Power Steering too weak Gen3 Golf R mk6 can’t change power assist force
RickNewy
Australia
C?ID=451241
Hi guys,
I’m trying to modify the power steering assist on my 2010 Golf R mk6.
[1k0-909-14xGEN3]
channel #44 Steering Adaptation and #03 Abs doesn’t have any Power adjustable value neither the Steering program to choose from.
Q:There’s a way to keep the power steering assist at the maximum power at all time for Gen3 steering module? 1k0-909-14xGEN3
I found on YouTube that is possible with the JD500 module using the program type 6 “handicap” (heavily increased steering aid)
-Maybe tricking something like vehicle speed, miss-calibrating the torque sensor min/max… etc etc?
As stated on the Ross Tech website the steering adaptation curves for this can be changed only with the factory tool.
https://forums.ross-tech.com/index.php?threads/1139/
Cheers
Rick
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 21.3.0(x64) Data version: 20210226 DS325.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Saturday,14,August,2021,14:32:38:54606
VIN: WVWZZZ1KZAW340484 License Plate: CQA20D
Mileage: 229110km-142362mi Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 52 55 56 62
72 77
VIN: WVWZZZ1KZAW340484 Mileage: 229110km-142362miles
PartNoSW:1K8907115D HW:8P0907115B
Self-Diagnosis Log
Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
Page 2
   Component: 2.0l R4/4V TFSI 0010
Revision: 5BH19--- Serial number:
Coding: 0403000C1C0F0160
Shop #: WSC 00006 067 57207
VCID: 2F3B1A48CB101893269-807A
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - MIL ON
Fault Status: 11100010
Mileage: 228850 km
Date: 2016.01.05
Time: 01:12:03
RPM: 1537 /min
Load: 39.2 %
Speed: 59.0 km/h
Temperature: 74.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Mileage: 228923 km
Date: 2016.01.05
Time: 02:27:56
RPM: 767 /min
Load: 16.1 %
Temperature: 73.0°C
Temperature: 33.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
Self-Diagnosis Log
Page 3
Part No SW: 02E 300 012 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2118
Revision: 51112 Serial number: 00001002230270
VCID: 1B63DE98AFA894337A1-804E
No fault code found. -------------------------------------------------------------------------------
Self-Diagnosis Log
Page 4
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 163B800D092600FA680F01EC901D00813D0000
VCID: 7AADFB1C4CD20D3BC17-802E
02214 - Tire Pressure Warning
Reset counter: 10
Mileage: 228929 km
Date: 2016.01.05
Time: 03:49:54
Count: 4608
Count: 397
Count: 49431
Count: 1
Count: 65023
01169 - Door Contact Switch Driver Side (F2)
Reset counter: 21
Mileage: 229071 km
Date: 2016.01.05
Time: 00:06:43
Count: 16384
Count: 32768
Count: 29184
Count: 147
Count: 51501
Count: 64754
  Count: 3328
Self-Diagnosis Log
Page 5
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000001002
VCID: 7DA7F0005D7C3A03E45-8028
Coding: 009795
Self-Diagnosis Log
Page 6
PartNoSW:1K0937087D HW:1K0937087D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 48180A3A9825F1C044080080240008E441550088736D8960E48000240000
VCID: 323D133CD422357B497-8066
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 26021 21 0512
Component: RLS 010310 05 54 0403
Coding: 0330AD
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Fault Frequency: 9
Reset counter: 19
Mileage: 228629 km
Date: 2016.01.05
Time: 20:32:02
Voltage: 12.35 V
Term 50 Off
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 50
Reset counter: 236
Mileage: 228659 km
Self-Diagnosis Log
Page 7
  Date: 2016.01.05
Time: 14:34:11
Voltage: 14.45 V
Term 50 Off
Fault Status: 00101010
Reset counter: 10
Mileage: 228820 km
Date: 2016.01.05
Time: 20:51:47
Voltage: 14.05 V
Term 50 Off
Fault Status: 00101110
Reset counter: 10
Mileage: 228930 km
Date: 2016.01.05
Time: 22:51:29
Voltage: 11.80 V
Term 50 Off
Self-Diagnosis Log
Page 8
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 D HW: 5K0 919 475
Component: PARKHILFE 8K H07 0010
Revision: -------- Serial number: 48331000400441
Coding: 100104
VCID: 372B22283F40D0537E9-8062
Self-Diagnosis Log
Page 9
PartNoSW:5K0959655D HW:5K0959655D
Component: AirbagVW10 037 0606
Serial number: 003FKRA4D7LY
Coding: 00003131
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B233E1803E8F4339A1-806E
  Serial number: 3572MSME40524351ZZZH
Serial number: 3582MSME391A1551ZZZT
Serial number: 3522QSME22144B7EZZZ.
