2017 VW Tiguan 4 Motion. Fault after main dealer service.
invernesspl
C?ID=345478
Hi.
My mothers 2017 Tiguan 2.0tdi 4 Motion just had a major service at the main VW dealer. oil, filter, air filter, pollen filter & Haldex service.
After collecting the car, about half hour later the engine management light comes on. I carried out a full scan which is below. I erased the DTC's and only one fault keeps coming back which is as follows:
Thursday,26,August,2021,16:03:43:41168
VCDS Version: Release 21.3.0 (x64) Running on Windows 8.1 x64
                Address 08: Auto HVAC       Labels: 3V0-907-044.clb
Control Module Part Number: 5NA 907 044 M    HW: 5NA 907 044 M
  Component and/or Version: AC Automat    H35 4301
           Software Coding: 0012010420211001110510000010102A
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_ACClimaPrehVW37X 002023 (VW37)
                      VCID: 49CF5E4C29330F4318D-801C
263425 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Reset counter: 216
                    Mileage: 73570 km
                    Date: 2021.08.26
                    Time: 16:03:39
                    Outside temperature: 32.5 °C
                    Voltage terminal 30: 13.2 V
                    System run time-Engine running time: 176 s
                    Air quality status: Malfunction
Is the Air Quality sensor located where the pollen filter is behind the glove box?[/B]
Full scan before erasing DTC's is below:
Thursday,26,August,2021,15:57:33:41168
VIN: WVGZZZ5NZHW403044   License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 52 5F A5
VIN: WVGZZZ5NZHW403044   Mileage: 73570km-45714miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 JC    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3023
   Revision: B4H24---
   Coding: 0119001203271D082000
   ASAM Dataset: EV_ECM20TDI01104L906026JC 004002
   ROD: EV_ECM20TDI01104L906026GQ_004.rod
   VCID: 74B1DFB81E3122AB9BB-8020
8 Faults Found:
20169 - Exhaust Pressure Sensor 1
          P0471 00 [237] - Implausible Signal
                    Mileage: 73256 km
                    Date: 2021.08.25
                    Time: 09:05:04
                    Engine RPM: 0.00 /min
                    Coolant temperature: 90 °C
                    Intake air temperature: 79 °C
                    Voltage terminal 30: 12.800 V
                    Exhaust mass flow of low-pressure EGR: calculated: 1.757
                    Differential pressure ratio: low-pressure EGR: 0.0 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 29.4 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 226.0 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 0.00 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 0.04 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 26.0 hPa
12002 - Diesel Particle Filter; Differential Pressure Sensor
          P2453 00 [237] - Implausible Signal
                    Mileage: 73312 km
                    Date: 2021.08.25
                    Time: 11:46:17
                    Intake air temperature: 78 °C
                    Voltage terminal 30: 12.820 V
                    Particle filter: air pressure sensor 1 bank 1: raw value: -143 hPa
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 0 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: 146 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -143 hPa
                    Outside temperature sensor 1: B1: raw value: 20.0 °C
                    Particle filter: soot mass measured: 0.00 g
                    Particle filter: soot mass calculated: 11.98 g
5158 - Diesel Particulate Filter; Differential Pressure Sensor
          P2456 00 [237] - Intermittent
                    Mileage: 73135 km
                    Date: 2021.08.25
                    Time: 07:24:35
                    Engine RPM: 1970.50 /min
                    Vehicle speed: 103 km/h
                    Intake air temperature: 108 °C
                    Voltage terminal 30: 14.860 V
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 1 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: 50 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -144 hPa
                    Outside temperature sensor 1: B1: raw value: 16.5 °C
                    Particle filter: soot mass measured: -9.99 g
                    Particle filter: soot mass calculated: 5.97 g
19226 - Particulate Trap Bank 1
          P2002 00 [101] - Efficiency Below Threshold
                    Mileage: 73367 km
                    Date: 2021.08.25
                    Time: 16:15:51
                    Engine RPM: 1772.00 /min
                    Normed load value: 42.4 %
                    Vehicle speed: 60 km/h
                    Voltage terminal 30: 13.380 V
                    Exhaust mass flow of low-pressure EGR: calculated: 4.801
                    Differential pressure ratio: low-pressure EGR: 43.4 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 290.2 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 490.0 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 50.28 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 39.27 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 291.0 hPa
31489 - Differential Pressure Sensor for DPF
          P154B 00 [032] - Faulty
                    Mileage: 73328 km
                    Date: 2021.08.25
                    Time: 12:53:19
                    Intake air temperature: 70 °C
                    Voltage terminal 30: 12.980 V
                    Unlearning counter according OBD: 37
                    Engine status: COENG_FINISH
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
31490 - Differential Pressure Sensor for DPF
