2006 Audi A3 2.0 TDI DSG (BKD) - Limp mode p-0299
VAGMAN
C?ID=374246
Hi,
I'm looking for some advice/guidance, I have a 2006 Audi 2.0 TDI DSG (BKD engine). It goes into limp mode with the following message.
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
RPM: 2415 /min
Torque: 240.0 Nm
Speed: 75.0 km/h
Load: 94.5 %
Voltage: 13.83 V
Bin. Bits: 11000000
Absolute Pres.: 2499.0 mbar
Absolute Pres.: 1346.4 mbar
This only seems to happen when the car is in 5th/6th gear.
The turbo actuator was removed and checked, it holds vacuum and moves freely.
The EGR cooler vacuum valve also holds vacuum.
All of the turbo pipes have been removed and checked for holes/leaks, seals all look good and when connected there is no movement between the connected pipes.
The vacuum pipes on the black solenoid have been vacuum tested:
the pipe that goes to the EGR cooler vacuum valve holds vacuum.
the pipe which goes to the turbo actuator holds vacuum.
the pipe which goes to the EGR valve holds vacuum.
the pipe that goes to the tandem pump holds vacuum.
the pipe which goes to the MAF sensor does not hold vacuum at all, I assume this is normal?
the pipe which goes to the vacuum reservoir (black ball) holds vacuum.
whilst the actuator was off, the movement in the turbo vanes was checked, the arm moved freely from top to bottom with very minimal effort.
Is there anything I've missed?
I understand there is a boost sensor, could this be an issue based on the message which is being logged?
could the black solenoid valve, where the vacuum pipes connect be faulty? is there a way I can test this?
any advice would be great, TIA
VAGMAN
C?ID=374246
Monday,26,July,2021,13:12:50:25558
VCDS Version: 21.3.0.0 (x64)
Address 01: Engine Labels: 03G-906-016-BKD.clb
Control Module Part Number: 03G 906 016 DT HW: 028 101 189 2
Component and/or Version: R4 2,0L EDC 0000AG 7000
Software Coding: 0300078
Work Shop Code: WSC 02629 005 00000
VCID: 78F9AE3F0BB09D4BFB-802C
RPM: 2142 /min
Torque: 146.0 Nm
Speed: 109.0 km/h
Load: 27.8 %
Voltage: 14.14 V
Bin. Bits: 11000000
Absolute Pres.: 1601.4 mbar
Absolute Pres.: 1203.6 mbar
Greetings from the USA, I would highly recommend that you post a full and unedited Autoscan ; its very helpful to "see the entire picture" !
VAGMAN
C?ID=374246
Hi Stefdds, thanks for the suggestion, below is one I've just taken from the car.
TIA for any pointers/guidance.
Sunday,01,August,2021,16:55:12:25558
VIN: WAUZZZ8P06A186786   License Plate:
Mileage: 174000km-108118mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77 7D
VIN: WAUZZZ8P06A186786   Mileage: 174000km-108118miles
   Part No SW: 03G 906 016 DT    HW: 028 101 189 2
   Component: R4 2,0L EDC 0000AG  7000
   Revision: 12345678    Serial number: AUX7Z0F2FNI049
   Coding: 0300078
   Shop #: WSC 02629 005 00000
                    RPM: 3549 /min
                    Torque: 304.0 Nm
                    Speed: 111.0 km/h
                    Load: 100.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 11000100
                    Absolute Pres.: 2417.4 mbar
                    Absolute Pres.: 1836.0 mbar
   Part No SW: 02E 300 042 S    HW: 02E 927 770 AE
   Component: GSG DSG         070 1102
   Revision: 04507000    Serial number: 00000603030083
   Shop #: WSC 06314 000 00000
   VCID: 2343A953E2B62E93FE-8076
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0023170
   VCID: 71EF931B68CACC033C-8024
   Part No SW: 8P0 820 043 M    HW: 8P0 820 043 M
   Component: KlimavollautomatH18 0260
   Revision: 314473      Serial number: 8P0820043M
   VCID: 366560074124AB3B29-8062
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H43 1201
   Revision: 00H43000    Serial number: 00000005559175
   Coding: 01884F01B214100000160000160000000008FE175C0100
   Shop #: WSC 06314 000 08192
   VCID: 408906DF13E0158B83-8014
   Subsystem 1 - Part No: 8P2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 C    HW: 8P0 959 655 C
   Component:    Airbag 9.41  H12 3760
   Revision: 91H12376    Serial number: 00362006UNN7
   Coding: 0071612
   VCID: 428D0CD71DEC079B95-8016
   Subsystem 1 - Serial number: 6332DRB40315101F9
   Subsystem 2 - Serial number: 6342DRB4031549B2J
   Subsystem 3 - Serial number: 63528RB4010C55D7N
   Subsystem 4 - Serial number: 63628RB4010D12D4F
   Subsystem 5 - Serial number: 63729RB401164F89R
   Subsystem 6 - Serial number: 63829RB4011649EAT
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H34 0070
   Coding: 0011112
   VCID: 418F03DB18EA1C838C-8014
   Component: E0221           H03 0080
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 981 B    HW: 8P0 920 981 B
   Component: KOMBIINSTR. VDO H80 0420
   Revision: D06         Serial number: 2242FD06013714
   Coding: 0000413
   Shop #: WSC 51791 067 57207
   VCID: 377B6D03462E523332-8062
   Part No SW: 1K0 907 530 G    HW: 1K0 907 951
   Component: J533__Gateway   H10 0140
   Revision:   H10       Serial number: 300010630180F1
   Coding: 3F3F0BC007002103
   VCID: 2B5341738A66E6D346-807E
   Revision: D06         Serial number: AUX7Z0F2FNI049
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0090
   Coding: 0000688
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 34615A0F5758B92B17-8060
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 C
   Component:    KSG          H04 0050
   Coding: 198000186D088505489FC63300
   VCID: 3C71722F7F08716BDF-8068
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H04 0020
00955 - Key 1
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Coding: 0000688
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186 C    HW: 8P0 035 186 C
   Component: concert II EU   H52 0100
   Revision:      02S    Serial number: AUZ2Z3F3742191
   Coding: 0021221
   Shop #: WSC 06435 000 00000
   VCID: 326D5C17AD4CB71B05-8066
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 D
   Component: Tuer-SG         020 0070
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 D
   Coding: 0000144
   Part No SW: 8P0 862 335 M    HW: 8P0 862 335 M
   Component: FSE_255x BT     H21 0200
   Revision: 00000001    Serial number: 00000000424935
   Coding: 0000122
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D574F6BB472E8E358-8078
End-------------------------(Elapsed Time: 02:08)--------------------------
Sounds like it's not making the amount of boost it should. You can check that in MVB 011, where field 2 is the specified pressure and field 3 is the actual (measured) pressure. It might make sense to log that data to see how it behaves short of setting a fault code.
Does the turbo spin freely?
