DQ200 DSG Gearbox Basic Setting Fluid Temperature Advanced Measuring
SirSkeedle
Manchester, UK
C?ID=426705
Hi all,
I was attempting to do a basic setting of a DQ200 gearbox on a 2018 SEAT LEON. I was following the Ross tech guide but found it was not applicable to me as the car had UDS so only advanced measuring was available, measuring blocks is greyed out. I could find 2 values, snapshot Transmission Fluid Temperature. there were 2 different ones, they read 17 and 24c. the value did not change after a drive. is this the correct id to read? the control module temperature changed and was about 77c at one point. But I could not confirm the fluid temperature was between 30 and 60c, so I was unable to go ahead with the basic setting. Any help to read this temp value would be much appreciated. thanks all
Please post an Auto-Scan so people can see exactly what TCM this gearbox has and what software is in it.
SirSkeedle
Manchester, UK
C?ID=426705
Sorry, didn't realise the scan would be helpful here. Will get it uploaded soon as I have access to laptop. thanks !
SirSkeedle
Manchester, UK
C?ID=426705
Wednesday,08,September,2021,16:35:19:04053
VIN: VSSZZZ5FZJR090057
Mileage: 85534km-53148mi   Repair Order: 08092021-2
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 4B 52 5F D6 D7
VIN: VSSZZZ5FZJR090057   Mileage: 85534km-53148miles
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 H    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 0B2500122424010B2000
   Shop #: WSC 00049 770 00173
   ASAM Dataset: EV_ECM18TFS0208V0906264H 001007
   ROD: EV_ECM18TFS0208V0906264H.rod
   VCID: 41DF4E7C31093753C0D-8014
Readiness: 1110 0001
   Part No SW: 0CW 300 042 H    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1604
   Revision: 00005008    Serial number: CU501711157513
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 3B233C9453E55D839A1-806E
   Part No SW: 5Q0 614 517 CT    HW: 5Q0 614 517 AG
   Component: ESC           H62 0653
   Revision: 00000000    Serial number: 63417000000916
   Coding: 20EE8A923429216C8777060560CA2804512C84E16006147530425074C203430B00000012121212B835351919323200
   Shop #: WSC 00049 770 00105
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 05579A6C65A1DB73BC5-8050
   Part No SW: 5F0 907 044 AK    HW: 5F0 907 044 AK
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 00100004200114011005000000101020
   Shop #: WSC 00049 770 00203
   VCID: 6FBBD8C4571DF123669-803A
   Air quality sensor:
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001734501090
   ROD: EV_BCMBOSCH_018.rod
   VCID: 094F965C49B9BF13D8D-805C
   Subsystem 1 - Part No SW: 5F2 955 119 A    HW: 5F2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 171029  041 0574
   Serial number:         171109131534
   Coding: 0BC5FD
   Serial number: 20931544X81A955555A0
   Coding: 00005D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1726306J2
   Serial number: 00000000000039889095
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419617321
   Coding: 0600040011
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000_009_AU37.rod
   VCID: 49CF565C0939FF1318D-801C
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 3500008151FF8428949C814500300400000000000000000000
   VCID: 3C213F8856EB5ABB93B-8068
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4PQLAAGI
   Coding: 98CCC000000000005C0000CC008800000065
   Subsystem 1 - Part No SW: -----------    HW: 454 001 711 17
   Serial number: 357000000005E164AA2O
   Subsystem 2 - Part No SW: -----------    HW: 454 002 311 17
   Serial number: 35800000000A8748DA2Z
   Subsystem 3 - Part No SW: -----------    HW: 454 802 111 17
   Serial number: 3510065914B120000005
   Subsystem 4 - Part No SW: -----------    HW: 454 802 111 17
   Serial number: 352005C4F4212000000C
   Subsystem 5 - Part No SW: -----------    HW: 454 802 511 17
   Serial number: 35500FBCC7812000000
   Part No SW: 5Q0 953 507 GP    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 06121704221602
   Coding: 1410
   VCID: 0A4DA9504CBFB40BD17-805E
   Part No SW: 5F0 920 950 E    HW: 5F0 920 950 E
   Component: KOMBI         303 0310
   Coding: 27A401082B80060001886A011000000080000000
   VCID: 290FF6DCA979DF13F8D-807C
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007165843
