My 2016 Skoda Superb has an intermittent Check Engine light issue, VCDS showing codes P2014, P2004 and P2015. The light first came on a year and a half back after a routine maintenance service at the Authorized Service point. In addition to the regular service, the front windscreen was also changed. Under the output tests section, the IMRC test doesn't work with the engine running, only with Ignition On Engine Off. With an external source of vacuum attached to the line going into the solenoid for the IMRC, the test shows the flaps to be working fine. I've observed that vacuum at the port where the solenoid inlet pipe is attached is negligible, although the brake booster gets proper vacuum. Is is normal for one port to have barely-there vacuum, or have I located the genesis of my error codes. Please guide.
Monday,16,August,2021,16:46:11:46039
VCDS Version: 21.3.0.0 HEX-V2 CB: 0.4544.4
VIN: TMBBLFNP1GA300921 License Plate:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 36 42 44 47 52 55 5F 6C
6D BB BC CA
VIN: TMBBLFNP1GA300921 Mileage: 43712km-27161miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CJSA) Labels:. 06K-907-425-V1.clb
Part No SW: 3G0 906 264 HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 0C2500122424040B3000
Shop #: WSC 33361 790 00000
ASAM Dataset: EV_ECM18TFS0203G0906264 001006
ROD: EV_ECM18TFS020_VW48.rod
VCID: 6597BAAEE5EAFB531C5-8030
15197 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 00 [172] - Electrical Malfunction
Mileage: 41634 km
Date: 2021.06.23
Time: 16:25:43
Engine RPM: 5687.25 /min
Normed load value: 100.0 %
Vehicle speed: 102 km/h
Coolant temperature: 95 °C
Intake air temperature: 57 °C
Voltage terminal 30: 13.515 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 75 s
MAP_MES_SAE: 178 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.934 V
FAC_TPS_1_SAE: 85.937500 %
FUP_H_SAE: 19920.0 kPa
15198 - Intake Manifold Flap; Bank 1
P2004 00 [236] - Stuck Open
Mileage: 41631 km
Date: 2021.06.23
Time: 16:08:57
Engine RPM: 1759.50 /min
Normed load value: 19.2 %
Vehicle speed: 34 km/h
Coolant temperature: 101 °C
Intake air temperature: 61 °C
Voltage terminal 30: 13.496 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 912 s
MAP_MES_SAE: 65 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
FAC_TPS_1_SAE: 18.359375 %
FUP_H_SAE: 11090.0 kPa
15195 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 00 [032] - Implausible Signal
Mileage: 42978 km
Date: 2021.07.12
Time: 20:50:08
Engine RPM: 790.00 /min
Normed load value: 23.9 %
Coolant temperature: 48 °C
Intake air temperature: 44 °C
Voltage terminal 30: 13.847 V
Unlearning counter according OBD: 29
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 6 s
MAP_MES_SAE: 35 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 13.671875 %
FUP_H_SAE: 14610.0 kPa
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 048 R HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0610
Revision: 00005005 Serial number: CU501603265560
ROD: EV_TCMDQ200021_VW26.rod
VCID: 4BC36C16634E2D232A1-801E
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 60976000004946
Coding: 1D07929C34200B6C0780060241C449B8492CD0E0608292B50043F038C202
VCID: 79AFE6DE79526FB3C8D-802C
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0398752985
Coding: 030C0C0703
ROD: EV_KessyHellaMQBAB.rod
VCID: 3A2D39D23CD4A4AB817-806E
Subsystem 1 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65059003
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 3V0 907 044 AL HW: 3V0 907 044 AL
Component: AC Automat H32 3701
Revision: 20K05000 Serial number: 00000B00093845
Coding: 11110004100100010005100000001402
ASAM Dataset: EV_ACClimaPrehVW37X 002012
VCID: 7EA5F5C2607C488BFDF-802A
Rear A/C control head:
Subsystem 1 - Part No SW: 3V0 907 049 B HW: 3V0 907 049 B
Component: E265KlimaHeck H02 0101
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061609702558
Coding: 0F919A46C0C722FB57C44086B10817240800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 0451872A0E90225BABB-8050
Subsystem 1 - Part No SW: 3V2 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x RL 160325 032 0121
Serial number: 00000001603230301441
Coding: 165DDD
Component: RLHS 037 0059
Serial number: S5Y16M04D13H20M37S27
Coding: 00084D
