Redir fail
   #21
crd4me
Canada
C?ID=261997
As requested :
debuglog-5.edl
40.5 kB
0000-6FA0
Options
debuglog-6.edl
59.0 kB
0000-6FA1
Option
   #22
I’m posting this here, but I’m not sure if it will be working.
No, the URLs won't work for anyone not logged into your Cloud account. But as Shaun stated, we can get them using the docid, so I've edited your post in order to avoid confusing others.
Shaun
Ok thanks I see what is wrong here. Feel free to bump this thread in a couple of days if I haven't gotten you a fix to try.
   #24
crd4me
Canada
C?ID=261997
Thanks Uwe :)
Thanks Shaun :)
   #25
Shaun
I put your interface onto the alpha release channel. Please checks for updates, and you should find a new CB to install V0.4554. Then give the measuring values a test again.
crd4me
Canada
C?ID=261997
Update completed ...
Will provide SITREP this evening :)
Kindest regards.
   #27
crd4me
Canada
C?ID=261997
No good news :/
Here is debug log for measuring block 208 and 209.
Docid : 0000-6FB1
crd4me
Canada
C?ID=261997
…also for some odd reason I can not access the vcds cloud functions :
Maybe a server error?
   #29
Shaun
This is a connectivity problem with the alpha. Bump the thread next week if I don't have something new for you to try. In the meantime, can you post a screenshot of what measuring values you are seeing now, did it change at all?
  • Informative
crd4me
Canada
C?ID=261997
Shaun,
No change on the values from what I saw yesterday evening (Eastern std. Time). Still the same as before.
I will post a screenshot, later today, of I see when entering measuring block 208 (from 1 to 4) and 209 (from 1 to 4).
   #32
Shaun
Ok, I pushed a new alpha CB V0.4555, this has fixes for the VCDS-Cloud connectivity but doesn't change anything for the measuring values. Can you update your interface and try to upload the last debug log you made again when you get the chance (it didn't actually upload because of the cloud issue)
To re-upload in VCDS-Mobile
[View Saved Files] -> find debug log -> [Options] -> [Upload]
crd4me
Canada
C?ID=261997
Update completed.
Vcds-clouds works.
i’ve uploaded to cloud previous debug file to:
/debug/debuglog-7.edl
33.9 kB
00006FB1
20:14:01 8/20/2021
crd4me
Canada
C?ID=261997
Just a quick bumb to see if there has been any development on this :)
Best regards.
   #35
Shaun
I'll try to have a new alpha for you by the end of the week.
   #36
Shaun
Check for updates, you should get new alpha CB V0.4556 with fixes for certain kw2000 measuring blocks group # >127
crd4me
Canada
C?ID=261997
I did the update through vcds-mobile. At somepoint the update stalled, but I think this was due to the fact that the hex-net disconnected from the wifi. However I think the update worked out. Now i see values in the 208 and 209 measuring block.
