ACC Fault code after changing ABS coding. Help?
MK7.5
C?ID=402753
I was messing around with 03 ABS coding, specifically byte 23 (changed from 77 to 7C, then to 76 and eventually back to 77). Now I have a fault stored in 13-Auto Dist. Reg, and my ACC isn't working. I didn't change anything in the ACC module, so not sure what happened.
Saturday,28,August,2021,13:00:33:43090
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVA7AU1KW224276   Mileage: 25007km-15538miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-DLRA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---
   Coding: 092500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
   ROD: EV_ECM20TFS0208V0906259Q.rod
   VCID: 4EC56429B05DA05B4DF-801A
Readiness: 1110 0101
   Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 2411E6818E517A0BCBB-8070
   No subsystems:
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 61059000000609
   Coding: 01FA6BA1502221704579030760C96980D60A84A2C0069677384250D8D2A84B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 06559C0918ADA81BB5F-8052
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6103279128
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D3451D6B1F5D33D21-8016
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000110500001211140A
   VCID: 6D87C3A51D1B7B43545-8038
   Air quality sensor:
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 01001915701239
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0B43AD3D03CFD573EA1-805E
   Component: WWS    190523  043 0551
   Serial number:         190529040911
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0205
   Serial number: S7Y19M06D18H23M45S55
   Coding: 0008DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000008061904220204
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418319168
   Coding: 0471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4CC16E214641924B23B-8018
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 330047C159FFC728949C810580401600000000000000000004
   VCID: 44D146016E115A0BEBB-8010
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 167
                    Mileage: 25007 km
                    Date: 2021.08.28
                    Time: 12:57:47
                    Control Module temperature: 64 °C
                    Voltage terminal 15: 11.9 V
   Serial number: 28051941350748
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382922F122D90EEB773-806C
   Serial number: 003GCR0C22G4
   VCID: 47CB510D5F2771130E9-8012
   Serial number: IBH00000000000BKP8VC
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 357000000004F374CD3X
   Subsystem 3 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 358000000003A020FC3I
   Subsystem 4 - Part No SW: -----------    HW: 480 401 906 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001B2EFDF5B5226P
   Subsystem 5 - Part No SW: -----------    HW: 480 401 906 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A6F001345535P
   Subsystem 6 - Part No SW: -----------    HW: 480 401 706 19
   Component: FrontSensor_D  005 6149
   Serial number: 35500019CF001346C853
   Subsystem 7 - Part No SW: -----------    HW: 480 401 706 19
   Component: FrontSensor_P  005 6149
   Serial number: 35600019CF001346746$
   Part No SW: 5G1 920 891 B    HW: 5G1 920 891 B
   Component: KOMBI         403 4191
   Coding: 0BAD301A7F88CF0502886B0B54010000A0000000
   VCID: 2C010EA1E681B24B03B-8078
   Serial number: 06061911603847
   Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85C4A9101D805B6DF-803A
   Generator:
   Component: 0-01-0d-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001188330099222
   Coding: 2DFFFF
   Serial number: 4546471505
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00017.05.19
   Coding: 0001
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000163099011
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1FD5C1A3DFA330D-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0518404430
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2733E50DFB2BC3A45-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0518694848
   Coding: 020111
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SDI2875A
   Coding: 003E13208000040000000000
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000031016617
   Coding: 111000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C213EE116E122CB93B-8068
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05GS0V
   Coding: 12000000008AAA8A000000000000
   Shop #: WSC 07294 004 104857
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E0504A9D09DC05B2DF-807A
   Component: FCM MQB Low   002 0345
   Serial number: 09061910524172
   Coding: 000000050900165206710F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 35372BC535CBF3836C5-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SDR01781
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000031198255
   Coding: 091000
   Part No SW: 5NA 035 026 E    HW: 5NA 035 026
   Component: MU-H-NS-US    H55 1418
   Serial number: A851L0KB000501
   Coding: 027310020000000021220002001808001F0507F401200405DE
   ASAM Dataset: EV_MUHig4CGen2AW7 001081
   ROD: EV_MUHig4CGen2AW7_VW37.rod
   VCID: 392F27F519D317E388D-806C
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJX0573408
   Subsystem 2 - Part No SW: V03 959 806 NG    HW: -----------
   Component: NAR 2021  --- 0081
   Compact disc data bank:
   Component: Gracenote2  --- 3013
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H11 0610
   Serial number: 05021915K12530
   Coding: 0003070000000201002223548150890084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D94A117A09462BCF3-8014
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 190419202209
   VCID: 2F3B19ADD797C953269-807A
0006 - Actuator for Structural Accoustics
          P193A 00 [009] - Open Circuit
                    Reset counter: 167
                    Mileage: 25007 km
                    Date: 2021.08.28
                    Time: 12:57:46
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----(Elapsed Time: 01:59, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
MK7.5
C?ID=402753
Here's an updated scan. A5 fault code as well "no basic setting." ... :( Is this something that I'm going to be able to fix, or do I need to setup an appointment with the dealer for Monday?