VAGMAN
C?ID=374246
Hi Uwe,
thanks, yes the turbo moves freely, I’ll have a go at MVB 11 and see what it outputs.
will report back when it’s done
thanks
VAGMAN
C?ID=374246
Hi Uwe,
I logged the information for the MVB 11 and below is what was recorded, the engine module logged the same error code:
RPM: 2583 /min
Torque: 308.0 Nm
Speed: 108.0 km/h
Load: 100.0 %
Voltage: 14.21 V
Bin. Bits: 11000000
Absolute Pres.: 1632.0 mbar
Sunday    1    August    2021    19:21:38:25558-VCID:78F9AE3F0BB09D4BFB-802C    VCDS Version: Release 21.3.0 (x64)    Data version: 20210226 DS325.0
03G 906 016 DT        R4 2.0L EDC 0000AG  7000
    Group A:    '011                Group B:     Not Running                Group C:     Not Running
        Engine Speed    Charge Pressure    Boost Pressure    Charge Pressure
    TIME    (G28)    Control Status    (actual)    Control Duty Cycle    TIME                    TIME
Marker    STAMP     /min     mg/str     mbar     %    STAMP                    STAMP
    0.03    819    6.9    989.4    76.1
    0.19    819    6.9    989.4    76.1
    0.35    819    6.9    989.4    76.1
    0.52    819    7.1    989.4    76.1
    0.7    819    6.6    989.4    76.1
    0.87    819    6.6    989.4    76.1
    1.04    819    6.6    989.4    76.1
    1.2    840    6.6    989.4    76.1
    1.36    819    6.9    989.4    76.1
    1.51    819    7.1    989.4    76.1
    1.68    819    6.9    989.4    76.1
    1.84    819    6.9    989.4    76.1
    2    819    6.9    989.4    76.1
    2.15    819    7.1    989.4    76.1
    2.32    819    7.1    989.4    76.1
    2.49    819    6.9    989.4    76.1
    2.65    819    7.1    989.4    76.1
    2.8    819    7.1    989.4    76.1
    2.96    819    7.4    989.4    76.1
    3.16    819    7.1    989.4    76.1
    3.32    819    7.4    989.4    76.1
    3.49    819    7.7    989.4    76.1
    3.67    819    7.7    989.4    76.1
    3.84    777    15.9    989.4    76.5
    3.99    924    15.6    989.4    80.9
    4.17    1029    15.4    979.2    81.3
    4.34    1071    13.7    979.2    78.9
    4.51    1092    12.4    979.2    76.1
    4.7    1113    12.1    979.2    75.3
    4.87    1113    12.1    979.2    74.9
    5.03    1092    12.4    979.2    76.1
    5.2    1092    12.6    979.2    76.1
    5.36    1092    14    979.2    78.5
    5.51    1092    13.7    979.2    78.9
    5.67    1092    14.3    979.2    79.7
    5.84    1092    14.5    979.2    80.1
    6.01    1071    15.1    979.2    81.3
    6.15    1050    9.9    979.2    78.9
    6.31    987    3.8    989.4    75.3
    6.49    945    4.4    989.4    76.1
    6.64    903    5.2    989.4    76.1
    6.81    861    6.9    989.4    76.1
    6.95    840    7.4    989.4    76.1
    7.13    819    8.2    989.4    76.1
    7.28    819    8.2    989.4    76.1
    7.44    819    8    989.4    76.1
    7.59    819    8.2    989.4    76.1
    7.77    819    8.2    989.4    76.1
    7.92    819    8.2    989.4    76.1
    8.08    819    8.5    989.4    76.1
    8.24    819    8.5    989.4    76.1
    8.41    819    8.2    989.4    76.1
    8.57    819    8.2    989.4    76.1
    8.74    819    8.5    989.4    76.1
    8.93    819    8.2    989.4    76.1
    9.1    819    8.5    989.4    76.1
    9.26    819    8.2    989.4    76.1
    9.45    819    8.2    989.4    76.1
    9.62    840    8    989.4    76.1
    9.79    840    8    989.4    76.1
    9.98    819    8.2    989.4    76.1
    10.16    840    8    989.4    76.1
    10.32    819    8.2    989.4    76.1
    10.51    819    8.2    989.4    76.1
    10.68    819    8.5    989.4    76.1
    10.85    819    8.2    989.4    76.1
    11.02    819    8    989.4    76.1
    11.18    819    8.5    989.4    76.1
    11.35    819    8.2    989.4    76.1
    11.5    819    8.2    989.4    76.1
    11.68    819    8    989.4    76.1
    11.85    819    8.5    989.4    76.1
    12.01    819    8.5    989.4    76.1
    12.2    819    9.1    989.4    76.1
    12.37    819    8.8    989.4    76.1
    12.53    819    9.1    989.4    76.1
    12.7    798    9.6    989.4    76.1
    12.86    798    9.9    989.4    76.1
    13.01    819    9.3    989.4    76.1
    13.17    819    8.8    989.4    76.1
    13.35    840    8.2    989.4    76.1
    13.5    861    7.1    989.4    76.1
    13.66    861    7.1    989.4    76.1
    13.81    840    7.4    989.4    76.1
    14    840    7.7    989.4    76.1
    14.16    840    8    989.4    76.1
    14.31    840    7.7    989.4    76.1
    14.49    819    8.2    989.4    76.1
    14.64    819    8    989.4    76.1
    14.8    819    8.2    989.4    76.1
    14.96    819    8    989.4    76.1
    15.13    966    15.4    989.4    81.3
    15.28    1092    10.7    979.2    73.7
    15.44    1092    16.7    979.2    81.3
    15.6    1176    20.3    979.2    80.9
    15.77    1281    21.4    969    77.7
    15.92    1323    22.2    958.8    76.1
    16.08    1260    22.5    958.8    77.7
    16.24    1197    22.2    969    80.9
    16.41    1197    15.4    979.2    80.1
    16.57    1134    14.8    989.4    80.9
    16.74    1176    14    989.4    78.9
    16.89    1197    15.4    989.4    78.5
    17.07    1260    20.6    979.2    78.1
    17.22    1365    19.8    979.2    76.1
    17.38    1344    19.8    979.2    76.1
    17.53    1239    15.9    979.2    77.7
    17.71    1134    11.8    989.4    76.9
    17.86    1113    8.2    999.6    71.7
    18.02    1071    7.7    999.6    72.9
    18.17    1050    4.7    999.6    74.1
    18.35    966    6.6    999.6    76.1
    18.5    945    10.4    999.6    76.1
    18.66    966    16.7    989.4    80.9
    18.81    1029    16.2    989.4    81.3
    18.99    1134    12.4    979.2    76.1
    19.14    1134    12.6    979.2    75.3
    19.3    1113    16.5    979.2    81.3
    19.45    1134    20.6    979.2    81.3
    19.63    1134    20.6    969    81.3
    19.78    1113    10.7    979.2    80.1
    19.94    1050    5.8    979.2    74.1
    20.09    966    4.7    989.4    76.1
    20.27    924    5.2    989.4    76.1
    20.42    882    6.3    989.4    76.1
    20.58    861    6.6    989.4    76.1
    20.74    861    6.9    989.4    76.1
    20.91    840    6.9    989.4    76.1
    21.07    840    7.1    989.4    76.1
