[MQB?] Infotainment unit - working after engine shut off?
Szogun
Poland
C?ID=403301
Hi,
I don't have any specific car on my mind - but we can focus on MQB platform.
Is it possible to change the power supply of the radio in such a way that it works after the engine is turned off?
And it could turns off after door open or central lock?
Now:
1. Engine is running. Radio too.
2. Shuting off engine and the radio is shuting down.
I want to:
2. Shuting off engine and radio is still playing.
3. Open door (or something else - central lock...) and radio is shuting down?
iichel
Eindhoven, NB, NL
C?ID=284912
You can problably influence the behaviour of the S-contact. I can in my Polo PQ, with kessy.
siLc
Tallinn, Estonia
C?ID=330192
The situation of radio off when turning the engine off and not removing the key from ignition itself is not how it should be, no matter if PQ or MQB.
Radio has battery power and on/off signal comes via CAN. Perhaps post an autoscan of the vehicle in question?
Ovidel
Vittorio Veneto, Italy
C?ID=390851
Hi.
on my car it works the way you want it to work. past b8 mib2 pro. maybe if you upload a backup of adaptations and an autoscan we will find out why it works abnormally for you.
hmmm....... interesting qestion - not the first time that it has been asked! My experience (with MQB platform cars) is that the switch-OFf dynamic for the MIB/MMI does vary with the vehicle and it is factory set - and it is not readily changeable with a diagnostic cable like VCDS - I would be delighted to be advised otherwise!
I'm not sure if this facility can be altered in the "engineering screen", or whether the coding is contained in module firmware (parameters) - again, happy to be told otherwise
Spacewalker
Poland
C?ID=159607
radio is control via CAN...... so what is send via CAN over gateway , is broadcasting to other controlers in proper time, proper ID, and proper frame
if you change by yourself logic .... then other module will see error due to coresponding with 5F
with kessy - engine off and infotinment is working
door open -- then all is shut down
is like key remove
Szogun
Poland
C?ID=403301
Thanks for replies. It's good to know that is interesting topic.
I have Leon with MIB1 and there everything works as it should.
But on the holiday I rented Leon with MIB2, and there radio was shutting down after door open.
In mean time I was talking with my friend - He has A3 8V (etron)with MIB1 and keyless system and the radio is shutting down with engine shut off.
And in the other A3 8V, but with MIB2 system and keyless system the radio is playing, after engine shut off, until driver door are opened.
So maybe there is a difference with MIB1/MIB2 unit?
I can upload autoscan and 5F adaptation from Leon 5F with MIB1 today.
But I don't had even OBD eleven on holiday - so I didnt make a scan Leon with MIB2.
Maybe someone can upload? @Ovidel ?
@iichel Can you tell me more about s-contact?
iichel
Eindhoven, NB, NL
C?ID=284912
s-contact is basically the click you used to hear when the key was removed, while it was already off.
it used to be a physical wire, nowadays it's a software message from either the bcm, steering column electronics or kessy/elv module
@iichel: on MQB platform cars, the "s-contact" is still a physical, single-throw, single-contact switch. It is embedded into the rear of the electrical multi-switch that sits on the back of the ignition key barrel (the wires terminate on the hex44 module connector).
I show the s-contact as "C key-switch" on my test-bench picture below (I modified the ignition switch to bring-out the s-contact onto a separate external switch for ease of operation)
justin 13703
Maryland, USA
C?ID=417194
I dont know if this will apply at all to the platforms in question, but on my NMS Passat with keyless ignition, changing the instrument cluster country code to "Germany" made the radio stay on after the ignition was turned off, until the driver door was opened. Just had to change units back to imperial from metric on the display.
Szogun
Poland
C?ID=403301
I'll check it today and let you know
iichel
Eindhoven, NB, NL
C?ID=284912
Don, thank you, and yes, I am by no means reluctant to agree with you.
What I was trying to explain, and failed, is that the S contact itself is a physical wire. But the message to, i.e. the radio, is software controlled.
On my ELV, part of the kessy system, I am in fact able to control the behaviour of the S-contact (physical wire to the BCM, software message to the radio)
Szogun
Poland
C?ID=403301
I have autoscan for A3 E-tron with MIB1 and this problem. It shuts down infotainment after engine shut down.
Maybe it will be easier to try this on example.
