HEX-NET telling "porkies" after update!!
OK - so this ain't your typical vehicle!
Back-story:
I just updated VCDS SW to the latest release version on my Surface Pro 7 together with an update of the dongle firmware on my trusty HEX-NET. I then connected to my MQB platform test-bench (in Access-Point mode)
My test-bench is a mongrel mix of modules ("Heinz" version to use an Aussie vernacular) - meaning that the modules have been sourced from wherever I could find the cheapest unit at the time of building. Needles-to-say, the set-up is insanely DTC rich because only key modules are connected and lots of sensors are missing - but that's OK. Here's the auto-scan using the SW version just installed:
Friday,03,September,2021,10:00:11:16808
VCDS Version: 21.9.0.1 (x64)  HEX-NET CB: 0.4555.4
Data version: 20210824 DS330.0
VIN: WVWZZZAUZEW015673   License Plate: DV52_HEX-NET
Mileage: 112010km-69599mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 09 16 17 19 42
VIN: WVWZZZAUZEW015673   Mileage: 112010km-69599miles
   Part No SW: 5Q0 937 084 CD    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H34 0236
   Serial number: 01001624900723
   Coding: 000000000000000000000000000000000000000000000000000000000020
   Shop #: WSC 12345 123 61029
   ROD: EV_BCMBOSCH_017.rod
   VCID: FCB4B19877AA4F699E-80A8
24 Faults Found:
395273 - Control Circuit for Signal Horn
          B1344 14 [009] - Open or Short to Ground
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
460041 - Heated Rear Window
          B1265 14 [009] - Open or Short to Ground
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert->Keine Anzeige]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
528405 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
528917 - Databus
          [ESP_21 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
533269 - Databus
          [ESP_20 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:54
539157 - Databus
          [Klima_12 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
541973 - Databus
          [Motor_04 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
542229 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
542485 - Databus
          [Motor_18 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:53
549141 - Databus
          [TSG_BT_01 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
550420 - Databus
          [TSG_FT_01 Datenbus empfangener Fehlerwert]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:54
554517 - Databus
          [ESP_05_alt aktiv]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
555029 - Databus
          [ESP_21_alt aktiv]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
555285 - Databus
          [LWI_01_alt aktiv]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
555541 - Databus
          [Motor_12_alt aktiv]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
556053 - Databus
          [LH_EPS_02_alt aktiv]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
558101 - Databus
          [Airbag_02 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
559125 - Databus
          [Motor_07 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:53
560661 - Databus
          [LDW_02 Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
560917 - Databus
          [Areaview_01_alt Datenbus fehlende Botschaft]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
568836 - Databus
          [LWR AFS - Kein Signal/Kommunikation]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
947204 - Control Module for Wiper Motor
          U10A3 00 [009] - No Communications
          [Scheibenwischermotor Fahrerseite->kein Signal/ Kommunikation]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
          U1101 00 [009] - Active
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
   Part No SW: 8V0 953 521 E    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 08121100010724
   Coding: 0101
   VCID: BC347198372A8F69DE-80E8
227387 - Windshield Wiper/Washer Switch
          B1149 13 [008] - Open Circuit
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:14:46
                    Operating time: 20880 min
                    Terminal 30 power supply: 12.8 V
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
                    FF U Wischer AD value: 201
                    FF U Wish Wash AD value: 163
                    FF U Intervall Poti AD value: 61
                    FF U MFA AD value: 252
   Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
   Component: KOMBI         252 2210
   Coding: 2211020000000808010A0000000000
   VCID: A81CBDC8D3B233C9AA-80FC
10 Faults Found:
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:00:03
9453073 - Fuel Level Sensor 1
          B103E 1A [008] - Resistance Too Low
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:04:21
15361024 - Component Protection
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
16776968 - Databus
          [ESP_24 keine Kommunikation]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