    21.22    840    7.4    989.4    76.1
    21.37    903    23.1    989.4    81.3
    21.55    1155    13.7    969    78.9
    21.7    1176    12.9    969    75.7
    21.86    1134    14.3    979.2    79.7
    22.02    1092    12.6    979.2    77.3
    22.19    1092    13.2    979.2    77.7
    22.35    1071    13.2    979.2    78.1
    22.5    1092    13.2    979.2    77.7
    22.66    1092    14.8    979.2    79.3
    22.83    1113    18.1    979.2    81.3
    22.99    1155    16.7    979.2    80.9
    23.15    1155    17    979.2    80.9
    23.34    1134    18.1    979.2    81.3
    23.51    1113    18.4    979.2    81.3
    23.68    1134    18.9    979.2    81.3
    23.85    1155    20.9    979.2    81.3
    24    1134    20.9    979.2    81.3
    24.16    1155    23.1    979.2    80.9
    24.32    1155    22.8    989.4    80.9
    24.49    1155    22.5    989.4    80.5
    24.65    1155    22.5    989.4    80.9
    24.82    1155    21.1    989.4    80.9
    24.97    1155    16.5    989.4    80.9
    25.16    1134    16.5    999.6    81.3
    25.32    1134    15.1    999.6    81.3
    25.47    1134    12.6    999.6    80.1
    25.63    1113    14.8    999.6    74.5
    25.8    1134    8.2    989.4    70.9
    25.96    1134    7.1    989.4    70.9
    26.12    1134    5.5    989.4    70.5
    26.31    1134    5.5    989.4    70.9
    26.48    1113    6    989.4    71.7
    26.65    1092    6.6    989.4    72.1
    26.84    1092    6.9    989.4    71.7
    27.01    1092    6.6    989.4    71.7
    27.18    1113    8.2    989.4    71.3
    27.37    1113    8.5    989.4    71.3
    27.54    1134    8.2    979.2    70.5
    27.71    1155    8.5    979.2    69.7
    27.88    1176    8    979.2    69.7
    28.04    1176    7.7    979.2    69.7
    28.21    1176    7.7    979.2    69.7
    28.38    1176    8    979.2    69.7
    28.54    1155    8.2    979.2    69.7
    28.7    1155    8.5    979.2    69.7
    28.89    1155    8.8    979.2    70.1
    29.06    1155    9.1    979.2    69.7
    29.23    1134    10.4    979.2    70.1
    29.42    1155    13.2    979.2    76.5
    29.59    1176    12.9    979.2    76.1
    29.76    1176    13.2    979.2    76.1
    29.95    1176    12.9    979.2    76.1
    30.12    1176    12.9    979.2    75.7
    30.29    1197    12.6    979.2    75.3
    30.49    1218    12.6    979.2    74.5
    30.65    1239    12.4    979.2    74.1
    30.82    1260    12.9    979.2    73.3
    31    1281    16.2    979.2    76.9
    31.17    1344    15.9    969    76.1
    31.34    1323    5.8    969    69.7
    31.51    1302    6    979.2    69.7
    31.67    1302    6    979.2    69.7
    31.84    1281    6.3    979.2    69.7
    32    1281    6    979.2    69.7
    32.19    1302    6    979.2    69.7
    32.36    1281    6.3    979.2    69.7
    32.51    1302    9.6    979.2    69.7
    32.69    1344    11.8    979.2    70.1
    32.84    1302    12.4    979.2    72.9
    33.01    1281    12.4    979.2    73.3
    33.15    1323    12.1    979.2    72.9
    33.33    1323    12.1    979.2    72.9
    33.49    1344    12.1    979.2    72.5
    33.64    1365    12.1    979.2    72.1
    33.79    1365    11.8    979.2    71.7
    33.98    1386    11.3    979.2    70.9
    34.15    1407    4.7    979.2    69.7
    34.32    1386    4.7    979.2    69.7
    34.5    1323    4.4    979.2    70.1
    34.68    1344    4.1    979.2    70.1
    34.84    1344    4.1    979.2    70.1
    35.02    1323    4.4    979.2    70.1
    35.2    1302    4.4    979.2    70.1
    35.37    1281    4.4    979.2    70.1
    35.57    1260    3.8    979.2    70.1
    35.73    1239    3.8    979.2    70.1
    35.9    1218    3.8    979.2    70.1
    36.09    1197    0.8    979.2    70.5
    36.26    1197    0    979.2    70.9
    36.43    1155    0    979.2    70.9
    36.6    1134    0    979.2    70.9
    36.76    1113    0    979.2    72.1
    36.93    1092    0    979.2    72.9
    37.11    1050    0    979.2    73.7
    37.26    1029    0    989.4    74.9
    37.43    987    0.5    989.4    76.1
    37.61    945    0.8    989.4    76.1
    37.78    903    1.1    989.4    76.1
    37.94    882    0.8    989.4    76.1
    38.12    861    0.8    989.4    76.1
    38.29    840    19.8    989.4    78.9
    38.45    987    19.8    979.2    81.3
    38.63    1071    18.1    969    81.3
    38.78    1197    16.5    969    80.1
    38.94    1260    18.7    969    78.5
    39.1    1260    20.6    969    77.7
    39.27    1260    20.9    969    78.1
    39.42    1239    21.1    969    79.3
    39.58    1218    21.4    979.2    80.1
    39.74    1218    21.7    979.2    80.5
    39.91    1218    23.3    989.4    79.7
    40.07    1239    23.9    989.4    78.9
    40.22    1239    24.4    989.4    78.9
    40.38    1302    24.4    989.4    76.1
    40.55    1365    24.7    989.4    76.1
    40.71    1428    24.7    989.4    76.1
    40.87    1449    25    999.6    76.1
    41.07    1491    25.3    999.6    76.1
    41.23    1554    25.3    999.6    76.1
    41.4    1617    25    1009.8    76.1
    41.58    1680    24.4    1020    76.1
    41.74    1722    23.6    1020    76.1
    41.89    1785    23.3    1020    76.1
    42.05    1827    23.1    1020    76.1
    42.23    1869    22.8    1030.2    76.1
    42.4    1911    22.5    1030.2    76.1
    42.57    1953    22.5    1030.2    76.1
    42.74    1953    22.2    1040.4    75.7
    42.9    1890    21.1    1040.4    75.3
    43.07    1701    22.8    1050.6    75.7
    43.25    1596    23.6    1050.6    75.7
    43.42    1470    24.4    1040.4    76.1
    43.61    1407    25.3    1040.4    76.1
    43.78    1365    26.1    1040.4    76.1
    43.95    1386    26.1    1040.4    76.1
    44.12    1407    25.8    1030.2    76.1
    44.31    1449    26.1    1030.2    76.1
    44.47    1470    26.1    1030.2    76.1
    44.62    1491    26.1    1030.2    76.1
    44.79    1533    26.1    1030.2    76.1
    44.95    1575    26.4    1030.2    76.1
    45.12    1596    26.4    1040.4    76.1
    45.29    1575    26.4    1040.4    75.7
    45.46    1596    26.6    1040.4    76.1
    45.62    1617    26.6    1040.4    76.1
    45.79    1659    26.9    1040.4    75.7
    45.97    1680    26.9    1040.4    72.9
    46.14    1701    26.9    1050.6    72.9
