2018 Polo AW headlight upgrade from halogen to LED
Jacce
Finland
C?ID=304131
I have problems with LED upgrade. Parts used is OE products; headlights, D6, D7, 55 and level sensor on rear axle. I donn't get the headlights to work except for low beam as they are now in emergency mode. No high beam, drl or blinkers. I belive the key is 09 coding and parameters. Could anyone share their codings and parameters for 09 BCM? Of course the fault may be somewehere else. This is above my knowledge. Here is the autoscan.
Monday,23,August,2021,11:03:12:19122
Dealer/Shop Name: AutoHaus Boost Oy
VIN: WVWZZZAWZJY008727   License Plate: POLO AW
Mileage: 58083km-36091mi   Repair Order:
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 2B 44 55 5F D6 D7
VIN: WVWZZZAWZJY008727   Mileage: 58083km-36091miles
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CHZL)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BD    HW: 04C 907 309 AT
   Component: R3 1.0l TFS   H21 5150
   Revision: WXH21---
   Coding: 01110032234415081000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10TFS01104C906026BD 002003
   ROD: EV_ECM10TFS01104C906026BF.rod
   VCID: 6492A5FDCEDF140B0BB-8030
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AA    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H22 0222
   Serial number: 08505417170806
   Coding: 09034B64154190B5D203A81824E142A649124D26224A245844541254452442659248B2644452241A222A482AA249D64A7D926B52BE
   Shop #: WSC 41391 003 1048576
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0_004.rod
   VCID: 6D84C0D91D155543545-8038
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0451497238
   Coding: 132C0C0623
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E26379500F31EDBBDF-806A
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 2G0 907 044 L    HW: 2G0 907 044 L
   Component: Climatronic   H03 0501
   Coding: 0120000008000100011004000244010D0000000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: EV_ACClimaBHBMQBA0.rod
   VCID: 2D0400D9DD959543145-8078
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H97 0915
   Serial number: 07001722900057
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 77A8E2B16F49EF93BE9-8022
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S4Y17M08D25H18M54S56
   Coding: 0038DD
   Driver door control module:
   Subsystem 2 - Part No SW: 2Q1 959 881     HW: 2Q1 959 881
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000015973688
   Coding: 130000
   Front passenger door control module:
   Subsystem 3 - Part No SW: 2Q1 959 882     HW: 2Q1 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000016043014
   Coding: 090000
   Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000016040269
   Coding: 030000
   Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000015973129
   Coding: 1B0000
919560 - Light Switch
          B126A 29 [008] - Signal Implausible
                    Reset counter: 130
                    Mileage: 57970 km
                    Date: 2021.08.16
                    Time: 20:43:29
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: 0
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
                    Zusaetzliche Umgebungsdaten-last wakeup: 33
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.6 V
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617203
   Coding: 0471051001
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4BC06E414341BB732A1-801E
1112340 - Front Right Center Parking Aid Sensor
          B10F9 14 [009] - Open or Short to Ground
                    Reset counter: 90
                    Mileage: 57970 km
                    Date: 2021.08.15
                    Time: 16:48:40
   Component: ACCCONTIMQB   H02 0233
   Coding: 2A00600200FF8748949C8145604087
   Part No SW: 2Q0 959 655 AH    HW: 2Q0 959 655 B
   Component: VW22Airbag    010 0349
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF000800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 035086612B91B333921-8056
   Left seat belt tensioner:
   Serial number: 2G4857705B0228R00173
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 2G4857706B0229R00811
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 442 062 407 17
   Serial number: 3577Y20B124C3A54D183
   Subsystem 4 - Part No SW: -----------    HW: 442 060 308 17
   Serial number: 3587Y20A3249F6C29046
   Subsystem 5 - Part No SW: -----------    HW: 442 0B0 408 17
   Serial number: 3517711BD2767322F1DL
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 408 17
   Serial number: 3527711BD2767320E18E
   Subsystem 7 - Part No SW: -----------    HW: 442 131 508 17
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11B3269FFA233E5
   Part No SW: 2G0 920 740 A    HW: 2G0 920 740 A
   Component: KOMBI         309 0460
   Coding: 04A401102D8000080C8822011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 201AE9ED9A47482BAF3-8074
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H97 0915
   Coding: 030100046F085600F800025C080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_VW27.rod
   VCID: 6FB8DAD11719A753669-803A
   Generator:
   Subsystem 2 - Part No SW: 2G0 959 442 F    HW: 2G0 959 442 F
   Component: E221__MFL-DC1  H02 0040
   Serial number: 39170002093120047344
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 1000E17E
131699 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 130
                    Mileage: 57970 km
                    Date: 2021.08.17
                    Time: 18:39:39
                    Terminal 30 power supply: 12.5 V
                    Terminal 15: OFF
   Part No SW: 2Q0 905 861     HW: 2Q0 905 861
   Component: ELV-MQBB      H06 0020
   Serial number: 17000128508006
   Coding: 5500000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002001
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 70BAD9AD0A27B8AB7F3-8024
Address 44: Steering Assist (J792)       Labels:* 2Qx-909-144-V1.clb
   Part No SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 610 6041
   Serial number: 0090417CB3H2411
   Coding: 010000000000000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3C223D9D16EF0CCB93B-8068
10551552 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [DEM_CODING_PLA_FAULT]
                    Reset counter: 90
                    Mileage: 57970 km
                    Date: 2021.08.08
                    Time: 16:20:39
                    Engine RPM: 0 /min
                    Terminal 15 status: On
                    Voltage terminal 30: 12.29 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 24 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 0 ?
                    Electric motor speed: 0 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: -0.1 Nm
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 178A000009200003
   Shop #: WSC 00046 000 00000
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DC4C69710D6123C0D-8014
66881 - Databus
                    Reset counter: 90
                    Mileage: 57970 km
                    Date: 2021.08.15
                    Time: 17:55:30
66882 - Databus
                    Reset counter: 90
                    Mileage: 57970 km
                    Date: 2021.08.15
                    Time: 17:55:31
13706005 - Databus
          [Empfangener Fehlerwert im Signal BCM1_LDS_Stellung: CAN Message Gateway_72]
                    Reset counter: 130
                    Mileage: 57970 km
                    Date: 2021.08.20
                    Time: 18:50:13
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      H41 0449
   Serial number: VWZAZ2T1572160
   Coding: 02720000BE0000004111000100080A001F0500C40120010003
   ROD: EV_MUStd4CTSAT_VW27.rod
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT2430499
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EA6F7954073DEDBFDF-802A
0019 - Headlamp Type
          C119F 00 [175] - Implausible
                    Fault Frequency: 91
                    Reset counter: 0
                    Mileage: 57970 km
                    Date: 2021.08.15
                    Time: 16:49:46
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
                    Fault Frequency: 213
                    Reset counter: 0
                    Mileage: 57970 km
                    Date: 2021.08.08
                    Time: 20:42:09
1090 - LED Turn Signal Lights
          C11BF F0 [174] - Current Coding Electrical Malfunction
                    Fault Frequency: 212
                    Reset counter: 0
End----------(Elapsed Time: 01:04, VBatt start/end: 12.5V/12.5V)-----------
@Jacce: hi.
I don't have a definitive answer but maybe try clearing the DTCs in your auto-scan and start with a fresh scan (your scan above contains lots of "aged DTCs" that have Fault Frequency=1. I suspect that some of the faults may have happened during the physical install exercise - so IMO they don't add value to your objective moving forward)
Also, ALL of the code-able variables in the BCM on your car appear to be contained within the adaptation channel database. This being so, maybe post-up a channel map so we can see how the BCM is currently configured. Again as a suggestion - perhaps set-up the admap dialogue box like this before you press the "Go" button
golfman
C?ID=103115
Get in touch with Downtime about this...
Im 100% sure he can sort this for you:thumbs:
Jacce
Finland
C?ID=304131
Thank you for the answers. Here is the admap of 09. I'm totally lost with this. I think it's something really simple but can't figure it out.
;SW:2Q0-937-089   HW:2Q0-937-089 ---  Cent. Elect.
