2018 Passat B8 DSG problem
daniel.b
Europe
C?ID=318819
The problem is, but not always, that the car cannot change from 2nd gear upwards. The turnover goes up but the gear does not change.
The car came with the error 16131 - Steering Angle Sensor (Not Initialized). Steering Angle adaptation has been done but it is to be improved because the car pulls slightly to the left. Can this sensor be associated with the DSG gearbox that does not shift from 2nd gear up?
Tuesday,10,August,2021,16:47:14:07292
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4544.4
VIN: WVWZZZ3CZXXXXXXXX   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZ3CZXXXXXXXX   Mileage: 138966km-86349miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 KD    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 4798
   Revision: B4H25---
   Coding: 0125041203641D083000
   Shop #: WSC 05311 115 00308
   ASAM Dataset: EV_ECM20TDI01104L906026KD 005005
   ROD: EV_ECM20TDI01104L906026KD_005.rod
   VCID: F6A0B98A49DBC13B69-80A2
4527 - Coolant Fan Control Circuit 1
          P0480 00 [038] - Electrical Malfunction
                    Mileage: 138966 km
                    Date: 2021.08.10
                    Time: 16:39:20
                    Engine RPM: 749.00 /min
                    Normed load value: 36.5 %
                    Coolant temperature: 89 °C
                    Intake air temperature: 81 °C
                    Voltage terminal 30: 12.820 V
                    Air mass: specified value: 250.0 mg/stroke
                    Coolant temperature sensor 1: B1: on radiator output: raw value: 2222.0 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside temperature sensor 1: B1: raw value: 23.5 °C
                    Coolant fan 1: activation: 30.07 %
                    Fuel temperature sensor 1: B1: raw value: 46.3 °C
   Part No SW: 0GC 300 042 H    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1404
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW48.rod
   VCID: AB1658FEC219CCD3C6-80FE
   No subsystems:
   Part No SW: 5Q0 614 517 DA    HW: 5Q0 614 517 AH
   Component: ESC           H62 0753
   Revision: 00000000    Serial number: 60738000001349
   Coding: 0FEC6A8F34280B754779060660C749F0562CD0E2600692713862F078C202420B00000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: F3A6809E5AA9D4134E-80A6
   Part No SW: 3Q0 959 435 F    HW: 3Q0 959 435 F
   Component: VWKESSYMQB    027 0907
   Revision: 00027000    Serial number: 0473337642
   Coding: 102F0F0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: BD3266A62C6D526368-80E8
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 12020104202410011015100200101822
   VCID: F8BCB7B243CFB74B7B-80AC
   Air quality sensor:
   Humidity sensor: exterior:
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 865808031802C2
   ROD: EV_BCMBOSCH_018.rod
   VCID: 8640C94A393BD1BB79-80D2
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    180212  042 0607
   Serial number:         180219112932
   Component: RLHS  047 0105
   Serial number: SAY18M03D14H17M47S11
   Coding: 00A8EE
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 09 01 2018  10001380
   Humidity sensor: interior:
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018061
   Coding: 0471051811
   Shop #: WSC 05311 115 00094
   ROD: EV_EPHVA18AU3700000.rod
   VCID: CBD6387E62D9ECD3E6-809E
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Coding: 3200670251FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: B5227E86145D8A23A0-80E0
   Part No SW: 3Q0 959 655 BG    HW: 3Q0 959 655 BG
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W3P48KHZI
   Coding: 88CCC000000000005C5400CF000800000065
   Shop #: WSC 05311 000 08193
   VCID: 8444D3420F07E3AB67-80D0
   Subsystem 1 - Part No SW: -----------    HW: 454 000 503 18
   Serial number: 357000000008E480DD2Y
   Subsystem 2 - Part No SW: -----------    HW: 454 000 403 18
   Serial number: 35800000000E0D585E2Y
   Subsystem 3 - Part No SW: -----------    HW: 454 800 903 18
   Serial number: 3510018CDE613000000O
   Subsystem 4 - Part No SW: -----------    HW: 454 800 903 18
   Serial number: 35200D8A2E113000000J
   Subsystem 5 - Part No SW: -----------    HW: 454 800 203 18
   Serial number: 35500122AC1130000002
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20180321301768
   Coding: 0410
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 751 C    HW: 3G0 920 751 C
   Component: KOMBI         302 0310
   Coding: 07A409082F80000801886B011001000080000000
   VCID: A502AEC6A4FDFAA310-80F0
   Component: GW MQB High   518 5323
   Serial number: 06031810521813
   Coding: 0B0300045F087300FB0002581C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: B83C77B2034F774BBB-80EC
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 39180000361260018105
   Coding: 2DFFFF
   Serial number: 758860000018031924DE
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H26 0780
   Serial number: 3008387
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 2302201800010105
   Serial number: 250118EAO29008
   Coding: 00350B208000020000001000
   VCID: C3C6105E4A8924931E-8096
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000008405823
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 819008 00
   Coding: 0100001000400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
14680107 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [Internal malfunction]
                    Mileage: 137834 km
                    Date: 2020.08.22
                    Time: 00:00:31
                    Write only channel
   Serial number: 110318ECA17983
   Coding: 003501208000020000001000
   VCID: C2C8155A55932D9B15-8096
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000008322347
   Coding: 090000
   Coding: 03DA000009000000
   VCID: F5A2BE8654DDCA2360-80A0
   Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846 B
   Component: MU-S-N-ER     851 0870
   Coding: 02840201FF0000005111000100080A031F0500C401200500CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: B02C4F92EB3FAF0BF3-80E4
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H51 8130
   Serial number: VWZ6ZHV0701955
   Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
   Component: ECE1 2018  --- 0915
End----------(Elapsed Time: 01:39, VBatt start/end: 13.0V/12.7V)-----------
Jef
HQ
I do not see a G85 issues messing with the transmission. It appears there may be a firmware update for the transmission. Currently the trans firmware is at 1404 and it looks like it may go up to 1427 but I'm not finding details of specifics... check with your dealer.
daniel.b
Europe
C?ID=318819
G85 sensor has been calibrated and the error has disappeared. the problem with the DSG still exists. below is a video with the problem.
Spacewalker
Poland
C?ID=159607
you can only do basic settings in DSG
Do a simple test:
Swich to manual gear , and strat drive check if UP arrow apear while accelerating
because DSG change gear if ECU tell to do that
From 1st to 2nd gear change , because this is a emergency mode, to not overload engine on 1st gear
and fix 44th .... this could be also a problem,
daniel.b
Europe
C?ID=318819
Thanks for the answer, is there anyone able to tell me what the error is, I can't find a description for it
"Internal Fault" seems pretty clear, no?
daniel.b
Europe
C?ID=318819
Spacewalker
Poland
C?ID=159607
Connect ODIS and follow guide function for that ....
Spacewalker
Poland
C?ID=159607
so what we can do for you ? You can only replace steering rack and perhaps stuck with similar issue ...
without proper tools, and no knowledge/solution .....is like walking in the dark
