Hi there,
I wonder if some knowledgeable soul could help me with the following error codes please?
Little bit of history if it helps;
Address 56: I had a new rear screen replaced in February and never had the errors before that. I noticed when they removed the old screen they cut through the old cables(!) although I believe they did unplug the chopped side of the harness from the connector before plugging the new ones back in so not sure whether anything might have been damaged by physically cutting through the cables? I need to remove the trim to check the connections but wanted to find out a little bit more about the errors before proceeding.
5F: I believe I have seen this error before when I enabled the Aux Input from the Green Engineering Menu when AMI BT is also enabled so not sure if this can be resolved without disabling one or the other? I had to enable the Aux Input again as I have an aftermarket Apple CarPlay unit fitted but still want the ability to stream BT Audio to the MMI when not using CarPlay.
A full Auto-Scan if it helps;
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109KW0DB005240
Coding: 010103010000000001
Shop #: WSC 02391 785 00200
VCID: 2D55403D744D08E358-8078
02981 - Connection between Radio and Impedance Converter 1
Reset counter: 17
Mileage: 221557 km
Date: 2021.08.06
Time: 11:27:05
Voltage: 14.10 V
02982 - Connection between Radio and Impedance Converter 2
Reset counter: 17
Mileage: 221557 km
Date: 2021.08.06
Time: 11:27:05
Voltage: 14.10 V
02877 - Digital Radio Antenna (R183)
Reset counter: 17
Mileage: 221557 km
Date: 2021.08.06
Time: 11:27:05
Voltage: 14.10 V
Part No SW: 4H0 035 654 B HW: 4H0 035 670 P
Component: H-BNT-EU H47 1034
Revision: -------- Serial number: 179J10D7516207
Coding: 02010100000BFDEF7DB4CB1E00000003080001000000000000
VCID: 2545B81D2CBD30A390-8070
Subsystem 1 - Part No: 8R0 060 884 GS
Component: EUR 2020 3001
Subsystem 2 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G
Component: DU8 D4 SV NB H48 0021
Serial number: AUZ8ZDDC900XFB9
Subsystem 3 - Part No SW: 4H2 919 600 H HW: 4H2 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000135353
Component: CD-Database 5571
03389 - Data Set Implausible
Reset counter: 17
Mileage: 221557 km
Date: 2021.08.06
Time: 11:27:25
Voltage: 14.00 V
Bin. Bits: 010
Friday,06,August,2021,11:38:46:23606
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ4H1EN009332 License Plate: OIG 8489
Mileage: 221557km-137669mi Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 19 1B 22 28 30
34 36 3B 3C 42 44 46 47 48 52 53 55 56 57 5B 5F 62 6C 6D 6F
72 81 82 84 85 88 89 8A 8B 8D 8E 8F 90 AC
VIN: WAUZZZ4H1EN009332 Mileage: 221557km-137669miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CTEC) Labels: None
Part No SW: 4H0 907 409 K HW: 4H0 907 409 K
Component: 4.2TDI EDC17 H10 0003
Revision: 5AH10---
Coding: 0A2A4032056601030800
Shop #: WSC 00000 780 00200
ASAM Dataset: EV_ECM42TDI1114H0907409K 001010
ROD: EV_ECM42TDI1114H0907409AA.rod
VCID: 346355599F67592B17-8060
Part No SW: 4H1 927 158 CM HW: 0BL 927 156 J
Component: 0BL 42 TDIRdW H16 1004
Revision: --H16---
VCID: 7DF5B07DECAD5863A8-8028
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 AA HW: 4H0 907 379 AA
Component: ESP PREMIUM H10 0665
Coding: E4FDEB2027BFD704E300
ASAM Dataset: EV_ESPPremi 005024
ROD: EV_ESPPremi_005_AU64.rod
VCID: 71ED9C4DA0F52C033C-8024
Part No SW: 4H0 907 064 DB HW: 4H0 907 064 DB
Component: BCM2 2.0 H35 0510
Coding: 05B76F4E000000000000
VCID: 6CD38D398FD7C1EB0F-8038
Serial number: 0213000338662012
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000079813313
Coding: C038B60085047201010001010101112131313333283333
VCID: 3565685D9C1D402320-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 P HW: 4H0 820 043 P
Component: Klima 4 Zonen H20 0201
Coding: 38E10AFE3C0000
ASAM Dataset: EV_AirCondiFront 003001
ROD: EV_AirCondiFront_002.rod
VCID: 2D55403D7C4D08E358-8078
Part No SW: 4H0 907 063 AB HW: 4H0 907 063 AB
Component: BCM1 2.0 H20 0242
Revision: 19020001 Serial number: 00000055079301
Coding: 0105001440349FF2F9014084A0001800009DC30A2F080201800008946100170000400009090000
VCID: 68DBF1299B2FEDCB6B-803C
Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 130524 H36 0090
Serial number: 130604121830
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21882514
Coding: 0200FF
Subsystem 3 - Part No SW: 4H0 941 531 G HW: 4H0 941 531 G
Component: E1 - LDS H01 0044
Serial number: 22 10 2013 00001265
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA106971000004940796
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 1B2906D6000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 2341A6052289CE93FE-8076