;Component:BCM A0 Std    H97 0915, Coding:
;EV_BCMA0,204001,EV_BCMA0_204.rod
;Friday,10,September,2021,15:39:08:19122
;VCDS Version: Release 21.9.0 (x64)  Data version: 20210903 DS330.0
;VCID: 77A8E2B16F49EF9396B-8022
IDE00001-ENG130235-Production mode-Entry_control,not_active ,3
IDE00001-ENG115730-Production mode-Exterior lighting,not_active ,3
IDE00001-ENG112304-Production mode-Heckwischer,not_active ,3
IDE00001-ENG98647-Production mode-Interior lights,not_active ,3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not_active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not_active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not_active ,3
IDE00002-Transport mode,active ,4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,5
IDE02269-ENG149191-Acknowledgement signals-Akustische_Rueckmeldung_entriegeln,not active ,5
IDE02269-ENG149190-Acknowledgement signals-Akustische_Rueckmeldung_global,not active ,5
IDE02269-ENG149195-Acknowledgement signals-Akustische_Rueckmeldung_Signalhorn,not active ,5
IDE02269-ENG149192-Acknowledgement signals-Akustische_Rueckmeldung_verriegeln,not active ,5
IDE02269-ENG149194-Acknowledgement signals-Dauer_der_Akustischen_Rueckmeldung_vom_Einfachhorn,normal ,5
IDE02269-ENG149193-Acknowledgement signals-Menuesteuerung_akustische_Rueckmeldung,not active ,5
IDE02269-ENG149189-Acknowledgement signals-Optische_Rueckmeldung_3.Bremsleuchte,not active ,5
IDE02269-ENG149188-Acknowledgement signals-Optische_Rueckmeldung_Komfortschliessen,active ,5
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,5
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,5
IDE02711-ENG149246-Rear wiper-Automatisches_Heckwischen,not active ,8
IDE02711-ENG112304-Rear wiper-Heckwischer,Keine_Spannungsanforderung ,8
IDE02711-ENG149248-Rear wiper-Heckwischer_Weiterlauf,not active ,8
IDE02711-ENG115850-Rear wiper-Komfortwischen_Heck,active ,8
IDE02711-ENG149251-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_1,5 s,8
IDE02711-ENG149252-Rear wiper-Komfortwischen_Heck_Intervallpausenzeit_Stufe_2,3 s,8
IDE02711-ENG149250-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Automatik,7 s,8
IDE02711-ENG149249-Rear wiper-Komofortwischen_Heck_Intervallpausenzeit_Stufe_Intervall,7 s,8
IDE02711-ENG149245-Rear wiper-Menuesteuerung_Komfortwischen_HW,active ,8
IDE02711-ENG148996-Rear wiper-rear_window_wiper,nur Komfortwischen ,8
IDE02711-ENG149247-Rear wiper-Traenenwischen_Heck,active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE02957-ENG154500-Ambient lighting-Ambience_borders_front,not installed ,8
IDE02957-ENG133384-Ambient lighting-Ambient_Farbliste_HMI,not active ,8
IDE02957-ENG154513-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,8
IDE02957-ENG154514-Ambient lighting-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,8
IDE02957-ENG149168-Ambient lighting-Ambientelicht_mit_raste_heckdeckel,not enabled ,8
IDE02957-ENG126836-Ambient lighting-Ambientemenue mit alle Zonen,not active ,8
IDE02957-ENG126835-Ambient lighting-Ambientemenue mit globalem aus,not active ,8
IDE02957-ENG154907-Ambient lighting-Applikationsleisten_Tuer,not installed ,8
IDE02957-ENG154995-Ambient lighting-Cupholderbeleuchtung,not installed ,8
IDE02957-ENG125648-Ambient lighting-Dachbeleuchtung,not installed ,8
IDE02957-ENG125029-Ambient lighting-Defaultwert Ambienteprofil Farbe,Cold white ,8
IDE02957-ENG149163-Ambient lighting-Defaultwert_Ambienteprofil_Fussraum,0 %,8
IDE02957-ENG149164-Ambient lighting-Defaultwert_Ambienteprofil_Tuer,50 %,8
IDE02957-ENG149165-Ambient lighting-Defaultwert_Ambienteprofil_Vorn,50 %,8
IDE02957-ENG125651-Ambient lighting-Farbwahl ueber Fahrprofil,not installed ,8
IDE02957-ENG125650-Ambient lighting-Farbwahl ueber HMI,not installed ,8
IDE02957-ENG114629-Ambient lighting-Footwell lighting,not installed ,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG155264-Ambient lighting-Lautsprecherbeleuchtung,not installed ,8
IDE02957-ENG125647-Ambient lighting-Mittelkonsolenbeleuchtung,not installed ,8
IDE02957-ENG125649-Ambient lighting-Panoramaschiebedachbeleuchtung,not installed ,8
IDE02957-ENG149167-Ambient lighting-Tuerinnengriff_mit_Tuertafel,not installed ,8
IDE02957-ENG149166-Ambient lighting-Tuerinnengriffbeleuchtung_mit_I-Tafel,not installed ,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,0.0 °,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,20.0 %/s,16
IDE03638-ENG149111-Stationary cornering lamp-bei_Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,120.0 °C,16
IDE03638-ENG149114-Stationary cornering lamp-Obere_Geschwindigkeitsschwelle,40.0 km/h,16
IDE03638-ENG149117-Stationary cornering lamp-obere_Grenztemperatur,100.0 °C,16
IDE03638-ENG149116-Stationary cornering lamp-Oberer_Lenkradwinkel,120 °,16
IDE03638-ENG149113-Stationary cornering lamp-Untere_Geschwindigkeitsschwelle,0.0 km/h,16
IDE03638-ENG149118-Stationary cornering lamp-untere_Grenztemperatur,80.0 °C,16
IDE03638-ENG149115-Stationary cornering lamp-Unterer_Lenkradwinkel,80 °,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE_R119 ,16
IDE03638-ENG149112-Stationary cornering lamp-Zeitwert_Einschaltzeit_Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,9
IDE04927-MAS01535-Window heater-Rear window defogger,installed ,9
IDE04927-MAS01564-Window heater-Front windshield heater,not installed ,9
IDE04927-ENG142182-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung,35.0 °C,9
IDE04927-ENG142181-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung,35.0 °C,9
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,600 s,9
IDE04927-ENG142180-Window heater-Heckscheibenheizung_Zeitwert,320 s,9
IDE04927-ENG142179-Window heater-Temperaturabhaengige_Einschaltzeit_FSH,active ,9
IDE04927-ENG142178-Window heater-Temperaturabhaengige_Einschaltzeit_HSH,active ,9
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 00 00 46 08 7F 09 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0B 00 00 00 0B 1E 7F 00 00 00 00 00 00 00 00 00 0B 00 00 00 0C 1E 7F 00 00 00 00 00 00 00 00 00 17 00 00 00 46 3A 7F 08 09 7F 00 00 00 00 00 00 17 00 00 00 46 3A 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,208
IDE05548-ENG149125-Additional interior light-Signal_mapping_ambient_lighting_doors_lin,0 ,38
IDE05548-ENG149126-Additional interior light-Signal_mapping_door_handle_lighting_lin,0 ,38
IDE05548-ENG149127-Additional interior light-Signal_mapping_puddle_light_lin,puddle light ,38
IDE06089-ENG149261-Seat heater level current consumption allocation-Art_der_Sitzheizungsregelung,Time-controlled ,36
IDE06089-ENG155386-Seat heater level current consumption allocation-Not_networked_seat_heater_rearseats,not connected ,36
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,seat_heater_on_LIN ,36
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,36
IDE06089-ENG149262-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 1,0 %,36
IDE06089-ENG149263-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 2,20 %,36
IDE06089-ENG149264-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 3,0 %,36
IDE06089-ENG149265-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 4,100 %,36
IDE06089-ENG149266-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 5,0 %,36
IDE06089-ENG149267-Seat heater level current consumption allocation-Sitzheizung PWM Stufe 6,100 %,36
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.05 ,36
IDE06089-ENG149271-Seat heater level current consumption allocation-Sitzheizung Stufe 0 Ansteuerzeit,2 min,36
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,24.00 °C,36
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,36
IDE06089-ENG149269-Seat heater level current consumption allocation-Sitzheizung Stufe 4 Ansteuerzeit,15 min,36
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,32.00 °C,36
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,30.00 °C,36
IDE06089-ENG149268-Seat heater level current consumption allocation-Sitzheizung Stufe 6 Ansteuerzeit,15 min,36
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,40.00 °C,36
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,38.00 °C,36
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,36
IDE06089-ENG155904-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase LO,Keine_Spannungsanforderung ,36
IDE06096-ENG149157-Interior lights-Innenlicht_bei_offenem_Heckdeckel_einschalten,active ,8
IDE06096-ENG98648-Interior lights-Interior lighting,Sollspannungsanforderung_13.5 ,8
IDE08786-MAS10528-Assistance light functions-Rain light sensor,Rain light sensor ,9
IDE08786-MAS10545-Assistance light functions-Humidity sensor,installed ,9
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,not active ,9
IDE08786-ENG149124-Assistance light functions-AFL_Zeitverzoegerung,0 ms,9
IDE08786-ENG149123-Assistance light functions-Assistenzfahrlicht_bei_Regen,not active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,0 °,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,0 °,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,0_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,1 °,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,0 °,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,0_Ohm ,7
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,Energiemanagement oder Zeit ,6
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,30 min,6
IDE11421-ENG179280-Leaving concept-VLK_Deaktivierung_der_Diagnose,not active ,6
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,3
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000100  ,3
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000110  ,3
IDE11944-MAS10510-Keyless access and start authorization-Kessy,installed ,5
