Hi all. I'm trying to retrofit easy open to my 2013 Sharan where I'm now stuck with B1303 Sensor for Rear Lid/Hatch Opening - Missing Calibration / Basic Setting.
I've upgraded my factory KESSY with KESSY + VIP, relearn all keys/functions with Dealer Tools as well as Change coding in BCM to get the Convenience Menu on MFD. Everything works except I got the error and Easy Open still not working.
Here's the full scan.
As seen in many other Sharan with Easy Open, the Sensor for Rear Lid Opening is not listed under Kessy Slave module like other model. I've got the sensor new from Aliexpress (3AA 962 243 H)
Some experts/experienced guys are telling me that I should be able to do basic settings with dealer tools, but we couldnt get it right at all, both Online and Offline. Some models will require an Output Test under VCDS to clear the error ("control voltage to sensor") but the output test is not there in my case.
Here's are my adaptation map/measuring values from Kessy Module
I'm hoping if someone can shed some lights on this. either there's something wrong with the kick sensor itself, or some parameter adaptation are not right or I simply miss something in between. I could not find any adaptation map from Sharan with Easy Open. Thank you.
Tuesday,24,August,2021,22:54:28:01985
VCDS Version: 21.8.0.0 (x64) HEX-NET CB: 0.4553.4
Data version: 20210731 DS330.0
VIN: WVWZZZ7NZDV024587 License Plate: BENZINKOPF
Mileage: 118390km-73564mi Repair Order: 210824
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 18 19 25 2B 2E 3C 42 44 46
47 4C 4F 52 53 55 5F 62 65 6C 6D 72 A5 BE BF
VIN: WVWZZZ7NZDV024587 Mileage: 118390km-73564miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 06J 906 027 DJ HW: 06J 907 309 A
Component: MED17.5.2 06 2269
Revision: P3H07--- Serial number:
Coding: 0404000C1C070160
Shop #: WSC 00020 790 00000
VCID: 76A0EAE901C0FC3929-8022
VINID: 9E69EAAAA1DEA949800841481C276FDCB1
Part No SW: 02E 300 058 T HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3515
Revision: 05651213 Serial number: 00001211151749
Shop #: WSC 00020 000 90108
VCID: 2B160B9D8A02F1D186-807E
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 P HW: 7N0 614 109 P
Component: J104 C3 450M VD4C 0030
Revision: --H07--- Serial number: 00000006425793
Coding: 0003896
VCID: 3A383ED9755858590D-806E
Part No SW: 5K0 959 434 F HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1202
Revision: 00093000 Serial number: 0344538672
Coding: 13100C
VCID: 383C24D183544A49FB-806C
221445 - Sensor for Rear Lid/Hatch Opening
B1303 54 [009] - Missing Calibration / Basic Setting
Reset counter: 74
Part No SW: 7N0 907 044 F HW: 7N0 907 044 F
Component: Clima-Sharan H01 0202
Revision: 00001K03
Coding: 0210154458
VCID: 332613FD9A32A911CE-8066
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 46590ABFED2118C3D0CA04C9310009EC47FD1408777DADB0E4844220E2C0
VCID: 3E3032C9A970747931-806A
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 121015 31 0032
Serial number: 121024214914
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y12M11D27H21M39S02S4
Coding: 0680BB
Part No SW: 1K8 919 475 B HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0479
Revision: -------- Serial number: 39491531403690
Coding: 0131167011
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00.rod
VCID: 393A21D5B85E534104-806C
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 16111202720002
Coding: 010180
VCID: 271EF7AD56EAD5B162-8072
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00M H11 0014
Serial number: 003LGPQ8V001
Coding: 00304D
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3FCE4FCDA67A7D713A-806A
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60E09C11179DY
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS607C8D1E179D1
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60BD9C1117DD+
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS6081641E179DP
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS609E1FE616DD0
Part No SW: 5K0 953 521 CM HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20121116100931
Coding: 3012240000
ROD: EV_SMLSNGVOLWS.rod
VCID: 79BAE1D5F8DE934144-802C
