VW Golf 8 can`t clear DTC message OBD2 broadcast!
trompt
C?ID=258023
I want to clear the error on the ABS control unit but get a message clear thru OBD2 broadcast, but its not working.
Maybe it doesn't work due to SFD security?
I also deleted 17 and 19 and claer all dtc.
downtime
Finland
C?ID=280813
What if you go to module 03 and clear dtcs there?
trompt
C?ID=258023
That's what i did first.
does'nt work.
I have the latest firmware and software installed, could that be it?
What is the fault you are trying to clear?
Please post an Auto-Scan for context.
trompt
C?ID=258023
I have completely uninstalled vcds and then reinstalled it now i can erase it, but i see the following problem.
When I scan the car I see 5F Malfunction 0010 but before I create another log file and after that I see no error message.
How can I find out what error message this is?
unday,12,September,2021,23:02:34:22779
VCDS Version: 21.9.0.2 (x64)  HEX-NET CB: 0.4555.4
VIN: WVWZZZCDZLW000000   License Plate: 89
Mileage: 8467km-5261mi   Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 52 5F 75 82
          A5 D6 D7 8107 811E 811F 8120 8121
VIN: WVWZZZCDZLW000000   Mileage: 8467km-5261miles
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DPBA)       Labels: None
   Part No SW: 05E 906 012     HW: 05E 907 309 D
   Component: R4 1.5l TFS   H20 9970
   Revision: 8AH20000    CVN: C152E256
   Coding: 011900322364150830080000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906012 002008
   ROD: EV_ECM15TFS01105E906012.rod
   VCID: 5CF4437957737C697D-8008
   VINID: 9E69EAAAA4D4A9C9C00450C71804110640
Readiness: 1110 0001
   Part No SW: 5WA 614 517 BA    HW: 5WA 614 517 A
   Component: ESC           H09 0020
   Serial number: 60280000000378a
   Coding: 34FC2C9022214471527A50070AC961862DB458F042D067C0019CA231218FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 007045
   ROD: EV_Brake1ESCEPBMQB37W_007_VW38.rod
   VCID: 085C4F29B36BC0C909-805C SFD
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 C    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003_VW38.rod
   VCID: 54E4AB593FA3B429B5-8000
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 727 P    HW: 5WA 907 727 T
   Component: Climatronic   H01 0341
   Coding: 002000010211120010100000111011110000131100200000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005067
   ROD: EV_ACClimaBHBVW38X_VW38.rod
   VCID: 5DF24E7D4C6975610A-8008
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H01 0002
   Serial number: 00000000000000046620
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001120120192656501
   Part No SW: 5WA 937 086 Q    HW: 5WA 937 086 J
   Component: BCM 37W BOSCH 016 0136
   Serial number: BXJ53F240120940
   ASAM Dataset: EV_BCM37w 005001
   ROD: EV_BCM37w_005_VW38.rod
   VCID: 5F8E74754665677118-800A SFD
   Subsystem 1 - Part No SW: 5H1 955 119     HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0041
   Serial number: 907453F0401930601788
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           051 0206
   Serial number: SBY20M01D21H16M29S00
   Subsystem 3 - Part No SW: 5H0 941 193 AD    HW: 5H0 941 193 AD
   Component: LiSi           H05 0007
   Serial number: 92471TB50014I
   Subsystem 4 - Part No SW: 5H0 925 200 P    HW: 5H0 925 200 P
   Component: DiETa          H06 0007
   Serial number: 92471TAR0008B
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000000802470
   Subsystem 6 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA    005 0316
   Serial number: 000000000ZY200100429
   Subsystem 7 - Part No SW: 5H0 959 561 H    HW: 5H0 959 561 H
   Component: DACHKONSOLE    006 0006
   Serial number: 92413TA300658-------
   Steering Column Switch:
   Subsystem 8 - Part No SW: 5Q1 953 507 Q    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000013012004221083
   Part No SW: 5WA 919 298     HW: 5WA 919 298
   Component: PLA 12K Kanal H04 0026
   Serial number: 000020121994630
   Coding: 8200026001
   ASAM Dataset: EV_EPHBO2CVW3800000 002027
   ROD: EV_EPHBO2CVW3800000_VW38.rod
   VCID: 13666845FA2D7311EC-8046
   Part No SW: 5WA 907 572 A    HW: 5WA 907 572
   Component: ACC Bosch MQB H10 0246
   Coding: 060318F70007404512474000000040054E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
   ROD: EV_FRONTRADARBOSCHVW380_003.rod
   VCID: 4CD4B339E793ECE9ED-8018
   Part No SW: 5WA 959 655 A    HW: 5WA 959 655 A
   Component: AirbagVW40    007 0523
   Serial number: 000000003C0DKR6
   Coding: 88CC000000C0C000000000000000000051540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001028
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 55E2565D3459AD2142-8000 SFD
   Subsystem 1 - Part No SW: -----------    HW: 480 402 801 20
   Serial number: 3510001A532AA632857
   Subsystem 2 - Part No SW: -----------    HW: 480 402 801 20
   Serial number: 3520001A532BE5946172
   Subsystem 3 - Part No SW: -----------    HW: 480 001 512 19
   Serial number: 35700000000237A4734C
   Subsystem 4 - Part No SW: -----------    HW: 480 001 301 20
   Serial number: 35800000000FAA79E443
   Subsystem 5 - Part No SW: -----------    HW: 480 402 001 20
   Component: FrontSensor_D  001 614A
   Serial number: 3550001B931DC1B597AK