9456433 - Key
          B104B 31 [009] - No Signal
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.12
                    Time: 00:00:02
9456681 - Key
          B104C 29 [009] - Implausible Signal
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:12:12
16776993 - Databus
          [ESP_21 keine Kommunikation]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1109
   Revision: --------    Serial number: 0000073193
   Coding: 0000003800086400EF0006481C0F00000001000000000000000000000000
   GVL: 0150100000000000000400000000000000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: B3265AA41A7440110F-80E6
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:40:11
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
66304 - Databus
          U1124 00 [008] - Additional Installations Detected
          [Mehrverbau CAN]
                    Fault Frequency: 16
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:00:01
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: OFF
66565 - Diagnostic Databus
          U1202 00 [008] - Malfunction
          [Bus defekt CAN-Diagnose]
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:31:10
                    Terminal 30 power supply: 11.5 V
                    Terminal 15: On
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000081671967
   Coding: 001002000001040000000000
   VCID: C4C409784FDAF7A9A6-8090
8 Faults Found:
65571 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Türelektronik Beifahrer (J387)]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:52
65573 - Local Data Bus
          U10BA 00 [009] - No Communication
          [Türelektronik Beifahrerseite hinten (J389)]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:52
65593 - Switch for Central Locking
          B122D 29 [009] - Signal Implausible
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:00:18
65650 - Turn Signal in Exterior Mirror
          B11FD 13 [009] - Open Circuit
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:04:59
458752 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:52
458803 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:52
589825 - Local Data Bus
          [Lokaler Datenbus 1 (LIN)]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:53
65652 - Motors for Central Locking
          B122B 13 [009] - Open Circuit
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:00:18
End----------(Elapsed Time: 00:22, VBatt start/end: 12.8V/12.8V)-----------
What's happened:
When I tried to access the CAN Gateway module directly, I got the message in the first screen below:
When I select "Yes" in the dialogue-box on the first screenshot - VCDS loads the correct EV_GatewLear 006010 from the ASAM dataset as shown for the hex19 module in the auto-scan above
When I select "No" on the first screenshot, the remaining 2 x screenshots eventuate
If I use my HEX-NET2 which I also updated (again in AP mode) - none of the above happens; the dongle works perfectly on my test-bench
Now, as I have said - the modules on my test bench came from various places and when I read the VIN on the hex19 module, it is different to the VIN on the auto-scan (which comes from the VIN that is in the hex17 module), and CP errors abound. And in truth, the little white-lie in the first screenshot really doesn't matter because its only a test-bench and both dongles work perfectly well on the real car that currently sits in my workshop.
BUT, purley from an intellectual perspective- is the dynamic above explainable? Why does it happen on HEX-NET and not on HEX-NET2?
Eric
HC800000
@Shaun is going to be off until Tuesday, I think.
Eric
HC800000
In the meantime, maybe you can explain more clearly what you did.
What was the exact sequence of things? Autoscan first or 19 first? Did you swap for the HN2 without restarting VCDS? Once you had the HN2 connected, what did you do? An autoscan? Go directly to 19? Et cetera :)
Shaun
Does the HN2 talk DoIP when it does this or UDS CAN? An Autoscan with the HN2 would probably be helpful.
  1. Autoscan first or 19 first?
    From memory-No. Because I have so many DTCs on the test-bench, there usually is no useful information for me in the auto-scan report. However, as is my normal practice - I did "Test" the dongle connection from the "Program options" screen as my first step. So, I went directly to the "Select Control Module" screen and selected the hex19 module from there. It was only after getting the odd message that is in my first screenshot that I ran the auto-scan report - I really wanted to see how HN1 reported the hex19 module. And to be clear - I did start an entirely new VCDS session after updating the 2 x HEX-NET dongles.
  2. Did you swap for the HN2 without restarting VCDS?
    I can't be certain, but I don't think that I closed the VCDS session before starting again with HN2 connected. However, I can remember re-testing the HN2 connection in the "Program options" screen again before proceeding.