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0032
Coding: 830000
Part No SW: 7N0 920 870 F HW: 7N0 920 870 F
Component: KOMBI H05 0705
Coding: 140D01
VCID: 35222DE59446B721E0-8060
10486016 - Control module
B2001 00 [009] - Incorrect software version
[BAP: Steuergerät falsche Softwareversion]
Reset counter: 73
Mileage: 118247 km
Date: 2021.08.23
Time: 21:16:27
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 5K0 963 271 B
Component: Zuheizer 051 2706
Revision: 00051000 Serial number: 09021535000000
Coding: 0000021
VCID: 2E100289B91084F9A1-807A
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Component: J533 Gateway H56 1663
Revision: H56 Serial number: 15101500F11091
Coding: 468023
VCID: 72A8D6F9ADA8E01905-8026
Component: IMMO H05 0705
Coding: 000007
Shop #: WSC 00046 000 00000
VCID: 6A98CE998D7828D9BD-803E
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000263247003
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F2E1F8D761A8DF1AA-807A
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7663856043
Coding: 010100
VCID: 2A180E9945F8E8D97D-807E
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0495886885
Coding: 04011202
ROD: EV_HREntryHella_VW32.rod
VCID: 3D3235C5AC766F6128-8068
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0503974197
Coding: 040112
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 G HW: 7N0 959 793 G
Component: TSG FA H03 0553
Revision: Serial number: 0000044585295
Coding: 01152E20DD01411011
VCID: 46C05A29F1A02CB979-8012
Part No: 7N0 909 144 P
Component: EPS_ZFLS Kl. 275 3305
Revision: 00H21000
VCID: 40CC4C311384028943-8014
Part No SW: 5K0 035 456 C HW: 5K0 035 456 C
Component: KonzernAmp 8K H07 0202
Revision: -------- Serial number: EAA086A0026825
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1_VW12.rod
VCID: 2A180E994DF8E8D97D-807E
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1663
Coding: 050B0500
VCID: 6FAEDF8DBE9ACDF1EA-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H04 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H04 0220
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 G HW: 7N0 959 792 G
Component: TSG BF H03 0553
Revision: Serial number: 0000044559479
Coding: 01152E20DF01411011
VCID: 45C25D25CCA627A170-8010
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000605996
Coding: 0024157
VCID: 36202AE94140BC39E9-8062
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 053200000B000200
VCID: 373E27ED8E4A4531F2-8062
Subsystem 1 - Part No: 1T0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 1T0 941 329 Labels: 3D0-941-329.CLB
Part No SW: 5K7 035 200 H HW: 5K7 035 200 H
Component: MU-S--ROA H31 0359
Serial number: VWZAZ2S5325164
Coding: 02240800FF00000001110006000900A39F0104C60100010001
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 291AF19548FEE3C174-807C
15360768 - Component Protection
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6300)]
Reset counter: 73
Mileage: 118247 km
Date: 2021.08.23
Time: 21:16:27
Voltage terminal 30: 12.2 V
3077 - Telephone baseplate
B1051 13 [009] - Open Circuit
[Bracket for mobile phone holder - open circuit]
Reset counter: 73
Mileage: 118247 km
Date: 2021.08.23
Time: 21:16:26
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 H HW: 7N0 959 794 H
Component: TSG HL H01 0553
Revision: Serial number: 0000131364399
Coding: 01006C200001411001
VCID: 48DC5411FBB43AC98B-801C
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H06 0011
Serial number: 40000000451190
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Coding: 01240801AA01000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 302C1CF16B249209B3-8064
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 73
passive
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 E HW: 7N0 959 107 A
Component: HDSG-Modul H11 0243
Revision: 41011001 Serial number: 297200524
Coding: 0733334002
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H01 0553
Revision: Serial number: 0000131364461
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3AA-980-654.clb
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H09 0300
Serial number: 0187634102
Coding: 01000100000000100000040000010100
