Engine Vibration at Idle and Juddering Pulling Away
Ronnie.Vincent
C?ID=389395
Hi, my VW Sharan 2017Y has developed an engine vibration at idle and juddering on pulling away? Undertook a VCDS scan and apart from the TPMS errors that were down to a slow puncture which has been repaired the only other faults are 18826 Coolant Pump for Intercooler and 03789 Terminial 75 Limp Mode Active?
Wondered if the Coolant Pump issue would cause this? I considered it may be an injector problem or possibly the dual mass flywheel starting to fall apart?
Sunday,05,September,2021,14:53:57:08428
VCDS Version: 21.9.0.1 (x64)  HEX-V2 CB: 0.4555.4
Data version: 20210824 DS330.0
VIN: WVWZZZ7NZJV007025   License Plate: FN67 ORU
Mileage: 244350km-151832mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 13 15 16 17 18 19 25 42 44 46 4C 52 53 5F 61
          62 69 72
VIN: WVWZZZ7NZJV007025   Mileage: 244350km-151832miles
Address 01: Engine (J623-DFMA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 HJ    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1628
   Revision: 8AH20---    CVN: 61FB8A94B866C2AD
   Coding: 0119001A043501082000
   Shop #: WSC 53961 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906016HJ 001003
   ROD: EV_ECM20TDI01104L906016HD_001_VW36.rod
   VCID: 78A9EF25C251450B9F2-802C
   VINID: 9E69EAAAA1DEA9A9800070021452E6CF9A
18826 - Coolant Pump for Intercooler
          P190D 00 [032] - Mechanical Malfunction
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CL    HW: 5N0 614 109 CL
   Component: ESC-EBC460iV1 H14 0014
   Serial number: A01IWR7
   Coding: 11F0449A8920C2730877880222C89143103117F0000B4085
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 77ABEC19CF4F4A73968-8022
0763 - Tire Pressure Warning
          C102D 00 [136] - -
                    Fault Frequency: 19
                    Reset counter: 133
                    Mileage: 214290 km
                    Date: 2020.09.04
                    Time: 16:02:25
                    Additional_Codes: 26 C1 00 0D 84 7F 00 48 02
                    DTC: 00 02 FB
                    Additional2: 00 05 01 08 05 22 15 00 15 00
0764 - TPMS Display
          C1146 F0 [136] - Not Available
                    Reset counter: 78
                    Mileage: 237726 km
                    Date: 2021.06.27
                    Time: 06:14:09
                    Additional_Codes: 1B 7C 00 0D 8C 7F 00 48 02
                    DTC: 00 02 FC
                    Additional2: 00 0A 01 08 05 22 A2 00 A2 00
   Part No SW: 7N0 907 044 AS    HW: 7N0 907 044 AS
   Component: Clima-Sharan  H04 0606
   Revision: 00001K06
   Coding: 021000C449
   VCID: 015F82C1918B04C3A8C-8054
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0186
   Revision: BC122001
   Coding: 40180A3F8925E1C0408800C09400817403D10008426D29226480C72000C1
   Shop #: WSC 00020 790 00000
   VCID: 45D756D1C5A3E8E3D44-8010
   Subsystem 1 - Part No SW: 7N2 955 119 B    HW: 7N2 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 030617  024 0644
   Serial number: 17060103004531
   Coding: 004DBD
   Component: RLHS  042 0105
   Serial number: S4Y17M06D28H18M56S02
   Coding: 0228BB
03789 - Terminal 75 Limp Mode Active
                    Reset counter: 158
                    Mileage: 243511 km
                    Date: 2021.09.01
                    Time: 12:02:51
                    Voltage: 11.90 V
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39361719100057
   Coding: 0031051101
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372B2C198FCF8A73568-8062
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 2805170440A1AB
   Coding: 00000100FE0739
   ROD: EV_ACCBEGVW361.rod
   VCID: 3635211D88C5737B4DE-8062
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag11H H15 0016
   Serial number: 003PWPDWG6ZF