   Coding: 030100F42F085900EB0002481C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_AU37.rod
   VCID: 3829239862D3769B773-806C
   Generator:
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Serial number: 000000000I0573211017
   Coding: 012000
   Serial number: 758860000017121007C9
   Serial number: 0000292845567
   Coding: 00140220DC01040000001000
   VCID: 47CB50641F2D09630E9-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Serial number: 00000000000017865984
   Coding: 2D0000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 81170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B3D4B43B35D5C3821-8026
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 07111710803426
   Coding: 000000070100094E00000900000000000000000000000000000000000000
   VCID: 72BDD1B0442FDCCB897-8026
   Serial number: 0000292548121
   Coding: 00140220DE01040000001000
   VCID: 46D55D601827106BF5F-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Serial number: 00000000000017794159
   Coding: 350000
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 858 B    HW: 5QA 035 858 B
   Component: MU-S-ND-ER    H41 0468
   Serial number: SEZAZ2T1287006
   Coding: 04738001D70A000011110101008808002F0101C601200500C6
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SK25.rod
   Subsystem 1 - Part No SW: 5F0 919 606     HW: 5F0 919 606
   Component: ABTm-2_8-CR  H41 1042
   Serial number: SEZ8Z9T6C020WD
   Subsystem 2 - Part No SW: 6P0 919 866 AB    HW: -----------
   Component: ECE1 2018  --- 0910
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EA5F580007788ABFDF-802A
   ROD: EV_LEDPLUSRightKEBODVW416.rod
End----------(Elapsed Time: 01:29, VBatt start/end: 12.1V/12.0V)-----------
OK, with this transmission, there no real-time "fluid temperature", just like in this thread here:
SirSkeedle
Manchester, UK
C?ID=426705
Awesome! And i suppose this makes sense, but also, why haha. But im struggling to understand what the final outcome was for this.
Which one are we looking at for basic setting, fluid temp?
ENG100625 -- Coolant temperature (°C)
IDE00102-ENG102028-Control Module temperature
ENG122361-Temperatur Hybrid
Also, over on that post, Eric mentions about starting the car from cold in P and letting engine warm up naturally, will the transmission heat up to over 60c quite quickly? My customer is taking a 15 minute drive to me to have the work done. Thanks so much again!
I don't have a car with a transmission like that to look at, but if I did, I would watch all three of them. Based on what others have reported they should all be reasonably close.
DGMotors
C?ID=57532
On these the ECU monitors the fluid temp in the mechatronic unit and not the gearbox oil temp, I know it states it must be at 30C and have run the engine to full temp leave for 30-60 mins to soak into gearbox and do basic settings etc. but have also found the ECU doesn't seem to care what temp the gearbox is at I have done loads of basic settings with under temp and all completed fine, if they don't complete most times something else is wrong.
  • Informative
SirSkeedle
Manchester, UK
C?ID=426705
Okay, i understand. Do we know how important the temperature is, for example if it was a little too low/high, how would this affect the basic setting? Would it actually still go ahead or would it fail? Thanks again
SirSkeedle
Manchester, UK
C?ID=426705
Okay, so the customer is approx 15 minute drive away, his engine was upto temp by the time he was with me. Would this be suitable to start the basic setting at? I can check the above temps for eg control module temp to ensure it is 30-60. Do you know if it will continue through basic setting if the temp is actually out of these values? thanks
DGMotors
C?ID=57532
It will start fine under 30c. Never managed to get the temp anywhere near 60c - so cant say if it will start over 60c
Just try the basic settings - if it fails it will give you code
255 - Failure code - 00
Make a note of the failure code and then you can work out what is wrong
SirSkeedle
Manchester, UK
C?ID=426705
Okay, that is perfect! Something else whilst i am here. Does anybody know of any set out instructions for this procedure? Ross tech have a page provided for the 7S DSG, but only covers meas blocks and not UDS cars with only adv meas. I am having to work this out via instructions for another gearbox i believe. Thanks again
