_functions_1_to_70-Light_function_58,not active ,9
ENG253344-ENG258566-Interior_light_functions_1_to_70-Light_function_59,not active ,9
ENG253344-ENG261278-Interior_light_functions_1_to_70-Light_function_6,not active ,9
ENG253344-ENG260248-Interior_light_functions_1_to_70-Light_function_60,not active ,9
ENG253344-ENG260845-Interior_light_functions_1_to_70-Light_function_61,not active ,9
ENG253344-ENG258817-Interior_light_functions_1_to_70-Light_function_62,not active ,9
ENG253344-ENG260488-Interior_light_functions_1_to_70-Light_function_63,not active ,9
ENG253344-ENG259000-Interior_light_functions_1_to_70-Light_function_64,not active ,9
ENG253344-ENG260181-Interior_light_functions_1_to_70-Light_function_65,not active ,9
ENG253344-ENG259146-Interior_light_functions_1_to_70-Light_function_66,not active ,9
ENG253344-ENG258530-Interior_light_functions_1_to_70-Light_function_67,not active ,9
ENG253344-ENG261172-Interior_light_functions_1_to_70-Light_function_68,not active ,9
ENG253344-ENG258454-Interior_light_functions_1_to_70-Light_function_69,not active ,9
ENG253344-ENG259680-Interior_light_functions_1_to_70-Light_function_7,not active ,9
ENG253344-ENG260506-Interior_light_functions_1_to_70-Light_function_70,not active ,9
ENG253344-ENG258912-Interior_light_functions_1_to_70-Light_function_8,not active ,9
ENG253344-ENG258633-Interior_light_functions_1_to_70-Light_function_9,not active ,9
ENG253391-ENG258190-Interior_light_general_settings-Automatic_ambiance_lighting_with_fpa,not active ,14
ENG253391-ENG259555-Interior_light_general_settings-Crash_color,01 ,14
ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light,not active ,14
ENG253391-ENG258939-Interior_light_general_settings-Door_warning_light_brightness,100 %,14
ENG253391-ENG258181-Interior_light_general_settings-Door_warning_light_color,01 ,14
ENG253391-ENG259296-Interior_light_general_settings-Innenlicht_durch_Fahrerassistenz,active ,14
ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk,not active ,14
ENG253391-ENG261275-Interior_light_general_settings-Interior_light_alternative_clamp_control_entry,not active ,14
ENG253391-ENG260888-Interior_light_general_settings-Interior_light_alternative_clamp_control_exit,not active ,14
ENG253391-ENG258268-Interior_light_general_settings-interior_light_color,01 ,14
ENG253391-ENG260936-Interior_light_general_settings-Interior_light_dependency_on_key_or_belt_buckle,02 ,14
ENG253391-ENG259666-Interior_light_general_settings-Interior_light_function,active ,14
ENG253391-ENG260600-Interior_light_general_settings-Interior_light_trunk_light,active ,14
ENG253391-ENG259259-Interior_light_general_settings-Kl30alm,active ,14
ENG253391-ENG259746-Interior_light_general_settings-Kl30G_activation_by_opening_trunk,active ,14
ENG253391-ENG260275-Interior_light_general_settings-Kl30G_wake_up_behaviour,not active ,14
ENG253391-ENG259384-Interior_light_general_settings-Kl30G_without_pwm,not active ,14
ENG253391-ENG258730-Interior_light_general_settings-Kl58_color,01 ,14
ENG253391-ENG260492-Interior_light_general_settings-Mapping_fpa_profile_1,1 ,14
ENG253391-ENG261042-Interior_light_general_settings-Mapping_fpa_profile_2,5 ,14
ENG253391-ENG258453-Interior_light_general_settings-Mapping_fpa_profile_3,3 ,14
ENG253391-ENG260820-Interior_light_general_settings-Mapping_fpa_profile_4,4 ,14
ENG253391-ENG258889-Interior_light_general_settings-Mapping_fpa_profile_5,2 ,14
ENG253391-ENG260732-Interior_light_general_settings-Mapping_fpa_profile_6,7 ,14
ENG253391-ENG260062-Interior_light_general_settings-Mfg_interior_light_color,01 ,14
ENG253391-ENG260638-Interior_light_general_settings-Pso_active_participant_ambient_lighting_interior_enabled,active ,14
ENG253391-ENG258979-Interior_light_general_settings-roof_console_installed,active ,14
ENG253391-ENG258685-Interior_light_general_settings-Trunk_light_brightness,100 %,14
ENG253391-ENG260452-Interior_light_general_settings-Trunk_light_color,01 ,14
ENG253223-ENG260423-Interior_light_hmi_config-Bytes 25-60,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
ENG253223-ENG259513-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_1,64 ,100
ENG253223-ENG260783-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_2,64 ,100
ENG253223-ENG260290-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_3,64 ,100
ENG253223-ENG258130-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_4,64 ,100
ENG253223-ENG259034-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_5,64 ,100
ENG253223-ENG259728-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_6,64 ,100
ENG253223-ENG258649-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_7,64 ,100
ENG253223-ENG258756-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_8,64 ,100
ENG253223-ENG260831-Interior_light_hmi_config-Hmi_ambient_color,not active ,100
ENG253223-ENG258324-Interior_light_hmi_config-Hmi_ambient_colors_bitmask,00 00 00 00 ,100
ENG253223-ENG258789-Interior_light_hmi_config-Hmi_ambient_colors_fod_bitmask,00 00 00 00 ,100
ENG253223-ENG260180-Interior_light_hmi_config-Hmi_ambient_profile_1,not active ,100
ENG253223-ENG258163-Interior_light_hmi_config-Hmi_ambient_profile_2,not active ,100
ENG253223-ENG258800-Interior_light_hmi_config-Hmi_ambient_profile_3,not active ,100
ENG253223-ENG258761-Interior_light_hmi_config-Hmi_ambient_profile_4,not active ,100
ENG253223-ENG259948-Interior_light_hmi_config-Hmi_ambient_profile_5,not active ,100
ENG253223-ENG261117-Interior_light_hmi_config-Hmi_ambient_profile_6,not active ,100
ENG253223-ENG258601-Interior_light_hmi_config-Hmi_ambient_profile_7,not active ,100
ENG253223-ENG259615-Interior_light_hmi_config-Hmi_ambient_profile_8,not active ,100
ENG253223-ENG258875-Interior_light_hmi_config-Hmi_config_fixed_color_play_of_colors,00 ,100
ENG253223-ENG260154-Interior_light_hmi_config-Hmi_config_hmi_preview,not active ,100
ENG253223-ENG258806-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_1,00 ,100
ENG253223-ENG260370-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_2,00 ,100
ENG253223-ENG261327-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_3,00 ,100
ENG253223-ENG260102-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_4,00 ,100
ENG253223-ENG259550-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_5,00 ,100
ENG253223-ENG258870-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_6,00 ,100
ENG253223-ENG260001-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_7,00 ,100
ENG253223-ENG259068-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_8,00 ,100
ENG253223-ENG259772-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_1,00 ,100
ENG253223-ENG259687-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_2,00 ,100
ENG253223-ENG259129-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_3,00 ,100
ENG253223-ENG260699-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_4,00 ,100
ENG253223-ENG259317-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_5,00 ,100
ENG253223-ENG258480-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_6,00 ,100
ENG253223-ENG261090-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_7,00 ,100
ENG253223-ENG258664-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_8,00 ,100
ENG253223-ENG261119-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_1,00 ,100
ENG253223-ENG259685-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_2,00 ,100
ENG253223-ENG260690-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_3,00 ,100
ENG253223-ENG259252-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_4,00 ,100
ENG253223-ENG258904-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_5,00 ,100
ENG253223-ENG260909-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_6,00 ,100
ENG253223-ENG258840-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_7,00 ,100
ENG253223-ENG260828-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_8,00 ,100
ENG253223-ENG259535-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_1,00 ,100
ENG253223-ENG259249-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_2,00 ,100
ENG253223-ENG258349-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_3,00 ,100
ENG253223-ENG260458-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_4,00 ,100
ENG253223-ENG258285-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_5,00 ,100
ENG253223-ENG258936-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_6,00 ,100
ENG253223-ENG260143-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_7,00 ,100
ENG253223-ENG259986-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_8,00 ,100
ENG253223-ENG260694-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_1,00 ,100
ENG253223-ENG259604-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_2,00 ,100
ENG253223-ENG258410-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_3,00 ,100
ENG253223-ENG261012-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_4,00 ,100
ENG253223-ENG259932-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_5,00 ,100
ENG253223-ENG260104-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_6,00 ,100
ENG253223-ENG260125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_7,00 ,100
ENG253223-ENG259125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_8,00 ,100
ENG253223-ENG260419-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_1,00 ,100
ENG253223-ENG261132-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_2,00 ,100
ENG253223-ENG260056-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_3,00 ,100
ENG253223-ENG259330-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_4,00 ,100
ENG253223-ENG258990-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_5,00 ,100
ENG253223-ENG259936-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_6,00 ,100
ENG253223-ENG258422-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_7,00 ,100
ENG253223-ENG258463-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_8,00 ,100
ENG253223-ENG258418-Interior_light_hmi_config-Hmi_config_timer_hmi_preview,0 s,100
ENG253223-ENG259957-Interior_light_hmi_config-Hmi_contour_color,not active ,100
ENG253223-ENG259365-Interior_light_hmi_config-Hmi_contour_colors_bitmask,00 00 00 00 ,100
ENG253223-ENG259211-Interior_light_hmi_config-Hmi_contour_colors_fod_bitmask,00 00 00 00 ,100
ENG253223-ENG260051-Interior_light_hmi_config-Hmi_Display_Color_light_function,02 ,100
ENG253223-ENG258352-Interior_light_hmi_config-Hmi_door_contact,not active ,100
ENG253223-ENG258250-Interior_light_hmi_config-Hmi_fpa_dependency,not active ,100
ENG253223-ENG260229-Interior_light_hmi_config-Hmi_functional_ambiance_lighting_list,not active ,100
ENG253223-ENG258930-Interior_light_hmi_config-Hmi_functional_ambience_lighting,not active ,100
ENG253223-ENG258483-Interior_light_hmi_config-Hmi_menu_ambient_lighting,not active ,100
ENG253223-ENG261116-Interior_light_hmi_config-Hmi_play_of_colors,not active ,100
ENG253223-ENG260969-Interior_light_hmi_config-Hmi_setup_set_1,FF ,100
ENG253223-ENG260367-Interior_light_hmi_config-Hmi_setup_set_2,FF ,100
ENG253223-ENG259030-Interior_light_hmi_config-Hmi_setup_set_3,FF ,100
ENG253223-ENG260913-Interior_light_hmi_config-Hmi_setup_set_4,FF ,100
ENG253223-ENG258666-Interior_light_hmi_config-Hmi_setup_set_5,FF ,100
ENG253223-ENG259988-Interior_light_hmi_config-Hmi_setup_set_6,FF ,100
ENG253223-ENG258907-Interior_light_hmi_config-Hmi_setup_set_7,FF ,100
ENG253223-ENG258492-Interior_light_hmi_config-Hmi_setup_set_8,FF ,100
ENG253223-ENG259126-Interior_light_hmi_config-roof_console_door_contact,active ,100
ENG253355-Interior_light_interface_function,No_voltage_requirement ,1
ENG253312-ENG259098-Interior_light_lin_slaves_config-Failure_location_lin10_slave_1,01 ,51
ENG253312-ENG261000-Interior_light_lin_slaves_config-Failure_location_lin10_slave_10,01 ,51
ENG253312-ENG260844-Interior_light_lin_slaves_config-Failure_location_lin10_slave_11,45 ,51
ENG253312-ENG260815-Interior_light_lin_slaves_config-Failure_location_lin10_slave_12,47 ,51
ENG253312-ENG260672-Interior_light_lin_slaves_config-Failure_location_lin10_slave_13,01 ,51
ENG253312-ENG260204-Interior_light_lin_slaves_config-Failure_location_lin10_slave_14,01 ,51
ENG253312-ENG258398-Interior_light_lin_slaves_config-Failure_location_lin10_slave_15,01 ,51
ENG253312-ENG258994-Interior_light_lin_slaves_config-Failure_location_lin10_slave_2,01 ,51
ENG253312-ENG258883-Interior_light_lin_slaves_config-Failure_location_lin10_slave_3,10 ,51
ENG253312-ENG259653-Interior_light_lin_slaves_config-Failure_location_lin10_slave_4,11 ,51
ENG253312-ENG261303-Interior_light_lin_slaves_config-Failure_location_lin10_slave_5,01 ,51
ENG253312-ENG259057-Interior_light_lin_slaves_config-Failure_location_lin10_slave_6,01 ,51
ENG253312-ENG260484-Interior_light_lin_slaves_config-Failure_location_lin10_slave_7,01 ,51
ENG253312-ENG260881-Interior_light_lin_slaves_config-Failure_location_lin10_slave_8,22 ,51
ENG253312-ENG260091-Interior_light_lin_slaves_config-Failure_location_lin10_slave_9,23 ,51
ENG253312-ENG259183-Interior_light_lin_slaves_config-Failure_location_lin5_slave_1,01 ,51
ENG253312-ENG258660-Interior_light_lin_slaves_config-Failure_location_lin5_slave_10,01 ,51
ENG253312-ENG260169-Interior_light_lin_slaves_config-Failure_location_lin5_slave_11,44 ,51
ENG253312-ENG261201-Interior_light_lin_slaves_config-Failure_location_lin5_slave_12,46 ,51
ENG253312-ENG259253-Interior_light_lin_slaves_config-Failure_location_lin5_slave_13,01 ,51
ENG253312-ENG259633-Interior_light_lin_slaves_config-Failure_location_lin5_slave_14,01 ,51
ENG253312-ENG258313-Interior_light_lin_slaves_config-Failure_location_lin5_slave_15,01 ,51
ENG253312-ENG260266-Interior_light_lin_slaves_config-Failure_location_lin5_slave_2,01 ,51
ENG253312-ENG259102-Interior_light_lin_slaves_config-Failure_location_lin5_slave_3,07 ,51
ENG253312-ENG259003-Interior_light_lin_slaves_config-Failure_location_lin5_slave_4,08 ,51
ENG253312-ENG260961-Interior_light_lin_slaves_config-Failure_location_lin5_slave_5,01 ,51
ENG253312-ENG259969-Interior_light_lin_slaves_config-Failure_location_lin5_slave_6,01 ,51
ENG253312-ENG258881-Interior_light_lin_slaves_config-Failure_location_lin5_slave_7,01 ,51
ENG253312-ENG260157-Interior_light_lin_slaves_config-Failure_location_lin5_slave_8,19 ,51
ENG253312-ENG258637-Interior_light_lin_slaves_config-Failure_location_lin5_slave_9,1A ,51
ENG253312-ENG259033-Interior_light_lin_slaves_config-Failure_location_lin9_slave_1,01 ,51
ENG253312-ENG260297-Interior_light_lin_slaves_config-Failure_location_lin9_slave_10,01 ,51
ENG253312-ENG259053-Interior_light_lin_slaves_config-Failure_location_lin9_slave_11,01 ,51
ENG253312-ENG260470-Interior_light_lin_slaves_config-Failure_location_lin9_slave_12,01 ,51
ENG253312-ENG259540-Interior_light_lin_slaves_config-Failure_location_lin9_slave_13,01 ,51
ENG253312-ENG258446-Interior_light_lin_slaves_config-Failure_location_lin9_slave_14,01 ,51
ENG253312-ENG260819-Interior_light_lin_slaves_config-Failure_location_lin9_slave_15,01 ,51
ENG253312-ENG260376-Interior_light_lin_slaves_config-Failure_location_lin9_slave_2,2A ,51
ENG253312-ENG260700-Interior_light_lin_slaves_config-Failure_location_lin9_slave_3,2B ,51
ENG253312-ENG259312-Interior_light_lin_slaves_config-Failure_location_lin9_slave_4,01 ,51
ENG253312-ENG260870-Interior_light_lin_slaves_config-Failure_location_lin9_slave_5,01 ,51
ENG253312-ENG259978-Interior_light_lin_slaves_config-Failure_location_lin9_slave_6,32 ,51
ENG253312-ENG260092-Interior_light_lin_slaves_config-Failure_location_lin9_slave_7,01 ,51
ENG253312-ENG260166-Interior_light_lin_slaves_config-Failure_location_lin9_slave_8,01 ,51
ENG253312-ENG259286-Interior_light_lin_slaves_config-Failure_location_lin9_slave_9,01 ,51
ENG253312-ENG261097-Interior_light_lin_slaves_config-Lin10_slave_1,not installed ,51
ENG253312-ENG261248-Interior_light_lin_slaves_config-Lin10_slave_10,not installed ,51
ENG253312-ENG260250-Interior_light_lin_slaves_config-Lin10_slave_11,not installed ,51
ENG253312-ENG260843-Interior_light_lin_slaves_config-Lin10_slave_12,not installed ,51
ENG253312-ENG258140-Interior_light_lin_slaves_config-Lin10_slave_13,not installed ,51
ENG253312-ENG260746-Interior_light_lin_slaves_config-Lin10_slave_14,not installed ,51
ENG253312-ENG259479-Interior_light_lin_slaves_config-Lin10_slave_15,not installed ,51
ENG253312-ENG259817-Interior_light_lin_slaves_config-Lin10_slave_2,not installed ,51
ENG253312-ENG258374-Interior_light_lin_slaves_config-Lin10_slave_3,not installed ,51
ENG253312-ENG259748-Interior_light_lin_slaves_config-Lin10_slave_4,not installed ,51
ENG253312-ENG261167-Interior_light_lin_slaves_config-Lin10_slave_5,not installed ,51
ENG253312-ENG260490-Interior_light_lin_slaves_config-Lin10_slave_6,not installed ,51
ENG253312-ENG260905-Interior_light_lin_slaves_config-Lin10_slave_7,not installed ,51
ENG253312-ENG259342-Interior_light_lin_slaves_config-Lin10_slave_8,not installed ,51
ENG253312-ENG260924-Interior_light_lin_slaves_config-Lin10_slave_9,not installed ,51
ENG253312-ENG260567-Interior_light_lin_slaves_config-Lin5_slave_1,not installed ,51
ENG253312-ENG260991-Interior_light_lin_slaves_config-Lin5_slave_10,not installed ,51
ENG253312-ENG260074-Interior_light_lin_slaves_config-Lin5_slave_11,not installed ,51
ENG253312-ENG260190-Interior_light_lin_slaves_config-Lin5_slave_12,not installed ,51
ENG253312-ENG258636-Interior_light_lin_slaves_config-Lin5_slave_13,not installed ,51
ENG253312-ENG261344-Interior_light_lin_slaves_config-Lin5_slave_14,not installed ,51
ENG253312-ENG259457-Interior_light_lin_slaves_config-Lin5_slave_15,not installed ,51
ENG253312-ENG258488-Interior_light_lin_slaves_config-Lin5_slave_2,not installed ,51
ENG253312-ENG259073-Interior_light_lin_slaves_config-Lin5_slave_3,not installed ,51
ENG253312-ENG258217-Interior_light_lin_slaves_config-Lin5_slave_4,not installed ,51
ENG253312-ENG259044-Interior_light_lin_slaves_config-Lin5_slave_5,not installed ,51
ENG253312-ENG258512-Interior_light_lin_slaves_config-Lin5_slave_6,not installed ,51
ENG253312-ENG261216-Interior_light_lin_slaves_config-Lin5_slave_7,not installed ,51
ENG253312-ENG259326-Interior_light_lin_slaves_config-Lin5_slave_8,not installed ,51
ENG253312-ENG258818-Interior_light_lin_slaves_config-Lin5_slave_9,not installed ,51
ENG253312-ENG261286-Interior_light_lin_slaves_config-Lin9_slave_1,not installed ,51
ENG253312-ENG260287-Interior_light_lin_slaves_config-Lin9_slave_10,not installed ,51
ENG253312-ENG259769-Interior_light_lin_slaves_config-Lin9_slave_11,not installed ,51
ENG253312-ENG258599-Interior_light_lin_slaves_config-Lin9_slave_12,not installed ,51
ENG253312-ENG261101-Interior_light_lin_slaves_config-Lin9_slave_13,not installed ,51
ENG253312-ENG258193-Interior_light_lin_slaves_config-Lin9_slave_14,not installed ,51
ENG253312-ENG260653-Interior_light_lin_slaves_config-Lin9_slave_15,not installed ,51
ENG253312-ENG258200-Interior_light_lin_slaves_config-Lin9_slave_2,not installed ,51
ENG253312-ENG260161-Interior_light_lin_slaves_config-Lin9_slave_3,not installed ,51
ENG253312-ENG258186-Interior_light_lin_slaves_config-Lin9_slave_4,not installed ,51
ENG253312-ENG260052-Interior_light_lin_slaves_config-Lin9_slave_5,not installed ,51
ENG253312-ENG259941-Interior_light_lin_slaves_config-Lin9_slave_6,not installed ,51
ENG253312-ENG259228-Interior_light_lin_slaves_config-Lin9_slave_7,not installed ,51
ENG253312-ENG260950-Interior_light_lin_slaves_config-Lin9_slave_8,not installed ,51
ENG253312-ENG260524-Interior_light_lin_slaves_config-Lin9_slave_9,not installed ,51
ENG253400-ENG259423-Interior_light_router_config-Output_bcm_amb1_light_function,00 ,93
ENG253400-ENG258209-Interior_light_router_config-Output_bcm_amb2_light_function,00 ,93
ENG253400-ENG261174-Interior_light_router_config-Output_bcm_amb3_light_function,00 ,93
ENG253400-ENG259810-Interior_light_router_config-Output_bcm_amb4_light_function,00 ,93
ENG253400-ENG261141-Interior_light_router_config-Output_bcm_frl_light_function,00 ,93
ENG253400-ENG258669-Interior_light_router_config-Output_BCM_interiorlight,00 ,93
ENG253400-ENG260789-Interior_light_router_config-Output_bcm_krl_light_function,FE ,93
ENG253400-ENG263574-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_left,00 ,93
ENG253400-ENG263530-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_right,00 ,93
ENG253400-ENG263557-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_left,00 ,93
ENG253400-ENG263579-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_right,00 ,93
ENG253400-ENG259911-Interior_light_router_config-Output_lin10_light_function_slave_1,00 ,93
ENG253400-ENG261157-Interior_light_router_config-Output_lin10_light_function_slave_10,00 ,93
ENG253400-ENG259627-Interior_light_router_config-Output_lin10_light_function_slave_11,00 ,93
ENG253400-ENG260063-Interior_light_router_config-Output_lin10_light_function_slave_12,00 ,93
ENG253400-ENG260392-Interior_light_router_config-Output_lin10_light_function_slave_13,00 ,93
ENG253400-ENG261033-Interior_light_router_config-Output_lin10_light_function_slave_14,00 ,93
ENG253400-ENG260756-Interior_light_router_config-Output_lin10_light_function_slave_15,00 ,93
ENG253400-ENG259504-Interior_light_router_config-Output_lin10_light_function_slave_2,00 ,93
ENG253400-ENG259442-Interior_light_router_config-Output_lin10_light_function_slave_3,00 ,93
ENG253400-ENG260805-Interior_light_router_config-Output_lin10_light_function_slave_4,00 ,93
ENG253400-ENG258266-Interior_light_router_config-Output_lin10_light_function_slave_5,00 ,93
ENG253400-ENG259364-Interior_light_router_config-Output_lin10_light_function_slave_6,00 ,93
ENG253400-ENG258390-Interior_light_router_config-Output_lin10_light_function_slave_7,00 ,93
ENG253400-ENG259292-Interior_light_router_config-Output_lin10_light_function_slave_8,00 ,93
ENG253400-ENG258719-Interior_light_router_config-Output_lin10_light_function_slave_9,00 ,93
ENG253400-ENG259289-Interior_light_router_config-Output_lin5_light_function_slave_1,00 ,93
ENG253400-ENG260386-Interior_light_router_config-Output_lin5_light_function_slave_10,00 ,93
ENG253400-ENG259124-Interior_light_router_config-Output_lin5_light_function_slave_11,00 ,93
ENG253400-ENG259695-Interior_light_router_config-Output_lin5_light_function_slave_12,00 ,93
ENG253400-ENG260422-Interior_light_router_config-Output_lin5_light_function_slave_13,00 ,93
ENG253400-ENG261133-Interior_light_router_config-Output_lin5_light_function_slave_14,00 ,93
ENG253400-ENG258921-Interior_light_router_config-Output_lin5_light_function_slave_15,00 ,93
ENG253400-ENG260665-Interior_light_router_config-Output_lin5_light_function_slave_2,00 ,93
ENG253400-ENG260238-Interior_light_router_config-Output_lin5_light_function_slave_3,00 ,93
ENG253400-ENG260068-Interior_light_router_config-Output_lin5_light_function_slave_4,00 ,93
ENG253400-ENG260774-Interior_light_router_config-Output_lin5_light_function_slave_5,00 ,93
ENG253400-ENG258506-Interior_light_router_config-Output_lin5_light_function_slave_6,00 ,93
ENG253400-ENG259536-Interior_light_router_config-Output_lin5_light_function_slave_7,00 ,93
ENG253400-ENG260354-Interior_light_router_config-Output_lin5_light_function_slave_8,00 ,93
ENG253400-ENG261251-Interior_light_router_config-Output_lin5_light_function_slave_9,00 ,93
ENG253400-ENG259104-Interior_light_router_config-Output_lin9_light_function_slave_1,00 ,93
ENG253400-ENG260459-Interior_light_router_config-Output_lin9_light_function_slave_10,00 ,93
ENG253400-ENG259020-Interior_light_router_config-Output_lin9_light_function_slave_11,00 ,93
ENG253400-ENG260441-Interior_light_router_config-Output_lin9_light_function_slave_12,00 ,93
ENG253400-ENG260308-Interior_light_router_config-Output_lin9_light_function_slave_13,00 ,93
ENG253400-ENG258226-Interior_light_router_config-Output_lin9_light_function_slave_14,00 ,93
ENG253400-ENG259889-Interior_light_router_config-Output_lin9_light_function_slave_15,00 ,93
ENG253400-ENG259254-Interior_light_router_config-Output_lin9_light_function_slave_2,00 ,93
ENG253400-ENG258737-Interior_light_router_config-Output_lin9_light_function_slave_3,00 ,93
ENG253400-ENG260120-Interior_light_router_config-Output_lin9_light_function_slave_4,00 ,93
ENG253400-ENG258661-Interior_light_router_config-Output_lin9_light_function_slave_5,00 ,93
ENG253400-ENG260829-Interior_light_router_config-Output_lin9_light_function_slave_6,00 ,93
ENG253400-ENG260402-Interior_light_router_config-Output_lin9_light_function_slave_7,00 ,93
ENG253400-ENG261173-Interior_light_router_config-Output_lin9_light_function_slave_8,00 ,93
ENG253400-ENG260176-Interior_light_router_config-Output_lin9_light_function_slave_9,00 ,93
ENG253400-ENG258236-Interior_light_router_config-Output_roof_console_1,FF ,93
ENG253400-ENG258284-Interior_light_router_config-Output_roof_console_2,FF ,93
ENG253400-ENG260269-Interior_light_router_config-Output_roof_console_3,FF ,93
ENG253400-ENG261203-Interior_light_router_config-Output_roof_console_4,FF ,93
ENG253400-ENG258705-Interior_light_router_config-Output_roof_console_5,FF ,93
ENG253400-ENG258805-Interior_light_router_config-Output_roof_console_6,FF ,93
ENG253400-ENG260327-Interior_light_router_config-Output_tsg_bfs_1,00 ,93
ENG253400-ENG259694-Interior_light_router_config-Output_tsg_bfs_2,00 ,93
ENG253400-ENG261276-Interior_light_router_config-Output_tsg_bfs_3,00 ,93
ENG253400-ENG258178-Interior_light_router_config-Output_tsg_bfs_4,00 ,93
ENG253400-ENG260821-Interior_light_router_config-Output_tsg_bfsh_1,00 ,93
ENG253400-ENG260853-Interior_light_router_config-Output_tsg_bfsh_2,00 ,93
ENG253400-ENG258859-Interior_light_router_config-Output_tsg_bfsh_3,00 ,93
ENG253400-ENG261258-Interior_light_router_config-Output_tsg_bfsh_4,00 ,93
ENG253400-ENG260340-Interior_light_router_config-Output_tsg_fs_1,00 ,93
ENG253400-ENG258105-Interior_light_router_config-Output_tsg_fs_2,00 ,93
ENG253400-ENG260046-Interior_light_router_config-Output_tsg_fs_3,00 ,93
ENG253400-ENG258946-Interior_light_router_config-Output_tsg_fs_4,00 ,93
ENG253400-ENG259611-Interior_light_router_config-Output_tsg_fsh_1,00 ,93
ENG253400-ENG258415-Interior_light_router_config-Output_tsg_fsh_2,00 ,93
ENG253400-ENG260438-Interior_light_router_config-Output_tsg_fsh_3,00 ,93
ENG253400-ENG259398-Interior_light_router_config-Output_tsg_fsh_4,00 ,93
ENG253388-ENG174170-Kessyfunktion-central_locking_system_selective_sigle_door_kessy_NAR,active ,4
ENG253388-ENG259401-Kessyfunktion-Gesamtoeffnung_ueber_Kessy,active ,4
ENG253388-ENG258623-Kessyfunktion-Heck_wiederentriegelung_ohne_Auswurf,active ,4
ENG253388-ENG259486-Kessyfunktion-Komfortbedienung_fh_oeffnen_ueber_kessy,not active ,4
ENG253388-ENG258699-Kessyfunktion-Komfortbedienung_fh_schliessen_ueber_kessy,active ,4
ENG253388-ENG259448-Kessyfunktion-Verriegeln_ueber_Toggle_nur_bei_Aussenhaut_geschlossen,not active ,4
ENG253388-ENG259117-Kessyfunktion-Wiederentriegelung_komplett,not_active ,4
ENG253388-ENG260947-Kessyfunktion-ZV_Kessy_Toggle_Taster_aktiv,not active ,4
ENG172886-MAS10514-lcm-Expanded high beam control,High beam assistant ,4
ENG172886-ENG142185-lcm-LCM_blinker,false ,4
ENG172886-ENG142034-lcm-Light_Control_Module,direkt verbaut ,4
ENG253068-ENG261092-Leuchte 0 BLK VL B24-Dimming Direction DEF 0,maximize ,20
ENG253068-ENG259139-Leuchte 0 BLK VL B24-Dimming Direction GHI 0,maximize ,20
ENG253068-ENG259025-Leuchte 0 BLK VL B24-Dimming Direction JKL 0,maximize ,20
ENG253068-ENG259443-Leuchte 0 BLK VL B24-Dimmwert ABC 0,0 ,20
ENG253068-ENG260613-Leuchte 0 BLK VL B24-Dimmwert DEF 0,0 ,20
ENG253068-ENG259327-Leuchte 0 BLK VL B24-Dimmwert GHI 0,0 ,20
ENG253068-ENG261252-Leuchte 0 BLK VL B24-Dimmwert JKL 0,0 ,20
ENG253068-ENG115875-Leuchte 0 BLK VL B24-Fehlerort mittleres Byte DTC-DFCC 0,00 ,20
ENG253068-ENG116547-Leuchte 0 BLK VL B24-Lampendefektbit Position 0,00 ,20
ENG253068-ENG258269-Leuchte 0 BLK VL B24-Lasttyp_0,not_active ,20
ENG253068-ENG260373-Leuchte 0 BLK VL B24-Lichtansteuerung HD ABC 0,Always ,20
ENG253068-ENG115876-Leuchte 0 BLK VL B24-Lichtfunktion A 0,not active ,20
ENG253068-ENG115877-Leuchte 0 BLK VL B24-Lichtfunktion B 0,not active ,20
ENG253068-ENG115880-Leuchte 0 BLK VL B24-Lichtfunktion C 0,not active ,20
ENG253068-ENG115881-Leuchte 0 BLK VL B24-Lichtfunktion D 0,not active ,20
ENG253068-ENG115884-Leuchte 0 BLK VL B24-Lichtfunktion E 0,not active ,20
ENG253068-ENG115885-Leuchte 0 BLK VL B24-Lichtfunktion F 0,not active ,20
ENG253068-ENG115888-Leuchte 0 BLK VL B24-Lichtfunktion G 0,not active ,20
ENG253068-ENG115889-Leuchte 0 BLK VL B24-Lichtfunktion H 0,not active ,20
ENG253068-ENG258703-Leuchte 0 BLK VL B24-Lichtfunktion I 0,not active ,20
ENG253068-ENG261318-Leuchte 0 BLK VL B24-Lichtfunktion J 0,not active ,20
ENG253068-ENG258291-Leuchte 0 BLK VL B24-Lichtfunktion K 0,not active ,20
ENG253068-ENG258466-Leuchte 0 BLK VL B24-Lichtfunktion L 0,not active ,20
ENG263470-ENG261125-Leuchte 1 BLK VR B9-Dimming Direction DEF 1,maximize ,20
ENG263470-ENG259203-Leuchte 1 BLK VR B9-Dimming Direction GHI 1,maximize ,20
ENG263470-ENG259792-Leuchte 1 BLK VR B9-Dimming Direction JKL 1,maximize ,20
ENG263470-ENG259773-Leuchte 1 BLK VR B9-Dimmwert ABC 1,0 ,20
ENG263470-ENG259452-Leuchte 1 BLK VR B9-Dimmwert DEF 1,0 ,20
ENG263470-ENG258945-Leuchte 1 BLK VR B9-Dimmwert GHI 1,0 ,20
ENG263470-ENG260514-Leuchte 1 BLK VR B9-Dimmwert JKL 1,0 ,20
ENG263470-ENG115894-Leuchte 1 BLK VR B9-Fehlerort mittleres Byte DTC-DFCC 1,00 ,20
ENG263470-ENG116548-Leuchte 1 BLK VR B9-Lampendefektbitposition 1,00 ,20
ENG263470-ENG115892-Leuchte 1 BLK VR B9-Lasttyp 1,not_active ,20
ENG263470-ENG258732-Leuchte 1 BLK VR B9-Lichtansteuerung HD ABC 1,Always ,20
ENG263470-ENG115895-Leuchte 1 BLK VR B9-Lichtfunktion A 1,not active ,20
ENG263470-ENG115896-Leuchte 1 BLK VR B9-Lichtfunktion B 1,not active ,20
ENG263470-ENG115899-Leuchte 1 BLK VR B9-Lichtfunktion C 1,not active ,20
ENG263470-ENG115900-Leuchte 1 BLK VR B9-Lichtfunktion D 1,not active ,20
ENG263470-ENG115903-Leuchte 1 BLK VR B9-Lichtfunktion E 1,not active ,20
ENG263470-ENG115904-Leuchte 1 BLK VR B9-Lichtfunktion F 1,not active ,20
ENG263470-ENG115907-Leuchte 1 BLK VR B9-Lichtfunktion G 1,not active ,20
ENG263470-ENG116549-Leuchte 1 BLK VR B9-Lichtfunktion H 1,not active ,20
ENG263470-ENG258834-Leuchte 1 BLK VR B9-Lichtfunktion I 1,not active ,20
ENG263470-ENG259586-Leuchte 1 BLK VR B9-Lichtfunktion J 1,not active ,20
ENG263470-ENG260282-Leuchte 1 BLK VR B9-Lichtfunktion K 1,not active ,20
ENG263470-ENG260467-Leuchte 1 BLK VR B9-Lichtfunktion L 1,not active ,20
ENG263477-ENG260590-Leuchte 10 SHUTTER L B23-Dimming Direction DEF 10,maximize ,20
ENG263477-ENG260408-Leuchte 10 SHUTTER L B23-Dimming Direction GHI 10,maximize ,20
ENG263477-ENG258321-Leuchte 10 SHUTTER L B23-Dimming Direction JKL 10,maximize ,20
ENG263477-ENG260576-Leuchte 10 SHUTTER L B23-Dimmwert ABC 10,0 ,20
ENG263477-ENG258223-Leuchte 10 SHUTTER L B23-Dimmwert DEF 10,0 ,20
ENG263477-ENG260725-Leuchte 10 SHUTTER L B23-Dimmwert GHI 10,0 ,20
ENG263477-ENG258779-Leuchte 10 SHUTTER L B23-Dimmwert JKL 10,0 ,20
ENG263477-ENG116064-Leuchte 10 SHUTTER L B23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,20
ENG263477-ENG116560-Leuchte 10 SHUTTER L B23-Lampendefektbitposition 10,00 ,20
ENG263477-ENG116062-Leuchte 10 SHUTTER L B23-Lasttyp 10,not_active ,20
ENG263477-ENG260677-Leuchte 10 SHUTTER L B23-Lichtansteuerung HD ABC 10,Always ,20
ENG263477-ENG116065-Leuchte 10 SHUTTER L B23-Lichtfunktion A 10,not active ,20
ENG263477-ENG116066-Leuchte 10 SHUTTER L B23-Lichtfunktion B 10,not active ,20
ENG263477-ENG116069-Leuchte 10 SHUTTER L B23-Lichtfunktion C 10,not active ,20
ENG263477-ENG116070-Leuchte 10 SHUTTER L B23-Lichtfunktion D 10,not active ,20
ENG263477-ENG116073-Leuchte 10 SHUTTER L B23-Lichtfunktion E 10,not active ,20
ENG263477-ENG116074-Leuchte 10 SHUTTER L B23-Lichtfunktion F 10,not active ,20
ENG263477-ENG116077-Leuchte 10 SHUTTER L B23-Lichtfunktion G 10,not active ,20
ENG263477-ENG116078-Leuchte 10 SHUTTER L B23-Lichtfunktion H 10,not active ,20
ENG263477-ENG261127-Leuchte 10 SHUTTER L B23-Lichtfunktion I 10,not active ,20
ENG263477-ENG259264-Leuchte 10 SHUTTER L B23-Lichtfunktion J 10,not active ,20
ENG263477-ENG258792-Leuchte 10 SHUTTER L B23-Lichtfunktion K 10,not active ,20
ENG263477-ENG260117-Leuchte 10 SHUTTER L B23-Lichtfunktion L 10,not active ,20
ENG263480-ENG260377-Leuchte 11 SHUTTER R B22-Dimming Direction DEF 11,maximize ,20
ENG263480-ENG261238-Leuchte 11 SHUTTER R B22-Dimming Direction GHI 11,maximize ,20
ENG263480-ENG258509-Leuchte 11 SHUTTER R B22-Dimming Direction JKL 11,maximize ,20
ENG263480-ENG259362-Leuchte 11 SHUTTER R B22-Dimmwert ABC 11,0 ,20
ENG263480-ENG259167-Leuchte 11 SHUTTER R B22-Dimmwert DEF 11,0 ,20
ENG263480-ENG259831-Leuchte 11 SHUTTER R B22-Dimmwert GHI 11,0 ,20
ENG263480-ENG259729-Leuchte 11 SHUTTER R B22-Dimmwert JKL 11,0 ,20
ENG263480-ENG116083-Leuchte 11 SHUTTER R B22-Fehlerort mittleres Byte DTC-DFCC 11,00 ,20
ENG263480-ENG116561-Leuchte 11 SHUTTER R B22-Lampendefektbitposition 11,00 ,20
ENG263480-ENG116081-Leuchte 11 SHUTTER R B22-Lasttyp 11,not_active ,20
ENG263480-ENG259732-Leuchte 11 SHUTTER R B22-Lichtansteuerung HD ABC 11,Always ,20
ENG263480-ENG116084-Leuchte 11 SHUTTER R B22-Lichtfunktion A 11,not active ,20
ENG263480-ENG116085-Leuchte 11 SHUTTER R B22-Lichtfunktion B 11,not active ,20
ENG263480-ENG116088-Leuchte 11 SHUTTER R B22-Lichtfunktion C 11,not active ,20
ENG263480-ENG116089-Leuchte 11 SHUTTER R B22-Lichtfunktion D 11,not active ,20
ENG263480-ENG116092-Leuchte 11 SHUTTER R B22-Lichtfunktion E 11,not active ,20
