2011 Jetta TDI Sportwagen ABS problem?
appold
C?ID=381949
Hi,
As can be seen on the Autoscan, I have a number of problems with this vehicle. At the moment, I'm most concerned about the ABS issues. There are 4 of them:
03842 - RPM Sensor Rear Right: Incorrect Signal
These issues have a history (but perhaps not the one I thought).
About two weeks ago, the car flooded after a severe rainstorm and, as happened in the past, the a running and some other lights came on. That had happened in the past and I usually vacuum the front driver's footwell and use a fan to help the under-dash area dry out. Usually, I disconnect the battery except for when actually driving and the problem more or less solves itself after a few weeks. This time, the car lost functions (the windows wouldn't operate, the turn signals would not operate, and the fuel door wouldn't open).
I e-mailed and called in a panic, receiving an e-mail reply from Andy and very helpful advice from Dana over the phone. (Thank you very much Dana.) The CE/CM was indeed wet (sitting in water). I dried it out and cleaned off some black goop on both sides of the board and put everything back together. The car works again.
I had always assumed that the ABS, tire pressure, stability, and airbag lights lit up because of the water but that issue did not clear up. All the lights will sometimes go out but then they might all come on again, the next time the car is driven.
I hooked up VCDS, set it to read the speeds indicated by each wheel, and went for a short drive. At first, the right rear sent strange signals -- sometimes as if the sensor was not working but then sometimes much faster than the other wheels. On the graph, the pattern looked saw-toothed, rather than as if there were momentary drops and short spikes (I was probably driving about 10 mph at the time). After a few blocks, the issue seemed to go away. After letting the car sit for a few hours, I went for a second drive and there was no trace of an issue. (I logged the second trip but there is nothing to see in that log.)
In between trips, I did pull off the wheel and examine the sensor. I wiggled the wire a bit but I didn't see or feel any obvious signs of damage. I didn't want to pull out the sensor because I didn't want to break it (it seems to happen on Youtube) without having a replacement handy.
How should I proceed from here?
Steve
Saturday,31,July,2021,16:36:33:47515
VIN: 3VWML7AJ1BM611760   License Plate:
Mileage: 260780km-162041mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 3VWML7AJ1BM611760   Mileage: 260780km-162041miles
   Part No SW: 03L 906 019 DA    HW: 03L 906 019 DA
   Component: R4 2,0L EDC G000SG  9971
   Revision: 12H08---    Serial number:
   Coding: 0050072
   Shop #: WSC 00066 000 00000
   VCID: 6D87C940B19A67D3545-8038
001025 - EGR System
               P0401 - 001 - Insufficient Flow - MIL ON
                    Fault Status: 11100001
                    Fault Frequency: 255
                    Mileage: 235032 km
                    Date: 2014.04.24
                    Time: 16:52:54
                    RPM: 1403 /min
                    Speed: 38.0 km/h
                    Voltage: 14.14 V
                    Load: 63.1 %
                    Load: 100.0 %
                    Mass Air / Rev.: 260.0 mg/str
                    Mass Air / Rev.: 400.0 mg/str
009231 - Exhaust Gas Recirculation System
               P240F - 000 - Response too Slow - MIL ON
                    Fault Status: 11100000
                    Mileage: 255617 km
                    Date: 2015.09.04
                    Time: 16:06:52
                    RPM: 1978 /min
                    Speed: 53.0 km/h
                    Load: 62.0 %
                    Mass Air / Rev.: 0.0 mg/str
                    Mass Air / Rev.: 55.0 mg/str
                    Mass Air / Rev.: 295.0 mg/str
                    Mass Air / Rev.: 385.0 mg/str
001025 - EGR System
               P0401 - 002 - Insufficient Flow - Intermittent
                    Mileage: 260391 km
                    Date: 2015.12.16
                    Time: 00:02:01
                    RPM: 1794 /min
                    Speed: 70.0 km/h
                    Voltage: 13.83 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 650.0 mg/str
                    Mass Air / Rev.: 670.0 mg/str
054282 - Terminal 30
               U140A - 000 - Open Circuit - Intermittent
                    Voltage: 12.39 V
                    Temperature: -90.0°C
                    Absolute Pres.: 0.0 mbar
                    Torque: 0.0 Nm
Readiness: 1 3 0 0 0
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   Coding: 114B600C492300FB881206EA92190042B70000
   VCID: 74B1DC24DEB0B61B9BB-8020
                    Reset counter: 169
                    Mileage: 260642 km
                    Date: 2015.12.18
                    Time: 19:17:03
                    Count: 7
                    Count: 2
                    Count: 4096
                    Count: 87
                    Count: 44544
                    Count: 62465
                    Fault Status: 00100011
                    Reset counter: 174
                    Mileage: 260652 km
                    Date: 2015.12.19
                    Time: 18:11:10
                    Count: 4608
                    Count: 83
                    Count: 50946
                    Count: 65535