                    Mileage: 73328 km
                    Date: 2021.08.25
                    Time: 12:53:19
28991 - No Communications with NOX Sensor 1
          U029D 00 [032] - -
25147 - Control Circuit for Reductant Pump 1
          P208B 00 [096] - Implausible Signal
Readiness: 1 3 0 0 0
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 60277000000516
   Coding: 0AEE929A34200B6F4777070462C74950492CD0E2E046927D30605078C02A4200002F641A1B13111435351919323200
   VCID: 76B5E5B0084D30BBA5F-8022
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NA 907 044 M    HW: 5NA 907 044 M
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000B00387115
   Humidity sensor: exterior:
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 31
                    Reset counter: 1
                    Mileage: 72955 km
                    Date: 2021.08.20
                    Time: 14:26:08
                    Outside temperature: 22.0 °C
                    Voltage terminal 30: 11.9 V
                    Air quality status: Slightly dirty air: stage 3
   Part No SW: 5Q0 937 084 CE    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H34 0236
   Serial number: 02001703200110
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7DA7FA9C2D7B63E3E45-8028
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 161214  033 0372
   Serial number: 00000001612120463584
   Component: RLHS  042 0105
   Serial number: S7Y17M02D07H02M24S24
   Coding: 00A8DD
   Serial number: 000000000ZY170042NPK
   Serial number: 00000000000068320510
   Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 001201177478011
   Coding: 0071451001
   ASAM Dataset: EV_EPHBO18VW3260000 007015
   ROD: EV_EPHBO18VW3260000_SK37.rod
   VCID: 372B28B44FC789B37E9-8062
   Component: ACCCONTIMQB   H01 0233
   Coding: 2A0060C150FF8728749C8145004087
   VCID: 3E253D9060FDB8FBBDF-806A
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2HXP3N
   Coding: 98CCC0C00C0000005C5400CF008800000065
   VCID: 1079B3280AE97E8B1F3-8044
   Left seat belt tensioner:
   Serial number: 5NC857705C0025R00385
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 5NC857706C0025R01070
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 602 17
   Serial number: 35700000000AB99D412V
   Subsystem 4 - Part No SW: -----------    HW: 480 000 602 17
   Serial number: 35800000000B6854012A
   Subsystem 5 - Part No SW: -----------    HW: 480 400 602 17
   Serial number: 3510001B3247FF95C1DL
   Subsystem 6 - Part No SW: -----------    HW: 480 400 602 17
   Serial number: 3520001B3247FF96A33D
   Subsystem 7 - Part No SW: -----------    HW: 480 400 202 17
   Serial number: 3550001A5244A734D7DA
   Subsystem 8 - Part No SW: -----------    HW: 480 400 202 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001AB244A735F48A
   Subsystem 9 - Part No SW: -----------    HW: 480 400 202 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001AB244A735831$
   Subsystem 10 - Part No SW: -----------    HW: 480 400 202 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001AB244A734A42Y
   Subsystem 11 - Part No SW: -----------    HW: 480 000 102 17
   Serial number: I0M0000000023DA4112X
   Subsystem 12 - Part No SW: -----------    HW: 480 000 102 17
   Serial number: I0N00000000E85A4A028
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170203500085
   Coding: 0C00
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41DF466C1103C703C0D-8014
   Part No SW: 5NA 920 951 A    HW: 5NA 920 951 A
   Component: KOMBI         309 8311
   Coding: 27A400006380060001886B031401000000000000
   VCID: 3FDB409467F7B1F3B69-806A
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005888040
   Coding: 030500045F087300FB07224C0A0F00010001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3B10D4B7974173269-807A
   Generator:
   Subsystem 2 - Part No SW: 5TA 959 442 A    HW: 5TA 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 0371704185000444AO2B
   Coding: 280000
   Serial number: 9059452904
9175296 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
                    Reset counter: 253
                    Mileage: 73030 km
                    Date: 2021.08.24
                    Time: 10:43:42
                    Terminal 30 power supply: 14.5 V
                    Terminal 15: On
   Serial number: HA1-00010.01.17
   Coding: 0101
   VCID: 4ACD61402C35045B117-801E
   Serial number: 211016EJL21975
   Coding: 00310220D001048000001000
   VCID: 43D34C640B1FD513D21-8016
   Serial number: 00000000000013227000
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D7527C052BEB23FC5-8010
   Serial number: 060117EA518352
   Coding: 00310020DE01048000001000
   VCID: 42DD49601405DC1BD97-8016
   Serial number: 00000000000013045639
   Coding: 050000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730601FF00000051110101008808001F0100C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 313F16ACA1A3578330D-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL072UT
   Subsystem 2 - Part No SW: 5NA 919 866 AG    HW: -----------
   Component: ECE AS 2020  --- 1310
   Serial number: 06021712K10174
   Coding: 0003070600000401000213448050A90084000E000020
   VCID: 3B23348473EFADD39A1-806E
End----------(Elapsed Time: 01:29, VBatt start/end: 12.3V/12.3V)-----------
I'm not certain where the HVAC's Air Quality Sensor is located on that car, but it has no bearing on the DPF faults that were triggering engine management light. All that air quality sensor does is tell the HVAC when it might want to auto-engage recirc mode.
invernesspl
C?ID=345478
I just wondered if the main dealer might have disturbed or damaged the sensor when carrying out the service.