ENG263480-ENG116093-Leuchte 11 SHUTTER R B22-Lichtfunktion F 11,not active ,20
ENG263480-ENG116096-Leuchte 11 SHUTTER R B22-Lichtfunktion G 11,not active ,20
ENG263480-ENG116097-Leuchte 11 SHUTTER R B22-Lichtfunktion H 11,not active ,20
ENG263480-ENG260510-Leuchte 11 SHUTTER R B22-Lichtfunktion I 11,not active ,20
ENG263480-ENG258304-Leuchte 11 SHUTTER R B22-Lichtfunktion J 11,not active ,20
ENG263480-ENG260059-Leuchte 11 SHUTTER R B22-Lichtfunktion K 11,not active ,20
ENG263480-ENG260686-Leuchte 11 SHUTTER R B22-Lichtfunktion L 11,not active ,20
ENG263462-ENG259122-Leuchte 12 NL L B45-Dimming Direction DEF 12,maximize ,20
ENG263462-ENG260186-Leuchte 12 NL L B45-Dimming Direction GHI 12,maximize ,20
ENG263462-ENG258138-Leuchte 12 NL L B45-Dimming Direction JKL 12,maximize ,20
ENG263462-ENG261305-Leuchte 12 NL L B45-Dimmwert ABC 12,0 ,20
ENG263462-ENG258909-Leuchte 12 NL L B45-Dimmwert DEF 12,0 ,20
ENG263462-ENG261043-Leuchte 12 NL L B45-Dimmwert GHI 12,0 ,20
ENG263462-ENG261121-Leuchte 12 NL L B45-Dimmwert JKL 12,0 ,20
ENG263462-ENG116102-Leuchte 12 NL L B45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,20
ENG263462-ENG116562-Leuchte 12 NL L B45-Lampendefektbitposition 12,00 ,20
ENG263462-ENG116100-Leuchte 12 NL L B45-Lasttyp 12,not_active ,20
ENG263462-ENG258775-Leuchte 12 NL L B45-Lichtansteuerung HD ABC 12,Always ,20
ENG263462-ENG116103-Leuchte 12 NL L B45-Lichtfunktion A 12,not active ,20
ENG263462-ENG116104-Leuchte 12 NL L B45-Lichtfunktion B 12,not active ,20
ENG263462-ENG116107-Leuchte 12 NL L B45-Lichtfunktion C 12,not active ,20
ENG263462-ENG116108-Leuchte 12 NL L B45-Lichtfunktion D 12,not active ,20
ENG263462-ENG116111-Leuchte 12 NL L B45-Lichtfunktion E 12,not active ,20
ENG263462-ENG116112-Leuchte 12 NL L B45-Lichtfunktion F 12,not active ,20
ENG263462-ENG116115-Leuchte 12 NL L B45-Lichtfunktion G 12,not active ,20
ENG263462-ENG116116-Leuchte 12 NL L B45-Lichtfunktion H 12,not active ,20
ENG263462-ENG261188-Leuchte 12 NL L B45-Lichtfunktion I 12,not active ,20
ENG263462-ENG260482-Leuchte 12 NL L B45-Lichtfunktion J 12,not active ,20
ENG263462-ENG258107-Leuchte 12 NL L B45-Lichtfunktion K 12,not active ,20
ENG263462-ENG259735-Leuchte 12 NL L B45-Lichtfunktion L 12,not active ,20
ENG263429-ENG258235-Leuchte 13 NL R B5-Dimming Direction DEF 13,maximize ,20
ENG263429-ENG258860-Leuchte 13 NL R B5-Dimming Direction GHI 13,maximize ,20
ENG263429-ENG261185-Leuchte 13 NL R B5-Dimming Direction JKL 13,maximize ,20
ENG263429-ENG260614-Leuchte 13 NL R B5-Dimmwert ABC 13,0 ,20
ENG263429-ENG258948-Leuchte 13 NL R B5-Dimmwert DEF 13,0 ,20
ENG263429-ENG261076-Leuchte 13 NL R B5-Dimmwert GHI 13,0 ,20
ENG263429-ENG260048-Leuchte 13 NL R B5-Dimmwert JKL 13,0 ,20
ENG263429-ENG116121-Leuchte 13 NL R B5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,20
ENG263429-ENG116563-Leuchte 13 NL R B5-Lampendefektbitposition 13,00 ,20
ENG263429-ENG116119-Leuchte 13 NL R B5-Lasttyp 13,not_active ,20
ENG263429-ENG259297-Leuchte 13 NL R B5-Lichtansteuerung HD ABC 13,Always ,20
ENG263429-ENG116122-Leuchte 13 NL R B5-Lichtfunktion A 13,not active ,20
ENG263429-ENG116123-Leuchte 13 NL R B5-Lichtfunktion B 13,not active ,20
ENG263429-ENG116564-Leuchte 13 NL R B5-Lichtfunktion C 13,not active ,20
ENG263429-ENG116127-Leuchte 13 NL R B5-Lichtfunktion D 13,not active ,20
ENG263429-ENG116130-Leuchte 13 NL R B5-Lichtfunktion E 13,not active ,20
ENG263429-ENG116131-Leuchte 13 NL R B5-Lichtfunktion F 13,not active ,20
ENG263429-ENG116134-Leuchte 13 NL R B5-Lichtfunktion G 13,not active ,20
ENG263429-ENG116135-Leuchte 13 NL R B5-Lichtfunktion H 13,not active ,20
ENG263429-ENG259477-Leuchte 13 NL R B5-Lichtfunktion I 13,not active ,20
ENG263429-ENG259138-Leuchte 13 NL R B5-Lichtfunktion J 13,not active ,20
ENG263429-ENG258127-Leuchte 13 NL R B5-Lichtfunktion K 13,not active ,20
ENG263429-ENG259174-Leuchte 13 NL R B5-Lichtfunktion L 13,not active ,20
ENG263460-ENG260021-Leuchte 16 BLK SL B42_C31-Dimming Direction DEF 16,maximize ,20
ENG263460-ENG258735-Leuchte 16 BLK SL B42_C31-Dimming Direction GHI 16,maximize ,20
ENG263460-ENG260912-Leuchte 16 BLK SL B42_C31-Dimming Direction JKL 16,maximize ,20
ENG263460-ENG260010-Leuchte 16 BLK SL B42_C31-Dimmwert ABC 16,100 ,20
ENG263460-ENG258276-Leuchte 16 BLK SL B42_C31-Dimmwert DEF 16,0 ,20
ENG263460-ENG259552-Leuchte 16 BLK SL B42_C31-Dimmwert GHI 16,0 ,20
ENG263460-ENG260945-Leuchte 16 BLK SL B42_C31-Dimmwert JKL 16,0 ,20
ENG263460-ENG116178-Leuchte 16 BLK SL B42_C31-Fehlerort mittleres Byte DTC-DFCC 16,17 ,20
ENG263460-ENG116567-Leuchte 16 BLK SL B42_C31-Lampendefektbitposition 16,39 ,20
ENG263460-ENG116176-Leuchte 16 BLK SL B42_C31-Lasttyp 16,Blinkleuchten ,20
ENG263460-ENG258626-Leuchte 16 BLK SL B42_C31-Lichtansteuerung HD ABC 16,Always ,20
ENG263460-ENG116179-Leuchte 16 BLK SL B42_C31-Lichtfunktion A 16,Blinken links Hellphase ,20
ENG263460-ENG116180-Leuchte 16 BLK SL B42_C31-Lichtfunktion B 16,not active ,20
ENG263460-ENG116183-Leuchte 16 BLK SL B42_C31-Lichtfunktion C 16,not active ,20
ENG263460-ENG116184-Leuchte 16 BLK SL B42_C31-Lichtfunktion D 16,not active ,20
ENG263460-ENG116187-Leuchte 16 BLK SL B42_C31-Lichtfunktion E 16,not active ,20
ENG263460-ENG116188-Leuchte 16 BLK SL B42_C31-Lichtfunktion F 16,not active ,20
ENG263460-ENG116191-Leuchte 16 BLK SL B42_C31-Lichtfunktion G 16,not active ,20
ENG263460-ENG116192-Leuchte 16 BLK SL B42_C31-Lichtfunktion H 16,not active ,20
ENG263460-ENG261052-Leuchte 16 BLK SL B42_C31-Lichtfunktion I 16,not active ,20
ENG263460-ENG258938-Leuchte 16 BLK SL B42_C31-Lichtfunktion J 16,not active ,20
ENG263460-ENG258710-Leuchte 16 BLK SL B42_C31-Lichtfunktion K 16,not active ,20
ENG263460-ENG259847-Leuchte 16 BLK SL B42_C31-Lichtfunktion L 16,not active ,20
ENG253179-ENG258693-Leuchte 17 BLK_SR B4_A61-Dimming Direction DEF 17,maximize ,20
ENG253179-ENG259225-Leuchte 17 BLK_SR B4_A61-Dimming Direction GHI 17,maximize ,20
ENG253179-ENG260036-Leuchte 17 BLK_SR B4_A61-Dimming Direction JKL 17,maximize ,20
ENG253179-ENG259305-Leuchte 17 BLK_SR B4_A61-Dimmwert ABC 17,100 ,20
ENG253179-ENG260736-Leuchte 17 BLK_SR B4_A61-Dimmwert DEF 17,0 ,20
ENG253179-ENG261209-Leuchte 17 BLK_SR B4_A61-Dimmwert GHI 17,0 ,20
ENG253179-ENG260649-Leuchte 17 BLK_SR B4_A61-Dimmwert JKL 17,0 ,20
ENG253179-ENG116197-Leuchte 17 BLK_SR B4_A61-Fehlerort mittleres Byte DTC-DFCC 17,19 ,20
ENG253179-ENG116568-Leuchte 17 BLK_SR B4_A61-Lampendefektbitposition 17,43 ,20
ENG253179-ENG116195-Leuchte 17 BLK_SR B4_A61-Lasttyp 17,Blinkleuchten ,20
ENG253179-ENG259860-Leuchte 17 BLK_SR B4_A61-Lichtansteuerung HD ABC 17,Always ,20
ENG253179-ENG116198-Leuchte 17 BLK_SR B4_A61-Lichtfunktion A 17,Blinken rechts Hellphase ,20
ENG253179-ENG116569-Leuchte 17 BLK_SR B4_A61-Lichtfunktion B 17,not active ,20
ENG253179-ENG116202-Leuchte 17 BLK_SR B4_A61-Lichtfunktion C 17,not active ,20
ENG253179-ENG116203-Leuchte 17 BLK_SR B4_A61-Lichtfunktion D 17,not active ,20
ENG253179-ENG116206-Leuchte 17 BLK_SR B4_A61-Lichtfunktion E 17,not active ,20
ENG253179-ENG116207-Leuchte 17 BLK_SR B4_A61-Lichtfunktion F 17,not active ,20
ENG253179-ENG116210-Leuchte 17 BLK_SR B4_A61-Lichtfunktion G 17,not active ,20
ENG253179-ENG116211-Leuchte 17 BLK_SR B4_A61-Lichtfunktion H 17,not active ,20
ENG253179-ENG258378-Leuchte 17 BLK_SR B4_A61-Lichtfunktion I 17,not active ,20
ENG253179-ENG259950-Leuchte 17 BLK_SR B4_A61-Lichtfunktion J 17,not active ,20
ENG253179-ENG259363-Leuchte 17 BLK_SR B4_A61-Lichtfunktion K 17,not active ,20
ENG253179-ENG259816-Leuchte 17 BLK_SR B4_A61-Lichtfunktion L 17,not active ,20
ENG263478-ENG260141-Leuchte 18 BLK HL A60-Dimming Direction DEF 18,maximize ,20
ENG263478-ENG258397-Leuchte 18 BLK HL A60-Dimming Direction GHI 18,maximize ,20
ENG263478-ENG259980-Leuchte 18 BLK HL A60-Dimming Direction JKL 18,maximize ,20
ENG263478-ENG261250-Leuchte 18 BLK HL A60-Dimmwert ABC 18,100 ,20
ENG263478-ENG258343-Leuchte 18 BLK HL A60-Dimmwert DEF 18,0 ,20
ENG263478-ENG258799-Leuchte 18 BLK HL A60-Dimmwert GHI 18,0 ,20
ENG263478-ENG259813-Leuchte 18 BLK HL A60-Dimmwert JKL 18,0 ,20
ENG263478-ENG116216-Leuchte 18 BLK HL A60-Fehlerort mittleres Byte DTC-DFCC 18,16 ,20
ENG263478-ENG116570-Leuchte 18 BLK HL A60-Lampendefektbitposition 18,08 ,20
ENG263478-ENG116214-Leuchte 18 BLK HL A60-Lasttyp 18,LED_Blinkleuchten ,20
ENG263478-ENG258246-Leuchte 18 BLK HL A60-Lichtansteuerung HD ABC 18,Always ,20
ENG263478-ENG116217-Leuchte 18 BLK HL A60-Lichtfunktion A 18,Blinken links Hellphase ,20
ENG263478-ENG116218-Leuchte 18 BLK HL A60-Lichtfunktion B 18,not active ,20
ENG263478-ENG116221-Leuchte 18 BLK HL A60-Lichtfunktion C 18,not active ,20
ENG263478-ENG116222-Leuchte 18 BLK HL A60-Lichtfunktion D 18,not active ,20
ENG263478-ENG116225-Leuchte 18 BLK HL A60-Lichtfunktion E 18,not active ,20
ENG263478-ENG116226-Leuchte 18 BLK HL A60-Lichtfunktion F 18,not active ,20
ENG263478-ENG116229-Leuchte 18 BLK HL A60-Lichtfunktion G 18,not active ,20
ENG263478-ENG116230-Leuchte 18 BLK HL A60-Lichtfunktion H 18,not active ,20
ENG263478-ENG259904-Leuchte 18 BLK HL A60-Lichtfunktion I 18,not active ,20
ENG263478-ENG260450-Leuchte 18 BLK HL A60-Lichtfunktion J 18,not active ,20
ENG263478-ENG258383-Leuchte 18 BLK HL A60-Lichtfunktion K 18,not active ,20
ENG263478-ENG261100-Leuchte 18 BLK HL A60-Lichtfunktion L 18,not active ,20
ENG263431-ENG258368-Leuchte 19 BLK HR C27-Dimming Direction DEF 19,maximize ,20
ENG263431-ENG260517-Leuchte 19 BLK HR C27-Dimming Direction GHI 19,maximize ,20
ENG263431-ENG260100-Leuchte 19 BLK HR C27-Dimming Direction JKL 19,maximize ,20
ENG263431-ENG259136-Leuchte 19 BLK HR C27-Dimmwert ABC 19,100 ,20
ENG263431-ENG260521-Leuchte 19 BLK HR C27-Dimmwert DEF 19,0 ,20
ENG263431-ENG260131-Leuchte 19 BLK HR C27-Dimmwert GHI 19,0 ,20
ENG263431-ENG259140-Leuchte 19 BLK HR C27-Dimmwert JKL 19,0 ,20
ENG263431-ENG116235-Leuchte 19 BLK HR C27-Fehlerort mittleres Byte DTC-DFCC 19,18 ,20
ENG263431-ENG116571-Leuchte 19 BLK HR C27-Lampendefektbitposition 19,18 ,20
ENG263431-ENG116233-Leuchte 19 BLK HR C27-Lasttyp 19,LED_Blinkleuchten ,20
ENG263431-ENG258684-Leuchte 19 BLK HR C27-Lichtansteuerung HD ABC 19,Always ,20
ENG263431-ENG116236-Leuchte 19 BLK HR C27-Lichtfunktion A 19,Blinken rechts Hellphase ,20
ENG263431-ENG116237-Leuchte 19 BLK HR C27-Lichtfunktion B 19,not active ,20
ENG263431-ENG116240-Leuchte 19 BLK HR C27-Lichtfunktion C 19,not active ,20
ENG263431-ENG116241-Leuchte 19 BLK HR C27-Lichtfunktion D 19,not active ,20
ENG263431-ENG116244-Leuchte 19 BLK HR C27-Lichtfunktion E 19,not active ,20
ENG263431-ENG116245-Leuchte 19 BLK HR C27-Lichtfunktion F 19,not active ,20
ENG263431-ENG116248-Leuchte 19 BLK HR C27-Lichtfunktion G 19,not active ,20
ENG263431-ENG116249-Leuchte 19 BLK HR C27-Lichtfunktion H 19,not active ,20
ENG263431-ENG258386-Leuchte 19 BLK HR C27-Lichtfunktion I 19,not active ,20
ENG263431-ENG261194-Leuchte 19 BLK HR C27-Lichtfunktion J 19,not active ,20
ENG263431-ENG260240-Leuchte 19 BLK HR C27-Lichtfunktion K 19,not active ,20
ENG263431-ENG258090-Leuchte 19 BLK HR C27-Lichtfunktion L 19,not active ,20
ENG263453-ENG259538-Leuchte 2 SL VL B20-Dimming Direction DEF 2,maximize ,20
ENG263453-ENG259039-Leuchte 2 SL VL B20-Dimming Direction GHI 2,maximize ,20
ENG263453-ENG261192-Leuchte 2 SL VL B20-Dimming Direction JKL 2,maximize ,20
ENG263453-ENG260561-Leuchte 2 SL VL B20-Dimmwert ABC 2,100 ,20
ENG263453-ENG259420-Leuchte 2 SL VL B20-Dimmwert DEF 2,0 ,20
ENG263453-ENG258177-Leuchte 2 SL VL B20-Dimmwert GHI 2,0 ,20
ENG263453-ENG260473-Leuchte 2 SL VL B20-Dimmwert JKL 2,0 ,20
ENG263453-ENG115912-Leuchte 2 SL VL B20-Fehlerort mittleres Byte DTC-DFCC 2,29 ,20
ENG263453-ENG116550-Leuchte 2 SL VL B20-Lampendefektbitposition 2,0A ,20
ENG263453-ENG115910-Leuchte 2 SL VL B20-Lasttyp 2,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263453-ENG259674-Leuchte 2 SL VL B20-Lichtansteuerung HD ABC 2,Always ,20
ENG263453-ENG115913-Leuchte 2 SL VL B20-Lichtfunktion A 2,Position lamps ,20
ENG263453-ENG115914-Leuchte 2 SL VL B20-Lichtfunktion B 2,Parking light left ,20
ENG263453-ENG115917-Leuchte 2 SL VL B20-Lichtfunktion C 2,not active ,20
ENG263453-ENG115918-Leuchte 2 SL VL B20-Lichtfunktion D 2,not active ,20
ENG263453-ENG115921-Leuchte 2 SL VL B20-Lichtfunktion E 2,not active ,20
ENG263453-ENG115922-Leuchte 2 SL VL B20-Lichtfunktion F 2,not active ,20
ENG263453-ENG115925-Leuchte 2 SL VL B20-Lichtfunktion G 2,not active ,20
ENG263453-ENG115926-Leuchte 2 SL VL B20-Lichtfunktion H 2,not active ,20
ENG263453-ENG261008-Leuchte 2 SL VL B20-Lichtfunktion I 2,not active ,20
ENG263453-ENG259089-Leuchte 2 SL VL B20-Lichtfunktion J 2,not active ,20
ENG263453-ENG259764-Leuchte 2 SL VL B20-Lichtfunktion K 2,not active ,20
ENG263453-ENG261215-Leuchte 2 SL VL B20-Lichtfunktion L 2,not active ,20
ENG263476-ENG258998-Leuchte 20 BR L A71-Dimming Direction DEF 20,minimze ,20
ENG263476-ENG260228-Leuchte 20 BR L A71-Dimming Direction GHI 20,minimze ,20
ENG263476-ENG258824-Leuchte 20 BR L A71-Dimming Direction JKL 20,maximize ,20
ENG263476-ENG261006-Leuchte 20 BR L A71-Dimmwert ABC 20,100 ,20
ENG263476-ENG260784-Leuchte 20 BR L A71-Dimmwert DEF 20,0 ,20
ENG263476-ENG260188-Leuchte 20 BR L A71-Dimmwert GHI 20,0 ,20
ENG263476-ENG258358-Leuchte 20 BR L A71-Dimmwert JKL 20,0 ,20
ENG263476-ENG116254-Leuchte 20 BR L A71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,20
ENG263476-ENG116572-Leuchte 20 BR L A71-Lampendefektbitposition 20,09 ,20
ENG263476-ENG116252-Leuchte 20 BR L A71-Lasttyp 20,LED_Bremsleuchten ,20
ENG263476-ENG259045-Leuchte 20 BR L A71-Lichtansteuerung HD ABC 20,Always ,20
ENG263476-ENG116255-Leuchte 20 BR L A71-Lichtfunktion A 20,Brake lamp ,20
ENG263476-ENG116256-Leuchte 20 BR L A71-Lichtfunktion B 20,not active ,20
ENG263476-ENG116259-Leuchte 20 BR L A71-Lichtfunktion C 20,not active ,20
ENG263476-ENG116260-Leuchte 20 BR L A71-Lichtfunktion D 20,not active ,20
ENG263476-ENG116263-Leuchte 20 BR L A71-Lichtfunktion E 20,not active ,20
ENG263476-ENG116264-Leuchte 20 BR L A71-Lichtfunktion F 20,not active ,20
ENG263476-ENG116267-Leuchte 20 BR L A71-Lichtfunktion G 20,not active ,20
ENG263476-ENG116268-Leuchte 20 BR L A71-Lichtfunktion H 20,not active ,20
ENG263476-ENG259111-Leuchte 20 BR L A71-Lichtfunktion I 20,not active ,20
ENG263476-ENG259768-Leuchte 20 BR L A71-Lichtfunktion J 20,not active ,20
ENG263476-ENG260741-Leuchte 20 BR L A71-Lichtfunktion K 20,not active ,20
ENG263476-ENG258272-Leuchte 20 BR L A71-Lichtfunktion L 20,not active ,20
ENG263446-ENG259371-Leuchte 21 BR R C8-Dimming Direction DEF 21,minimze ,20
ENG263446-ENG261222-Leuchte 21 BR R C8-Dimming Direction GHI 21,minimze ,20
ENG263446-ENG260449-Leuchte 21 BR R C8-Dimming Direction JKL 21,maximize ,20
ENG263446-ENG260142-Leuchte 21 BR R C8-Dimmwert ABC 21,100 ,20
ENG263446-ENG259169-Leuchte 21 BR R C8-Dimmwert DEF 21,0 ,20
ENG263446-ENG258330-Leuchte 21 BR R C8-Dimmwert GHI 21,0 ,20
ENG263446-ENG260224-Leuchte 21 BR R C8-Dimmwert JKL 21,0 ,20
ENG263446-ENG116273-Leuchte 21 BR R C8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,20
ENG263446-ENG116573-Leuchte 21 BR R C8-Lampendefektbitposition 21,19 ,20
ENG263446-ENG116271-Leuchte 21 BR R C8-Lasttyp 21,LED_Bremsleuchten ,20
ENG263446-ENG259749-Leuchte 21 BR R C8-Lichtansteuerung HD ABC 21,Always ,20
ENG263446-ENG116274-Leuchte 21 BR R C8-Lichtfunktion A 21,Brake lamp ,20
ENG263446-ENG116275-Leuchte 21 BR R C8-Lichtfunktion B 21,not active ,20
ENG263446-ENG116278-Leuchte 21 BR R C8-Lichtfunktion C 21,not active ,20
ENG263446-ENG116279-Leuchte 21 BR R C8-Lichtfunktion D 21,not active ,20
ENG263446-ENG116282-Leuchte 21 BR R C8-Lichtfunktion E 21,not active ,20
ENG263446-ENG116283-Leuchte 21 BR R C8-Lichtfunktion F 21,not active ,20
ENG263446-ENG116286-Leuchte 21 BR R C8-Lichtfunktion G 21,not active ,20
ENG263446-ENG116287-Leuchte 21 BR R C8-Lichtfunktion H 21,not active ,20
ENG263446-ENG260531-Leuchte 21 BR R C8-Lichtfunktion I 21,not active ,20
ENG263446-ENG258267-Leuchte 21 BR R C8-Lichtfunktion J 21,not active ,20
ENG263446-ENG261265-Leuchte 21 BR R C8-Lichtfunktion K 21,not active ,20
ENG263446-ENG261356-Leuchte 21 BR R C8-Lichtfunktion L 21,not active ,20
ENG263487-ENG261009-Leuchte 22 BR M A57-Dimming Direction DEF 22,maximize ,20
ENG263487-ENG259558-Leuchte 22 BR M A57-Dimming Direction GHI 22,maximize ,20
ENG263487-ENG258098-Leuchte 22 BR M A57-Dimming Direction JKL 22,maximize ,20
ENG263487-ENG260824-Leuchte 22 BR M A57-Dimmwert ABC 22,127 ,20
ENG263487-ENG261330-Leuchte 22 BR M A57-Dimmwert DEF 22,0 ,20
ENG263487-ENG260249-Leuchte 22 BR M A57-Dimmwert GHI 22,0 ,20
ENG263487-ENG260794-Leuchte 22 BR M A57-Dimmwert JKL 22,0 ,20
ENG263487-ENG116292-Leuchte 22 BR M A57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,20
ENG263487-ENG116574-Leuchte 22 BR M A57-Lampendefektbitposition 22,29 ,20
ENG263487-ENG116290-Leuchte 22 BR M A57-Lasttyp 22,LED_dritte_Bremsleuchte ,20
ENG263487-ENG259134-Leuchte 22 BR M A57-Lichtansteuerung HD ABC 22,Always ,20
ENG263487-ENG116293-Leuchte 22 BR M A57-Lichtfunktion A 22,Brake lamp ,20
ENG263487-ENG116294-Leuchte 22 BR M A57-Lichtfunktion B 22,not active ,20
ENG263487-ENG116297-Leuchte 22 BR M A57-Lichtfunktion C 22,not active ,20
ENG263487-ENG116298-Leuchte 22 BR M A57-Lichtfunktion D 22,not active ,20
ENG263487-ENG116301-Leuchte 22 BR M A57-Lichtfunktion E 22,not active ,20
ENG263487-ENG116302-Leuchte 22 BR M A57-Lichtfunktion F 22,not active ,20
ENG263487-ENG116305-Leuchte 22 BR M A57-Lichtfunktion G 22,not active ,20
ENG263487-ENG116306-Leuchte 22 BR M A57-Lichtfunktion H 22,not active ,20
ENG263487-ENG261266-Leuchte 22 BR M A57-Lichtfunktion I 22,not active ,20
ENG263487-ENG259294-Leuchte 22 BR M A57-Lichtfunktion J 22,not active ,20
ENG263487-ENG258164-Leuchte 22 BR M A57-Lichtfunktion K 22,not active ,20
ENG263487-ENG259578-Leuchte 22 BR M A57-Lichtfunktion L 22,not active ,20
ENG263433-ENG259710-Leuchte 23 SL HL C10-Dimming Direction DEF 32,minimze ,20
ENG263433-ENG258905-Leuchte 23 SL HL C10-Dimming Direction GHI 32,maximize ,20
ENG263433-ENG260532-Leuchte 23 SL HL C10-Dimming Direction JKL 32,maximize ,20
ENG263433-ENG259737-Leuchte 23 SL HL C10-Dimmwert ABC 32,127 ,20
ENG263433-ENG259346-Leuchte 23 SL HL C10-Dimmwert DEF 32,0 ,20
ENG263433-ENG260258-Leuchte 23 SL HL C10-Dimmwert GHI 32,0 ,20
ENG263433-ENG260382-Leuchte 23 SL HL C10-Dimmwert JKL 32,0 ,20
ENG263433-ENG116482-Leuchte 23 SL HL C10-Fehlerort mittleres Byte DTC-DFCC 32,00 ,20
ENG263433-ENG116584-Leuchte 23 SL HL C10-Lampendefektbitposition 32,00 ,20
ENG263433-ENG116480-Leuchte 23 SL HL C10-Lasttyp 32,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG263433-ENG259035-Leuchte 23 SL HL C10-Lichtansteuerung HD ABC 32,Always ,20
ENG263433-ENG116483-Leuchte 23 SL HL C10-Lichtfunktion A 32,Blinken links aktiv ,20
ENG263433-ENG116484-Leuchte 23 SL HL C10-Lichtfunktion B 32,Blinken rechts aktiv ,20
ENG263433-ENG116487-Leuchte 23 SL HL C10-Lichtfunktion C 32,Nebelschlusslicht wenn kein Anhaenger gesteckt ,20
ENG263433-ENG116488-Leuchte 23 SL HL C10-Lichtfunktion D 32,not active ,20
ENG263433-ENG116491-Leuchte 23 SL HL C10-Lichtfunktion E 32,not active ,20
ENG263433-ENG116492-Leuchte 23 SL HL C10-Lichtfunktion F 32,not active ,20
ENG263433-ENG116495-Leuchte 23 SL HL C10-Lichtfunktion G 32,not active ,20
ENG263433-ENG116496-Leuchte 23 SL HL C10-Lichtfunktion H 32,not active ,20
ENG263433-ENG258763-Leuchte 23 SL HL C10-Lichtfunktion I 32,not active ,20
ENG263433-ENG259842-Leuchte 23 SL HL C10-Lichtfunktion J 32,not active ,20
ENG263433-ENG258857-Leuchte 23 SL HL C10-Lichtfunktion K 32,not active ,20
ENG263433-ENG260175-Leuchte 23 SL HL C10-Lichtfunktion L 32,not active ,20
ENG263475-ENG260709-Leuchte 24 SL HR A65-Dimming Direction DEF 24,minimze ,20
ENG263475-ENG258518-Leuchte 24 SL HR A65-Dimming Direction GHI 24,maximize ,20
ENG263475-ENG258189-Leuchte 24 SL HR A65-Dimming Direction JKL 24,maximize ,20
ENG263475-ENG259150-Leuchte 24 SL HR A65-Dimmwert ABC 24,127 ,20
ENG263475-ENG259120-Leuchte 24 SL HR A65-Dimmwert DEF 24,0 ,20
ENG263475-ENG259774-Leuchte 24 SL HR A65-Dimmwert GHI 24,0 ,20
ENG263475-ENG259393-Leuchte 24 SL HR A65-Dimmwert JKL 24,0 ,20
ENG263475-ENG116330-Leuchte 24 SL HR A65-Fehlerort mittleres Byte DTC-DFCC 24,00 ,20
ENG263475-ENG116576-Leuchte 24 SL HR A65-Lampendefektbitposition 24,00 ,20
ENG263475-ENG116328-Leuchte 24 SL HR A65-Lasttyp 24,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG263475-ENG258842-Leuchte 24 SL HR A65-Lichtansteuerung HD ABC 24,Always ,20
ENG263475-ENG116331-Leuchte 24 SL HR A65-Lichtfunktion A 24,Blinken links aktiv ,20
ENG263475-ENG116332-Leuchte 24 SL HR A65-Lichtfunktion B 24,Blinken rechts aktiv ,20
ENG263475-ENG116335-Leuchte 24 SL HR A65-Lichtfunktion C 24,Nebelschlusslicht wenn kein Anhaenger gesteckt ,20
ENG263475-ENG116336-Leuchte 24 SL HR A65-Lichtfunktion D 24,not active ,20
ENG263475-ENG116339-Leuchte 24 SL HR A65-Lichtfunktion E 24,not active ,20
ENG263475-ENG116340-Leuchte 24 SL HR A65-Lichtfunktion F 24,not active ,20
ENG263475-ENG116343-Leuchte 24 SL HR A65-Lichtfunktion G 24,not active ,20
ENG263475-ENG116344-Leuchte 24 SL HR A65-Lichtfunktion H 24,not active ,20
ENG263475-ENG260865-Leuchte 24 SL HR A65-Lichtfunktion I 24,not active ,20
ENG263475-ENG260414-Leuchte 24 SL HR A65-Lichtfunktion J 24,not active ,20
ENG263475-ENG260577-Leuchte 24 SL HR A65-Lichtfunktion K 24,not active ,20
ENG263475-ENG260598-Leuchte 24 SL HR A65-Lichtfunktion L 24,not active ,20
ENG263447-ENG260768-Leuchte 25 KZL H A59-Dimming Direction DEF 25,maximize ,20
ENG263447-ENG259422-Leuchte 25 KZL H A59-Dimming Direction GHI 25,maximize ,20
ENG263447-ENG258848-Leuchte 25 KZL H A59-Dimming Direction JKL 25,maximize ,20
ENG263447-ENG258210-Leuchte 25 KZL H A59-Dimmwert ABC 25,127 ,20
ENG263447-ENG260749-Leuchte 25 KZL H A59-Dimmwert DEF 25,0 ,20
ENG263447-ENG258574-Leuchte 25 KZL H A59-Dimmwert GHI 25,0 ,20
ENG263447-ENG259896-Leuchte 25 KZL H A59-Dimmwert JKL 25,0 ,20
ENG263447-ENG116349-Leuchte 25 KZL H A59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,20
ENG263447-ENG116577-Leuchte 25 KZL H A59-Lampendefektbitposition 25,28 ,20
ENG263447-ENG116347-Leuchte 25 KZL H A59-Lasttyp 25,allg_LED_mit_Open_Load_Diagnose_ohne_PWM ,20
ENG263447-ENG259553-Leuchte 25 KZL H A59-Lichtansteuerung HD ABC 25,Always ,20
ENG263447-ENG116350-Leuchte 25 KZL H A59-Lichtfunktion A 25,Position lamps ,20
ENG263447-ENG116351-Leuchte 25 KZL H A59-Lichtfunktion B 25,not active ,20
ENG263447-ENG116354-Leuchte 25 KZL H A59-Lichtfunktion C 25,not active ,20
ENG263447-ENG116355-Leuchte 25 KZL H A59-Lichtfunktion D 25,not active ,20
ENG263447-ENG116358-Leuchte 25 KZL H A59-Lichtfunktion E 25,not active ,20
ENG263447-ENG259247-Leuchte 25 KZL H A59-Lichtfunktion F25,not active ,20
ENG263447-ENG116362-Leuchte 25 KZL H A59-Lichtfunktion G 25,not active ,20
ENG263447-ENG116363-Leuchte 25 KZL H A59-Lichtfunktion H 25,not active ,20
ENG263447-ENG260931-Leuchte 25 KZL H A59-Lichtfunktion I 25,not active ,20
ENG263447-ENG258654-Leuchte 25 KZL H A59-Lichtfunktion J 25,not active ,20
ENG263447-ENG260798-Leuchte 25 KZL H A59-Lichtfunktion K 25,not active ,20
ENG263447-ENG258935-Leuchte 25 KZL H A59-Lichtfunktion L 25,not active ,20
ENG263489-ENG259412-Leuchte 26 NSL L A72-Dimming Direction DEF 26,maximize ,20
ENG263489-ENG259883-Leuchte 26 NSL L A72-Dimming Direction GHI 26,maximize ,20
ENG263489-ENG260584-Leuchte 26 NSL L A72-Dimming Direction JKL 26,maximize ,20
ENG263489-ENG261357-Leuchte 26 NSL L A72-Dimmwert ABC 26,100 ,20
ENG263489-ENG260958-Leuchte 26 NSL L A72-Dimmwert DEF 26,0 ,20
ENG263489-ENG258546-Leuchte 26 NSL L A72-Dimmwert GHI 26,0 ,20
ENG263489-ENG259662-Leuchte 26 NSL L A72-Dimmwert JKL 26,0 ,20
ENG263489-ENG116368-Leuchte 26 NSL L A72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,20
ENG263489-ENG116578-Leuchte 26 NSL L A72-Lampendefektbitposition 26,0C ,20
ENG263489-ENG116366-Leuchte 26 NSL L A72-Lasttyp 26,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263489-ENG260640-Leuchte 26 NSL L A72-Lichtansteuerung HD ABC 26,Always ,20
ENG263489-ENG116369-Leuchte 26 NSL L A72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,20
ENG263489-ENG116370-Leuchte 26 NSL L A72-Lichtfunktion B 26,not active ,20
ENG263489-ENG116373-Leuchte 26 NSL L A72-Lichtfunktion C 26,not active ,20
ENG263489-ENG116374-Leuchte 26 NSL L A72-Lichtfunktion D 26,not active ,20
ENG263489-ENG116377-Leuchte 26 NSL L A72-Lichtfunktion E 26,not active ,20
ENG263489-ENG116378-Leuchte 26 NSL L A72-Lichtfunktion F 26,not active ,20
ENG263489-ENG116381-Leuchte 26 NSL L A72-Lichtfunktion G 26,not active ,20
ENG263489-ENG116382-Leuchte 26 NSL L A72-Lichtfunktion H 26,not active ,20
ENG263489-ENG258650-Leuchte 26 NSL L A72-Lichtfunktion I 26,not active ,20
ENG263489-ENG258937-Leuchte 26 NSL L A72-Lichtfunktion J 26,not active ,20
ENG263489-ENG259765-Leuchte 26 NSL L A72-Lichtfunktion K 26,not active ,20
ENG263489-ENG260970-Leuchte 26 NSL L A72-Lichtfunktion L 26,not active ,20
ENG263468-ENG259400-Leuchte 27 NSL R C6-Dimming Direction DEF 27,maximize ,20
ENG263468-ENG260627-Leuchte 27 NSL R C6-Dimming Direction GHI 27,maximize ,20
ENG263468-ENG260547-Leuchte 27 NSL R C6-Dimming Direction JKL 27,maximize ,20
ENG263468-ENG259742-Leuchte 27 NSL R C6-Dimmwert ABC 27,100 ,20
ENG263468-ENG258926-Leuchte 27 NSL R C6-Dimmwert DEF 27,0 ,20
ENG263468-ENG259009-Leuchte 27 NSL R C6-Dimmwert GHI 27,0 ,20
ENG263468-ENG260084-Leuchte 27 NSL R C6-Dimmwert JKL 27,0 ,20
ENG263468-ENG116387-Leuchte 27 NSL R C6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,20
ENG263468-ENG116579-Leuchte 27 NSL R C6-Lampendefektbitposition 27,1C ,20
ENG263468-ENG116385-Leuchte 27 NSL R C6-Lasttyp 27,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263468-ENG258715-Leuchte 27 NSL R C6-Lichtansteuerung HD ABC 27,Always ,20
ENG263468-ENG116388-Leuchte 27 NSL R C6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,20
ENG263468-ENG116389-Leuchte 27 NSL R C6-Lichtfunktion B 27,not active ,20
ENG263468-ENG116392-Leuchte 27 NSL R C6-Lichtfunktion C 27,not active ,20
ENG263468-ENG116393-Leuchte 27 NSL R C6-Lichtfunktion D 27,not active ,20
ENG263468-ENG116396-Leuchte 27 NSL R C6-Lichtfunktion E 27,not active ,20
ENG263468-ENG116397-Leuchte 27 NSL R C6-Lichtfunktion F 27,not active ,20
ENG263468-ENG116400-Leuchte 27 NSL R C6-Lichtfunktion G 27,not active ,20
ENG263468-ENG116401-Leuchte 27 NSL R C6-Lichtfunktion H 27,not active ,20
ENG263468-ENG258753-Leuchte 27 NSL R C6-Lichtfunktion I 27,not active ,20
ENG263468-ENG258206-Leuchte 27 NSL R C6-Lichtfunktion J 27,not active ,20
ENG263468-ENG260268-Leuchte 27 NSL R C6-Lichtfunktion K 27,not active ,20
ENG263468-ENG259071-Leuchte 27 NSL R C6-Lichtfunktion L 27,not active ,20
ENG263472-ENG258565-Leuchte 28 RFL L C11-Dimming Direction DEF 28,maximize ,20
ENG263472-ENG258532-Leuchte 28 RFL L C11-Dimming Direction GHI 28,maximize ,20
ENG263472-ENG259396-Leuchte 28 RFL L C11-Dimming Direction JKL 28,maximize ,20
ENG263472-ENG259919-Leuchte 28 RFL L C11-Dimmwert ABC 28,100 ,20
ENG263472-ENG258647-Leuchte 28 RFL L C11-Dimmwert DEF 28,0 ,20
ENG263472-ENG261179-Leuchte 28 RFL L C11-Dimmwert GHI 28,0 ,20
ENG263472-ENG260446-Leuchte 28 RFL L C11-Dimmwert JKL 28,0 ,20
ENG263472-ENG116406-Leuchte 28 RFL L C11-Fehlerort mittleres Byte DTC-DFCC 28,31 ,20
ENG263472-ENG116580-Leuchte 28 RFL L C11-Lampendefektbitposition 28,0B ,20
ENG263472-ENG116404-Leuchte 28 RFL L C11-Lasttyp 28,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263472-ENG258804-Leuchte 28 RFL L C11-Lichtansteuerung HD ABC 28,Always ,20
ENG263472-ENG116407-Leuchte 28 RFL L C11-Lichtfunktion A 28,Rueckfahrlicht ,20
ENG263472-ENG116408-Leuchte 28 RFL L C11-Lichtfunktion B 28,not active ,20
ENG263472-ENG116411-Leuchte 28 RFL L C11-Lichtfunktion C 28,not active ,20
ENG263472-ENG116412-Leuchte 28 RFL L C11-Lichtfunktion D 28,not active ,20
ENG263472-ENG116415-Leuchte 28 RFL L C11-Lichtfunktion E 28,not active ,20
ENG263472-ENG116416-Leuchte 28 RFL L C11-Lichtfunktion F 28,not active ,20
ENG263472-ENG116419-Leuchte 28 RFL L C11-Lichtfunktion G 28,not active ,20
ENG263472-ENG116420-Leuchte 28 RFL L C11-Lichtfunktion H 28,not active ,20
ENG263472-ENG260485-Leuchte 28 RFL L C11-Lichtfunktion I 28,not active ,20
ENG263472-ENG260652-Leuchte 28 RFL L C11-Lichtfunktion J 28,not active ,20
ENG263472-ENG258363-Leuchte 28 RFL L C11-Lichtfunktion K 28,not active ,20
ENG263472-ENG260174-Leuchte 28 RFL L C11-Lichtfunktion L 28,not active ,20
ENG263492-ENG261198-Leuchte 29 RFL R A64-Dimming Direction DEF 29,maximize ,20
ENG263492-ENG259250-Leuchte 29 RFL R A64-Dimming Direction GHI 29,maximize ,20
ENG263492-ENG260299-Leuchte 29 RFL R A64-Dimming Direction JKL 29,maximize ,20
ENG263492-ENG259879-Leuchte 29 RFL R A64-Dimmwert ABC 29,100 ,20
ENG263492-ENG260443-Leuchte 29 RFL R A64-Dimmwert DEF 29,0 ,20
ENG263492-ENG260415-Leuchte 29 RFL R A64-Dimmwert GHI 29,0 ,20
ENG263492-ENG260684-Leuchte 29 RFL R A64-Dimmwert JKL 29,0 ,20
ENG263492-ENG116425-Leuchte 29 RFL R A64-Fehlerort mittleres Byte DTC-DFCC 29,32 ,20
ENG263492-ENG116581-Leuchte 29 RFL R A64-Lampendefektbitposition 29,1B ,20
ENG263492-ENG116423-Leuchte 29 RFL R A64-Lasttyp 29,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263492-ENG260077-Leuchte 29 RFL R A64-Lichtansteuerung HD ABC 29,Always ,20
ENG263492-ENG116426-Leuchte 29 RFL R A64-Lichtfunktion A 29,Rueckfahrlicht ,20
ENG263492-ENG116427-Leuchte 29 RFL R A64-Lichtfunktion B 29,not active ,20
ENG263492-ENG116429-Leuchte 29 RFL R A64-Lichtfunktion C 29,not active ,20
ENG263492-ENG116431-Leuchte 29 RFL R A64-Lichtfunktion D 29,not active ,20
ENG263492-ENG116434-Leuchte 29 RFL R A64-Lichtfunktion E 29,not active ,20
ENG263492-ENG116435-Leuchte 29 RFL R A64-Lichtfunktion F 29,not active ,20
ENG263492-ENG116438-Leuchte 29 RFL R A64-Lichtfunktion G 29,not active ,20
ENG263492-ENG116439-Leuchte 29 RFL R A64-Lichtfunktion H 29,not active ,20
ENG263492-ENG260646-Leuchte 29 RFL R A64-Lichtfunktion I 29,not active ,20
ENG263492-ENG259712-Leuchte 29 RFL R A64-Lichtfunktion J 29,not active ,20
ENG263492-ENG259236-Leuchte 29 RFL R A64-Lichtfunktion K 29,not active ,20
ENG263492-ENG259606-Leuchte 29 RFL R A64-Lichtfunktion L 29,not active ,20
ENG263454-ENG260476-Leuchte 3 SL VR B32-Dimming Direction DEF 3,maximize ,20
ENG263454-ENG259703-Leuchte 3 SL VR B32-Dimming Direction GHI 3,maximize ,20
ENG263454-ENG259508-Leuchte 3 SL VR B32-Dimming Direction JKL 3,maximize ,20
ENG263454-ENG258539-Leuchte 3 SL VR B32-Dimmwert ABC 3,100 ,20
ENG263454-ENG259082-Leuchte 3 SL VR B32-Dimmwert DEF 3,0 ,20
ENG263454-ENG260713-Leuchte 3 SL VR B32-Dimmwert GHI 3,0 ,20
ENG263454-ENG261150-Leuchte 3 SL VR B32-Dimmwert JKL 3,0 ,20
ENG263454-ENG115931-Leuchte 3 SL VR B32-Fehlerort mittleres Byte DTC-DFCC 3,2A ,20
ENG263454-ENG116551-Leuchte 3 SL VR B32-Lampendefektbitposition 3,1A ,20
ENG263454-ENG115929-Leuchte 3 SL VR B32-Lasttyp 3,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263454-ENG260316-Leuchte 3 SL VR B32-Lichtansteuerung HD ABC 3,Always ,20
ENG263454-ENG115932-Leuchte 3 SL VR B32-Lichtfunktion A 3,Position lamps ,20
ENG263454-ENG115933-Leuchte 3 SL VR B32-Lichtfunktion B 3,Parking light right ,20
ENG263454-ENG115936-Leuchte 3 SL VR B32-Lichtfunktion C 3,not active ,20
ENG263454-ENG115937-Leuchte 3 SL VR B32-Lichtfunktion D 3,not active ,20
ENG263454-ENG115940-Leuchte 3 SL VR B32-Lichtfunktion E 3,not active ,20
ENG263454-ENG116552-Leuchte 3 SL VR B32-Lichtfunktion F 3,not active ,20
ENG263454-ENG115944-Leuchte 3 SL VR B32-Lichtfunktion G 3,not active ,20
ENG263454-ENG115945-Leuchte 3 SL VR B32-Lichtfunktion H 3,not active ,20
ENG263454-ENG260399-Leuchte 3 SL VR B32-Lichtfunktion I 3,not active ,20
ENG263454-ENG260155-Leuchte 3 SL VR B32-Lichtfunktion J 3,not active ,20
ENG263454-ENG260622-Leuchte 3 SL VR B32-Lichtfunktion K 3,not active ,20
ENG263454-ENG258091-Leuchte 3 SL VR B32-Lichtfunktion L 3,not active ,20
ENG263428-ENG260857-Leuchte 30 FR L C72-Dimming Direction DEF 30,maximize ,20
ENG263428-ENG258841-Leuchte 30 FR L C72-Dimming Direction GHI 30,maximize ,20
ENG263428-ENG259433-Leuchte 30 FR L C72-Dimming Direction JKL 30,maximize ,20
ENG263428-ENG259620-Leuchte 30 FR L C72-Dimmwert ABC 30,0 ,20
ENG263428-ENG260960-Leuchte 30 FR L C72-Dimmwert DEF 30,0 ,20
ENG263428-ENG260191-Leuchte 30 FR L C72-Dimmwert GHI 30,0 ,20
ENG263428-ENG259143-Leuchte 30 FR L C72-Dimmwert JKL 30,0 ,20
ENG263428-ENG116444-Leuchte 30 FR L C72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,20
ENG263428-ENG116582-Leuchte 30 FR L C72-Lampendefektbitposition 30,00 ,20
ENG263428-ENG116442-Leuchte 30 FR L C72-Lasttyp 30,not_active ,20
ENG263428-ENG261067-Leuchte 30 FR L C72-Lichtansteuerung HD ABC 30,Always ,20
ENG263428-ENG116445-Leuchte 30 FR L C72-Lichtfunktion A 30,not active ,20
ENG263428-ENG116446-Leuchte 30 FR L C72-Lichtfunktion B 30,not active ,20
ENG263428-ENG116449-Leuchte 30 FR L C72-Lichtfunktion C 30,not active ,20
ENG263428-ENG116450-Leuchte 30 FR L C72-Lichtfunktion D 30,not active ,20
ENG263428-ENG116453-Leuchte 30 FR L C72-Lichtfunktion E 30,not active ,20
ENG263428-ENG116454-Leuchte 30 FR L C72-Lichtfunktion F 30,not active ,20
ENG263428-ENG116457-Leuchte 30 FR L C72-Lichtfunktion G 30,not active ,20
ENG263428-ENG116458-Leuchte 30 FR L C72-Lichtfunktion H 30,not active ,20
ENG263428-ENG260108-Leuchte 30 FR L C72-Lichtfunktion I 30,not active ,20
ENG263428-ENG260034-Leuchte 30 FR L C72-Lichtfunktion J 30,not active ,20
ENG263428-ENG259668-Leuchte 30 FR L C72-Lichtfunktion K 30,not active ,20