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
Address BE: Slid. Door Rear Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 A HW: 7N0 959 244 A
Component: Schiebetuer_l 005 2314
Serial number: 12457609
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
Address BF: Slid. Door Rear Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2314
Serial number: 12457614
ROD: EV_AST.rod
End----------(Elapsed Time: 02:02, VBatt start/end: 12.4V/12.4V)-----------
;SW:5K0-959-434-F HW:5K0-959-434 --- Acc/Start Auth. --- SA: 32840
;Component:VWKESSYPQ35GP 093 1202 Coding:13100C
;EV_KESSYPQ35G A02717 EV_KESSYPQ35G_A02_VW31.rod
;Tuesday 24 August
;VCDS Version: Beta 21.8.0 (x64) Data version: 20210731 DS330.0
;VCID: 383C24D183544A49FB-806C
ENG105462-CAN-timeout service-key message 260 ms 1
ENG105634-Correction value LED dimming 1 1
ENG114301-Cycletime for voltage monitoring during sleepmode 100 ms 1
ENG105791-Delta value LED dimming curve first point 40 percent dimming 11.0 % 1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming 34.0 % 1
ENG105793-Delta value LED dimming curve second point 60 percent dimming 23.0 % 1
ENG105794-Delta value LED dimming curve third point 80 percent dimming 28.0 % 1
ENG121944-ENG154598-Developer Coding: VIP-exeption_drivers_doors_interior_scan not active 1
ENG121944-ENG154691-Developer Coding: VIP-interior_scan_clamp_15_new_concept not active 1
ENG121944-ENG154710-Developer Coding: VIP-open_cabrio_canopy_interior_scan not active 1
ENG121944-ENG121900-Developer Coding: VIP-VIP function active 1
ENG121944-ENG121901-Developer Coding: VIP-VIP function during Kl15 not active 1
ENG121944-ENG121902-Developer Coding: VIP-VIP function during motor running not active 1
ENG105802-ENG98487-DeveloperCoding: Fahrzeugumfeld-Convertible not active 1
ENG105802-ENG100924-DeveloperCoding: Fahrzeugumfeld-Pre Catch for Trunk installed 1
ENG105802-ENG103200-DeveloperCoding: Fahrzeugumfeld-Steering wheel Right hand steering 1
ENG105802-ENG127437-DeveloperCoding: Fahrzeugumfeld-Switching edge VIT positive edge 1
ENG105803-ENG112090-DeveloperCoding: Key Minder (Byte 1)-Remotestartauswertung not active 1
ENG105803-ENG101923-DeveloperCoding: Key Minder (Byte 1)-Retry handling big car / expanded search activated 1
ENG105803-ENG100928-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening not active 1
ENG105803-ENG99649-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening no KESSY unlocking activated 1
ENG105803-ENG99417-DeveloperCoding: Key Minder (Byte 1)-Softtouch mounted installed 1
ENG105804-ENG99123-DeveloperCoding: Key Minder (Byte 2)-Inhibit ID-transmitter for passive go activated 1
ENG105804-ENG102581-DeveloperCoding: Key Minder (Byte 2)-Lock prevention tailgate not active 1
ENG105804-ENG101018-DeveloperCoding: Key Minder (Byte 2)-No locking with ID-transmitter last used interior activated 1
ENG105804-ENG103451-DeveloperCoding: Key Minder (Byte 2)-Re-open after passive comfort closing activated 1
ENG105804-ENG99711-DeveloperCoding: Key Minder (Byte 2)-Re-open last handling ZV entriegeln 1
ENG105804-ENG103237-DeveloperCoding: Key Minder (Byte 2)-Re-open tailgate activated 1
ENG105804-ENG104103-DeveloperCoding: Key Minder (Byte 2)-Send numbers of ID-transmitters interior (ELV-Scan) activated 1
ENG105805-ENG155267-DeveloperCoding: LF Transmission-lf_shutdown not active 1
ENG105805-ENG155268-DeveloperCoding: LF Transmission-lf_shutdown_gotrigger not active 1
ENG105805-ENG102436-DeveloperCoding: LF Transmission-Standardisation of ZAT activated 1
ENG105805-ENG101761-DeveloperCoding: LF Transmission-ZAT active during clamp 58d on not active 1
ENG105805-ENG99363-DeveloperCoding: LF Transmission-ZAT active during clamp 58t on activated 1
ENG105806-ENG104126-DeveloperCoding: Naeherungssensor-AUDI doorknobs mounted not active 1
ENG105806-ENG102457-DeveloperCoding: Naeherungssensor-Detection of an repeated failed doorknob actuation activated 1
ENG105806-ENG102353-DeveloperCoding: Naeherungssensor-No turn off for driver doorknob while passive Fahrertürgriff wird nicht abgeschaltet 1
ENG105806-ENG99826-DeveloperCoding: Naeherungssensor-Proximity Sensor: sensor stays active after fault detection activated 1
