Hi
First I want to start with that I hope all is healthy and doing well on these harsh 'corona' times, I think positivity is the key!
To my main issue
I recently had a VW Tiguan year 2009 (5N) type where a friend lost all his keys to it
the procedure for me to be able to make and adapt a new key to the car includes removal of the instrument cluster.
After I was finish with my job the ABS, ESP and Parking brake is blinking like a christmas tree.
I was not sure what the problem is so I tried to check online for some Settings with VCDS which have helped me many times before,
however this time It didnt go as I wanted to.
After some searching on forum and google I think problem is with coding!
and I read somewhere that in service book there is a picture that might help with this issue but I cant figure it out how.
I upload that image here!
I have scanned the car and I upload the scan here to see if anyone have the time and will to try to help me to fix this issue since this
was not present before I made the key!
Here is the scan below
I have taken the car now to my garage and I have it overnight and hopefully this is a really easy fix! If needed I could go to my garage anytime!
With kind Regards
Hikahuza~
To my main issue
Friday,20,August,2021,18:58:04:62265
VCDS Version: 21.3.0.0 (x64)
VIN: WVGZZZ5NZ9W028209 License Plate: HOZ027
Mileage: 255550km-158791mi Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 03 08 09 15 16 17 18 19 1C 22 25 42 44 46 52 53 56 62 69
72
VIN: WVGZZZ5NZ9W028209 Mileage: 255550km-158791miles
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 997 016 M HW: 03L 906 022 G
Component: R4 2.0l TDI G000SG 9980
Revision: 13H01--- Serial number: VWX7Z0H63NM105
Coding: 0000172
Shop #: WSC 33314 003 1048576
VCID: 3C4F76CC7F989E6BDF-8068
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 L HW: 5N0 614 517 L
Component: J104 C2 450 V2 0006
Revision: --H12--- Serial number: 00000001323434
Coding: 0010000
Shop #: WSC 01324 785 00200
VCID: 374569E046BEBD3332-8062
Reset counter: 195
Mileage: 255557 km
Time: 05:55:41
Hex Value: 0x0009
Voltage: 13.75 V
Bin. Bits: 00011111
Count: 166
Hex Value: 0x0000
03201 - Adaptation Overboost
Reset counter: 195
Mileage: 255557 km
Time: 05:55:41
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DC HW: 1K0 907 044 DC
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6BED85904A76C9D306-803E
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000008707644
Coding: ED8A8FA301041C0047190000140000000008FF475C400124390000000000
VCID: 335D5DF052C651130E-8066
Subsystem 1 - Part No: 5N1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 180708 012 0203
Coding: 00038805
Shop #: WSC 01324
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 250608 046 0204
Coding: 00208933
Shop #: WSC 01324
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__200 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPDRPGTV
Coding: 0012336
VCID: 3B4D75D07A969953D6-806E
Subsystem 1 - Serial number: 6333FTS615951948
Subsystem 2 - Serial number: 6343FTS6B800001B
Subsystem 3 - Serial number: 6353ETS60BTAUVNH
Subsystem 4 - Serial number: 6363ETS6U9JAUVNH
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0101
Coding: 0002022
VCID: 0131C73858FA3383CC-8054
Component: E0221 002 0010
Part No SW: 5N0 920 870 D HW: 5N0 920 870 D
Component: KOMBIINSTRUMENT VDD 2420
Revision: V0004000 Serial number: VWX7Z0H63NM105
Coding: 0007104
Shop #: WSC 80093 222 69422
VCID: 315157F8A8DA63037C-8064
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 1K0 815 007 BH
Component: Standheizer 042 4404
Revision: 00042000 Serial number: 09011075000000
Coding: 0001012
Shop #: WSC 80093 222 71269
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 100708F2003250
Coding: F9827F46001A026002
VCID: 355963E85CB24F2320-8060
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T3Q7303
VCID: 7DC9BBC824025763A8-8028
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0AY 907 554 C HW: 0AY 907 554 C
Component: Haldex 4Motion 0041
Coding: 0000005
VCID: 4BAD25102A3629D366-801E
Component: IMMO VDD 2420
Shop #: WSC 00137 211 56823
Part No SW: 5N0 959 701 HW: 5N0 959 701
Component: Tuer-SG 006 1205
Coding: 0000188
VCID: 72D398F46D5C181BC5-8026
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 G HW: 5N1 909 148 E
Component: J500__APA-BS KL.095 0401
Revision: 1AH01251 Serial number: 00080590059802
Coding: 0000258
Shop #: WSC 40752 222 91593
VCID: 365B64E441B4443B29-8062
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Revision: 00020000 Serial number: 00000000000000
Coding: 80800A0052830C7F3F04840560084F0BE0FC00
VCID: 033DCD3042E62193DE-8056
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Fault Status: 01100111
Reset counter: 181
Part No SW: 5N0 959 702 HW: 5N0 959 702
Coding: 0000188
VCID: 73DD9DF012461113CE-8026
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 5N0 907 801 B HW: 5N0 907 801 B
Component: J540 EPB3 VW-09384 0005
Revision: H09 Serial number: 00000000096927
Coding: 0000057
Shop #: WSC 22894 210 01865
VCID: 2E6B4C84B9E47CFB61-807A
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 012 0029
Revision: 00000000 Serial number: VWZ1Z2H5503100
Coding: 0500040004
VCID: 6BED85908A76C9D306-803E
Reset counter: 153
Mileage: 254600 km
Time: 03:06:56
Part No SW: 5N0 959 703 HW: 5N0 959 703
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 01324 785 1012552
VCID: 74DF9EEC1748162BD7-8020
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0050
Revision: 3A002002 Serial number: 00000112833680
Coding: 0100000100000000
VCID: 2F5551807EEE75F36A-807A
16355 - Control Module - Watchdog Timer
014 - Defective
Fault Status: 01101110
Reset counter: 27
Mileage: 141547 km
Time: 09:25:10
Part No SW: 5N0 959 704 HW: 5N0 959 704
Coding: 0000144
VCID: 75D9A3E81C320F23E0-8020
End-------------------------(Elapsed Time: 01:37)--------------------------
With kind Regards
Hikahuza~