ENG263428-ENG258691-Leuchte 30 FR L C72-Lichtfunktion L 30,not active ,20
ENG263445-ENG260925-Leuchte 31 AMBL 1 C61-Dimming Direction DEF 31,maximize ,20
ENG263445-ENG259991-Leuchte 31 AMBL 1 C61-Dimming Direction GHI 31,maximize ,20
ENG263445-ENG259114-Leuchte 31 AMBL 1 C61-Dimming Direction JKL 31,maximize ,20
ENG263445-ENG261277-Leuchte 31 AMBL 1 C61-Dimmwert ABC 31,0 ,20
ENG263445-ENG259981-Leuchte 31 AMBL 1 C61-Dimmwert DEF 31,0 ,20
ENG263445-ENG260837-Leuchte 31 AMBL 1 C61-Dimmwert GHI 31,0 ,20
ENG263445-ENG258112-Leuchte 31 AMBL 1 C61-Dimmwert JKL 31,0 ,20
ENG263445-ENG116463-Leuchte 31 AMBL 1 C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,20
ENG263445-ENG116583-Leuchte 31 AMBL 1 C61-Lampendefektbitposition 31,00 ,20
ENG263445-ENG116461-Leuchte 31 AMBL 1 C61-Lasttyp 31,not_active ,20
ENG263445-ENG260205-Leuchte 31 AMBL 1 C61-Lichtansteuerung HD ABC 31,Always ,20
ENG263445-ENG116464-Leuchte 31 AMBL 1 C61-Lichtfunktion A 31,not active ,20
ENG263445-ENG116465-Leuchte 31 AMBL 1 C61-Lichtfunktion B 31,not active ,20
ENG263445-ENG116468-Leuchte 31 AMBL 1 C61-Lichtfunktion C 31,not active ,20
ENG263445-ENG116469-Leuchte 31 AMBL 1 C61-Lichtfunktion D 31,not active ,20
ENG263445-ENG116472-Leuchte 31 AMBL 1 C61-Lichtfunktion E 31,not active ,20
ENG263445-ENG116473-Leuchte 31 AMBL 1 C61-Lichtfunktion F 31,not active ,20
ENG263445-ENG116476-Leuchte 31 AMBL 1 C61-Lichtfunktion G 31,not active ,20
ENG263445-ENG116477-Leuchte 31 AMBL 1 C61-Lichtfunktion H 31,not active ,20
ENG263445-ENG260861-Leuchte 31 AMBL 1 C61-Lichtfunktion I 31,not active ,20
ENG263445-ENG260553-Leuchte 31 AMBL 1 C61-Lichtfunktion J 31,not active ,20
ENG263445-ENG259999-Leuchte 31 AMBL 1 C61-Lichtfunktion K 31,not active ,20
ENG263445-ENG260353-Leuchte 31 AMBL 1 C61-Lichtfunktion L 31,not active ,20
ENG263449-ENG259710-Leuchte 32 AMBL 2 C35-Dimming Direction DEF 32,maximize ,20
ENG263449-ENG258905-Leuchte 32 AMBL 2 C35-Dimming Direction GHI 32,maximize ,20
ENG263449-ENG260532-Leuchte 32 AMBL 2 C35-Dimming Direction JKL 32,maximize ,20
ENG263449-ENG259737-Leuchte 32 AMBL 2 C35-Dimmwert ABC 32,0 ,20
ENG263449-ENG259346-Leuchte 32 AMBL 2 C35-Dimmwert DEF 32,0 ,20
ENG263449-ENG260258-Leuchte 32 AMBL 2 C35-Dimmwert GHI 32,0 ,20
ENG263449-ENG260382-Leuchte 32 AMBL 2 C35-Dimmwert JKL 32,0 ,20
ENG263449-ENG116482-Leuchte 32 AMBL 2 C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,20
ENG263449-ENG116584-Leuchte 32 AMBL 2 C35-Lampendefektbitposition 32,00 ,20
ENG263449-ENG116480-Leuchte 32 AMBL 2 C35-Lasttyp 32,not_active ,20
ENG263449-ENG259035-Leuchte 32 AMBL 2 C35-Lichtansteuerung HD ABC 32,Always ,20
ENG263449-ENG116483-Leuchte 32 AMBL 2 C35-Lichtfunktion A 32,not active ,20
ENG263449-ENG116484-Leuchte 32 AMBL 2 C35-Lichtfunktion B 32,not active ,20
ENG263449-ENG116487-Leuchte 32 AMBL 2 C35-Lichtfunktion C 32,not active ,20
ENG263449-ENG116488-Leuchte 32 AMBL 2 C35-Lichtfunktion D 32,not active ,20
ENG263449-ENG116491-Leuchte 32 AMBL 2 C35-Lichtfunktion E 32,not active ,20
ENG263449-ENG116492-Leuchte 32 AMBL 2 C35-Lichtfunktion F 32,not active ,20
ENG263449-ENG116495-Leuchte 32 AMBL 2 C35-Lichtfunktion G 32,not active ,20
ENG263449-ENG116496-Leuchte 32 AMBL 2 C35-Lichtfunktion H 32,not active ,20
ENG263449-ENG258763-Leuchte 32 AMBL 2 C35-Lichtfunktion I 32,not active ,20
ENG263449-ENG259842-Leuchte 32 AMBL 2 C35-Lichtfunktion J 32,not active ,20
ENG263449-ENG258857-Leuchte 32 AMBL 2 C35-Lichtfunktion K 32,not active ,20
ENG263449-ENG260175-Leuchte 32 AMBL 2 C35-Lichtfunktion L 32,not active ,20
ENG263439-ENG258755-Leuchte 33 AMBL 3 C36-Dimming Direction DEF 33,maximize ,20
ENG263439-ENG258237-Leuchte 33 AMBL 3 C36-Dimming Direction GHI 33,maximize ,20
ENG263439-ENG259038-Leuchte 33 AMBL 3 C36-Dimming Direction JKL 33,maximize ,20
ENG263439-ENG259476-Leuchte 33 AMBL 3 C36-Dimmwert ABC 33,0 ,20
ENG263439-ENG260461-Leuchte 33 AMBL 3 C36-Dimmwert DEF 33,0 ,20
ENG263439-ENG261181-Leuchte 33 AMBL 3 C36-Dimmwert GHI 33,0 ,20
ENG263439-ENG258425-Leuchte 33 AMBL 3 C36-Dimmwert JKL 33,0 ,20
ENG263439-ENG116501-Leuchte 33 AMBL 3 C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,20
ENG263439-ENG116585-Leuchte 33 AMBL 3 C36-Lampendefektbitposition 33,00 ,20
ENG263439-ENG116499-Leuchte 33 AMBL 3 C36-Lasttyp 33,not_active ,20
ENG263439-ENG259471-Leuchte 33 AMBL 3 C36-Lichtansteuerung HD ABC 33,Always ,20
ENG263439-ENG116502-Leuchte 33 AMBL 3 C36-Lichtfunktion A 33,not active ,20
ENG263439-ENG116503-Leuchte 33 AMBL 3 C36-Lichtfunktion B 33,not active ,20
ENG263439-ENG116506-Leuchte 33 AMBL 3 C36-Lichtfunktion C 33,not active ,20
ENG263439-ENG116507-Leuchte 33 AMBL 3 C36-Lichtfunktion D 33,not active ,20
ENG263439-ENG116510-Leuchte 33 AMBL 3 C36-Lichtfunktion E 33,not active ,20
ENG263439-ENG116511-Leuchte 33 AMBL 3 C36-Lichtfunktion F 33,not active ,20
ENG263439-ENG116514-Leuchte 33 AMBL 3 C36-Lichtfunktion G 33,not active ,20
ENG263439-ENG116515-Leuchte 33 AMBL 3 C36-Lichtfunktion H 33,not active ,20
ENG263439-ENG260403-Leuchte 33 AMBL 3 C36-Lichtfunktion I 33,not active ,20
ENG263439-ENG261239-Leuchte 33 AMBL 3 C36-Lichtfunktion J 33,not active ,20
ENG263439-ENG260953-Leuchte 33 AMBL 3 C36-Lichtfunktion K 33,not active ,20
ENG263439-ENG261234-Leuchte 33 AMBL 3 C36-Lichtfunktion L 33,not active ,20
ENG263434-ENG259648-Leuchte 34 AMBL 4 C37-Dimming Direction DEF 34,maximize ,20
ENG263434-ENG259188-Leuchte 34 AMBL 4 C37-Dimming Direction GHI 34,maximize ,20
ENG263434-ENG260464-Leuchte 34 AMBL 4 C37-Dimming Direction JKL 34,maximize ,20
ENG263434-ENG259524-Leuchte 34 AMBL 4 C37-Dimmwert ABC 34,0 ,20
ENG263434-ENG260705-Leuchte 34 AMBL 4 C37-Dimmwert DEF 34,0 ,20
ENG263434-ENG258677-Leuchte 34 AMBL 4 C37-Dimmwert GHI 34,0 ,20
ENG263434-ENG259924-Leuchte 34 AMBL 4 C37-Dimmwert JKL 34,0 ,20
ENG263434-ENG116520-Leuchte 34 AMBL 4 C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,20
ENG263434-ENG116586-Leuchte 34 AMBL 4 C37-Lampendefektbitposition 34,00 ,20
ENG263434-ENG116518-Leuchte 34 AMBL 4 C37-Lasttyp 34,not_active ,20
ENG263434-ENG259804-Leuchte 34 AMBL 4 C37-Lichtansteuerung HD ABC 34,Always ,20
ENG263434-ENG116521-Leuchte 34 AMBL 4 C37-Lichtfunktion A 34,not active ,20
ENG263434-ENG116522-Leuchte 34 AMBL 4 C37-Lichtfunktion B 34,not active ,20
ENG263434-ENG116525-Leuchte 34 AMBL 4 C37-Lichtfunktion C 34,not active ,20
ENG263434-ENG116526-Leuchte 34 AMBL 4 C37-Lichtfunktion D 34,not active ,20
ENG263434-ENG116529-Leuchte 34 AMBL 4 C37-Lichtfunktion E 34,not active ,20
ENG263434-ENG116530-Leuchte 34 AMBL 4 C37-Lichtfunktion F 34,not active ,20
ENG263434-ENG116533-Leuchte 34 AMBL 4 C37-Lichtfunktion G 34,not active ,20
ENG263434-ENG116534-Leuchte 34 AMBL 4 C37-Lichtfunktion H 34,not active ,20
ENG263434-ENG259061-Leuchte 34 AMBL 4 C37-Lichtfunktion I 34,not active ,20
ENG263434-ENG258125-Leuchte 34 AMBL 4 C37-Lichtfunktion J 34,not active ,20
ENG263434-ENG259670-Leuchte 34 AMBL 4 C37-Lichtfunktion K 34,not active ,20
ENG263434-ENG260771-Leuchte 34 AMBL 4 C37-Lichtfunktion L 34,not active ,20
ENG276130-ENG258314-Leuchte 35 LED Warnblinktaster C60-Dimming Direction DEF 35,maximize ,20
ENG276130-ENG260208-Leuchte 35 LED Warnblinktaster C60-Dimming Direction GHI 35,maximize ,20
ENG276130-ENG260869-Leuchte 35 LED Warnblinktaster C60-Dimming Direction JKL 35,maximize ,20
ENG276130-ENG259780-Leuchte 35 LED Warnblinktaster C60-Dimmwert ABC 35,100 ,20
ENG276130-ENG258175-Leuchte 35 LED Warnblinktaster C60-Dimmwert DEF 35,0 ,20
ENG276130-ENG259257-Leuchte 35 LED Warnblinktaster C60-Dimmwert GHI 35,0 ,20
ENG276130-ENG260977-Leuchte 35 LED Warnblinktaster C60-Dimmwert JKL 35,0 ,20
ENG276130-ENG258758-Leuchte 35 LED Warnblinktaster C60-Fehlerort mittleres Byte DTC-DFCC 35,00 ,20
ENG276130-ENG258551-Leuchte 35 LED Warnblinktaster C60-Lampendefektbitposition 35,00 ,20
ENG276130-ENG259566-Leuchte 35 LED Warnblinktaster C60-Lasttyp 35,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG276130-ENG260595-Leuchte 35 LED Warnblinktaster C60-Lichtansteuerung HD ABC 35,Always ,20
ENG276130-ENG260217-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion A 35,Warnblink Taster Suchbeleuchtung ,20
ENG276130-ENG259017-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion B 35,not active ,20
ENG276130-ENG259618-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion C 35,not active ,20
ENG276130-ENG259584-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion D 35,not active ,20
ENG276130-ENG259128-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion E 35,not active ,20
ENG276130-ENG258995-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion F 35,not active ,20
ENG276130-ENG258137-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion G 35,not active ,20
ENG276130-ENG259014-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion H 35,not active ,20
ENG276130-ENG258258-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion I 35,not active ,20
ENG276130-ENG260608-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion J 35,not active ,20
ENG276130-ENG260082-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion K 35,not active ,20
ENG276130-ENG261046-Leuchte 35 LED Warnblinktaster C60-Lichtfunktion L 35,not active ,20
ENG253037-ENG259399-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction DEF 36,maximize ,20
ENG253037-ENG260703-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction GHI 36,maximize ,20
ENG253037-ENG260112-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction JKL 36,maximize ,20
ENG253037-ENG258344-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert ABC 36,0 ,20
ENG253037-ENG258426-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert DEF 36,0 ,20
ENG253037-ENG260039-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert GHI 36,0 ,20
ENG253037-ENG259503-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert JKL 36,0 ,20
ENG253037-ENG260858-Leuchte 36 LEDNL_PWM_L_B37-Fehlerort mittleres Byte DTC-DFCC 36,00 ,20
ENG253037-ENG258523-Leuchte 36 LEDNL_PWM_L_B37-Lampendefektbitposition 36,00 ,20
ENG253037-ENG261341-Leuchte 36 LEDNL_PWM_L_B37-Lasttyp 36,not_active ,20
ENG253037-ENG259878-Leuchte 36 LEDNL_PWM_L_B37-Lichtansteuerung HD ABC 36,Always ,20
ENG253037-ENG258899-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion A 36,not active ,20
ENG253037-ENG260362-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion B 36,not active ,20
ENG253037-ENG258356-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion C 36,not active ,20
ENG253037-ENG258388-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion D 36,not active ,20
ENG253037-ENG258248-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion E 36,not active ,20
ENG253037-ENG260017-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion F 36,not active ,20
ENG253037-ENG260071-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion G 36,not active ,20
ENG253037-ENG259734-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion H 36,not active ,20
ENG253037-ENG260720-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion I 36,not active ,20
ENG253037-ENG259525-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion J 36,not active ,20
ENG253037-ENG259972-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion K 36,not active ,20
ENG253037-ENG259404-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion L 36,not active ,20
ENG253226-ENG260671-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction DEF 37,maximize ,20
ENG253226-ENG258552-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction GHI 37,maximize ,20
ENG253226-ENG260966-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction JKL 37,maximize ,20
ENG253226-ENG260262-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert ABC 37,0 ,20
ENG253226-ENG258498-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert DEF 37,0 ,20
ENG253226-ENG258952-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert GHI 37,0 ,20
ENG253226-ENG260588-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert JKL 37,0 ,20
ENG253226-ENG258708-Leuchte 37 LEDNL_PWM_R_B38-Fehlerort mittleres Byte DTC-DFCC 37,00 ,20
ENG253226-ENG260786-Leuchte 37 LEDNL_PWM_R_B38-Lampendefektbitposition 37,00 ,20
ENG253226-ENG259218-Leuchte 37 LEDNL_PWM_R_B38-Lasttyp 37,not_active ,20
ENG253226-ENG260323-Leuchte 37 LEDNL_PWM_R_B38-Lichtansteuerung HD ABC 37,Always ,20
ENG253226-ENG259995-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion A 37,not active ,20
ENG253226-ENG259686-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion B 37,not active ,20
ENG253226-ENG259495-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion C 37,not active ,20
ENG253226-ENG258914-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion D 37,not active ,20
ENG253226-ENG258741-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion E 37,not active ,20
ENG253226-ENG261001-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion F 37,not active ,20
ENG253226-ENG259796-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion G 37,not active ,20
ENG253226-ENG258391-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion H 37,not active ,20
ENG253226-ENG260757-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion I 37,not active ,20
ENG253226-ENG261282-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion J 37,not active ,20
ENG253226-ENG258097-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion K 37,not active ,20
ENG253226-ENG261120-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion L 37,not active ,20
ENG253185-ENG260594-Leuchte 38 Sidemarker_V_B21-Dimming Direction DEF 38,maximize ,20
ENG253185-ENG259176-Leuchte 38 Sidemarker_V_B21-Dimming Direction GHI 38,maximize ,20
ENG253185-ENG258361-Leuchte 38 Sidemarker_V_B21-Dimming Direction JKL 38,maximize ,20
ENG253185-ENG258271-Leuchte 38 Sidemarker_V_B21-Dimmwert ABC 38,0 ,20
ENG253185-ENG258593-Leuchte 38 Sidemarker_V_B21-Dimmwert DEF 38,0 ,20
ENG253185-ENG259740-Leuchte 38 Sidemarker_V_B21-Dimmwert GHI 38,0 ,20
ENG253185-ENG260375-Leuchte 38 Sidemarker_V_B21-Dimmwert JKL 38,0 ,20
ENG253185-ENG259110-Leuchte 38 Sidemarker_V_B21-Fehlerort mittleres Byte DTC-DFCC 38,00 ,20
ENG253185-ENG259339-Leuchte 38 Sidemarker_V_B21-Lampendefektbitposition 38,00 ,20
ENG253185-ENG258774-Leuchte 38 Sidemarker_V_B21-Lasttyp 38,not_active ,20
ENG253185-ENG259319-Leuchte 38 Sidemarker_V_B21-Lichtansteuerung HD ABC 38,Always ,20
ENG253185-ENG258971-Leuchte 38 Sidemarker_V_B21-Lichtfunktion A 38,not active ,20
ENG253185-ENG260328-Leuchte 38 Sidemarker_V_B21-Lichtfunktion B 38,not active ,20
ENG253185-ENG258602-Leuchte 38 Sidemarker_V_B21-Lichtfunktion C 38,not active ,20
ENG253185-ENG260130-Leuchte 38 Sidemarker_V_B21-Lichtfunktion D 38,not active ,20
ENG253185-ENG260126-Leuchte 38 Sidemarker_V_B21-Lichtfunktion E 38,not active ,20
ENG253185-ENG260093-Leuchte 38 Sidemarker_V_B21-Lichtfunktion F 38,not active ,20
ENG253185-ENG258515-Leuchte 38 Sidemarker_V_B21-Lichtfunktion G 38,not active ,20
ENG253185-ENG259657-Leuchte 38 Sidemarker_V_B21-Lichtfunktion H 38,not active ,20
ENG253185-ENG259428-Leuchte 38 Sidemarker_V_B21-Lichtfunktion I 38,not active ,20
ENG253185-ENG258516-Leuchte 38 Sidemarker_V_B21-Lichtfunktion J 38,not active ,20
ENG253185-ENG260994-Leuchte 38 Sidemarker_V_B21-Lichtfunktion K 38,not active ,20
ENG253185-ENG259179-Leuchte 38 Sidemarker_V_B21-Lichtfunktion L 38,not active ,20
ENG253171-ENG259501-Leuchte 39 Sidemarker_H C26-Dimming Direction DEF 39,maximize ,20
ENG253171-ENG260533-Leuchte 39 Sidemarker_H C26-Dimming Direction GHI 39,maximize ,20
ENG253171-ENG259331-Leuchte 39 Sidemarker_H C26-Dimming Direction JKL 39,maximize ,20
ENG253171-ENG259663-Leuchte 39 Sidemarker_H C26-Dimmwert ABC 39,0 ,20
ENG253171-ENG260625-Leuchte 39 Sidemarker_H C26-Dimmwert DEF 39,0 ,20
ENG253171-ENG258607-Leuchte 39 Sidemarker_H C26-Dimmwert GHI 39,0 ,20
ENG253171-ENG259031-Leuchte 39 Sidemarker_H C26-Dimmwert JKL 39,0 ,20
ENG253171-ENG260272-Leuchte 39 Sidemarker_H C26-Fehlerort mittleres Byte DTC-DFCC 39,00 ,20
ENG253171-ENG261342-Leuchte 39 Sidemarker_H C26-Lampendefektbitposition 39,00 ,20
ENG253171-ENG258910-Leuchte 39 Sidemarker_H C26-Lasttyp 39,not_active ,20
ENG253171-ENG261145-Leuchte 39 Sidemarker_H C26-Lichtansteuerung HD ABC 39,Always ,20
ENG253171-ENG259436-Leuchte 39 Sidemarker_H C26-Lichtfunktion A 39,not active ,20
ENG253171-ENG260471-Leuchte 39 Sidemarker_H C26-Lichtfunktion B 39,not active ,20
ENG253171-ENG260554-Leuchte 39 Sidemarker_H C26-Lichtfunktion C 39,not active ,20
ENG253171-ENG258988-Leuchte 39 Sidemarker_H C26-Lichtfunktion D 39,not active ,20
ENG253171-ENG259727-Leuchte 39 Sidemarker_H C26-Lichtfunktion E 39,not active ,20
ENG253171-ENG258355-Leuchte 39 Sidemarker_H C26-Lichtfunktion F 39,not active ,20
ENG253171-ENG261095-Leuchte 39 Sidemarker_H C26-Lichtfunktion G 39,not active ,20
ENG253171-ENG258577-Leuchte 39 Sidemarker_H C26-Lichtfunktion H 39,not active ,20
ENG253171-ENG259902-Leuchte 39 Sidemarker_H C26-Lichtfunktion I 39,not active ,20
ENG253171-ENG260202-Leuchte 39 Sidemarker_H C26-Lichtfunktion J 39,not active ,20
ENG253171-ENG260436-Leuchte 39 Sidemarker_H C26-Lichtfunktion K 39,not active ,20
ENG253171-ENG259237-Leuchte 39 Sidemarker_H C26-Lichtfunktion L 39,not active ,20
ENG263459-ENG258414-Leuchte 4 TFL L B3-Dimming Direction DEF 4,maximize ,20
ENG263459-ENG260894-Leuchte 4 TFL L B3-Dimming Direction GHI 4,maximize ,20
ENG263459-ENG259900-Leuchte 4 TFL L B3-Dimming Direction JKL 4,maximize ,20
ENG263459-ENG259665-Leuchte 4 TFL L B3-Dimmwert ABC 4,0 ,20
ENG263459-ENG260507-Leuchte 4 TFL L B3-Dimmwert DEF 4,0 ,20
ENG263459-ENG258447-Leuchte 4 TFL L B3-Dimmwert GHI 4,0 ,20
ENG263459-ENG258461-Leuchte 4 TFL L B3-Dimmwert JKL 4,0 ,20
ENG263459-ENG115950-Leuchte 4 TFL L B3-Fehlerort mittleres Byte DTC-DFCC 4,00 ,20
ENG263459-ENG116553-Leuchte 4 TFL L B3-Lampendefektbitposition 4,00 ,20
ENG263459-ENG115948-Leuchte 4 TFL L B3-Lasttyp 4,not_active ,20
ENG263459-ENG259234-Leuchte 4 TFL L B3-Lichtansteuerung HD ABC 4,Always ,20
ENG263459-ENG115951-Leuchte 4 TFL L B3-Lichtfunktion A 4,not active ,20
ENG263459-ENG115952-Leuchte 4 TFL L B3-Lichtfunktion B 4,not active ,20
ENG263459-ENG115955-Leuchte 4 TFL L B3-Lichtfunktion C 4,not active ,20
ENG263459-ENG115956-Leuchte 4 TFL L B3-Lichtfunktion D 4,not active ,20
ENG263459-ENG115959-Leuchte 4 TFL L B3-Lichtfunktion E 4,not active ,20
ENG263459-ENG115960-Leuchte 4 TFL L B3-Lichtfunktion F 4,not active ,20
ENG263459-ENG115963-Leuchte 4 TFL L B3-Lichtfunktion G 4,not active ,20
ENG263459-ENG115964-Leuchte 4 TFL L B3-Lichtfunktion H 4,not active ,20
ENG263459-ENG258442-Leuchte 4 TFL L B3-Lichtfunktion I 4,not active ,20
ENG263459-ENG258629-Leuchte 4 TFL L B3-Lichtfunktion J 4,not active ,20
ENG263459-ENG259468-Leuchte 4 TFL L B3-Lichtfunktion K 4,not active ,20
ENG263459-ENG258421-Leuchte 4 TFL L B3-Lichtfunktion L 4,not active ,20
ENG263465-ENG260616-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction DEF 40,maximize ,20
ENG263465-ENG259877-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction GHI v,maximize ,20
ENG263465-ENG258734-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction JKL 40,maximize ,20
ENG263465-ENG258702-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert ABC 40,0 ,20
ENG263465-ENG259888-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert DEF 40,0 ,20
ENG263465-ENG258927-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert GHI 40,0 ,20
ENG263465-ENG258852-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert JKL 40,0 ,20
ENG263465-ENG260246-Leuchte 40 Zusatz_hecklicht_HL C9-Fehlerort mittleres Byte DTC-DFCC 40,00 ,20
ENG263465-ENG259652-Leuchte 40 Zusatz_hecklicht_HL C9-Lampendefektbitposition 40,00 ,20
ENG263465-ENG260978-Leuchte 40 Zusatz_hecklicht_HL C9-Lasttyp 40,not_active ,20
ENG263465-ENG259185-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtansteuerung HD ABC 40,Always ,20
ENG263465-ENG259008-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion A 40,not active ,20
ENG263465-ENG258714-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion B 40,not active ,20
ENG263465-ENG258586-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion C 40,not active ,20
ENG263465-ENG258768-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion D 40,not active ,20
ENG263465-ENG259573-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion E 40,not active ,20
ENG263465-ENG258923-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion F 40,not active ,20
ENG263465-ENG258928-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion G 40,not active ,20
ENG263465-ENG259450-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion H 40,not active ,20
ENG263465-ENG260309-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion I 40,not active ,20
ENG263465-ENG258499-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion J 40,not active ,20
ENG263465-ENG261065-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion K 40,not active ,20
ENG263465-ENG259658-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion L 40,not active ,20
ENG263486-ENG259814-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction DEF 41,maximize ,20
ENG263486-ENG259194-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction GHI 41,maximize ,20
ENG263486-ENG258697-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction JKL 41,maximize ,20
ENG263486-ENG260405-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert ABC 41,0 ,20
ENG263486-ENG261284-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert DEF 41,0 ,20
ENG263486-ENG259351-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert GHI 41,0 ,20
ENG263486-ENG258887-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert JKL 41,0 ,20
ENG263486-ENG258329-Leuchte 41 Zusatz_hecklicht_HR A67-Fehlerort mittleres Byte DTC-DFCC 41,00 ,20
ENG263486-ENG258960-Leuchte 41 Zusatz_hecklicht_HR A67-Lampendefektbitposition 41,00 ,20
ENG263486-ENG261015-Leuchte 41 Zusatz_hecklicht_HR A67-Lasttyp 41,not_active ,20
ENG263486-ENG260435-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtansteuerung HD ABC 41,Always ,20
ENG263486-ENG260996-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion A 41,not active ,20
ENG263486-ENG259966-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion B 41,not active ,20
ENG263486-ENG258450-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion C 41,not active ,20
ENG263486-ENG259570-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion D 41,not active ,20
ENG263486-ENG260906-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion E 41,not active ,20
ENG263486-ENG260838-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion F 41,not active ,20
ENG263486-ENG258108-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion G 41,not active ,20
ENG263486-ENG258430-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion H 41,not active ,20
ENG263486-ENG260615-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion I 41,not active ,20
ENG263486-ENG260918-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion J 41,not active ,20
ENG263486-ENG258150-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion K 41,not active ,20
ENG263486-ENG258739-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion L 41,not active ,20
ENG253110-ENG261024-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction DEF 42,maximize ,20
ENG253110-ENG258668-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction GHI 42,maximize ,20
ENG253110-ENG258123-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction JKL 42,maximize ,20
ENG253110-ENG258370-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert ABC 42,0 ,20
ENG253110-ENG258109-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert DEF 42,0 ,20
ENG253110-ENG261169-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert GHI 42,0 ,20
ENG253110-ENG259028-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert JKL 42,0 ,20
ENG253110-ENG259381-Leuchte 42 Wischblinksignal_li C30_B35-Fehlerort mittleres Byte DTC-DFCC 42,00 ,20
ENG253110-ENG259973-Leuchte 42 Wischblinksignal_li C30_B35-Lampendefektbitposition 42,00 ,20
ENG253110-ENG258662-Leuchte 42 Wischblinksignal_li C30_B35-Lasttyp 42,not_active ,20
ENG253110-ENG258290-Leuchte 42 Wischblinksignal_li C30_B35-Lichtansteuerung HD ABC 42,Always ,20
ENG253110-ENG258895-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion A 42,not active ,20
ENG253110-ENG260384-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion B 42,not active ,20
ENG253110-ENG261085-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion C 42,not active ,20
ENG253110-ENG260667-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion D 42,not active ,20
ENG253110-ENG260232-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion E 42,not active ,20
ENG253110-ENG258671-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion F 42,not active ,20
ENG253110-ENG259243-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion G 42,not active ,20
ENG253110-ENG259518-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion H 42,not active ,20
ENG253110-ENG259526-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion I 42,not active ,20
ENG253110-ENG259239-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion J 42,not active ,20
ENG253110-ENG258327-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion K 42,not active ,20
ENG253110-ENG260944-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion L 42,not active ,20
ENG253212-ENG261135-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction DEF 43,maximize ,20
ENG253212-ENG258953-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction GHI 43,maximize ,20
ENG253212-ENG260351-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction JKL 43,maximize ,20
ENG253212-ENG259567-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert ABC 43,0 ,20
ENG253212-ENG259435-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert DEF 43,0 ,20
ENG253212-ENG260024-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert GHI 43,0 ,20
ENG253212-ENG259623-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert JKL 43,0 ,20
ENG253212-ENG258411-Leuchte 43 Wischblinksignal_re C33_B36-Fehlerort mittleres Byte DTC-DFCC 43,00 ,20
ENG253212-ENG261311-Leuchte 43 Wischblinksignal_re C33_B36-Lampendefektbitposition 43,00 ,20
ENG253212-ENG259612-Leuchte 43 Wischblinksignal_re C33_B36-Lasttyp 43,not_active ,20
ENG253212-ENG261054-Leuchte 43 Wischblinksignal_re C33_B36-Lichtansteuerung HD ABC 43,Always ,20
ENG253212-ENG258146-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion A 43,not active ,20
ENG253212-ENG258144-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion B 43,not active ,20
ENG253212-ENG258171-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion C 43,not active ,20
ENG253212-ENG259397-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion D 43,not active ,20
ENG253212-ENG260658-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion E 43,not active ,20
ENG253212-ENG260002-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion F 43,not active ,20
ENG253212-ENG260698-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion G 43,not active ,20
ENG253212-ENG261082-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion H 43,not active ,20
ENG253212-ENG260261-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion I 43,not active ,20
ENG253212-ENG259097-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion J 43,not active ,20
ENG253212-ENG260203-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion K 43,not active ,20
ENG253212-ENG258986-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion L 43,not active ,20
ENG253108-ENG258231-Leuchte 44 ALV C70-Dimming Direction DEF 44,maximize ,20
ENG253108-ENG260416-Leuchte 44 ALV C70-Dimming Direction GHI 44,maximize ,20
ENG253108-ENG260409-Leuchte 44 ALV C70-Dimming Direction JKL 44,maximize ,20
ENG253108-ENG261347-Leuchte 44 ALV C70-Dimmwert ABC 44,127 ,20
ENG253108-ENG260630-Leuchte 44 ALV C70-Dimmwert DEF 44,0 ,20
ENG253108-ENG259610-Leuchte 44 ALV C70-Dimmwert GHI 44,0 ,20
ENG253108-ENG261335-Leuchte 44 ALV C70-Dimmwert JKL 44,0 ,20
ENG253108-ENG260566-Leuchte 44 ALV C70-Fehlerort mittleres Byte DTC-DFCC 44,85 ,20
ENG253108-ENG261036-Leuchte 44 ALV C70-Lampendefektbitposition 44,00 ,20
ENG253108-ENG258970-Leuchte 44 ALV C70-Lasttyp 44,LED Lichtmodul ohne Open Load Diagnose ,20
ENG253108-ENG258540-Leuchte 44 ALV C70-Lichtansteuerung HD ABC 44,Always ,20
ENG253108-ENG260079-Leuchte 44 ALV C70-Lichtfunktion A 44,Ambientelichtmodul Versorgung ,20
ENG253108-ENG260296-Leuchte 44 ALV C70-Lichtfunktion B 44,not active ,20
ENG253108-ENG261154-Leuchte 44 ALV C70-Lichtfunktion C 44,not active ,20
ENG253108-ENG259507-Leuchte 44 ALV C70-Lichtfunktion D 44,not active ,20
ENG253108-ENG258260-Leuchte 44 ALV C70-Lichtfunktion E 44,not active ,20
ENG253108-ENG260714-Leuchte 44 ALV C70-Lichtfunktion F 44,not active ,20
ENG253108-ENG260064-Leuchte 44 ALV C70-Lichtfunktion G 44,not active ,20
ENG253108-ENG259720-Leuchte 44 ALV C70-Lichtfunktion H 44,not active ,20
ENG253108-ENG258947-Leuchte 44 ALV C70-Lichtfunktion I 44,not active ,20
ENG253108-ENG260429-Leuchte 44 ALV C70-Lichtfunktion J 44,not active ,20
ENG253108-ENG260305-Leuchte 44 ALV C70-Lichtfunktion K 44,not active ,20
ENG253108-ENG259925-Leuchte 44 ALV C70-Lichtfunktion L 44,not active ,20
ENG276131-ENG259161-Leuchte 45 C61-Dimming Direction DEF 45,maximize ,20
ENG276131-ENG260000-Leuchte 45 C61-Dimming Direction GHI 45,maximize ,20
ENG276131-ENG258382-Leuchte 45 C61-Dimming Direction JKL 45,maximize ,20
ENG276131-ENG258536-Leuchte 45 C61-Dimmwert ABC 45,100 ,20
ENG276131-ENG261049-Leuchte 45 C61-Dimmwert DEF 45,0 ,20
ENG276131-ENG258646-Leuchte 45 C61-Dimmwert GHI 45,0 ,20
ENG276131-ENG258455-Leuchte 45 C61-Dimmwert JKL 45,0 ,20
ENG276131-ENG258548-Leuchte 45 C61-Fehlerort mittleres Byte DTC-DFCC 45,89 ,20
ENG276131-ENG259186-Leuchte 45 C61-Lampendefektbitposition 45,00 ,20
ENG276131-ENG259655-Leuchte 45 C61-Lasttyp 45,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG276131-ENG259881-Leuchte 45 C61-Lichtansteuerung HD ABC 45,Always ,20
ENG276131-ENG258376-Leuchte 45 C61-Lichtfunktion A 45,Luggage compartment light ,20
ENG276131-ENG260107-Leuchte 45 C61-Lichtfunktion B 45,not active ,20
ENG276131-ENG259696-Leuchte 45 C61-Lichtfunktion C 45,not active ,20
ENG276131-ENG258534-Leuchte 45 C61-Lichtfunktion D 45,not active ,20
ENG276131-ENG258311-Leuchte 45 C61-Lichtfunktion E 45,not active ,20
ENG276131-ENG259561-Leuchte 45 C61-Lichtfunktion F 45,not active ,20
ENG276131-ENG258655-Leuchte 45 C61-Lichtfunktion G 45,not active ,20
ENG276131-ENG258706-Leuchte 45 C61-Lichtfunktion H 45,not active ,20
ENG276131-ENG260201-Leuchte 45 C61-Lichtfunktion I 45,not active ,20
ENG276131-ENG259692-Leuchte 45 C61-Lichtfunktion J 45,not active ,20
ENG276131-ENG259667-Leuchte 45 C61-Lichtfunktion K 45,not active ,20
ENG276131-ENG259221-Leuchte 45 C61-Lichtfunktion L 45,not active ,20
ENG263430-ENG259519-Leuchte 5 TFL R B4-Dimming Direction DEF 5,maximize ,20
ENG263430-ENG258873-Leuchte 5 TFL R B4-Dimming Direction GHI 5,maximize ,20
ENG263430-ENG260664-Leuchte 5 TFL R B4-Dimming Direction JKL 5,maximize ,20
ENG263430-ENG261164-Leuchte 5 TFL R B4-Dimmwert ABC 5,0 ,20
ENG263430-ENG259517-Leuchte 5 TFL R B4-Dimmwert DEF 5,0 ,20
ENG263430-ENG260636-Leuchte 5 TFL R B4-Dimmwert GHI 5,0 ,20
ENG263430-ENG258543-Leuchte 5 TFL R B4-Dimmwert JKL 5,0 ,20
ENG263430-ENG115969-Leuchte 5 TFL R B4-Fehlerort mittleres Byte DTC-DFCC 5,00 ,20
ENG263430-ENG116554-Leuchte 5 TFL R B4-Lampendefektbitposition 5,00 ,20
ENG263430-ENG115967-Leuchte 5 TFL R B4-Lasttyp 5,not_active ,20
ENG263430-ENG258404-Leuchte 5 TFL R B4-Lichtansteuerung HD ABC 5,Always ,20
ENG263430-ENG115970-Leuchte 5 TFL R B4-Lichtfunktion A 5,not active ,20
ENG263430-ENG115971-Leuchte 5 TFL R B4-Lichtfunktion B 5,not active ,20
ENG263430-ENG115974-Leuchte 5 TFL R B4-Lichtfunktion C 5,not active ,20
ENG263430-ENG115975-Leuchte 5 TFL R B4-Lichtfunktion D 5,not active ,20
ENG263430-ENG115978-Leuchte 5 TFL R B4-Lichtfunktion E 5,not active ,20
ENG263430-ENG116555-Leuchte 5 TFL R B4-Lichtfunktion F 5,not active ,20
ENG263430-ENG115982-Leuchte 5 TFL R B4-Lichtfunktion G 5,not active ,20
ENG263430-ENG115983-Leuchte 5 TFL R B4-Lichtfunktion H 5,not active ,20
ENG263430-ENG259352-Leuchte 5 TFL R B4-Lichtfunktion I 5,not active ,20
ENG263430-ENG260105-Leuchte 5 TFL R B4-Lichtfunktion J 5,not active ,20
ENG263430-ENG261301-Leuchte 5 TFL R B4-Lichtfunktion K 5,not active ,20
ENG263430-ENG258882-Leuchte 5 TFL R B4-Lichtfunktion L 5,not active ,20
ENG263442-ENG259123-Leuchte 6 ABL L C5-Dimming Direction DEF 6,maximize ,20
ENG263442-ENG258751-Leuchte 6 ABL L C5-Dimming Direction GHI 6,maximize ,20
ENG263442-ENG259402-Leuchte 6 ABL L C5-Dimming Direction JKL 6,maximize ,20
ENG263442-ENG260099-Leuchte 6 ABL L C5-Dimmwert ABC 6,0 ,20
ENG263442-ENG259481-Leuchte 6 ABL L C5-Dimmwert DEF 6,0 ,20
ENG263442-ENG258578-Leuchte 6 ABL L C5-Dimmwert GHI 6,0 ,20
ENG263442-ENG259931-Leuchte 6 ABL L C5-Dimmwert JKL 6,0 ,20
ENG263442-ENG115988-Leuchte 6 ABL L C5-Fehlerort mittleres Byte DTC-DFCC 6,00 ,20
ENG263442-ENG116556-Leuchte 6 ABL L C5-Lampendefektbitposition 6,00 ,20
ENG263442-ENG115986-Leuchte 6 ABL L C5-Lasttyp 6,not_active ,20
ENG263442-ENG260333-Leuchte 6 ABL L C5-Lichtansteuerung HD ABC 6,Always ,20
ENG263442-ENG115989-Leuchte 6 ABL L C5-Lichtfunktion A 6,not active ,20
