Cat Converters (2003 Audi A4)
cschmitz20
Verified VCDS-Lite User
C?ID=385099
I have a 2003 Audi A4 Cabrio. I am just trying to prepare for emmissions testing un february. I have an evap issue and i also have a cat issue with bank 1. I run the tests and bank 2 is fine but the test keeps shutting off while trying to run bank 1. I have already got code P0421 but was able to pass last time with only the evap monitor not ready. With bank 1 not ever gettin set should i just keep tryinh and trying or is there a good chance my cat 1 i shot?
cschmitz20
C?ID=385099
Its kind of both. What does it mean that the one bank just keeps turning the test off despite the other bank testing ok?
Westbury, UK
A problem with a sensor used by one bank but not the other???
Really need an Auto-Scan since we don't even know what engine your A4 cabrio has...
cschmitz20
C?ID=385099
I have the auto scan just finding time to post. I
One quick question i tried to do the force readiness option and there seems to be an issue when it comes to to oxygen sensor transpose test.it never gets high enough rpm to run that test. But the oxygen sensors are set to ready? Is there another set of sensors? It seems to prevent the other cat from passing.
Were not asking you to chisel it into granite or anything!
As stated in post #2 and #4 and now #6, Please post a current, full, unedited Auto-scan. Otherwise.... your simply guessing.
cschmitz20
C?ID=385099
Will do. Also in the us. Which side is bank 1 and bank 2? I see both online. I thought bank 1 was my drivers. But now i read its passenger? Damn interwebs
cschmitz20
C?ID=385099
Quick question you can tell what the transpose oxygem sensor is by looking at the auto scan?
cschmitz20
C?ID=385099
CDS Self-Diagnosis Log Friday,10,September,2021,09:40:13:55140 Page 4 VIN: WAUAT48H63K022250 License Plate: Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb Part No: 8H0 959 433 C Component: Komfortgerát T7B 1412 Coding: 11788 Shop #: WSC 00672 VCID: 34311D17D72619EB5BB-4B00 Subsystem 1 - Part No: 8H1959801 Component: Tõrsteuer.FS BRM 0001 Component: Tõrsteuer.BF BRM 0001 5 Faults Found: 01134 - Alarm Horn (H12) 37-10 - Faulty - Intermittent 01134 - Alarm Horn (H12) 49-00 - No Communications 00955 - Key 1 35-10 - - - Intermittent 01333 - Door Control Module; Rear Left (J388) 80-10 - Single-Wire Operation - Intermittent 01334 - Door Control Module; Rear Right (J389) 80-10 - Single-Wire Operation - Intermittent ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00070 Shop #: WSC 00672 VCID: 04518DD7C736696BABB-4B00 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 195 F Component: symphony II NP2 0051 Coding: 00205 Shop #: WSC 40313 VCID: 2A0D036F05D25F1BF17-4E62 2 Faults Found: 00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 36-00 - Open Circuit 00856 - Radio Antenna 36-00 - Open Circuit ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Friday,10,September,2021,09:40:13:55140 Page 5 VIN: WAUAT48H63K022250 License Plate: Address 63: Entry Assist,D Labels: None Part No: 8H0 959 760 A Component: EasyEntry F M H11 X023 Coding: 00006 Shop #: WSC 00065 VCID: 35372013DC6C00E36C5-4B1E No fault code found. ------------------------------------------------------------------------------- Address 73: Entry Assist, P Labels: None Part No: 8H0 959 760 A Component: EasyEntry BF H11 X023 Coding: 00005 Shop #: WSC 00000 VCID: 35372013DC6C00E36C5-4B1E 2 Faults Found: 01336 - Company Data Bus for Comfort System 80-00 - Single-Wire Operation 01794 - Control Module - Incorrect Chassis (VIN) Number 35-00 - - End----------(Elapsed Time: 05:43, VBatt start/end: 12.3V/12.2V)-----------
cschmitz20
C?ID=385099
Ok it's posted
cschmitz20
C?ID=385099
OK posted
cschmitz20
C?ID=385099
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 21.3.0(x64) Data version: 20210226 DS325.0 www.Ross-Tech.com Dealer/Shop Name: Workshop Code: 000 00000 000000 Self-Diagnosis Log Friday,10,September,2021,09:40:13:55140 VIN: WAUAT48H63K022250 License Plate: Mileage: Repair Order: Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57 63 65 67 73 75 76 77 VIN: WAUAT48H63K022250 Mileage: 213350km-132569miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06C-909-559-ASN.lbl Part No SW: 8E0 909 559 E HW: 8E0 909 059 Component: 3.0L V6/5V G 0004 Coding: 0016584 Shop #: WSC 00672 785 00200 VCID: 372B2A1BC350F2F37E9-5160 1 Fault Found: 16805 - Warm Up Catalyst; Bank 1 P0421 - 001 - Efficiency Below Threshold Readiness: 0000 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01J-927-156.lbl Part No: 01J 927 156 FE Component: V30 01J 3.0l 5V USA 3031 Coding: 01001 Shop #: WSC 03213 VCID: 74B1DD1797A659EB9BB-5160 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 G Component: ABS/ESP front 2328 Coding: 04499 Shop #: WSC 00672 VCID: 2C0105770F16412B03B-51F2 No fault code found. ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Friday,10,September,2021,09:40:13:55140 Page 2 VIN: WAUAT48H63K022250 License Plate: Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 L Component: A4 Klimaautomat 1116 Coding: 00100 Shop #: WSC 00672 VCID: 2A0D036F05E25F1BF17-513C 4 Faults Found: 01809 - Actuating Motor for Temperature Flap; Left (V158) 41-10 - Blocked or No Voltage - Intermittent 00716 - Air recirculation Flap Positioning Motor (V113) 41-10 - Blocked or No Voltage - Intermittent 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143) 30-10 - Open or Short to Plus - Intermittent 00819 - High Pressure Sensor (G65) 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 E Component: int. Lastmodul USA 0305 Coding: 00013 Shop #: WSC 00672 VCID: 34311D17D72619EB5BB-4B00 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8H0-959-655-84.lbl Part No: 8H0 959 655 B Component: Airbag 8.4EC 1015 Coding: 0010105 Shop #: WSC 00672 785 00200 VCID: 392F2C23F544E48388D-5160 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 N Component: Lenksáulenmodul 0308 Coding: 02041 Shop #: WSC 00672 VCID: 3E253F3FE96AC3BBBDF-4B00 No fault code found. ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Friday,10,September,2021,09:40:13:55140 Page 3 VIN: WAUAT48H63K022250 License Plate: Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8H0 920 950 E Component: KOMBI+WEGFAHRS. RB4 D16 Coding: 02201 Shop #: WSC 03213 VCID: 2E050F7F390A333B2DF-5160 WAUAT48H63K022250 AUZ6Z0B0400950 1 Fault Found: 00562 - Sensor for Oil Level/Temperature (G266) 27-00 - Implausible Signal ------------------------------------------------------------------------------- Address 26: Auto Roof Labels: 8H0-959-255.lbl Part No: 8H0 959 255 B Component: VSG B6 CABRIO 7195 Shop #: WSC 02101 444 12602 VCID: 35372013D95C00E36C5-5160 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No: 8H0 959 760 Component: Sitzmemory EE H04 X013 Coding: 00002 Shop #: WSC 00065 VCID: 74B1DD17979659EB9BB-4B1E No fault code found. ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Friday,10,September,2021,09:40:13:55140 Page 4 VIN: WAUAT48H63K022250 License Plate: Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb Part No: 8H0 959 433 C Component: Komfortgerát T7B 1412 Coding: 11788 Shop #: WSC 00672 VCID: 34311D17D72619EB5BB-4B00 Subsystem 1 - Part No: 8H1959801 Component: Tõrsteuer.FS BRM 0001 Component: Tõrsteuer.BF BRM 0001 5 Faults Found: 01134 - Alarm Horn (H12) 37-10 - Faulty - Intermittent 01134 - Alarm Horn (H12) 49-00 - No Communications 00955 - Key 1 35-10 - - - Intermittent 01333 - Door Control Module; Rear Left (J388) 80-10 - Single-Wire Operation - Intermittent 01334 - Door Control Module; Rear Right (J389) 80-10 - Single-Wire Operation - Intermittent ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00070 Shop #: WSC 00672 VCID: 04518DD7C736696BABB-4B00 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 195 F Component: symphony II NP2 0051 Coding: 00205 Shop #: WSC 40313 VCID: 2A0D036F05D25F1BF17-4E62 2 Faults Found: 00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 36-00 - Open Circuit 00856 - Radio Antenna 36-00 - Open Circuit ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Friday,10,September,2021,09:40:13:55140 Page 5 VIN: WAUAT48H63K022250 License Plate: Address 63: Entry Assist,D Labels: None Part No: 8H0 959 760 A Component: EasyEntry F M H11 X023 Coding: 00006 Shop #: WSC 00065 VCID: 35372013DC6C00E36C5-4B1E No fault code found. ------------------------------------------------------------------------------- Address 73: Entry Assist, P Labels: None Part No: 8H0 959 760 A Component: EasyEntry BF H11 X023 Coding: 00005 Shop #: WSC 00000 VCID: 35372013DC6C00E36C5-4B1E 2 Faults Found: 01336 - Company Data Bus for Comfort System 80-00 - Single-Wire Operation 01794 - Control Module - Incorrect Chassis (VIN) Number 35-00 - - End----------(Elapsed Time: 05:43, VBatt start/end: 12.3V/12.2V)-----------
cschmitz20
C?ID=385099
sorry missed the first part of the scan
cschmitz20
C?ID=385099
Is this scan ok?
cschmitz20
C?ID=385099
What do you need to see? I copied and pasted.
Westbury, UK
What "PC" are you using? Losing all the line breaks is very unusual.
I open the saved .txt file (look in C:/Ross-Tech/VCDS/Scans) using Notepad, select all then copy - then I start a new post here and click on the </> icon in the editor then paste the saved text. Works every time for me and takes only seconds.
cschmitz20
C?ID=385099
Just a regular acer laptop.
cschmitz20
C?ID=385099
Highlight copy and paste from pdf. Can we discuss my questions?
