Cold air from vents mk7
harvard
Pirate
Walking the Plank
Poland
I have bought a used mk7 2014 from DE. The problem is tha when temp. set to 22-24 cold air goes ou from the vents. After driving about 50km still cool air.I scanned vcds and got as follows
There is aux heat im my car so if I turn it on there is hot ait just after sturtup but a few km later cold air comes out again.
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 00120104202100001000000000000002
   Shop #: WSC 00028 028 00024
   ROD: EV_ACManueBHBVW37X_SK48.rod
   VCID: 3C51072DB76AC7A1FF-8068
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
                    Mileage: 26679 km
                    Date: 2017.01.25
                    Time: 08:47:59
                    Voltage terminal 30: 14.2 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.value: 1
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
Don't know where to start my diagnostic from.
mk7 1.6 tdi 105 77kw
DGMotors
C?ID=57532
Can you please provide a full autoscan - as we need more information about the car. Also does it have Mit Silikat on the coolant bottle?
harvard
Pirate
Walking the Plank
Poland
Removed.  Data from a clone/pirate copy of VCDS is not acceptable here.
I checked that bag in the coolant container it is in one piece (not torn and took it out for safety reason). But sth strange happens when running at night with lower temp. outside, temp from 27 to HI gave worm to very hot temp. at HI. At below 27 it is still not worm.
Funny... Scan in first post appears to have been made with a legitimate interface, but has a totally different HVAC module than the one in your Auto-Scan (AC Manuell vs. Climatronic).
Post an Auto-Scan from your car using a legitimate interface or off to the Hall of Shame you go.
harvard
Pirate
Walking the Plank
Poland
Don't know what the problem is. I bought vcds on alixpress as many vag users do. I know it is not the genuine one but the money issue is the case.
HI, I'm curious, how much did the alixpress "vcds" cost ? (funds, how much) ?
You are always welcome here ..... so long as you use a legitimate VCDS interface. Perhaps you could use a friends or other individuals genuine interface? $199.00 USD.