ENG263442-ENG115990-Leuchte 6 ABL L C5-Lichtfunktion B 6,not active ,20
ENG263442-ENG115993-Leuchte 6 ABL L C5-Lichtfunktion C 6,not active ,20
ENG263442-ENG115994-Leuchte 6 ABL L C5-Lichtfunktion D 6,not active ,20
ENG263442-ENG115997-Leuchte 6 ABL L C5-Lichtfunktion E 6,not active ,20
ENG263442-ENG115998-Leuchte 6 ABL L C5-Lichtfunktion F 6,not active ,20
ENG263442-ENG116001-Leuchte 6 ABL L C5-Lichtfunktion G 6,not active ,20
ENG263442-ENG116002-Leuchte 6 ABL L C5-Lichtfunktion H 6,not active ,20
ENG263442-ENG259152-Leuchte 6 ABL L C5-Lichtfunktion I 6,not active ,20
ENG263442-ENG260123-Leuchte 6 ABL L C5-Lichtfunktion J 6,not active ,20
ENG263442-ENG258263-Leuchte 6 ABL L C5-Lichtfunktion K 6,not active ,20
ENG263442-ENG260915-Leuchte 6 ABL L C5-Lichtfunktion L 6,not active ,20
ENG263471-ENG258829-Leuchte 7 ABL R B1-Dimming Direction DEF 7,minimze ,20
ENG263471-ENG258643-Leuchte 7 ABL R B1-Dimming Direction GHI 7,maximize ,20
ENG263471-ENG260358-Leuchte 7 ABL R B1-Dimming Direction JKL 7,maximize ,20
ENG263471-ENG258757-Leuchte 7 ABL R B1-Dimmwert ABC 7,0 ,20
ENG263471-ENG260928-Leuchte 7 ABL R B1-Dimmwert DEF 7,0 ,20
ENG263471-ENG258547-Leuchte 7 ABL R B1-Dimmwert GHI 7,0 ,20
ENG263471-ENG260103-Leuchte 7 ABL R B1-Dimmwert JKL 7,0 ,20
ENG263471-ENG116007-Leuchte 7 ABL R B1-Fehlerort mittleres Byte DTC-DFCC 7,00 ,20
ENG263471-ENG116557-Leuchte 7 ABL R B1-Lampendefektbitposition 7,00 ,20
ENG263471-ENG116005-Leuchte 7 ABL R B1-Lasttyp 7,not_active ,20
ENG263471-ENG259256-Leuchte 7 ABL R B1-Lichtansteuerung HD ABC 7,Always ,20
ENG263471-ENG116008-Leuchte 7 ABL R B1-Lichtfunktion A 7,not active ,20
ENG263471-ENG116009-Leuchte 7 ABL R B1-Lichtfunktion B 7,not active ,20
ENG263471-ENG116012-Leuchte 7 ABL R B1-Lichtfunktion C 7,not active ,20
ENG263471-ENG116013-Leuchte 7 ABL R B1-Lichtfunktion D 7,not active ,20
ENG263471-ENG116016-Leuchte 7 ABL R B1-Lichtfunktion E 7,not active ,20
ENG263471-ENG116017-Leuchte 7 ABL R B1-Lichtfunktion F 7,not active ,20
ENG263471-ENG116020-Leuchte 7 ABL R B1-Lichtfunktion G 7,not active ,20
ENG263471-ENG116021-Leuchte 7 ABL R B1-Lichtfunktion H 7,not active ,20
ENG263471-ENG259451-Leuchte 7 ABL R B1-Lichtfunktion I 7,not active ,20
ENG263471-ENG259043-Leuchte 7 ABL R B1-Lichtfunktion J 7,not active ,20
ENG263471-ENG261166-Leuchte 7 ABL R B1-Lichtfunktion K 7,not active ,20
ENG263471-ENG258778-Leuchte 7 ABL R B1-Lichtfunktion L 7,not active ,20
ENG263437-ENG260885-Leuchte 8 FL L B39-Dimming Direction DEF 8,maximize ,20
ENG263437-ENG259591-Leuchte 8 FL L B39-Dimming Direction GHI 8,maximize ,20
ENG263437-ENG259283-Leuchte 8 FL L B39-Dimming Direction JKL 8,maximize ,20
ENG263437-ENG259944-Leuchte 8 FL L B39-Dimmwert ABC 8,0 ,20
ENG263437-ENG258915-Leuchte 8 FL L B39-Dimmwert DEF 8,0 ,20
ENG263437-ENG261200-Leuchte 8 FL L B39-Dimmwert GHI 8,0 ,20
ENG263437-ENG259325-Leuchte 8 FL L B39-Dimmwert JKL 8,0 ,20
ENG263437-ENG116026-Leuchte 8 FL L B39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,20
ENG263437-ENG116558-Leuchte 8 FL L B39-Lampendefektbitposition 8,00 ,20
ENG263437-ENG116024-Leuchte 8 FL L B39-Lasttyp 8,not_active ,20
ENG263437-ENG261218-Leuchte 8 FL L B39-Lichtansteuerung HD ABC 8,Always ,20
ENG263437-ENG116027-Leuchte 8 FL L B39-Lichtfunktion A 8,not active ,20
ENG263437-ENG116028-Leuchte 8 FL L B39-Lichtfunktion B 8,not active ,20
ENG263437-ENG116031-Leuchte 8 FL L B39-Lichtfunktion C 8,not active ,20
ENG263437-ENG116032-Leuchte 8 FL L B39-Lichtfunktion D 8,not active ,20
ENG263437-ENG116035-Leuchte 8 FL L B39-Lichtfunktion E 8,not active ,20
ENG263437-ENG116036-Leuchte 8 FL L B39-Lichtfunktion F 8,not active ,20
ENG263437-ENG116039-Leuchte 8 FL L B39-Lichtfunktion G 8,not active ,20
ENG263437-ENG116040-Leuchte 8 FL L B39-Lichtfunktion H 8,not active ,20
ENG263437-ENG261106-Leuchte 8 FL L B39-Lichtfunktion I 8,not active ,20
ENG263437-ENG259701-Leuchte 8 FL L B39-Lichtfunktion J 8,not active ,20
ENG263437-ENG260491-Leuchte 8 FL L B39-Lichtfunktion K 8,not active ,20
ENG263437-ENG260880-Leuchte 8 FL L B39-Lichtfunktion L 8,not active ,20
ENG263456-ENG260851-Leuchte 9 FL R B2-Dimming Direction DEF 9,maximize ,20
ENG263456-ENG260306-Leuchte 9 FL R B2-Dimming Direction GHI 9,maximize ,20
ENG263456-ENG261237-Leuchte 9 FL R B2-Dimming Direction JKL 9,maximize ,20
ENG263456-ENG260111-Leuchte 9 FL R B2-Dimmwert ABC 9,0 ,20
ENG263456-ENG260295-Leuchte 9 FL R B2-Dimmwert DEF 9,0 ,20
ENG263456-ENG259797-Leuchte 9 FL R B2-Dimmwert GHI 9,0 ,20
ENG263456-ENG260331-Leuchte 9 FL R B2-Dimmwert JKL 9,0 ,20
ENG263456-ENG116045-Leuchte 9 FL R B2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,20
ENG263456-ENG116559-Leuchte 9 FL R B2-Lampendefektbitposition 9,00 ,20
ENG263456-ENG116043-Leuchte 9 FL R B2-Lasttyp 9,not_active ,20
ENG263456-ENG258094-Leuchte 9 FL R B2-Lichtansteuerung HD ABC 9,Always ,20
ENG263456-ENG116046-Leuchte 9 FL R B2-Lichtfunktion A 9,not active ,20
ENG263456-ENG116047-Leuchte 9 FL R B2-Lichtfunktion B 9,not active ,20
ENG263456-ENG116050-Leuchte 9 FL R B2-Lichtfunktion C 9,not active ,20
ENG263456-ENG116051-Leuchte 9 FL R B2-Lichtfunktion D 9,not active ,20
ENG263456-ENG116054-Leuchte 9 FL R B2-Lichtfunktion E 9,not active ,20
ENG263456-ENG116055-Leuchte 9 FL R B2-Lichtfunktion F 9,not active ,20
ENG263456-ENG116058-Leuchte 9 FL R B2-Lichtfunktion G 9,not active ,20
ENG263456-ENG116059-Leuchte 9 FL R B2-Lichtfunktion H 9,not active ,20
ENG263456-ENG260691-Leuchte 9 FL R B2-Lichtfunktion I 9,not active ,20
ENG263456-ENG260334-Leuchte 9 FL R B2-Lichtfunktion J 9,not active ,20
ENG263456-ENG258156-Leuchte 9 FL R B2-Lichtfunktion K 9,not active ,20
ENG263456-ENG259184-Leuchte 9 FL R B2-Lichtfunktion L 9,not active ,20
ENG253237-IDE03311-Licht Konfig-Abhängig-Emergency braking display,active ,4
ENG253237-IDE07470-Licht Konfig-Abhängig-After-run for park light,No_sidelights_delay ,4
ENG253237-ENG142020-Licht Konfig-Abhängig-All-weather light,installed ,4
ENG253237-ENG258575-Licht Konfig-Abhängig-Diskrete_SBBR_links,installed ,4
ENG253237-ENG259588-Licht Konfig-Abhängig-Diskrete_SBBR_rechts,installed ,4
ENG253237-ENG142191-Licht Konfig-Abhängig-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,4
ENG253237-ENG142190-Licht Konfig-Abhängig-Signaturlicht_verbaut,not installed ,4
ENG253374-ENG246963-Licht_bedienung-Anzeigezeit_LTM_PopUp1,4.0 s,12
ENG253374-ENG246964-Licht_bedienung-Anzeigezeit_LTM_PopUp1_lang,4 s,12
ENG253374-ENG246965-Licht_bedienung-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,12
ENG253374-ENG246966-Licht_bedienung-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,12
ENG253374-ENG246978-Licht_bedienung-Licht_anforderung_FAS,not installed ,12
ENG253374-ENG246979-Licht_bedienung-Licht_anforderung_Pilopark,not active ,12
ENG253374-ENG246980-Licht_bedienung-Licht_Reaktivierungs_grenze,95 m,12
ENG253374-ENG246981-Licht_bedienung-Lichttastermodul,LTM_Zentraltaste ,12
ENG253374-ENG246982-Licht_bedienung-LTM_Anzeige_Config,02 ,12
ENG253374-ENG246983-Licht_bedienung-LTM_Beleuchtung_Geschwindigkeits_Schwelle,10 km/h,12
ENG253374-ENG246984-Licht_bedienung-LTM_BGL_Geschwindigkeitsabhängig,active ,12
ENG253374-ENG246985-Licht_bedienung-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,12
ENG253374-ENG246986-Licht_bedienung-LTM_BGL_Wegabhängig,active ,12
ENG253374-ENG246987-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabhängig,active ,12
ENG253374-ENG246988-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,12
ENG253374-ENG246989-Licht_bedienung-LTM_GlobalOFF_Wegabhängig,active ,12
ENG253374-ENG246990-Licht_bedienung-LTM_GlobalOFF_Zündungsabhängig,not active ,12
ENG253335-ENG259757-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_A,00 ,28
ENG253335-ENG261031-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_B,00 ,28
ENG253335-ENG259460-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_C,00 ,28
ENG253335-ENG261084-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_D,00 ,28
ENG253335-ENG260307-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_1,00 ,28
ENG253335-ENG258132-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_2,00 ,28
ENG253335-ENG258256-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_A,00 ,28
ENG253335-ENG260342-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_B,00 ,28
ENG253335-ENG259281-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_C,00 ,28
ENG253335-ENG260011-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_D,00 ,28
ENG253335-ENG260245-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_1,00 ,28
ENG253335-ENG261364-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_2,00 ,28
ENG253335-ENG260487-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_A,00 ,28
ENG253335-ENG260833-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_B,00 ,28
ENG253335-ENG261075-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_C,00 ,28
ENG253335-ENG260552-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_D,00 ,28
ENG253335-ENG260964-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_1,00 ,28
ENG253335-ENG260937-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_2,00 ,28
ENG253335-ENG261254-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_A,00 ,28
ENG253335-ENG259240-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_B,00 ,28
ENG253335-ENG258653-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_C,00 ,28
ENG253335-ENG258931-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_D,00 ,28
ENG253335-ENG259853-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_1,00 ,28
ENG253335-ENG258582-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_2,00 ,28
ENG174381-MAS00525-light_control-Trailer turn signal indicator lamp,INDIVIDUAL ,4
ENG174381-MAS07990-light_control-Comfort flasher,active ,4
ENG174381-MAS07991-light_control-Comfort flasher set point,3 ,4
ENG174381-MAS10538-light_control-Light rotary sw. connection,Data bus LIN 1 ,4
ENG174381-MAS12415-light_control-Parking lamp indicator lamp,INDIVIDUAL ,4
ENG174381-MAS21315-light_control-Convenience flashing cancellation,active ,4
ENG174381-ENG142188-light_control-bewusstes Standlicht,Aktive Begrenzung ,4
ENG174381-ENG154711-light_control-PreCrash_RECAS,active ,4
ENG174381-ENG126817-light_control-Umfeldleuchte als Manoevrierleuchte,not active ,4
ENG174381-ENG142004-light_control-Umgreifende_Heckklappe,not installed ,4
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,2
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,2
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,2
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,2
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,2
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,2
ENG126648-ENG260631-LIN-Mirrormode-LIN10,active ,2
ENG126648-ENG259894-LIN-Mirrormode-LIN11,active ,2
ENG126648-ENG260777-LIN-Mirrormode-LIN12,active ,2
ENG126648-ENG258456-LIN-Mirrormode-LIN13,active ,2
ENG126648-ENG259488-LIN-Mirrormode-LIN14,active ,2
ENG126648-ENG260898-LIN-Mirrormode-LIN7,active ,2
ENG126648-ENG259836-LIN-Mirrormode-LIN8,active ,2
ENG126648-ENG258319-LIN-Mirrormode-LIN9,active ,2
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,2
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.04 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,4 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,13.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,39 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,43 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,47 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,40 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,60 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Horn operation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS02790-LIN-SMLS_konfig_2-Diagnosis,not active ,2
ENG153728-MAS03758-LIN-SMLS_konfig_2-Not assigned,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG253274-ENG260814-Lock Unlock Taster-Lock_Unlock_Taster_diskret,not active ,2
ENG253274-ENG258303-Lock Unlock Taster-Lock_Unlock_Taster_Logik,Rocker sw. ,2
ENG263467-LWRBasissoftware,15 %,16
ENG263444-IDE03638-LWRKonfiguration-Stationary cornering lamp,ECE R48 ,8
ENG263444-IDE03644-LWRKonfiguration-Highway light,activated ,8
ENG263444-MAS02922-LWRKonfiguration-City light,activated ,8
ENG263444-MAS07013-LWRKonfiguration-All-weather light,activated ,8
ENG263444-MAS07933-LWRKonfiguration-Eco mode,not activated ,8
ENG263444-ENG172238-LWRKonfiguration-chassis_unit,Verbundlenkerhinterachse ,8
ENG263444-ENG260425-LWRKonfiguration-Function_activation_LWR,activated ,8
ENG263444-ENG174374-LWRKonfiguration-LED_Headlight,activated ,8
ENG263444-ENG259430-LWRKonfiguration-LWR_konfig,CAN automatic ,8
ENG263444-ENG172241-LWRKonfiguration-lwr_sensors,2_sensors ,8
ENG263444-ENG171501-LWRKonfiguration-Market,ECE ,8
ENG263444-ENG173009-LWRKonfiguration-offroad_light,not activated ,8
ENG263444-ENG172245-LWRKonfiguration-rain_light,not activated ,8
ENG263444-ENG174637-LWRKonfiguration-Source_height_value,BCM ,8
ENG263444-ENG172240-LWRKonfiguration-steering_curve,normal ,8
ENG253084-MDK,00 ,4
ENG249798-MDK_coding-,00 ,8
ENG249798-ENG253476-MDK_coding-MDK_bBtle_COV,00 ,8
ENG249798-ENG253477-MDK_coding-MDK_bExtendedScActivation_COV,00 ,8
ENG253387-mdk_locking_coding,not installed ,3
ENG122979-ENG141953-Networking-Getriebesteuergeraet,Monostable selector lever ,8
ENG124714-ENG142044-OCU-DWA_push,not active ,10
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,10
ENG124714-OCU-,not installed ,10
ENG124714-ENG259569-OCU-Remote HuF,active ,10
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,10
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,10
ENG124714-ENG260662-OCU-Remote HuF maximale Ausführungsdauer,30 s,10
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,10
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,10
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active ,10
ENG253051-ENG258966-Par_AutomatikFKT-AutomatikFunktion_Entfernungsschwelle_Wechsel_Zyklus_IDGeberAbwesenheit_Beschleunigtes_Entry,26.5 m,27
ENG253051-ENG260817-Par_AutomatikFKT-AutomatikFunktion_Gueltigkeitsdauer_IDGeber_Authentifizierungsstatus_Beschleunigtes_Entry,5.00 s,27
ENG253051-ENG260526-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Inkrement,1 ,27
ENG253051-ENG261190-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle,60 ,27
ENG253051-ENG258545-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle_Offset,5 ,27
ENG253051-ENG258184-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Dekrement,60 s,27
ENG253051-ENG260053-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Inkrement,10 s,27
ENG253051-ENG258738-Par_AutomatikFKT-AutomatikFunktionen_WechselBeiIDGebernInRuhe_Timeout,30 s,27
ENG253051-ENG258350-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_FahrendesFzg,20 km/h,27
ENG253051-ENG260570-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_StehendesFzg,10 km/h,27
ENG253051-ENG259634-Par_AutomatikFKT-Schwellwert_BEM_Umgebungsscan,1 ,27
ENG253051-ENG259977-Par_AutomatikFKT-TemporaereSperrungFuerAutomatikFunktionen_Dauer,2 s,27
ENG253257-ENG259939-Par_Dienste-Beeinflussung_StartStopp_DauerWiederstart,500 ms,18
ENG253257-ENG259005-Par_Dienste-Beeinflussung_StartStopp_Timeout,500 ms,18
ENG253257-ENG259811-Par_Dienste-Bereichsueberwachung_Pilotiertes_Parken_Timeout,120 s,18
ENG253257-ENG258849-Par_Dienste-BereichsueberwachungPilotiertesParken_Zyklus,2.0 s,18
ENG253257-ENG261028-Par_Dienste-EntryGoDeaktivierung_ZweiteBedienhandlung_Timeout,5 s,18
ENG253257-ENG261102-Par_Dienste-Innenraumsuche_GueltigkeitFuerExterneFunktionen,10 s,18
ENG253257-ENG258558-Par_Dienste-Paketbotenmodus_Timeout,15 min,18
ENG253257-ENG259702-Par_Dienste-Signalisierungsdauer_Ergebnis_IDGebersuche_ext_Funktionen,500 ms,18
ENG253257-ENG260866-Par_Dienste-SpielschutzFuerDienste_Dekrement_Timeout,60 s,18
ENG253257-ENG260031-Par_Dienste-SpielschutzFuerDienste_Schwelle,10 ,18
ENG253257-ENG277119-Par_Dienste-Timeout_ServiceKey_Message,260 ms,18
ENG253257-ENG258560-Par_Dienste-VIT_Mindest_Empfangs_Dauer_Betaetigt_Start_Suche,10 ms,18
ENG253386-ENG259497-Par_IDGeberSuche-Innenraumsuche_Kl15_Pause,5000 ms,26
ENG253386-ENG258238-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FahrendesFzg,20 km/h,26
ENG253386-ENG260811-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FensterGeschlossen,5.0 %,26
ENG253386-ENG258295-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_SADGeschlossen,1 %,26
ENG253386-ENG259267-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_StehendesFzg,10 km/h,26
ENG253386-ENG261289-Par_IDGeberSuche-Innenraumsuche_Kl15_Wiederholungen,5 ,26
ENG253386-ENG260801-Par_IDGeberSuche-Innenraumsuche_verzoegertFFBKomfortschließen,0 ms,26
ENG253386-ENG260447-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Heck_ZeitfensterFuerRasten,500 ms,26
ENG253386-ENG260184-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_FensterOffen,100.0 %,26
ENG253386-ENG260557-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_SADOffen,5.0 %,26
ENG253386-ENG258851-Par_IDGeberSuche-SignalisierungFunkkommunikation_Vorlauf,0 ms,26
ENG253398-ENG261340-Par_ScanStrat_RetryHandling-anz_GesamtRetries,1 ,18
ENG253398-ENG260989-Par_ScanStrat_RetryHandling-anz_RetriesAuthentifizierung,2 ,18
ENG253398-ENG260903-Par_ScanStrat_RetryHandling-Dynamischer_Anteil_Registering,7 ms,18
ENG253398-ENG259141-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_3DLF,75 ms,18
ENG253398-ENG259602-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_UWB,80 ms,18
ENG253398-ENG259661-Par_ScanStrat_RetryHandling-Schwellwert_Auswertung_UWB,FF FF FF FF ,18
ENG253398-ENG258787-Par_ScanStrat_RetryHandling-Timeout_Go_Authentifizierungsphase,160 ms,18
ENG253398-ENG260198-Par_ScanStrat_RetryHandling-Wartezeit_Challenge_Retry_Challenge_Entry,6 ms,18
ENG253398-ENG259374-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Entry,4 ms,18
ENG253398-ENG261047-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Go,35 ms,18
ENG253136-IDE02456-Passive_EntryExit_Toggle-Passive entry right rear door handle,activated ,8
ENG253136-IDE02457-Passive_EntryExit_Toggle-Passive entry left rear door handle,activated ,8
ENG253136-IDE02458-Passive_EntryExit_Toggle-Passive entry frt.pass. door handle,activated ,8
ENG253136-IDE02459-Passive_EntryExit_Toggle-Passive entry driver door handle,activated ,8
ENG253136-IDE02460-Passive_EntryExit_Toggle-Passive exit right rear door handle,not activated ,8
ENG253136-IDE02461-Passive_EntryExit_Toggle-Passive exit left rear door handle,not activated ,8
ENG253136-IDE02462-Passive_EntryExit_Toggle-Passive exit frt. pass. door handle,activated ,8
ENG253136-IDE02463-Passive_EntryExit_Toggle-Passive exit driver door handle,activated ,8
ENG253136-IDE03178-Passive_EntryExit_Toggle-Unlocking by electr. sliding door,activated ,8
ENG253136-MAS18905-Passive_EntryExit_Toggle-Passive entry via control section rear,activated ,8
ENG253136-MAS18906-Passive_EntryExit_Toggle-Passive entry by rear sensor,activated ,8
ENG253136-MAS18907-Passive_EntryExit_Toggle-Monitoring of locking by pulling door handle,activated ,8
ENG253136-MAS18912-Passive_EntryExit_Toggle-Passive exit door handle control section rear,not activated ,8
ENG253136-MAS18913-Passive_EntryExit_Toggle-Lock/unlock button on driver door active,not activated ,8
ENG253136-MAS18914-Passive_EntryExit_Toggle-Lock/unlock button on front passenger door active,not activated ,8
ENG253136-MAS18915-Passive_EntryExit_Toggle-Lock/unlock button on rear driver side active,not activated ,8
ENG253136-MAS18916-Passive_EntryExit_Toggle-Lock/unlock button on front passenger side active,not activated ,8
ENG253136-MAS18917-Passive_EntryExit_Toggle-Lock/unlock button control section rear active,not activated ,8
ENG253136-ENG259982-Passive_EntryExit_Toggle-Passive_Exit_EasyClose_aktiv,not activated ,8
ENG253136-ENG259242-Passive_EntryExit_Toggle-TemporaerSperrungFuerExit_aktiv,not activated ,8
ENG253136-ENG260214-Passive_EntryExit_Toggle-Verriegelungskontrolle_Heck_aktiv,not activated ,8
ENG129043-PASSIVE_GO,activated ,4
ENG253210-ENG260453-Personalisierung_2_0-Active_Participant_Doorlocking_Enabled,Deactivated ,12
ENG253210-ENG259841-Personalisierung_2_0-Active_Participant_ExteriorLight_Enabled,activated ,12
ENG253210-ENG260445-Personalisierung_2_0-Active_Participant_InteriorLight_Enabled,activated ,12
ENG253210-ENG259660-Personalisierung_2_0-Active_Participant_Mirror_Enabled,activated ,12
ENG253210-ENG259827-Personalisierung_2_0-Active_Participant_WiperComfort_Enabled,activated ,12
ENG253210-ENG258609-Personalisierung_2_0-PSO_Setup_1,not_active ,12
ENG253210-ENG260679-Personalisierung_2_0-PSO_Setup_2,not_active ,12
ENG253210-ENG259992-Personalisierung_2_0-PSO_Setup_Bereich_1,0 ms,12
ENG253210-ENG260317-Personalisierung_2_0-PSO_Setup_Bereich_2,0 ms,12
ENG253210-ENG260178-Personalisierung_2_0-Version_ Personalisierung,no customization ,12
ENG253210-ENG247653-Personalisierung_2_0-Wait_for_IAA_Slot_Info,150 ms,12
ENG263457-PSI5Konfiguration,02 ,16
ENG263448-PSI5Sensoren,front_and_rear ,1
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,8
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,8
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,8
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung,not active ,8
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,8
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,8
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,8
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,8
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,8
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,8
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,8
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,8
ENG263432-ENG142229-Regensensorik_Verbauund_ABT_Steuerung-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,3
ENG263432-ENG141956-Regensensorik_Verbauund_ABT_Steuerung-Humidity sensor,installedLIN1 ,3
ENG263432-ENG253444-Regensensorik_Verbauund_ABT_Steuerung-Light sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG253437-Regensensorik_Verbauund_ABT_Steuerung-rain sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG124476-Regensensorik_Verbauund_ABT_Steuerung-Sunlight photo sensor,not installed ,3
ENG264033-ENG264176-RLFS_RLS Codierung (KII05)-Filterleerung bei Poti-Verstellung,On ,3
ENG264033-ENG264051-RLFS_RLS Codierung (KII05)-Licht an bei Regen,Master steuert ,3
ENG264033-ENG264182-RLFS_RLS Codierung (KII05)-Licht an über Geschwindigkeit,Master steuert ,3
ENG264033-ENG264183-RLFS_RLS Codierung (KII05)-Lichtschaltschwellen Kalibrierung,0% (Standard) ,3
ENG264033-ENG159332-RLFS_RLS Codierung (KII05)-Parameter set,Parametersatz I ,3
ENG264033-ENG264191-RLFS_RLS Codierung (KII05)-Regenerkennung bei Kl.15 aus,OFF ,3
ENG264033-ENG264193-RLFS_RLS Codierung (KII05)-Regensensorbetrieb,On ,3
ENG264033-ENG264273-RLFS_RLS Codierung (KII05)-Start-Up-Wipe,On ,3
ENG264033-ENG264277-RLFS_RLS Codierung (KII05)-Transmission 550nm,80% Transmission ,3
ENG264033-ENG264278-RLFS_RLS Codierung (KII05)-Transmission 880nm,80% Transmission ,3
ENG264033-ENG264282-RLFS_RLS Codierung (KII05)-Wischeranlagentyp,Direct ,3
ENG179054-ENG179160-RLFS_ZF_TRW-p_n_1st_wipe_threshold,100 %,12
ENG179054-ENG179161-RLFS_ZF_TRW-p_n_highspeed_wipe_threshold,100 %,12
ENG179054-ENG179162-RLFS_ZF_TRW-p_n_interval_wipe_threshold,100 %,12
ENG179054-ENG179163-RLFS_ZF_TRW-p_n_LIN_Filter,3 ,12
ENG179054-ENG179164-RLFS_ZF_TRW-p_n_permanent_wipe_threshold,100 %,12
ENG179054-ENG179165-RLFS_ZF_TRW-p_n_RsEmergencyReducePercent,10 %,12
ENG179054-ENG179166-RLFS_ZF_TRW-p_t_ParkPosition_SpeedReset,1300 ms,12
ENG179054-ENG179167-RLFS_ZF_TRW-p_t_ParkPosition_WipeTimeout,1000 ms,12
ENG179054-ENG263513-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Cycle,2.0 s,12
ENG179054-ENG263511-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Delay,4.0 s,12
ENG179054-ENG179170-RLFS_ZF_TRW-p_t_tunnel_wipe_delay,6 s,12
ENG179054-ENG179171-RLFS_ZF_TRW-p_t_tunnel_wipe_window,15 s,12
ENG179054-ENG179172-RLFS_ZF_TRW-pa_lx_tunnel_light_on,1100 ,12
ENG179054-ENG179173-RLFS_ZF_TRW-pa_n_wisch_max_2,2 ,12
ENG179054-ENG179174-RLFS_ZF_TRW-pa_t_tunnel_delay_decrement,30 s,12
ENG179054-ENG179175-RLFS_ZF_TRW-pa_t_tunnel_delay_max,120 s,12
ENG179054-ENG179176-RLFS_ZF_TRW-Pa_t_tunnel_delay_on,1800 ms,12
ENG179054-ENG179177-RLFS_ZF_TRW-pa_t_tunnel_delay_step,5 s,12
ENG179054-ENG179178-RLFS_ZF_TRW-pa_v_RsActivationSpeed,5 km/h,12
ENG179054-ENG179179-RLFS_ZF_TRW-pa_v_wisch_max_1,20 km/h,12
ENG179054-ENG179180-RLFS_ZF_TRW-pa_v_wisch_max_2,4 km/h,12
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,5
ENG253157-roof_module,installed ,1
ENG253336-MAS10512-Schiebedach_ZV-Sunroof module MD1,not installed ,6
ENG253336-ENG260428-Schiebedach_ZV-dachrollo_2_verbaut,not installed ,6
ENG253336-ENG258762-Schiebedach_ZV-dachrollo_verbaut,not installed ,6
ENG253336-ENG261040-Schiebedach_ZV-Komfortbedienung_reichweitenbegrenzung_verdeck,not active ,6
ENG253336-ENG259091-Schiebedach_ZV-Komfortbedienung_verdecktaste_aktiv,not active ,6
ENG253336-ENG116647-Schiebedach_ZV-SAD Komfort oeffnen,not active ,6
ENG253336-ENG289611-Schiebedach_ZV-SAD Komfort_oeffnungs_modus,Open ,6
ENG253336-ENG149216-Schiebedach_ZV-SAD_Komfort_schliessen,not active ,6
ENG253336-ENG259548-Schiebedach_ZV-SAD_MD3,not active ,6
ENG253336-ENG259227-Schiebedach_ZV-SAD_t_Freigabe_eFH,600 s,6
ENG253336-ENG258522-Schiebedach_ZV-schiebedach_2_verbaut,not installed ,6
ENG253238-ENG258554-Schluesselkonfiguration-Fahrzeugplattform_MEB_aktiv,not activated ,1
ENG253238-ENG258470-Schluesselkonfiguration-Kessy_UWB_Frequenzband_a_aktiv,activated ,1
ENG253238-ENG259650-Schluesselkonfiguration-Kessy_UWB_Frequenzband_b_aktiv,activated ,1
ENG253238-ENG261161-Schluesselkonfiguration-Kessy_UWB_Frequenzband_c_aktiv,activated ,1
ENG253118-IDE02851-Schlüsselpositionsnachbildung (SPN)-S-contact shut-off after timeout,Yes ,31
ENG253118-ENG126943-Schlüsselpositionsnachbildung (SPN)-Display_duration_emergency_off,3000 ms,31
ENG253118-ENG126944-Schlüsselpositionsnachbildung (SPN)-Display_duration_error_mode_2_SPN,10 s,31
ENG253118-ENG126945-Schlüsselpositionsnachbildung (SPN)-min_time_for_Terminal_50_request,300 ms,31
ENG253118-ENG129003-Schlüsselpositionsnachbildung (SPN)-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,31
ENG253118-ENG253448-Schlüsselpositionsnachbildung (SPN)-Number_of_ZAT_activations_to_fault,10 ,31
ENG253118-ENG126939-Schlüsselpositionsnachbildung (SPN)-rpm_threshold_engine_runnning,100 /min,31
ENG253118-ENG126946-Schlüsselpositionsnachbildung (SPN)-Terminal_S_Timeout,30 min,31
ENG253118-ENG258251-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_clampcoordinator_trigger,1000 ms,31
ENG253118-ENG126947-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_ignition_trigger,35 s,31
ENG253264-Seat_cushion_fan,not installed ,1
ENG253224-ENG258215-Seat_pneumatics-Bcm_response_timer,350 ms,8
ENG253224-ENG259532-Seat_pneumatics-Installation_seat_pneumatics,not installed ,8
ENG253224-ENG260752-Seat_pneumatics-Installation_side_support,not installed ,8
ENG253224-ENG259164-Seat_pneumatics-Massage_intensity_level,0 ,8
ENG253224-ENG259581-Seat_pneumatics-Massage_programs,0 ,8
ENG253224-ENG259920-Seat_pneumatics-occupancy_passenger_side,5 ,8
ENG253224-ENG259260-Seat_pneumatics-Popup_knockout_time,25 min,8
ENG253224-ENG259408-Seat_pneumatics-Seat_pneumatics_adjustment_passenger_side,not installed ,8
ENG253224-ENG259024-Seat_pneumatics-Velocity_limit,10 km/h,8
ENG253224-ENG260841-Seat_pneumatics-Velocity_min,10 km/h,8
ENG253090-ENG261034-Seat_pneumatics_massage_program_allocation-massage_program_allocation_01,1 ,6
ENG253090-ENG258845-Seat_pneumatics_massage_program_allocation-massage_program_allocation_02,2 ,6
ENG253090-ENG258718-Seat_pneumatics_massage_program_allocation-massage_program_allocation_03,5 ,6
ENG253090-ENG260661-Seat_pneumatics_massage_program_allocation-massage_program_allocation_04,1 ,6
ENG253090-ENG258113-Seat_pneumatics_massage_program_allocation-massage_program_allocation_05,2 ,6
ENG253090-ENG259726-Seat_pneumatics_massage_program_allocation-massage_program_allocation_06,5 ,6
ENG253283-ENG258595-Signal_mapping_tsg-verzoegerung_swc_signale,0 ms,4
ENG253283-ENG260734-Signal_mapping_tsg-Zeitbasis_0,50 ms,4
ENG253283-ENG260177-Signal_mapping_tsg-Zeitbasis_1,250 ms,4
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,5000 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,5000 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,400 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG289599-SMLS_konfig_entw-lrh_taster_haengt_aus,50 ms,48
ENG153742-ENG289600-SMLS_konfig_entw-lrh_taster_haengt_ein,60 s,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,100 ms,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,250 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,200 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,200 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,2000 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,1000 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,30 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,5.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,300 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG253011-MAS10520-Special_function-Special function 1,not installed ,4
ENG253011-SFT00048-Special_function-Special Function 2,not enabled ,4
ENG253011-ENG260472-Special_function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4
ENG141635-ENG260621-Spiegelverstellung-cp_Komfortbedienung_Spiegel_anklappen,not active ,3
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,active ,3
ENG141635-ENG258306-Spiegelverstellung-Menuesteuerung_Spiegelabsenkung,not active ,3
ENG141635-ENG259505-Spiegelverstellung-Menuesteuerung_synchrone_Spiegelverstellung,active ,3
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,not active ,3
ENG141635-ENG260424-Spiegelverstellung-Spiegelanklappen_bei_Verriegelung,active ,3
ENG141635-ENG260252-Spiegelverstellung-Spiegelverstellung_Synchron,active ,3
ENG253125-ENG260641-SRA-p_sra_bcm_temperaturgrenze,0 °C,8
ENG253125-ENG260115-SRA-p_sra_geschwindigkeitsgrenze,0 km/h,8
ENG253125-ENG259607-SRA-p_sra_nach_t_frontwaschendauer,0 ms,8
ENG253125-ENG259677-SRA-p_sra_obere_aussentemperaturgrenze,-100 °C,8
ENG253125-ENG261148-SRA-p_sra_untere_aussentemperaturgrenze,-100 °C,8
ENG253125-ENG260015-SRA-p_t_sra_ueberlast,0 s,8
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG253353-ENG260527-Störungsmeldungen Licht/Wischwasch-p_Lichtrouter_meldung_ausmaskiert,00 ,15
ENG253353-ENG260368-Störungsmeldungen Licht/Wischwasch-p_t_LDS_defekt_meldung,10 s,15
ENG253353-ENG260726-Störungsmeldungen Licht/Wischwasch-p_t_RLS_Meldung,2000 ms,15
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.04 s,21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.04 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.04 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.08 s,21
ENG141663-ENG258796-Suchbeleuchtung_allgemein-Eingabemedium Suchbeleuchtung von ALM,not active ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,6.9 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,1.8 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.08 s,21
ENG141663-ENG260116-Suchbeleuchtung_allgemein-Suchbeleuchtung PSO2.0 Teilnehmer,active ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 ,21
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 lx,22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 lx,22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 lx,22
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 ,12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 ,12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 ,12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 ,12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 ,12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,3.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,3.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,11.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %,12
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 ,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 ,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 ,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 ,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 ,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 %,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 %,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 %,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 %,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 %,10
ENG253155-ENG115658-Suchbeleuchtung_KL_58xs_max-x0,0 lx,8
ENG253155-ENG101574-Suchbeleuchtung_KL_58xs_max-X1,8 lx,8
ENG253155-ENG99557-Suchbeleuchtung_KL_58xs_max-X2,50 lx,8
ENG253155-ENG102140-Suchbeleuchtung_KL_58xs_max-X3,500 lx,8
ENG253155-ENG115659-Suchbeleuchtung_KL_58xs_max-y0,100.0 ,8
ENG253155-ENG99777-Suchbeleuchtung_KL_58xs_max-Y1,100.0 ,8
ENG253155-ENG100480-Suchbeleuchtung_KL_58xs_max-Y2,100.0 ,8
ENG253155-ENG100773-Suchbeleuchtung_KL_58xs_max-Y3,100.0 ,8
ENG253251-ENG115658-Suchbeleuchtung_KL_58xs_min-x0,0 lx,8
ENG253251-ENG101574-Suchbeleuchtung_KL_58xs_min-X1,8 lx,8
ENG253251-ENG99557-Suchbeleuchtung_KL_58xs_min-X2,50 lx,8
ENG253251-ENG102140-Suchbeleuchtung_KL_58xs_min-X3,500 lx,8
ENG253251-ENG115659-Suchbeleuchtung_KL_58xs_min-y0,6.0 ,8