IDE11944-ENG174170-Keyless access and start authorization-central_locking_system_selective_sigle_door_kessy_NAR,not active ,5
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,not active ,5
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,5
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,5
IDE11944-ENG149273-Keyless access and start authorization-Kessy_Komfort_oeffnen,not active ,5
IDE11944-ENG149274-Keyless access and start authorization-Kessy_Komfort_schliessen,active ,5
IDE11944-ENG149275-Keyless access and start authorization-Oeffnung_Heckdeckel_bei_Wiederentriegelung,active ,5
IDE11944-ENG149000-Keyless access and start authorization-Steering_wheel_locking_system,installed ,5
MAS01490-IDE08581-Energy management-Recuperation,not active ,5
MAS01490-MAS12921-Energy management-Predictive energy management,not active ,5
MAS01490-ENG149047-Energy management-Eingriff_durch_Energiemanagement,active ,5
MAS01490-ENG98636-Energy management-Hybrid,No ,5
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 32 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain,active ,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,NOT-DEFINED ,24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4300 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
ENG153709-ENG155626-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG_DTC,First_dtc ,9
ENG148492-MAS01577-Anti-theft protection-Parking heater,not installed ,5
ENG148492-ENG149232-Anti-theft protection-Akustischer_Alarm_Signalhorn,not active ,5
ENG148492-ENG115864-Anti-theft protection-Alarmsignal,frequency_modulated ,5
ENG148492-ENG148991-Anti-theft protection-anti_theft_alarm_system,not active ,5
ENG148492-ENG148992-Anti-theft protection-anti_theft_alarm_with_simple_horn,not installed ,5
ENG148492-ENG148993-Anti-theft protection-anti_theft_alarm_without_Thatcham,No ,5
ENG148492-ENG148990-Anti-theft protection-deactivation_button_anti_theft_alarm_sensor,not installed ,5
ENG148492-ENG154590-Anti-theft protection-Deaktivierung_DWA_ueber_MMI,not active ,5
ENG148492-ENG123016-Anti-theft protection-Diebstahlschutz_mit_Anhaenger,not active ,5
ENG148492-ENG149229-Anti-theft protection-DWA_Alarmverzoegerung,immidiat_driver_door_contact_thatcham ,5
ENG148492-ENG149230-Anti-theft protection-DWA_Camper_Modus,not active ,5
ENG148492-ENG148994-Anti-theft protection-interior_monitoring_sensor,No ,5
ENG148492-ENG149231-Anti-theft protection-Sirenen_Alarmzahl,10_Alarme ,5
ENG148492-ENG142008-Anti-theft protection-tilt_sensor,No ,5
ENG148492-ENG149228-Anti-theft protection-Verzoegerung_Panikalarm,keine_verzoegerung ,5
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken,active ,5
ENG141649-ENG130187-Außenlicht_Blinker-Blinkkontrolleuchte_fuer_Anhaenger,separte ,5
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken,active ,5
ENG141649-ENG115854-Außenlicht_Blinker-Komfortblinken_Blinkzyklen,3 ,5
ENG141647-MAS10529-Außenlicht_Front-Low beam: bulb type,H7 ,9
ENG141647-ENG149099-Außenlicht_Front-Allwetterlicht_Ausschaltgrenze,350 km/h,9
ENG141647-ENG149098-Außenlicht_Front-Allwetterlicht_Einschaltgrenze,350 km/h,9
ENG141647-ENG149106-Außenlicht_Front-Fahrlicht_bei_Tag,Daytime running lamps ,9
ENG141647-ENG149097-Außenlicht_Front-Lichthupe_bei_Zuendung_aus_moeglich,active ,9
ENG141647-ENG126567-Außenlicht_Front-max_scheinwerfer_2limitieren,in_Betrieb_lassen ,9
ENG141647-ENG149100-Außenlicht_Front-Scheinwerferferreinigungsansteuerung_und_Abblendlichtanzeige_bei_Dauerfahrlicht,not active ,9
ENG141647-ENG149103-Außenlicht_Front-Standlicht_aktiviert_zusaetzlich_Tagfahrlicht,active ,9
ENG141647-ENG149101-Außenlicht_Front-Tagfahrlicht_Aktivierung_durch_BAP_oder_Bedienfolge_moeglich,active ,9
ENG141647-ENG149104-Außenlicht_Front-Tagfahrlicht_Dauerfahrlicht_bei_Handbremse_abschalten,not active ,9
ENG141647-ENG149107-Außenlicht_Front-Tagfahrlicht_nur_in_Schalterstellung_AUTO,not active ,9
ENG141647-ENG149105-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht_aktiviert_zusaetzlich_Standlicht,not active ,9
ENG141647-ENG149102-Außenlicht_Front-Werkseinstellung_fuer_Tagfahrlicht_Freischaltung_BAP_/_Bedienfolge,active ,9
ENG141648-MAS10533-Aussenlicht_Heck-Brake light is turn signal,No ,5
ENG141648-ENG179109-Aussenlicht_Heck-Bremslicht_mit_Schlusslichtfunktion,not active ,5
ENG141648-ENG149110-Aussenlicht_Heck-Nebelschlusslicht_Warngeschwindigkeit,255 km/h,5
ENG141648-ENG115847-Aussenlicht_Heck-Notbremsanzeige_NBA,active ,5
ENG141648-ENG155652-Aussenlicht_Heck-Schlusslicht_mit_Brems_und_Blinklichtfunktion,not active ,5
ENG141648-ENG149109-Aussenlicht_Heck-Schlusslicht_mit_Bremslichtfunktion,not active ,5
ENG141656-MAS10538-Außenlicht_uebergreifend-Light rotary sw. connection,Discrete signal current ,16
ENG141656-MAS10541-Außenlicht_uebergreifend-Light rotary switch with fog light,Yes ,16
ENG141656-MAS10542-Außenlicht_uebergreifend-Light rotary switch with fog tail light,Yes ,16
ENG141656-MAS10543-Außenlicht_uebergreifend-Light rotary sw. with AFL,Yes ,16
ENG141656-MAS10544-Außenlicht_uebergreifend-Light rotary switch with park. light pos.,Yes ,16
ENG141656-ENG248495-Außenlicht_uebergreifend-ABL_off_ECE48_Rev6,No ,16
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,Energy management ,16
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,Energy management ,16
ENG141656-ENG126566-Außenlicht_uebergreifend-beidseitiges_dauerparklicht,active ,16
ENG141656-ENG149092-Außenlicht_uebergreifend-Coming_home_Leuchten,Low beam ,16
ENG141656-ENG149089-Außenlicht_uebergreifend-Coming_Home_Verbaustatus,manual ,16
ENG141656-ENG149093-Außenlicht_uebergreifend-Coming-home_Einschaltereignis,ignition ,16
ENG141656-ENG248654-Außenlicht_uebergreifend-ECE48_Rev6_aktiv,not active ,16
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,not_active ,16
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,16
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,16
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,16
ENG141656-ENG149096-Außenlicht_uebergreifend-Helligkeitsschwelle_Forward-Messung,116 ,16
ENG141656-ENG149094-Außenlicht_uebergreifend-Helligkeitsschwelle_Infrarot-Messung,72 ,16
ENG141656-ENG155156-Außenlicht_uebergreifend-keine_LCM_blinker,false ,16
ENG141656-ENG149086-Außenlicht_uebergreifend-Kontrollleuchte_fuer_Begrenzungslicht,integriert_in_Suchbeleuchtung ,16
ENG141656-ENG149095-Außenlicht_uebergreifend-Leaving-Home_Verbausstatus,Enabled ,16
ENG141656-ENG126569-Außenlicht_uebergreifend-lho_aktiviert,active ,16
ENG141656-ENG126570-Außenlicht_uebergreifend-lho_zeit,30 seconds ,16
ENG141656-ENG149005-Außenlicht_uebergreifend-Lichtdrehschalter_mit_Nebellicht_bei_Assistenzfahrlicht,Yes ,16
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,16
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,16
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,16
ENG141656-ENG149088-Außenlicht_uebergreifend-Menueeinstellung_CHO_LHO,Menuesteuerung_Zeit_aktivieren ,16
ENG141656-ENG149091-Außenlicht_uebergreifend-Menueeinstellung_Cominghome,30 seconds ,16
ENG141656-ENG149090-Außenlicht_uebergreifend-Menuesteuerung_Coming_Home_Werkseinstellung,active ,16
ENG141656-ENG149087-Außenlicht_uebergreifend-Parklicht_ueber_LSS_aktiviert,One-sided ,16
ENG141656-ENG126565-Außenlicht_uebergreifend-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,16
ENG141656-ENG137035-Außenlicht_uebergreifend-Standlicht-Verfuegbarkeit,24 s,16
ENG141656-ENG248823-Außenlicht_uebergreifend-TFL_off_ECE48_Rev6,No ,16
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Sollspannungsanforderung 13.5 ,16
ENG148494-MAS10534-Background lighting-Input medium: search illumination,HMI ,21
ENG148494-ENG142240-Background lighting-Daempfung Abdimmen KL 58xd PWM,0.04 s,21
ENG148494-ENG154582-Background lighting-Daempfung_Abdimmen_KL_58xs_PWM,0.04 s,21
ENG148494-ENG154583-Background lighting-Daempfung_Abdimmen_KL_58xt_PWM,0.04 s,21
ENG148494-ENG154584-Background lighting-Daempfung_Aufdimmen_KL_58xd_PWM,0.04 s,21
ENG148494-ENG154585-Background lighting-Daempfung_Aufdimmen_KL_58xt_PWM,0.04 s,21
ENG148494-ENG179120-Background lighting-Daempfung_Aufdimmen_KL58xs_PWM,0.04 s,21
ENG148494-ENG142242-Background lighting-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG148494-ENG142241-Background lighting-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
ENG148494-ENG149159-Background lighting-KL58_Einschalten_mit_Rampe,not active ,21
ENG148494-ENG149160-Background lighting-KL58_Verriegelungsausschalten,not_active ,21
ENG148494-ENG149161-Background lighting-Lichtsensor_wirkt_auf_Suchbeleuchtung,active ,21
ENG148494-ENG149162-Background lighting-Suchbeleuchtung_Festwert,100 %,21
ENG148494-ENG142234-Background lighting-Umgebungs_helligkeit_auswahl,Fotosensor_Kombi ,21
ENG148494-ENG130188-Background lighting-Warnblinktastersuchbeleuchtung_Aktivierung,always_active ,21
ENG148494-ENG130190-Background lighting-Warnblinktastersuchbeleuchtung_Faktor,0.100 ,21
ENG148494-ENG130189-Background lighting-Warnblinktastersuchbeleuchtung_Grundwert,6.0 %,21
ENG148609-ENG148997-Fahrerinformation-Cockpit_button_1,installed ,5
ENG148609-ENG148998-Fahrerinformation-Cockpit_button_2,not installed ,5
ENG148609-ENG148999-Fahrerinformation-Cockpit_button_3,not installed ,5
ENG148609-ENG149003-Fahrerinformation-Cockpit_button_4,not installed ,5
ENG141650-MAS10514-Fernlicht_assistent-Expanded high beam control,AFS: Fernlicht ueber AFS ,6
ENG141650-ENG149120-Fernlicht_assistent-Fernlichtassistent_Reset,not active ,6
ENG141650-ENG149122-Fernlicht_assistent-Fernlichtassistent_Zeitverzoegerungswert,800 ms,6
ENG141650-ENG149119-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent,present ,6
