Why the Auto Scan is so important.
VR6 Bug
Elmer, NJ
C?ID=197078
My wife called me today around 5:30. She got home and shut the key off and removed it from our B5 blue anthracite V6 4 Motion Passat wagon. Sorry for the details just love the car, but anyway it kept running! I recently got my balls busted for not posting an auto scan. Here is what I found in a place most people wouldn't look.
Just and FYI for the newbies.
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Volkswagen of Salem County
Tuesday,28,April,2015,23:21:08:17432
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
   Mileage: 212220km-131867miles
Address 01: Engine        Labels: 078-907-551-ATQ.lbl
   Part No: 3B0 907 551 BA
   Component: 2.8L V6/5V      G   0050
   Coding: 07251
   Shop #: WSC 09113
   VCID: 63C5585BF111A03913D-5124
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8D0 927 156 AT
   Component: AG5 01V 2.8l5V  USA 3132
   Coding: 00102
   Shop #: WSC 05311
   VCID: 7F0DF42B7DB964D9175-5140
Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
   Part No: 8E0 614 111 A
   Component: ABS/EDS 5.3 QUATTRO D10
   Shop #: BB 24334
   VCID: 1C3723A78CEFDFC1927-5124
   Part No: 6Q0 909 605 C
   Component: 03 AIRBAG VW6       0003
   Coding: 12339
   Shop #: WSC 05311
   VCID: 377DDC0B15099C999F5-5124
Address 17: Instruments        Labels: 3B0-920-xx2-17.lbl
   Part No: 3B0 920 920 BX
   Component: B5-KOMBIINSTR. VDO V27
   Coding: 05265
   Shop #: WSC 00113
   VCID: 75E116034F852E894D9-5124
   Part No: 6N0 909 901
   Coding: 00005
   Shop #: WSC 08217
   VCID: 70EF271730E70BA19EF-5124
   Part No: 1J0 959 799 AJ
   Component: 6W Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 08217
   VCID: 060361CF22633511543-4B02
   Subsystem 1 - Part No: 1J1959801D
   Component: 6W Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802E
   Component: 6W Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811D
   Component: 6W Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812D
   Component: 6W Tõrsteuerger. HR0002r
00849 - S-contact at Ignition/Starter Switch (D)
            25-10 - Unknown Switch Condition - Intermittent
   Part No: 1J0 035 180 B
   Component:  Radio DE2         0005
   Coding: 05043
   Shop #: WSC 00028
   VCID: 1E3329AF9AF3CDD17C3-519A
End-------------------------(Elapsed Time: 04:39)--------------------------
GaryM
Oxford, UK
C?ID=226919
Yeah, but you forgot to include the installation list at the top of the scan ;) It's an important part of the scan because it allows people to immediately see and pinpoint which controllers are at fault without having to look through a mile of scan output to find out. Oh, and the scan isn't wrapped in [CODE][/CODE] tags either ;)
At least you found what the problem was caused by :)
NEtech
Denmark
C?ID=56995
No he did not :), it does not exist on that B5 (3B) model, first next Model (3C).
But you are right about the wrapping.
@VR6 Bug if you are testing your nice car often, you could put this line in the MyAutoScan.txt (placed in the VCDS directory):
3B,VR6 Bug VW Passat B5,01,02,03,15,17,19,46,56
You have no Climatronic ?
VR6 Bug
Elmer, NJ
C?ID=197078
I should do that for my older cars, thanks. Im assuming code tags and wrap is what Uwe did to my post. Ill try to figure it out.
No Cliamtronic, no wheel controls, non heated cloth seats. GLS model.
The CODE tags trick is explained in this post right under the video.
roth
C?ID=242642
You will find out when you have the pleasure of recoding late model ABS or any other module. :)
BR, Andy