ENG253251-ENG99777-Suchbeleuchtung_KL_58xs_min-Y1,6.0 ,8
ENG253251-ENG100480-Suchbeleuchtung_KL_58xs_min-Y2,100.0 ,8
ENG253251-ENG100773-Suchbeleuchtung_KL_58xs_min-Y3,100.0 ,8
ENG153970-ENG115658-Suchbeleuchtung_KL_58xs_PWM-x0,0.0 ,6
ENG153970-ENG101574-Suchbeleuchtung_KL_58xs_PWM-X1,50.0 ,6
ENG153970-ENG99557-Suchbeleuchtung_KL_58xs_PWM-X2,100.0 ,6
ENG153970-ENG115659-Suchbeleuchtung_KL_58xs_PWM-y0,0.0 %,6
ENG153970-ENG99777-Suchbeleuchtung_KL_58xs_PWM-Y1,50.0 %,6
ENG153970-ENG100480-Suchbeleuchtung_KL_58xs_PWM-Y2,100.0 %,6
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 ,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 ,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 ,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 ,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 ,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 %,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 %,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 %,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 %,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 %,10
ENG253314-ENG115658-Suchbeleuchtung_KL_58xt_min-x0,0 lx,8
ENG253314-ENG101574-Suchbeleuchtung_KL_58xt_min-X1,8 lx,8
ENG253314-ENG99557-Suchbeleuchtung_KL_58xt_min-X2,50 lx,8
ENG253314-ENG102140-Suchbeleuchtung_KL_58xt_min-X3,500 lx,8
ENG253314-ENG115659-Suchbeleuchtung_KL_58xt_min-y0,6.0 ,8
ENG253314-ENG99777-Suchbeleuchtung_KL_58xt_min-Y1,6.0 ,8
ENG253314-ENG100480-Suchbeleuchtung_KL_58xt_min-Y2,100.0 ,8
ENG253314-ENG100773-Suchbeleuchtung_KL_58xt_min-Y3,100.0 ,8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 ,6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 ,6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 ,6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,24
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,24
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,24
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,24
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,24
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1021 lx,24
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,24
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,160 ,24
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,300 ,24
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,380 ,24
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,440 ,24
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,24
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ,10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,100 ,10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,150 ,10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,200 ,10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,255 ,10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 %,10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 %,10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 %,10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 %,10
ENG249751-Two_keys,active ,3
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG253297-ENG263583-Unterdrückung Zündungswarnung-Ausgabe MoLaWa_AAW,active ,8
ENG253297-ENG263581-Unterdrückung Zündungswarnung-Entprellung_MoLaWa,1.5 ,8
ENG253297-ENG263504-Unterdrückung Zündungswarnung-Entprellzeit Statuswechsel Belegt zu nicht Belegt,0.8 s,8
ENG253297-ENG263522-Unterdrückung Zündungswarnung-Entprellzeit Statuswecsel  nicht Belegt zu Belegt,0.0 s,8
ENG253297-ENG263576-Unterdrückung Zündungswarnung-Freigabeentprellung Abschaltung nach EM,60 s,8
ENG253297-ENG263531-Unterdrückung Zündungswarnung-Unterdrückung der Zündungswarnung,active ,8
ENG252991-Vehicle configuration,activated ,1
ENG253245-ENG261297-verbauliste_subcan-Digitale Dachantenne,not installed ,4
ENG253245-ENG260206-verbauliste_subcan-kessy_io,installed ,4
ENG253245-ENG260575-verbauliste_subcan-nfc_miko,not installed ,4
ENG253245-ENG260904-verbauliste_subcan-nfc_tgs,not installed ,4
ENG253245-ENG260755-verbauliste_subcan-rsad_hl,installed ,4
ENG253245-ENG259512-verbauliste_subcan-rsad_hr,installed ,4
ENG253245-ENG259217-verbauliste_subcan-rsad_in,not installed ,4
ENG253245-ENG258528-verbauliste_subcan-rsad_vl,installed ,4
ENG253245-ENG259345-verbauliste_subcan-rsad_vr,installed ,4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,6
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,6
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,6
ENG141634-ENG116655-Verdecksteuergeraet-Kessy Komfortbedienung Reichweitenbegrenzung,active ,6
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,6
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,6
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,6
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,6
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active ,6
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,6
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,6
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,6
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,6
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,6
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,6
ENG253327-ENG277083-Verlassenswarnung und Standlichtnachlauf-Ausgabedauer Wegrollwarnung,10 s,8
ENG253327-ENG261189-Verlassenswarnung und Standlichtnachlauf-Ausgabeverhalten Verlassenswarnung,VLW mit VLK2.2 Kriterien ,8
ENG253327-ENG261016-Verlassenswarnung und Standlichtnachlauf-Ausgabeverzögerung der Verlassenswarnung,1.4 s,8
ENG253327-ENG277084-Verlassenswarnung und Standlichtnachlauf-Ausgabeverzögerung der Wegrollwarnung,1.0 s,8
ENG253327-ENG261326-Verlassenswarnung und Standlichtnachlauf-Entprellung Degradierte Verlassenswarnung,1.6 s,8
ENG253327-ENG259356-Verlassenswarnung und Standlichtnachlauf-Entprellung Verlassenswarnung,5 min,8
ENG253327-ENG258196-Verlassenswarnung und Standlichtnachlauf-Fahrzeuggeschwindigkeit zur Stillstandserkennung,3 km/h,8
ENG253327-ENG116720-Verlassenswarnung und Standlichtnachlauf-Standlicht-Nachlaufzeit,30 min,8
ENG253327-ENG277124-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Standlichtnachlauf,not active ,8
ENG253327-ENG277125-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Verlassenswarnung,equippt ,8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 00 00 ,28
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 00 00 ,28
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 00 00 ,28
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 00 00 ,28
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,28
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,28
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,28
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,28
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,28
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,28
ENG159625-ENG142259-Virtual pedal-Kick_and_close,not installed ,8
ENG159625-ENG115869-Virtual pedal-Virtuelles_Pedal,not active ,8
ENG159625-ENG259761-Virtual pedal-Virtuelles_Pedal_HMI_Auswahl,active ,8
ENG159625-ENG126611-Virtual pedal-virtuelles_pedal_HMI_einstellbar,not active ,8
ENG253214-ENG261193-Virtuelles_Pedal_Global-Bremslichtquittierung,not active ,4
ENG253214-ENG261115-Virtuelles_Pedal_Global-Bremslichtquittierung bei offenem Heckdeckel bzw. -klappe,not active ,4
ENG253214-ENG259151-Virtuelles_Pedal_Global-Quittierungslicht_Max,5000 ms,4
ENG253214-ENG273673-Virtuelles_Pedal_Global-Sperrzeit_Bewertung_Spotlight,300 ms,4
ENG253214-ENG142257-Virtuelles_Pedal_Global-Virtuelles_Pedal_Verbau,not installed ,4
ENG154424-IDE05534-Waschen-Headlamp washer system,not installed ,8
ENG154424-ENG154706-Waschen-Mindestwaschzeit_Frontwischer,0 ms,8
ENG154424-ENG249933-Waschen-RVC_Speed_Hysteresis,5 km/h,8
ENG154424-ENG249934-Waschen-RVC_Speed_max,50 km/h,8
ENG154424-ENG260022-Waschen-RVC_Waschen,not installed ,8
ENG154424-ENG249936-Waschen-RVC_Waschen_HMI,not active ,8
ENG154424-ENG260162-Waschen-Time_RVC_cleaning_Pumpe_active_BCM,1.5 s,8
ENG154424-ENG281090-Waschen-Transportmodus_SRA,not active ,8
ENG154424-ENG258116-Waschen-Waschen_ohne_KL15,not active ,8
ENG154424-ENG260669-Waschen-Wiederstart_Restfunktionen,not active ,8
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG261175-Waschen_Parameter-pa_t_wasch_min_heck,1200 ms,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG253306-ENG259934-Wascher_pumpe-p_n_Spielschutz_Wascherpumpen,10 ,4
ENG253306-ENG258230-Wascher_pumpe-p_t_Delay_Frontwaschen,0 ms,4
ENG253306-ENG260892-Wascher_pumpe-p_t_DWP_Blockiererkennung,100 ms,4
ENG253306-ENG259530-Wascher_pumpe-p_t_Wascherpumpe_max,10 s,4
ENG253287-ENG261269-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_defined_rpm,500.00 ,11
ENG253287-ENG258373-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOSignal_Timer1,3000 ms,11
ENG253287-ENG258259-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOsignal_Timer2,3000 ms,11
ENG141651-ENG258596-ZV allgemein-abgesichertes_Safen_aktiv,not active ,6
ENG141651-ENG260901-ZV allgemein-Bedienstellen_tankklappenentriegelung,via_ZV ,6
ENG141651-ENG173067-ZV allgemein-central_locking_system_deadlock_mechanism,safe_function_not_active ,6
ENG141651-ENG259465-ZV allgemein-Funk_bei_Kl15_ein,not active ,6
ENG141651-ENG260878-ZV allgemein-kein_Safe_bei_IRUE_Abwahl,not active ,6
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,6
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,6
ENG141651-ENG261270-ZV allgemein-rollsicherung_ZV_plausibilisierung,not active ,6
ENG141651-ENG260049-ZV allgemein-Rueckmeldung_TKL,active ,6
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale_Entriegelung ,6
ENG141651-ENG258274-ZV allgemein-ZV_Verriegelung_ueber_SZ_bei_offener_FT_zulassen,not active ,6
ENG141653-ENG258843-ZV Heck-Direktauswurf_heckdeckel,not active ,6
ENG141653-ENG258544-ZV Heck-eingeschränkte_Freigabe_HD_Innentaste,not active ,6
ENG141653-ENG260874-ZV Heck-Elektrische_Laderaumabdeckung_Aktiviert,not installed ,6
ENG141653-ENG259200-ZV Heck-Elektrische_Laderaumabdeckung_verbaut,not installed ,6
ENG141653-ENG263593-ZV Heck-HD_Innentaster_bei_ext_verriegelt,not active ,6
ENG141653-ENG259391-ZV Heck-HDF_IT_direkt,not installed ,6
ENG141653-ENG260877-ZV Heck-Heck_autolock,active ,6
ENG141653-ENG259349-ZV Heck-Heck_ohne_softtouch,not active ,6
ENG141653-ENG260581-ZV Heck-Heckschloss_mit_VR,Yes ,6
ENG141653-ENG260712-ZV Heck-Heckschloss_rastengesteuert,contact_control ,6
ENG141653-ENG259467-ZV Heck-Heckschloss_Typ,1 or 2 notch rear actuator ,6
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.8 s,6
ENG141653-ENG248302-ZV Heck-unlocking_trunk_lid_via_double_actuation,not active ,6
ENG141653-ENG140934-ZV Heck-valet_parking,not active ,6
ENG141653-ENG258713-ZV Heck-ZV_entriegelt_heckdeckel,active ,6
ENG253049-ENG260834-ZV Komfort_Fensterheber-Ausstiegspanel_Automatiklauf,not active ,8
ENG253049-ENG261010-ZV Komfort_Fensterheber-BAP_komfortschließen_brasilien,not active ,8
ENG253049-ENG259807-ZV Komfort_Fensterheber-el_fh_hinten,not installed ,8
ENG253049-ENG116663-ZV Komfort_Fensterheber-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG253049-ENG259968-ZV Komfort_Fensterheber-Fensterheber_freigabnachlauf_busruhe,active ,8
ENG253049-ENG258141-ZV Komfort_Fensterheber-Freigabenachlauf_abbruch_bei_tueroeffnen,active ,8
ENG253049-ENG260611-ZV Komfort_Fensterheber-KL_15_aus_fh_freigabenachlauf,active ,8
ENG253049-ENG159639-ZV Komfort_Fensterheber-Komfort_oeffnen,not active ,8
ENG253049-ENG273538-ZV Komfort_Fensterheber-Komfort_schließen,active ,8
ENG253049-ENG258991-ZV Komfort_Fensterheber-Komfortbedienung_ffb_aktiv,active ,8
ENG253049-ENG258982-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_funk,active ,8
ENG253049-ENG260329-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_sz,not active ,8
ENG253049-ENG259463-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_fh_taster,active ,8
ENG253049-ENG259865-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_funk,active ,8
ENG253049-ENG149198-ZV Komfort_Fensterheber-Komfortbedienung_global,active ,8
ENG253049-ENG260481-ZV Komfort_Fensterheber-komfortbedienung_global_hmi,adjustable ,8
ENG253049-ENG259275-ZV Komfort_Fensterheber-Komfortfunktion_im_Transportmodus,not active ,8
ENG253049-ENG116642-ZV Komfort_Fensterheber-Komfortoeffnen nur FH Fahrertuer,not active ,8
ENG253049-ENG155244-ZV Komfort_Fensterheber-Komfortschliessen_Brasilien,not active ,8
ENG263451-ENG252093-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abbruchblinken_Heck,not active ,7
ENG263451-ENG248659-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,7
ENG263451-ENG248660-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,7
ENG263451-ENG248661-ZV NFZ - Elektronische Rueckwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,7
ENG263451-ENG248662-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,7
ENG263451-ENG263534-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Oeffnungsblinken_Heckauswurf,not active ,7
ENG263451-ENG248664-ZV NFZ - Elektronische Rueckwandklappe-eRWK_ohne_FFB_HDF,not active ,7
ENG263451-ENG252079-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,7
ENG263451-ENG252068-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Start_Umfelderkennung,2.0 s,7
ENG263491-ENG263568-ZV NFZ - Tueren HBFS-Schiebetuer HBFS,mechanisch ,2
ENG263491-ENG258359-ZV NFZ - Tueren HBFS-Schlosstyp HBFS,OBWr_Schloss ,2
ENG263491-ENG263538-ZV NFZ - Tueren HBFS-Tuerkontaktmodul HBFS,Yes ,2
ENG263438-ENG263586-ZV NFZ - Tueren HFS-Schiebetuer HFS,mechanisch ,2
ENG263438-ENG258315-ZV NFZ - Tueren HFS-Schlosstyp HFS,OBWr_Schloss ,2
ENG263438-ENG263572-ZV NFZ - Tueren HFS-Tuerkontaktmodul HFS,Yes ,2
ENG253123-ENG259042-ZV Nutzfahrzeuge-SBT_Schloss_direkt,not installed ,5
ENG253123-ENG142041-ZV Nutzfahrzeuge-Schiebetueren_Crafter,not installed ,5
ENG253123-ENG260914-ZV Nutzfahrzeuge-TKM_BFS_verbaut,installed ,5
ENG253123-ENG258445-ZV Nutzfahrzeuge-TKM_FS_verbaut,installed ,5
ENG252999-ENG260270-ZV Quittierungen-Akustische Quittierungsdauer Einfachhorn,short ,6
ENG252999-ENG258724-ZV Quittierungen-Komfort_quittung,active ,6
ENG252999-ENG260606-ZV Quittierungen-Quittierton_beim_zweiten_ZV_AUF_Befehl,not active ,6
ENG252999-ENG258550-ZV Quittierungen-Quittierton_beim_zweiten_ZV_ZU_Befehl,not active ,6
ENG252999-ENG260511-ZV Quittierungen-Quittierton_global,not active ,6
ENG252999-ENG258336-ZV Quittierungen-Quittierungston_bei_entriegeln,not active ,6
ENG252999-ENG263543-ZV Quittierungen-Quittungs_blinken_bei_verriegeln,DELAY ,6
ENG252999-ENG263595-ZV Quittierungen-Quittungs_ton_bei_verriegeln,not active ,6
ENG252999-ENG259470-ZV Quittierungen-Quittungston_hmi_einstellbar,not active ,6
ENG252999-ENG260257-ZV Quittierungen-Quittungston_ueber_hupe,not active ,6
ENG141652-ENG258598-ZV Türkonfiguration-Fzg_mit_Vier_Tueren,No ,2
ENG141652-ENG260173-ZV Türkonfiguration-Schloesser_direkt_gesteuert,vordere via CAN angeschlossen: hinten diskre ,2
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,2
ENG141652-ENG258913-ZV Türkonfiguration-ZV Schlosstyp,Einmotorenschloss ohne Safe ,2
ENG253276-ENG173074-ZV_Autolock-automatic_unlock_nar,not active ,2
ENG253276-ENG116621-ZV_Autolock-automatisches Entriegeln,active ,2
ENG253276-ENG115756-ZV_Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,2
ENG253276-ENG260929-ZV_Autolock-ZV_autolock_autounlock_hmi,not active ,2
ENG253027-ENG173641-ZV_Crash-central_locking_system_emergency_assist,active ,2
ENG253027-ENG259575-ZV_Crash-Verzoegerung_ZV_Entriegelung_bei_Seitencrash,active ,2
ENG263484-ENG263546-ZV_HW_Router-PIN_A11,Ansteuerung KiSi/Safe ,5
ENG263484-ENG263569-ZV_HW_Router-PIN_A31,LuT zentral oder Tankklappenrückmeldung ,5
ENG263484-ENG263532-ZV_HW_Router-PIN_A32,Softtouch Heckdeckel ,5
ENG263484-ENG263567-ZV_HW_Router-PIN_A33,eKisi-Status Tür hinten rechts ,5
ENG263484-ENG263596-ZV_HW_Router-PIN_A35,eKisi-Status Tür hinten links ,5
ENG263484-ENG263575-ZV_HW_Router-PIN_A48,mechan. SBT (TIG/TAG rechts) ,5
ENG263484-ENG263528-ZV_HW_Router-PIN_A49,Hauptraste SBT links ,5
ENG263484-ENG263547-ZV_HW_Router-PIN_A50,mechan. SBT (TIG/TAG links) ,5
ENG263484-ENG263598-ZV_HW_Router-PIN_A51,IRUE/NGS aus oder Heckscheibenbruch ,5
ENG263484-ENG263545-ZV_HW_Router-PIN_A7,Ansteuerung KiSi/Safe ,5
ENG263484-ENG263590-ZV_HW_Router-PIN_C21,Ansteuerung eÖ-Motor links ,5
ENG263484-ENG263523-ZV_HW_Router-PIN_C22,Ansteuerung eÖ-Motor rechts ,5
ENG263484-ENG263565-ZV_HW_Router-PIN_C34,Hauptraste Tür hinten rechts ,5
ENG263484-ENG263571-ZV_HW_Router-PIN_C59,Cockpit-Taste 4 ,5
ENG263427-ENG252063-zv_router_global-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,5
ENG263427-ENG263506-zv_router_global-Elektrischer_SBT_Feststeller_verbaut,not installed ,5
ENG263427-ENG263563-zv_router_global-Elektronische_Kindersicherung_eKiSi,Yes ,5
ENG263427-ENG263551-zv_router_global-FFB_Schiebetuer_entriegelt,No ,5
ENG263427-ENG248688-zv_router_global-Freischaltung_der_Kisi_Auswurffunktion,active ,5
ENG263427-ENG248689-zv_router_global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,not active ,5
ENG263427-ENG248698-zv_router_global-HD_Innentaster_im_Heck,not installed ,5
ENG263427-ENG263588-zv_router_global-Laderaumschliessung_Taster_togglen,not active ,5
ENG263427-ENG263582-zv_router_global-Laderaumtaster_verbaut,not installed ,5
ENG263427-ENG248768-zv_router_global-NFZ_Schliessung,not active ,5
ENG263427-ENG263555-zv_router_global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt,active ,5
ENG263427-ENG259542-zv_router_global-Schiebetuer_verriegeln_bei_offenem_tank,active ,5
ENG263427-ENG263553-zv_router_global-Schiebetuertaste_Armaturentafel_bei extern_verriegelt,not active ,5
ENG263427-ENG133390-zv_router_global-Wiederverriegelung_Laderaum,not installed ,5
Elapsed Time: 03:06
adpmap-10-5WA-919-298-A_WV1ZZZSKZMX050719-20210914-1405.CSV
    SW:5WA-919-298-A   HW:5WA-919-298 ---  Park/Steer Assist
    Component:PLA 12K Kanal H04 0230, Coding:8200026011
    EV_EPHBO2CVW3800000,002028,EV_EPHBO2CVW3800000_VW38.rod
    Tuesday,14,September,2021,14:05:56:34165
    VCDS Version: Release 21.9.0  Data version: 20210824 DS330.0
    VCID: 54F175BC6E7318FB53A-8000
IDE00845-Wheel circumference,1950 mm,2
IDE01165-Park assist activation tone,OFF ,1
IDE01167-Convertible offset for volume level 1,1 ,1
IDE02328-Distance to curb,15 cm,1
IDE02329-Allowance for vehicle fittings (width),0 cm,1
IDE02333-Allowance for vehicle fittings (length),0 cm,1
IDE14666-Parking aid: personalization,not activated ,1
MAS05448-Vehicle path display,not activated ,1
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners,0.000 1/m,6
MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners,0.000 1/m,6
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang,0.000 m,6
MAS15621-Restart information,not activated ,1
MAS21139-MAS21140-Manually determined wheel sizes-Manually determined tire size front left,0 mm,8
MAS21139-MAS21141-Manually determined wheel sizes-Manually determined tire size front right,0 mm,8
MAS21139-MAS21142-Manually determined wheel sizes-Manually determined tire size rear left,0 mm,8
MAS21139-MAS21143-Manually determined wheel sizes-Manually determined tire size rear right,0 mm,8
Elapsed Time: 00:04
adpmap-13-5WA-907-572-B_WV1ZZZSKZMX050719-20210914-1406.CSV
    SW:5WA-907-572-B   HW:5WA-907-572 ---  Auto Dist. Reg
    Component:ACC Bosch MQB H20 0395, Coding:0E0200070077404512474000000000044E4020000000000000000000000000
    EV_FRONTRADARBOSCHVW380,004017,EV_FRONTRADARBOSCHVW380_004_VW38.rod
    Tuesday,14,September,2021,14:06:03:34165
    VCID: 4DC760D84D5949331C4-8018
IDE01949-Distance basic setting option,On ,1
IDE05815-Sail function,Activating ,1
IDE08935-Expanded restart function,On ,1
IDE09564-Distance change via speed adjustment,On ,1
IDE09565-Prioritized target object display,OFF ,1
IDE12516-Predictive speed limit regulation,not activated ,1
IDE15695-Front radar-based localization,Deactivated ,1
MAS19336-Active participant function activated,Deactivated ,1
Elapsed Time: 00:04
adpmap-15-1EA-959-655-CH_WV1ZZZSKZMX050719-20210914-1406.CSV
    SW:1EA-959-655-CH   HW:1EA-959-655-CH ---  Airbags
    Component:VW40Airbag    009 0166, Coding:88CC008000E0C00000000000000000005154000020AA00005C00F680002B0065
    EV_AirbaVW40ALVVW38X,001012,EV_AirbaVW40ALVVW38X.rod
    Tuesday,14,September,2021,14:06:11:34165
    VCID: 094F94C8F9B11513F0C-805C
IDE05178-Conclude start of operation,completed ,1
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
IDE06527-IDE06311-Adaptation pre-crash-Left seat belt tensioner,not defined ,4
IDE06527-IDE06312-Adaptation pre-crash-Right seat belt tensioner,not defined ,4
IDE06527-IDE07271-Adaptation pre-crash-Belt tensioner second row right,not defined ,4
IDE06527-IDE07274-Adaptation pre-crash-Belt tensioner second row left,not defined ,4
IDE06527-IDE12159-Adaptation pre-crash-Belt feed control module for 2nd row left,not defined ,4
IDE06527-IDE12160-Adaptation pre-crash-Belt feed control module for 2nd row right,not defined ,4
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,3
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,3
IDE07160-ENG258305-Control module switch-off: switch-off time-BusKnockOut_Tmr_NVEM,0 min,3
IDE07277-Programming of belt tensioner 2nd row: left,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,1024
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,activated ,8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12258-Adaptation airbag 2-Assistance-System-Monitor,activated ,8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,not defined ,8
IDE12055-IDE14841-Adaptation airbag 2-Seat Belt Tensioner Igniter: center 3rd row,not defined ,8
IDE12055-IDE15776-Adaptation airbag 2-Deactivation igniter: DC/DC converter,not defined ,8
IDE12055-IDE16063-Adaptation airbag 2-Igniter for high-voltage battery 3 open circuit,not defined ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
IDE15773-MAS05774-Wireless belt request/seat occupancy detection-2nd Row Left,00 EB 01 4E DC 94 ,72
IDE15773-MAS05775-Wireless belt request/seat occupancy detection-2nd Row Right,9F DB 01 4E DC 94 ,72
IDE15773-MAS14174-Wireless belt request/seat occupancy detection-2nd Row Center,A1 DB 01 4E DC 94 ,72
IDE15773-MAS20986-Wireless belt request/seat occupancy detection-1st Row Center,FF FF FF FF FF FF ,72
IDE15773-MAS20987-Wireless belt request/seat occupancy detection-3rd Row Center,FF FF FF FF FF FF ,72
IDE15773-MAS20988-Wireless belt request/seat occupancy detection-4th Row Center,FF FF FF FF FF FF ,72
IDE15773-MAS25344-Wireless belt request/seat occupancy detection-3rd Row Left,FF FF FF FF FF FF ,72
IDE15773-MAS25345-Wireless belt request/seat occupancy detection-4th Row Left,FF FF FF FF FF FF ,72
IDE15773-MAS25346-Wireless belt request/seat occupancy detection-4th Row Right,FF FF FF FF FF FF ,72
IDE15773-MAS25347-Wireless belt request/seat occupancy detection-3rd Row Right,FF FF FF FF FF FF ,72
IDE15773-MAS25348-Wireless belt request/seat occupancy detection-1st Row Right,FF FF FF FF FF FF ,72
IDE15773-MAS25349-Wireless belt request/seat occupancy detection-1st Row Left,FF FF FF FF FF FF ,72
MAS00975-IDE00947-Airbag adaptations-Driver side rear curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Frt.passenger side rear curtain airbag igniter,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
MAS00975-IDE07192-Airbag adaptations-Thorax airbag igniter,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Driver side seat belt tensioner igniter 3,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Front passenger side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,activated ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00023-Airbag adaptations-Driver side active head restraint igniter,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Igniter for active head restraint on frt. passenger side,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupied recognition passenger side,activated ,8
Elapsed Time: 00:08
adpmap-17-5H0-920-340-A_WV1ZZZSKZMX050719-20210914-1400.CSV
    SW:5H0-920-340-A   HW:5H0-920-340-A ---  Instruments
    Component:KOMBI         203 3460, Coding:04A41447639C00080180220B2000000800101C00
    EV_DashBoardVDDMQB37W,003032,EV_DashBoardVDDMQB37W_003_VW38.rod
    Tuesday,14,September,2021,14:00:32:34165
    VCID: 2019E96C6A4BB45B872-8074
IDE00301-Mileage,1649 km,3
IDE00343-Language variant,Turkish ,1
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,122 d,2
IDE00820-ENG98466-Activating and deactivating all development messages-CAN,not active ,1
IDE00820-ENG148062-Activating and deactivating all development messages-Ethernet,not active ,1
IDE02489-Display depiction,Variant 1 ,1
IDE03346-IDE00301-Units adjusted-Mileage,Kilometers ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,Liters ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG262858-Service-key settings-p_deactivate_SK-Sub_Function_Current_Data,On ,5
IDE03568-ENG262855-Service-key settings-p_deactivate_SK-Sub_Function_Daily_Data,On ,5
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,OFF ,5
IDE07221-Cylinder shut-off,Readout ,1
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-IDE12722-Configuration of displayable contents-Driving profile display,No display ,4
IDE11472-MAS01833-Configuration of displayable contents-Charge air pressure,not active ,4
IDE11472-MAS03555-Configuration of displayable contents-Lap counter,not active ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS05757-Configuration of displayable contents-Engine torque,not active ,4
IDE11472-MAS14767-Configuration of displayable contents-Convenience tire pressure warning display,No display ,4
IDE11472-MAS15298-Configuration of displayable contents-Night vision system automatic triggering,not active ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE11472-MAS19327-Configuration of displayable contents-Engine power,not active ,4
IDE11472-MAS19328-Configuration of displayable contents-Transmission temperature,not active ,4
IDE11472-MAS19329-Configuration of displayable contents-G-meter,not active ,4
IDE11472-MAS19330-Configuration of displayable contents-Torque distribution,not active ,4
IDE12050-Acoustic: drive position R,active ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,not active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12792-IDE00301-Personalization of user account 1-Mileage,Kilometers ,70
IDE12792-MAS01230-Personalization of user account 1-Date,dd_mm_yy ,70
IDE12792-MAS01456-Personalization of user account 1-Speed,Kilometers per hour ,70
IDE12792-MAS02201-Personalization of user account 1-Temperature,°C ,70
IDE12792-MAS02957-Personalization of user account 1-Time,24h ,70
IDE12792-MAS03032-Personalization of user account 1-Volume,Liters ,70
IDE12792-MAS03034-Personalization of user account 1-Pressure,bar ,70
IDE12792-MAS05637-Personalization of user account 1-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12792-MAS05638-Personalization of user account 1-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12792-MAS05875-Personalization of user account 1-Average consumption: electric drive,kWh per 100 km ,70
IDE12792-Personalization of user account 1-,not active ,70
IDE12792-ENG154881-Personalization of user account 1-Active_design,0 ,70
IDE12792-ENG154882-Personalization of user account 1-Active_view,0 ,70
IDE12792-ENG155000-Personalization of user account 1-DC_aktiverSpeicherplatz,0 ,70
IDE12792-ENG155001-Personalization of user account 1-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12792-ENG155002-Personalization of user account 1-DC_linkeTubeninformation,00 ,70
IDE12792-ENG155003-Personalization of user account 1-DC_rechteTubeninformation,00 ,70
IDE12792-ENG155004-Personalization of user account 1-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155005-Personalization of user account 1-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155006-Personalization of user account 1-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155007-Personalization of user account 1-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155008-Personalization of user account 1-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155009-Personalization of user account 1-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155051-Personalization of user account 1-Display_Average_Consumption,active ,70
IDE12792-ENG155052-Personalization of user account 1-Display_Average_Speed,active ,70
IDE12792-ENG155053-Personalization of user account 1-Display_ComfortPowerConsumption,not active ,70
IDE12792-ENG155054-Personalization of user account 1-Display_ConsumerList,not active ,70
IDE12792-ENG155055-Personalization of user account 1-Display_CoolantTemperature,not active ,70
IDE12792-ENG155056-Personalization of user account 1-Display_CurrentConsumption,active ,70
IDE12792-ENG155057-Personalization of user account 1-Display_DigitalSpeedometer,active ,70
IDE12792-ENG155058-Personalization of user account 1-Display_Distance,active ,70
IDE12792-ENG155059-Personalization of user account 1-Display_DrivingTime,active ,70
IDE12792-ENG155060-Personalization of user account 1-Display_DualSpeedometer,not active ,70
IDE12792-ENG155061-Personalization of user account 1-Display_Laptimer,not active ,70
IDE12792-ENG155062-Personalization of user account 1-Display_LiveTips,not active ,70
IDE12792-ENG155063-Personalization of user account 1-Display_Nachtankmenge,not active ,70
IDE12792-ENG155064-Personalization of user account 1-Display_OilTemperature,active ,70
IDE12792-ENG155065-Personalization of user account 1-Display_Range,active ,70
IDE12792-ENG155066-Personalization of user account 1-Display_ResetTime,not active ,70
IDE12792-ENG155067-Personalization of user account 1-Display_SpeedWarning,not active ,70
IDE12792-ENG155068-Personalization of user account 1-Display_VZA,active ,70
IDE12792-ENG155069-Personalization of user account 1-Display_ZeroEmission_Distance,not active ,70
IDE12792-ENG155070-Personalization of user account 1-Display_ZeroEmission_Time,not active ,70
IDE12792-ENG155246-Personalization of user account 1-LastMode_HMI_global_active_layout,0 ,70
IDE12792-ENG155247-Personalization of user account 1-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12792-ENG155248-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12792-ENG155249-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12792-ENG155250-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12792-ENG155251-Personalization of user account 1-LastMode_HMI_HistoryState_main,0 ,70
IDE12792-ENG155252-Personalization of user account 1-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12792-ENG155253-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12792-ENG155254-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12792-ENG155255-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12792-ENG155256-Personalization of user account 1-LastMode_HMI_HistoryState_sport,0 ,70
IDE12792-ENG155257-Personalization of user account 1-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12792-ENG155258-Personalization of user account 1-LastMode_HMI_MFA_store,0 ,70
IDE12792-ENG155259-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12792-ENG155260-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12792-ENG155261-Personalization of user account 1-LastMode_v_Kunde_aktiv,not active ,70
IDE12792-ENG155262-Personalization of user account 1-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12792-ENG155263-Personalization of user account 1-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12792-ENG262859-Personalization of user account 1-speed_value,0 ,70
IDE12792-ENG263509-Personalization of user account 1-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12794-IDE00301-Personalization of user account 2-Mileage,Kilometers ,70
IDE12794-MAS01230-Personalization of user account 2-Date,dd_mm_yy ,70
IDE12794-MAS01456-Personalization of user account 2-Speed,Kilometers per hour ,70
IDE12794-MAS02201-Personalization of user account 2-Temperature,°C ,70
IDE12794-MAS02957-Personalization of user account 2-Time,24h ,70
IDE12794-MAS03032-Personalization of user account 2-Volume,Liters ,70
IDE12794-MAS03034-Personalization of user account 2-Pressure,bar ,70
IDE12794-MAS05637-Personalization of user account 2-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12794-MAS05638-Personalization of user account 2-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12794-MAS05875-Personalization of user account 2-Average consumption: electric drive,kWh per 100 km ,70
IDE12794-Personalization of user account 2-,not active ,70
IDE12794-ENG154881-Personalization of user account 2-Active_design,0 ,70
IDE12794-ENG154882-Personalization of user account 2-Active_view,0 ,70
IDE12794-ENG155000-Personalization of user account 2-DC_aktiverSpeicherplatz,0 ,70
IDE12794-ENG155001-Personalization of user account 2-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12794-ENG155002-Personalization of user account 2-DC_linkeTubeninformation,00 ,70
IDE12794-ENG155003-Personalization of user account 2-DC_rechteTubeninformation,00 ,70
IDE12794-ENG155004-Personalization of user account 2-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155005-Personalization of user account 2-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155006-Personalization of user account 2-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155007-Personalization of user account 2-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155008-Personalization of user account 2-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155009-Personalization of user account 2-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155051-Personalization of user account 2-Display_Average_Consumption,active ,70