ENG141650-ENG149121-Fernlicht_assistent-Menuesteuerung_Fernlichtassistent_Werkseinstellung,present ,6
ENG141645-IDE05739-HW_Verbau-Footwell lamp,not installed ,8
ENG141645-MAS06495-HW_Verbau-Engine hood contact switch,installed ,8
ENG141645-MAS10521-HW_Verbau-Exterior temp. sensor,installed ,8
ENG141645-ENG126574-HW_Verbau-auspraegung_Bremsfluessigkeitsschalter,Open ,8
ENG141645-ENG115848-HW_Verbau-Signalhorn_ohne_KL15,active ,8
ENG141645-ENG149002-HW_Verbau-Signalhorn_ueber_LIN,horn_via_LIN ,8
ENG148603-ENG115658-Innen_beleuchtung_KL58_xd_max-x0,0 lx,10
ENG148603-ENG101574-Innen_beleuchtung_KL58_xd_max-X1,8 lx,10
ENG148603-ENG99557-Innen_beleuchtung_KL58_xd_max-X2,200 lx,10
ENG148603-ENG102140-Innen_beleuchtung_KL58_xd_max-X3,300 lx,10
ENG148603-ENG102936-Innen_beleuchtung_KL58_xd_max-X4,500 lx,10
ENG148603-ENG115659-Innen_beleuchtung_KL58_xd_max-y0,16.0 ,10
ENG148603-ENG99777-Innen_beleuchtung_KL58_xd_max-Y1,16.0 ,10
ENG148603-ENG100480-Innen_beleuchtung_KL58_xd_max-Y2,100.0 ,10
ENG148603-ENG100773-Innen_beleuchtung_KL58_xd_max-Y3,100.0 ,10
ENG148603-ENG100631-Innen_beleuchtung_KL58_xd_max-Y4,100.0 ,10
ENG148602-ENG115658-Innen_beleuchtung_KL58_xd_min-x0,0 lx,10
ENG148602-ENG101574-Innen_beleuchtung_KL58_xd_min-X1,8 lx,10
ENG148602-ENG99557-Innen_beleuchtung_KL58_xd_min-X2,220 lx,10
ENG148602-ENG102140-Innen_beleuchtung_KL58_xd_min-X3,300 lx,10
ENG148602-ENG102936-Innen_beleuchtung_KL58_xd_min-X4,500 lx,10
ENG148602-ENG115659-Innen_beleuchtung_KL58_xd_min-y0,6.0 ,10
ENG148602-ENG99777-Innen_beleuchtung_KL58_xd_min-Y1,6.0 ,10
ENG148602-ENG100480-Innen_beleuchtung_KL58_xd_min-Y2,100.0 ,10
ENG148602-ENG100773-Innen_beleuchtung_KL58_xd_min-Y3,100.0 ,10
ENG148602-ENG100631-Innen_beleuchtung_KL58_xd_min-Y4,100.0 ,10
ENG148607-ENG115658-Innen_beleuchtung_KL58_xd_PWM-x0,0 ,12
ENG148607-ENG101574-Innen_beleuchtung_KL58_xd_PWM-X1,10 ,12
ENG148607-ENG99557-Innen_beleuchtung_KL58_xd_PWM-X2,50 ,12
ENG148607-ENG102140-Innen_beleuchtung_KL58_xd_PWM-X3,100 ,12
ENG148607-ENG102936-Innen_beleuchtung_KL58_xd_PWM-X4,220 ,12
ENG148607-ENG103548-Innen_beleuchtung_KL58_xd_PWM-X5,253 ,12
ENG148607-ENG115659-Innen_beleuchtung_KL58_xd_PWM-y0,3.0 %,12
ENG148607-ENG99777-Innen_beleuchtung_KL58_xd_PWM-Y1,3.0 %,12
ENG148607-ENG100480-Innen_beleuchtung_KL58_xd_PWM-Y2,6.0 %,12
ENG148607-ENG100773-Innen_beleuchtung_KL58_xd_PWM-Y3,10.0 %,12
ENG148607-ENG100631-Innen_beleuchtung_KL58_xd_PWM-Y4,80.0 %,12
ENG148607-ENG102174-Innen_beleuchtung_KL58_xd_PWM-Y5,100.0 %,12
ENG148599-ENG115658-Innen_beleuchtung_KL58_xs_max-x0,0 lx,8
ENG148599-ENG101574-Innen_beleuchtung_KL58_xs_max-X1,8 lx,8
ENG148599-ENG99557-Innen_beleuchtung_KL58_xs_max-X2,50 lx,8
ENG148599-ENG102140-Innen_beleuchtung_KL58_xs_max-X3,500 lx,8
ENG148599-ENG115659-Innen_beleuchtung_KL58_xs_max-y0,100.0 ,8
ENG148599-ENG99777-Innen_beleuchtung_KL58_xs_max-Y1,100.0 ,8
ENG148599-ENG100480-Innen_beleuchtung_KL58_xs_max-Y2,100.0 ,8
ENG148599-ENG100773-Innen_beleuchtung_KL58_xs_max-Y3,100.0 ,8
ENG148605-ENG115658-Innen_beleuchtung_KL58_xs_PWM-x0,0.0 %,6
ENG148605-ENG101574-Innen_beleuchtung_KL58_xs_PWM-X1,50.0 %,6
ENG148605-ENG99557-Innen_beleuchtung_KL58_xs_PWM-X2,100.0 %,6
ENG148605-ENG115659-Innen_beleuchtung_KL58_xs_PWM-y0,0.0 %,6
ENG148605-ENG99777-Innen_beleuchtung_KL58_xs_PWM-Y1,50.0 %,6
ENG148605-ENG100480-Innen_beleuchtung_KL58_xs_PWM-Y2,100.0 %,6
ENG148601-ENG115658-Innen_beleuchtung_KL58_xt_max-x0,0 lx,8
ENG148601-ENG101574-Innen_beleuchtung_KL58_xt_max-X1,8 lx,8
ENG148601-ENG99557-Innen_beleuchtung_KL58_xt_max-X2,50 lx,8
ENG148601-ENG102140-Innen_beleuchtung_KL58_xt_max-X3,500 lx,8
ENG148601-ENG115659-Innen_beleuchtung_KL58_xt_max-y0,100.0 ,8
ENG148601-ENG99777-Innen_beleuchtung_KL58_xt_max-Y1,100.0 ,8
ENG148601-ENG100480-Innen_beleuchtung_KL58_xt_max-Y2,100.0 ,8
ENG148601-ENG100773-Innen_beleuchtung_KL58_xt_max-Y3,100.0 ,8
ENG148600-ENG115658-Innen_beleuchtung_KL58_xt_min-x0,0 lx,8
ENG148600-ENG101574-Innen_beleuchtung_KL58_xt_min-X1,8 lx,8
ENG148600-ENG99557-Innen_beleuchtung_KL58_xt_min-X2,50 lx,8
ENG148600-ENG102140-Innen_beleuchtung_KL58_xt_min-X3,500 lx,8
ENG148600-ENG115659-Innen_beleuchtung_KL58_xt_min-y0,6.0 ,8
ENG148600-ENG99777-Innen_beleuchtung_KL58_xt_min-Y1,6.0 ,8
ENG148600-ENG100480-Innen_beleuchtung_KL58_xt_min-Y2,100.0 ,8
ENG148600-ENG100773-Innen_beleuchtung_KL58_xt_min-Y3,100.0 ,8
ENG148606-ENG115658-Innen_beleuchtung_KL58_xt_PWM-x0,0.0 %,6
ENG148606-ENG101574-Innen_beleuchtung_KL58_xt_PWM-X1,50.0 %,6
ENG148606-ENG99557-Innen_beleuchtung_KL58_xt_PWM-X2,100.0 %,6
ENG148606-ENG115659-Innen_beleuchtung_KL58_xt_PWM-y0,0.0 %,6
ENG148606-ENG99777-Innen_beleuchtung_KL58_xt_PWM-Y1,50.0 %,6
ENG148606-ENG100480-Innen_beleuchtung_KL58_xt_PWM-Y2,100.0 %,6
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG148597-ENG115658-Innenbeleuchtung_Abdimmen-x0,0 ms,22
ENG148597-ENG101574-Innenbeleuchtung_Abdimmen-X1,100 ms,22
ENG148597-ENG115664-Innenbeleuchtung_Abdimmen-x10,1000 ms,22
ENG148597-ENG99557-Innenbeleuchtung_Abdimmen-X2,200 ms,22
ENG148597-ENG102140-Innenbeleuchtung_Abdimmen-X3,300 ms,22
ENG148597-ENG102936-Innenbeleuchtung_Abdimmen-X4,400 ms,22
ENG148597-ENG103548-Innenbeleuchtung_Abdimmen-X5,500 ms,22
ENG148597-ENG113992-Innenbeleuchtung_Abdimmen-X6,600 ms,22
ENG148597-ENG115661-Innenbeleuchtung_Abdimmen-x7,700 ms,22
ENG148597-ENG115662-Innenbeleuchtung_Abdimmen-x8,800 ms,22
ENG148597-ENG115663-Innenbeleuchtung_Abdimmen-x9,900 ms,22
ENG148597-ENG115659-Innenbeleuchtung_Abdimmen-y0,100.0 %,22
ENG148597-ENG99777-Innenbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG148597-ENG115668-Innenbeleuchtung_Abdimmen-y10,0.0 %,22
ENG148597-ENG100480-Innenbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG148597-ENG100773-Innenbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG148597-ENG100631-Innenbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG148597-ENG102174-Innenbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG148597-ENG113993-Innenbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG148597-ENG115665-Innenbeleuchtung_Abdimmen-y7,5.0 %,22
ENG148597-ENG115666-Innenbeleuchtung_Abdimmen-y8,3.0 %,22
ENG148597-ENG115667-Innenbeleuchtung_Abdimmen-y9,1.0 %,22
ENG148598-ENG115658-Innenbeleuchtung_Fotosensor-x0,0 ,22
ENG148598-ENG101574-Innenbeleuchtung_Fotosensor-X1,50 ,22
ENG148598-ENG99557-Innenbeleuchtung_Fotosensor-X2,100 ,22
ENG148598-ENG102140-Innenbeleuchtung_Fotosensor-X3,200 ,22
ENG148598-ENG102936-Innenbeleuchtung_Fotosensor-X4,253 ,22
ENG148598-ENG115659-Innenbeleuchtung_Fotosensor-y0,0 lx,22
ENG148598-ENG99777-Innenbeleuchtung_Fotosensor-Y1,50 lx,22
ENG148598-ENG100480-Innenbeleuchtung_Fotosensor-Y2,100 lx,22
ENG148598-ENG100773-Innenbeleuchtung_Fotosensor-Y3,200 ,22
ENG148598-ENG100631-Innenbeleuchtung_Fotosensor-Y4,500 ,22
ENG148596-ENG115658-Innenbeleuchtung_Hochdimmen-x0,0 ms,22
ENG148596-ENG101574-Innenbeleuchtung_Hochdimmen-X1,100 ms,22
ENG148596-ENG115664-Innenbeleuchtung_Hochdimmen-x10,1000 ms,22
ENG148596-ENG99557-Innenbeleuchtung_Hochdimmen-X2,200 ms,22
ENG148596-ENG102140-Innenbeleuchtung_Hochdimmen-X3,300 ms,22
ENG148596-ENG102936-Innenbeleuchtung_Hochdimmen-X4,400 ms,22
ENG148596-ENG103548-Innenbeleuchtung_Hochdimmen-X5,500 ms,22
ENG148596-ENG113992-Innenbeleuchtung_Hochdimmen-X6,600 ms,22
ENG148596-ENG115661-Innenbeleuchtung_Hochdimmen-x7,700 ms,22
ENG148596-ENG115662-Innenbeleuchtung_Hochdimmen-x8,800 ms,22
ENG148596-ENG115663-Innenbeleuchtung_Hochdimmen-x9,900 ms,22
ENG148596-ENG115659-Innenbeleuchtung_Hochdimmen-y0,0.0 %,22
ENG148596-ENG99777-Innenbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG148596-ENG115668-Innenbeleuchtung_Hochdimmen-y10,100.0 %,22
ENG148596-ENG100480-Innenbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG148596-ENG100773-Innenbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG148596-ENG100631-Innenbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG148596-ENG102174-Innenbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG148596-ENG113993-Innenbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG148596-ENG115665-Innenbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG148596-ENG115666-Innenbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG148596-ENG115667-Innenbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG148604-ENG115658-Innenbeleuchtung_KL58xd_log_Bus-x0,0.0 %,12
ENG148604-ENG101574-Innenbeleuchtung_KL58xd_log_Bus-X1,6.0 %,12
ENG148604-ENG99557-Innenbeleuchtung_KL58xd_log_Bus-X2,16.0 %,12
ENG148604-ENG102140-Innenbeleuchtung_KL58xd_log_Bus-X3,30.0 %,12
ENG148604-ENG102936-Innenbeleuchtung_KL58xd_log_Bus-X4,60.0 %,12
ENG148604-ENG103548-Innenbeleuchtung_KL58xd_log_Bus-X5,100.0 %,12
ENG148604-ENG115659-Innenbeleuchtung_KL58xd_log_Bus-y0,10 ,12
ENG148604-ENG99777-Innenbeleuchtung_KL58xd_log_Bus-Y1,10 ,12
ENG148604-ENG100480-Innenbeleuchtung_KL58xd_log_Bus-Y2,100 ,12
ENG148604-ENG100773-Innenbeleuchtung_KL58xd_log_Bus-Y3,150 ,12
ENG148604-ENG100631-Innenbeleuchtung_KL58xd_log_Bus-Y4,220 ,12
ENG148604-ENG102174-Innenbeleuchtung_KL58xd_log_Bus-Y5,253 ,12
ENG148595-ENG149169-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x0,0 ms,10
ENG148595-ENG149170-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x1,2000 ms,10
ENG148595-ENG149171-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x2,3000 ms,10
ENG148595-ENG149172-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x3,4000 ms,10
ENG148595-ENG149173-Innenbeleuchtung_Tasterdimmung-tasterdimmung_x4,5100 ms,10
ENG148595-ENG149174-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y0,1.0 %,10
ENG148595-ENG149175-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y1,5.0 ,10
ENG148595-ENG149176-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y2,15.0 ,10
