- Aug 22, 2014
- 500
- 231
- Maryland, USA
- C?ID=66650
EPC light came on while driving but car still drives good. I did a visual inspection on the engine, I also carried out engine diagnosis and found the faults below.
I cleared the above faults but EPC light came back on again next day after about 40 miles drive. I carried out a secon auto scan and showed the following results:
What I am not sure about is the displayed knock sensor values, should they be reading zero if system was working ok? Also the rail pressure reads 5610kpa which is about 56.1 bar at idling. Torque restriction fault came up after clearing same fault. Could it be that HP pump drive is affecting fuel pressure delivery at certain times causing cylinder selective knock controls and subsequent EPC light on?
Any ideas would be appreciated folks.
Tuesday,27,July,2021,20:10:51:46890
VCDS Version: 21.3.0.0 (x64)
VIN: 1VWBT7A35EC060828 License Plate: KING PASSAT
Address 01: Engine Labels: 06K-907-425-V2.clb
Control Module Part Number: 06K 906 070 J HW: 06K 907 425
Component and/or Version: R4 1.8l TFS H09 9364
Software Coding: 001A0012242400170000
Work Shop Code: WSC 09003 957 00200
ASAM Dataset: EV_ECM18TFS02006K906070J 001009 (VW41)
ROD: EV_ECM18TFS02006K906070J.rod
VCID: 3162DCDD609E70037C-8064
9 Faults Found:
15084 - Cylinder 3 Knock Control
P2338 00 [096] - Limit Reached
15083 - Cylinder 2 Knock Control
P2337 00 [096] - Limit Reached
Mileage: 133646 km
Date: 2086.14.24
Time: 07:58:44
Engine RPM: 1828.50 /min
Normed load value: 57.6 %
Vehicle speed: 103 km/h
Coolant temperature: 85 °C
Intake air temperature: 40 °C
Voltage terminal 30: 14.140 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 1396 s
MAP_MES_SAE: 102 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.982 V
FAC_TPS_1_SAE: 36.718750 %
FUP_H_SAE: 19900.0 kPa
15357 - Torque Restriction due to Fuel Pressure
P102F 00 [096] - -
Mileage: 133648 km
Date: 2086.14.24
Time: 08:00:25
Engine RPM: 1822.25 /min
Normed load value: 59.6 %
Intake air temperature: 39 °C
STATE_LS_SAE[1]: CL
T_AST_SAE: 1397 s
MAP_MES_SAE: 91 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.021 V
FAC_TPS_1_SAE: 23.046875 %
FUP_H_SAE: 19890.0 kPa
15189 - Oil Pressure Switch for reduced Oil Pressure
P164D 00 [032] - Malfunction
15125 - Cylinder 1
P0301 00 [096] - Misfire Detected
15131 - Cylinder 3
P0303 00 [096] - Misfire Detected
15134 - Cylinder 4
P0304 00 [096] - Misfire Detected
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
19803 - EVAP System
P0456 00 [096] - Very Small Leak Detected
Address 01: DTCs cleared
Address 01: Engine (06K 906 070 J)
20:17:45
IDE00151 Oil fill level 120 mm
ENG101667 Fuel pump: adaption value 0.000 %
ENG100969 Fuel pump: fuel pressure: I-controller 0.000 %
ENG100250 Fuel regulating valve: duty cycle 18.430 %
ENG101692 Fuel supply system: high-pressure regulator 217.228 hPa
20:18:19
IDE00148 Mean injection time 0.8 ms
IDE00149 Ignition angle of current cylinder: actual value 1.87 °
IDE00151 Oil fill level 63 mm
IDE01905 Average of ignition timing angle delay adjustment 19.87 °
ENG100250 Fuel regulating valve: duty cycle 18.871 %
ENG101692 Fuel supply system: high-pressure regulator 1193.66 hPa
20:18:31
IDE00155 Ignition timing angle retard cylinder 1 0.00 °
IDE00156 Ignition timing angle retard cylinder 2 0.00 °
IDE00157 Ignition timing angle retard cylinder 3 0.00 °
IDE01905 Average of ignition timing angle delay adjustment 19.50 °
ENG100969 Fuel pump: fuel pressure: I-controller 16.606 %
ENG100250 Fuel regulating valve: duty cycle 355.202 hPa
20:18:45
IDE00149 Ignition angle of current cylinder: actual value 2.25 °
IDE00186 Fuel low pressure: actual value 11.003 bar
ENG100250 Fuel regulating valve: duty cycle 17.111 %
ENG101692 Fuel supply system: high-pressure regulator -753.897 hPa
20:19:34
IDE00149 Ignition angle of current cylinder: actual value 1.12 °
ENG100250 Fuel regulating valve: duty cycle 16.490 %
ENG101692 Fuel supply system: high-pressure regulator 4.96004 hPa
Saturday,31,July,2021,09:51:41:46890
VIN: 1VWBT7A35EC060828 License Plate: KING VW 2ND DIAG
Mileage: 134520km-83586mi Repair Order:
Chassis Type: A3-VW41 (7N0)
75 77
VIN: 1VWBT7A35EC060828 Mileage: 134520km-83586miles
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 070 J HW: 06K 907 425
Component: R4 1.8l TFS H09 9364
Revision: --H09--- Serial number:
Shop #: WSC 09003 957 00200
Mileage: 134409 km
Date: 2021.07.30
Time: 22:21:30
Engine RPM: 1901.50 /min
Normed load value: 53.3 %
Vehicle speed: 107 km/h
Coolant temperature: 84 °C
Intake air temperature: 36 °C
Voltage terminal 30: 14.160 V
Unlearning counter according OBD: 37
STATE_LS_SAE[1]: CL
T_AST_SAE: 1722 s
MAP_MES_SAE: 97 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.987 V
FAC_TPS_1_SAE: 29.296875 %
FUP_H_SAE: 19870.0 kPa
P102F 00 [096] - -