ENG105806-ENG102252-DeveloperCoding: Naeherungssensor-Suppress fault manager entry "Falschverbau aktiv" Fehlerspeichereintrag wird nicht unterdrueckt 1
ENG105807-ENG121989-DeveloperCoding: Passiv Entry Exit (Byte 1)-Impairment Entry / Exit key on low battery activated 1
ENG105807-ENG99763-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: access door not open activated 1
ENG105807-ENG103722-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: all doors not open not active 1
ENG105808-ENG101891-DeveloperCoding: Passiv Entry Exit (Byte 2)-Auto lock not active 1
ENG105808-ENG98383-DeveloperCoding: Passiv Entry Exit (Byte 2)-Auto unlock not active 1
ENG105808-ENG100534-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passiv Entry Exit activated 1
ENG105808-ENG100246-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed activated 1
ENG105808-ENG103289-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: control by pulling door handle during active DSL activated 1
ENG105808-ENG103620-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: retry with antennastep 1 not active 1
ENG105808-ENG103529-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry: second control concept not active 1
ENG105809-ENG114300-DeveloperCoding: Passiv Go-Change Go antenna at every request not active 1
ENG105809-ENG114299-DeveloperCoding: Passiv Go-Change Go antenna during retry challenge activated 1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open not active 1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open not active 1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery activated 1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go activated 1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start activated 1
ENG105810-ENG103075-DeveloperCoding: Sonstiges-Battery manager mounted not active 1
ENG105810-ENG102728-DeveloperCoding: Sonstiges-Diagnostic: service 86 - response on event not active 1
ENG105810-ENG98656-DeveloperCoding: Sonstiges-internal not active 1
ENG105810-ENG102591-DeveloperCoding: Sonstiges-Response extension for scan procedure not active 1
ENG105810-ENG99430-DeveloperCoding: Sonstiges-Scan Procedure: Timeoutcontrol active activated 1
ENG105810-ENG104010-DeveloperCoding: Sonstiges-Use default antenna data not active 1
ENG105825-Diagnostic: wait time after power on 3000 ms 1
ENG105898-Doorknob contact sensor disconnecting time 5400 min 1
ENG107050-Interior scan: deceleration after comfort closing 5000 ms 1
ENG107051-Interior scan: max. engine speed for standing engine 10 km/h 1
ENG107052-Interior scan: opening threshold sliding roof 1 % 1
ENG107053-Interior scan: opening threshold window lifter 5.0 % 1
ENG107054-Interior scan: Speed - threshold 20 km/h 1
ENG98656-internal 0 B 1
ENG107211-Key Minder: delay reunlocking tailgate 500 ms 1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time 10 s 1
ENG107213-Key Minder: p_keyless_eventsearch_retries 4 1
ENG107363-LED dimming curve first point 20 percent dimming 4.0 % 1
ENG107592-MCTX Pause 1 B 1
ENG107593-MCTX pause for Go / Key Minder 10 ms 1
ENG107594-MCTX pause for Go authentification 7 B 1
ENG107595-MCTX settling phase 7 B 1
ENG108165-Passive Entry Exit: control by pulling the door handle during active DSL (timeout) 2.00 s 1
ENG108166-Passive Entry Exit: entry request e-sliding door active time 500 ms 1
ENG108167-Passive Entry Exit: minimum activity time locking sensor 140 ms 1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY 210 ms 1
ENG108169-Passive Entry Exit: T_ACT_OP_2 5000 ms 1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement 200 ms 1
ENG108298-Proximity Sensor: duration of proximity Signal 10 s 1
ENG108299-Proximity Sensor: lower limit Impuls 2000 µs 1
ENG108300-Proximity Sensor: lower limit proximity-Impuls 12200 µs 1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle 10.0 km/h 1
ENG108302-Proximity Sensor: max. Impulslength 75 ms 1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls 20400 µs 1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic 14 ms 1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls 71 ms 1