                    Count: 255
                    Fault Status: 00101100
                    Reset counter: 174
                    Mileage: 260642 km
                    Date: 2015.12.18
                    Time: 19:17:03
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 80
                    Count: 44544
                    Count: 62465
                    Reset counter: 133
                    Mileage: 260652 km
                    Date: 2015.12.19
                    Time: 02:24:26
                    Count: 3
                    Count: 2
                    Count: 20480
                    Count: 16390
                    Count: 44032
                    Count: 65281
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00147
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B7E120D54AAF13AC5-8020
   Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
   Component: BCM PQ35 B    011 0035
   Revision: BG011001
   Coding: 2D380E1F902F3EC400080081600000C401000086535D8560648020000040
   VCID: 34311C249E30F61B5BB-8060
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 27071  21  0512
   Coding: 009795
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R00P35-
   Coding: 00003044
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 392F2D10B9D20B7388D-806C
   Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
   Component: BF-Gewichtss.  007 0001
   Serial number: ---0000R--0005BYQ100
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME7F727354ZZZ0
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME32557354ZZZS
   Serial number: 3511HSME061A2C22ZZZG
   Serial number: 3521HSME1A272D22ZZZL
   Serial number: 35527SME36354F20ZZZE
   Serial number: 35627SME1F227721ZZZE
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 11
                    Reset counter: 174
                    Mileage: 260642 km
                    Date: 2021.07.27
                    Time: 19:17:20
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JFF000VF
   Coding: 108A140000
   Shop #: WSC 00066 000 00187
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72BDDA3CA424B82B897-8026
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0007378
   Coding: 820000
   Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
   Component: KOMBI         H03 0406
   Coding: 270F01
   VCID: 2F3B13487796D5C3269-807A
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 29071001200002
   Coding: E9807F0600160300002002
   VCID: 2E050E4C7C1CDCCB2DF-807A
                    Fault Frequency: 64
                    Reset counter: 134
                    Mileage: 260642 km
                    Date: 2015.12.18
                    Time: 19:17:03
01304 - Radio
                    Reset counter: 129
                    Mileage: 260642 km
                    Date: 2015.12.18
                    Time: 19:17:07
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223R999K06
   Coding: 0000002
   VCID: 7EA5FE0CECFCEC4BFDF-802A
   Component: IMMO          H03 0406
   VCID: 6A8DC25C8CF470EB317-803E
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0001234423
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 270BFB685F668D83EE9-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005011476
   Coding: 000490
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 133
                    Mileage: 260645 km
                    Date: 2021.07.27
                    Time: 19:24:53
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 313F15306D22C33330D-8064
                    Fault Status: 00101101
                    Fault Frequency: 12
                    Reset counter: 174
                    Mileage: 260694 km
                    Date: 2015.12.22
                    Time: 02:30:36
                    Voltage: 13.88 V
                        DU
                    Temperature: 33.0°C
                    RPM: 890 /min
                    Speed: 24.0 km/h
                    Speed: 24.0 km/h
   Component: EZE_2         H25 5603
   Coding: 050B0500
   VCID: 6FBBD348B79695C3669-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0001209770
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 2809F854527882FBE73-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005112584
   Coding: 000490
Address 56: Radio
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668271623
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 323D1A3C64A4F82B497-8066
          B104F 13 [009] - Short to GND
                    Fault Frequency: 13
                    Reset counter: 134
                    Mileage: 260642 km
                    Date: 2021.07.27
                    Time: 19:17:03
          B104E 13 [009] - Short to GND
                    Reset counter: 129
                    Mileage: 260642 km
                    Date: 2021.07.27
                    Time: 19:17:03
0022 - Radio
          U1066 00 [009] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                    Reset counter: 129
                    Mileage: 260642 km
                    Date: 2021.07.27
                    Time: 19:17:02
End----------(Elapsed Time: 01:19, VBatt start/end: 13.8V/13.8V)-----------
Spacewalker
Poland
C?ID=159607
pull new wires from ABS to one senor to see if error gone
hard to say if sensor is faulty, or encider ,or wires
but is easier to startfrom wires i think
appold
C?ID=381949
Thank you. I will give that a try.
