2015 Audi S3 8V fuel tank calibration/basic setting...
miktip
C?ID=32173
17- Instruments
Says basic settings missing...trying to recalibrate fuel tank but it wants 3 numbers...
Thank you
miktip
C?ID=32173
Monday,13,September,2021,03:45:16:53834
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WAUBFGFF5F1000000   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 22 2B 42 44 52 55 5F A9 BB
          BC
VIN: WAUBFGFF5F1000000   Mileage: 228158km-141770miles
   Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
   Component: KOMBI         H02 4291
   Coding: 0BED181B3B80D7050201A8001800000000000000
   Shop #: WSC 06385 790 00016
   VCID: 4CC1984BD64633CB0B9-8018
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 119
                    Mileage: 226306 km
                    Date: 2021.08.23
                    Time: 16:54:49
I dont see the Basic setting 3 digit number for this in the Factory Manual...
Thank you
That fault code in an instrument cluster is almost always due to some Service Interval related setting being off. I've never seen that fault code have anything to do with a tank sender.
Is there a problem with your fuel gauge or tank sender? If so, please describe it.
miktip
C?ID=32173
Thank you Uwe.
I assumed it was the fuel tank cause if you go to the basic settings in that module it gives you these options:
IDE02689-Complete tank calibration
IDE02690-IDE00805- Wet dry tank calibration
IDE05997- ENG114972 Immobolizer kessy key search
miktip
C?ID=32173
I found this:
Going to try it...see if it fixs. Will report back.
