Unable to find a .ROD file for CRFT1_ESP
Wrc_corolla
C?ID=351736
Hi I am trying to diagnose an ABS light on a VW Crafter Panel Van and when trying to access "95: LT3 ESP" I get an error message that it is unable to find a .ROD file, CRFT1_ESP.rod. Below is the autoscan. Is there a missing file I need or something? I have updated to latest version etc.
Thursday,09,September,2021,18:25:55:56620
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: xxx License Plate:
Mileage: 4   Repair Order:
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
VIN: xxx
Address 01: Engine (J623-CKTB)       Labels:. 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 Q    HW: 03L 906 012 A
   Component: R4 2.0l TDI   H26 9977
   Revision: 72H26---    Serial number: VWXDZ0M1019390 CVN: 07D419D2
   Coding: 0119401020040C080000
   ASAM Dataset: EV_ECM20TDI01103L906012Q 002014
   ROD: EV_ECM20TDI01103L906012Q_002.rod
   VCID: 323D18D324A2B35B615-8066
   VINID: 9E606AAAA095A941800C424524DD3C4687
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 A    HW: 906 900 270 2
   Component: IMMO          0805  1246
   Revision: 00805000    Serial number: VWXDZ0M1019390
   VCID: 2517F38F69ECD4E3F47-8070
Address 94: LT3 Airbag
   Part No HW: 9069005701
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F7834F758C8463A47-8000
Address 95: LT3 ESP
   Part No HW: 0009015901
   Serial number: 000901590110851
   ASAM Dataset: CRFT2_ESP 3
   ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
   Part No SW: 9069023301    HW: 9069019800
   ASAM Dataset: 32 791
   ROD: CRFT_KOMBI_32_791.rod
   VCID: 015F871FD184D8C3A8F-8054
9219 - ABS Control Module (J104): Shutoff level implausible
            Test Complete - Active/Stored
Address 99: LT3 Ign. Switch
   Part No HW: 9069002702
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
900F - ABS Control Module (J104): Emergency opening canceled
            Test Complete - Stored
900E - ABS Control Module (J104): Emergency opening performed
900D - ABS Control Module (J104): Emergency opening detected
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  1246
   Revision: 00805000    Serial number: 12345678901234
   Shop #: WSC 00137 211 56823
01179 - Incorrect Key Programming
00172 - Key 2 not learned
            002 - Lower Limit Exceeded
Address 9B: LT3 Driver Door
   Part No HW: 9068204126
   ASAM Dataset: 33 773
   ROD: CRFT_FTUHR_33_773.rod (*)
9023 - Central locking; emergency opening activated: msg from elect. Ign./starter switch
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BA3F5F7B368B213F23-802E
9092 - Interior Monitoring Sensor (G273)/ Interior Monitoring Sensor (G592): Comm. error
Address B4: LT3 Central Elec.
   Part No SW: 9069022001    HW: 9069013100
   ASAM Dataset: 33 833
   ROD: CRFT_EZE_33_1088.rod (*)
   VCID: 7DA7FBEFAD7CBC23CC7-8028
9097 - Cent. locking - emerg. unlock activated: Sensor msg. from elect. Ign./start switch
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 06559403F8AAFFFB9DD-8052
End----------(Elapsed Time: 00:51, VBatt start/end: 12.4V/12.3V)-----------
                Address 95: LT3 ESP
Control Module Part Number: 0009015901
  Component and/or Version:
           Software Coding:
            Work Shop Code:
VCDS Info:
       Labels: None
       ROD: CRFT1_ESP.rod
                Address 95: LT3 ESP
           Software Coding:
            Work Shop Code:
VCDS Info:
       Labels: None
       ROD: CRFT1_ESP.rod
Wrc_corolla
C?ID=351736
Bump. Can you provide any support for this issue?
I think I would start with a Full / Complete and unedited Auto-scan and the VIN (minus the last 5 digits if you would like to conceal your individual and unique equipment). That is typically a requirement here.
Wrc_corolla
C?ID=351736
Ok I didn't think it would matter for this issue and hid it as it's not my vehicle but full autoscan is below.
I saw a similar query on another thread but no real resolution. Is this an issue with the vcds module or software or is it likely to be an issue with the vehicle hardware or compatibility?
VIN: WV1ZZZ2EZD6034959   License Plate: HAMEL
Mileage: 4444   Repair Order: xxx
Address 95: LT3 ESP
   ROD: CRFT1_ESP.rod
No Faults Found
   ASAM Dataset: 21 3
                Address 95: LT3 ESP
           Software Coding:
            Work Shop Code:
VCDS Info:
       Labels: None
       ROD: CRFT1_ESP.rod
                Address 95: LT3 ESP
           Software Coding:
            Work Shop Code:
VCDS Info:
       Labels: None
       ROD: CRFT1_ESP.rod
I don't see a "ROD not found" here. :confused:
What I do see is:
No Faults Found
That's indicative of a communications problem, which could be something with VCDS, or it could be something wonky with your ABS module.