   Part No SW: 5H0 920 340     HW: 5H0 920 340
   Component: KOMBI         237 1400
   Coding: 04A40000639C00080180620B2000080810300800
   ASAM Dataset: EV_DashBoardVDDMQB37W 002029
   ROD: EV_DashBoardVDDMQB37W_002_VW38.rod
   Part No SW: 5WA 907 530 B    HW: 5WA 907 530 B
   Component: GW2020 High   734 7068
   Revision: --------    Serial number: 150160900046131
   Coding: 0000808D0F00000000000000010301307301610900000300030100000001010000000000000000000000000000000000
   GVL: 3D080000020840DC800080004800004000004000004400000200000000000044
   ASAM Dataset: EV_GatewMQB2020 004003
   ROD: EV_GatewMQB2020_VW38.rod
   VCID: 47DE8C15FEF50FB1C0-8012 SFD
   Generator:
   Component: 2-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 4921023805
   Subsystem 3 - Part No SW: 3G0 959 442 R    HW: 3G0 959 442 R
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440066323201105
   Subsystem 4 - Part No SW: 5H0 959 542 D    HW: 5H0 959 542 D
   Component: KLR_JSS_1Zone  076 0019
2097338 - Ethernet Antenna Module
          U1646 00 [046] - No Communication
          [Antenna_control_module_1_no_communication_vlan]
                    Mileage: 8467 km
                    Date: 2021.09.12
                    Time: 14:33:40
   Part No SW: 5WA 909 059 E    HW: 3Q0 909 059 A
   Component: EBKV          H06 0092
   Serial number: BPA085210120013
   Coding: 1002C140730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 011021
   ROD: EV_BrakeBoostG2BoschVW37W_011_VW38.rod
   VCID: 52E8AD4105B7BA19A7-8006 SFD
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H08 0040
   Serial number: 20000006572008
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 3228CDC165779A1987-8066
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0361
   Serial number: 00000401299567
   Coding: 01589A400000A0508803010101010000000000212100000000000000215000
   VCID: 59FA5A6D5841894166-800C
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 E    HW: 2Q0 907 686 D
   Component: HRE_Master    H25 0284
   Serial number: 00000539504627
   Coding: 569945D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
   ROD: EV_HREntryHellaGen3Mstr.rod
   VCID: 3C34E3F9B7335C695D-8068
   Subsystem 1 - Part No SW: 2Q0 907 685 E    HW: 2Q0 907 685 D
   Component: HRE_Slave      H25 0284
   Serial number: 00000538239704
   Lane change assistance display left:
   Subsystem 2 - Part No SW: 5H1 949 145     HW: 5H1 949 145
   Component: SWA LED VL     H05 X005
   Serial number: 00000000000016909060
   Lane change assistance display right:
   Subsystem 3 - Part No SW: 5H1 949 146     HW: 5H1 949 146
   Component: SWA LED VR     H05 X005
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007SLB18387
   Coding: 003B1220D200040000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 49DA8A2DE8E1F9C1D6-801C
   Subsystem 1 - Part No SW: 5Q0 959 408 C    HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000037005403
   Coding: 110000
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  101 1040
   Serial number: 00041219
   Coding: 0000000000000000000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   VCID: 4DD2BE3D1C89E5E1FA-8018
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007SL911173
   Coding: 003B1020DE00040000801000
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 48DC8F29F3EB00C9C9-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 C    HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000036942473
   Coding: 090000
   Part No SW: 5H0 035 816 C    HW: 5H0 035 816 A
   Component: MU-O-ND-EU    H56 1668
   Serial number: WG8LGM1900000000
   Coding: 23800000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_VW38.rod
   VCID: 271E2C955EB5EFB120-8072 SFD
   No subsystems:
   Subsystem 2 - Part No SW: V03 959 804     HW: -----------
   Component: EU 2019/30     --- 202
   Part No SW: 5WA 035 284 A    HW: 5WA 035 284 A
   Component: OCU3HMQB37W   H12 0067
   Serial number: 0000000001VIRG8
   Coding: 023800009068A8209405460071502E07
   ASAM Dataset: EV_OCU3HMQB37W 001039
   ROD: EV_OCU3HMQB37W_001_VW38.rod
   VCID: 44C49B19CFC324A925-8010 SFD
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 5H1 919 608     HW: 5H1 919 608
   Component: HeadupDisplay H15 0027
   Coding: 5740C0
   ASAM Dataset: EV_HeadUpDisplMQB37W 001017
   ROD: EV_HeadUpDisplMQB37W.rod
   VCID: 6FAE04B5B6C5F7F1A8-803A
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H05 3129
   Serial number: E26735111200350
   Coding: 00000888216CC040109E00001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 6582669D64393DA1D2-8030
   Component: LED1R         H08 9202
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 B    HW: 5WA 035 741 B
   Component: TrxModulHigh  H10 0078
   Serial number: 0000000002VIWP1
   Coding: 02380011040080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: 43C69805CACD23911C-8016 SFD
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w.rod
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 01:33, VBatt start/end: 12.0V/12.0V)-----------
downtime
Finland
C?ID=280813
I would not worry about that as the Golf 8 platform seems to have more these random errors related to background software, ethernet connection etc.
