PCV Valve Noise 2003 Audi A4 Cabrio 3.0
cschmitz20
Verified VCDS-Lite User
C?ID=385099
Hello. So i have replaced quite a few things in this car. Finally got the oil level light to go off and have the triptronic working again. But now i have an ongoing issue which i think is the pcv valve. I have replaced a number of bad air hoses as i had multiple leaks and issues with misfires i had to replace the entire crankcase breather system and pcv valve as those hoses cracked while trying to replace the engine coolant sensor. All was good with that until last year when it started to make this high pitched sound especially while accelerarting but would go away. But after a few months it would be random and more of a high pitch honking noise. After reading it sounds like it was the pcv valve going bad. And i also lifted up the hood and noticed the noise was coming from the pcv valve as well as some vibration noise also coming from this little blue and green cylinder like object that connects air hoses very near the pcv valve
Needless to say, I have replaced the pcv valve 3 times and the noise goes off for a few days or so and then comes back again. Could 3 of these all fail or is something else going on? I also pulled the oil cap ofg without any issues and the engine runs rough which should be happening? I am not sure if buying an authentic part would be better? Just seems like a simple part and for 3 to fail seems odd? I do also get random misfires every so often with a cold start which could be related to this pcv valve. I did run smoke through the vaccum lines and there were no leaks.
cschmitz20
C?ID=385099
Hello. So i have replaced quite a few things in this car. Finally got the oil level light to go off and have the triptronic working again. But now i have an ongoing issue which i think is the pcv valve. I have replaced a number of bad air hoses as i had multiole leaks and issues with misfires i had to replace the entire crankcase breather system pcv valve as those hoses cracked while trying to replace the engine coolant sensor. All was good with that until last year when it started to make this high pitched sound especially while accelerarting but would go away. But after a few months it would be random and more of a pitch honking noise. After reading it sounds like it was the pcv valve going bad. And i also lifted up the hood and noticed the noise was coming from tbe pcv vavle as well as some vibration noise also coming from this little blue and green cylinder lile object that connects air hoses very near the pcv valve
Need less to say. I have replace the pcv valve 3 times and the noise goes off for a few days or so and then comes back again. Could 3 of these all fail or is something else going in? I also pulled the oil cap without any issues and the engine runs rough which should be happening? I am not sure if buying an authentic part would be better? Just seems like a simple part and for 3 to fail seems odd? I do also get random misfires every so often with a cold start which could be related to this pcv valve. I did run smoke through the vaccum mines and there were no leaks.
cschmitz20
C?ID=385099
Friday,13,August,2021,10:31:04:55140
VIN: WAUAT48H63K022250   License Plate:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUAT48H63K022250   Mileage: 212940km-132314miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 E    HW: 8E0 909 059
   Component: 3.0L V6/5V      G   0004
   Coding: 0016584
   Shop #: WSC 00672 785 00200
   VCID: 372B2A1BC350F2F37E9-5160
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No: 01J 927 156 FE
   Component: V30 01J 3.0l 5V USA 3031
   Coding: 01001
   Shop #: WSC 03213
   VCID: 74B1DD1797A659EB9BB-5160
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 G
   Component: ABS/ESP front       2328
   Coding: 04499
   Shop #: WSC 00672
   VCID: 2C0105770F16412B03B-51F2
   Part No: 8E0 820 043 L
   Component:   A4 Klimaautomat   1116
   Coding: 00100
   Shop #: WSC 00672
   VCID: 2A0D036F05E25F1BF17-513C
00716 - Air recirculation Flap Positioning Motor (V113)
            41-10 - Blocked or No Voltage - Intermittent
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  USA 0305
   Coding: 00013
   Shop #: WSC 00672
   VCID: 34311D17D72619EB5BB-4B00
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 B
   Component: Airbag 8.4EC        1015
   Coding: 0010105
   VCID: 392F2C23F544E48388D-5184
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0308
   Coding: 02041
   Shop #: WSC 00672
   VCID: 3E253F3FE96AC3BBBDF-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8H0 920 950 E
   Component: KOMBI+WEGFAHRS. RB4 D16
   Coding: 02201
   Shop #: WSC 03213
   VCID: 2E050F7F390A333B2DF-5160
   WAUAT48H63K022250     AUZ6Z0B0400950
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255 B
   Component:  VSG  B6 CABRIO     7195
   Shop #: WSC 02101 444 12602
   VCID: 35372013D95C00E36C5-5160
01983 - Hydraulic Pump Relay 2 for Convertible Top (J588)
01109 - Hydraulic Pump Relay (J321)
   Part No: 8H0 959 760
   Component: Sitzmemory EE H04   X013
   Coding: 00002
   Shop #: WSC 00065
   VCID: 74B1DD17979659EB9BB-4B1E
   Part No: 8H0 959 433 C
   Component: Komfortgerát T7B    1412
   Coding: 11788
   Shop #: WSC 00672
   Subsystem 1 - Part No: 8H1959801
   Component: Tõrsteuer.FS BRM 0001
   Component: Tõrsteuer.BF BRM 0001
            37-10 - Faulty - Intermittent
            49-00 - No Communications
00955 - Key 1
            35-10 - - - Intermittent
            80-10 - Single-Wire Operation - Intermittent
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00070
   Shop #: WSC 00672
   VCID: 04518DD7C736696BABB-4B00
   Part No: 8E0 035 195 F
   Component: symphony II NP2    0051
   Coding: 00205
   Shop #: WSC 40313
   VCID: 2A0D036F05D25F1BF17-4E62
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
            36-00 - Open Circuit
00856 - Radio Antenna
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F M H11   X023
   Coding: 00006
   Shop #: WSC 00065
   VCID: 35372013DC6C00E36C5-4B1E
Address 73: Entry Assist, P        Labels: None
   Component: EasyEntry BF  H11   X023
   Coding: 00005
            80-00 - Single-Wire Operation
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 - -
End----------(Elapsed Time: 05:24, VBatt start/end: 12.3V/12.3V)-----------
cschmitz20
C?ID=385099
I hope my auto scan is showing.
cschmitz20
C?ID=385099
Also when i search for pcv vañve in my erwin manual nothing even comes up.
cschmitz20
C?ID=385099
BUMP