Saturday,28,August,2021,14:32:19:43090
VIN: WVWVA7AU1KW224276   Mileage: 25014km-15542miles
   Revision: --H13---
   Revision: 00H06V07
   No subsystems:
   Coding: 132C0C0723
   Revision: 00001K08
   Air quality sensor:
   Coding: 0008DD
   Coding: 0471155811
          C1103 00 [009] - -
                    Reset counter: 167
                    Mileage: 25014 km
                    Date: 2021.08.28
                    Time: 14:29:48
                    Control Module temperature: 67 °C
                    Voltage terminal 15: 12.4 V
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 167
                    Mileage: 25014 km
                    Date: 2021.08.28
                    Time: 14:29:48
   Coding: 303344
   Generator:
   Coding: 2DFFFF
   Coding: 0001
   Coding: 02011103
   Coding: 020111
   Coding: 111000
   Coding: 911F0000
   Coding: 091000
0660 - No Basic Setting
          B2010 00 [009] - -
          [Initial_calibration_missing]
                    Reset counter: 167
                    Mileage: 25014 km
                    Date: 2021.08.28
                    Time: 14:29:48
                    Control Module temperature: 66 °C
                    Outside temperature: 37.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 47.8 s
                    mid: 00 1E
                    Status of camera: System malfunction
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
                    Reset counter: 167
                    Mileage: 25014 km
                    Date: 2021.08.28
                    Time: 14:29:47
End----------(Elapsed Time: 02:01, VBatt start/end: 12.4V/12.4V)-----------
myounus
Northwest UK
C?ID=321059
Your radar sensor is out of alignment. I’d advise taking the car to the dealers for it to be realigned.
MK7.5
C?ID=402753
That fault actually randomlly cleared itself. Now I just have this one and the one I posted earlier for A5. A5 just says it needs a basic setting. Do you know how to fix these 2 faults + the one in A5?
Saturday,28,August,2021,17:58:01:43090
VCDS Version: Release 21.3.0 (x64) Running on Windows 10 x64
                Address 13: Auto Dist. Reg       Labels: 3Q0-907-572.clb
Control Module Part Number: 5Q0 907 572 P    HW: 3QF 907 572 A
  Component and/or Version: ACC BOSCH MQB H11 0682
           Software Coding: 330047C159FFC728949C810580401600000000000000000004
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_ACCBOSCHVW416 002008 (VW37)
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 168
                    Mileage: 25047 km
                    Date: 2021.08.28
                    Time: 17:57:37
                    Control Module temperature: 59 °C
                    Voltage terminal 15: 12.1 V
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 168
                    Mileage: 25047 km
                    Date: 2021.08.28
                    Time: 17:57:37
MK7.5
C?ID=402753
Here's what I have now:
Module 13:
Saturday,28,August,2021,18:24:31:43090
              ASAM Dataset: EV_ACCBOSCHVW416 002008 (VW48)
                       ROD: EV_ACCBOSCHVW416_002_VW48.rod
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 168
                    Mileage: 25049 km
                    Date: 2021.08.28
                    Time: 18:22:05
                    Control Module temperature: 55 °C
                    Voltage terminal 15-Voltage: 12.4 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
Module A5:
Saturday,28,August,2021,18:25:19:43090
                Address A5: Frt Sens. Drv. Assist       Labels: 3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 654 L    HW: 3Q0 980 654 A
  Component and/or Version: MQB_B_MFK     H11 0610
           Software Coding: 0003070000000201002223548150890084000E20012000
              ASAM Dataset: EV_MFKBoschMQBB 002041 (VW48)
          B2010 00 [009] - -
                    Reset counter: 168
                    Mileage: 25049 km
                    Date: 2021.08.28
                    Time: 18:24:02
                    Control Module temperature: 56 °C
                    Outside temperature: 30.0 °C
                    System run time: 37.9 s
                    mid: 00 1E
                    Status of camera: operational
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
myounus
Northwest UK
C?ID=321059
The car needs to have the R242 camera and the j428 re-aligned. Take it to a dealer