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4G0 919 475 B HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0021
Revision: -------- Serial number: 56261329203837
Coding: B83B04
ASAM Dataset: EV_EPHVA2CAU64X0000 001004
ROD: EV_EPHVA2CAU64X0000.rod
VCID: 306B59496B7F650B73-8064
Address 11: Engine II (J624) Labels: None
Revision: 5AH10---
ASAM Dataset: EV_ECM42TDI2114H0907409K 001010
ROD: EV_ECM42TDI2114H0907409K.rod
Part No SW: 4H0 907 561 C HW: 4H0 907 561
Component: ACC3 H19 0032
Coding: 7E04020201
ASAM Dataset: EV_AdaptCruisContrAU64X 002024
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2B514E25425906D346-807E
Component: Airbag10.43 H81 0084
Revision: -------- Serial number: 003P10012Y2P
Coding: 30333045313430303037554A305234483053
VCID: 3B717E65B2399653D6-806E
Serial number: 3575HRB400I50MO29A52
Serial number: 3585HRB400Q50NTMJ9QO
Serial number: 3515JRB401850O3Q7GQJ
Serial number: 3525JRB401850O3QD0P9
Serial number: 3554VRB400650OE2A9G4
Serial number: 3564VRB401E50OLSG0D+
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Revision: -------- Serial number: 90815MJM00055
Coding: 0004FC
VCID: 387B61698B0FBD4B3B-806C
Subsystem 1 - Part No SW: 4H0 951 528 K HW: 4H0 951 528 K
Component: E221 - MFL H09 0010
Serial number: 22 07 2013 33034341
Part No SW: 4H0 920 850 P HW: 4H0 920 850 P
Component: TDieGBACC-NV- H53 0621
Revision: 36081094 Serial number: 658311013592070
Coding: 338E0800BF552600010000
Shop #: WSC 60407 002 104857
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU64.rod
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H05 0225
Serial number: 2131011002683
Part No SW: 4H0 907 468 AE HW: 4H0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001155781
Coding: 80CD077D00
ASAM Dataset: EV_GatewPkoUDS 001019
VCID: 74E39559DFE7192BD7-8020
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 60297814061911337749
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 13309001135021200410
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 L HW: 8K0 907 144 L
Component: DYNAMIKLENK. H06 0720
Revision: 52001005 Serial number: --------------
Coding: 0B0100
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0200
Serial number: 001910130001725
VCID: 285BB12953AF2DCBAB-807C
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 L HW: 4H0 919 158 L
Component: Klima Fond H16 0200
Coding: 2E00000000
ASAM Dataset: EV_AirCondiHeck 002001
ROD: EV_AirCondiHeck.rod
VCID: 397D646DB805A443C4-806C
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000050401
Coding: 01010101000000000001000202
VCID: 64C3E519670789AB47-8030
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008006
ROD: EV_AirSuspe_VW51.rod
VCID: 2F695A3576417AF36A-807A
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000079806399
Coding: C038BF8085857201030001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7100B9T8
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 387B6169830FBD4B3B-806C
Part No SW: 4H0 907 566 F HW: 4H0 907 566 F
Component: SWA Master H06 0020
Serial number: 0317977993
Coding: 040312
ASAM Dataset: EV_LaneChangAssis 001027
ROD: EV_LaneChangAssis_VW51.rod
VCID: 336156459A695E130E-8066
Subsystem 1 - Part No SW: 4H0 907 568 F HW: 4H0 907 568 F
Component: SWA Slave H06 0020
Serial number: 0317878834
Coding: 040312
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0273
Revision: -------- Serial number: 0000080302299
Coding: 011F1E015E0162C202083017
VCID: 489B11A9FBEFCDCB4B-801C
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H39 0010
Revision: 00001000 Serial number: 0006018805
Coding: 011101010001
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326F53416573571B05-8066
Revision: 00002001 Serial number: 0319104844
Coding: 011F0E2280B9399FFB20C7840E0316470000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 007C H06 0005
Serial number: 342400011032
Coding: 020200
Subsystem 4 - Part No SW: 4H0 907 133 A HW: 4H0 907 133 A
Component: J505-FSH H06 0046
Serial number: 00000000000000007842
Subsystem 5 - Part No SW: 4H0 947 135 N HW: 4H0 947 135 N
Component: Dachelektroni H13 0080
Serial number: A2013000000000745702
Coding: 070000
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0014 H06 0005
Serial number: 342400011158
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 006A H06 0005
Serial number: 342400011030
Coding: 020200
Subsystem 8 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00E0 H06 0005
Serial number: 342400011020
Coding: 020200
Subsystem 9 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93077621
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000047347
Coding: 030000
VCID: 1D3590FD04EDF863C8-8048
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 A HW: 4H0 959 860 A
