Adaptive Cruise control / radar sensor Mk7 Golf
invernesspl
C?ID=345478
Hi,
I've got a 2015 Golf GTD estate. I've had to replace a damaged radar sensor, but I cannot get the cruise control to activate. I believe it requires the angle setting, is this main dealer only? Or, does the radar unit require coding to the car perhaps?
Thanks,
Scan below.
Saturday,11,September,2021,10:19:13:41168
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WVWZZZAUZGP509690   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGP509690   Mileage: 68756km-42722miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BN    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H21 7607
   Revision: B5H21---    CVN: 2305CFBF
   Coding: 01190012034505082000
   Shop #: WSC 00117 210 00000
   ASAM Dataset: EV_ECM20TDI01104L906026BN 004004
   ROD: EV_ECM20TDI01104L906026BN_004.rod
   VCID: 77ABE8B40F4749B396B-8022
   VINID: 9E69EAAAA465A9780500918900E7C096F0
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:57
                    Engine RPM: 769.00 /min
                    Normed load value: 24.7 %
                    Coolant temperature: 72 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 13.120 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 61485000002510
   Coding: 04FA8AA124200975077D060941C32920512490E0608294F314605078C002
   VCID: 7EA5FD90207D78FBD5D-802A
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 02120104202100001000000000000002
   Shop #: WSC 00028 028 00068
   VCID: 3C21379876E1AAEBBB9-8068
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Revision: --------    Serial number: 86580806151611
   Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 005983685A890E0BA71-8054
   Component: WWS    150523  042 0551
   Serial number:         150530180912
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y15M06D05H16M26S14
   Coding: 90A8DD
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY151050CUY
   Serial number: 00000000000032626291
   Revision: --------    Serial number: 39391514003580
   Coding: 0071051001
   VCID: 43D34C640B1FD513FA3-8016
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 29031503210322
   Coding: 00000600FE030B
   VCID: 38292B8842D986CB5F1-806C
10 Faults Found:
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
          [FAULT_ATP_IKA_CONFIG]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 13.1 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
15361024 - Component Protection
          U1101 00 [009] - Active
          [FAULT_ATP_IKA_RESTRICTED]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
2101760 - invalid data record
          B2005 00 [009] - -
          [FAULT_BPC_NVM_Download]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
1807 - No Enable Identifications Active
          B2032 00 [009] - -
          [FAULT_SWAP_NO_FSID_ACTIVE]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
1804 - Internal Fault
          B200F F0 [009] - Unknown Error Elaboration
          [FAULT_TX_TIMEOUT_RDR1_HEADER]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
                    Voltage terminal 15: 13.0 V
1803 - Internal Fault
          [FAULT_TX_TIMEOUT_RDR1_OBJ_01]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
1802 - Internal Fault
          [FAULT_TX_TIMEOUT_RDR1_OBJ_02]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
1801 - Internal Fault
          [FAULT_TX_TIMEOUT_RDR1_OBJ_03]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
1800 - Internal Fault
          [FAULT_TX_TIMEOUT_RDR1_OBJ_04]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
1792 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_WORKSHOP_ALIGNMENT_NOT_DONE]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:55
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0F89V7
   Shop #: WSC 00028 028 00064
   VCID: 7F5B0094277771F3DEB-802A
   Left seat belt tensioner:
   Serial number: 34169677B03061571391
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676B04061540785
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 306 15
   Serial number: 357670000004589DB41/
   Subsystem 4 - Part No SW: -----------    HW: 480 000 306 15
   Serial number: 35867000000BE010C41T
   Subsystem 5 - Part No SW: -----------    HW: 480 400 106 15
   Serial number: 3516502C51A91E02B0DE
   Subsystem 6 - Part No SW: -----------    HW: 480 400 106 15
   Serial number: 3526502B31A14CC36055
   Subsystem 7 - Part No SW: -----------    HW: 480 400 106 15
   Serial number: 3556502991B41483D407
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150609500952
   Coding: 0C00
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41DF466C1103C703E8F-8014
   Part No SW: 5G1 920 941 A    HW: 5G1 920 941 A
   Component: KOMBI         202 6420
   Coding: 27A411002780260001886A011400000000000000
   VCID: 270BF8F49F671933C6B-8072
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 05061510801899
   Coding: 030100041F087300FB00005C080F00010001050000000000000000000000
   GVL: 01543C0000000000400C80000000480000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E2BC154B3BA3847-8020
   Generator:
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001180690085233
   Coding: 2CFFFF
   Serial number: 8270096803
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:56
                    Terminal 30 power supply: 13.1 V
                    Terminal 15: On
   Component: TSG FS        010 0031
   Serial number: 0000151964497
   Coding: 003B0220D001028000001000
   VCID: 47CB58743F27F93326B-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000009234294
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   Component: TSG BFS       010 0031
   Serial number: 0000153007126
   Coding: 003B0020DE01028000801000
   VCID: 46D55570382DE03BDDD-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000009168379
   Coding: 050000
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    H24 0253
   Serial number: VWZAZ2R0195794
   Coding: 02730201FF00000051111101008808001F0100C601200100CF
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 303913A8AAA95E8B171-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R1610341
   Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
   Component: ECE 2015/16  --- 0430
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 222
                    Mileage: 68756 km
                    Date: 2021.09.11
                    Time: 10:17:58
                    Voltage terminal 30: 13.2 V
                    BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:25, VBatt start/end: 13.2V/13.2V)-----------
dnoermann
C?ID=358118
The Radar is Cryptographically Proteced with CP: ComponentProtection and SWAP/Fec.
Only a VW Dealer (and people who can do online CP and Swap) can online enable this after a change of Sensor.