Friday,03,September,2021,11:23:36:16626
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4544.4
VIN: WAUMPBFF5GA119751 License Plate:
Chassis Type: FF-AU37 (5QE)
Scan: 01 02 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 6C
75 8C BB BC C0 C6
VIN: WAUMPBFF5GA119751 Mileage: 75737km-47060miles
Address 01: Engine (J623-CXUA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 H HW: 04E 907 309 F
Component: R4 1.4l TFSI H22 9130
Revision: X3H22---
Coding: 021D0012632401083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM14TFS01104E906023H 006003
ROD: EV_ECM14TFS01104E906023BD.rod
VCID: 2517F4B9F5650903DC5-8070
Part No SW: 0DD 300 045 P HW: 0DD 927 770 B
Component: GSG DQ400E H31 1122
Revision: 00031033 Serial number: TFK01510290272
Shop #: WSC 00099 780 00200
ROD: EV_TCMDQ400021_VW37.rod
VCID: 343119FD4EBF608B5BB-8060
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 907 379 AK HW: 5Q0 907 379 H
Component: ESC H31 0809
Revision: 00000000 Serial number: 60176000000991
Coding: 12FF409238213275017E020581C42948021C4C80408194F402A100588609
Shop #: WSC 12345 777 89765
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_001.rod
VCID: 0557943955A52903BC5-8050
Revision: 00021000 Serial number: 0392632173
Coding: 030C0C
VCID: 3A2D37C56CDB96FB817-806E
Part No SW: 8V0 820 043 J HW: 8V0 820 043 J
Component: AC Automat H06 0510
Revision: 20012000 Serial number: 00000000840923
Coding: 0300001001000000000000000000140001000000
ASAM Dataset: EV_AirCondiFrontNARAU37X 001015
ROD: EV_AirCondiFrontNARAU37X.rod
VCID: 392F28C969DD9DE388D-806C
Subsystem 1 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G395 pT-Sens1 H61 0006
Subsystem 2 - Part No SW: 12E 963 231 F HW: 12E 963 231 F
Component: J848 HV-PTC H09 0206
Serial number: LM160273003807000281
Humidity sensor: exterior:
Subsystem 3 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0003
Serial number: D6080C08000000000001
A/C compressor sub:
Subsystem 4 - Part No SW: 12E 820 803 D HW: 12E 820 803 D
Component: J842 eKK H02 0004
Serial number: IADD00000K0000000194
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AH HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061601400071
Coding: 04151C46C25106FD41CC5004531407A80800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 7F5B06D1377973D3F69-802A
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 151227 043 0580
Serial number: 160119010157
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 61237224
Coding: 02006C
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 19 10 2015 00000158
Serial number: 00000000000064798094
Sunroof control module:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000RO01G00000
Coding: 101F00
558100 - Databus
Fault Frequency: 21
Reset counter: 74
Mileage: 75331 km
Date: 2021.08.26
Time: 16:47:59
721416 - Switch for Sunroof
B13C4 29 [008] - Signal Implausible
Reset counter: 70
Mileage: 75617 km
Date: 2021.09.01
Time: 19:07:45
721420 - Switch for Sunroof
B13C4 01 [008] - Electrical Failure
Reset counter: 70
Mileage: 75617 km
Date: 2021.09.01
Time: 19:07:45
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391602201906
Coding: 0010150011
VCID: 43D34A211B11D733D21-8016
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR049N4C
Coding: 9DFCFCC0002000009000001AC24800000065
VCID: 47CB5E312F29FB130E9-8012
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34230167A25011650501
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34230168A21011650408
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001FTRAF
Coding: 303333
Subsystem 4 - Part No SW: ----------- HW: 480 002 701 16
Serial number: 357000000004B941C81M
Subsystem 5 - Part No SW: ----------- HW: 480 002 701 16
Serial number: 35800000000F9941C81W
Subsystem 6 - Part No SW: ----------- HW: 480 402 701 16
Serial number: 35100029F1EDD3E303BO
Subsystem 7 - Part No SW: ----------- HW: 480 402 701 16
Serial number: 35200029F1EDD3E3316L
Subsystem 8 - Part No SW: ----------- HW: 480 400 712 15
Serial number: 3550002B71D73C641341
Subsystem 9 - Part No SW: ----------- HW: 480 400 712 15
Component: FrontSensor_P 001 6149
Serial number: 3560002B31D73C60C0CA
9445929 - Seat occupied recognition control module
B1022 29 [008] - Signal Implausible
Fault Frequency: 20
Reset counter: 74
Mileage: 75331 km
Date: 2021.08.26
Time: 16:48:04
9577755 - Sensor Mat for Seat Occupied Detection
B1225 1B [008] - Resistance Too High
Fault Frequency: 26
Reset counter: 74
Mileage: 75331 km
Date: 2021.08.26
Time: 16:47:59
Part No SW: 8V0 953 521 FB HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 27011608490949