The DPF faults have cleared and not come back as yet, any ideas why might have caused that?
How much has the vehicle been driven since you cleared those faults?
Oh, and did the dealer really return it from a "major service" with those fault in it and the MIL on?
invernesspl
C?ID=345478
The light came on about 10 mins away from the dealership after collecting it, and it has driven about 30 miles since clearing the codes I'd say.
Well, I guess I'd wait and see if it comes back.
On MQB platform cars where the steering wheel is on the correct side - the air quality sensor (G238) is installed on the air intake grille in the front left (in direction of travel) of the plenum chamber (the vent under the windshield).
It's relatively easy to access - albeit I agree that the sensor is a relatively innocuous device which is very unlikely to cause an engine management light!!
invernesspl
C?ID=345478
The engine management light just came back on. 🤔
  • Informative
Westbury, UK
An easy check is to see if the hoses from the exhaust to the differential pressure sensor are clear, it's not unknown for one or both of them to be blocked by soot.
invernesspl
C?ID=345478
Hi Dave,
Which pipes are these? sorry not worked on the new Tiguan before.
I find it an odd coincidence that this problem has emerged straight after the main dealer has worked on the car. Cant help but think they have done something.
Westbury, UK
Highlighted the answer in my previous post ;)
invernesspl
C?ID=345478
Hi,
I've not had time to look at the differential pressure sensor yet, but we now have a new issue. (beginning to regret taking this to the main dealer now!)
My mum was driving the car long distance, and the dashboard suddenly lights up like a christmass tree. Airbag light on, lane assist not available, cruise not available etc. I carried out an autoscan and it would appear the problem is the steering column control module. U0212 00 [039] - No Communications.
I've read through some of the posts on the forum, and have checked all fuses that I could find but not found any problem. Seems suspicious that the fuse for it is located right next to the pollen filter, after the main dealer have just been working on that area.
Has anyone experience with this problem?
Thanks.
Sunday,12,September,2021,11:16:03:41168
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WVGZZZ5NZHW403044   Mileage: 74213km-46113miles
   Revision: B4H24---    CVN: DBFBCE1D4C6C0C4B
   VCID: 74B1DFB81E3122ABB39-8020
   VINID: 9E65EAAAA15EA989C400300410DA7B269F
          P0471 00 [104] - Implausible Signal
                    Mileage: 73602 km
                    Date: 2021.08.30
                    Time: 10:21:07
                    Intake air temperature: 71 °C
                    Voltage terminal 30: 12.960 V
                    Unlearning counter according OBD: 19
                    Exhaust mass flow of low-pressure EGR: calculated: 2.475
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 411.1 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 611.0 hPa
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 0.09 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 411.0 hPa
12002 - Particulate Filter; Differential Pressure Sensor
                    Mileage: 73602 km
                    Date: 2021.08.30
                    Time: 10:21:07
                    Par.fil: diff.pr.sens.1 bank 1: offset: 199 hPa
                    Outside temperature sensor 1: B1: raw value: 16.0 °C
                    Particle filter: soot mass calculated: 6.57 g
                    Mileage: 73600 km
                    Date: 2021.08.30
                    Time: 10:17:53
                    Engine RPM: 1816.50 /min
                    Vehicle speed: 45 km/h
                    Intake air temperature: 86 °C
                    Voltage terminal 30: 14.760 V
                    Particle filter: soot mass measured: -2.82 g
                    Particle filter: soot mass calculated: 6.49 g
          P154B 00 [175] - Faulty
                    Mileage: 73614 km
                    Coolant temperature: 17 °C
                    Intake air temperature: 17 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 12.360 V
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
                    Mileage: 73614 km
4714 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:10
                    Engine RPM: 1018.00 /min
                    Normed load value: 58.8 %
                    Vehicle speed: 5 km/h
                    Intake air temperature: 75 °C
                    Limitation: accelerator pedal: 40.2 Nm
                    selected gear-Bits 0-7: 1
Readiness: 1 5 0 0 0
   VCID: 76B5E5B0084D30BB8DD-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   VCID: 49CF5E4C29330F4330F-801C
                    Fault Frequency: 67
                    Reset counter: 29
                    Mileage: 73595 km