  3. Once you had the HN2 connected, what did you do? An autoscan? Go directly to 19? Et cetera :)
    I didn't create an auto-scan with HN2 connected - just confirmed the different dynamic, then closed the VCDS session
Eric: Hi - my responses embedded into your post above
Shaun: Hi - I didn't intervene with either dongle to force either DoIP, or UDS CAN. So I guess that whatever default protocol that VCDS uses to speak is the language that was used in my session (of course, my humble test-bench doesn't have anything as fancy as DoIP)
Here is an auto-scan made with HN2- as requested:
Friday,03,September,2021,13:41:04:14127
VCDS Version: 21.9.0.1 (x64)  HEX-NET2 CB: 0.4556.4
VIN: WVWZZZAUZEW015673   License Plate: DV52_HEX-NET2
   VCID: FCAA1FB8B668951B7BA-80A8
25 Faults Found:
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [009] - No Release by Immobilizer
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:00:19
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
          U1014 00 [009] - -
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
528405 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
528917 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
533269 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:54
539157 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
541973 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
542229 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
542485 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:53
549141 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
550420 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:54
554517 - Databus
          [ESP_05_alt aktiv]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
555029 - Databus
          [ESP_21_alt aktiv]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
555285 - Databus
          [LWI_01_alt aktiv]
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
555541 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
556053 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
558101 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
559125 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:53
560661 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
560917 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
568836 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:52
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:04:49
   Coding: 0101
   VCID: BC2ADFB8F6E8551B3BA-80E8
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.13
                    Time: 00:14:46
                    System status: 30
   VCID: A80213E81270E9BB4F2-80FC
10 Faults Found:
          B2010 00 [009] - -
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:00:03
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:04:21
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
16776962 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
16776968 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
16776971 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
16776988 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
9456433 - Key
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.12
                    Time: 00:00:02
9456681 - Key
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:12:12
16776993 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:36:00
   VCID: B338F484DBB69A63EA0-80E6
          U0100 00 [008] - -
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:40:11
                    Terminal 15: On
66304 - Databus
          [Mehrverbau CAN]
                    Fault Frequency: 16
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:00:01
                    Terminal 15: OFF
                    Reset counter: 23
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:31:10
                    Terminal 15: On
   VCID: C4DAA7588E182DDB43A-8090
8 Faults Found:
          U1111 00 [009] - -
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:52
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:52
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:00:18
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:04:59
458752 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:52
458803 - Databus
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:52
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:06:53
                    Reset counter: 238
                    Mileage: 112010 km
                    Date: 2016.01.11
                    Time: 00:00:18
End----------(Elapsed Time: 00:23, VBatt start/end: 12.8V/12.8V)-----------
@Eric / @Shaun : Update!
Galvanized into action by @Eric interest about the sequence of steps (which I thought to be an infinitely insightful question) - I tested his hypothesis and bingo, it does seem to matter!!
With further testing, the dynamic is now repeatable and it's the same with both HN1 & HN2 - and it seems to apply to ALL 5 x modules on my test-bench (even the hex17 module which has the same VIN as recognised in the auto-scan).
It appears that if I start a VCDS session without first making an auto-scan, the VIN error message appears when attempting direct control/access to a module. However, if I precede access to any of the modules with an auto-scan - normal operation happens!!
I have no idea why -but as I said, it's just a test-bench !!
Eric
HC800000
It's almost as if that VIN dialog was trying to tell you something, isn't it? ;)
Simple. The HEX-NET or HEX-v2 is supposed to retrieve the VIN over OBD2 at power-up, and VCDS will then rely on that. Not having an engine on your test stand, you are defeating that process (no, we can't make an autoscan at power-up to scour for a VIN in people's test stands, that would take too long). When you do your autoscan, and VCDS sees the HEX-NET/v2 is unable to provide a VIN, it will try whatever it can to get a VIN from the modules as it's scanning them. (New in 21.9 is that we will no longer be making assumptions based on part numbers if the VIN is missing, and will inform the user with the aforementionned dialog on individual module connection instead). If VCDS succeeds in its own VIN retrieval, it will then "inform" the interface of the VIN it found, and that should stay persistent until the next car-side power event. The newly found VIN should also stay persistent in VCDS under some conditions (if it recognizes it's the same car), which is why I asked if you had restarted VCDS before making that 'porkies' statement :)
@Eric : Thanks again for the insight - I wasn't aware that the VIN discovery process was altered in SW ver 21.9 (your response also explains the sudden existence of dialogue box containing the VIN message - which I hadn't recalled seeing before).
In retrospect and having understood your explanation, I'm now of the belief that my totally scurrilous "porkies" accusation was greatly exaggerated!! I shall repent and do penance for my sin (only kidding - I no longer have Catholic guilt and I no longer believe that the Pope is inflammable!) :D
