Airbag module VW21 Programming
Reggie
C?ID=449122
Hi, New to this forum and looking for help/instructions coding a new VW21 airbag module in a 2018 5N Tiguan.
We have a Hex-Net HN2 software version 21.9.0 and cant find any info for coding this module, have found help for the earlier VW10 but not our module.
We have entered the long coding from the old module but it was rejected.
The car has not been in an accident and there is no crash data stored it is just showing an ECU internal fault and lots of different airbag/tensioner faults which although not current will not clear down.
Any help would be much appreciated.
Cheers Colin
Reggie
C?ID=449122
This is the auto scan with the old VW21 module.
Monday,13,September,2021,14:25:10:52545
VCDS Version: 21.9.0.2 (x64)  HEX-NET2 CB: 0.4555.4
Dealer/Shop Name: Mill Lane Autos
VIN: WVGZZZ5NZJW397342   License Plate: EO18 HMZ
Mileage: 55768km-34652mi   Repair Order: 10751
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 29 39 42 44 4B 52 5F A5
          BB BC CA D6 D7
VIN: WVGZZZ5NZJW397342   Mileage: 55768km-34652miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CZPA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 E    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0003
   Revision: 1DH31000    CVN: A37C013E
   Coding: 012500122466050B24000000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0115NA907115E 001005
   ROD: EV_ECM20TFS0115NA907115E.rod
   VCID: 40D2293BEA0F171BE71-8014
   VINID: 9E65EAAAA15EA9A9C32470C4085758150D
Readiness: 1110 0001
   Part No SW: 0DL 300 012 M    HW: 0DE 927 711 B
   Component: GSG DQ500     H16 2107
   Revision: 00H16V33    CVN: D6B16A11
   VCID: 333876F7ABB9BC836A3-8066
   Revision: 00000000    Serial number: 60288000001896
   Coding: 0AEE939A54292373477A070462C54950C92AC4E2E046927D38425078C22A4200002F641A1B13111435351919323200
   VCID: 77A082E7FF4190A396B-8022
8200 - Databus
          [FCAN: Airbag_01 message is not received]
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
8204 - Databus
          [FCAN: Airbag_02 message is not received]
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:23
8206 - Databus
          [FCAN: Airbag_03 message is not received]
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:26
8400 - Databus
          [FCAN: AB_Gurt_FA signal is invalid]
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:14:24
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K09000    Serial number: 00000B00827230
   Coding: 0012002420011001110510000010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   VCID: 4AC60B13DC33DD4B395-801E
   Humidity sensor: exterior:
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
329479 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [008] - Open or Short to Plus
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.16
                    Time: 17:45:48
                    Voltage terminal 30: 12.9 V
                    Inside temperature: 32.2 °C
                    Outside temperature: 22.0 °C
                    Fresh air/recirculating air/back pressure door specified value: 873
                    Actual value for fresh air/recirculation air flow flap: 913
                    Actual value for fresh air/recirculation air flow flap: 100.0 %
459009 - Databus
          [Airbagsteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001804000834
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0944F41F99B59653F0F-805C
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 100118  033 0372
   Serial number: 00000001801080300321
   Component: RLHS  047 0105
   Serial number: TAY18M02D13H11M08S29
   Coding: 00A8DD
   Serial number: 000000000ZY180080LKY
   Serial number: 00000000000099872194
528405 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
558101 - Databus
          [Airbag_02 Datenbus fehlende Botschaft]
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
   Part No SW: 3Q0 919 294 B    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H08 0029
   Serial number: 002101187498040
   Coding: 0071451811
   ASAM Dataset: EV_EPHBO18VW3260000 007018
   ROD: EV_EPHBO18VW3260000.rod
   VCID: 382241DBB2DF5FDB5F1-806C
12664901 - Databus
          [Airbag - Airbag_01 - kein Signal/keine Kommunikation]
                    Fault Frequency: 27
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:21
   Component: ACCCONTIMQB   H02 0233
   Coding: 320067C158FF8728749C8145804087
   VCID: 3E2E57C390FB61EB95D-806A
1025 - Databus
          [FAULT_TIMEOUT_AIRBAG_01]
                    Fault Frequency: 27
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 19 °C
                    Longitudinal_acceleration_vehicle_reference: 0.06 m/s²
1026 - Databus
          [FAULT_TIMEOUT_AIRBAG_02]
                    Fault Frequency: 26
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
                    Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
2074 - Databus