                    Date: 2021.08.30
                    Time: 10:04:08
                    Outside temperature: 18.0 °C
                    Voltage terminal 30: 11.7 V
                    System run time-Terminal 15 on: 242 s
329479 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [008] - Open or Short to Plus
                    Reset counter: 28
                    Mileage: 73855 km
                    Date: 2021.09.11
                    Time: 07:57:17
                    Voltage terminal 30: 14.7 V
                    Inside temperature: 23.3 °C
                    Outside temperature: 16.5 °C
                    Fresh air/recirculating air/back pressure door specified value: 636
                    Actual value for fresh air/recirculation air flow flap: 975
                    Actual value for fresh air/recirculation air flow flap: 100.0 %
   VCID: 7DA7FA9C2D7B63E3CC7-8028
   Coding: 00A8DD
   Coding: 0071451001
   ROD: EV_EPHBO18VW3260000.rod
   VCID: 372B28B44FC789B356B-8062
   VCID: 3E253D9060FDB8FB95D-806A
1076 - Databus
          [FAULT_TIMEOUT_GRA_ACC_01]
                    Reset counter: 244
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:09
                    Voltage terminal 15: 13.1 V
                    Control Module temperature: 43 °C
                    Velocity_vehicle_reference: 1.02 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.03 m/s²
1116 - Databus
          [FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
                    Reset counter: 244
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:43:23
                    Voltage terminal 15: 13.2 V
                    Control Module temperature: 41 °C
                    Velocity_vehicle_reference: 0.52 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.09 m/s²
   VCID: 1079B3280AE97E8B371-8044
   Coding: 80000D
   Coding: 80000D
          B1000 1B [137] - Resistance Too High
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:11
   Coding: 0C00
   VCID: 41DF466C1103C703E8F-8014
   VCID: 3FDB409467F7B1F39EB-806A
   GVL: 01D43C0000000000408C80000000480000000000000000000000000000000000
   VCID: 2F3B10D4B79741730EB-807A
   Generator:
   Subsystem 2 - Part No SW: 5QA 915 181 D    HW: 5QA 915 181 D
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
          [MFL (LIN#2) Timeout]
                    Reset counter: 244
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:12
                    Terminal 30 power supply: 13.1 V
                    Terminal 15: On
          B130E 00 [008] - -
                    Reset counter: 29
                    Mileage: 73793 km
                    Date: 2021.09.11
                    Time: 07:23:17
                    Terminal 15: On
   Coding: 0101
   VCID: 4ACD61402C35045B395-801E
   VCID: 43D34C640B1FD513FA3-8016
   Coding: 0D0000
   Coding: 9107
   VCID: 45D7527C052BEB23D47-8010
   VCID: 42DD49601405DC1BF15-8016
   Coding: 050000
   VCID: 313F16ACA1A3578318F-8064
   VCID: 3B23348473EFADD3B23-806E
End----------(Elapsed Time: 01:39, VBatt start/end: 13.0V/13.4V)-----------
Sunday,12,September,2021,11:21:03:41168
VCDS Version: Release 21.9.0 (x64) Running on Windows 8.1 x64
                Address 15: Airbags       Labels: 5Q0-959-655.clb
Control Module Part Number: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
  Component and/or Version: AirbagVW21    003 0317
           Software Coding: 98CCC0C00C0000005C5400CF008800000065
              ASAM Dataset: EV_AirbaVW20SMEVW37X 002154 (VW37)
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:11
Sunday,12,September,2021,11:22:16:41168
                Address 19: CAN Gateway       Labels: 3Q0-907-530-V1.clb
Control Module Part Number: 3Q0 907 530 C    HW: 3Q0 907 530 C
  Component and/or Version: GW MQB High   418 4286
           Software Coding: 030500045F087300FB07224C0A0F00010001050000000000000000000000
              ASAM Dataset: EV_GatewNF 013020 (VW37)
                    Reset counter: 244
                    Mileage: 74001 km
                    Date: 2021.09.11
                    Time: 15:22:12
                    Terminal 15: On
          B130E 00 [008] - -
                    Reset counter: 29
                    Mileage: 73793 km
                    Date: 2021.09.11
                    Time: 07:23:17
                    Terminal 15: On
Sunday,12,September,2021,11:24:15:41168
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 026 JC    HW: 04L 907 309 P
  Component and/or Version: R4 2.0l TDI   H24 3023
           Software Coding: 0119001203271D082000
              ASAM Dataset: EV_ECM20TDI01104L906026JC 004002 (VW37)
Fault Codes have been Erased
                    Mileage: 74213 km
                    Date: 2021.09.12
                    Time: 11:25:35
                    Coolant temperature: 34 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.220 V
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
