Audi Q2 2017- Auto Trans -- Status: Malfunction: 0817 - Clutch 1/ P189A 00 [044] - Clearance too Small
Pfaizulla
UK (?)
C?ID=322498
Hi all,
My Audi Q2 (2017, automatic, mileage 22,839km) shows the following fault in the gearbox (bold).
The car drives normally as far as I can tell and no light indicators are on. I found the error when I did an auto scan. Any advice on how to resolve this issue. thanks, P.
Saturday,21,August,2021,17:29:29:37038
VIN: WAUZZZGA6HA053787   License Plate: KT17EOO
Mileage: 22839km-14191mi   Repair Order:
Chassis Type: GA-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F 6C A5 BB BC
VIN: WAUZZZGA6HA053787   Mileage: 22839km-14191miles
Address 01: Engine (J623-DDYA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 AN    HW: 04L 907 445 E
   Component: R4 1.6l TDI   H01 4114
   Revision: 22005001
   Coding: 0225401243651D092000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM16TDI03004L906056AN 004006
   ROD: EV_ECM16TDI03004L906056AN_004.rod
   VCID: 79AFE70B59505823C8D-802C
Readiness: N/A
   Part No SW: 0CW 300 041 E    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1004
   Revision: 00005026    Serial number: CU501704076373
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 372B21332FC48E537E9-8062
10817 - Clutch 1
                    Fault Frequency: 8
                    Mileage: 22735 km
                    Date: 2021.08.17
                    Time: 10:30:35
                    Engine RPM: 9998.25 /min
                    Engine torque: 36 Nm
                    Vehicle speed: 58 km/h
                    Control Module temperature: 53 ∞C
                    CURRENT pressure: -5.5 bar
                    Driving position: Tiptronic
                    Accelerator pedal position: 0.0 %
                    DTC memory status: 47616
   Revision: 00000000    Serial number: 61007000001023
   Coding: 34008A8D34250C6F8B7E0E0860CA242C512C30D1700624F31841F074823B4200002B64121213122835351919323200
   VCID: 77ABE1336F444E53BE9-8022
   Part No SW: 8V0 820 043 L    HW: 8V0 820 043 L
   Component: AC Automat    H03 0130
   Revision: 20003000    Serial number: 00000001220185
   Coding: 06100104002000001000000000001000
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 3B233D0313ECAA339A1-806E
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 3C2943A800PAG0MUFU03
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001709504399
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5B091347747613F69-802A
   Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Serial number: 20372220X81A955555A0
   Coding: 80005E
   Subsystem 2 - Part No SW: 8V0 941 531 BE    HW: 8V0 941 531 BE
   Component: E1 - LDS MQB  H06 0032
   Serial number: 25 01 2017  00000119
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY170822292
   Serial number: 00000000000069349111
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Reset counter: 162
                    Mileage: 22735 km
                    Date: 2021.08.16
                    Time: 21:01:06
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617099
   Coding: 0470151011
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4ACD68C74C3603BB117-801E
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 3200E7C214FF8728747C60458040A7
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   Part No SW: 5Q0 959 655 AQ    HW: 5Q0 959 655 AQ
   Component: AirbagVW21    003 0318
   Serial number: 003T8R2VKNS%
   Coding: 88CCF0C000000000585400DFC0C800000065
   VCID: 0F7BB9D377D46693069-805A
   Subsystem 1 - Part No SW: -----------    HW: 480 001 404 17
   Serial number: 35700000000A70381326
   Subsystem 2 - Part No SW: -----------    HW: 480 001 404 17
   Serial number: 3580000000006038132$
   Subsystem 3 - Part No SW: -----------    HW: 480 401 804 17
   Serial number: 3510001A124CEF22C7DI
   Subsystem 4 - Part No SW: -----------    HW: 480 401 804 17
   Serial number: 3520001A124CEF215292
   Subsystem 5 - Part No SW: -----------    HW: 480 401 204 17
   Serial number: 3550001A7255D2949510
   Subsystem 6 - Part No SW: -----------    HW: 480 400 704 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001AD257C4446668