Subsystem 3 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY160268MEJ
Serial number: 00000000000065407364
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0072930
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0137191
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0135949
Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0137182
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 136
Mileage: 41633 km
Date: 2021.06.23
Time: 16:23:58
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391609804437
Coding: 0071151011
VCID: 44D1472A4E10E25BEBB-8010
Part No SW: 5Q0 959 655 AE HW: 5Q0 959 655 AE
Component: AirbagVW21 005 0130
Serial number: 003NSR1LF4E7
Coding: 88FCC0C0000000004000000000C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
VCID: 035384360B9E2563921-8056
Subsystem 1 - Part No SW: ----------- HW: 480 002 504 16
Serial number: 35700000000DE5914A1T
Subsystem 2 - Part No SW: ----------- HW: 480 001 304 16
Serial number: 3580000000062B908A1K
Subsystem 3 - Part No SW: ----------- HW: 480 401 703 16
Serial number: 3510002B9200CA04431O
Subsystem 4 - Part No SW: ----------- HW: 480 401 703 16
Serial number: 3520002B5200CA01308L
Subsystem 5 - Part No SW: ----------- HW: 480 401 703 16
Serial number: 3550002B5200CA00715P
Part No SW: 3Q0 953 521 E HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160401500702
Coding: 1014
ROD: EV_SMLSVALEOMQB.rod
VCID: 323D11F2E4A45CEB497-8066
Part No SW: 3V0 920 710 HW: 3V0 920 710
Component: KOMBI 306 6422
Coding: 27A5011A2B800008010B2A001000000000000000
Shop #: WSC 73430 031 00000
VCID: 6C81CF8A0600CA1B43B-8038
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004779947
Coding: 0101000874085900EB00020A1C0F00000001070000000000000000000000
ROD: EV_GatewLear_013.rod
Generator:
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000B1269110718
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000071825004
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFDEFE212227F370D-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 A HW: 5Q0 959 760 A
Component: Sitzmemory H06 0009
Serial number: Y0006PC314456
Coding: 001400000000000001A080808080000000008181000000D4
ASAM Dataset: EV_SeatMemorDriveSide 001015
ROD: EV_SeatMemorDriveSide_001.rod
VCID: 3B233CD633EE9DA39A1-806E
Component: TSG FS 020 0041
Serial number: 270316ECQ17036
Coding: 001D0920DE01040000001100
VCID: 43D344364B1EE563D21-8016
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 8102
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 466 A HW: 3Q0 035 466 A
Component: MIB2_amp_P_SK H02 0250
Revision: 00000001 Serial number: SKZ8Z1GAS01N5D8
Coding: 0384010000AA002FAA0000000000
ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
ROD: EV_AMPMst16C5Gen2ALPI.rod
VCID: 2D07028EFD9A0313145-8078
Component: TSG BFS 020 0041
Serial number: 130416EDA02638
Coding: 001D0320DE01040000001100
VCID: 42DD41325404EC6BD97-8016
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 065E02003F000000
VCID: 40D94B3A5A08FE7BCF3-8014
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0006
Coding: B20000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: B20000
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 840 A HW: 5Q0 035 840 A
Component: MU-S--ER H25 0245
Serial number: SKZAZ2S0001206
Coding: 038401000000000011110002001028002F0203E60120010002
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 2B030C96C38E0D230A1-807E
Subsystem 1 - Part No SW: 3V0 919 605 HW: 3V0 919 605
Component: ABT_Std-2 H46 1031
Serial number: SKZ8Z9SFD0049Z
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H09 0170
Coding: 04840101A2002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
ROD: EV_CamSysRVRVCPANAMQBAB_005.rod
VCID: 77ABE0E64F4679C3BE9-8022
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30633951800000
Coding: 1008
ASAM Dataset: EV_DeckLidCONTIAU736 001012
VCID: 3FDB48C627F68183B69-806A
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 180416EDG0294C
Coding: 001C01208001040000001100
Component: TSG HBFS 020 0041
Serial number: 110416ED915917
Part No SW: 4M0 907 594 E HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 508000648101
VCID: 382923DA02D8B6BB773-806C
End----------(Elapsed Time: 01:57, VBatt start/end: 12.1V/12.1V)-----------