I don't see anything odd in your autoscan.
trompt
C?ID=258023
This was before erasing the dtc....
Sunday,12,September,2021,14:06:43:22779
VIN: WVWZZZCDZLW010000   License Plate: J-8
Mileage: 8464km-5259mi   Repair Order:
VIN: WVWZZZCDZLW000000   Mileage: 8464km-5259miles
17156 - Databus
8519 - Implausible Data Received from Cruise Control Front Distance Range Sensor
          U0433 00 [032] - -
          [CCan_ACC_Anhalteweg_inv]
   Air quality sensor:
131076 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Fault Frequency: 0
   Coding: 8200026001
1560 - Databus
          U1122 00 [032] - Implausible Message
          [FAULT_VMM_INCONSISTENCY_ACC]
2068 - Databus
          [FAULT_TSK_IRREV_ERROR]
16777018 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 28
                    Mileage: 7957 km
                    Date: 2021.08.24
                    Time: 12:47:33
16777020 - Control unit for information electronics 1
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 28
                    Mileage: 7957 km
                    Date: 2021.08.24
                    Time: 12:47:33
16777022 - Control unit for information electronics 1
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 28
                    Mileage: 7957 km
                    Date: 2021.08.24
                    Time: 12:47:33
   Generator:
          U1101 00 [040] - Active
                    Reset counter: 14
                    Mileage: 7613 km
                    Date: 2021.07.10
                    Time: 15:46:29
          U1646 00 [044] - No Communication
                    Fault Frequency: 130
                    Reset counter: 39
                    Mileage: 7483 km
                    Date: 2021.06.30
                    Time: 11:13:51
369232 - Control Module Improper Shut Down
          U3001 00 [040] - -
                    Reset counter: 32
435568 - Internal Control Module
          P06B8 00 [040] - Memory Error
          [Not_ShutDown_Right_NvMWriteError]
                    Reset counter: 32
   Coding: 569945D0
   Coding: 110000
   Coding: 090000
   No subsystems:
0080 - Databus
          [Ethernet Databus missing message - Transceiverbox]
                    Reset counter: 32
                    Mileage: 7926 km
                    Date: 2021.08.23
                    Time: 10:48:08
                    Voltage terminal 30: 14.4 V
1381120 - Secure Onboard Communication
          U1513 00 [008] - Key Not Available
   Coding: 5740C0
16777040 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [NAV_0x32_communication_error_bap_error_timeout_heartbeat]
                    Mileage: 7957 km
                    Date: 2021.08.24
                    Time: 12:47:33
0081 - Databus
          U1121 00 [032] - Missing Message
          [Ethernet-Datenbus - fehlende Botschaft- POS_GNSS_05_Position]
0083 - Ethernet Databus
          U1541 00 [032] - Missing Message from Information Electronics
          [Ethernet-Datenbus - fehlende Botschaft von der Informationselektronik]
End----------(Elapsed Time: 01:32, VBatt start/end: 14.5V/14.5V)-----------
downtime
Finland
C?ID=280813
Looks familiar :D My ID4 has similar errors randomly. Everything works but when you scan the car it's like a christmas tree with all the errors :)
trompt
C?ID=258023
It is indeed a known problem with these cars:banghead:
I scanned the car with obdeleven and the 5F malfunction does not appear.