ENG148595-ENG149177-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y3,40.0 ,10
ENG148595-ENG149178-Innenbeleuchtung_Tasterdimmung-tasterdimmung_y4,100.0 ,10
ENG148608-ENG148900-Lenkradhebel-Art des Lenkstockschalters,LSS ohne Elektronik ,5
ENG148608-ENG149233-Lenkradhebel-Aussenspiegelheizung_aktivierungssignal,Hardwaresignal ,5
ENG148608-ENG155105-Lenkradhebel-FAS-Taster,not installed ,5
ENG148608-ENG149006-Lenkradhebel-Fernlichtstellung,FL tastend ,5
ENG148608-ENG148901-Lenkradhebel-GRA-Bedienung,MFL-Bedienung ,5
ENG148608-ENG149001-Lenkradhebel-heated_mirror,installed with mirror switch ,5
ENG148608-ENG149004-Lenkradhebel-speed_limiter,installed ,5
ENG148608-ENG179276-Lenkradhebel-Umschaltung GRA zu SL,Direct ,5
ENG148608-ENG154803-Lenkradhebel-Verbauort_Lenkstockschalter,CAN ,5
ENG148608-ENG149234-Lenkradhebel-Versorgung_Lenkstockschalters_KL30,installed ,5
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,0 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,00 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,00 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,not active ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,not active ,16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0 ,16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0 ,16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize ,16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize ,16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize ,16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0 ,16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0 ,16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00 ,16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00 ,16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always ,16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active ,16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active ,16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active ,16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active ,16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active ,16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active ,16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active ,16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active ,16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,22 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,38 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebellicht links ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht links ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeine Scheinwerfer ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,23 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,42 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellicht rechts ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht rechts ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeine Scheinwerfer ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,18 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,18 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken rechts Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not active ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not active ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not active ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not active ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not active ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not active ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not active ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,0 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,00 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,00 ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,not active ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,not active ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,15 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,39 ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,10 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake lamp ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,Position lamps ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,Parking light left ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,15 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,3A ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,20 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake lamp ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,Position lamps ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,Parking light right ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake lamp ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,55 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Position lamps ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,55 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Position lamps ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,30 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,28 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Position lamps ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,allgemeineLEDmitOpenLoadDiagnose ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,33 ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergesteckt ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Dimmer terminal 58xs ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,127 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,127 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,00 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,00 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Unknown (70),16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Position lamps ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,Parking light left ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,Parking light right ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,126 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior lighting ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,0 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,00 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,00 ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,not active ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,not active ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,not active ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,0 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,00 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,00 ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,not active ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,not active ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,not active ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,0 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,00 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,00 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,not active ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,not active ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,not active ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,127 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,00 ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,00 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,127 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,00 ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,00 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,127 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,127 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,00 ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,00 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Unknown (70),16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,beidseitiges Dauerparklicht ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,Position lamps ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,Parking light left ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,127 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,127 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,00 ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,00 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Unknown (70),16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,beidseitiges Dauerparklicht ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,Position lamps ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,Parking light right ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,LED Kleinleistung ohne Open Load Diagnose ,16
ENG148593-Leuchtenkonfiguration (Aussenlicht Heck),0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 0D 10 00 39 18 00 64 08 09 0F 00 00 00 00 00 00 0D 20 00 3A 18 00 64 08 0A 0F 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 09 0A 00 29 08 09 37 00 00 00 00 00 00 00 00 00 09 1A 00 2A 08 0A 37 00 00 00 00 00 00 00 00 00 20 28 00 30 08 00 64 00 00 00 00 00 00 00 00 00 09 0C 00 33 1A 00 64 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 ,160
ENG148594-Leuchtenkonfiguration (Sonstiges),24 00 00 00 3E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 3F 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 40 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 02 00 64 00 00 00 00 00 00 00 00 00 24 00 00 00 04 00 64 00 00 00 00 00 00 00 00 00 24 00 00 08 26 00 64 00 00 00 00 00 00 00 00 00 08 00 00 01 25 00 64 00 00 00 00 00 00 00 00 00 08 00 00 07 29 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,192
ENG126648-MAS02526-LIN-Mirrormode-Activation,not active ,1