ENG108306-Proximity Sensor: max. length of Entryimpuls 10400 µs 1
ENG108307-Proximity Sensor: max. length of Exitimpuls 40400 µs 1
ENG108308-Proximity sensor: max. length of signal hall sensor 100 s 1
ENG108309-Proximity Sensor: max. signal-length 120 s 1
ENG108310-Proximity sensor: max. tolerance data bit length 20000 µs 1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle 20.0 km/h 1
ENG108312-Proximity Sensor: min. enginespeed for a running engine 300 /min 1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls 42 ms 1
ENG108314-Proximity Sensor: min. length of Entryimpuls 6200 µs 1
ENG108315-Proximity Sensor: min. length of Exitimpuls 24200 µs 1
ENG108316-Proximity sensor: min. tolerance data bit length 12000 µs 1
ENG108317-Proximity Sensor: SP_X2 10 min 1
ENG108318-Proximity Sensor: SP_X3 1 1
ENG108319-Proximity Sensor: SP_X4 80 1
ENG108320-Proximity Sensor: SP_X5 1 1
ENG108321-Proximity Sensor: SP_X6 30 min 1
ENG108322-Proximity Sensor: SP_X7 1 1
ENG108323-Proximity Sensor: Time Power On 1960 ms 1
ENG108324-Proximity Sensor: Timervalue for ExitReverseOption (BCM: par_t_Komfort_Umtasten) 2000 ms 1
ENG108325-Proximity sensor: turn-off limit from battery-manager 2 1
ENG108326-Proximity Sensor: upper limit intermission-length 10 ms 1
ENG121928-Rear_Lid_Opening_Sender_1_burst_length 10 1
ENG121918-Rear_Lid_Opening_Sender_1_timer_1 AA 1
ENG121919-Rear_Lid_Opening_Sender_1_timer_2 0 1
ENG121920-Rear_Lid_Opening_Sender_1_timer_3 9 1
ENG121921-Rear_Lid_Opening_Sender_1_timer_4 E2 1
ENG121922-Rear_Lid_Opening_Sender_1_timer_5 FF 1
ENG121908-Rear_Lid_Opening_Sender_1_treshold_1 5 1
ENG121909-Rear_Lid_Opening_Sender_1_treshold_2 10 1
ENG121910-Rear_Lid_Opening_Sender_1_treshold_3 10 1
ENG121911-Rear_Lid_Opening_Sender_1_treshold_4 10 1
ENG121912-Rear_Lid_Opening_Sender_1_treshold_5 10 1
ENG121927-Rear_Lid_Opening_Sender_1_vref 10 1
ENG121932-Rear_Lid_Opening_Sender_2_AS 1F 1
ENG121931-Rear_Lid_Opening_Sender_2_burst_length 2 1
ENG121923-Rear_Lid_Opening_Sender_2_timer_1 0B 1
ENG121924-Rear_Lid_Opening_Sender_2_timer_2 A5 1
ENG121925-Rear_Lid_Opening_Sender_2_timer_3 93 1
ENG121945-Rear_Lid_Opening_Sender_2_timer_4 CC 1
ENG121926-Rear_Lid_Opening_Sender_2_timer_5 6C 1
ENG121913-Rear_Lid_Opening_Sender_2_treshold_1 2 1
ENG121914-Rear_Lid_Opening_Sender_2_treshold_2 1F 1
ENG121915-Rear_Lid_Opening_Sender_2_treshold_3 2 1
ENG121916-Rear_Lid_Opening_Sender_2_treshold_4 1F 1
ENG121930-Rear_Lid_Opening_Sender_2_vref 10 1
ENG121937-Rear_Lid_Opening_Sender_Application_Data_Identification 2
ENG121942-Rear_Lid_Opening_Sender_ccycle_protection_decrement_interval 60 1
ENG121936-Rear_Lid_Opening_Sender_Checksum AA 1
ENG121943-Rear_Lid_Opening_Sender_comparisson 0 1
ENG121935-Rear_Lid_Opening_Sender_Counter_Reset do_no_reset 1
ENG121940-Rear_Lid_Opening_Sender_cycle_protection_activ_treshold FF 1
ENG121941-Rear_Lid_Opening_Sender_cycle_protection_deactiv_treshold 5 1
ENG121939-Rear_Lid_Opening_Sender_cycle_protection_decrement_value 19 1
ENG121938-Rear_Lid_Opening_Sender_cycle_protection_increment_value 6 1
ENG121903-Rear_Lid_Opening_Sender_Duration_Sensor_Request 4960 1
ENG121933-Rear_Lid_Opening_Sender_fusion_timer_A1 2 1
ENG121934-Rear_Lid_Opening_Sender_fusion_timer_A2 1F 1
ENG121904-Rear_Lid_Opening_Sender_vehicle_type 22 1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol 5 Step 1
ENG108576-Scan Procedure: cycle convenience coverage limiting 65 ms 1
ENG108577-Scan Procedure: Number of Repeats 1 1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause 1000 ms 1
ENG108579-Scan Procedure: Timeout Authentification Result 150 ms 1
ENG108580-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Go) 190 ms 1
ENG108581-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Kombi) 700 ms 1
ENG108582-Scan Procedure: Timeout LF Repetition 100 ms 1
ENG108583-Scan Procedure: Timeoutcontrol 20.00 s 1
ENG108585-ScanProcedure: Timeout Entry Response 250 ms 1
ENG108586-ScanProcedure: Timeout Response 100 ms 1
ENG109053-Standard dimming value ZAT 70 % 1
ENG100492-Stop_enabling_for_Start_/_Stop_function According to function requirements 1