    46.3    1722    27.2    1050.6    75.7
    46.48    1764    27.2    1050.6    76.1
    46.64    1785    27.5    1050.6    76.1
    46.8    1806    27.7    1050.6    76.1
    46.97    1827    27.7    1060.8    76.1
    47.13    1869    27.7    1060.8    76.1
    47.28    1785    0.5    1060.8    70.9
    47.44    1827    0    1060.8    70.9
    47.61    1806    0    1040.4    70.9
    47.77    1806    0    1020    70.9
    47.93    1785    0    999.6    70.9
    48.08    1806    25    999.6    76.1
    48.25    1785    25.8    989.4    76.1
    48.41    1575    23.9    979.2    75.3
    48.57    1281    24.7    999.6    76.1
    48.72    1239    25.3    1009.8    78.5
    48.9    1260    25.5    1009.8    78.5
    49.05    1260    25.5    1009.8    78.5
    49.21    1260    25.5    1009.8    77.7
    49.37    1281    25.5    1020    76.9
    49.54    1281    25.5    1020    76.5
    49.71    1302    25.5    1020    76.1
    49.87    1302    25.5    1020    76.1
    50.06    1323    25.8    1020    76.1
    50.23    1344    25.8    1020    76.1
    50.4    1344    25.8    1020    76.1
    50.57    1344    25.8    1020    76.1
    50.73    1365    25.8    1020    76.1
    50.9    1365    25.8    1020    76.1
    51.05    1386    26.1    1030.2    76.1
    51.23    1386    26.1    1030.2    76.1
    51.4    1407    26.1    1030.2    76.1
    51.56    1407    26.1    1030.2    76.1
    51.76    1428    26.1    1030.2    76.1
    51.93    1428    26.1    1030.2    76.1
    52.09    1449    26.1    1030.2    76.1
    52.28    1449    26.4    1030.2    76.1
    52.45    1449    26.4    1040.4    76.1
    52.62    1470    26.4    1040.4    76.1
    52.81    1470    26.4    1040.4    76.1
    52.98    1491    26.6    1040.4    76.1
    53.15    1491    26.6    1040.4    76.1
    53.31    1512    26.6    1040.4    76.1
    53.48    1533    26.6    1040.4    76.1
    53.65    1533    26.6    1040.4    76.1
    53.86    1533    26.6    1040.4    76.1
    54.01    1554    26.9    1050.6    76.1
    54.16    1554    0    1050.6    68.9
    54.3    1512    0    1050.6    70.9
    54.49    1512    0    1030.2    70.9
    54.64    1512    0    1020    70.9
    54.81    1512    0    999.6    70.9
    55    1491    0    999.6    70.9
    55.17    1554    24.2    989.4    76.1
    55.33    1575    24.2    969    75.7
    55.5    1512    24.7    979.2    76.1
    55.66    1512    25    989.4    76.1
    55.81    1533    25.3    999.6    76.1
    55.97    1533    25.5    1009.8    76.1
    56.15    1554    25.8    1009.8    76.1
    56.3    1554    26.1    1020    76.1
    56.46    1575    26.4    1030.2    76.1
    56.61    1575    26.4    1030.2    76.1
    56.79    1575    26.6    1040.4    76.1
    56.94    1596    26.6    1040.4    76.1
    57.1    1596    26.9    1040.4    75.7
    57.26    1617    26.9    1040.4    76.1
    57.44    1617    27.2    1050.6    76.1
    57.6    1638    27.2    1050.6    76.1
    57.75    1638    27.2    1050.6    76.1
    57.91    1638    27.5    1060.8    76.1
    58.08    1659    27.5    1060.8    76.1
    58.24    1680    27.5    1060.8    76.1
    58.39    1680    27.5    1060.8    76.1
    58.55    1701    27.5    1060.8    76.1
    58.74    1722    27.7    1060.8    76.1
    58.89    1701    27.7    1060.8    76.1
    59.06    1722    27.7    1071    76.1
    59.25    1722    28    1071    76.1
    59.42    1743    28    1071    75.7
    59.59    1743    28    1071    76.1
    59.78    1764    28.3    1071    76.1
    59.95    1680    0    1071    69.7
    60.12    1743    0    1060.8    70.9
    60.31    1722    0    1040.4    70.9
    60.48    1743    0    1020    70.9
    60.65    1722    0    999.6    70.9
    60.83    1680    0    999.6    70.9
    61    1680    0    989.4    70.9
    61.17    1701    23.6    989.4    76.1
    61.36    1827    24.4    969    76.1
    61.53    2184    24.7    969    75.7
    61.69    2562    24.7    969    73.7
    61.87    2835    24.4    989.4    72.5
    62.02    2919    0    1020    52.6
    62.18    2562    0    1060.8    59.4
    62.33    2373    0    1081.2    65.7
    62.5    2184    0    1050.6    70.9
    62.66    1890    0    1040.4    70.9
    62.81    1638    0    1040.4    70.9
    62.98    1449    5.2    1030.2    70.9
    63.17    1617    24.4    1009.8    76.1
    63.33    1848    24.7    989.4    76.1
    63.49    1869    25.8    989.4    74.9
    63.64    1659    26.4    999.6    73.7
    63.82    1659    26.4    1030.2    75.7
    63.97    1680    26.6    1030.2    76.1
    64.13    1575    25.8    1040.4    74.9
    64.28    1365    26.1    1040.4    76.1
    64.46    1281    26.9    1050.6    76.5
    64.62    1260    25.5    1040.4    4.8
    64.77    1176    0    1040.4    70.1
    64.93    1239    0    1040.4    70.9
    65.1    1239    0    1020    70.9
    65.26    1239    0    1009.8    70.9
    65.41    1218    0    1009.8    70.9
    65.57    1197    0    999.6    70.9
    65.74    1197    0    999.6    70.9
    65.9    1176    0    989.4    70.9
    66.06    1176    0    989.4    70.9
    66.25    1218    20    989.4    80.5
    66.42    1302    24.2    969    76.5
    66.59    1218    24.4    969    78.9
    66.78    1197    24.4    979.2    80.1
    66.95    1176    24.7    989.4    80.5
    67.12    1176    25    989.4    80.1
    67.3    1197    25.3    999.6    80.1
    67.46    1197    25.3    999.6    80.1
    67.62    1197    25.5    999.6    81.3
    67.81    1197    25.5    999.6    80.5
    67.98    1218    25.5    1009.8    80.1
    68.15    1218    25.8    1009.8    80.1
    68.32    1218    25.8    1009.8    80.1
    68.48    1218    25.8    1009.8    80.1
    68.65    1239    25.8    1009.8    79.7
    68.8    1239    25.8    1009.8    79.3
    68.98    1239    26.1    1020    78.9
    69.15    1239    26.1    1020    78.9
    69.3    1260    26.1    1020    78.5
    69.46    1260    26.1    1020    78.1
    69.63    1260    26.1    1020    78.5
    69.79    1260    26.1    1020    78.5
    69.95    1260    26.1    1020    77.7
    70.14    1281    26.1    1020    77.3
    70.31    1281    26.4    1020    77.3
    70.48    1281    26.4    1020    77.3
    70.67    1281    26.4    1020    76.9
    70.84    1281    26.4    1020    76.9