Component: MEM-FS-Fond H06 0155
Revision: AA000000 Serial number: 00000079229796
Coding: C03892808500700D0B00392038193A2039203B3B202020
VCID: 326F53416D73571B05-8066
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0273
Revision: -------- Serial number: 0000081273159
Coding: 011F1E015E0162C202083006
VCID: 3C737D79BF37916BDF-8068
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000872742
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C534D39475701EB4F-8078
Part No SW: 4H4 907 357 B HW: 7P6 907 357 B
Component: MxB-ECU 001 0049
Coding: 02F60A20221B0200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
VCID: 316D5C4D60756C037C-8064
Subsystem 1 - Part No SW: 7PP 941 472 E HW: 7PP 941 472 E Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H06 7510
Coding: E00300
Subsystem 2 - Part No SW: 7PP 941 472 E HW: 7PP 941 472 E Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H06 7510
Coding: E00300
Power module 1 for left matrix headlamp:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H02 0020
Coding: E00300
Power module 1 for right matrix headlamp:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H02 0020
Coding: E00300
Reset counter: 17
Mileage: 221557 km
Date: 2021.08.06
Time: 11:27:05
Voltage: 14.10 V
Reset counter: 17
Mileage: 221557 km
Date: 2021.08.06
Time: 11:27:05
Voltage: 14.10 V
Reset counter: 17
Mileage: 221557 km
Date: 2021.08.06
Time: 11:27:05
Voltage: 14.10 V
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4G0 919 129 C HW: 4G0 919 129
Component: NGTV-DVB H04 0690
Revision: R0043000 Serial number: 06801300843601
Coding: 03000000
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H06 0155
Revision: AA000000 Serial number: 00000079229879
Coding: C03896808500700D0B00392038193A2039203B3B382020
Reset counter: 17
Mileage: 221557 km
Date: 2021.08.06
Time: 11:27:25
Voltage: 14.00 V
Bin. Bits: 010
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0276
Revision: -------- Serial number: 0000080314363
Coding: 010F1E01420062C202083006
Shop #: WSC 60407 002 1048576
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0115637
Coding: 020D000101000000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI_007.rod
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC
Component: HDSG-Modul H12 0046
Revision: 10012001 Serial number: 305300004
Coding: 021004C020
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6FE99A35B6C13AF32A-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000129443
Coding: 220000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63C1E6056A098E93BE-8036
Component: TSG HR H06 0276
Revision: -------- Serial number: 0000080314362
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H2 927 731 A HW: 4H2 927 731 A
Component: GSM-RL H08 0083
Revision: 0R0D5015 Serial number: SN130712 0013
ROD: EV_GSM2x3Mono_AU64.rod
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4H0 919 617 A HW: 4H0 919 617 A
Component: HeadUpDisplay H08 0019
Coding: D30000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 2E574731714B73FB61-807A
Address 84: Night Vision (J853) Labels:* None
Part No SW: 4G0 907 547 HW: 4G0 907 547
Component: NV-ECU-Gen3 H06 0023
Serial number: 622352400201341
Coding: 201100
ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
ROD: EV_NightVisioGen3AE4AU64X.rod
VCID: 6BD18E2582D9C6D306-803E
Night vision system camera:
Subsystem 1 - Part No SW: 4G0 980 552 HW: 4G0 980 552
Component: NV-CAM-Gen3 H03 0006
Serial number: 623466500F1324300035
Component: DPC-SG H26 0081
Coding: EA160000
ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00013616022602
Coding: 776FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00013616016301
Coding: 376FF2
Address 8A: Multicont. Seat Rear,DS (J875) Labels:* None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00013391270402
Coding: 316F00
ASAM Dataset: EV_IVBDriveSideRear 001003
Part No SW: 4H0 907 541 C HW: 4H0 907 541
Coding: 7E04020201
ASAM Dataset: EV_AdaptCruisContr2AU64X 002021
ROD: EV_AdaptCruisContr2AU64X_002.rod
VCID: 295DB42D48A514C3B4-807C
Address 8D: Multicont. Seat Rear,PS (J874) Labels:* None
Serial number: 00013391271502
Coding: 316F00
ASAM Dataset: EV_IVBPasseSideRear 001003
Part No SW: 4H0 907 107 F HW: 4H0 907 107
Component: BV-SG H31 0081
Serial number: 005000212910137
Coding: 02C23B031111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2A5F4B214DA31FDBBD-807E
Component: RGS-VL H13 0080
Coding: 0066F609031F0376070308004240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4H0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H09 0011
Revision: 00000000 Serial number: 132490190
ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 09:42)--------------------------
