Vehicle was brought to me because it had light hit in rear end & customer wanted lane change radars calibrating. Thinking I would have to set up fixture and dopplers i was surprised to learn the radars could be calibrated dynamically. I check basic settings in lane change module & found options for resetting adaptions, reset to factory settings, production calibration, customer service calibrations step 1 & step 2.
Can anyone elaborate on these options and the correct procedures for lane change calibrations. Also any ideas on Telematic faults?
Thank You very much
Daniel
Thank You very much
Daniel
Saturday,11,September,2021,13:49:25:64419
VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4543.4
VIN: 3VV2B7AX1LM059620 License Plate:
Mileage: 34425km-21390mi Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 22 3C 42 44 52 5F 6C 75 BB BC
VIN: 3VV2B7AX1LM059620 Mileage: 34425km-21390miles
Address 01: Engine (J623-DGUA) Labels:. 06L-907-115-V1.clb
Part No SW: 83A 907 115 B HW: 06L 907 309 B
Component: R4 2.0l TFS H31 0005
Revision: 1DH31000
Coding: 012A00122426012F34000000000000000000000000000000
Shop #: WSC 06482 444 00000
ASAM Dataset: EV_ECM20TFS01183A907115B 001006
ROD: EV_ECM20TFS01183A907115B.rod
VCID: A502922DA41A25A310-80F0
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DT HW: 09G 927 158
Component: AISIN AQ8 206 3698
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00439
ROD: EV_TCMAQ450031_VW32.rod
VCID: 885CFB9933C818CB0B-80DC
Part No SW: 5Q0 614 517 FD HW: 5Q0 614 517 BN
Component: ESC H35 0191
Revision: 00000000 Serial number: 52759000000171
Coding: 0BFA6BA450251B75C57D0302A2C349D0D60AD8A3C045927410415058D28A4A0B00402F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: F8BC8B594328684B7B-80AC
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0526964018
Coding: 132C0C0723
ROD: EV_KessyHellaMQBAB.rod
VCID: C5C232AD445AC5A330-8090
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NN 907 044 T HW: 5NN 907 044 T
Component: AC Automat H36 4803
Revision: 20K03000 Serial number: 00000D00476007
Coding: 0002000420011800100400001211140E
Shop #: WSC 00066 790 00449
ASAM Dataset: EV_ACClimaPrehVW37X 002027
VCID: DDF2FACDCCCAAD6308-8088
Part No SW: 5Q0 937 087 BG HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 038 0303
Revision: -------- Serial number: C86419101900OA
Shop #: WSC 00066 790 00277
ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
ROD: EV_BCMBOSCH_020_VW37.rod
VCID: 814AE6BD10F229834C-80D4
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 190913 034 0373
Serial number: 19091121036660
Humidity sensor: interior:
Subsystem 2 - Part No SW: 5Q0 907 658 HW: 5Q0 907 658
Component: HS 003 0002
Serial number: S7Y19M08D26H06M31S57
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 M HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300231020190C201598
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3200009110FF8728749C810500409700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: C3C62CB54A6EFB931E-8096
Part No SW: 5Q0 959 655 BM HW: 5Q0 959 655 BM
Component: AirbagVW21 008 0403
Serial number: 003FGM062Z5I
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 8C54C78927B074EB2F-80D8
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000CGAUJ4
Coding: 303451
Subsystem 2 - Part No SW: ----------- HW: 480 002 108 19
Serial number: 3570000000006790AE3L
Subsystem 3 - Part No SW: ----------- HW: 480 000 309 19
Serial number: 35800000000F68F8DF3D
Subsystem 4 - Part No SW: ----------- HW: 480 402 808 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001A6F00134310EO
Subsystem 5 - Part No SW: ----------- HW: 480 402 808 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001C8F11B8585278
Subsystem 6 - Part No SW: ----------- HW: 480 402 209 19
Component: FrontSensor_D 004 6149
Serial number: 35500011E2CA02A5C321
Subsystem 7 - Part No SW: ----------- HW: 480 402 209 19
Component: FrontSensor_P 004 6149
Serial number: 3560001202CA02A2D48.
Part No SW: 5NA 920 850 D HW: 5NA 920 850 D
Component: KOMBI 343 6700
Coding: 0BA40C0AA388CF0502882B0914000000A0000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
VCID: C0CC23B95B78E08B03-8094
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 23101900840494
Coding: 030500347F085900FB0322481E0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: F0ACB3792B58300BB3-80A4
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5NA 959 442 A HW: 5NA 959 442 A
Component: E221__MFL-TAT H06 0025
Serial number: 2341918204601696FE2B
Coding: 280000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 9429356900
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00019.07.19
Coding: 0101
VCID: CCD40789673034EBEF-8098
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0148
Serial number: 11230018182710
Coding: 5294C640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: B93A4E5D38A2B14344-80EC
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0148
Serial number: 11230018360789
Part No SW: 5Q4 959 393 K HW: 5Q4 959 393 K
Component: TSG FS 007 0485
Serial number: 14058929200157
Coding: 003013200000048000000000
Shop #: WSC 01383 790 50316
VCID: CBD60495623E33D3E6-809E
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000004417059
Coding: 011000
Part No SW: 5QM 909 144 C HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1082
Coding: 811F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: D1EA16FD801219039C-8084
Part No SW: 5Q4 959 392 K HW: 5Q4 959 392 K
Component: TSG BFS 007 0485
Serial number: 15058929301388
VCID: CAD801916D442ADBDD-809E
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000004456020
Coding: 091000
Part No SW: 2GM 035 844 A HW: 2GM 035 844 A
Component: MU-S-S-US 725 0520
Coding: 02730600BE00000051220001001808211F0500C40120050002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: BFCE204526869F737A-80EA
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 254 8130
Serial number: VWZ6ZMW3015890
B11CF 53 [009] - Deactivated
Reset counter: 136
Mileage: 34425 km
Date: 2021.09.11
Time: 13:43:37
Voltage terminal 30: 12.6 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Audio Signal: available.
SDARS_tuner_status_2-Antenna current: 100 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Component: RVC Compact H18 0231
Coding: 0123060120002017300040
Part No SW: 5WA 035 283 HW: 5WA 035 283
Component: OCUGen3Low H10 0295
Serial number: 0000000908NVQS3
Coding: 02326020196828008005461160100607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VW37.rod
VCID: 8248E9B115F4329B55-80D6
7170 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Mileage: 34425 km
Date: 2021.09.11
Time: 13:43:07
Voltage terminal 30: 12.5 V
13631561 - Internal Control Module Memory Check Sum Error
B2000 49 [009] - Internal electronic failure
Mileage: 5869 km
Date: 2020.07.05
Time: 19:06:54
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 01:16, VBatt start/end: 14.6V/12.9V)-----------