    71.02    1302    26.4    1030.2    76.1
    71.21    1302    26.4    1030.2    76.1
    71.37    1302    26.4    1030.2    76.1
    71.54    1302    26.4    1030.2    76.1
    71.72    1302    26.4    1030.2    76.1
    71.89    1302    26.4    1030.2    76.1
    72.06    1323    26.4    1030.2    76.1
    72.25    1344    26.6    1030.2    76.1
    72.42    1344    26.6    1030.2    76.1
    72.59    1323    26.6    1030.2    76.1
    72.79    1323    26.6    1030.2    76.1
    72.95    1344    26.6    1030.2    76.1
    73.12    1344    26.6    1030.2    76.1
    73.29    1344    26.6    1030.2    76.1
    73.45    1344    26.6    1030.2    76.1
    73.62    1365    26.6    1030.2    76.1
    73.78    1365    26.9    1040.4    76.1
    73.96    1386    26.9    1040.4    76.1
    74.12    1386    26.9    1040.4    76.1
    74.28    1386    26.9    1040.4    76.1
    74.47    1386    26.9    1040.4    76.1
    74.63    1386    0    1040.4    4.8
    74.79    1302    0    1040.4    70.9
    74.95    1344    0    1030.2    70.9
    75.14    1491    25.3    1009.8    76.1
    75.31    1449    25.3    989.4    76.1
    75.48    1386    25.5    999.6    76.1
    75.65    1533    25.8    1009.8    76.1
    75.81    1722    26.4    1009.8    76.1
    75.98    1911    26.9    1009.8    76.1
    76.17    2184    27.2    1020    75.3
    76.34    2415    27.7    1030.2    74.1
    76.51    2625    28.3    1050.6    73.3
    76.7    2688    29.6    1081.2    71.3
    76.87    2730    31.3    1132.2    70.5
    77.02    2772    32.7    1183.2    70.9
    77.18    2793    34    1234.2    70.9
    77.35    2835    35.4    1275    70.9
    77.51    2877    36.8    1326    70.1
    77.68    2919    38.2    1366.8    70.1
    77.86    2982    39.8    1428    69.7
    78.02    3024    41.5    1479    68.9
    78.18    3045    43.4    1540.2    65.3
    78.35    3108    44.7    1601.4    62.2
    78.51    3171    46.4    1672.8    58.6
    78.67    3234    47.8    1744.2    55.8
    78.84    3297    49.4    1825.8    52.2
    79.03    3381    51.9    1917.6    48.6
    79.2    3444    52.4    2009.4    45
    79.37    3444    23.1    2101.2    4.8
    79.54    3444    17.8    2070.6    10.4
    79.7    3402    0    1876.8    47.4
    79.87    3381    0    1652.4    47.8
    80.04    3423    0    1417.8    47.8
    80.2    3402    0    1275    47.8
    80.37    3360    0    1173    47.8
    80.53    3318    0    1111.8    48.6
    80.72    3234    0    1060.8    49
    80.89    3171    0    1040.4    49.8
    81.06    3108    0    1030.2    50.2
    81.24    3024    0    1020    51
    81.42    2961    0    1009.8    52.2
    81.59    2772    0    999.6    55
    81.78    2436    0    1009.8    63
    81.95    2289    0    1020    69.3
    82.12    2121    0    1020    70.9
    82.3    2016    0    1009.8    70.9
    82.47    1932    0    1009.8    70.9
    82.64    1869    24.2    1009.8    74.9
    82.83    1953    24.7    999.6    76.1
    83    1848    26.1    999.6    74.5
    83.17    1848    26.9    1009.8    76.1
    83.37    1848    27.5    1030.2    75.7
    83.53    1785    26.4    1040.4    75.3
    83.7    1386    27.7    1060.8    76.1
    83.89    1407    27.7    1060.8    76.1
    84.05    1407    27.7    1060.8    76.1
    84.21    1428    27.7    1060.8    76.1
    84.37    1428    27.7    1050.6    76.1
    84.54    1344    26.9    1050.6    76.1
    84.7    1176    27.7    1060.8    80.5
    84.87    1197    27.7    1060.8    80.1
    85.04    1197    27.5    1050.6    80.1
    85.2    1680    26.9    1030.2    76.1
    85.37    2247    27.2    1009.8    75.3
    85.55    2793    25.8    1009.8    72.9
    85.72    2772    27.2    1030.2    70.5
    85.89    2793    29.6    1091.4    69.7
    86.08    2835    9.6    1162.8    4.8
    86.25    2751    0    1213.8    56.2
    86.41    2730    0    1193.4    56.2
    86.58    2730    0    1122    56.6
    86.74    2730    0    1071    56.6
    86.89    2667    0    1050.6    57.8
    87.06    2520    0    1030.2    60.2
    87.25    2331    0    1020    66.9
    87.42    2205    8.2    1020    70.9
    87.58    2163    5.8    1020    70.9
    87.77    2037    6    1030.2    70.9
    87.94    2058    27.7    1030.2    75.7
    88.11    2163    26.9    999.6    75.3
    88.3    1827    27.5    1030.2    73.3
    88.47    1764    0    1050.6    70.9
    88.63    1827    0    1060.8    70.9
    88.81    1890    15.4    1040.4    70.9
    88.97    1911    21.7    1030.2    74.9
    89.13    1806    0    1020    70.9
    89.3    1617    0    1030.2    70.9
    89.46    1323    0    1030.2    70.9
    89.61    1281    0    1030.2    70.9
    89.77    1281    0    1020    70.9
    89.94    1323    26.4    1009.8    76.1
    90.1    1491    24.7    989.4    76.1
    90.26    1449    25    979.2    76.1
    90.42    1344    25.5    989.4    76.1
    90.6    1344    25.8    999.6    76.1
    90.76    1365    26.1    1009.8    76.1
    90.92    1365    26.4    1009.8    76.1
    91.09    1365    26.6    1020    76.1
    91.26    1365    26.6    1030.2    76.1
    91.42    1386    26.6    1030.2    76.1
    91.59    1386    26.9    1030.2    76.1
    91.74    1407    26.9    1040.4    76.1
    91.92    1386    27.2    1040.4    76.1
    92.09    1386    27.2    1040.4    76.1
    92.24    1386    27.2    1040.4    76.1
    92.39    1407    27.5    1050.6    76.1
    92.57    1407    27.5    1050.6    76.1
    92.73    1407    27.5    1050.6    76.1
    92.88    1407    27.5    1050.6    76.1
    93.04    1407    27.5    1050.6    76.1
    93.21    1407    27.5    1050.6    76.1
    93.37    1428    27.7    1050.6    76.1
    93.53    1428    27.5    1050.6    76.1
    93.72    1428    27.7    1050.6    76.1
    93.89    1428    27.7    1050.6    76.1
    94.06    1428    27.7    1060.8    76.1
    94.26    1428    27.7    1050.6    76.1
    94.42    1428    27.7    1050.6    76.1
    94.59    1449    27.7    1060.8    76.1
    94.77    1449    27.7    1060.8    76.1
    94.94    1449    27.7    1060.8    76.1
    95.11    1449    27.7    1060.8    76.1
    95.28    1449    27.7    1060.8    76.1
    95.44    1449    27.7    1060.8    76.1
    95.6    1470    27.7    1060.8    76.1
