- Aug 10, 2016
- 3,759
- 4,173
- Netherlands, eastern part
- C?ID=284912
The turbocharger was replaced and the correlation between N75 opening/closing and turbocharger position arm is out of order.
Boost is about 300mbar too high at certain points and the car rightfully complaints about overboost and goes into limp home mode.
Tried to adapt the turbocharger via 0x01 - Login - Basic settings - adaptation of the turbocharger. But no lock.
Engine rpm increases a little, but basic setting says 'not running' and unable to start via pressing and releasing brake pedal and/or accelerator pedal.
Clearing the errors will make them return after a short drive. I believe adapting the turbocharger will solve the issue, but somehow it's not happening.
Perhaps VCDS is not capable, perhaps conditions not right (engine on/off?), perhaps temperature not OK, perhaps engine is being stupid?
Please turn off the sound since there was a torrential rain...
Sunday,22,August,2021,16:57:29:11868
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4544.4
Data version: 20210318 DS325.0
Dealer/Shop Name: iichel retrofitting
Workshop Code: 470 31889 031889
VIN: License Plate:
Mileage: 73220km-45496mi Repair Order:
Chassis Type: 1K-VW36 (7E0)
Scan: 01 02 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55
56 57 61 65 69 6C 77 0B
VIN: Mileage: 73220km-45496miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 DR HW: 03L 906 023 A
Component: R4 1.6l TDI H23 9978
Revision: --H23--- Serial number: 00000000000000
Coding: 00254036032401080000
ASAM Dataset: EV_ECM16TDI02103L906023DR 003016
ROD: EV_ECM16TDI02103L997557Q.rod
VCID: 79AF10A5095BB703C8D-802C
7286 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [175] - Implausible Signal
Mileage: 73224 km
Date: 2021.08.21
Time: 05:04:47
Engine RPM: 780.25 /min
Normed load value: 41.6 %
Coolant temperature: 43 ∞C
Intake air temperature: 23 ∞C
Voltage terminal 30: 12.988 V
Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 7.074 %
Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 85.001 %
High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 84.998 %
High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 0.718 V
Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
Turbocharger boost control: offset closed-V_BPA_TOL[0]: 3.501 V
High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 76
Readiness: 1 1 0 0 1
Address 02: Auto Trans
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885412500C5841A146E825500521504
Shop #: WSC 31889 470 31889
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: N/A
VCID: 0F7B4E7D27DF89B3069-805A
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW36)
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
Shop #: WSC 31889 047 31889
VCID: 372BD69D7FCF61737E9-8062
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E0B773-806C
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 247
Mileage: 73224 km
Date: 2016.01.12
Time: 05:03:17
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 173171327
Coding: 3EB82BBFA8EB3400B33807F0BFCB9FF0FF8067EFE08D78D031E400030800
VCID: 2B03FAEDB307D5930A1-807E
Subsystem 1 - Part No: 5K7 955 547
Component: RLHS 220816 0 42 0106
Coding: 0214DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Subsystem 4 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K0 951 605 C
Subsystem 6 - Part No: 1K8 951 171 A
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU027011200011418
Coding: 58BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
03431 - Activation of Left Parking Light
Reset counter: 247
Mileage: 73224 km
Date: 2016.01.12
Time: 05:11:34
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391528804191
Coding: 0031195101
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
12718592 - Databus
[Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Reset counter: 247
Mileage: 73224 km
Date: 2021.08.21
Time: 05:03:17
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX0142TCE
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F691C3DEC9B117-801E
Serial number: 3575HRB40650BI7U48C8
Serial number: 3585HRB405J09RECEOUJ
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140F01
VCID: 3333E28D6BB78D53421-8066
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuerger‰t f¸r Reifendruck¸berwachung: keine Kommunikation]
Reset counter: 32
Mileage: 73224 km
Date: 2021.08.21
Time: 05:11:30
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042204
VCID: 688945E162713E8B273-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000010000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2E05F3F98095A0BB2DF-807A
Component: IMMO H04 0709
Coding: 000007
VCID: 6A8D3FE97CFD0C9B317-803E
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [009] - -
Mileage: 73224 km
Date: 2021.08.21
Time: 05:03:20
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3BEEFD879FA9B3269-807A
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7666620365
Coding: 010100
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 H
Component: RNS-MID H26 6276
Revision: AB001001 Serial number: VWZ6Z7P1950254
Coding: 00070002010000A10001
VCID: 3635DB997845987B65F-8062
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
Component: J0769 SWA MasterH13 0120
Revision: 00H13000 Serial number: 6PZ 009 014-07
Coding: 0010161
Shop #: WSC 02756 790 00000
VCID: 2F3BEEFD8B1FA9B3269-807A
Subsystem 1 - Part No: 7E0 907 568 B
Component: J0770 SWA Slave H09 0110
Subsystem 2 - Serial number: 6PZ 009 014-27
Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AD HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3124
Serial number: CF3F0205
Coding: 001F00
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE8BE73-807C
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Coding: 0D4A000001000000
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A2DCFA94CDD7C1B817-806E
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 57: TV Tuner Labels: None
Part No SW: 3C0 919 148 B HW: 3C0 919 148
Component: R78 DTV-JP 0250
Revision: R0H14000 Serial number: 80100800042102
Coding: 0000816
Shop #: WSC 01324 020 00200
VCID: 280905E1AEF1FE8BE73-807C
Subsystem 1 - Part No: 4F0 919 805
Component: R204 TVKLeser 0010
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030F7A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058319
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0080
Revision: 3A002002 Serial number: 00000116932377
Coding: 0100000100000000
VCID: 2F3BEEFD871FA9B3269-807A
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Revision: 00H08000 Serial number: 525PA8-J060533
Coding: 0030115
VCID: 65974CD5996323E31C5-8030
03006 - Back-up Camera System not calibrated
Reset counter: 247
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105254406
Coding: 020100000100010000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 25170CD5D563E3E3DC5-8070
End----------(Elapsed Time: 03:00, VBatt start/end: 14.2V/14.1V)-----------