Coding: A418
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_009_AU37.rod
Part No SW: 8V0 920 972 G HW: 8V0 920 972 G
Component: KOMBI H03 6423
Coding: 0B6D0C192B8000080003BA101B00000000000000
VCID: 42DD4F25040BDE3BD97-8016
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 E HW: 5QE 907 530 A
Component: GW MQB EV 312 3244
Revision: -------- Serial number: 22011610800142
Coding: 0201001726F200005B00120C580000000001010100010000000000000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 48C95D0D2237F46B073-801C
Subsystem 1 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 24 01 2016 F0071018
Subsystem 2 - Part No SW: 5QE 915 181 HW: 5QE 915 181
Component: J367-BDMHella H04 8050
Serial number: 5987128703
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430011076
Coding: 03720100331A02030002050500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_003.rod
VCID: 4FFB7611C7592353469-801A
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861260116171226
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000011503002
Coding: 0D00000000000000
ROD: EV_ELVMarquMQB.rod
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 311015BJU15448
Coding: 001C1F204000048000000002
VCID: 41DF4029010DC523C0D-8014
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: C102
VCID: 44D1493D1E1FD00BEBB-8010
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 D HW: 5G0 907 080 D
Component: VW370P3815010 H07 4492
Revision: 00H07000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM09550115G0907080D 001018
ROD: EV_DMCM09550115G0907080D.rod
VCID: 2809FD8D8277146BE73-807C
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 091115BK714123
Coding: 001C17204C00048000000002
Shop #: WSC 34567 789 23456
VCID: 40D9452D0A07CC2BCF3-8014
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 011A000123200400
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FDB46D177F9B3D3B69-806A
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 C HW: 8V0 035 844
Component: MU-S-S-US 014 0660
Serial number: A7A01201160957
Coding: 01730301FF0A000021110001001A00002F0301040100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
Multimedia System 1:
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30G43X
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: ALJAL101121500020100
B11CF 53 [009] - Deactivated
Reset counter: 35
Mileage: 75737 km
Date: 2021.09.03
Time: 10:51:27
Voltage terminal 30: 13.1 V
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 303915EDBAA75CAB3F3-8064
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 017393011094BA0100F800000000
ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5Q0 915 182 E HW: 5Q0 915 182 C
Component: BECM H05 1101
Serial number: TA020001
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006042
ROD: EV_BECM06020115C6915182_VW37.rod
VCID: 353724F945C579836C5-8060
Battery interrupt switch:
Subsystem 1 - Part No SW: 5Q0 915 250 D HW: 5Q0 915 250 D
Component: BJB H27 0240
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D1 H14 0481
Serial number: V013C15A1031480
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D2 H14 0481
Serial number: V013C15A1031509
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D3 H14 0481
Serial number: V013C15A1130215
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D4 H14 0481
Serial number: V013C15A1031510
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D5 H14 0481
Serial number: V013C15A1130012
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D6 H14 0481
Serial number: V013C15A1130065
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D7 H14 0481
Serial number: V013C15A1130009
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D8 H14 0481
Serial number: V013C15A1130216
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 161215BLF0156A
Coding: 000C17204000048000000002
Component: TSG HBFS 020 0041
Serial number: 161215BLF01585
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 L HW: 5QE 035 335 B
Component: E_SOUND_SG H08 0211
Serial number: EN154802980000
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 006013
ROD: EV_ENoiseS1NNVW3707_006.rod
VCID: 4ACD67053C3B067B117-801E
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AB HW: 5QE 915 682 AB
Component: OBC KOSTAL H61 3012
Revision: -------- Serial number: 2001160L700059
Coding: 105168003000
ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
VCID: 0D47AC190DD55143F45-8058
End----------(Elapsed Time: 02:07, VBatt start/end: 13.2V/13.2V)-----------
I have admap for 09,16,17,44,51,2B,5F - if it will help.