9443349 - Rear Side Airbag Crash Sensor (on driver's side)
B1018 15 [137] - Open or Short to Plus
Mileage: 228596 km
Date: 2021.08.14
Time: 23:04:04
VCID: 76B5EF2C74CA695BA5F-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Self-Diagnosis Log
Page 10
  Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001632
PartNoSW:5K6920870F HW:5K6920870F
Component: KOMBI H03 0305
Coding: 170F00
VCID: 36352F2C38CA295B65F-8062
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 220210F2000790
Coding: EDA37F06000612000003
Shop #: WSC 01016 959 86335
VCID: 698FB4503574B6A338D-803C
  Address 22: AWD Labels: 0AY-907-554-V1.clb
PartNoSW:0BR907554A HW:0BR907554A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 43D346F877988CF3D21-8016
Coding: 0000692
Self-Diagnosis Log
Page 11
Component: IMMO H03 0305
VCID: 6A8DCB5C3CF2BDBB317-803E
PartNoSW:5N0035342B HW:5N0035342B
Revision: A1001003 Serial number: 7667849237
VCID: 2615FF6CE8EA59DBD5F-8072
PartNoSW:5K0959701B HW:5K0959701B
Component: Tuer-SG 009 2120
VCID: 313F1C30DD240E6330D-8064
00912 - Window Regulator Switch; Front Left (E40)
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 251 3001
Revision: 00H17000
Component: Tuer-SG 009 2114
Self-Diagnosis Log
Page 12
PartNoSW:5K0959702C HW:5K0959702C
  Coding: 0000948
VCID: 3333163827383C73421-8066
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
PartNoSW:5M0907357C HW:5M0907357C
Component: AFS-Steuergeraet 0142
Coding: 1475932
VCID: 3431152422363B4B5BB-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0005
Coding: 00000022
014 - Defective
Fault Status: 01101110
Reset counter: 236
Mileage: 229112 km
Date: 2016.01.05
Time: 21:52:01
Voltage: 12.07 V
ABS 1
Revision: 00000001 Serial number: VWZ1Z3K3009752
Self-Diagnosis Log
Page 13
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 040 0167
  Coding: 0500040004
VCID: 629DA37CC442E5FBF97-8036
03138 - Input AUX IN
  Reset counter: 214
Mileage: 228596 km
Date: 2016.01.05
Time: 23:04:16
PartNoSW:5K0959703C HW:5K0959703C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
PartNoSW:5K0959704C HW:5K0959704C
Coding: 0000144
VCID: 35372820294C22436C5-8060
Self-Diagnosis Log
Page 14
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
PartNoSW:1K8051730B HW:1K8051730B
Component: Telefon H02 5400
Revision: 00002000 Serial number: 20389520248745
Coding: 402120
End----------(Elapsed Time: 01:24, VBatt start/end: 12.0V/12.0V)-----------
TBAx
C?ID=287144
This power steering has characteristics curve 251 installed (as denoted by "Kl. 251" in it‘s identification.
It is too new to allow for a change using adaption channels however if you have another tool besides VCDS, you can just flash another characteristics curve to it. VCDS unfortunately does not support update programming.
RickNewy
Australia
C?ID=451241
Thanks for the explanation!
I’m wondering why other tools can do and VCDS can’t do it but with the previous version or newer is possible… we talking about software not hardware I guess?
Anyway I found another interesting reaction from the power steering,
If I mechanically disconnect the steering angle sensor behind the steering wheel and i put the DSG in “N” the steering becomes perfectly smooth and lighter at any speed.
So I would like to trick the power steering module thinking that the vehicle is always in this “neutral” stage..
Any ideas?
siLc
Tallinn, Estonia
C?ID=330192
You probably have a mechanical issue somewhere. Find and fix that issue and you won't need to resort to hacks.
RickNewy
Australia
C?ID=451241
What do you mean?? It doesn’t matter if this code or one of my cars had issues. We need this hack for all our rally cars whit short steering column
Spacewalker
Poland
C?ID=159607
older steering rack like 2005 ....2006 .... yes, can be adjust via VCDS
use odis and flash to proper one, normally people swap steering and never touch that . because minor different between skoda, golf , etc ...
RickNewy
Australia
C?ID=451241
Yes yes, I know there’s the “handicap” program number 6 for the Gen2/3 racks and they worked like an hydraulic power steering at any speed either stationary or 100km/h it’s perfect.
With the Mk6 Golf R I’m having a big problem because the power steering is (understandably) programmed to fading away while building speed, which is the opposite of what I need…
I’d like to recreate the pure “hydraulic” power steering effect on stock Gen3 steering rack using only software or tricking the module to stay at maximum force all the time without sourcing aftermarket or modified steering racks.
langers2k
C?ID=224085
You can do that on your MK6 R as it has a 1K0909144J steering module:
- Update the rack firmware to the latest version (two stages)
- Use the '51' dataset
You'll need to find someone with VCP or ODIS as it's not possible with VCDS.
Loads of useful links here: https://www.drive2.ru/l/4842693/
siLc
Tallinn, Estonia
C?ID=330192
Now I see what your aim was. Then no mechanical stuff needed.