IDE12794-ENG155052-Personalization of user account 2-Display_Average_Speed,active ,70
IDE12794-ENG155053-Personalization of user account 2-Display_ComfortPowerConsumption,not active ,70
IDE12794-ENG155054-Personalization of user account 2-Display_ConsumerList,not active ,70
IDE12794-ENG155055-Personalization of user account 2-Display_CoolantTemperature,not active ,70
IDE12794-ENG155056-Personalization of user account 2-Display_CurrentConsumption,active ,70
IDE12794-ENG155057-Personalization of user account 2-Display_DigitalSpeedometer,active ,70
IDE12794-ENG155058-Personalization of user account 2-Display_Distance,active ,70
IDE12794-ENG155059-Personalization of user account 2-Display_DrivingTime,active ,70
IDE12794-ENG155060-Personalization of user account 2-Display_DualSpeedometer,not active ,70
IDE12794-ENG155061-Personalization of user account 2-Display_Laptimer,not active ,70
IDE12794-ENG155062-Personalization of user account 2-Display_LiveTips,not active ,70
IDE12794-ENG155063-Personalization of user account 2-Display_Nachtankmenge,not active ,70
IDE12794-ENG155064-Personalization of user account 2-Display_OilTemperature,active ,70
IDE12794-ENG155065-Personalization of user account 2-Display_Range,active ,70
IDE12794-ENG155066-Personalization of user account 2-Display_ResetTime,not active ,70
IDE12794-ENG155067-Personalization of user account 2-Display_SpeedWarning,not active ,70
IDE12794-ENG155068-Personalization of user account 2-Display_VZA,active ,70
IDE12794-ENG155069-Personalization of user account 2-Display_ZeroEmission_Distance,not active ,70
IDE12794-ENG155070-Personalization of user account 2-Display_ZeroEmission_Time,not active ,70
IDE12794-ENG155246-Personalization of user account 2-LastMode_HMI_global_active_layout,0 ,70
IDE12794-ENG155247-Personalization of user account 2-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12794-ENG155248-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12794-ENG155249-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12794-ENG155250-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12794-ENG155251-Personalization of user account 2-LastMode_HMI_HistoryState_main,0 ,70
IDE12794-ENG155252-Personalization of user account 2-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12794-ENG155253-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12794-ENG155254-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12794-ENG155255-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12794-ENG155256-Personalization of user account 2-LastMode_HMI_HistoryState_sport,0 ,70
IDE12794-ENG155257-Personalization of user account 2-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12794-ENG155258-Personalization of user account 2-LastMode_HMI_MFA_store,0 ,70
IDE12794-ENG155259-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12794-ENG155260-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12794-ENG155261-Personalization of user account 2-LastMode_v_Kunde_aktiv,not active ,70
IDE12794-ENG155262-Personalization of user account 2-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12794-ENG155263-Personalization of user account 2-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12794-ENG262859-Personalization of user account 2-speed_value,0 ,70
IDE12794-ENG263509-Personalization of user account 2-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12796-IDE00301-Personalization of user account 3-Mileage,Kilometers ,70
IDE12796-MAS01230-Personalization of user account 3-Date,dd_mm_yy ,70
IDE12796-MAS01456-Personalization of user account 3-Speed,Kilometers per hour ,70
IDE12796-MAS02201-Personalization of user account 3-Temperature,°C ,70
IDE12796-MAS02957-Personalization of user account 3-Time,24h ,70
IDE12796-MAS03032-Personalization of user account 3-Volume,Liters ,70
IDE12796-MAS03034-Personalization of user account 3-Pressure,bar ,70
IDE12796-MAS05637-Personalization of user account 3-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12796-MAS05638-Personalization of user account 3-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12796-MAS05875-Personalization of user account 3-Average consumption: electric drive,kWh per 100 km ,70
IDE12796-Personalization of user account 3-,not active ,70
IDE12796-ENG154881-Personalization of user account 3-Active_design,0 ,70
IDE12796-ENG154882-Personalization of user account 3-Active_view,0 ,70
IDE12796-ENG155000-Personalization of user account 3-DC_aktiverSpeicherplatz,0 ,70
IDE12796-ENG155001-Personalization of user account 3-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12796-ENG155002-Personalization of user account 3-DC_linkeTubeninformation,00 ,70
IDE12796-ENG155003-Personalization of user account 3-DC_rechteTubeninformation,00 ,70
IDE12796-ENG155004-Personalization of user account 3-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155005-Personalization of user account 3-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155006-Personalization of user account 3-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155007-Personalization of user account 3-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155008-Personalization of user account 3-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155009-Personalization of user account 3-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155051-Personalization of user account 3-Display_Average_Consumption,active ,70
IDE12796-ENG155052-Personalization of user account 3-Display_Average_Speed,active ,70
IDE12796-ENG155053-Personalization of user account 3-Display_ComfortPowerConsumption,not active ,70
IDE12796-ENG155054-Personalization of user account 3-Display_ConsumerList,not active ,70
IDE12796-ENG155055-Personalization of user account 3-Display_CoolantTemperature,not active ,70
IDE12796-ENG155056-Personalization of user account 3-Display_CurrentConsumption,active ,70
IDE12796-ENG155057-Personalization of user account 3-Display_DigitalSpeedometer,active ,70
IDE12796-ENG155058-Personalization of user account 3-Display_Distance,active ,70
IDE12796-ENG155059-Personalization of user account 3-Display_DrivingTime,active ,70
IDE12796-ENG155060-Personalization of user account 3-Display_DualSpeedometer,not active ,70
IDE12796-ENG155061-Personalization of user account 3-Display_Laptimer,not active ,70
IDE12796-ENG155062-Personalization of user account 3-Display_LiveTips,not active ,70
IDE12796-ENG155063-Personalization of user account 3-Display_Nachtankmenge,not active ,70
IDE12796-ENG155064-Personalization of user account 3-Display_OilTemperature,active ,70
IDE12796-ENG155065-Personalization of user account 3-Display_Range,active ,70
IDE12796-ENG155066-Personalization of user account 3-Display_ResetTime,not active ,70
IDE12796-ENG155067-Personalization of user account 3-Display_SpeedWarning,not active ,70
IDE12796-ENG155068-Personalization of user account 3-Display_VZA,active ,70
IDE12796-ENG155069-Personalization of user account 3-Display_ZeroEmission_Distance,not active ,70
IDE12796-ENG155070-Personalization of user account 3-Display_ZeroEmission_Time,not active ,70
IDE12796-ENG155246-Personalization of user account 3-LastMode_HMI_global_active_layout,0 ,70
IDE12796-ENG155247-Personalization of user account 3-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12796-ENG155248-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12796-ENG155249-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12796-ENG155250-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12796-ENG155251-Personalization of user account 3-LastMode_HMI_HistoryState_main,0 ,70
IDE12796-ENG155252-Personalization of user account 3-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12796-ENG155253-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12796-ENG155254-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12796-ENG155255-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12796-ENG155256-Personalization of user account 3-LastMode_HMI_HistoryState_sport,0 ,70
IDE12796-ENG155257-Personalization of user account 3-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12796-ENG155258-Personalization of user account 3-LastMode_HMI_MFA_store,0 ,70
IDE12796-ENG155259-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12796-ENG155260-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12796-ENG155261-Personalization of user account 3-LastMode_v_Kunde_aktiv,not active ,70
IDE12796-ENG155262-Personalization of user account 3-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12796-ENG155263-Personalization of user account 3-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12796-ENG262859-Personalization of user account 3-speed_value,0 ,70
IDE12796-ENG263509-Personalization of user account 3-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12798-IDE00301-Personalization of user account 4-Mileage,Kilometers ,70
IDE12798-MAS01230-Personalization of user account 4-Date,dd_mm_yy ,70
IDE12798-MAS01456-Personalization of user account 4-Speed,Kilometers per hour ,70
IDE12798-MAS02201-Personalization of user account 4-Temperature,°C ,70
IDE12798-MAS02957-Personalization of user account 4-Time,24h ,70
IDE12798-MAS03032-Personalization of user account 4-Volume,Liters ,70
IDE12798-MAS03034-Personalization of user account 4-Pressure,bar ,70
IDE12798-MAS05637-Personalization of user account 4-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12798-MAS05638-Personalization of user account 4-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12798-MAS05875-Personalization of user account 4-Average consumption: electric drive,kWh per 100 km ,70
IDE12798-Personalization of user account 4-,not active ,70
IDE12798-ENG154881-Personalization of user account 4-Active_design,0 ,70
IDE12798-ENG154882-Personalization of user account 4-Active_view,0 ,70
IDE12798-ENG155000-Personalization of user account 4-DC_aktiverSpeicherplatz,0 ,70
IDE12798-ENG155001-Personalization of user account 4-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12798-ENG155002-Personalization of user account 4-DC_linkeTubeninformation,00 ,70
IDE12798-ENG155003-Personalization of user account 4-DC_rechteTubeninformation,00 ,70
IDE12798-ENG155004-Personalization of user account 4-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155005-Personalization of user account 4-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155006-Personalization of user account 4-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155007-Personalization of user account 4-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155008-Personalization of user account 4-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155009-Personalization of user account 4-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155051-Personalization of user account 4-Display_Average_Consumption,active ,70
IDE12798-ENG155052-Personalization of user account 4-Display_Average_Speed,active ,70
IDE12798-ENG155053-Personalization of user account 4-Display_ComfortPowerConsumption,not active ,70
IDE12798-ENG155054-Personalization of user account 4-Display_ConsumerList,not active ,70
IDE12798-ENG155055-Personalization of user account 4-Display_CoolantTemperature,not active ,70
IDE12798-ENG155056-Personalization of user account 4-Display_CurrentConsumption,active ,70
IDE12798-ENG155057-Personalization of user account 4-Display_DigitalSpeedometer,active ,70
IDE12798-ENG155058-Personalization of user account 4-Display_Distance,active ,70
IDE12798-ENG155059-Personalization of user account 4-Display_DrivingTime,active ,70
IDE12798-ENG155060-Personalization of user account 4-Display_DualSpeedometer,not active ,70
IDE12798-ENG155061-Personalization of user account 4-Display_Laptimer,not active ,70
IDE12798-ENG155062-Personalization of user account 4-Display_LiveTips,not active ,70
IDE12798-ENG155063-Personalization of user account 4-Display_Nachtankmenge,not active ,70
IDE12798-ENG155064-Personalization of user account 4-Display_OilTemperature,active ,70
IDE12798-ENG155065-Personalization of user account 4-Display_Range,active ,70
IDE12798-ENG155066-Personalization of user account 4-Display_ResetTime,not active ,70
IDE12798-ENG155067-Personalization of user account 4-Display_SpeedWarning,not active ,70
IDE12798-ENG155068-Personalization of user account 4-Display_VZA,active ,70
IDE12798-ENG155069-Personalization of user account 4-Display_ZeroEmission_Distance,not active ,70
IDE12798-ENG155070-Personalization of user account 4-Display_ZeroEmission_Time,not active ,70
IDE12798-ENG155246-Personalization of user account 4-LastMode_HMI_global_active_layout,0 ,70
IDE12798-ENG155247-Personalization of user account 4-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12798-ENG155248-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12798-ENG155249-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12798-ENG155250-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12798-ENG155251-Personalization of user account 4-LastMode_HMI_HistoryState_main,0 ,70
IDE12798-ENG155252-Personalization of user account 4-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12798-ENG155253-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12798-ENG155254-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12798-ENG155255-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12798-ENG155256-Personalization of user account 4-LastMode_HMI_HistoryState_sport,0 ,70
IDE12798-ENG155257-Personalization of user account 4-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12798-ENG155258-Personalization of user account 4-LastMode_HMI_MFA_store,0 ,70
IDE12798-ENG155259-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12798-ENG155260-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12798-ENG155261-Personalization of user account 4-LastMode_v_Kunde_aktiv,not active ,70
IDE12798-ENG155262-Personalization of user account 4-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12798-ENG155263-Personalization of user account 4-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12798-ENG262859-Personalization of user account 4-speed_value,0 ,70
IDE12798-ENG263509-Personalization of user account 4-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12800-IDE00301-Personalization of user account 5-Mileage,Kilometers ,70
IDE12800-MAS01230-Personalization of user account 5-Date,dd_mm_yy ,70
IDE12800-MAS01456-Personalization of user account 5-Speed,Kilometers per hour ,70
IDE12800-MAS02201-Personalization of user account 5-Temperature,°C ,70
IDE12800-MAS02957-Personalization of user account 5-Time,24h ,70
IDE12800-MAS03032-Personalization of user account 5-Volume,Liters ,70
IDE12800-MAS03034-Personalization of user account 5-Pressure,bar ,70
IDE12800-MAS05637-Personalization of user account 5-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12800-MAS05638-Personalization of user account 5-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12800-MAS05875-Personalization of user account 5-Average consumption: electric drive,kWh per 100 km ,70
IDE12800-Personalization of user account 5-,not active ,70
IDE12800-ENG154881-Personalization of user account 5-Active_design,0 ,70
IDE12800-ENG154882-Personalization of user account 5-Active_view,0 ,70
IDE12800-ENG155000-Personalization of user account 5-DC_aktiverSpeicherplatz,0 ,70
IDE12800-ENG155001-Personalization of user account 5-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12800-ENG155002-Personalization of user account 5-DC_linkeTubeninformation,00 ,70
IDE12800-ENG155003-Personalization of user account 5-DC_rechteTubeninformation,00 ,70
IDE12800-ENG155004-Personalization of user account 5-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155005-Personalization of user account 5-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155006-Personalization of user account 5-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155007-Personalization of user account 5-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155008-Personalization of user account 5-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155009-Personalization of user account 5-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155051-Personalization of user account 5-Display_Average_Consumption,active ,70
IDE12800-ENG155052-Personalization of user account 5-Display_Average_Speed,active ,70
IDE12800-ENG155053-Personalization of user account 5-Display_ComfortPowerConsumption,not active ,70
IDE12800-ENG155054-Personalization of user account 5-Display_ConsumerList,not active ,70
IDE12800-ENG155055-Personalization of user account 5-Display_CoolantTemperature,not active ,70
IDE12800-ENG155056-Personalization of user account 5-Display_CurrentConsumption,active ,70
IDE12800-ENG155057-Personalization of user account 5-Display_DigitalSpeedometer,active ,70
IDE12800-ENG155058-Personalization of user account 5-Display_Distance,active ,70
IDE12800-ENG155059-Personalization of user account 5-Display_DrivingTime,active ,70
IDE12800-ENG155060-Personalization of user account 5-Display_DualSpeedometer,not active ,70
IDE12800-ENG155061-Personalization of user account 5-Display_Laptimer,not active ,70
IDE12800-ENG155062-Personalization of user account 5-Display_LiveTips,not active ,70
IDE12800-ENG155063-Personalization of user account 5-Display_Nachtankmenge,not active ,70
IDE12800-ENG155064-Personalization of user account 5-Display_OilTemperature,active ,70
IDE12800-ENG155065-Personalization of user account 5-Display_Range,active ,70
IDE12800-ENG155066-Personalization of user account 5-Display_ResetTime,not active ,70
IDE12800-ENG155067-Personalization of user account 5-Display_SpeedWarning,not active ,70
IDE12800-ENG155068-Personalization of user account 5-Display_VZA,active ,70
IDE12800-ENG155069-Personalization of user account 5-Display_ZeroEmission_Distance,not active ,70
IDE12800-ENG155070-Personalization of user account 5-Display_ZeroEmission_Time,not active ,70
IDE12800-ENG155246-Personalization of user account 5-LastMode_HMI_global_active_layout,0 ,70
IDE12800-ENG155247-Personalization of user account 5-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12800-ENG155248-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12800-ENG155249-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12800-ENG155250-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12800-ENG155251-Personalization of user account 5-LastMode_HMI_HistoryState_main,0 ,70
IDE12800-ENG155252-Personalization of user account 5-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12800-ENG155253-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12800-ENG155254-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12800-ENG155255-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12800-ENG155256-Personalization of user account 5-LastMode_HMI_HistoryState_sport,0 ,70
IDE12800-ENG155257-Personalization of user account 5-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12800-ENG155258-Personalization of user account 5-LastMode_HMI_MFA_store,0 ,70
IDE12800-ENG155259-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12800-ENG155260-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12800-ENG155261-Personalization of user account 5-LastMode_v_Kunde_aktiv,not active ,70
IDE12800-ENG155262-Personalization of user account 5-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12800-ENG155263-Personalization of user account 5-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12800-ENG262859-Personalization of user account 5-speed_value,0 ,70
IDE12800-ENG263509-Personalization of user account 5-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12802-IDE00301-Personalization of user account 6-Mileage,Kilometers ,70
IDE12802-MAS01230-Personalization of user account 6-Date,dd_mm_yy ,70
IDE12802-MAS01456-Personalization of user account 6-Speed,Kilometers per hour ,70
IDE12802-MAS02201-Personalization of user account 6-Temperature,°C ,70
IDE12802-MAS02957-Personalization of user account 6-Time,24h ,70
IDE12802-MAS03032-Personalization of user account 6-Volume,Liters ,70
IDE12802-MAS03034-Personalization of user account 6-Pressure,bar ,70
IDE12802-MAS05637-Personalization of user account 6-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12802-MAS05638-Personalization of user account 6-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12802-MAS05875-Personalization of user account 6-Average consumption: electric drive,kWh per 100 km ,70
IDE12802-Personalization of user account 6-,not active ,70
IDE12802-ENG154881-Personalization of user account 6-Active_design,0 ,70
IDE12802-ENG154882-Personalization of user account 6-Active_view,0 ,70
IDE12802-ENG155000-Personalization of user account 6-DC_aktiverSpeicherplatz,0 ,70
IDE12802-ENG155001-Personalization of user account 6-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12802-ENG155002-Personalization of user account 6-DC_linkeTubeninformation,00 ,70
IDE12802-ENG155003-Personalization of user account 6-DC_rechteTubeninformation,00 ,70
IDE12802-ENG155004-Personalization of user account 6-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155005-Personalization of user account 6-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155006-Personalization of user account 6-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155007-Personalization of user account 6-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155008-Personalization of user account 6-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155009-Personalization of user account 6-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155051-Personalization of user account 6-Display_Average_Consumption,active ,70
IDE12802-ENG155052-Personalization of user account 6-Display_Average_Speed,active ,70
IDE12802-ENG155053-Personalization of user account 6-Display_ComfortPowerConsumption,not active ,70
IDE12802-ENG155054-Personalization of user account 6-Display_ConsumerList,not active ,70
IDE12802-ENG155055-Personalization of user account 6-Display_CoolantTemperature,not active ,70
IDE12802-ENG155056-Personalization of user account 6-Display_CurrentConsumption,active ,70
IDE12802-ENG155057-Personalization of user account 6-Display_DigitalSpeedometer,active ,70
IDE12802-ENG155058-Personalization of user account 6-Display_Distance,active ,70
IDE12802-ENG155059-Personalization of user account 6-Display_DrivingTime,active ,70
IDE12802-ENG155060-Personalization of user account 6-Display_DualSpeedometer,not active ,70
IDE12802-ENG155061-Personalization of user account 6-Display_Laptimer,not active ,70
IDE12802-ENG155062-Personalization of user account 6-Display_LiveTips,not active ,70
IDE12802-ENG155063-Personalization of user account 6-Display_Nachtankmenge,not active ,70
IDE12802-ENG155064-Personalization of user account 6-Display_OilTemperature,active ,70
IDE12802-ENG155065-Personalization of user account 6-Display_Range,active ,70
IDE12802-ENG155066-Personalization of user account 6-Display_ResetTime,not active ,70
IDE12802-ENG155067-Personalization of user account 6-Display_SpeedWarning,not active ,70
IDE12802-ENG155068-Personalization of user account 6-Display_VZA,active ,70
IDE12802-ENG155069-Personalization of user account 6-Display_ZeroEmission_Distance,not active ,70
IDE12802-ENG155070-Personalization of user account 6-Display_ZeroEmission_Time,not active ,70
IDE12802-ENG155246-Personalization of user account 6-LastMode_HMI_global_active_layout,0 ,70
IDE12802-ENG155247-Personalization of user account 6-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12802-ENG155248-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12802-ENG155249-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12802-ENG155250-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12802-ENG155251-Personalization of user account 6-LastMode_HMI_HistoryState_main,0 ,70
IDE12802-ENG155252-Personalization of user account 6-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12802-ENG155253-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12802-ENG155254-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12802-ENG155255-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12802-ENG155256-Personalization of user account 6-LastMode_HMI_HistoryState_sport,0 ,70
IDE12802-ENG155257-Personalization of user account 6-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12802-ENG155258-Personalization of user account 6-LastMode_HMI_MFA_store,0 ,70
IDE12802-ENG155259-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12802-ENG155260-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12802-ENG155261-Personalization of user account 6-LastMode_v_Kunde_aktiv,not active ,70
IDE12802-ENG155262-Personalization of user account 6-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12802-ENG155263-Personalization of user account 6-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12802-ENG262859-Personalization of user account 6-speed_value,0 ,70
IDE12802-ENG263509-Personalization of user account 6-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12804-IDE00301-Personalization of user account 7-Mileage,Kilometers ,70
IDE12804-MAS01230-Personalization of user account 7-Date,dd_mm_yy ,70
IDE12804-MAS01456-Personalization of user account 7-Speed,Kilometers per hour ,70
IDE12804-MAS02201-Personalization of user account 7-Temperature,°C ,70
IDE12804-MAS02957-Personalization of user account 7-Time,24h ,70
IDE12804-MAS03032-Personalization of user account 7-Volume,Liters ,70
IDE12804-MAS03034-Personalization of user account 7-Pressure,bar ,70
IDE12804-MAS05637-Personalization of user account 7-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12804-MAS05638-Personalization of user account 7-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12804-MAS05875-Personalization of user account 7-Average consumption: electric drive,kWh per 100 km ,70
IDE12804-Personalization of user account 7-,not active ,70
IDE12804-ENG154881-Personalization of user account 7-Active_design,0 ,70
IDE12804-ENG154882-Personalization of user account 7-Active_view,0 ,70
IDE12804-ENG155000-Personalization of user account 7-DC_aktiverSpeicherplatz,0 ,70
IDE12804-ENG155001-Personalization of user account 7-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12804-ENG155002-Personalization of user account 7-DC_linkeTubeninformation,00 ,70
IDE12804-ENG155003-Personalization of user account 7-DC_rechteTubeninformation,00 ,70
IDE12804-ENG155004-Personalization of user account 7-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155005-Personalization of user account 7-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155006-Personalization of user account 7-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155007-Personalization of user account 7-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155008-Personalization of user account 7-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155009-Personalization of user account 7-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155051-Personalization of user account 7-Display_Average_Consumption,active ,70
IDE12804-ENG155052-Personalization of user account 7-Display_Average_Speed,active ,70
IDE12804-ENG155053-Personalization of user account 7-Display_ComfortPowerConsumption,not active ,70
IDE12804-ENG155054-Personalization of user account 7-Display_ConsumerList,not active ,70
IDE12804-ENG155055-Personalization of user account 7-Display_CoolantTemperature,not active ,70
IDE12804-ENG155056-Personalization of user account 7-Display_CurrentConsumption,active ,70
IDE12804-ENG155057-Personalization of user account 7-Display_DigitalSpeedometer,active ,70
IDE12804-ENG155058-Personalization of user account 7-Display_Distance,active ,70
IDE12804-ENG155059-Personalization of user account 7-Display_DrivingTime,active ,70
IDE12804-ENG155060-Personalization of user account 7-Display_DualSpeedometer,not active ,70
IDE12804-ENG155061-Personalization of user account 7-Display_Laptimer,not active ,70
IDE12804-ENG155062-Personalization of user account 7-Display_LiveTips,not active ,70
IDE12804-ENG155063-Personalization of user account 7-Display_Nachtankmenge,not active ,70
IDE12804-ENG155064-Personalization of user account 7-Display_OilTemperature,active ,70
IDE12804-ENG155065-Personalization of user account 7-Display_Range,active ,70
IDE12804-ENG155066-Personalization of user account 7-Display_ResetTime,not active ,70
IDE12804-ENG155067-Personalization of user account 7-Display_SpeedWarning,not active ,70
IDE12804-ENG155068-Personalization of user account 7-Display_VZA,active ,70
IDE12804-ENG155069-Personalization of user account 7-Display_ZeroEmission_Distance,not active ,70
IDE12804-ENG155070-Personalization of user account 7-Display_ZeroEmission_Time,not active ,70
IDE12804-ENG155246-Personalization of user account 7-LastMode_HMI_global_active_layout,0 ,70
IDE12804-ENG155247-Personalization of user account 7-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12804-ENG155248-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12804-ENG155249-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12804-ENG155250-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12804-ENG155251-Personalization of user account 7-LastMode_HMI_HistoryState_main,0 ,70
IDE12804-ENG155252-Personalization of user account 7-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12804-ENG155253-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12804-ENG155254-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12804-ENG155255-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12804-ENG155256-Personalization of user account 7-LastMode_HMI_HistoryState_sport,0 ,70
IDE12804-ENG155257-Personalization of user account 7-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12804-ENG155258-Personalization of user account 7-LastMode_HMI_MFA_store,0 ,70
IDE12804-ENG155259-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12804-ENG155260-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12804-ENG155261-Personalization of user account 7-LastMode_v_Kunde_aktiv,not active ,70
IDE12804-ENG155262-Personalization of user account 7-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12804-ENG155263-Personalization of user account 7-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12804-ENG262859-Personalization of user account 7-speed_value,0 ,70
IDE12804-ENG263509-Personalization of user account 7-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12960-Resetting oil service,no warning ,1
IDE12961-Oil quality,poor oil quality ,1
IDE12962-Oil: soot entry,4400 km,2
IDE12963-Oil: thermal loading,1200 km,2
IDE12964-Oil: driven distance since last oil service,1600 km,3
IDE12965-Oil: time since last oil service,90 d,2
IDE12966-Oil: min distance until next oil service (flexible interval),15000 km,2
IDE12967-Oil: max. distance until next oil service (flexible interval),30000 km,2
IDE12968-Oil: min time until next oil service (flexible interval),365 d,2
IDE12969-Oil: max time until next oil service (flexible interval),730 d,2
IDE12970-Oil: distance until next oil service (fixed interval),15000 km,2
IDE12971-Oil: time until next oil service (fixed interval),365 d,2
IDE12978-Inspection: distance until next inspection,15000 km,3
IDE12979-Inspection: time until next inspection,365 d,2
IDE12980-Inspection: distance driven since the last inspection,1600 km,3
IDE12981-Inspection: time since the last inspection,90 d,2
IDE12982-Inspection: distance reset value,15000 km,2
IDE12983-Inspection: time reset value,365 d,2
IDE13031-MAS03935-Long-term store-Drive time,0 min,44
IDE13031-MAS15517-Long-term store-Travel distance,0 m,44
IDE13031-MAS15549-Long-term store-Average speed distance,0 m,44
IDE13031-MAS15550-Long-term store-Time since average speed,0 min,44
IDE13031-MAS15551-Long-term store-Distance average consumption of VKM,0 m,44
IDE13031-MAS15552-Long-term store-Consumption average consumption of VKM,0 ml,44
IDE13031-MAS15553-Long-term store-Distance average consumption of gasoline,0 m,44
IDE13031-MAS15554-Long-term store-Consumption average consumption of gasoline,0 g,44
IDE13031-MAS15555-Long-term store-Distance average consumption of electricity,0 m,44
IDE13031-MAS15556-Long-term store-Consumption average consumption by individual electrics,0.000 kWh,44
IDE13031-MAS15557-Long-term store-Consumption average consumption by BMS electrics,0.000 kWh,44
IDE13094-Tachometer end value,Variant 2 ,1
IDE13275-IDE00301-Personalization default value-Mileage,Kilometers ,70
IDE13275-MAS01230-Personalization default value-Date,dd_mm_yy ,70
IDE13275-MAS01456-Personalization default value-Speed,Kilometers per hour ,70
IDE13275-MAS02201-Personalization default value-Temperature,°C ,70
IDE13275-MAS02957-Personalization default value-Time,24h ,70
IDE13275-MAS03032-Personalization default value-Volume,Liters ,70
IDE13275-MAS03034-Personalization default value-Pressure,bar ,70
IDE13275-MAS05637-Personalization default value-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE13275-MAS05638-Personalization default value-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE13275-MAS05875-Personalization default value-Average consumption: electric drive,kWh per 100 km ,70
IDE13275-Personalization default value-,not active ,70