   Coding: 003148
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 40D947C5DA01CDCBE72-8014
   Serial number: 3493ETS608FF9791DDDR
   Serial number: 3503ETS60971C7A1D9D+
   Serial number: 3513ETS6085C2791D9D$
   Serial number: 3523ETS60331B7A1D9DW
   Serial number: 35540TS603B587F1D9D-
   Part No SW: 5K0 953 569 BC    HW: 5K0 953 569 BC
   Revision: --X01---    Serial number: 20190803200352
   Coding: 1082440008
   Shop #: WSC 01286 386 08256
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7AADF52DFC5D571BE96-802E
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 1641713483301425AD1B
   Coding: 280000
   Part No SW: 7N0 920 970 Q    HW: 7N0 920 970 Q
   Component: KOMBI         H03 1107
   Coding: 410F010800
   VCID: 41DF42C1D10BC4C3E8C-8014
   Part No: 7N0 963 271 G
   Component: Zuheizer        051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0000041
   VCID: 38292F258E51850B5F2-806C
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 240617F1000528
   Coding: 468023
   Shop #: WSC 00000 288 1232291
   VCID: 7BA3F029F3E76E13F20-802E
   Component: IMMO          H03 1107
   VCID: 6A8DC56D8CFDE79B196-803E
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H05 0561
   Revision:             Serial number: 0000263070715
   Coding: 01110620D101411011
   Shop #: WSC 00020 790 12345
   VCID: 49CF5AE1E9BB0C8330C-801C
   Part No: 7N0 909 144 R
   Component: EPS_ZFLS Kl. 275    3501
   Revision: 00H21000
   VCID: 42DD4DCDD88DDFDBF16-8016
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H05 0561
   Revision:             Serial number: 0000263073709
   Coding: 01110420DE01411011
   VCID: 48C95FE5F2B1F58B2F2-801C
   Part No SW: 5K7 035 200 K    HW: 5K7 035 200 K
   Component: MU-S-D-ER     H41 0449
   Serial number: VWZAZ2T5281563
   Coding: 02240800FF00000011111101008808001F0100C60020010003
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2C010375468939AB2BA-8078
   Component: Batt.regelung H56 1682
   Coding: 030F7873
   VCID: 71BFD201A1AB144358C-8024
   Subsystem 1 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 44166F47225831516902
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 K    HW: 7N0 959 794 G
   Component: TSG HL        H06 0561
   Revision:             Serial number: 0000265257031
   Coding: 010004200001411001
   VCID: 4BC360E9E3C71E93020-801E
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000366687497
   Coding: 0100000101000000
   VCID: 323D1D0D642D6F5B616-8066
   Component: TSG HR        H06 0561
   Revision:             Serial number: 0000265257388
End----------(Elapsed Time: 01:33, VBatt start/end: 12.3V/12.3V)-----------
Ronnie.Vincent
C?ID=389395
Strikes me as unlikely.
How does the engine run otherwise? Good at idle? Good under load?
It's a bit rough at idle but once you move up the rev range and increase speed it runs ok, given that it does have 151,000 on the clock. Had the vehicle running at idle and by pushing the clutch pedal up & down you can hear the note of the noise change and the rattle. So at the moment will settle for a problem with the clutch until I get it into my independent VAG Specialist and see what they say in the next couple of days. Fairly confident the engine is not going to disintegrate on me!
Perhaps, at 151K, Throw out bearing ? Let us know what you find.
Vic72
Covington, TX, USA
C?ID=419103
I had my 2010 jetta 2.0 at a volkswagen gagage and listening to it idle there was an extra noise that he said is my fluwheel being somewhat loose and he said sometime the flywheel needs replaces it not just a matter of tighning some bolts and the tranny will need pulled to do it.
JMR
Romania
C?ID=432218
HMC
C?ID=28246
Hi Ronnie.Vincent,
Sounds very much like you have a failing Dual Mass Flywheel, I would not wait too long before getting it replaced.
Regards HMC
