redneckincanada
- Sep 2, 2021
- 10
- 0
- Winnipeg, Canada
- C?ID=210156 (NRRT)
I used these two instructions for the install:
I used this control module: 1K0-953-549-AQ
According to this chart from Ross Tech it should work, right? http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Or do I need to purchase a different control module?
On the bottom of this https://www.vwvortex.com/threads/diy-multi-function-steering-wheel-retrofit.2938601/ the user "Ronin" says to access "Select "44" for the control module ("Steering Assist"). Choose "10 Adaptation" and then read channel "1"
BUT the problem is when I do that I get "ERROR" and cannot make any changes.
Any help or advice on this would be appreciated. Thanks.
DIY: Multi-Function Steering Wheel Retrofit
www.vwvortex.com
VW Jetta-Golf GTI MFSW steering wheel swap or paddle shifter button retrofit
How to swap a steering wheel from the GTI, GLI, or add paddle shifters onto your Jetta, Golf, Tiguan, or Sportwagen
www.myturbodiesel.com
Thursday,02,September,2021,15:41:00:65037
VCDS Version: 21.3.0.0 (x64)
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWGT71K46M849274 Mileage: 138830km-86264miles
01-Engine -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H05--- Serial number: VWZ7Z0F4607131
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 63EB4577A2ABB593BE-8036
Readiness: 0 0 0 0 X
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 00066 000 00000
VCID: 3FA3A9076E83B173FA-806A
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 77D3012706334933F2-8022
00898 - Control Circuit A/C compressor
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 P HW: 3C0 937 049 P
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000471334
Coding: 10018E231004150007140000001400000008730B5C0000
Shop #: WSC 00066 123 12345
VCID: 364DCC2341B9703B29-8062
Component: Wischer 271006 020 0501
Coding: 00065535
Shop #: WSC 00066
9 Faults Found:
Fault Status: 01101100
Reset counter: 175
Mileage: 134259 km
Voltage: 11.10 V
Reset counter: 175
Mileage: 134259 km
Voltage: 11.10 V
Fault Frequency: 218
Reset counter: 175
Mileage: 123877 km
Voltage: 11.40 V
Fault Status: 00111100
Fault Frequency: 45
Reset counter: 214
Mileage: 134259 km
Voltage: 11.35 V
02399 - Control Circuit for Terminal 30 for Interior Illumination
Fault Status: 00111001
Reset counter: 214
Mileage: 138831 km
Voltage: 12.20 V
Reset counter: 213
Mileage: 138644 km
Voltage: 12.40 V
Reset counter: 212
Mileage: 138829 km
Voltage: 11.90 V
Reset counter: 211
Mileage: 138820 km
Voltage: 12.65 V
Fault Status: 00101100
Reset counter: 214
Mileage: 138831 km
Voltage: 12.20 V
Address 15: Airbags
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0002021
Shop #: WSC 01279 785 00200
VCID: 01276FFF58F70783CC-8054
Component: E0221 002 0010
01426 - Controls in Steering Wheel (E221)
Part No SW: 1K0 920 853 K HW: 1K0 920 853 K
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4607131
Coding: 0023403
Shop #: WSC 92703 999 73766
VCID: 3245F033ADD16C1B05-8066
Reset counter: 211
Mileage: 138820 km
Time: 07:27:20
Reset counter: 214
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001068251196
Coding: 3D3F0B4007001002
VCID: 2C79EE4B8FF53AEB4F-8078
Reset counter: 7
Mileage: 123877 km
Time: 01:08:39
01304 - Radio
Reset counter: 7
Mileage: 123877 km
Time: 01:08:43
Reset counter: 213
Mileage: 138644 km
Time: 04:15:53
Reset counter: 211
Mileage: 138820 km
Time: 07:27:20
Reset counter: 212
Mileage: 138829 km
Time: 02:01:39
Component: IMMO 3HL 1610
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 22007001 Serial number: 00000011369003
Coding: 0001205
VCID: 3B5BDD177A9BAD53D6-806E
Fault Status: 01100101
Reset counter: 175
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 3449F62B57C5622B17-8060
Mileage: 138810 km
Temperature: 37.0°C
Voltage: 12.80 V
Voltage: 12.60 V
02546 - Steering Limit Stop
Mileage: 138810 km
Temperature: 19.0°C
Voltage: 11.20 V
Voltage: 11.00 V
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 13900F880106083F2D04058FB0880F0488FC00
VCID: 71C73F3F685717033C-8024
00956 - Key 2
Fault Status: 00110101
Fault Frequency: 9
Reset counter: 202
Mileage: 138714 km
Time: 23:33:44
Reset counter: 212
Mileage: 138829 km
Time: 02:01:40
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 22007001 Serial number: 00000527269001
Coding: 0001204
VCID: 3C59DE0B7F95AA6BDF-8068
Fault Status: 00100101
Reset counter: 215
Address 56: Radio
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000476500
Coding: 0001168
VCID: 3E5DD4036989B87BF1-806A
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000455140
Coding: 0001168
Component: PTC-Element 0404
VCID: 2D7FE34FB4EF33E358-8078
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 01:14)--------------------------