ENG102207-Time Sensor Power Off Group 2 3600 min 1
ENG109974-Voltage monitoring: overvoltage Delta 500 mV 1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU 16000 mV 1
ENG109976-Voltage monitoring: overvoltage for Keyless Go 27000 mV 1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta 0 mV 1
ENG109978-Voltage monitoring: undervoltage Delta 500 mV 1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU 9000 mV 1
ENG109980-Voltage monitoring: undervoltage for Keyless Go 6000 mV 1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta 0 mV 1
ENG110364-ZAT nominal voltage 13.0 V 1
ENG110365-ZAT post-carridge during clamp 15 off 10 min 1
;Tuesday 24 August
;Tuesday 24 August
;Tuesday 24 August
Group Description Actual
IDE00019-ENG99033 Voltage terminal 30-Voltage 12.411
IDE00020-MAS01632 Terminal 15 status-Status Terminal 15 on
IDE00075 Vehicle speed 0
IDE00323 Security Access: Number of invalid keys 0
IDE01715-MAS01632 Status terminal S-Status On
IDE01716-MAS01632 Terminal 50 status-Status OFF
IDE02406 Key number of last identified ID sensor ID sensor 1
IDE02407-MAS01632 Status of vehicle locking-Status Vehicle unlocked
IDE02408-MAS00218 Individual door locking: status-Driver door closed
IDE02408-MAS00219 Individual door locking: status-Front Passenger Door closed
IDE02408-MAS00220 Individual door locking: status-Left rear door closed
IDE02408-MAS00221 Individual door locking: status-Right rear door closed
IDE02409-MAS01632 ID-sensor 1 authentication: status-Status No response
IDE02410-MAS01632 ID-sensor 2 authentication: status-Status No response
IDE02411-MAS01632 ID-sensor 3 authentication: status-Status No response
IDE02412-MAS01632 ID-sensor 4 authentication: status-Status No response
IDE02413 Door handle touch sensor: last operation Driver door
IDE02414-MAS00080 Driver exterior door handle touch sensor-Coding information coded
IDE02414-MAS02176 Driver exterior door handle touch sensor-Approach to the inside not active
IDE02414-MAS02177 Driver exterior door handle touch sensor-Actuation to the inside not active
IDE02414-MAS02178 Driver exterior door handle touch sensor-Approach to the outside not active
IDE02414-MAS02179 Driver exterior door handle touch sensor-Actuation to the outside not active
IDE02414-MAS02451 Driver exterior door handle touch sensor-Pulling actuation: outside door handle not active
IDE02415-MAS00080 Front passenger exterior door handle touch sensor-Coding information coded
IDE02415-MAS02176 Front passenger exterior door handle touch sensor-Approach to the inside not active
IDE02415-MAS02177 Front passenger exterior door handle touch sensor-Actuation to the inside not active
IDE02415-MAS02178 Front passenger exterior door handle touch sensor-Approach to the outside not active
IDE02415-MAS02179 Front passenger exterior door handle touch sensor-Actuation to the outside not active
IDE02415-MAS02451 Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle not active
IDE02416-MAS00080 Left rear outside door handle touch sensor-Coding information Not coded
IDE02416-MAS02176 Left rear outside door handle touch sensor-Approach to the inside not active
IDE02416-MAS02177 Left rear outside door handle touch sensor-Actuation to the inside not active
IDE02416-MAS02178 Left rear outside door handle touch sensor-Approach to the outside not active
IDE02416-MAS02179 Left rear outside door handle touch sensor-Actuation to the outside not active
IDE02416-MAS02451 Left rear outside door handle touch sensor-Pulling actuation: outside door handle not active
IDE02417-MAS00080 Right rear outside door handle touch sensor-Coding information Not coded
IDE02417-MAS02176 Right rear outside door handle touch sensor-Approach to the inside not active
IDE02417-MAS02177 Right rear outside door handle touch sensor-Actuation to the inside not active
IDE02417-MAS02178 Right rear outside door handle touch sensor-Approach to the outside not active
IDE02417-MAS02179 Right rear outside door handle touch sensor-Actuation to the outside not active
IDE02417-MAS02451 Right rear outside door handle touch sensor-Pulling actuation: outside door handle not active
IDE02418-ENG98489 Proximity sensor driver door: number of triggers-counts 100
