You can say, "outhouse" here. Hell, you can even say "shit-house".
I'm not sure I buy into that theory. Cold engines do not like to be revved.
I'm obliged sir
Just thinking of the children who want to know all about , as everyone should of course!
Yes, you are right. Again. To clarify for readers, it doesn't mean putting the vehicle in S for the first part of the drive and driving like you stole it.
Hi, thanks for the input and info which is pretty comprehensive. Firstly, with the exception of the Superb which I purchased recently, all my other vehicles are manual. Admittedly, running a small taxi company certain vehicles only do short local work but the rest do get a regular blast up the motorway. In addition the ironic thing is my Octavia, the one which is giving the issues, doesn't and never has, gone into limp mode. Even with the light on it pulls like a train right through the rev range and will always red line! I think I will take your advice and search out the 'foam' type of cleaner rather than the liquid sort and give that a go.
As it was explained to me, there are some very small oilways in some parts, and higher revs when cold risks reducing the oil film across bearing surfaces breaking through, when actually you need the volume under pressure to keep parts from touching oneanother. Think of the oil as a liquid spacer.
As almost all your vehicles are manual Ronnie, no doubt you'll be able to draw something from this guidance which I just wanted to give to those with who are asking the question how best to protect the engine when cold. It was good Uwe caused me to elaborate a little on the use of S! And hopefully staving off or preventing the light.
So D, S or M? For those a bit confused at this point, be sensible. If you want to avoid the early gear changes, especially in town, at least initially, or when the engine is cold, you may want to choose D but select the manual option; if you have paddles its a breeze. Just change gear at 2000 rather than 1600 and that should stop that 1200 rpm business, which to many will not feel right I'm sure. VAG have incorporated so many clever features in their vehicles, but not an algorithm for the gearbox that alters the change speeds according to the engine temperature. I am not qualified to say, but they may say this guidance is 'nicht nötig'.
For & Auto owners, maybe Ross-Tech will in future provide a means to get into the controller to reset those shift intervals. However, these cranks are beautifully balanced and they are tough as tanks if you don't act like an idiot. I guess this is a complicated, perhaps controversial subject, and, as Uwe alluded to, you can understand it can't really be just universall advice, like put it in S and go [like a bat out of hell because that's better than D, right?]; No it has to be taken with a large pinch of common sense. This is my formula:
When cold, always wait 30 seconds before driving off. I cringe every time I see someone start their car in the morning, clearly late, and just gas it from the get-go. Wait. Always wait, then select the manual option and change as it feels 'right' at around 2000, change to a higher gear on the downgrade and back up one on the upgrade. Lugging is also not good for the engine.
When warm, leave in D, unless you're driving round town, in which case, I use S. It delays and thus reduces unnecessary shifts and, it is suggested to me, results in higher and hotter gas flow to help with this problem that afflicts so many as the mileages rack up. Cold goo is sticky as glue!
That's about as simple as I can make it. If you listen to your engine as I do, you will notice he always tells you how he feels. If you take notice what he is saying, I don't think you can go far wrong. VAG engines will last a very long time with that little bit of extra care.
Regarding your scenario Ronnie, as you havent actually been forced into limp mode, we need to prevent that as its such a headache, but the dreaded limp will get you if you dont take quick and radical action. If I'm ciorrect, the garage service didn't seem to work for you either, so try this:
additive in fuel.
Fully foam up the inside of the so you can get no more in, even after resting the process for 30 minutes - Dont keep spraying if the foam is escaping. must be below 40C.
Allow to rest for another hour.
Drive straight away after this treatment, holding a steady 2500-3000 rpm for at least 60 miles without stopping.
If light does not extinguish after 150 miles of driving like this (not necessarily all in one journey!), then you should look in your kit for static regeneration. If that function does not work you'll need to take your laptop for a ride (bearing in mind you must not be distracted) and use regeneration whilst driving. There seem to be two powerful functions for this inside . Its good we have those codes for accessing that. If they do not help, you may well need to remove the can and take it to the bathroom when your partner isn't looking! Some brilliant videos on DIY cleaning online. But taking the damn thing off is the last thing you want to do.
Let us know how you get on with these tips and tricks and share any of your own here. I'm sure many will find it informative and help us all avoid the stealers.
