VW Tiguan AD1 2016 Euro LED Taillight Retrofit
kjrehsi
C?ID=287868
Hi Guys,
Anybody here carried out retrofit of Euro LED Taillight Retrofit on a AD1 Tiguan?
I'd appreciate any information on how to make a suitable harness :)
kjrehsi
C?ID=287868
Well looks like not many here have done the retrofit
So I went to erwin and purchased the relevant diagrams for the LED taillights :)
Left Tail light
Right Tail light
So from the above diagrams it seems like I will need to run few wires from BCM for the conversion
BCM - T73a Pin 71 --> Left Lamp - Pin 3 (Already present in Pin 2) - Brake light
BCM - T73b Pin 3 --> Left Lamp - Pin 2 - Tail light
BCM - T73b Pin 11 --> Left Lamp - Pin 4 - Reverse
BCM - T73b Pin 9 --> Right Lamp - Pin 2 - Tail light
BCM - T73a Pin 64 --> Right Lamp - Pin 4 - Reverse
Currently looking at the wire colours in the plugs I have the following
Left Lamp (current)
Pin1 - brown
Pin2 - black / red
Pin3 - empty
Pin4 - empty
Pin5 - white / black
Right Lamp (Current)
Pin1 - brown
Pin2 - purple / black
Pin3 - empty
Pin4 - empty
Pin5 - green / black
What do you suggest guys?
kjrehsi
C?ID=287868
Hi All,
Just to update this thread, somebody finally helped me on one of the forums and made a wiring 'plan' to follow i.e. run 4 wires from BCM to the outer tail lights and reposition pin at plug A to plug C..
So apparently the wiring diagram I got from erwin website aren't correct? :confused:
Here are the correct ones
This was the wiring plan
Outer Lamp Left
Add wires from BCM T73c / 3 to Pin 2
Add wires from BCM T73c / 11 to Pin 4
Outer Lamp Right -
Add wires from BCM T73c / 9 to Pin 2
Add wires from BCM T73a / 64 to Pin 4
Inner Lamps -
Reposition Pin T73a / 64 at BCM to T73c / 6
I got a copy of Tail light settings from a Highline Tiguan and was able to code the new LEDs tail lights.
However, not so successful unfortunately
As you can see from the second images, Inner Brake Lamps don't work :( Because in the new LED's the reverse lights
have moved to outer lamps so when I put the car in reverse its then they activate lol
I have checked the coding multiple times and can't figure out why it's the case?
I have 1 error in Ctrl Electronics now saying my 'Tail Light' is short in the Inner Lamps. However as you can see they work.
I am attaching my AdMap, can somebody guide me on how I can fix this?
*Inner Tail / Running lights working*
*No Brake lights in the Inner Lamps*
kjrehsi
C?ID=287868
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    127
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    2A
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    1A
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    37 - allgemeine LED bis 12W
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    Parking light right
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    127
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    29
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    0A
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    37 - allgemeine LED bis 12W
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    127
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    38 - LED Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    127
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    38 - LED Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    127
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    2B
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    9
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    34 - LED Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    not active
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    127
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    2D
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    19
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    34 - LED Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    not active
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    127
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    Quittierungsfunktion 1
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    127
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    35
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    32 - allgemeine LED bis 12W
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    only_if_closed
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    not active
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    127
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2E
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    0C
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    32 - allgemeine LED bis 12W
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    only_if_closed
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    Parking light right
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    not active
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    127
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    127
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    2F
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    1C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    43 - allgemeine LED
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    only_if_closed
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    minimize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    127
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    36
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    1A
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    32 - allgemeine LED bis 12W
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    only_if_closed
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    Brake lamp
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    127
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    32 - allgemeine LED bis 12W
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    127
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    32 - allgemeine LED bis 12W
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active
kjrehsi
C?ID=287868
Instead of this
Inner Lamps -
Should run wire directly from T73c / 6 to the inner lamps?
@kjrehsi: Hi.
For the inner brake-light problem, try this:
  • ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 > maximize
  • ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 > 34 - LED Bremsleuchten
  • ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 > not active
kjrehsi
C?ID=287868
@kjrehsi: Hi.
Thank you, will try this and report back
kjrehsi
C?ID=287868
@kjrehsi: Hi.
@DV52 no joy :(
downtime
Finland
C?ID=280813
If you want to compare, adamap from my previous R-Line Tig with factory high leds on the rear : https://forums.ross-tech.com/index.php?threads/19332/#post-191362
Leuchte 27 was in my car, as an example :
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Brake light ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16=> This you naturally need to select as left hand traffic as you're in UK (Nebelschlussleuchte wenn kein Anhaenger gesteckt und Linksverkehr)
kjrehsi
C?ID=287868
Believe me or not I am actually using your admap as a reference guide :) I had bookmarked your link previously :)
So for Lichtfunktion C27 I actually selected right hand drive :facepalm:
kjrehsi
C?ID=287868
Ok matched everything with @downtime and still no luck :(
Looks like I will need to run a wire directly from T73c/6 to the inner lamps.
However for the life of me don't understand as to why am getting a Fault error for the Right Inner Running lights when they are working 🤷‍♂️
downtime
Finland
C?ID=280813
I believe your wiring is not correct. I know the Erwin diagrams sometimes but very very rarely have errors.
Did you download the diagrams using your own VIN?
kjrehsi
C?ID=287868
Yes Pal downloaded the diagrams from Erwin. If you look at the very first wiring diagrams above are from my VIN.
The second set of diagrams were from a different forum (vwvortex).
I am pretty sure the suggested route for inner brake lamps are not correct. I am going run a wire from C6 to back and test if that makes the brake lights to work
kjrehsi
C?ID=287868
Well i ended up running wire from plug C pin 9 to the rear inner lamps and everything works as factory. No error or faults.
No compromise to coding i.e., it is as if factory.
Thanks for the support everybody
Johan1
C?ID=359010
How you doing mate,
well thank you so much for being gentle and explained at your best how you followed all the steps to retrofit the tail leds on a tiguan ad1.
i would like to ask you some cuation cause at the end of your story was never cleared for me ,
after all i understand that there must be 4 wires runing from bcm to the tail lights....and then one wire from bcm to the inner lights.
so is it 4 or 5 total wires from bcm to the rear lights ?
Outer Lamp Left
Outer Lamp Right -
Inner Lamps -
Reposition Pin T73a / 64 at BCM to T73c / 6...............Instead ...run wire directly from T73c / 6 to the inner lamps
as far as i can understand are 5 wires totaly right?
and then this is not clear for me>>>>once you said this>>>>Reposition Pin T73a / 64 at BCM to T73c / 6...............Instead ...run wire directly from T73c / 6 to the inner lamps
and then at the end you said this>>>>>Well i ended up running wire from plug C pin 9 to the rear inner lamps and everything works as factory. No error or faults.
so is it from T73C pin6 or pin9 ?
and this last wire you mentioned to the innerlights but in which point or pin in the innerlights ??
and then came this >>>>>No compromise to coding i.e., it is as if factory....this means that there is no need for coding from the begining or no need coding for just jthe inner lights
sorry about asking so much mate and i appreciate all your efforts and your sharing
will wait for your answer /and Thanks in advance
cheers.
vastechnics
C?ID=143747
I don’t any wires to front. In the back all. Just wire normal light from inner lights to other lights and wire brake lights from outer to inner. Also wire back up lights to outer. All can be taken from connection point in tailgate. Then make good coding