IDE02419-ENG98489 Proximity sensor frt.pass. door: number of triggers-counts 47
IDE02420-ENG98489 Proximity sensor left rear door: number of triggers-counts 0
IDE02421-ENG98489 Proximity sensor right rear door: number of triggers-counts 0
IDE02422-MAS01482 Driver door handle: version information-Hardware version 70
IDE02422-MAS01483 Driver door handle: version information-Software version 2F
IDE02422-MAS02180 Driver door handle: version information-ZSB version information 49
IDE02423-MAS01482 ass. door handle: version information-Hardware version 70
IDE02423-MAS01483 ass. door handle: version information-Software version 2F
IDE02423-MAS02180 ass. door handle: version information-ZSB version information 49
IDE02424-MAS01482 Left rear door handle: version information-Hardware version 0
IDE02424-MAS01483 Left rear door handle: version information-Software version 0
IDE02424-MAS02180 Left rear door handle: version information-ZSB version information 0
IDE02425-MAS01482 Right rear door handle: version information-Hardware version 0
IDE02425-MAS01483 Right rear door handle: version information-Software version 0
IDE02425-MAS02180 Right rear door handle: version information-ZSB version information 0
IDE02426-MAS02398 Key number last identified in left exterior area-ID sensor 1 Yes
IDE02426-MAS02399 Key number last identified in left exterior area-ID sensor 2 No
IDE02426-MAS02400 Key number last identified in left exterior area-ID sensor 3 No
IDE02426-MAS02401 Key number last identified in left exterior area-ID sensor 4 No
IDE02427-MAS02398 Key number last identified in right exterior area-ID sensor 1 Yes
IDE02427-MAS02399 Key number last identified in right exterior area-ID sensor 2 No
IDE02427-MAS02400 Key number last identified in right exterior area-ID sensor 3 No
IDE02427-MAS02401 Key number last identified in right exterior area-ID sensor 4 No
IDE02428-MAS02398 Key number last identified in rear exterior area-ID sensor 1 Yes
IDE02428-MAS02399 Key number last identified in rear exterior area-ID sensor 2 No
IDE02428-MAS02400 Key number last identified in rear exterior area-ID sensor 3 No
IDE02428-MAS02401 Key number last identified in rear exterior area-ID sensor 4 No
IDE02429-MAS02398 Key number last identified in interior area-ID sensor 1 No
IDE02429-MAS02399 Key number last identified in interior area-ID sensor 2 No
IDE02429-MAS02400 Key number last identified in interior area-ID sensor 3 No
IDE02429-MAS02401 Key number last identified in interior area-ID sensor 4 No
IDE02430-MAS02398 Key number last identified in luggage compartment area-ID sensor 1 No
IDE02430-MAS02399 Key number last identified in luggage compartment area-ID sensor 2 No
IDE02430-MAS02400 Key number last identified in luggage compartment area-ID sensor 3 No
IDE02430-MAS02401 Key number last identified in luggage compartment area-ID sensor 4 No
IDE02466-ENG98489 Play protection activation counter driver door-counts 0
IDE02467-ENG98489 Play protection activation counter frt.pass. door-counts 0
IDE02468-ENG98489 Play protection activation counter left rear door-counts 0
IDE02469-ENG98489 Play protection activation counter right rear door-counts 0
IDE02482-MAS00976 72h-Signaling counter driver door-Counter 0
IDE02483-MAS00976 72-hour signaling counter frt.pass. door-Counter 0
IDE02484-MAS00976 72h-Signaling counter left rear door-Counter 0
IDE02485-MAS00976 72h-Signaling counter right rear door-Counter 0
IDE02495 Service-Key: Number of activations 6
IDE02496 Service-Key: Number of Timeouts 0
IDE02497 Service-Key: Number of incomplete messages 0
IDE03008-ENG99475 Stop process prevented-AT-Information 0
IDE03008-ENG102295 Stop process prevented-Keyless-Info 0
IDE03008-ENG101026 Stop process prevented-Koordinator-Status 0
IDE03008-ENG103965 Stop process prevented-UID-Info 0
IDE03008-ENG103850 Stop process prevented-WFS-Info 0
IDE03010-MAS00976 Number of prevented stop processes-Counter 0
IDE03010-MAS00976 Number of prevented stop processes-Counter 11
IDE03127-IDE03212 Prevented stop processes (ring memory)-Start/stop conditions 3
