Hi Folks,
I am getting repeated P0442 DTC on my 2009 Mk4 City Golf.
Please see below:
Mode 03: Emission related fault codes
Address 7E8: 1 Fault Found:
P0442 - EVAP Emission Control Sys: Small Leak
Thursday,30,April,2015,17:17:33:24871
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
The full story is that the car was in a fender bender and took a smack in the left rear corner. This DTC showed up soon after that. The body shop that repaired the car said that they found a cracked canister, and that they replaced it. The code didn't come back immediately, but it did come back. I should also note that the car has also become a bit cantankerous to fill with gas...I have to feed her slow now.
Anyway, my questions are: How do I troubleshoot this? What am I looking for, and where? Any suggestions? Am I looking under the car, or inside the quarter panel in the trunk/hatch area? Any advice on where to start would be appreciated. I'm fine with wrenches and/or a multi-meter, but this one is new on me.
Thanks,
Rem
Please see below:
Thanks,
Rem
Thursday,30,April,2015,17:27:53:24871
VIN: 9BWEL41J494016080 License Plate:
Mileage: 152360km-94672mi Repair Order:
76
VIN: 9BWEL41J494016080 Mileage: 152360km-94672miles
Address 01: Engine Labels: None
Part No SW: 06A 906 012 AB HW: 06A 906 032 RF
Component: 2,0L 85KW G 0802
Revision: 00ÿW Serial number: 000-00000.00.
Coding: 0000001
Shop #: WSC 00000 785 00200
VCID: 5CB7BB279C4AA0C1527-5140
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
VCID: 3365309B51544FB9A3D-5140
Part No: 1C0 909 601
Component: 1L AIRBAG VW51 0011
Coding: 12620
VCID: 5DB1B623D050A9C9259-8008
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1JE 920 807
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 11332
VCID: 7AFBDDBF66BE7EF120B-5122
9BWEL41J494016080 VWZ7Z0H0243276
Part No: 6N0 909 901
Coding: 00006
VCID: 70EFFF9730C234A19EF-5106
Part No: 1C0 959 799 C
Component: 8C Komfortgerát HLO 0004
Coding: 00258
VCID: 377D048B152CA3999F5-4AE8
Component: 8C Tõrsteuer.FS KLO 0202
Component: 8C Tõrsteuer.BF KLO 0202
Component: 8C Tõrsteuer.HL KLO 0202
Component: 8C Tõrsteuer.HR KLO 0202
00912 - Window Regulator Switch; Front Left (E40)
End-------------------------(Elapsed Time: 06:14)--------------------------