Mileage: 134409 km
Date: 2021.07.30
Time: 22:21:31
Engine RPM: 1896.50 /min
Normed load value: 56.9 %
Voltage terminal 30: 14.238 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 1723 s
MAP_MES_SAE: 82 kPa
FAC_TPS_1_SAE: 20.312500 %
FUP_H_SAE: 19780.0 kPa
Address 02: Auto Trans (J217) Labels:* 09G-927-749-V1.clb
Part No SW: 09G 927 749 B HW: 09G 927 749 B
Component: AISIN AG6 G3 101 2855
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_001_VW25.rod
VCID: 3874E1F983E4A14B3B-806C
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: C54BC0F5492800FAA31303E692210041A0100012
VCID: 7EF837E1E9405F7BB1-802A
Part No SW: 561 907 426 E HW: 561 907 426 E
Component: AC Manuell H02 0303
Revision: 00001K02
Coding: 0010001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 1D3A106D0C06E463C8-8048
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: EF200E1B902B08D4098800010600044800F1A08640801D20648060000C70
Shop #: WSC 34687 002 1048576
VCID: 78F421F9CB64614BFB-802C
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM03N6N5
Coding: 00005033
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75EA28CDD4761C23E0-8020
Serial number: 6940000Y1300010DXL0$
Coding: 303044
Serial number: 3572MSME7D12147EZZZ%
Serial number: 3582MSME0B36317FZZZ/
Serial number: 3516KSME046E3B28ZZZ.
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME0A3B2229ZZZT
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME7971042AZZZY
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME706E042AZZZ
Part No SW: 1K5 953 521 BM HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20131106301362
Coding: 088A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 79F224FDF86E784384-802C
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 F HW: 561 920 970 F
Component: KOMBI H04 0811
Coding: 231E01
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 23111303001104
Coding: 461000
VCID: 7BFE3EF5FA524A5396-802E
Address 1C: Position Sensing
Component: IMMO H04 0811
VCID: 6AD00BB18DC8C3DB7D-803E
Address 2E: Media Player 3
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0007551978
Coding: 0404F5
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BBE5E755292AA53F6-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630131118150940
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 288 3501
Revision: 00H22000
VCID: 3972E4FD70EEB843C4-806C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 01030108
VCID: 6FE61AA5BE2A26F32A-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011315400458
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0007573547
Coding: 0404F4
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CBC5D69579CAD6BFF-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631131119073805
Coding: 800000
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7N3522476
Coding: 0100044004000B
VCID: 2B5ECEB54AB21AD346-807E
Reset counter: 119
Mileage: 134290 km
Date: 2015.12.20
Time: 20:36:33
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140510
Coding: 02140102C2163A107F1606C00000
ROD: EV_OCULow_001.rod
VCID: 53AEB6553A4262132E-8006
12670464 - Databus
Fault Frequency: 18
Reset counter: 122
Mileage: 129987 km
Date: 2021.06.20
Time: 00:34:24
0035 - Databus
Fault Frequency: 18
Reset counter: 122
Mileage: 129987 km
Date: 2021.06.20
Time: 00:34:24
2103041 - Control Module
Fault Priority: 8
Reset counter: 86
Mileage: 134524 km
Date: 2021.07.31
Time: 21:50:01
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665501647
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E58C7A171A06FFB61-807A
End-------------------------(Elapsed Time: 03:32)--------------------------
P2337 00 [032] - Limit Reached
Mileage: 134409 km
Date: 2021.07.30
Time: 22:21:30
STATE_LS_SAE[1]: CL
T_AST_SAE: 1722 s
MAP_MES_SAE: 97 kPa
P102F 00 [032] - -
Mileage: 134409 km
Date: 2021.07.30
Time: 22:21:31
STATE_LS_SAE[1]: CL
T_AST_SAE: 1723 s
MAP_MES_SAE: 82 kPa
09:56:22
IDE00188 Fuel high-pressure: actual value 59.4 bar
09:59:20
IDE00188 Fuel high-pressure: actual value 56.5 bar
IDE00407 Rail pressure regulation: status Regulated operation via quantity control valve
IDE00589 Fuel pressure 5620 kPa rel
IDE01774 Status misfire recognition not active
IDE01775 Misfires per 1000 revolutions of cylinder 1 0
IDE01776 Misfires per 1000 revolutions of cylinder 2 0
IDE06192 Knock sensor: cylinder 2: voltage 0.462 V
IDE06193 Knock sensor: cylinder 3: voltage 0.542 V
IDE06194 Knock sensor: cylinder 4: voltage 0.460 V
IDE06195 Knock sensor: cylinder 1: voltage 0.506 V
09:59:29
IDE00188 Fuel high-pressure: actual value 57.1 bar
IDE00589 Fuel pressure 5610 kPa rel
IDE06192 Knock sensor: cylinder 2: voltage 0.459 V
IDE06193 Knock sensor: cylinder 3: voltage 0.535 V
IDE06194 Knock sensor: cylinder 4: voltage 0.463 V
IDE06195 Knock sensor: cylinder 1: voltage 0.498 V