    95.77    1470    27.7    1060.8    76.1
    95.94    1470    28    1060.8    76.1
    96.1    1470    27.7    1060.8    76.1
    96.25    1470    27.7    1060.8    76.1
    96.41    1491    0    1060.8    4.8
    96.58    1428    0    1060.8    70.9
    96.74    1449    0    1050.6    70.9
    96.89    1428    0    1030.2    70.9
    97.05    1428    0    1020    70.9
    97.23    1386    0    1009.8    70.9
    97.38    1365    0    999.6    70.9
    97.54    1344    0    999.6    70.9
    97.69    1302    0    999.6    70.9
    97.87    1260    0    999.6    70.9
    98.03    1239    0    989.4    70.9
    98.18    1197    0    989.4    70.9
    98.34    1155    0    989.4    70.9
    98.51    1134    0    989.4    71.3
    98.67    1092    0    989.4    72.5
    98.84    1071    0    989.4    73.3
    99.02    1071    0    989.4    73.7
    99.19    1050    0    989.4    74.1
    99.36    1050    0    989.4    74.5
    99.56    1029    0    989.4    74.5
    99.72    1029    0    989.4    74.9
    99.89    1029    11    989.4    74.1
    100.07    1071    11.3    979.2    74.1
    100.23    1155    24.7    979.2    81.3
    100.39    1218    24.4    969    80.5
    100.58    1260    24.7    969    78.1
    100.74    1365    24.7    969    76.1
    100.89    1365    25    969    76.1
    101.05    1386    25.3    979.2    76.1
    101.24    1386    25.5    989.4    76.1
    101.39    1386    25.8    999.6    76.1
    101.55    1407    26.1    1009.8    76.1
    101.71    1428    26.4    1009.8    76.1
    101.88    1428    26.6    1020    76.1
    102.03    1449    26.9    1030.2    76.1
    102.2    1470    26.9    1030.2    76.1
    102.35    1470    27.2    1040.4    76.1
    102.52    1470    27.2    1040.4    76.1
    102.67    1470    27.5    1050.6    76.1
    102.83    1491    27.5    1050.6    76.1
    103    1491    27.5    1050.6    76.1
    103.19    1512    27.7    1050.6    76.1
    103.36    1533    27.7    1060.8    76.1
    103.52    1533    28    1060.8    76.1
    103.71    1533    28    1060.8    76.1
    103.86    1554    28    1060.8    76.1
    104.02    1554    28    1060.8    76.1
    104.18    1575    28    1071    76.1
    104.35    1575    28    1071    76.1
    104.5    1575    28    1071    75.3
    104.65    1512    0    1071    70.5
    104.82    1554    0    1060.8    70.9
    105.01    1533    0    1030.2    70.9
    105.17    1554    0    1009.8    70.9
    105.35    1533    0    1009.8    70.9
    105.53    1512    0    999.6    70.9
    105.7    1491    0    999.6    70.9
    105.85    1470    0    989.4    70.9
    106    1470    0    989.4    70.9
    106.18    1491    20    989.4    76.1
    106.33    1596    25.3    989.4    76.1
    106.49    1554    25.5    969    75.7
    106.65    1491    25.5    989.4    76.1
    106.82    1512    26.1    999.6    76.1
    106.98    1512    26.4    1009.8    76.1
    107.13    1533    26.6    1020    76.1
    107.29    1533    26.9    1030.2    76.1
    107.46    1554    27.2    1040.4    76.1
    107.62    1554    27.5    1040.4    76.1
    107.78    1575    27.5    1050.6    76.1
    107.95    1596    27.7    1050.6    76.1
    108.12    1596    27.7    1060.8    76.1
    108.28    1617    28    1060.8    76.1
    108.47    1638    28.3    1071    76.1
    108.64    1638    28.3    1071    76.1
    108.81    1974    29.4    1071    76.1
    108.97    2352    29.4    1060.8    74.5
    109.14    2646    29.4    1071    72.9
    109.31    2940    0    1091.4    4.8
    109.5    2667    0    1142.4    57.8
    109.67    2436    0    1173    62.6
    109.83    2226    0    1142.4    70.5
    110.01    1932    0    1101.6    70.9
    110.16    1680    0    1071    70.9
    110.32    1491    0    1050.6    70.9
    110.48    1491    21.1    1030.2    76.1
    110.66    1701    24.4    1009.8    76.1
    110.83    1680    26.1    999.6    75.3
    111    1638    26.4    1009.8    76.1
    111.19    1638    26.9    1030.2    75.7
    111.35    1638    26.1    1040.4    76.1
    111.51    1344    26.6    1050.6    76.1
    111.66    1260    27.7    1050.6    78.1
    111.83    1239    27.7    1050.6    78.9
    111.99    1260    27.5    1050.6    78.1
    112.15    1260    27.5    1050.6    78.1
    112.31    1260    27.5    1040.4    77.7
    112.47    1281    27.2    1040.4    76.9
    112.64    1281    27.2    1040.4    76.5
    112.81    1281    27.2    1040.4    76.5
    112.98    1302    27.2    1040.4    76.1
    113.14    1302    27.2    1040.4    76.1
    113.31    1302    27.2    1040.4    76.1
    113.47    1302    27.2    1040.4    76.1
    113.64    1323    27.5    1040.4    76.1
    113.81    1323    27.2    1040.4    76.1
    113.98    1323    27.5    1040.4    76.1
    114.13    1344    27.5    1040.4    76.1
    114.3    1344    27.5    1040.4    76.1
    114.48    1344    27.5    1040.4    62.2
    114.65    1218    0    1050.6    70.1
    114.81    1302    0    1040.4    70.9
    114.97    1323    0    1030.2    70.9
    115.15    1323    0    1020    70.9
    115.32    1302    0    1009.8    70.9
    115.47    1281    0    999.6    70.9
    115.66    1260    0    999.6    70.9
    115.83    1239    0    999.6    70.9
    116    1218    0    989.4    70.9
    116.19    1197    0    989.4    70.9
    116.36    1176    0    989.4    70.9
    116.53    1155    0    989.4    70.9
    116.7    1113    0    989.4    71.7
    116.86    1092    0    989.4    72.9
    117.03    1071    0    989.4    73.3
    117.22    1050    0.5    989.4    74.1
    117.39    1029    0.5    989.4    74.9
    117.56    1008    0.5    989.4    75.7
    117.73    1008    0    989.4    75.7
    117.89    1008    0    989.4    75.7
    118.06    987    0    989.4    76.1
    118.23    1029    18.7    989.4    81.3
    118.39    1113    17.3    979.2    81.3
    118.56    1239    19.5    969    78.9
    118.74    1386    24.4    958.8    76.1
    118.9    1344    24.7    969    76.1
    119.06    1365    25    979.2    76.1
    119.24    1365    25.3    979.2    76.1
    119.41    1386    25.8    989.4    76.1
    119.58    1407    26.1    999.6    76.1
    119.77    1428    26.4    1009.8    76.1
    119.94    1449    26.6    1020    76.1
    120.11    1449    26.9    1030.2    76.1