IDE13275-ENG154881-Personalization default value-Active_design,0 ,70
IDE13275-ENG154882-Personalization default value-Active_view,0 ,70
IDE13275-ENG155000-Personalization default value-DC_aktiverSpeicherplatz,0 ,70
IDE13275-ENG155001-Personalization default value-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE13275-ENG155002-Personalization default value-DC_linkeTubeninformation,00 ,70
IDE13275-ENG155003-Personalization default value-DC_rechteTubeninformation,00 ,70
IDE13275-ENG155004-Personalization default value-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155005-Personalization default value-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155006-Personalization default value-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155007-Personalization default value-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155008-Personalization default value-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155009-Personalization default value-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155051-Personalization default value-Display_Average_Consumption,active ,70
IDE13275-ENG155052-Personalization default value-Display_Average_Speed,active ,70
IDE13275-ENG155053-Personalization default value-Display_ComfortPowerConsumption,not active ,70
IDE13275-ENG155054-Personalization default value-Display_ConsumerList,not active ,70
IDE13275-ENG155055-Personalization default value-Display_CoolantTemperature,not active ,70
IDE13275-ENG155056-Personalization default value-Display_CurrentConsumption,active ,70
IDE13275-ENG155057-Personalization default value-Display_DigitalSpeedometer,active ,70
IDE13275-ENG155058-Personalization default value-Display_Distance,active ,70
IDE13275-ENG155059-Personalization default value-Display_DrivingTime,active ,70
IDE13275-ENG155060-Personalization default value-Display_DualSpeedometer,not active ,70
IDE13275-ENG155061-Personalization default value-Display_Laptimer,not active ,70
IDE13275-ENG155062-Personalization default value-Display_LiveTips,active ,70
IDE13275-ENG155063-Personalization default value-Display_Nachtankmenge,not active ,70
IDE13275-ENG155064-Personalization default value-Display_OilTemperature,active ,70
IDE13275-ENG155065-Personalization default value-Display_Range,active ,70
IDE13275-ENG155066-Personalization default value-Display_ResetTime,not active ,70
IDE13275-ENG155067-Personalization default value-Display_SpeedWarning,not active ,70
IDE13275-ENG155068-Personalization default value-Display_VZA,active ,70
IDE13275-ENG155069-Personalization default value-Display_ZeroEmission_Distance,not active ,70
IDE13275-ENG155070-Personalization default value-Display_ZeroEmission_Time,not active ,70
IDE13275-ENG155246-Personalization default value-LastMode_HMI_global_active_layout,0 ,70
IDE13275-ENG155247-Personalization default value-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE13275-ENG155248-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE13275-ENG155249-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE13275-ENG155250-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE13275-ENG155251-Personalization default value-LastMode_HMI_HistoryState_main,0 ,70
IDE13275-ENG155252-Personalization default value-LastMode_HMI_HistoryState_mfa,0 ,70
IDE13275-ENG155253-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE13275-ENG155254-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE13275-ENG155255-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE13275-ENG155256-Personalization default value-LastMode_HMI_HistoryState_sport,0 ,70
IDE13275-ENG155257-Personalization default value-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,5 ,70
IDE13275-ENG155258-Personalization default value-LastMode_HMI_MFA_store,0 ,70
IDE13275-ENG155259-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE13275-ENG155260-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE13275-ENG155261-Personalization default value-LastMode_v_Kunde_aktiv,not active ,70
IDE13275-ENG155262-Personalization default value-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE13275-ENG155263-Personalization default value-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE13275-ENG262859-Personalization default value-speed_value,0 ,70
IDE13275-ENG263509-Personalization default value-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE13441-Secondary speed in case of unit replacement,No display ,1
IDE13607-MAS16706-Lock display contents-List time out,72000 s,9
IDE14112-Gas system test - warning reset,No ,1
IDE14116-Gas system test - warning time,1443 d,2
IDE14123-MAS01129-Design variant activation-Variant 1,not active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,not active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,not active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,Yes ,1
IDE14188-Range indicator configuration,422 km,8
IDE14220-Vehicle speed warning for India-,90 s,1
IDE14222-Test number length: authentic time,16 B,1
IDE14875-MAS19483-Activation of views-View 1,active ,2
IDE14875-MAS19484-Activation of views-View 2,not active ,2
IDE14875-MAS19485-Activation of views-View 3,active ,2
IDE14875-MAS19486-Activation of views-View 4,active ,2
IDE14875-MAS19487-Activation of views-View 5,not active ,2
IDE14875-MAS19488-Activation of views-View 6,not active ,2
IDE14875-MAS19489-Activation of views-View 7,not active ,2
IDE14875-MAS19490-Activation of views-View 8,not active ,2
IDE14875-MAS19491-Activation of views-View 9,not active ,2
IDE14875-MAS19492-Activation of views-View 10,not active ,2
IDE14875-MAS19493-Activation of views-View 12,not active ,2
IDE14875-MAS19494-Activation of views-View 11,not active ,2
IDE14875-MAS19495-Activation of views-View 13,not active ,2
IDE14875-MAS19496-Activation of views-View 14,not active ,2
IDE14875-MAS19497-Activation of views-View 15,not active ,2
IDE14875-MAS19498-Activation of views-View 16,not active ,2
IDE15080-Logo,kein_logo ,1
IDE15909-Removable seats,Removable seats ,1
MAS01083-IDE12211-Country Variant-China variant,No ,2
MAS01083-IDE14114-Country Variant-USA Variant,No ,2
MAS01083-IDE14115-Country Variant-Asian variant,No ,2
MAS01758-IDE00500-Date / time-Hour,13 H,6
MAS01758-IDE00501-Date / time-Minute,59 min,6
MAS01758-IDE00502-Date / time-Year,2021 yr,6
MAS01758-IDE00503-Date / time-Month,9 Months,6
MAS01758-IDE00504-Date / time-Day,14 d,6
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG262830-Correction_factor_consumption_and_operating_range_electric,100 %,1
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,10 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,1E ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,3C ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG153810-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X1,00 ,18
ENG153810-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X2,0A ,18
ENG153810-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X3,32 ,18
ENG153810-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X4,64 ,18
ENG153810-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X5,96 ,18
ENG153810-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X6,FD ,18
ENG153810-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y1,12 ‰,18
ENG153810-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y2,12 ‰,18
ENG153810-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y3,20 ‰,18
ENG153810-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y4,70 ‰,18
ENG153810-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y5,500 ‰,18
ENG153810-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y6,1000 ‰,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,80.0 %,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.0 %,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,40.0 %,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,25.0 %,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,12.0 %,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,0.0 %,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,40.0 %,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.0 %,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,75.0 %,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,85.0 %,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,95.0 %,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,100.0 %,24
ENG251650-GPS_speed,active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4.0 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6.0 °C,16
ENG135292-phev_stat_intervall-,1.0 ,7
ENG135292-phev_stat_intervall-,100 m,7
ENG135292-phev_stat_intervall-,0 min,7
ENG135292-phev_stat_intervall-,5.0 km,7
ENG135292-phev_stat_intervall-,kein ,7
ENG135292-phev_stat_intervall-,1.0 s,7
ENG135292-phev_stat_intervall-,00000000 00010000  ,7
ENG262832-Switching_Networking,Ethernet ,1
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.50 ,18
ENG153987-volume_offset,100 %,1
Elapsed Time: 00:32
adpmap-19-5WA-907-530-J_WV1ZZZSKZMX050719-20210914-1401.CSV
    SW:5WA-907-530-J   HW:5WA-907-530-C ---  CAN Gateway
    Component:GW2020 High   752 7084, Coding:0000808D0700000000000000012303327301610902000100030100000001010000000000000000000000000000000000
    EV_GatewMQB2020,004008,EV_GatewMQB2020_VW38.rod
    Tuesday,14,September,2021,14:01:11:34165
    VCDS Version: Release 21.9.0  Data version: 20210824 DS330.0
    VCID: 4FFB7AD047557B236E8-801A
IDE00001-MAS00170-Production mode-OBD,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS21169-Production mode-Parking coordinator,Deactivating ,3
IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,not active ,5
IDE00820-ENG259081-Activating and deactivating all development messages-BCmE_development_CAN_messages,not active ,5
IDE00820-ENG258247-Activating and deactivating all development messages-eASS_development_CAN_messages,not active ,5
IDE00820-ENG261332-Activating and deactivating all development messages-EHR_development_CAN_messages,not active ,5
IDE00820-ENG260014-Activating and deactivating all development messages-FoD_development_CAN_messages,not active ,5
IDE00820-ENG260247-Activating and deactivating all development messages-FPA_development_CAN_messages,not active ,5
IDE00820-ENG260571-Activating and deactivating all development messages-GW_development_CAN_messages,not active ,5
IDE00820-ENG259210-Activating and deactivating all development messages-HD_development_CAN_messages,not active ,5
IDE00820-ENG259946-Activating and deactivating all development messages-HV-EM_development_CAN_messages,not active ,5
IDE00820-ENG259153-Activating and deactivating all development messages-IDS_development_CAN_messages,not active ,5
IDE00820-ENG258853-Activating and deactivating all development messages-KS_development_CAN_messages,not active ,5
IDE00820-ENG258958-Activating and deactivating all development messages-MFL_development_CAN_messages,not active ,5
IDE00820-ENG258567-Activating and deactivating all development messages-MKE_development_CAN_messages,not active ,5
IDE00820-ENG260849-Activating and deactivating all development messages-MV-EM_development_CAN_messages,not active ,5
IDE00820-ENG259788-Activating and deactivating all development messages-NV-EM_development_CAN_messages,not active ,5
IDE00820-ENG260650-Activating and deactivating all development messages-OBDC_development_CAN_messages,not active ,5
IDE00820-ENG261321-Activating and deactivating all development messages-PaCo_development_CAN_messages,not active ,5
IDE00820-ENG261353-Activating and deactivating all development messages-RWB_development_CAN_messages,not active ,5
IDE00820-ENG258585-Activating and deactivating all development messages-SDA_development_CAN_messages,not active ,5
IDE00820-ENG258798-Activating and deactivating all development messages-SK1a_development_CAN_messages,not active ,5
IDE00820-ENG260530-Activating and deactivating all development messages-SK3_development_CAN_messages,not active ,5
IDE00820-ENG259285-Activating and deactivating all development messages-SOK_development_CAN_messages,not active ,5
IDE00820-ENG258316-Activating and deactivating all development messages-SWaP_development_CAN_messages,not active ,5
IDE00820-ENG259637-Activating and deactivating all development messages-VDC_development_CAN_messages,not active ,5
IDE00820-ENG259338-Activating and deactivating all development messages-VKMS_development_CAN_messages,not active ,5
IDE00820-ENG259833-Activating and deactivating all development messages-WUM_development_CAN_messages,not active ,5
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,70 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB+ ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 ,2
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE07160-Control module switch-off: switch-off time,20 min,2
IDE08220-Vehicle production mode,not active ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,1.0 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,0 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,-15000 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,150 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,150 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,10 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,1.0 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,1.0 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,1.0 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,1.0 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,1.0 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,1.0 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),1.5 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,1.0 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,4.0 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,1.0 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,1.0 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,1.0 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,1.0 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,1.0 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,1.0 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,1.0 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,1.0 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,0.0 l/100km,48
IDE10351-MAS10460-Message mirroring-Target bus,not active ,2
IDE10351-MAS21167-Message mirroring-Source bus,Powertrain data bus ,2
IDE10735-Number requests autonomous recharging,9 ,1
IDE11689-48V-System: locking,regular operation ,1
IDE13844-Distance left for deactivation of production mode,100 km,1
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,0.0 kWh/100 km,40
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,0.0 kWh/100 km,40
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,0.0 kWh/100 km,40
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,0.0 kWh/100 km,40
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,0.0 kWh/100 km,40
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,0.0 kWh/100 km,40
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,0.0 kWh/100 km,40
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,0.0 kWh/100 km,40
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,0.0 kWh/100 km,40
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,0.0 kWh/100 km,40
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,0.0 kWh/100 km,40
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,0.0 kWh/100 km,40
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,0.0 kWh/100 km,40
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,0.0 kWh/100 km,40
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,0.0 kWh/100 km,40
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,0.0 kWh/100 km,40
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,0.0 kWh/100 km,40
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,0.0 kWh/100 km,40
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,0.0 kWh/100 km,40
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,0.0 kWh/100 km,40
IDE14750-Deactivate all development messages,0 ,5
IDE15316-FoD Partner,available. ,1
IDE15331-Multifunction steering wheel extended adaptation,Configuration 4 ,3
IDE15756-Ethernet port 3 VLAN configuration,VLAN_Komfort ,1
IDE15853-Report system for deviations: coding,0 ,3
MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,not active ,5
MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,not active ,5
MAS08072-ENG172201-Driving profile selection-FPA_Funktion,not active ,5
MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,not active ,5
MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,not active ,5
MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,not active ,5
MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,not active ,5
MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,not active ,5
MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,not active ,5
MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,not active ,5
MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,not active ,5
MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,not active ,5
MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,not active ,5
MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,not active ,5
MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,not active ,5
MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,not active ,5
MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,not active ,5
MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,not active ,5
MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,not active ,5
MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,not active ,5
MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,not active ,5
MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,not active ,5
MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,not active ,5
MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,not active ,5
MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,not active ,5
MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,not active ,5
MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,not active ,5
MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,not active ,5
MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,not active ,5
MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,not active ,5
MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,not active ,5
MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,not active ,5
MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,not active ,5
MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,not active ,5
MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,not active ,5
MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,not active ,5
MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,not active ,5
MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,not active ,5
MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Dropping slope on curve ,5
MAS12667-SFT271901-Specified installation of sub-bus users-Generator,Yes ,4
MAS12667-SFT271921-Specified installation of sub-bus users-Multifunction steering wheel control module,Yes ,4
MAS12667-SFT271927-Specified installation of sub-bus users-Battery Monitoring Control Module,Yes ,4
MAS12667-SFT271977-Specified installation of sub-bus users-Inverter for electrical outlet,Yes ,4
MAS12667-SFT271986-Specified installation of sub-bus users-Analog clock,No ,4
MAS12667-SFT272175-Specified installation of sub-bus users-Control head driving profile,No ,4
MAS12667-SFT272190-Specified installation of sub-bus users-Steering Wheel Touch Recognition Control Module,No ,4
MAS16743-Alternator gear ratio,73 ,1
SFT271921-IDE02583-Multifunction steering wheel control module-Steering wheel Tiptronic switch,not installed ,3
SFT271921-IDE07856-Multifunction steering wheel control module-Terminal status,active with terminal 58 ,3
SFT271921-MAS02311-Multifunction steering wheel control module-Steering wheel heating button,not active ,3
SFT271921-MAS04733-Multifunction steering wheel control module-Two-stage,not active ,3
SFT271921-MAS06614-Multifunction steering wheel control module-Variant,CCS ,3
SFT271921-MAS09758-Multifunction steering wheel control module-Temperature sensor,not installed ,3
SFT271921-MAS10720-Multifunction steering wheel control module-Speed limiter,not active ,3
SFT271921-MAS13892-Multifunction steering wheel control module-Platform,MQB2020 ,3
SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function,not active ,3
SFT271921-MAS21171-Multifunction steering wheel control module-Distance regulation function query (FoD),automatic ,3
SFT271921-MAS21172-Multifunction steering wheel control module-Travel Assist function query (FoD),automatic ,3
SFT271921-ENG262857-Multifunction steering wheel control module-Kombi_02_gueltig,invalid ,3
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG253088-EM_function_variant_EM-HLR,0 ,1
ENG279934-ENG280094-Engress_filter-packet_based_/_port_shaper_burst_size_configuration,2000 ,10
ENG279934-ENG280095-Engress_filter-packet_based_/_port_shaper_shaping_rate_configuration,2000 packets/s,10
ENG279934-ENG280098-Engress_filter-port_shaper_bucket_count_select,packet_based ,10
ENG279934-ENG280099-Engress_filter-port_shaper_enabling,enable_shaper ,10
ENG253271-ENG259280-GW_Content_list-Bus_ID,00 ,48
ENG253271-ENG253458-GW_Content_list-Node_address,00 00 ,48
ENG253382-ENG258827-IDS_critical_PDUs_list_mqb2020-Airbag_01_can-id_0x040,On ,8
ENG253382-ENG259901-IDS_critical_PDUs_list_mqb2020-Airbag_02_can-id_0x520,On ,8
ENG253382-ENG259106-IDS_critical_PDUs_list_mqb2020-Airbag_03_can-id_0x041,On ,8
ENG253382-ENG261312-IDS_critical_PDUs_list_mqb2020-APS_Master_can-id_0x380,On ,8
ENG253382-ENG259066-IDS_critical_PDUs_list_mqb2020-ARA_02_can-id_0x2A5,On ,8
ENG253382-ENG260221-IDS_critical_PDUs_list_mqb2020-BMS_NV_01_can-id_0x1F3,On ,8
ENG253382-ENG258308-IDS_critical_PDUs_list_mqb2020-Bremse_EV_02_can-id_0x387,On ,8
ENG253382-ENG258444-IDS_critical_PDUs_list_mqb2020-EA_01_can-id_0x1A4,On ,8
ENG253382-ENG259736-IDS_critical_PDUs_list_mqb2020-EA_02_can-id_0x1F0,On ,8
ENG253382-ENG258228-IDS_critical_PDUs_list_mqb2020-EPB_03_can-id_0x1F7,On ,8
ENG253382-ENG258443-IDS_critical_PDUs_list_mqb2020-ESP_10_can-id_0x116,On ,8
ENG253382-ENG258403-IDS_critical_PDUs_list_mqb2020-ESP_14_can-id_0x08A,On ,8
ENG253382-ENG259539-IDS_critical_PDUs_list_mqb2020-ESP_20_can-id_0x65D,On ,8
ENG253382-ENG258752-IDS_critical_PDUs_list_mqb2020-ESP_21_can-id_0x0FD,On ,8
ENG253382-ENG258803-IDS_critical_PDUs_list_mqb2020-ESP_24_can-id_0x31B,On ,8
ENG253382-ENG259454-IDS_critical_PDUs_list_mqb2020-GRA_ACC_01_can-id_0x12B,On ,8
ENG253382-ENG260975-IDS_critical_PDUs_list_mqb2020-HCA_01_can-id_0x126,On ,8
ENG253382-ENG258427-IDS_critical_PDUs_list_mqb2020-IPA_01_can-id_0x138,On ,8
ENG253382-ENG259431-IDS_critical_PDUs_list_mqb2020-Klemmen_Status_01_can-id_0x3C0,On ,8
ENG253382-ENG258280-IDS_critical_PDUs_list_mqb2020-Klemmen_Steuerung_01_can-id_0x58C,On ,8
ENG253382-ENG259354-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_L_can-id_0x56B,On ,8
ENG253382-ENG258318-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_R_can-id_0x56C,On ,8
ENG253382-ENG260165-IDS_critical_PDUs_list_mqb2020-LCM_Soll_Fkt_can-id_0x193,On ,8
ENG253382-ENG259048-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_L_can-id_0x19B,On ,8
ENG253382-ENG259708-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_R_can-id_0x19D,On ,8
ENG253382-ENG259220-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_L_03_can-id_0x16A95416,On ,8
ENG253382-ENG259096-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_R_03_can-id_0x16A95417,On ,8
ENG253382-ENG260883-IDS_critical_PDUs_list_mqb2020-LH_EPS_01_can-id_0x32A,On ,8
ENG253382-ENG261199-IDS_critical_PDUs_list_mqb2020-LH_EPS_02_can-id_0x11D,On ,8
ENG253382-ENG259434-IDS_critical_PDUs_list_mqb2020-LH_EPS_03_can-id_0x09F,On ,8
ENG253382-ENG258969-IDS_critical_PDUs_list_mqb2020-Licht_Anf_01_can-id_0x3D5,On ,8
ENG253382-ENG259107-IDS_critical_PDUs_list_mqb2020-LWI_01_can-id_0x086,On ,8
ENG253382-ENG259990-IDS_critical_PDUs_list_mqb2020-MFG_02_can-id_0x48D,On ,8
ENG253382-ENG260730-IDS_critical_PDUs_list_mqb2020-Motor_14_can-id_0x3BE,On ,8
ENG253382-ENG258115-IDS_critical_PDUs_list_mqb2020-Motor_Code_01_can-id_0x641,On ,8
ENG253382-ENG258876-IDS_critical_PDUs_list_mqb2020-PreCrash_02_can-id_0x13F,On ,8
ENG253382-ENG261021-IDS_critical_PDUs_list_mqb2020-Q_Diode_01_can-id_0x298,On ,8
ENG253382-ENG260760-IDS_critical_PDUs_list_mqb2020-RCTA_01_can-id_0x2B7,On ,8
ENG253382-ENG259993-IDS_critical_PDUs_list_mqb2020-TSG_FT_02_can-id_0x3E5,On ,8
ENG253382-ENG260263-IDS_critical_PDUs_list_mqb2020-WBA_03_can-id_0x394,On ,8
ENG253192-MAS01898-IDS_white_list_features-Powertrain,On ,1
ENG253192-MAS16574-IDS_white_list_features-Infotainment,On ,1
ENG253396-Mirroring_LIN3_to_LIN4,No ,1
ENG137850-MVK_Warning,regular operation ,1
ENG253252-ENG260330-Node_to_cluster_list-NCL_element_1,00 00 00 00 00 ,160
ENG253252-ENG260846-Node_to_cluster_list-NCL_element_10,00 00 00 00 00 ,160
ENG253252-ENG258686-Node_to_cluster_list-NCL_element_11,00 00 00 00 00 ,160
ENG253252-ENG259563-Node_to_cluster_list-NCL_element_12,00 00 00 00 00 ,160
ENG253252-ENG259135-Node_to_cluster_list-NCL_element_13,00 00 00 00 00 ,160
ENG253252-ENG261302-Node_to_cluster_list-NCL_element_14,00 00 00 00 00 ,160
ENG253252-ENG259590-Node_to_cluster_list-NCL_element_15,00 00 00 00 00 ,160
ENG253252-ENG261163-Node_to_cluster_list-NCL_element_16,00 00 00 00 00 ,160
ENG253252-ENG258229-Node_to_cluster_list-NCL_element_17,00 00 00 00 00 ,160
ENG253252-ENG259389-Node_to_cluster_list-NCL_element_18,00 00 00 00 00 ,160
ENG253252-ENG260540-Node_to_cluster_list-NCL_element_19,00 00 00 00 00 ,160
ENG253252-ENG259624-Node_to_cluster_list-NCL_element_2,00 00 00 00 00 ,160
ENG253252-ENG258136-Node_to_cluster_list-NCL_element_20,00 00 00 00 00 ,160
ENG253252-ENG261360-Node_to_cluster_list-NCL_element_21,00 00 00 00 00 ,160
ENG253252-ENG260775-Node_to_cluster_list-NCL_element_22,00 00 00 00 00 ,160
ENG253252-ENG259077-Node_to_cluster_list-NCL_element_23,00 00 00 00 00 ,160
ENG253252-ENG259062-Node_to_cluster_list-NCL_element_24,00 00 00 00 00 ,160
ENG253252-ENG260421-Node_to_cluster_list-NCL_element_25,00 00 00 00 00 ,160
ENG253252-ENG261354-Node_to_cluster_list-NCL_element_26,00 00 00 00 00 ,160
ENG253252-ENG258201-Node_to_cluster_list-NCL_element_27,00 00 00 00 00 ,160
ENG253252-ENG260110-Node_to_cluster_list-NCL_element_28,00 00 00 00 00 ,160
ENG253252-ENG258645-Node_to_cluster_list-NCL_element_29,00 00 00 00 00 ,160
ENG253252-ENG261260-Node_to_cluster_list-NCL_element_3,00 00 00 00 00 ,160
ENG253252-ENG259078-Node_to_cluster_list-NCL_element_30,00 00 00 00 00 ,160
ENG253252-ENG260192-Node_to_cluster_list-NCL_element_31,00 00 00 00 00 ,160
ENG253252-ENG259747-Node_to_cluster_list-NCL_element_32,00 00 00 00 00 ,160
ENG253252-ENG259375-Node_to_cluster_list-NCL_element_4,00 00 00 00 00 ,160
ENG253252-ENG259916-Node_to_cluster_list-NCL_element_5,00 00 00 00 00 ,160
ENG253252-ENG260559-Node_to_cluster_list-NCL_element_6,00 00 00 00 00 ,160
ENG253252-ENG259415-Node_to_cluster_list-NCL_element_7,00 00 00 00 00 ,160
ENG253252-ENG260302-Node_to_cluster_list-NCL_element_8,00 00 00 00 00 ,160
ENG253252-ENG259224-Node_to_cluster_list-NCL_element_9,00 00 00 00 00 ,160
ENG253340-SFD_Testmode,not active ,1
ENG253268-MAS03173-TCR_bus_can-Powertrain data bus,00 00 03 ,24
ENG253268-MAS03174-TCR_bus_can-Comfort data bus,00 00 30 ,24
ENG253268-MAS03177-TCR_bus_can-Infotainment data bus,00 01 C0 ,24
ENG253268-MAS03178-TCR_bus_can-Suspension data bus,00 00 04 ,24
ENG253268-MAS05686-TCR_bus_can-Data bus diagnostics,00 00 00 ,24
ENG253268-MAS12185-TCR_bus_can-Hybrid data bus,00 00 02 ,24
ENG253268-MAS16909-TCR_bus_can-Data bus driver assistance systems,00 00 08 ,24
ENG253268-MAS16910-TCR_bus_can-Migration data bus,00 00 01 ,24
ENG253184-MAS03179-TCR_bus_lin-Local data bus 2,00 01 C0 ,12
ENG253184-MAS03180-TCR_bus_lin-Local data bus,00 00 00 ,12
ENG253184-MAS05972-TCR_bus_lin-Local data bus 3,00 00 00 ,12
ENG253184-MAS06525-TCR_bus_lin-Local data bus 4,00 00 00 ,12
ENG253199-MAS16912-TCR_bus_vlan-VLAN_FAS,00 04 00 ,24
ENG253199-MAS16913-TCR_bus_vlan-VLAN_Infotainment,00 20 00 ,24
ENG253199-MAS16915-TCR_bus_vlan-VLAN_Komfort,00 08 00 ,24
ENG253199-MAS16916-TCR_bus_vlan-VLAN_Powertrain,00 02 00 ,24
ENG253199-MAS18934-TCR_bus_vlan-VLAN_Connect,00 10 00 ,24
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,10
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,10
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,10 ,10
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,0 min,10
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,10
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,10
ENG118773-ENG260551-WakeUpMonitor_Configuration-WakeUpMonitor_Start_WakeUp_Delay,0 s,10
Elapsed Time: 00:19
adpmap-23-5WA-909-059-H_WV1ZZZSKZMX050719-20210914-1406.CSV
    SW:5WA-909-059-H   HW:3Q0-909-059-B ---  Brake Booster
    Component:EBKV          H06 0112, Coding:5402C500090000000027C58800006DDBB66DDBB600
    EV_BrakeBoostG2BoschVW37W,014027,EV_BrakeBoostG2BoschVW37W_014.rod
    Tuesday,14,September,2021,14:06:23:34165
    VCID: 55F788B8658901F3A44-8000
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,20 min,2
IDE11447-electro-mechanical brake booster,active ,1
IDE11985-Expected OBD requirements,EOBD ,1
IDE14698-Parameters of leak test-,17.0000000 mm,20
IDE14698-Parameters of leak test-,10.0000000 mm/s,20
IDE14698-Parameters of leak test-,1 ,20
IDE14698-Parameters of leak test-,1.0 s,20
IDE14698-Parameters of leak test-,15.0000000 mm,20
IDE14698-Parameters of leak test-,3.0000000 mm/s,20
IDE14698-Parameters of leak test-,12.0 s,20
IDE14698-Parameters of leak test-,10.0 s,20
IDE14698-Parameters of leak test-,30.0000000 mm/s,20
IDE14698-Parameters of leak test-,10 bar,20
IDE14698-Parameters of leak test-,5.0000000 mm,20
IDE14698-Parameters of leak test-,12.0000000 mm,20
IDE14699-Parameters of heaviness test-,12.0000000 mm,13
IDE14699-Parameters of heaviness test-,30.0000000 mm/s,13
IDE14699-Parameters of heaviness test-,0 ,13
IDE14699-Parameters of heaviness test-,0.5 s,13
IDE14699-Parameters of heaviness test-,0.0 s,13
IDE14699-Parameters of heaviness test-,1.29980468750 Nm,13
IDE14699-Parameters of heaviness test-,50.0000000 mm/s,13
IDE14700-Parameters of ventilation routine-,21.0000000 mm,18
IDE14700-Parameters of ventilation routine-,180.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,25 ,18
IDE14700-Parameters of ventilation routine-,50.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,0.0 s,18
IDE14700-Parameters of ventilation routine-,30.0000000 mm,18
IDE14700-Parameters of ventilation routine-,5.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,5 ,18
IDE14700-Parameters of ventilation routine-,1.7968750 mm/s,18
IDE14700-Parameters of ventilation routine-,1.0 s,18
IDE80111-Analysis 111,active ,1
IDE80121-Analysis 121-,80 s,2
IDE80121-Analysis 121-,0 ,2
IDE80122-Analysis 122-,10 s,2
IDE80122-Analysis 122-,0 ,2
IDE80123-Analysis 123,OFF ,1
IDE80124-Analysis 124-,00 ,2
IDE80124-Analysis 124-,0 ,2
IDE80125-Analysis 125-,0 ,2
IDE80126-Analysis 126,0 ,2
IDE80131-MAS05513-Analysis 131-Bit 0,OFF ,1
IDE80131-MAS05514-Analysis 131-Bit 1,OFF ,1
IDE80131-MAS05515-Analysis 131-Bit 2,OFF ,1
IDE80131-MAS05516-Analysis 131-Bit 3,OFF ,1
IDE80131-MAS05517-Analysis 131-Bit 4,OFF ,1
IDE80131-MAS05518-Analysis 131-Bit 5,OFF ,1
IDE80131-MAS05519-Analysis 131-Bit 6,OFF ,1
IDE80131-MAS05520-Analysis 131-Bit 7,OFF ,1
IDE80134-Analysis 134-,00 00 00 00 ,40
IDE80134-Analysis 134-,00 ,40
IDE80135-Analysis 135-,00 00 00 00 ,40
IDE80135-Analysis 135-,00 ,40
IDE80136-Analysis 136-,00 00 00 00 ,40
IDE80136-Analysis 136-,00 ,40
IDE80137-Analysis 137-,00 00 00 00 ,40
IDE80137-Analysis 137-,00 ,40
MAS00194----,00 00 ,2
Elapsed Time: 00:06
adpmap-42-5Q4-959-593-H_WV1ZZZSKZMX050719-20210914-1406.CSV
    SW:5Q4-959-593-H   HW:5Q4-959-593-H ---  Door Elect, Driver
    Component:TSG FS        010 0692, Coding:00309320D000040100001020
    EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW27.rod
    Tuesday,14,September,2021,14:06:43:34165
    VCID: 4ACD6BC4BC375E0B396-801E
Elapsed Time: 00:02
adpmap-44-5R3-907-146-A_WV1ZZZSKZMX050719-20210914-1406.CSV
    SW:5R3-907-146-A   HW:5R3-907-146 ---  Steering Assist
    Component:BASGEN1MQB37  261 2040, Coding:0000000100000000000102010100010000000101010101
    EV_SteerAssisBASGEN1MQB37,007046,EV_SteerAssisBASGEN1MQB37_007_VW38.rod
    Tuesday,14,September,2021,14:06:48:34165
    VCID: 36352F34D8CF2AEB4DE-8062
IDE03724-Straight line running,Active: with learned value ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE06657-Steering angle: calculated,not active ,1
IDE06678-Pull compensation,Active: with learned value ,1
IDE09571-RPM monitoring,active ,1
IDE14345-Lateral assistant coordinator: parking assist,active ,1
IDE14346-Lateral assistant coordinator: reduced stopping distance,not active ,1
IDE14347-Lateral assistance coordinator: lane assist,active ,1
IDE14348-Lateral assistant coordination: counter-steering assist,active ,1
IDE15619-Maneuvering assistant lateral control coordinator,not active ,1
MAS09008-Plausibility check,not active ,1
Elapsed Time: 00:04
adpmap-52-5Q4-959-592-H_WV1ZZZSKZMX050719-20210914-1406.CSV
    SW:5Q4-959-592-H   HW:5Q4-959-592-H ---  Door Elect, Pass.
