2006 Golf RCD330 Retrofit problems...
Alex_
C?ID=382493
Hello, about a year ago I fitted a Pioneer SPH-DA250DAB radio to my GTI (all of the steering wheel controls worked as they should) however over the year I realised I wanted something that looked like it was meant to be there unlike an aftermarket unit so I ordered an RCD330 radio and patiently waited for it to arrive.
Once it arrived I installed it and it worked well apart from my steering wheel controls no longer worked.
Next I decided to change the Canbus module to a revision L one because I had a revision F module and I'd heard about the battery drain problems.
So after checking the old revision F modules Long coding I fitted the revision L module.
After an error with the Long coding due to the length of code being different I discovered I needed to used the Installation list instead. Now I've gotten to the point where I'm pretty sure I have ticked all of the boxes in the Installation list that need to be ticked.
However when I perform an Auto-Scan I keep getting a fault code "01317" for address 56 - Radio and my steering wheel controls proceed to not work like they did with the Aftermarket radio.
Thursday,02,September,2021,14:23:19:58439
VIN: WVWZZZ1KZ6W163698   License Plate: T40YLX
Mileage: 174980km-108727mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZ6W163698   Mileage: 174980km-108727miles
   Part No SW: 1K0 907 115 J    HW: 1K0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZ7Z0F3618449
   Coding: 040300031C070160
   Shop #: WSC 00191 264 15243
   VCID: 2D070EA7511F7A13145-8078
Readiness: 0110 0100
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000602220876
   Shop #: WSC 01279 785 00200
   VCID: 1471BB43D275CBDB3BB-8040
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0004738
   VCID: 71BFD2D78DA75EF370D-8024
   Part No: 1K0 907 044 BE
   Component: ClimatronicPQ35 090 0808
   VCID: 6B83C0BFAF8BB4234A1-803E
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000005517454
   Coding: E50D8E2700041521641400641400000000097F0764
   Shop #: WSC 12345 785 00200
   VCID: 2B0300BF6F0B74230A1-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00207646
   Shop #: WSC 12345
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 38 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD09ZR6.
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3B2330FF9F6BE4A39A1-806E
   Subsystem 1 - Serial number: 6332MSME0E5F1B6AX
   Subsystem 2 - Serial number: 6342MSME1041663D6
   Subsystem 3 - Serial number: 6352QSME0B22352FH
   Subsystem 4 - Serial number: 6362QSME09541C5FT
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0013142
   VCID: 77ABECCFE3C300C3BE9-8022
   Part No: 1K6 920 962 D
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0001403
   Shop #: WSC 00011 067 57207
   VCID: 323D1DDB482125EB497-8066
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K081080A67
   Coding: ED807F060006020001
   Shop #: WSC 06314 123 12345
   VCID: 303917D3462D17FB3F3-8064
   Component: IMMO            VDD 4312
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2374
   Coding: 0000692
   VCID: 363521CBA44939CB65F-8062
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.3   D06 1701
   VCID: 34311BC3B2352BDB5BB-8060
   Part No: 1K0 959 433 AK
   Coding: 18C802087F2D8505485FC69010CC
   Shop #: WSC 05946 002 104857
   VCID: 79AFEAF7D5D716B3C8D-802C
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
   Part No: 1K0 959 702 K
   Coding: 0000692
   VCID: 372B2CCFA343C0C37E9-8062
Address 56: Radio (J503)       Labels: None
   Part No SW: -----------    HW: -----------
   Component: Radio         --- 5814
   Coding: 16000440040000
   VCID: 6FBBD4AF97934803669-803A
                    Reset counter: 164
                    Mileage: 174984 km
                    Time: 14:08:14
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2438
   Coding: 0000144
   VCID: 333318DFB73B2CE3421-8066
   Part No: 1K0 959 704 F
   Coding: 0000144
Address 77: Telephone        Labels: 1K0-035-729-UNI.lbl
   Part No: 1K0 035 729 E
   Component: CIB PAH  HW 203 SW  0308
   Coding: 0000234
   Shop #: WSC 00000 785 00200
01530 - Radio Mute Switch
            009 - Open or Short to Ground
End----(Elapsed Time: 01:08, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
So my questions are...
Have I coded the revision L module correctly?
What could be causing the fault code for 56- Radio?
To get my steering wheel controls to work do I need to fit one of these MFSW adapters? (https://www.ebay.co.uk/itm/203043034328?hash=item2f464ed4d8:g:7R0AAOSwD0dfBe66)
Thank you for your time and thoughts, Alex.
Spacewalker
Poland
C?ID=159607
what I know is that cluster (Yes, cluster) is reponsibile for radio control via MFSW
there was never confirguration with MFSW and low Line cluster
After market radio is just for P&P , and forget about any diagnostic
you can not Remove adr 56 from CAN GATEWAY
VW never made a car without radio, seems for me that radio is a minimum quipment
Alex_
C?ID=382493
Not sure I completely understand...
So from what you've said, I understand that the RCD330 is an aftermarket radio therefore the fault code cannot be removed because of the radio being unable to communicate with the MFSW via the instrument cluster, correct?
What I don't understand is that you're saying I have lowline clocks? I was under the impression they were midline as they show me my Fuel economy, fuel range, trip, speed warning and ignition on time?
But thank you for clearing up the cause of the fault code and I am no longer worried about it.