ENG126648-ENG149044-LIN-Mirrormode-LIN4,not active ,1
ENG126648-ENG149045-LIN-Mirrormode-LIN5,not active ,1
ENG148592-ENG115658-LuB_Lichtrouter_Kennlinie_1-x0,0.0 %,12
ENG148592-ENG101574-LuB_Lichtrouter_Kennlinie_1-X1,5.0 %,12
ENG148592-ENG99557-LuB_Lichtrouter_Kennlinie_1-X2,50.0 %,12
ENG148592-ENG102140-LuB_Lichtrouter_Kennlinie_1-X3,75.0 %,12
ENG148592-ENG102936-LuB_Lichtrouter_Kennlinie_1-X4,110.0 %,12
ENG148592-ENG103548-LuB_Lichtrouter_Kennlinie_1-X5,126.5 %,12
ENG148592-ENG115659-LuB_Lichtrouter_Kennlinie_1-y0,0.0 %,12
ENG148592-ENG99777-LuB_Lichtrouter_Kennlinie_1-Y1,6.0 %,12
ENG148592-ENG100480-LuB_Lichtrouter_Kennlinie_1-Y2,16.0 %,12
ENG148592-ENG100773-LuB_Lichtrouter_Kennlinie_1-Y3,30.0 %,12
ENG148592-ENG100631-LuB_Lichtrouter_Kennlinie_1-Y4,60.0 %,12
ENG148592-ENG102174-LuB_Lichtrouter_Kennlinie_1-Y5,100.0 %,12
ENG122979-MAS00075-Networking-ABS Control Module,installed ,8
ENG122979-MAS00798-Networking-Transmission Control Module (TCM),not installed ,8
ENG122979-MAS01374-Networking-Trailer,not installed ,8
ENG122979-MAS03175-Networking-Extended data bus,installed ,8
ENG122979-MAS09880-Networking-Interval potentiometer,installed ,8
ENG122979-MAS09882-Networking-MFA button on BCM,not installed ,8
ENG122979-MAS10518-Networking-A/C electronics,installed ,8
ENG122979-MAS10570-Networking-Window lift type,MQB_window_regulator ,8
ENG122979-ENG149007-Networking-Door LIN,installed ,8
ENG122979-ENG149008-Networking-Roof LIN,installed ,8
ENG122979-ENG149009-Networking-Sounder LIN,not installed ,8
ENG148614-ENG148862-Patch_code_driver-Parameter_1,FF 08 00 FF FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,128
ENG148614-ENG148865-Patch_code_driver-Parameter_2,FF FF ,128
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,128
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,FF FF ,128
ENG148615-ENG148862-Patch_code_passenger-Parameter_1,FF 08 00 FF FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,128
ENG148615-ENG148865-Patch_code_passenger-Parameter_2,FF FF ,128
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,128
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,FF FF ,128
ENG141646-MAS00481-Querschnitts_funktionen-BAP,active ,5
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-MAS04194-Querschnitts_funktionen-Driver side,Left ,5
ENG141646-MAS10509-Querschnitts_funktionen-Traffic,Right ,5
ENG141646-MAS10511-Querschnitts_funktionen-Personalization transfer,installed ,5
ENG141646-ENG149084-Querschnitts_funktionen-CAN_Wecken_bei_Softtouchbetaetigung,active ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG149085-Querschnitts_funktionen-Klemmenfehler_auf_CAN_ausgeben,active ,5
ENG141646-ENG126575-Querschnitts_funktionen-mute_mode_aktiv,not active ,5
ENG141646-ENG148952-Querschnitts_funktionen-P_locked,not installed ,5
ENG141646-ENG125011-Querschnitts_funktionen-pa_Funktion_2aus3,installed ,5
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-IDE05534-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG149254-Scheinwerferreinigung-Adaptives_Nachwischen_bei_SRA,active ,10
ENG115729-ENG149255-Scheinwerferreinigung-Anzahl_Betaetigungen_Frontwaschanlage_pro_SRA_Aktivierung,10 ,10
ENG115729-ENG149253-Scheinwerferreinigung-SRA_bei_Waschwassermangel,active ,10
ENG115729-ENG149258-Scheinwerferreinigung-SRA_Einweichpausenzeit,2000 ms,10
ENG115729-ENG149259-Scheinwerferreinigung-SRA_Nachwaschzeit,800 ms,10
ENG115729-ENG149260-Scheinwerferreinigung-SRA_Pausenzeit,10000 ms,10
ENG115729-ENG149256-Scheinwerferreinigung-SRA_Verzoegerungszeit,0 ms,10
ENG115729-ENG149257-Scheinwerferreinigung-SRA_Waschzeit,800 ms,10
ENG115729-ENG148897-Scheinwerferreinigung-windshield_washer_system,not installed ,10
ENG116588-MAS10520-Sonderfunktionen-Special function 1,not installed ,4
ENG116588-ENG130186-Sonderfunktionen-Signalprioritaet_fuer_Blinker,SMLS ,4
ENG116588-ENG126568-Sonderfunktionen-Sonderfunktionen_2,not enabled ,4
ENG141635-ENG149220-Spiegelverstellung-Funk_Spiegelanklappen,not active ,5
ENG141635-ENG149221-Spiegelverstellung-Funk_Spiegelanklappung_Modus,by_convenience_operation_via_remote_control_key ,5
ENG141635-ENG149219-Spiegelverstellung-Menue__Spiegel_absenkung,not active ,5
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,not active ,5
ENG141635-ENG149043-Spiegelverstellung-only_ECU_FHSG_Driver_side,not installed ,5
ENG141635-ENG149223-Spiegelverstellung-Profilfunktion_fuer_Anklappung_der_Aussenspiegel,active ,5
ENG141635-ENG155908-Spiegelverstellung-Spiegel_ausklappen_ueber_FFB_auf,not active ,5
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG149224-Spiegelverstellung-Spiegelanklappung_geschwindigkeitsabhaengig,not active ,5
ENG141635-ENG149041-Spiegelverstellung-window_regulator_node_adress,getauscht ,5
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 lx,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 lx,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 lx,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 lx,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 lx,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 ,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 ,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 ,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 ,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 ,10
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 lx,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 lx,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 lx,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 lx,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 lx,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 ,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 ,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 ,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 ,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 ,10
ENG141632-MAS10512-Sunroof-Sunroof module MD1,not installed ,4
ENG141632-MAS10513-Sunroof-Sunroof module MD shade,not installed ,4
ENG141632-ENG149217-Sunroof-SAD_Komfort_oeffnen,not active ,4
ENG141632-ENG149216-Sunroof-SAD_Komfort_schliessen,not active ,4
ENG141632-ENG149215-Sunroof-SAD_Richtung_Komfortoeffnen,Open ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG148611-MAS10548-Verbau Personalisierung-Profile function,Key profile ,8
ENG148611-ENG126849-Verbau Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,8
ENG148611-ENG133401-Verbau Personalisierung-Anzahl_Benutzerkonten,1 ,8
ENG148611-ENG133402-Verbau Personalisierung-Automatische_ Schluesselzuordnung,active ,8
ENG148611-ENG126850-Verbau Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,8
ENG148611-ENG126848-Verbau Personalisierung-Personalisierung_aktiv,active ,8
ENG148611-ENG126851-Verbau Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,8
ENG148611-ENG142030-Verbau Personalisierung-Profil_Variante,Schluessel ,8
ENG148611-ENG133403-Verbau Personalisierung-PSO_FSG_Setup2_Bit_0,active ,8
ENG148611-ENG133404-Verbau Personalisierung-PSO_FSG_Setup2_Bit_1,active ,8
ENG148611-ENG133405-Verbau Personalisierung-PSO_FSG_Setup2_Bit_2,active ,8
ENG148611-ENG133406-Verbau Personalisierung-PSO_FSG_Setup2_Bit_3,active ,8
ENG148611-ENG133407-Verbau Personalisierung-PSO_FSG_Setup2_Bit_4,active ,8
ENG148611-ENG133408-Verbau Personalisierung-PSO_FSG_Setup2_Bit_5,active ,8
ENG148611-ENG133409-Verbau Personalisierung-PSO_FSG_Setup2_Bit_6,active ,8
ENG148611-ENG133410-Verbau Personalisierung-PSO_FSG_Setup2_Bit_7,active ,8
ENG148610-ENG148877-Vernetzungs-_Diagnosefunktionen-can_msg_1,00 00 ,20
ENG148610-ENG148878-Vernetzungs-_Diagnosefunktionen-can_msg_2,00 00 ,20
ENG148610-ENG148879-Vernetzungs-_Diagnosefunktionen-can_msg_3,00 00 ,20
ENG148610-ENG148880-Vernetzungs-_Diagnosefunktionen-can_msg_4,00 00 ,20
ENG148610-ENG148881-Vernetzungs-_Diagnosefunktionen-lin_msg_1,00 00 ,20
ENG148610-ENG148882-Vernetzungs-_Diagnosefunktionen-lin_msg_2,00 00 ,20
ENG148610-ENG148883-Vernetzungs-_Diagnosefunktionen-lin_msg_3,00 00 ,20
ENG148610-ENG148884-Vernetzungs-_Diagnosefunktionen-lin_msg_4,00 00 ,20
ENG148610-ENG148885-Vernetzungs-_Diagnosefunktionen-lin_msg_5,00 00 ,20
ENG148610-ENG148886-Vernetzungs-_Diagnosefunktionen-lin_msg_6,00 00 ,20
ENG148612-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_1,04 04 90 19 02 00 00 08 FF BE F7 07 D0 10 10 F6 00 C8 32 0B 0F 03 84 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 0A 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 02 98 10 00 02 51 C0 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 EF 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00 ,128
ENG148612-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_1-Parameter_2,58 9A ,128
ENG148613-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_1,03 84 02 8A 14 1E EC 01 0B 02 08 00 00 00 00 05 32 02 1E 19 0A 00 0A F4 32 1E 10 00 03 FD 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 2A 1E 20 1E 32 64 D8 C4 F1 F6 28 1E 05 1E 00 00 3C 06 37 11 10 0C 32 C8 F6 E7 F6 FB 19 14 05 0E 14 01 5E 02 34 10 10 0E 32 64 D8 D8 F1 F6 28 1E 05 0F 0C 19 19 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG148613-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_2-Parameter_2,B8 CA ,128
ENG130135-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_1,29 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 01 90 01 90 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130135-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_3-Parameter_2,19 34 ,128
