- Aug 5, 2021
- 17
- 6
- Brisbane, Australia
- C?ID=451235
Hi,
I have a problem with my daughters MK6 Golf 1.4 TSI. The horn and buttons on the MFSW aren't working.
I tried changing out the clock spring as that was what seemed to be the suggested course of action, but that failed to fix the problem.
I have since checked the circuit diagram and noticed that the horn plate switches go back to the left hand control unit in the MFSW.
I have performed my first auto scan and noticed that the J453 module is not listed anywhere, I have checked auto scans of other similar vehicles in other threads and it is usually seen as a subsystem of J527.
I also noticed that the CAN Gateway is throwing a Control Module Incorrectly Coded error.
I was going to try changing out the modules in the MFSW but I thought I would get some advice first.
Should I change out the buttons in the MFSW and is there anything wrong with the coding of the the CAN Gateway that I can fix?
Another issue is that the car randomly faults after running for at least 5 minutes I see that there is P0106 error in the engine module, what could be the cause of this?
Any assistance would be greatly appreciated.
Friday,06,August,2021,13:49:03:04739
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4544.4
Data version: 20210731 DS325.1
VIN: WVWZZZ1KZ9W536434 License Plate: 096 CE9
Mileage: 186170km-115680mi Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W536434 Mileage: 186170km-115680miles
37-Navigation -- Status: Not registered 0001
Address 01: Engine (CAV) Labels: 03C-906-027-CAV.clb
Part No SW: 03C 906 027 BA HW: 03C 906 027 F
Component: MED17.5.5 G 9660
Revision: L1H08--- Serial number:
Coding: 0000077
Shop #: WSC 05004 004 1048576
VCID: 619FAC702D488233E0D-8034
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 000 - Implausible Signal
Mileage: 186171 km
Date: 2015.12.28
Time: 04:54:53
RPM: 1489 /min
Load: 86.2 %
Speed: 68.0 km/h
Temperature: 87.0°C
Temperature: 40.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
Readiness: 0010 0000
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 048 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 9033
Revision: 00043014 Serial number: CU501811067923
Shop #: WSC 20048 959 130058
VCID: 3B233E18EF6488E39A1-806E
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 163B600D21250000680F06E7841D0080B100
Shop #: WSC 11574 002 1048576
VCID: 77ABE2289FCC6C83BE9-8022
Fault Status: 00101101
Reset counter: 21
Mileage: 184347 km
Date: 2015.12.28
Time: 04:04:02
Count: 4864
Count: 8193
Count: 49717
Count: 260
Count: 51
03388 - Engine Control Module - Pressure Information
Reset counter: 20
Mileage: 186171 km
Date: 2015.12.28
Time: 04:54:53
Count: 32768
Count: 4608
Count: 8251
Count: 49732
Count: 47
01177 - Engine Control Unit
Fault Status: 01101101
Reset counter: 20
Mileage: 186171 km
Date: 2015.12.28
Time: 04:54:53
Count: 32768
Count: 4608
Count: 8250
Count: 49732
Count: 47
Part No SW: 5K0 907 044 AK HW: 5K0 907 044 AK
Component: Climatronic 130 0305
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
VCID: 74B1D5248E3A079B9BB-8020
Part No SW: 1K0 937 084 HW: 1K0 937 084
Component: BCM PQ35 B 020 0358
Revision: 00020000
Coding: 40180A3A982518C044080080140000A443510088436D8D60648000000000
VCID: 6B83CE58D384D8634A1-803E
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 10030 21 0501
Coding: 009795
Component: RLS 270309 05 54 0402
Coding: 0330AD
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 033 0604
Serial number: 003C2R38576U
Coding: 00003134
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77ABE2289F4C6C83BE9-8022
Component: S.Sens.Fahr.V U01 ----
Serial number: 5F116245ZZZZZZZZZZZZ
Component: S.Sens.Beif.V U01 ----
Serial number: 6B6D3545ZZZZZZZZZZZZ
Serial number: 0A4D1E16ZZZZZZZZZZZZ
Serial number: 3A32210FZZZZZZZZZZZZ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0001232
VCID: 76B5EF2C94C6158BA5F-8022
Part No SW: 5K0 920 870 B HW: 5K0 920 870 B
Component: KOMBI H21 0030
Coding: 170900
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
VCID: 2C010D44168A1F5B03B-8078
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 150309F2000827
Coding: ED807F06000202000003
VCID: 372B2228D34CAC837E9-8062
Mileage: 184332 km
Date: 2015.12.28
Time: 03:06:16
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H21 0030
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 D
Component: RNS-MID H61 3970
Revision: AB001001 Serial number: VWZ6Z7L5330010
Coding: 0C000400000000000000
Shop #: WSC 02204 959 101037
VCID: 2F3B1A48271C6443269-807A
Part No SW: 1K0 959 701 AF HW: 1K0 959 701 AF
Component: Tuer-SG 008 2034
Coding: 0004788
VCID: 72BDD33CF8AE09AB897-8026
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 69 2501
Revision: 00H15000
VCID: 2C010D441A0A1F5B03B-8078
Part No SW: 1K0 959 702 AF HW: 1K0 959 702 AF
Coding: 0004788
VCID: 73B3D63887B400A3821-8026
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 7AADFB1CA0DE71EBC17-802E
Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
Coding: 0000144
VCID: 7BA3FE18AFE448E3DA1-802E
End----------(Elapsed Time: 01:11, VBatt start/end: 13.8V/13.8V)-----------