Spacewalker
Poland
C?ID=159607
middle or low line - both crap for me
middle is not operate via MFSW too
swap to Highline
Tharkhold
Canada
C?ID=311665
RCD330 is not an aftermarket radio at all, it's an original VWAG item that's not available in most of the world. It will work with all the other car systems via canbus...
I've had both a 330 and now a MIB2 unit from a 2020 NAR passat in my PQ-based car, and can still use the MFSW buttons with a midline/highline cluster; it just won't show information on the cluster itself.
I would say to get a much newer gateway from aliexpress to remove that part from the potential problem source. I have a 7N0 907 530 AR unit.
You definitively don't need a '56' radio in a car... I 'only' have a '5F' unit, no '56', and no issues.
This is a recent(ish) autoscan of my 2010 mk5 jetta sedan with mk6 electronics with the 'AR' gateway:
Tuesday,24,August,2021,20:50:59:50436
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 21.8.0.0 (x64)  HEX-V2 CB: 0.4553.4
Data version: 20210731 DS330.0
VIN: 3VWHJ7AJ9AM130127   License Plate:
Mileage: 182820km-113599mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F 62 72
VIN: 3VWHJ7AJ9AM130127   Mileage: 182820km-113599miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AM    HW: 1K0 907 115 AA
   Revision: AAH11---    Serial number:
   Coding: 0403010A18070160
   Shop #: WSC 00066 000 00000
   VCID: 71BCDDA0ADA54AC35CD-8025
   VINID: 0E69D868745A2517410C00421C0EF0B2DF
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 114B600C492500FA880C06E692200041340000
   Shop #: WSC 00066 123 12345
   VCID: 78AAE084C2DF1B8B9B3-802D
   Part No SW: 3C8 907 336 AC    HW: 3C8 907 336 AC
   Revision: 00009001
   Coding: 0000000002
   Shop #: WSC 00066 000 00149
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6E86C6DCB01B553B41F-803B
   Part No SW: 5K0 937 086 E    HW: 5K0 937 086 E
   Component: BCM PQ35 M    011 0029
   Revision: BJ011001
   Coding: 27210B3F902F3EE4004800814000978C0768008650008D205C8040000000
   VCID: 36362EBC884B2DFB49F-8063
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 22041  21  0512
   Coding: 009395
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 09 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM02THSH
   Coding: 0012345
   VCID: 6E86C6DCBC9B553B41F-803B
   Subsystem 1 - Serial number: 6332MSME506530752
   Subsystem 2 - Serial number: 6342MSME5115056D8
   Subsystem 3 - Serial number: 6351HSME20544F412
   Subsystem 4 - Serial number: 6361HSME206D637BG
   Subsystem 5 - Serial number: 63727SME21096136V
   Subsystem 6 - Serial number: 63827SME21095645-
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0000731
   VCID: 76B6EEBCC4CB6DFB89F-8023
   Subsystem 1 - Part No: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H31 0037
   Coding: 00000130
   Part No SW: 1K8 920 861 B    HW: 1K8 920 861 B
   Component: KOMBI         H05 0308
   Coding: 070C00
   Shop #: WSC 00066 123 00149
   VCID: 303A18A46AAF03CB133-8065
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 1005201500F108
   Coding: 351002
   Shop #: WSC 01279 785 12345
   VCID: 005A88649A0F534BA33-8055
   Component: IMMO          H05 0308
   VCID: 6A8ECACC8CF3B91B1D7-803F
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0000721322
   Coding: 0004F5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 2708F3F85F614473C29-8073
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004822845
   Coding: 000490
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 313C1DA06D250AC31CD-8065
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0000718501
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide_VW32.rod
   VCID: 280AF0C4527F4B0BCB3-807D
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000004810173
   Coding: 000490
   Part No SW: 5C0 035 200 F    HW: 5C0 035 200 F
   Component: MU-S-S-US     H61 0605
   Serial number: VWZAZ2W1463244
   Coding: 02140100BE00000001220001001828009F0100C40020010002
   Shop #: WSC 06050 062 00200
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 186AC004E21FFB8B7B3-804D
End----------(Elapsed Time: 01:00, VBatt start/end: 12.1V/12.1V)-----------
Tharkhold
Canada
C?ID=311665
FYI this is a lowline mk5 cluster:
iu
This is a 'midline' mk5 cluster screen from my 2008 Rabbit with an RNS315 and working GTI MFSW:
(I dont think any NAR mk5 rabbits got the lowline.)
Here I upgraded to a Highline mk5 cluster, mk6 MFSW and the 330 radio:
(note that the 330 WILL NOT display any kind of information on the MFD, regardless of trim/options/coding!)
This is the '200F' MIB2 unit in my 2010 Jetta (same as the autoscan above), and this will display stuff in a highline cluster (might have to have a mk6/white one though...).
dieseltje
The Netherlands
C?ID=148044
Steeringwheel issues is because of old lin signal.
In passat b6 eu version you have steeringwheel electronics that supports both lin signals. The lin 2.0?? Supports RCD330 and Discover Media PQ systems.
There are special converter boxes so 8 button steeringwheel also works with RCD330
On Aliexpress you can find those as steering wheel controle adaptor for rcd330
Spacewalker
Poland
C?ID=159607
hmm... that autoscan you post is not from picture you post
so what is a proper car to look ?
I have my own solution for those who use a low line , old gen cars, with latest gen radio, etc.
but this is require additionall module