   Part No SW: 8V0 953 521 HR    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 14041704221539
   Coding: EC5C
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 117FBFAB61E0706310D-8044
   Part No SW: 8V0 920 972 P    HW: 8V0 920 972 P
   Component: KOMBI         H04 8317
   Coding: 2784220C678426000180E8001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 4BC36DC3434C1AB32A1-801E
   Component: GW MQB High   515 5286
   Serial number: 06041710800588
   Coding: 030100041F0873005B000258180B00000001010000000000000000000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 2F3B1953D7944693269-807A
   Generator:
   Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
   Component: J453 MFL  H04 0003
   Serial number: 20170412084608 20380
   Serial number: 75886000001704130D39
8520138 - Control Module for Battery Monitoring
          P1B02 00 [009] - Defective
                    Reset counter: 121
                    Mileage: 22731 km
                    Date: 2021.08.16
                    Time: 20:41:00
                    Terminal 30 power supply: 14.1 V
                    Terminal 15: On
   Serial number: 050417ED433222
   Coding: 00128A205C01040000001003
   VCID: 43D345E36B1CD2F3D21-8016
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D38071CD6933B817-806E
   Serial number: 290317ECS17979
   Coding: 001282205E01040000001003
   VCID: 42DD40E77406DBFBD97-8016
   Part No SW: 81A 035 192 D    HW: 81A 035 192
   Component: MU-HS-LND-EU  045 0191
   Coding: 01720601FF0A000011111101000A00102F0036C601F001008E
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 221DE0679446FBFBB97-8076
   Subsystem 1 - Part No SW: 8W0 919 866 M    HW: -----------
   Component: ECE 2017  --- 0024
   Multimedia System 1:
   Subsystem 2 - Part No SW: 81A 919 604     HW: 81A 919 604
   Component: DU Std AU216  H41 0080
   Serial number: INX00119011700020965
   Subsystem 3 - Part No SW: 81C 919 614 A    HW: 81C 919 614 A
   Component: ControlUnit_B  H20 0200
   Serial number: APVAK120031700060164
2562 - Navigation System
          B126C F0 [008] - Navigation Database Faulty
                    Reset counter: 167
                    Mileage: 22445 km
                    Date: 2021.08.06
                    Time: 15:59:10
                    Voltage terminal 30: 12.7 V
   Coding: 0272060102002001400040
   VCID: 392F270B19D0982388D-806C
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 05041711K13369
   Coding: 040207060000040101021344814EA90098000E000020
   ROD: EV_MFKBoschMQBB_VW46.rod
   VCID: 3C213E1F16E2AD0B93B-8068
   Serial number: 010417ECU3262C
   Coding: 000082004001040000001002
   VCID: 45D75BFB6528ECC3FC5-8010
   Serial number: 010417ECU32629
End----------(Elapsed Time: 01:29, VBatt start/end: 14.2V/14.3V)-----------
Engine rpm 9998 ??
Yes, that seems quite strange. With such low miles, I would check with a dealer to see if there are any software updates available for the TCM.
Discovered RT page HERE. (click on "here")
HW: 0AM 927 769 E
Pfaizulla
UK (?)
C?ID=322498
I took the car to an Audi Dealer for a diagnostics and this is what they said: "Carried out GFF, found fault in vehicle with Mechantronic clutch fucnton, checked for relevant TPI's found TPI; 2058137/6 Require gearbox t be removed and reinstalled, remove & install multi clutch pack. will require parts may require multi clutch plate 8 HRS labour." cost: 2,304,07 GBP
@Uwe any thoughts?
thanks,
P
@Uwe any thoughts?
Given that the vehicle has less than 15,000 miles on it, that's inexcusable. I would be on the phone with your local Audi importer/representative and see about getting this repair covered by Audi.
Pfaizulla
UK (?)
C?ID=322498
Thanks for this. I am trying to get Audi Warranty department to step in but so far they are saying because the car has not been serviced with Audi (in fact, I do not have service history at all/ I bought it without it), they can not cover the cost for this. I am not sure how a normal servicing or lack thereof would affect the gearbox! I am thinking of complaining/escelating to Audi itself.