          [FAULT_SEATBELT_NOT_EQUIPPED]
                    Fault Frequency: 16
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR3VXJKR
   Coding: 98CCC0C00C0000005C5400CF008800000065
   Left seat belt tensioner:
   Serial number: 5NC857705C0041S00424
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 5NC857706C0040S01339
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 202 18
   Serial number: 357000000002B8097B2M
   Subsystem 4 - Part No SW: -----------    HW: 480 001 202 18
   Serial number: 35800000000AB8097B2V
   Subsystem 5 - Part No SW: -----------    HW: 480 401 102 18
   Serial number: 3510001A3291EE4567A9
   Subsystem 6 - Part No SW: -----------    HW: 480 401 102 18
   Serial number: 35200019B291EE43241%
   Subsystem 7 - Part No SW: -----------    HW: 480 401 102 18
   Serial number: 3550001A728928945484
   Subsystem 8 - Part No SW: -----------    HW: 480 400 902 18
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001B52909F0263F4
   Subsystem 9 - Part No SW: -----------    HW: 480 400 902 18
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001B52909F0623F5
   Subsystem 10 - Part No SW: -----------    HW: 480 400 902 18
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001B52909F04B51Z
   Subsystem 11 - Part No SW: -----------    HW: 480 000 502 18
   Serial number: I0M00000000E49C45A2E
   Subsystem 12 - Part No SW: -----------    HW: 480 000 502 18
   Serial number: I0N00000000D49C45A2E
8 Faults Found:
9440017 - Driver's side; side-airbag igniter
          B100B 11 [136] - Short to Ground
                    Mileage: 55338 km
                    Date: 2021.07.26
                    Time: 18:36:31
13636096 - Supply voltage
          U1012 00 [008] - Voltage too High
          [Powersupply  upper threshold exceeded]
                    Fault Frequency: 12
                    Reset counter: 53
                    Mileage: 55342 km
                    Date: 2021.07.27
                    Time: 08:37:44
9629972 - Indicator Lamp for Passenger Airbag Enabled
          B12F1 14 [136] - Open or Short to Ground
                    Mileage: 55338 km
                    Date: 2021.07.26
                    Time: 18:36:57
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [136] - Open or Short to Ground
                    Mileage: 55338 km
                    Date: 2021.07.26
                    Time: 18:36:57
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 61
                    Mileage: 55590 km
                    Date: 2021.07.31
                    Time: 00:00:50
16712603 - Internal Control Module Memory Check Sum Error
          B2000 00 [137] - -
          [Electronic Control Unit Malfunction]
                    Mileage: 55554 km
                    Date: 2021.07.30
                    Time: 18:36:23
16712693 - Internal Control Module Memory Check Sum Error
          B2000 00 [136] - -
                    Mileage: 55342 km
                    Date: 2021.07.27
                    Time: 09:22:39
16712694 - Internal Control Module Memory Check Sum Error
          B2000 00 [136] - -
                    Mileage: 55338 km
                    Date: 2021.07.27
                    Time: 08:20:21
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20180214200836
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41D42C3FE1051E13E8F-8014
   Part No SW: 5NA 920 791 B    HW: 5NA 920 791 B
   Component: KOMBI         408 3195
   Coding: 27A400086F84060001886B031401000000000000
   VCID: 42D62333E403050BF15-8016
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
   Component: GW MQB High   518 5323
   Serial number: 30011810521743
   Coding: 030500047F085900FB07225E1E0F00010001070000000000000000000000
   GVL: 01D63C0000000000408C80000000C80010000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   Generator:
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0301815454930731AS3B
   Coding: 2D0000
   Serial number: 3022226604
131605 - No Communications with Airbag Control Module
          U0151 00 [008] - -
          [Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
                    Fault Frequency: 24
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:23
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: On
          U1101 00 [008] - Active
                    Fault Frequency: 15
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.09.02
                    Time: 11:57:26
                    Terminal 30 power supply: 13.1 V
                    Terminal 15: On
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.09.13
                    Time: 11:08:30
                    Terminal 30 power supply: 11.2 V
                    Terminal 15: On
   Serial number: HA1-00011.01.18
   Coding: 0101
   VCID: 4CCA0D0BD647C37B0B9-8018
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45DC382FF52D3233D47-8010
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 201217ELK19667