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 0F FF DF FF 00 00 00 0A 01 00 00 00 ,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,FF CE ,128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,03 20 02 26 14 EC 04 02 02 0A 02 02 00 0A 05 28 04 14 19 0F 00 05 EC 19 1E 14 00 05 FB 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 1E 00 19 1E 20 1E FA E2 CE F1 F6 28 1E 32 08 1E 00 00 32 02 16 0E 14 12 C8 EC D8 F1 F6 1E 14 32 00 0C 14 01 2C 02 19 0E 14 12 FA E2 CE F1 F6 28 1E 32 00 0E 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,8C 1F ,128
ENG130138-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_1,04 04 90 19 02 00 00 08 FF BE F7 07 D0 10 10 F6 00 C8 32 0B 0F 03 84 01 90 F0 F0 F0 00 20 FC 7C 00 14 00 0A 01 2C 07 00 00 01 5E 04 07 0C 14 32 0F 9A 00 02 98 10 00 02 51 C0 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 00 00 05 05 0F 2D 50 73 04 04 27 10 19 04 C0 70 D3 00 4E 53 12 12 0C 03 00 8F 01 00 00 07 5A 0B 00 0E 53 6D 03 00 10 80 0C 00 ,128
ENG130138-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_1-Parameter_2,1C 9C ,128
ENG130139-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_1,03 84 02 8A 14 1E EC 01 0B 02 08 00 00 00 00 05 32 02 1E 19 0A 00 0A F4 32 1E 10 00 03 FD 0A 0A F6 12 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 2A 1E 20 1E 32 64 D8 C4 F1 F6 28 1E 05 1E 00 00 3C 06 37 11 10 0C 32 C8 F6 E7 F6 FB 19 14 05 0E 14 01 5E 02 34 10 10 0E 32 64 D8 D8 F1 F6 28 1E 05 0F 0C 19 19 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_2-Parameter_2,B8 CA ,128
ENG130140-ENG148862-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_1,29 02 25 05 0B FD 00 6E 0D 10 3F 50 50 50 5C 64 80 A7 50 5C 4B 4B 4B 4B 0A 0A 0A 0A FF FF 00 00 32 32 64 64 00 02 0A 02 32 06 64 0A DC 50 FD 64 F0 0D 00 02 02 00 00 00 00 00 00 01 E0 3C 02 28 00 00 02 02 01 01 20 28 14 02 31 40 02 11 24 38 52 28 13 06 4D 26 11 06 54 2A 14 06 5C 33 1A 09 01 90 01 90 14 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-ENG148865-Window_Regulator_Supplier_Settings_Passener_Side_3-Parameter_2,EF A8 ,128
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 0F FF DF FF 00 00 00 0A 01 00 00 00 ,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,AC 46 ,128
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,03 20 02 26 14 EC 04 02 02 0A 02 02 00 0A 05 28 04 14 19 0F 00 05 EC 19 1E 14 00 05 FB 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 1E 00 19 1E 20 1E FA E2 CE F1 F6 28 1E 32 08 1E 00 00 32 02 16 0E 14 12 C8 EC D8 F1 F6 1E 14 32 00 0C 14 01 2C 02 19 0E 14 12 FA E2 CE F1 F6 28 1E 32 00 0E 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,8C 1F ,128
ENG124895-Window_Regulator_VW_Settings_Driver_Side,F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 28 32 32 03 01 00 00 00 00 01 F4 02 08 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 96 96 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 0F 3C 50 00 64 1E 50 06 00 E1 01 00 0A 00 14 00 00 ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 A0 00 00 32 3C C8 00 4E 00 4D 79 64 64 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 42 41 30 39 01 00 00 00 00 00 00 00 00 00 AD 84 ,88
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,F0 08 FF F0 00 10 C8 19 0F 00 14 14 00 14 C8 28 32 32 03 01 00 00 00 00 01 F4 02 08 00 09 64 00 00 00 00 00 00 00 00 00 00 00 00 86 32 32 06 C8 4E 4D 79 32 14 1E CD C6 14 0A 60 E6 6D D9 64 14 32 0A 0A 0B 0F 0F 1E 0F 3C 50 00 64 1E 50 06 00 E1 01 00 0A 00 14 00 00 ,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 23 00 32 32 01 90 00 00 00 00 00 00 00 A0 00 00 32 3C C8 00 4E 00 4D 79 00 00 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 42 41 30 39 01 00 00 00 00 00 00 00 00 00 A0 02 ,88
ENG148493-ENG115721-Windshield wiper-Frontwischer,Sollspannungsanforderung 13.5 ,6
ENG148493-ENG133394-Windshield wiper-Frontwischer_Abtauposition,keine_Abtaupostition ,6
ENG148493-ENG149235-Windshield wiper-Frontwischer_Referenzlauf,active ,6
ENG148493-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,6
ENG148493-ENG149241-Windshield wiper-Geschwindigkeitsabhaengige_Wischstufenrueckschaltung,active ,6
ENG148493-ENG149239-Windshield wiper-Menuesteuerung_Frontwischer,not active ,6
ENG148493-ENG154706-Windshield wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG148493-ENG149042-Windshield wiper-rain_sensor_function,installed ,6
ENG148493-ENG149238-Windshield wiper-Regensensor_aktivieren,active ,6
ENG148493-ENG149242-Windshield wiper-Traenenwischen_Front_Status,not active ,6
ENG148493-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,active ,6
ENG148493-ENG148995-Windshield wiper-windshield_wiper_typ,Direct ,6
ENG148493-ENG149237-Windshield wiper-Wischer_abparken_bei_Oeffnen_der_Motorhaube,not active ,6
ENG148493-ENG149236-Windshield wiper-Wischer_stop_bei_KL15_aus,not active ,6
ENG148493-ENG149244-Windshield wiper-Wischer_stop_bei_Motorstart,immer_Wischerstopp ,6
ENG148493-ENG149243-Windshield wiper-Wischer_Stopp_bei_Oeffnen_der_Motorhaube,active ,6
ENG141651-MAS10522-ZV allgemein-Lock/unlock: direct button,Rocker sw. ,5
ENG141651-MAS10546-ZV allgemein-Radio freq.,434.42MHz ,5
ENG141651-MAS10554-ZV allgemein-Central locking without SAFE function,installed ,5
ENG141651-ZV allgemein-,not active ,5
ENG141651-ENG179102-ZV allgemein-Abgesichertes Safen,not active ,5
ENG141651-ENG248507-ZV allgemein-Auswertung_Batt_TranspID_Telegramm,not active ,5
ENG141651-ENG179106-ZV allgemein-Autolock_nur_bei_Motorlauf,not active ,5
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,5
ENG141651-ENG149179-ZV allgemein-Funk_bei_Klemme_15_ein,not active ,5
ENG141651-ENG179144-ZV allgemein-Kessy Wiederentriegelung mit Außenhaut,not active ,5
ENG141651-ENG149181-ZV allgemein-Menuesteuerung_Tuerentriegelung,active ,5
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,5
ENG141651-ENG179092-ZV allgemein-Schlossansteuerung,all_doors_connected_directly ,5
ENG141651-ENG149384-ZV allgemein-seitenselektive_Oeffnung,Yes ,5
ENG141651-ENG149180-ZV allgemein-ZV_Tuerentriegelung,Globale_Entriegelung ,5
ENG141654-ENG149213-ZV Autolock-Autolock_Autounlock_wirkt_auf_Heck,active ,5
ENG141654-ENG149211-ZV Autolock-automatisches_Entriegeln,active ,5
ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit,active ,5
ENG141654-ENG149212-ZV Autolock-Autounlock_NAR,not active ,5
ENG141654-ENG149214-ZV Autolock-Menuesteuerung_ZV_Autolock-Unlock,adjustable ,5
ENG141655-ENG149225-ZV Crash-Heckdeckel-Bedienstellen_nachCrash_temporaer_sperren,active ,4
ENG141655-ENG149227-ZV Crash-SAD_PreCrash_Konturschliessen,active ,4
ENG141655-ENG149226-ZV Crash-ZV-Entriegelung_nach_Seitencrash,not active ,4
ENG141653-MAS07515-ZV Heck-Trunk lid remote unlocking: int. button,not installed ,5
ENG141653-MAS10551-ZV Heck-Rear lid lock control,Contact control ,5
ENG141653-MAS10555-ZV Heck-Central locking: rear lock type,1 or 2 notch rear actuator ,5
ENG141653-MAS10561-ZV Heck-Rear lock with safety catch,Yes ,5
ENG141653-ENG149183-ZV Heck-Direkter_Auswurf_des_Heckdeckels,active ,5
ENG141653-ENG149185-ZV Heck-Freigabenachlauf_Heck_nach_Einzeloeffnung_ueber_HDF-Funktaster,not active ,5
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,5
ENG141653-ENG126630-ZV Heck-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,5
ENG141653-ENG155905-ZV Heck-Softtouch_Auswertung,digitale_Logik ,5
ENG141653-ENG149182-ZV Heck-ZV_entriegelt_auch_Heckdeckel,active ,5
ENG141653-ENG149184-ZV Heck-ZV_Heck_nur_direkt_auswerfen,not active ,5
ENG148616-IDE02021-ZV Komfort (Fensterheber)-Comfort closing,active ,7
ENG148616-IDE02022-ZV Komfort (Fensterheber)-Comfort opening,not active ,7
ENG148616-MAS10525-ZV Komfort (Fensterheber)-Electrical window lift: front,active ,7
ENG148616-MAS10526-ZV Komfort (Fensterheber)-Electrical window left: rear,Yes ,7
ENG148616-ENG154964-ZV Komfort (Fensterheber)-BAP_Komfortschließen,not active ,7
ENG148616-ENG248524-ZV Komfort (Fensterheber)-Busruhe_bei_Fensterheberfreigabenachlauf,not active ,7
ENG148616-ENG149202-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_oeffnen,active ,7
ENG148616-ENG149206-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_schliessen,active ,7
ENG148616-ENG149203-ZV Komfort (Fensterheber)-FH_SAD_Kl15Aus_Freigabezeit,600 s,7
ENG148616-ENG149196-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Kl_15_aus,active ,7
ENG148616-ENG149197-ZV Komfort (Fensterheber)-Freigabenachlauf_FH_bei_Tueroeffnen,active ,7
ENG148616-ENG149201-ZV Komfort (Fensterheber)-Funk_Komfort_oeffnen,active ,7
ENG148616-ENG149205-ZV Komfort (Fensterheber)-Funk_Komfort_schliessen,active ,7
ENG148616-ENG155240-ZV Komfort (Fensterheber)-Kindersicherung_Beifahrerfenster,not active ,7
ENG148616-ENG149198-ZV Komfort (Fensterheber)-Komfortbedienung_global,active ,7
ENG148616-ENG149199-ZV Komfort (Fensterheber)-Komfortoeffnen_nur_FH_Fahrertuer,not active ,7
ENG148616-ENG155244-ZV Komfort (Fensterheber)-Komfortschliessen_Brasilien,not active ,7
ENG148616-ENG149209-ZV Komfort (Fensterheber)-Manuelle_ZV_Variantenprogrammierung,not active ,7
ENG148616-ENG149207-ZV Komfort (Fensterheber)-Menuesteuerung_Komfortbedienung_einstellbar,adjustable ,7
ENG148616-ENG149200-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_oeffnen,active ,7
ENG148616-ENG149204-ZV Komfort (Fensterheber)-Schliesszylinder_Komfort_schliessen,active ,7
ENG141652-MAS01914-ZV Türkonfiguration-Type of lock,1 Motor locks without Safe (NAR locks) ,5
ENG141652-MAS06443-ZV Türkonfiguration-Lock cylinder passenger door,not installed ,5
ENG141652-MAS10567-ZV Türkonfiguration-Four-door,Yes ,5
Elapsed Time: 01:28
downtime
Finland
C?ID=280813
Most likely the Leuchte channels are not correct. I have luckily one adamap from LED Polo :) So I'll make a comparison this evening and check what channels you need to change and to what to make this work.
Jacce
Finland
C?ID=304131
And here is newest autoscan.