    120.3    1470    26.9    1030.2    76.1
    120.47    1470    27.2    1040.4    76.1
    120.64    1470    27.5    1040.4    76.1
    120.82    1491    27.7    1050.6    76.1
    120.99    1491    27.7    1050.6    76.1
    121.15    1512    27.7    1060.8    76.1
    121.32    1512    28    1060.8    76.1
    121.49    1533    28    1060.8    76.1
    121.65    1533    28    1060.8    76.1
    121.81    1554    28    1060.8    76.1
    121.98    1575    28.3    1071    76.1
    122.12    1575    28.3    1071    76.1
    122.29    1596    28.3    1071    76.1
    122.46    1617    28.3    1071    76.1
    122.62    1617    28.5    1071    75.7
    122.78    1638    28.5    1071    76.1
    122.93    1638    28.8    1081.2    76.1
    123.1    1659    28.8    1081.2    76.1
    123.27    1680    28.8    1081.2    76.1
    123.43    1680    29.1    1091.4    75.7
    123.6    1701    29.1    1091.4    76.1
    123.78    1701    29.1    1091.4    76.1
    123.93    1701    29.4    1091.4    75.7
    124.1    1722    29.4    1091.4    76.1
    124.28    1743    29.6    1101.6    76.1
    124.44    1764    29.9    1101.6    76.1
    124.62    1659    0    1101.6    69.7
    124.8    1722    0    1091.4    70.9
    124.97    1869    28.8    1050.6    76.1
    125.15    1995    28.5    1050.6    75.7
    125.33    2226    29.1    1050.6    75.3
    125.5    2520    29.6    1060.8    73.3
    125.68    2583    30.5    1091.4    70.9
    125.86    2625    32.4    1142.4    71.7
    126.03    2646    33.8    1193.4    71.3
    126.21    2688    35.7    1254.6    70.9
    126.39    2751    37.1    1295.4    70.5
    126.53    2793    38.2    1346.4    70.5
    126.7    2835    39.8    1397.4    70.1
    126.88    2877    41.5    1458.6    69.7
    127.04    2940    43.4    1509.6    67.7
    127.2    2982    45    1581    64.9
    127.36    3045    46.4    1642.2    60.6
    127.54    3108    48    1723.8    57.4
    127.72    3171    50.2    1815.6    53.4
    127.89    3255    52.4    1907.4    49.8
    128.08    3339    56    2009.4    45.4
    128.25    3402    57.9    2111.4    42.6
    128.43    3360    23.9    2193    4.8
    128.6    3150    24.2    2101.2    12.8
    128.75    2667    28.5    1927.8    15.9
    128.91    2499    31.6    1734    12.4
    129.08    2457    31.8    1611.6    9.2
    129.26    2415    29.4    1540.2    8
    129.42    2352    25    1489.2    7.6
    129.58    2016    23.6    1428    7.2
    129.74    1827    20.3    1356.6    4.8
    129.9    1806    5.8    1305.6    5.2
    130.07    1806    0    1234.2    70.9
    130.23    1785    0    1173    70.9
    130.38    1743    0    1122    70.9
    130.55    1722    0    1081.2    70.9
    130.71    1722    0    1060.8    70.9
    130.87    1911    26.4    1040.4    76.1
    131.03    1806    26.4    1020    73.7
    131.19    1701    26.4    1030.2    73.7
    131.36    1575    27.2    1040.4    75.7
    131.53    1533    27.7    1040.4    76.1
    131.7    1512    27.7    1050.6    76.1
    131.85    1491    28    1060.8    76.1
    132.03    1512    28    1060.8    76.1
    132.21    1512    28.3    1060.8    76.1
    132.37    1512    28.3    1071    76.1
    132.53    1512    28.5    1071    76.1
    132.69    1533    28.5    1071    76.1
    132.88    1533    28.5    1071    76.1
    133.03    1554    28.5    1071    76.1
    133.19    1554    28.5    1071    76.1
    133.34    1554    28.5    1081.2    76.1
    133.53    1554    28.8    1081.2    76.1
    133.7    1554    28.5    1081.2    76.1
    133.85    1533    0    1081.2    70.9
    134.03    1491    0    1071    70.9
    134.18    1533    0    1060.8    70.9
    134.33    1533    0    1040.4    70.9
    134.48    1533    0    1020    70.9
    134.67    1680    25.5    1009.8    76.1
    134.84    1575    26.1    999.6    75.3
    135    1533    26.6    1009.8    76.1
    135.18    1554    26.9    1030.2    76.1
    135.36    1533    27.5    1040.4    76.1
    135.53    1554    27.7    1050.6    76.1
    135.7    1554    27.7    1050.6    76.1
    135.88    1554    28    1060.8    76.1
    136.05    1575    28.3    1060.8    76.1
    136.24    1470    0    1071    69.7
    136.4    1512    0    1060.8    70.9
    136.58    1533    0    1040.4    70.9
    136.77    1533    0    1030.2    70.9
    136.94    1512    0    1009.8    70.9
    137.11    1512    0    1009.8    70.9
    137.31    1470    0    999.6    70.9
    137.45    1449    0    999.6    70.9
    137.61    1449    0    989.4    70.9
    137.77    1428    0    989.4    70.9
    137.95    1407    0    989.4    70.9
    138.1    1407    0    979.2    70.9
    138.26    1407    25.8    979.2    76.1
    138.42    1554    24.7    969    76.1
    138.58    1428    25    969    76.1
    138.74    1428    25.3    979.2    76.1
    138.9    1428    25.8    999.6    76.1
    139.05    1428    26.1    999.6    76.1
    139.23    1428    26.6    1009.8    76.1
    139.39    1449    26.9    1020    76.1
    139.53    1449    26.9    1030.2    76.1
    139.69    1449    27.2    1040.4    76.1
    139.87    1449    27.5    1040.4    76.1
    140.03    1449    27.5    1040.4    76.1
    140.18    1470    27.7    1050.6    76.1
    140.33    1470    27.7    1050.6    76.1
    140.5    1449    28    1060.8    76.1
    140.66    1470    28    1060.8    76.1
    140.82    1470    28    1060.8    76.1
    140.98    1533    28    1060.8    76.1
    141.15    1638    28.3    1060.8    76.1
    141.3    1743    28.5    1071    76.1
    141.46    1785    29.1    1071    74.5
    141.65    1785    29.4    1081.2    75.7
    141.81    1785    29.6    1091.4    76.1
    141.96    1785    29.9    1101.6    75.7
    142.12    1806    30.2    1101.6    75.7
    142.28    1806    30.5    1111.8    76.1
    142.45    1827    0    1122    4.8
    142.61    1785    0    1122    70.9
    142.8    1806    0    1081.2    70.9
    142.97    1785    0    1050.6    70.9
    143.14    1764    0    1030.2    70.9
    143.3    1722    0    1020    70.9
    143.46    1680    0    1009.8    70.9
    143.61    1638    0    1009.8    70.9
    143.77    1596    0    999.6    70.9
    143.94    1554    0    999.6    70.9
    144.11    1491    0    999.6    70.9