   Coding: 003F0220D001048000001000
   VCID: 43D82637FB190C03FA3-8016
65799 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 27
                    Mileage: 55768 km
                    Date: 2021.08.16
                    Time: 17:34:02
458752 - Databus
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
458857 - Databus
          [RGS_VL_01 Datenbus fehlende Botschaft]
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: 91170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B8B6F7EB39FC83AA3-8026
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 28011810520726
   Coding: 000000050100085600104F010A0000000000000000000000000000000000
   VCID: 72B6B3F39423F58BA15-8026
13705485 - Databus
          [Airbag_02 data bus missing message]
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:21
   Serial number: 130118EAD11319
   Coding: 003F0020DE01048000001000
                    Reset counter: 27
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 16:47:26
458752 - Databus
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
458857 - Databus
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Coding: 02730601FF00000051110101008808001F0500E6012000008F
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323673F354A3B58B615-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHV0082647
   Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
   Component: ECE1 2018  --- 0915
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:30
                    Voltage terminal 30: 12.3 V
                    Network diagnosis-Status: Enabled
6943 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Reversible belt tensioner (0x1F) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.09.02
                    Time: 19:05:54
                    Voltage terminal 30: 11.6 V
7199 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Reversible belt tensioner (0x1F) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.18
                    Time: 16:11:03
                    Voltage terminal 30: 12.7 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 20011812K11898
   Coding: 0003070600000401000213448150A90094000E200040
   VCID: 3C2A5DCB86E773FBBB9-8068
1122563 - Databus
          [Timeout_Airbag_01]
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:23
                    Control Module temperature: 23 °C
                    Outside temperature: 18.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 3.3 s
                    Voltage terminal 15: 12.0 V
                    mid: 01 A5
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1123187 - Local Data Bus
          U116B 00 [008] - Received Malfunction Value
          [RDR1_Header_FGN_Status]
                    Fault Frequency: 27
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:23
                    mid: 02 C0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 211217ELK36263
   Coding: 002A00200100048000001000
   Serial number: 211217ELL16653
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 308040732602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D2C50CF9DFD7AF38C7-8068
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 167EAF63D80B49AB6DD-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:15, VBatt start/end: 12.2V/12.2V)-----------
Reggie
C?ID=449122
This is the autoscan with the new uncoded VW21
Monday,13,September,2021,14:35:20:52545
Mileage: 55768km-34652mi   Repair Order: 10751/A
          BB BC CA D6 D7
8200 - Databus
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
8204 - Databus
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:23
8206 - Databus
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:26
8400 - Databus
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:14:24
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.16
                    Time: 17:45:48
459009 - Databus
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
   Coding: 00A8DD
528405 - Databus
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
558101 - Databus
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
   Coding: 0071451811
12664901 - Databus
                    Fault Frequency: 27
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:21
1025 - Databus
                    Fault Frequency: 27
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
1026 - Databus
                    Fault Frequency: 26
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
2074 - Databus
                    Fault Frequency: 16
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:22
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4P9R0T
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   Coding: 80000D
   Coding: 80000D
   Component: FrontSensor_P  000 6149
   Serial number: 3560001B52909F04B511
   Subsystem 11 - Part No SW: -----------    HW: 480 400 902 18
   Subsystem 13 - Part No SW: -----------    HW: 480 000 502 18
21 Faults Found:
9442587 - Igniter for battery interrupt
          B1015 1B [129] - Resistance Too High
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [129] - Resistance Too High
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [129] - Resistance Too High
9443402 - Rear Side Airbag Crash Sensor (on driver's side)
          B1018 4A [129] - Incorrect Component(s) Installed
9443146 - Driver's Side Airbag Crash Sensor
          B1017 4A [129] - Incorrect Component(s) Installed
9443658 - Rear Side Airbag Crash Sensor (on front passenger's side)
          B1019 4A [129] - Incorrect Component(s) Installed
9451082 - Crash sensor side airbag; passenger side
          B1036 4A [129] - Incorrect Component(s) Installed
9443914 - Driver's Front Airbag Crash Sensor
          B101A 4A [129] - Incorrect Component(s) Installed
9450058 - Pedestrian Protection Crash Sensor (driver's side)
          B1032 4A [129] - Incorrect Component(s) Installed
9450314 - Pedestrian Protection Crash Sensor (passenger's side)
          B1033 4A [129] - Incorrect Component(s) Installed
9496906 - Front Crash Sensor for Pedestrian Protection
          B10E9 4A [129] - Incorrect Component(s) Installed
9444170 - Front Passenger's Front Airbag Crash Sensor
          B101B 4A [129] - Incorrect Component(s) Installed
9735498 - Pedestrian Protection Crash Sensor 2; Driver Side
          B148D 4A [129] - Incorrect Component(s) Installed
9735754 - Pedestrian Protection Crash Sensor 2; Passenger Side
          B148E 4A [129] - Incorrect Component(s) Installed
10493696 - Pre-Crash Not Configured
          B201F 00 [137] - -
9444885 - Driver's seat position sensor
          B101E 15 [129] - Open or Short to Plus
9445141 - Passenger's seat position sensor
          B101F 15 [129] - Open or Short to Plus
13697024 - Component Protection
          U1100 00 [129] - No Basic Setting
          [Component Protection Not Configured Or Invalid Initial State/ Adjustment]
15361024 - Component Protection
          U1101 00 [129] - Active
          [ATP DiagServiceOrEepFailure]
10490624 - No End-of-Line Programming
          B2013 00 [137] - -
          [ECU not EOL programmed]
10487040 - invalid data record
          B2005 00 [137] - -
          [Invalid Dataset]
   Coding: 0C10
16776962 - Databus
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
   Generator:
   Coding: 2D0000
          U0151 00 [008] - -
                    Fault Frequency: 24
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:23
                    Terminal 15: On
                    Fault Frequency: 15
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.09.02
                    Time: 11:57:26
                    Terminal 15: On
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.09.13
                    Time: 11:08:30
                    Terminal 15: On
   Coding: 0101
                    Reset counter: 27
                    Mileage: 55768 km
                    Date: 2021.08.16
                    Time: 17:34:02
458752 - Databus
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
458857 - Databus
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
   Coding: 91170000
13705485 - Databus
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:21
                    Reset counter: 27
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 16:47:26
458752 - Databus
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
458857 - Databus
                    Fault Frequency: 8
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:20
6697 - Databus
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:30
          U1111 00 [008] - -
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.09.02
                    Time: 19:05:54
          U1111 00 [008] - -
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.18
                    Time: 16:11:03
1122563 - Databus
          [Timeout_Airbag_01]
                    Fault Frequency: 9
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:23
                    mid: 01 A5
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
                    Fault Frequency: 27
                    Reset counter: 67
                    Mileage: 55768 km
                    Date: 2021.08.17
                    Time: 17:10:23
                    mid: 02 C0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
You could copy & paste the coding from the old scan into the new module, but unfortunately, these modules have
Component Protection (as evidenced by the U1100 fault in the new module). That means the new module must be adapted via an on-line connection to VAG's servers, which can't be done using VCDS. Even with ODIS, it requires special "Fazit" credentials.
Fred's Imports
Vermont, USA
C?ID=16454
Might need an SVC code to unlock the new module with ODIS, there should be a parts bulletin linked to the parts breakdown in ETKA.
Post edit, there's no parts bulletin for SVC code on this application.