    Component:TSG BFS       010 0691, Coding:00301120D000040100801000
    EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_VW27.rod
    Tuesday,14,September,2021,14:06:56:34165
    VCID: 49CF54C8B931551330C-801C
Elapsed Time: 00:02
adpmap-75-5WA-035-286-A_WV1ZZZSKZMX050719-20210914-1410.CSV
    SW:5WA-035-286-A   HW:5WA-035-286-A ---  Telematics
    Component:OCU3HMQB37W   H12 0135, Coding:06359010106818008005460000500607
    EV_OCU3HMQB37W,002012,EV_OCU3HMQB37W_002_VW38.rod
    Tuesday,14,September,2021,14:10:50:34165
    VCID: 46D55FF4A82FBA6BDDE-8012
IDE00608-MAS00713-Fuel type-Gas,not installed ,1
IDE00608-MAS00716-Fuel type-Diesel,installed ,1
IDE00608-MAS00717-Fuel type-Petroleum gas,not installed ,1
IDE00608-MAS00718-Fuel type-Natural gas,not installed ,1
IDE00608-MAS00720-Fuel type-Battery / electric,not installed ,1
IDE00608-MAS03131-Fuel type-Hydrogen,not installed ,1
IDE00761-MAS08397-Run-on time-Long term energy budget,3600 mAh,5
IDE00761-MAS08398-Run-on time-Short term energy budget,1000 mAh,5
IDE00761-MAS08399-Run-on time-Waiting period from sleep to standby mode,5 min,5
IDE00765-Delay of audio output,1.0 s,1
IDE00769-Call number 1 for info call,empty ,5
IDE00770-Number 1 for roadside assistance,empty ,5
IDE00820-Activating and deactivating all development messages-,not activated ,1
IDE00820-ENG263580-Activating and deactivating all development messages-gnss_position_debug_traces,On ,1
IDE02330-Call number 2 for info call,                ,15
IDE02331-Number 2 for roadside assistance,empty ,5
IDE03581-MAS00478-Vehicle function list CAN-Reserved,0 ,3
IDE03581-ENG183857-Vehicle function list CAN-brakes,activated ,3
IDE03581-ENG252060-Vehicle function list CAN-Central_Electrics,activated ,3
IDE03581-ENG252043-Vehicle function list CAN-Clima,activated ,3
IDE03581-ENG252092-Vehicle function list CAN-Dash_Board,activated ,3
IDE03581-ENG252042-Vehicle function list CAN-Engine,activated ,3
IDE03581-ENG252080-Vehicle function list CAN-Front_door_co_driver,activated ,3
IDE03581-ENG252077-Vehicle function list CAN-Front_door_driver,activated ,3
IDE03581-ENG98593-Vehicle function list CAN-Gateway,activated ,3
IDE03581-ENG252094-Vehicle function list CAN-seat_memory_driver,not activated ,3
IDE03581-ENG252083-Vehicle function list CAN-Steering_Column_Electronics,activated ,3
IDE04307-IDE01762-Vehicle function list BAP-Doors,not activated ,11
IDE04307-IDE03031-Vehicle function list BAP-Seat adjustment,not activated ,11
IDE04307-IDE03111-Vehicle function list BAP-Interior lighting,not activated ,11
IDE04307-MAS00688-Vehicle function list BAP-Multi-function display,activated ,11
IDE04307-MAS00903-Vehicle function list BAP-Service interval display (SID),not activated ,11
IDE04307-MAS01118-Vehicle function list BAP-Air Conditioning,not activated ,11
IDE04307-MAS01282-Vehicle function list BAP-Wiper,not activated ,11
IDE04307-MAS01891-Vehicle function list BAP-Lane assist,not activated ,11
IDE04307-MAS02444-Vehicle function list BAP-Central locking system,activated ,11
IDE04307-MAS03385-Vehicle function list BAP-Lane change assistance,not activated ,11
IDE04307-MAS03420-Vehicle function list BAP-Head-Up-Display,not activated ,11
IDE04307-MAS03853-Vehicle function list BAP-Traffic sign detection,not activated ,11
IDE04307-MAS04219-Vehicle function list BAP-Parking heater,activated ,11
IDE04307-MAS05087-Vehicle function list BAP-ACC,not activated ,11
IDE04307-MAS05506-Vehicle function list BAP-Stopping distance reduction,not activated ,11
IDE04307-MAS06654-Vehicle function list BAP-Charge manager,not activated ,11
IDE04307-MAS07249-Vehicle function list BAP-High Beam,not activated ,11
IDE04307-MAS08072-Vehicle function list BAP-Driving profile selection,not activated ,11
IDE04307-MAS08785-Vehicle function list BAP-Parking aid,not activated ,11
IDE04307-MAS20539-Vehicle function list BAP-BAP distance PaCo_0x55,not activated ,11
IDE04307-MAS20545-Vehicle function list BAP-BAP distance doors2_0x63,not activated ,11
IDE04307-MAS20550-Vehicle function list BAP-BAP distance infotainment_settings_0x50,not activated ,11
IDE04307-MAS20553-Vehicle function list BAP-BAP distance mirror_0x0E,not activated ,11
IDE04307-MAS20556-Vehicle function list BAP-BAP distance unit_master_0x13,not activated ,11
IDE04307-MAS22226-Vehicle function list BAP-BAP distance REM_0x5B,not activated ,11
IDE04307-MAS22227-Vehicle function list BAP-BAP distance REM2_0x67,not activated ,11
IDE04307-MAS22228-Vehicle function list BAP-BAP distance remote_services_0x4E,not activated ,11
IDE04307-MAS22229-Vehicle function list BAP-BAP distance info_settings_0x50_Buszuordnung,Ethernet ,11
IDE04307-MAS23125-Vehicle function list BAP-BAP distance RemonteStartOnline_0x70,not activated ,11
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,255 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,60 min,2
IDE07699-Mobile network operator,apn3.vwg-connect ,21
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,OFF ,1
IDE08814-ENG244944-Navigation receiver GNSS configuration-Beidou,OFF ,1
IDE08814-ENG244974-Navigation receiver GNSS configuration-Dead_reckoning_position_transmission,On ,1
IDE08814-ENG245012-Navigation receiver GNSS configuration-GPS_output_on_CAN,On ,1
IDE09244-Fuel tank volume,70 l,1
IDE11108-Remote vehicle immobilizer safety protocol,Fazit4MyCar ,1
IDE11306-ENG154717-Vehicle status remote query-Remote_Vehicle_Status_BEM_Alert_Changed,not activated ,5
IDE11306-ENG154718-Vehicle status remote query-Remote_Vehicle_Status_Bussleep,not activated ,5
IDE11306-ENG154719-Vehicle status remote query-Remote_Vehicle_Status_Bussleep_Delay,5 s,5
IDE11306-ENG123302-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_Off_Delay,40 s,5
IDE11306-ENG123301-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,5
IDE11306-ENG154720-Vehicle status remote query-Remote_Vehicle_Status_Trigger_Relock,10 s,5
IDE13547-ENG101574-Dimming curve of the red functional lighting in case of various colors at the same time-X1,0 ,12
IDE13547-ENG99557-Dimming curve of the red functional lighting in case of various colors at the same time-X2,20 ,12
IDE13547-ENG102140-Dimming curve of the red functional lighting in case of various colors at the same time-X3,50 ,12
IDE13547-ENG102936-Dimming curve of the red functional lighting in case of various colors at the same time-X4,100 ,12
IDE13547-ENG103548-Dimming curve of the red functional lighting in case of various colors at the same time-X5,150 ,12
IDE13547-ENG113992-Dimming curve of the red functional lighting in case of various colors at the same time-X6,253 ,12
IDE13547-ENG99777-Dimming curve of the red functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13547-ENG100480-Dimming curve of the red functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13547-ENG100773-Dimming curve of the red functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13547-ENG100631-Dimming curve of the red functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13547-ENG102174-Dimming curve of the red functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13547-ENG113993-Dimming curve of the red functional lighting in case of various colors at the same time-Y6,50 %,12
IDE13548-ENG101574-Dimming curve of the green functional lighting in case of various colors at the same time-X1,0 ,12
IDE13548-ENG99557-Dimming curve of the green functional lighting in case of various colors at the same time-X2,20 ,12
IDE13548-ENG102140-Dimming curve of the green functional lighting in case of various colors at the same time-X3,50 ,12
IDE13548-ENG102936-Dimming curve of the green functional lighting in case of various colors at the same time-X4,100 ,12
IDE13548-ENG103548-Dimming curve of the green functional lighting in case of various colors at the same time-X5,150 ,12
IDE13548-ENG113992-Dimming curve of the green functional lighting in case of various colors at the same time-X6,253 ,12
IDE13548-ENG99777-Dimming curve of the green functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13548-ENG100480-Dimming curve of the green functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13548-ENG100773-Dimming curve of the green functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13548-ENG100631-Dimming curve of the green functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13548-ENG102174-Dimming curve of the green functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13548-ENG113993-Dimming curve of the green functional lighting in case of various colors at the same time-Y6,50 %,12
IDE14170-Timeout for service key query,10 ,1
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Maximum private sphere in shape 2 ,7
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,not activated ,7
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic setting not recognized Guest: services,Workshop settings adopted ,7
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic setting not recognized Guest: campaigns with interest weighting,Workshop settings adopted ,7
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic setting not recognized Guest: campaigns with consent,Workshop settings adopted ,7
IDE14995-MAS19887-Private sphere mode: workshop settings-Display info window for current privacy settings,No display ,7
IDE14995-MAS19892-Private sphere mode: workshop settings-Display selection for recurring dialog display,No display ,7
IDE14995-MAS19893-Private sphere mode: workshop settings-Selection for recurring dialog display availability,for personalized users ,7
IDE14995-ENG98891-Private sphere mode: workshop settings-Reserved,0 ,7
IDE15042-MAS19716-Privacy mode: customer settings-Services,Maximum private sphere in shape 2 ,3
IDE15042-MAS19722-Privacy mode: customer settings-Data collector,not activated ,3
IDE15042-MAS19887-Privacy mode: customer settings-Display info window for current privacy settings,No display ,3
IDE15074-MAS13668-Broadband audio-Emergency call,not activated ,1
IDE15074-MAS20714-Broadband audio-Breakdown assistance/information call,not activated ,1
IDE15695-Front radar-based localization-,not activated ,1
IDE15695-ENG263520-Front radar-based localization-Front_radar_rem_data_output,not activated ,1
MAS01078-Vehicle model,Light commercial vehicles (category N1) ,1
MAS07110-Muting of audio sources,Muting not active ,1
MAS07467-Speed warning maximum speed,0 km/h,2
MAS08170-User profile name,blank ,5
MAS08171-User profile password,blank ,5
MAS08172-Mobile Online services: first host name-,https://mod3vkmsmbbreg-0.prd.eu.dp.vwg-connect.com/mbb/vehicles/v2/registration/        ,513
MAS08172-MAS17438-Mobile Online services: first host name-Preselection of host names,free ,513
MAS08172-ENG247627-Mobile Online services: first host name-Online_Service_Backend_Type,MBB ,513
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
MAS08177-Acoustic warning for vehicle shut-down,activated ,1
MAS08366-MAS01487-Keypad-LED,Direct ,1
MAS08366-MAS10536-Keypad-Keys,Normal/Hybrid ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS09650-Threshold for vehicle movement recognition,5 km/h,2
MAS13395-Transmission_status_activation-,activated ,5
MAS13395-MAS13397-Transmission_status_activation-No transmission after OTVreques,1000 d,5
MAS13395-MAS13398-Transmission_status_activation-Number of days prior to service schedule_before display combi,30 d,5
MAS13395-MAS13399-Transmission_status_activation-Number of days before service reminder,0 d,5
MAS13396-MAS13392-Remote BatteryCharging Management_Battery Status Report-threshold,95 %,3
MAS13396-MAS13394-Remote BatteryCharging Management_Battery Status Report-Steps Above Threshold,1 %,3
MAS13396-MAS13442-Remote BatteryCharging Management_Battery Status Report-Transmission interval below threshold,5 %,3
MAS13840-Gnss data transmission rate,10 Hz ,2
MAS13841-Gnss min height,5 °,2
MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,50 ,6
MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,50 %,6
MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
MAS17119-ENG245041-Fault memory mobile online service threshold-Step_00,100 ,32
MAS17119-ENG244993-Fault memory mobile online service threshold-Step_01,100 ,32
MAS17119-ENG244984-Fault memory mobile online service threshold-Step_02,100 ,32
MAS17119-ENG245001-Fault memory mobile online service threshold-Step_03,100 ,32
MAS17119-ENG245016-Fault memory mobile online service threshold-Step_04,100 ,32
MAS17119-ENG245017-Fault memory mobile online service threshold-Step_05,100 ,32
MAS17119-ENG245042-Fault memory mobile online service threshold-Step_06,100 ,32
MAS17119-ENG245043-Fault memory mobile online service threshold-Step_07,100 ,32
MAS17119-ENG244962-Fault memory mobile online service threshold-Step_08,0 ,32
MAS17119-ENG245032-Fault memory mobile online service threshold-Step_09,0 ,32
MAS17119-ENG245002-Fault memory mobile online service threshold-Step_10,0 ,32
MAS17119-ENG245003-Fault memory mobile online service threshold-Step_11,0 ,32
MAS17119-ENG245018-Fault memory mobile online service threshold-Step_12,0 ,32
MAS17119-ENG244967-Fault memory mobile online service threshold-Step_13,0 ,32
MAS17119-ENG244985-Fault memory mobile online service threshold-Step_14,0 ,32
MAS17119-ENG244968-Fault memory mobile online service threshold-Step_15,0 ,32
MAS17427-MAS00220-Door configuration-Left rear door,installed ,1
MAS17427-MAS00221-Door configuration-Right rear door,installed ,1
MAS17427-SFT271922-Door configuration-Left rear door control module,not installed ,1
MAS17427-SFT271923-Door configuration-Right rear door control module,not installed ,1
MAS17439-Wifi hotspot mobile phone connection: network operator, ,17
MAS17460-Wifi hotspot mobile phone connection: user profile name, ,5
MAS17461-Wifi hotspot mobile phone connection: password, ,5
MAS17554-Digital key: backend notification,not activated ,1
MAS17562-Query interval for Real Time Monitoring,1 s,1
MAS18217-IDE09602-Activation status for local hazard warning service-Locale hazard warning,OFF ,1
MAS18217-MAS18218-Activation status for local hazard warning service-Accident,OFF ,1
MAS18217-MAS18219-Activation status for local hazard warning service-Breakdown,OFF ,1
MAS18217-MAS18220-Activation status for local hazard warning service-Loss of traction,OFF ,1
MAS18217-MAS18221-Activation status for local hazard warning service-Visual obstruction,OFF ,1
MAS18217-MAS18222-Activation status for local hazard warning service-Hydroplaning,OFF ,1
MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
MAS18272-Breakdown assistance call: protocol version,Generation_20 ,1
MAS18603-ENG247383-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247384-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Up,0.2 s,4
MAS18603-ENG247607-Damping factor for dimming up and down-Functional_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247608-Damping factor for dimming up and down-Functional_Illumination_Damping_Up,0.2 s,4
MAS18701-Setting the product data,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 C6 02 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,3296
MAS19210-Maximum waiting time to transfer UserID from IAA,150 ms,1
MAS19211-Delay time for synchronization with memory site,400 ms,1
MAS19213-Operation during severe BAP errors while storing data,Continue operation ,1
MAS19214-Maximum synchronization of an unused shadow drive,28 d,1
MAS19215-Waiting time until change to settings is transferred,60 s,2
MAS19216-Number of extensions until transfer is completed,3 s,1
MAS19218-Delay time for picking up changes,120 s,1
MAS19219-Maximum waiting time for HMI availability,5 min,1
MAS19220-Download before activating driver (driver already stored),Do not perform download ,1
MAS19221-Maximum storage duration,120 s,1
MAS19222-Maximum waiting time before storing is canceled,5 s,1
MAS19233-Identify Authorize Authenticate - user management,not installed ,1
MAS19239-Time window for key recognition,5 min,1
MAS19240-Authorization level after-run time,30 min,1
MAS19241-Key recognition mode setting,automatic ,1
MAS19242-User images display,On ,1
MAS19243-BCM user switching,OFF ,1
MAS19244-Permanent safety mode setting,On ,1
MAS19335-Maximum duration of relocation,60 s,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,Not_present ,10
ENG253242-ENG113413-a2b_data_streams-reserved_01,0 ,10
ENG253242-ENG261390-a2b_data_streams-reserved_02,0 ,10
ENG253242-ENG261450-a2b_data_streams-reserved_03,0 ,10
ENG253242-ENG261451-a2b_data_streams-reserved_04,0 ,10
ENG253242-ENG261386-a2b_data_streams-Reserved_05,0 ,10
ENG253242-ENG261387-a2b_data_streams-Reserved_06,0 ,10
ENG253242-ENG261388-a2b_data_streams-Reserved_07,0 ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG261370-Airbag_Signal_Setting,100 ms ,1
ENG275595-IDE01762-BAP_Connection_Control-Doors,OFF ,25
ENG275595-IDE03031-BAP_Connection_Control-Seat adjustment,OFF ,25
ENG275595-IDE03111-BAP_Connection_Control-Interior lighting,OFF ,25
ENG275595-MAS00688-BAP_Connection_Control-Multi-function display,OFF ,25
ENG275595-MAS01118-BAP_Connection_Control-Air Conditioning,OFF ,25
ENG275595-MAS01282-BAP_Connection_Control-Wiper,OFF ,25
ENG275595-MAS01891-BAP_Connection_Control-Lane assist,OFF ,25
ENG275595-MAS02444-BAP_Connection_Control-Central locking system,OFF ,25
ENG275595-MAS03385-BAP_Connection_Control-Lane change assistance,OFF ,25
ENG275595-MAS03420-BAP_Connection_Control-Head-Up-Display,OFF ,25
ENG275595-MAS03853-BAP_Connection_Control-Traffic sign detection,OFF ,25
ENG275595-MAS05087-BAP_Connection_Control-ACC,OFF ,25
ENG275595-MAS05506-BAP_Connection_Control-Stopping distance reduction,OFF ,25
ENG275595-MAS07249-BAP_Connection_Control-High Beam,OFF ,25
ENG275595-MAS08072-BAP_Connection_Control-Driving profile selection,OFF ,25
ENG275595-MAS08785-BAP_Connection_Control-Parking aid,OFF ,25
ENG275595-MAS20539-BAP_Connection_Control-BAP distance PaCo_0x55,OFF ,25
ENG275595-MAS20545-BAP_Connection_Control-BAP distance doors2_0x63,OFF ,25
ENG275595-MAS20550-BAP_Connection_Control-BAP distance infotainment_settings_0x50,OFF ,25
ENG275595-MAS20553-BAP_Connection_Control-BAP distance mirror_0x0E,OFF ,25
ENG275595-MAS20556-BAP_Connection_Control-BAP distance unit_master_0x13,OFF ,25
ENG275595-ENG98891-BAP_Connection_Control-Reserved,OFF ,25
ENG275595-ENG113413-BAP_Connection_Control-reserved_01,OFF ,25
ENG275595-ENG261390-BAP_Connection_Control-reserved_02,OFF ,25
ENG123200-Driving_Follow_Up_Time,5 min,1
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258583-function_configuration_a2b_topology-Mic_Module_Display,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG253218-ENG113413-function_configuration_a2b_topology-reserved_01,0 ,5
ENG253218-ENG261390-function_configuration_a2b_topology-reserved_02,0 ,5
ENG253218-ENG261450-function_configuration_a2b_topology-reserved_03,0 ,5
ENG244879-function_configuration_sw_update,On ,1
ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
ENG247336-MAS01424-Geofencing_Area_Height-max.value,4294967294 m,8
ENG247336-MAS01425-Geofencing_Area_Height-min.value,1 m,8
ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,2147483647 °,8
ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2147483648 °,8
ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,2147483647 °,8
ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2147483648 °,8
ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Mileage,500 m,12
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Driving direction,30 °,12
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
ENG153744-supress_climatisation_settings,not activated ,1
ENG153745-supress_climatisation_temperature,not activated ,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
Elapsed Time: 00:31
adpmap-811E-5WA-962-133-B_WV1ZZZSKZMX050719-20210914-1411.CSV
    SW:5WA-962-133-B   HW:5WA-962-133-B ---  Burglary Protection FL
    Component:Kessy RSAD    070 0636, Coding:
    EV_RSADVL37w,002013,EV_RSADVL37w.rod
    Tuesday,14,September,2021,14:11:42:34165
    VCDS Version: Release 21.9.0  Data version: 20210824 DS330.0
    VCID: 47CB52F0AF25A363268-8012
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 ,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 ,2
ENG253318-Par_Fahrzeugkonfiguration,255 dBµA/m,5
Elapsed Time: 00:01
adpmap-811F-5WA-962-133-B_WV1ZZZSKZMX050719-20210914-1411.CSV
    SW:5WA-962-133-B   HW:5WA-962-133-B ---  Burglary Protection FR
    EV_RSADVR37w,002013,EV_RSADHL37w.rod
    Tuesday,14,September,2021,14:11:45:34165
Elapsed Time: 00:01
adpmap-8120-5WA-962-133-B_WV1ZZZSKZMX050719-20210914-1411.CSV
    SW:5WA-962-133-B   HW:5WA-962-133-B ---  Burglary Protection RL
    EV_RSADHL37w,002013,EV_RSADHL37w.rod
    Tuesday,14,September,2021,14:11:49:34165
Elapsed Time: 00:01
adpmap-8121-5WA-962-133-B_WV1ZZZSKZMX050719-20210914-1411.CSV
    SW:5WA-962-133-B   HW:5WA-962-133-B ---  Burglary Protection RR
    EV_RSADHR37w,002013,EV_RSADHL37w.rod
    Tuesday,14,September,2021,14:11:53:34165
Elapsed Time: 00:01
adpmap-A5-5WA-980-653-A_WV1ZZZSKZMX050719-20210914-1411.CSV
    SW:5WA-980-653-A   HW:5WA-980-653 ---  Frt Sens. Drv. Assist
    Component:MQB MFK 3.0   H06 3129, Coding:000108900068C040409E00001020000002018000000000000000000000000000
    EV_MFK3ValeoMQB,005050,EV_MFK3ValeoMQB_005_VW38.rod
    Tuesday,14,September,2021,14:11:24:34165
    VCID: 4DC760D84D5949331C4-8018
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.000 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.000 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.000 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,0 mm,8
Elapsed Time: 00:07
adpmap-D6-992-941-571-AE_WV1ZZZSKZMX050719-20210914-1411.CSV
    SW:992-941-571-AE   HW:992-941-571-A ---  Light Ctrl Left 2
    Component:LED1L         H08 9202, Coding:
    EV_LLPGen3LKEBODPO68X,001003,EV_LLPGen3LKEBODPO68X_VW27.rod
    Tuesday,14,September,2021,14:11:34:34165
    VCID: 6597B87835E99173344-8030
ENG178994-Kodiercontainer Teilenummer,----------- ,11
ENG178993-Kodiercontainer Version,---- ,4
ENG178996-VehicleEquipmentCode And ProductionNumberCombination,00 00 00 00 00 00 00 00 00 00 00 00 ,12
Elapsed Time: 00:01
adpmap-D7-992-941-571-AE_WV1ZZZSKZMX050719-20210914-1411.CSV
    SW:992-941-571-AE   HW:992-941-571-A ---  Light Ctrl Right 2
    Component:LED1R         H08 9202, Coding:
    EV_LLPGen3RKEBODPO68X,001003,EV_LLPGen3LKEBODPO68X_VW27.rod
    Tuesday,14,September,2021,14:11:38:34165
Elapsed Time: 00:01
blockmap-OBD_WV1ZZZSKZMX050719-20210914-1412.CSV
    33-OBD2
    Tuesday,14,September,2021,14:12:03:34165
    VCID: 55F788B86C0901F3A44-8000
04,Calculated load value,0.0 %,0.0 %
05,Engine coolant temperature,38 °C,38 °C
0C,Engine RPM,0 /min,0 /min
0D,Vehicle speed,0 km/h,0 km/h
0F,Intake air temperature,34 °C
10,Mass Air Flow,0.00 g/s
11,Throttle position sensor,13.7 %
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,0 s
21,Distance travelled with MIL on,0 km
2F,Fuel Level Input,54.9 %
30,Warm-ups since DTC cleared,62
31,Distance since DTC cleared,1632 km
33,Barometric pressure,100 kPa abs
42,Control module voltage,11.280 V,11.200 V
45,Relative Throttle Position,0.0 %
46,Ambient Air Temp,28 °C
49,Accelerator Pedal Position D,14.1 %,14.5 %
4A,Accelerator Pedal Position E,14.1 %
4C,Commanded Throttle Actuator Control,0.0 %
51,Fuel type,Diesel
5C,Engine Oil Temp,35 °C
5E,Engine Fuel Rate,0.00 L/h
61,Torque Driver's Request,0.0 %
62,Torque actual,0.0 %
63,Torque Reference,320 Nm
65,Auxiliary Input/Output,GEAR_RCMD: N
67,Engine Coolant Temp,ECT 1:37 °C
69,EGR Command/Actual/Error,EGR A:0/0/0 %,EGR B:0/0/0 %
6B,EGR Temperature,EGRTemp 11/12:---/36 °C,EGRTemp 21/22:---/--- °C
6D,Fuel Press. Control A/B,FRP CMD:40000/--- kPa,FRP ACT:680/--- kPa,FRTemp:---/--- °C
70,Boost Press Ctrl A/B,BP_A cmd/act:91.7/100.4 kPa
71,Var. Geom. Turb. Ctrl A/B,VGT_A cmd/act:100.0/11.4 %,VGT_B cmd/act:---/--- %
77,Charge Air Temp.,B1S1/B1S2:37/37 °C
78,EGT Bank 1,S1/S2/S3/S4:,15/31/31/29 °C
7A,DPF Bank 1 Delta/In/Out,0.02/---/--- kPa
7F,Engine Run Time,Total:53H877s,Idle:18H512s
83,NOx Sensor Bank 1/2,NOx11:65535 ppm,NOx21:65535 ppm
85,NOx Control System,ReAg Rate/Demand:0.0/0.00 L/h,Reag Tnk Lvl:67.1 %,NWI Time:---
8B,Aftertreatment status,PF_Regen:Status:N,Typ:Pass.,PF_Load: 94.5 %,PF_Regen_Avg_D: 0 km
8C,O2 sensor wide range,1.001 lbd,7.995 lbd,7.995,7.995
8E,Eng. friction %torque,16.0 %
8F,PM sensor output,B1S1:ACT:NO    REGN:NO,B1S1:0.00 %
9B,DEF sensor,conc. proper,DEF_CON:  %,DEF_T:  °C,Reag Tnk Lvl: 100 %
9D,Fuel rate,Engine: 0.00 g/s,Vehicle: 0.00 g/s
9E,Exhaust flow rate,0.0 kg/h
A2,Cyl fuel rate,0.00 mg/str
A4,Trans. gear,N
A6,Odometer,1649.2 km
Type 02 - VIN : WV1ZZZSKZMX050719 (Address E8)
Type 04 - Calibration ID : 05L023AA0672BEAJHCUBDD0032251000NOX00907807 0046NOX00907807 0046NOX00907807 0046PMS00906261 1000 (Address E8)
Type 04 - Calibration ID : 0GC906555F++4161 (Address E9)
Type 06 - Calibration Verification Number : 0024DDC3 (Address E8)
Type 06 - Calibration Verification Number : 746D3ABF (Address E8)
Type 06 - Calibration Verification Number : 66040229 (Address E8)
Type 06 - Calibration Verification Number : D51ED7E2 (Address E8)
Type 06 - Calibration Verification Number : 43FB2DAA (Address E8)
Type 06 - Calibration Verification Number : E8811639 (Address E9)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Type 0B - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 32
    Ignition cycle count : 316
         NMHC Catalyst : 8 / 2
         NOx/SCR Catalyst : 34 / 32
         NOx Adsorber : 0 / 0
         PM Filter : 18 / 2
         Exhaust Gas Sensor : 14 / 32
         EGR and/or VVT : 41 / 32
         Boost Pressure : 316 / 32
         Fuel : 107 / 32
Type 17 - Vehicle Operation Data - Distance-Fuel Used, Recent/Lifetime:
         Total Distance Traveled : -0.1 km / 1649.2 km
         Total Fuel Consumed : -0.01 L / 111.20 L
OwnerTR
Turkey
C?ID=493252
5F-Information Electr map content with VIM code, USB doesn't play video I guess multimedia.
Is this multimedia Composition Color MIB3?
    SW:5H0-035-869   HW:5H0-035-869 ---  Information Electr.
    Component:MU-E-D-ER     099 1325, Coding:63521000000000000000000000000000000000000000000000
    EV_MUEIMQB37w,001003,EV_MUEIMQB37w_SE38.rod
    Friday,24,September,2021,10:13:57:34165
    VCDS Version: Release 21.9.0  Data version: 20210903 DS330.0
    VCID: 6C81CD5CD603A03B6B9-8038
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,manual ,1
IDE00768-Country identification: country of sale,TR ,2
IDE00769-Call number 1 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE02125-MAS08233-Voice operation for telephone-other,installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02330-Call number 2 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,255 ,121
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,255 ,121
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,255 ,121
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,255 ,121
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,255 ,121
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,255 ,121
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,255 ,121
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,255 ,121
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,255 ,121
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,255 ,121
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,255 ,121
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,255 ,121
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,255 ,121
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,255 ,121
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,255 ,121
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,255 ,121
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,255 ,121
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,255 ,121
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,255 ,121
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,255 ,121
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,255 ,121
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,255 ,121
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,255 ,121
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,255 ,121
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,255 ,121
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,255 ,121
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,255 ,121
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,255 ,121
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,255 ,121
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,255 ,121
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,255 ,121
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,255 ,121
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,255 ,121
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,255 ,121
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,255 ,121
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,255 ,121
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,255 ,121
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,255 ,121
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,255 ,121
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,255 ,121
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,255 ,121
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,255 ,121
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,255 ,121
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,255 ,121
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,255 ,121
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,255 ,121
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,255 ,121
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,255 ,121
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,30 ,121
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,30 ,121
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,30 ,121
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,30 ,121
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,30 ,121
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,30 ,121
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,30 ,121
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,30 ,121
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,30 ,121
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,30 ,121
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,30 ,121
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,30 ,121
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,30 ,121
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,30 ,121
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,30 ,121
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,30 ,121
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,30 ,121
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,30 ,121
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,30 ,121
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,30 ,121
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,30 ,121
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,30 ,121
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,30 ,121
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,30 ,121
IDE02502-Confirmation of installation change,EF 67 ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,not activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,not activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,not activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,not activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,not activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,not activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,not activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,not activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,not activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,not activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,not activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,not activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,not activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,not activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,not activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Terminal 15 ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,CAB_2 ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Infotainment data bus ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,Terminal 15 ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,CAB_5 ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,not activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Infotainment data bus ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,CAB_5 ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,CAB_5 ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,CAB_5 ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,not activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Infotainment data bus ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,Powertrain data bus ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,not activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,not activated ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,CAB_5 ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,Comfort data bus ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Powertrain data bus ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,not activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,not activated ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,not activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort data bus ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Terminal 15 ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,CAB_6 ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,not activated ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,Infotainment data bus ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,Infotainment data bus ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,Comfort data bus ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Terminal 15 ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,not activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,CAN_FAS ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Infotainment data bus ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,CAB_5 ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE04550-Bluetooth: Sniff mode,On ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,0 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE10604-Menu entries for mobile online services,not activated ,1
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dBµV,28 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,32 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11105-Brand-specific display of connect application, ,64
IDE11122-Country identification: country of sale HMI,TR ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11638-Bluetooth Audio Codec,01 ,1
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,slave ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Deactivated ,2
MAS00951-Bluetooth,On ,1
MAS03782-WLAN,On ,1
ENG248412-5_ghz_wlan,OFF ,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,Not_present ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG248413-alphabetic_scrollbar,On ,1
ENG252010-Car_net,we_connect ,1
ENG248423-channel_band_width_802_11ac,40MHz ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,No ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,BAP ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,BAP ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,OFF ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,0 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,OFF ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,BAP ,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG253062-Display_legal_text_MOD,OFF ,1
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248427-ENG248668-exit_screen_configuration-exit_screen,activated ,2
ENG248427-ENG248669-exit_screen_configuration-exit_screen_length_of_time,50000 ms,2
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258583-function_configuration_a2b_topology-Mic_Module_Display,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,20 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,OFF ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,OFF ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP_over_IP ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,No ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,usb_only ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Not available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_without_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Not available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Not available ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,usb_only ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,not installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,usb_only ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG101416-function_configuration_connectivity-Reserved_1,OFF ,6
ENG248430-ENG99458-function_configuration_connectivity-Reserved_2,not installed ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,OFF ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,OFF ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,OFF ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,OFF ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,OFF ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,not activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,OFF ,6
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,0 ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,1 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,OFF ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,OFF ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,OFF ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,not installed ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,not installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,not installed ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,Deactivated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,On ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,none ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,not installed ,3
ENG248435-ENG251555-function_configuration_pso-iaa_function,Deactivated ,2
ENG248435-ENG248795-function_configuration_pso-pso_function,Deactivated ,2
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,activated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,not activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,EU_RdW ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,EU_Band_III-N ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,EU_RdW ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,available. ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,AM_FM_ANT ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,Deactivated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,Deactivated ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,On ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,Deactivated ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,On ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,1 ,8
ENG248437-ENG248800-function_configuration_rvc-rear_view_low_rvc,not_active ,3
ENG248437-ENG245031-function_configuration_rvc-rvc_low_black_screen_trunk_open,not activated ,3
ENG248437-ENG244966-function_configuration_rvc-rvc_low_black_screen_velocity_threshold,not activated ,3
ENG248437-ENG245015-function_configuration_rvc-rvc_low_failsafe,not activated ,3
ENG248437-ENG248807-function_configuration_rvc-rvc_low_lid_close_delay_time,0 s,3
ENG248437-ENG248808-function_configuration_rvc-rvc_low_videofailure_detection_time,0 ,3
ENG248438-ENG248523-function_configuration_sound-brand_sound,No_Brand_Sound ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248440-function_configuration_swap_fod,swap_active_fod_not_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,IVI_partition_only ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,Ethernet ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,Deactivated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG248448-ENG248814-ipv4_address_of_subnet_1_on_ccu-segment_1,10 ,4
ENG248448-ENG248815-ipv4_address_of_subnet_1_on_ccu-segment_2,173 ,4
ENG248448-ENG248816-ipv4_address_of_subnet_1_on_ccu-segment_3,201 ,4
ENG248448-ENG248817-ipv4_address_of_subnet_1_on_ccu-segment_4,1 ,4
ENG248449-ENG248814-ipv4_address_of_subnet_1_on_mib-segment_1,10 ,4
ENG248449-ENG248815-ipv4_address_of_subnet_1_on_mib-segment_2,173 ,4
ENG248449-ENG248816-ipv4_address_of_subnet_1_on_mib-segment_3,201 ,4
ENG248449-ENG248817-ipv4_address_of_subnet_1_on_mib-segment_4,2 ,4
ENG248450-ENG248814-ipv4_address_of_subnet_2_on_ccu-segment_1,10 ,4
ENG248450-ENG248815-ipv4_address_of_subnet_2_on_ccu-segment_2,173 ,4
ENG248450-ENG248816-ipv4_address_of_subnet_2_on_ccu-segment_3,202 ,4
ENG248450-ENG248817-ipv4_address_of_subnet_2_on_ccu-segment_4,1 ,4
ENG248451-ENG248814-ipv4_address_of_subnet_2_on_mib-segment_1,10 ,4
ENG248451-ENG248815-ipv4_address_of_subnet_2_on_mib-segment_2,173 ,4
ENG248451-ENG248816-ipv4_address_of_subnet_2_on_mib-segment_3,202 ,4
ENG248451-ENG248817-ipv4_address_of_subnet_2_on_mib-segment_4,2 ,4
ENG248456-ENG248814-ipv4_address_of_the_wlan_ap-segment_1,10 ,4
ENG248456-ENG248815-ipv4_address_of_the_wlan_ap-segment_2,173 ,4
ENG248456-ENG248816-ipv4_address_of_the_wlan_ap-segment_3,189 ,4
ENG248456-ENG248817-ipv4_address_of_the_wlan_ap-segment_4,1 ,4
ENG248457-ENG248814-ipv6_address_of_subnet_1_on_ccu-segment_1,FD 30 ,8
ENG248457-ENG248815-ipv6_address_of_subnet_1_on_ccu-segment_2,E0 8E ,8
ENG248457-ENG248816-ipv6_address_of_subnet_1_on_ccu-segment_3,C0 31 ,8
ENG248457-ENG248817-ipv6_address_of_subnet_1_on_ccu-segment_4,00 01 ,8
ENG248458-ENG248814-ipv6_address_of_subnet_1_on_mib-segment_1,FD 30 ,8
ENG248458-ENG248815-ipv6_address_of_subnet_1_on_mib-segment_2,E0 8E ,8
ENG248458-ENG248816-ipv6_address_of_subnet_1_on_mib-segment_3,C0 31 ,8
ENG248458-ENG248817-ipv6_address_of_subnet_1_on_mib-segment_4,00 01 ,8
ENG248459-ENG248814-ipv6_address_of_subnet_2_on_ccu-segment_1,FD 30 ,8
ENG248459-ENG248815-ipv6_address_of_subnet_2_on_ccu-segment_2,E0 8E ,8
ENG248459-ENG248816-ipv6_address_of_subnet_2_on_ccu-segment_3,C0 31 ,8
ENG248459-ENG248817-ipv6_address_of_subnet_2_on_ccu-segment_4,00 02 ,8
ENG248460-ENG248814-ipv6_address_of_subnet_2_on_mib-segment_1,FD 30 ,8
ENG248460-ENG248815-ipv6_address_of_subnet_2_on_mib-segment_2,E0 8E ,8
ENG248460-ENG248816-ipv6_address_of_subnet_2_on_mib-segment_3,C0 31 ,8
ENG248460-ENG248817-ipv6_address_of_subnet_2_on_mib-segment_4,00 02 ,8
ENG248465-ENG248814-ipv6_address_of_the_wlan_ap-segment_1,FD 30 ,8
ENG248465-ENG248815-ipv6_address_of_the_wlan_ap-segment_2,E0 8E ,8
ENG248465-ENG248816-ipv6_address_of_the_wlan_ap-segment_3,C0 31 ,8
ENG248465-ENG248817-ipv6_address_of_the_wlan_ap-segment_4,01 03 ,8
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
ENG248467-number_to_name_matching_algorithm,detect_numbers ,1
ENG252007-Privacy_mode,activated ,2
ENG248469-same_ssid_for_2_4_and_5_ghz,Yes ,1
ENG248470-sortorder,sortorder_1 ,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG248475-wlan_ap_local_net_dhcp_lease_time,72 H,1
ENG244949-ENG248626-wlan_channel_numbers-channel_number_for_2_4GHz,6 ,1
ENG244949-ENG248627-wlan_channel_numbers-channel_number_for_5GHz,12 ,1
Elapsed Time: 00:42
luca2006
Tunisia
Do you have AA or apple car wireless working?
OwnerTR
Turkey
C?ID=493252
luca2006
Tunisia
Do you have SOS and e SIM module?
I saw that you have telematic module?
OwnerTR
Turkey
C?ID=493252
There is SOS. I don't understand SIM. If you say Navigation sim card, No Navigation. There is only Android Auto.
Westbury, UK
Navigation uses an SD card for the maps not a SIM card.
SIM card = Subscriber Identity Module, used by mobile communication systems to identify the subscriber.
OwnerTR
Turkey
C?ID=493252
I don't know about Sim card subscription of SOS system. Once I accidentally pressed the SOS button and the system made a call, and the Emergency Call attendant answered the phone.