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 2B 44 55 5F D6 D7
VIN: WVWZZZAWZJY008727   Mileage: 58469km-36330miles
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHZL)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BD    HW: 04C 907 309 AT
   Component: R3 1.0l TFS   H21 5150
   Revision: WXH21---    CVN: 70E1CBCB
   Coding: 01110032234415081000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10TFS01104C906026BD 002003
   ROD: EV_ECM10TFS01104C906026BF.rod
   VCID: 6492A5FDCEDF140B239-8030
   VINID: 9E69EAAAA467A9AA400081C21C2F87860F
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AA    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H22 0222
   Serial number: 08505417170806
   Coding: 09034B64154190B5D203A81824E142A649124D26224A245844541254452442659248B2644452241A222A482AA249D64A7D926B52BE
   Shop #: WSC 41391 003 1048576
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0_004.rod
   VCID: 6D84C0D91D1555437C7-8038
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0451497238
   Coding: 132C0C0623
   ROD: EV_KessyHellaMQBAB_VW27.rod
   VCID: 3E26379500F31EDB95D-806A
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 2G0 907 044 L    HW: 2G0 907 044 L
   Component: Climatronic   H03 0501
   Coding: 0120000008000100011004000244010D0000000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: EV_ACClimaBHBMQBA0_VW27.rod
   VCID: 2D0400D9DD9595433C7-8078
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H97 0915
   Serial number: 07001722900057
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 77A8E2B16F49EF9396B-8022
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S4Y17M08D25H18M54S56
   Coding: 0038DD
   Driver door control module:
   Subsystem 2 - Part No SW: 2Q1 959 881     HW: 2Q1 959 881
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000015973688
   Coding: 130000
   Front passenger door control module:
   Subsystem 3 - Part No SW: 2Q1 959 882     HW: 2Q1 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000016043014
   Coding: 090000
   Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000016040269
   Coding: 030000
   Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000015973129
   Coding: 1B0000
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617203
   Coding: 0471051001
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4BC06E414341BB73023-801E
1112340 - Front Right Center Parking Aid Sensor
          B10F9 14 [009] - Open or Short to Ground
                    Reset counter: 95
                    Mileage: 58374 km
                    Date: 2021.09.06
                    Time: 01:59:58
   Component: ACCCONTIMQB   H02 0233
   Coding: 2A00600200FF8748949C8145604087
   Part No SW: 2Q0 959 655 AH    HW: 2Q0 959 655 B
   Component: VW22Airbag    010 0349
   Revision: --------
   Coding: 88CCC0C0000000005C5400CF000800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 035086612B91B333BA3-8056
   Left seat belt tensioner:
   Serial number: 2G4857705B0228R00173
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 2G4857706B0229R00811
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 442 062 407 17
   Serial number: 3577Y20B124C3A54D183
   Subsystem 4 - Part No SW: -----------    HW: 442 060 308 17
   Serial number: 3587Y20A3249F6C29046
   Subsystem 5 - Part No SW: -----------    HW: 442 0B0 408 17
   Serial number: 3517711BD2767322F1DL
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 408 17
   Serial number: 3527711BD2767320E18E
   Subsystem 7 - Part No SW: -----------    HW: 442 131 508 17
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11B3269FFA233E5
   Part No SW: 2G0 920 740 A    HW: 2G0 920 740 A
   Component: KOMBI         309 0460
   Coding: 04A401102D8000080C8822011001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 201AE9ED9A47482B871-8074
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H97 0915
   Coding: 030100046F085600F800025C080F00010001070000000000000000000000
   GVL: 01443C000000060040009000000048000000C000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_VW27.rod
   VCID: 6FB8DAD11719A7534EB-803A
   Generator:
   Subsystem 2 - Part No SW: 2G0 959 442 F    HW: 2G0 959 442 F
   Component: E221__MFL-DC1  H02 0040
   Serial number: 39170002093120047344
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 1000E17E
131734 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x96]
                    Reset counter: 96
                    Mileage: 58374 km
                    Date: 2021.09.06
                    Time: 02:03:45
                    Terminal 30 power supply: 13.4 V
                    Terminal 15: On
131735 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x97]
                    Reset counter: 96
                    Mileage: 58374 km
                    Date: 2021.09.06
                    Time: 02:03:45
                    Terminal 15: On
   Part No SW: 2Q0 905 861     HW: 2Q0 905 861
   Component: ELV-MQBB      H06 0020
   Serial number: 17000128508006
   Coding: 5500000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002001
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 70BAD9AD0A27B8AB571-8024
Address 44: Steering Assist (J792)       Labels:* 2Qx-909-144-V1.clb
   Part No SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 610 6041
   Serial number: 0090417CB3H2411
   Coding: 010000000000000001010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3C223D9D16EF0CCBBB9-8068
10551552 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [DEM_CODING_PLA_FAULT]
                    Reset counter: 95
                    Mileage: 58374 km
                    Date: 2021.09.06
                    Time: 02:00:00
                    Engine RPM: 0 /min
                    Terminal 15 status: On
                    Voltage terminal 30: 12.35 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 21 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 0 °
                    Electric motor speed: 0 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: -0.1 Nm
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0070
   Coding: 1788000009200003
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DC4C69710D6123E8F-8014
66881 - Databus
                    Reset counter: 95
                    Mileage: 58374 km
                    Date: 2021.09.06
                    Time: 01:59:56
66882 - Databus
                    Reset counter: 95
                    Mileage: 58374 km
                    Date: 2021.09.06
                    Time: 01:59:56
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      H41 0449
   Serial number: VWZAZ2T1572160
   Coding: 02720000BE0000004111000100080A001F0500C40120010003
   ROD: EV_MUStd4CTSAT_VW27.rod
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT2430499
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EA6F7954073DEDBD5D-802A
0019 - Headlamp Type
          C119F 00 [175] - Implausible
                    Fault Frequency: 29
                    Reset counter: 0
                    Mileage: 58374 km
                    Date: 2021.09.06
                    Time: 01:59:55
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
                    Fault Frequency: 29
                    Reset counter: 0
                    Mileage: 58374 km
                    Date: 2021.09.06
                    Time: 01:59:55
1090 - LED Turn Signal Lights
          C11BF F0 [174] - Current Coding Electrical Malfunction
                    Fault Frequency: 28
                    Reset counter: 0
End----------(Elapsed Time: 01:03, VBatt start/end: 12.1V/12.1V)-----------
Jacce
Finland
C?ID=304131
@downtime: First admap I've posted was wrong. It was from another Polo. I've updated the post with correct admap.
Jacce
Finland
C?ID=304131
@downtime: The Polo got only headlight upgrade. Rear lights are normal glow versions.
downtime
Finland
C?ID=280813
Ok, that would've been my next question :D I'll check the adamaps this evening and get back to you
downtime
Finland
C?ID=280813
First of all, are you sure your BCM even supports LED headlights? You have 089 which is std BCM and the adamap I'm just checking is -90 which is std+ BCM.
Anyway, what you could try is to write the complete light configuration again. This one is from LED headlight and rear lights car, you will need to manually modify the rear light settings to glow lamps again.
ENG148593-Leuchtenkonfiguration (Aussenlicht Heck),0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 22 10 00 39 18 00 64 1F 09 0F 00 00 00 00 00 00 27 20 00 3A 18 00 64 1F 0A 0F 00 00 00 00 00 00 22 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 20 28 00 30 08 00 7F 00 14 00 00 00 00 00 00 00 2D 0C 00 33 1A 00 64 00 00 00 00 00 00 00 00 00 1A 2B 00 34 19 00 64 00 00 00 00 00 00 00 00 00 ,160
Then the range control module 55, try to change coding of that to =>
178A000009200003
Jacce
Finland
C?ID=304131
Thank you. I'll try those codes.
For BCM I've confirmed that it is suitable. I've crosschecked few vins with LED lights with etka. All Polos with manual gearbox has 089 BCM and with DSG they have 090.
090 has external gateway module. 089 has integrated gateway in BCM.
I'll update as soon as I've tried those codings tomorrow.
Today I discovered that ecus on headlights D6 and D7 have zero codings (000000). Wonder if that is one of the problems.-?
downtime
Finland
C?ID=280813
Could be. But those are usually coded through the 55 module. Means, when you input the right code for that, it automatically recodes the slave modules as well.
Is your range control module originally from Polo?
Jacce
Finland
C?ID=304131
The 55 module is from identical car with 089 BCM and factory LEDs. D6 and D7 came with used LED headlights.
If those codes work, which channels do I need to change for rear glow lamps ?
downtime
Finland
C?ID=280813
I'm attaching Don's excellent post from the other thread here. You can find there which leuchte channels are for rear lights. Just check your current adamap what are the light settings there and change them to match.
Jacce
Finland
C?ID=304131
Ok. Did you check was there other differences between my adamap and your working adamap?
downtime
Finland
C?ID=280813
That's the problem, on the light channels there were no visible differences. I'll post the adamap here for reference.
Jacce
Finland
C?ID=304131
I have now done the coding on both 09 and 55. I'll post autscan later today when I hook up VCDS to car.
Thing is that nothing changed and basic settings is not possible in 55. I allso discovered this in 55. Check pics..
Polo_55_a
Polo_55_b
Polo_55_c
downtime
Finland
C?ID=280813
Check module 55 advanced info, what does it say as dataset there?
Jacce
Finland
C?ID=304131
Here is the result.
Wednesday,15,September,2021,07:20:16:19122
VCDS Version: Release 21.9.0 (x64)
Control Module Part Number: 7P6 907 357 E
  Component and/or Version: AFS-ECU       H07 0070
           Software Coding: 178A000009200003
            Work Shop Code: WSC 00788
Advanced Identification/FAZIT
     Identification: SME-RBG
     Revision: --------
     Date: 27.10.17
     Manufacturer number: 0008
     Test stand number: 0732
Flash Status
     Programming Attempts(application): 0/0
     Programming Attempts(data): 1
     Successful Attempts(data): 1
     Flash Date: 00.00.00
     Flash Tool Code(data): 00255 648 00788
Misc.
     Hardware number: 7P6 907 357 A
     Workshop System Name: J745
     Equipment/PR Code: FFFFFFFFFFFFFFFFFFFFFFFF
     Dataset Number: V03935262NK
     Dataset Version: 0001
     ASAM Dataset Revision: 001001
VCDS Info:
       Labels: 7P6-907-357.clb
downtime
Finland
C?ID=280813
This is the dataset currently in the unit :
What is the problem with basic settings?