IDE03127-IDE03212 Prevented stop processes (ring memory)-Start/stop conditions 2
IDE03127-IDE03212 Prevented stop processes (ring memory)-Start/stop conditions 1
IDE03127-MAS00106 Prevented stop processes (ring memory)-Year 2094
IDE03127-MAS00106 Prevented stop processes (ring memory)-Year 2036
IDE03127-MAS00107 Prevented stop processes (ring memory)-Month 14
IDE03127-MAS00108 Prevented stop processes (ring memory)-Day 11
IDE03127-MAS00108 Prevented stop processes (ring memory)-Day 14
IDE03127-MAS00108 Prevented stop processes (ring memory)-Day 28
IDE03127-MAS00109 Prevented stop processes (ring memory)-Hours 13
IDE03127-MAS00109 Prevented stop processes (ring memory)-Hours 16
IDE03127-MAS00109 Prevented stop processes (ring memory)-Hours 10
IDE03127-MAS00110 Prevented stop processes (ring memory)-Minutes 0
IDE03127-MAS00110 Prevented stop processes (ring memory)-Minutes 50
IDE03127-MAS00110 Prevented stop processes (ring memory)-Minutes 13
IDE03127-MAS00111 Prevented stop processes (ring memory)-Seconds 20
IDE03127-MAS00111 Prevented stop processes (ring memory)-Seconds 6
IDE03127-MAS00111 Prevented stop processes (ring memory)-Seconds 0
IDE04042-ENG20505 ID sensor history data-Scan 1 Origin Passive Go
IDE04042-ENG104152 ID sensor history data-Scan 1 Single Scan Interior with trunk
IDE04042-ENG20412 ID sensor history data-Scan 1 Trigger Go authentication request
IDE04042-ENG99205 ID sensor history data-Scan 1 Trigger Information 62
IDE04042-ENG20435 ID sensor history data-Scan 2 Origin Passive Go
IDE04042-ENG99359 ID sensor history data-Scan 2 Single Scan Interior with trunk
IDE04042-ENG20402 ID sensor history data-Scan 2 Trigger Go ID request
IDE04042-ENG103833 ID sensor history data-Scan 2 Trigger Information 52
IDE04042-ENG20483 ID sensor history data-Scan 3 Origin Passive Go
IDE04042-ENG102354 ID sensor history data-Scan 3 Single Scan Interior with trunk
IDE04042-ENG20414 ID sensor history data-Scan 3 Trigger Go authentication request
IDE04042-ENG100775 ID sensor history data-Scan 3 Trigger Information 62
IDE05204 Manufacturer production data door handle drivers door 11 22 05 13 47
IDE05205 Manufacturer production data door handle front pass.door 11 22 05 07 78
IDE05206 Manufacturer production data door handle left rear 00 00 00 00 00
IDE05207 Manufacturer production data door handle right rear 00 00 00 00 00
ENG121906 Last_LIN_Message_Kessy 00 00 3E 00 22 F0 FF FF
ENG121907 Last_LIN_Message_LIN 00 00 04 00 80 FF FF FF
ENG121905 Rear_Lid_Deactivation_Reason 3
ENG121948-ENG121879 Rear_Lid_Opening_Sender_Cycle_Data-trace_1 0
ENG121948-ENG121888 Rear_Lid_Opening_Sender_Cycle_Data-trace_10 0
ENG121948-ENG121889 Rear_Lid_Opening_Sender_Cycle_Data-trace_11 0
ENG121948-ENG121890 Rear_Lid_Opening_Sender_Cycle_Data-trace_12 0
ENG121948-ENG121891 Rear_Lid_Opening_Sender_Cycle_Data-trace_13 0
ENG121948-ENG121892 Rear_Lid_Opening_Sender_Cycle_Data-trace_14 0
ENG121948-ENG121893 Rear_Lid_Opening_Sender_Cycle_Data-trace_15 0
ENG121948-ENG121894 Rear_Lid_Opening_Sender_Cycle_Data-trace_16 0
ENG121948-ENG121895 Rear_Lid_Opening_Sender_Cycle_Data-trace_17 0
ENG121948-ENG121896 Rear_Lid_Opening_Sender_Cycle_Data-trace_18 0
ENG121948-ENG121897 Rear_Lid_Opening_Sender_Cycle_Data-trace_19 0
ENG121948-ENG121880 Rear_Lid_Opening_Sender_Cycle_Data-trace_2 0
ENG121948-ENG121898 Rear_Lid_Opening_Sender_Cycle_Data-trace_20 0
ENG121948-ENG121881 Rear_Lid_Opening_Sender_Cycle_Data-trace_3 0
ENG121948-ENG121882 Rear_Lid_Opening_Sender_Cycle_Data-trace_4 0
ENG121948-ENG121883 Rear_Lid_Opening_Sender_Cycle_Data-trace_5 0
ENG121948-ENG121884 Rear_Lid_Opening_Sender_Cycle_Data-trace_6 0
ENG121948-ENG121885 Rear_Lid_Opening_Sender_Cycle_Data-trace_7 0
ENG121948-ENG121886 Rear_Lid_Opening_Sender_Cycle_Data-trace_8 0
ENG121948-ENG121887 Rear_Lid_Opening_Sender_Cycle_Data-trace_9 0
ENG121949-ENG121899 Rear_Lid_Opening_Sender_ROM-Parameter_Version-Param_Version_Layout_Version 2320
ENG121947-ENG121876 Rear_Lid_Opening_Sender_Status-Detected_Approach_Sender_1 No
ENG121947-ENG121877 Rear_Lid_Opening_Sender_Status-Detected_Approach_Sender_2 No
ENG121947-ENG121878 Rear_Lid_Opening_Sender_Status-Sensor_Connection Yes
Elapsed Time: 00:11