    144.28    1386    0    999.6    70.9
    144.46    1239    0    999.6    70.9
    144.63    1176    0    999.6    70.9
    144.8    1113    0    999.6    71.7
    144.99    1050    0    999.6    73.7
    145.15    1008    0.5    999.6    75.3
    145.32    966    1.1    989.4    76.1
    145.51    924    0.8    989.4    76.1
    145.68    903    0.8    989.4    76.1
    145.86    882    0.8    989.4    76.1
    146.05    840    1.1    989.4    76.1
    146.21    840    7.4    989.4    76.1
    146.37    819    7.7    989.4    76.1
    146.56    903    4.1    989.4    76.1
    146.73    966    1.1    989.4    76.1
    146.9    966    0    989.4    76.1
    147.09    945    0    989.4    76.1
    147.26    945    0    989.4    76.1
    147.43    945    0    989.4    76.1
    147.61    945    0    989.4    76.1
    147.78    966    19.2    989.4    77.3
    147.93    1071    24.2    979.2    81.3
    148.13    1260    24.4    969    78.9
    148.29    1638    24.7    958.8    76.1
    148.46    2016    25    948.6    76.1
    148.65    2499    25    948.6    73.7
    148.83    2940    23.6    969    72.5
    149    2961    25.8    1009.8    69.3
    149.16    3066    28.3    1071    67.7
    149.33    3129    30.7    1142.4    66.9
    149.5    3213    32.9    1213.8    66.1
    149.68    3318    35.4    1305.6    66.1
    149.86    3423    38.4    1407.6    61.8
    150.02    3549    41.2    1499.4    56.2
    150.2    3696    43.4    1621.8    50.2
    150.38    3843    46.1    1754.4    43.4
    150.53    3969    49.1    1866.6    39
    150.71    4095    51.9    1958.4    32.3
    150.87    4221    54.6    2019.6    26.3
    151.04    4389    55.2    2050.2    17.9
    151.23    4515    54.9    2050.2    10.8
    151.4    4494    44.7    2040    11.6
    151.57    3171    25.3    2060.4    4.8
    151.76    2919    0    2009.4    53
    151.93    2961    0    1693.2    52.2
    152.09    2940    0    1458.6    52.6
    152.26    2898    0    1295.4    53.4
    152.42    2835    0    1203.6    54.6
    152.58    2772    0    1142.4    55.4
    152.73    2709    0    1101.6    57
    152.91    2646    0    1071    57.8
    153.07    2583    0    1050.6    59
    153.23    2415    0    1040.4    63.8
    153.38    2226    0    1040.4    70.9
    153.56    2100    0    1030.2    70.9
    153.72    1974    0    1030.2    70.9
    153.88    1848    0    1020    70.9
    154.06    1743    0    1020    70.9
    154.22    1680    0    1009.8    70.9
    154.39    1638    0    1009.8    70.9
    154.54    1575    0    999.6    70.9
    154.74    1575    0    999.6    70.9
    154.9    1554    0    989.4    70.9
    155.07    1533    26.1    989.4    76.1
    155.26    1680    25.3    979.2    74.1
    155.43    1995    26.1    989.4    76.1
    155.6    2310    26.6    989.4    74.9
    155.79    2604    26.9    1009.8    73.3
    155.96    2856    27.7    1040.4    71.3
    156.11    3045    29.1    1091.4    67.7
    156.28    3297    30.7    1152.6    65.7
    156.44    3591    32.1    1224    65.3
    156.59    3801    34    1315.8    63.4
    156.75    3843    37.3    1438.2    55
    156.92    3969    41.5    1570.8    43
    157.08    4053    44.5    1713.6    39
    157.23    4200    47.2    1836    28.7
    157.39    4263    50.5    1927.8    24.3
    157.57    3927    42.8    1989    48.6
    157.75    2919    57.9    2019.6    53.8
    157.91    2940    58.7    2029.8    48.6
    158.08    2982    59.8    2091    47
    158.23    2688    56.5    2142    54.2
    158.39    2121    59.8    2111.4    67.7
    158.55    2184    59.6    1978.8    71.7
    158.73    2163    56    1876.8    74.1
    158.89    1743    52.7    1805.4    58.2
    159.05    1680    48.9    1693.2    76.1
    159.23    1701    45    1570.8    76.1
    159.4    1701    42    1489.2    76.1
    159.57    1533    37.6    1417.8    74.1
    159.76    1428    36.5    1346.4    76.1
    159.93    1428    34.6    1295.4    76.1
    160.1    1428    33.2    1244.4    76.1
    160.27    1449    32.1    1213.8    76.1
    160.43    1449    31.6    1183.2    76.1
    160.6    1449    31    1162.8    76.1
    160.76    1449    30.5    1152.6    76.1
    160.95    1470    30.2    1132.2    76.1
    161.12    1470    29.6    1122    76.1
    161.29    1365    0    1111.8    70.1
    161.48    1449    0    1091.4    70.9
    161.65    1428    0    1060.8    70.9
    161.82    1386    0    1040.4    70.9
    162.01    1344    0    1030.2    70.9
    162.17    1302    0    1020    70.9
    162.33    1260    0    1020    70.9
    162.48    1218    0    1009.8    70.9
    162.66    1176    0    1009.8    70.9
    162.81    1134    0    999.6    71.3
    162.97    1092    0    999.6    72.9
    163.13    1050    0    999.6    74.1
    163.3    987    0.8    999.6    75.7
    163.46    966    0.8    999.6    76.1
    163.62    924    1.1    999.6    76.1
    163.81    882    1.1    989.4    76.1
    163.97    882    0.8    989.4    76.1
    164.13    861    0.5    989.4    76.1
    164.31    840    6.6    989.4    76.1
    164.48    840    7.1    989.4    76.1
    164.64    903    3.8    989.4    76.1
    164.83    945    1.1    989.4    76.1
    164.99    945    0.5    989.4    76.1
    165.15    945    0.5    989.4    76.1
    165.34    924    0.8    989.4    76.1
    165.51    903    1.1    989.4    76.1
    165.65    924    0    989.4    76.1
    165.81    924    6.6    989.4    76.1
    165.99    924    0    989.4    76.1
    166.14    987    20.3    989.4    81.3
    166.3    1281    24.4    979.2    78.5
    166.45    1218    24.2    958.8    80.5
    166.63    1239    24.7    969    78.9
    166.78    1260    24.7    979.2    78.1
    166.94    1260    22.8    979.2    78.1
    167.09    1239    15.9    989.4    78.9
    167.27    1218    6.6    989.4    69.7
    167.42    1239    6.3    999.6    69.7
    167.57    1239    5.2    999.6    69.7
    167.72    1260    5.5    999.6    69.7
    167.89    1239    5.5    999.6    69.7
    168.04    1239    7.7    989.4    69.7
    168.2    1239    9.1    989.4    69.7
    168.36    1365    24.7    989.4    76.1
    168.53    1344    25.3    969    76.1
    168.69    1239    25.8    979.2    78.5
    168.84    1239    8    999.6    78.5
    169    1176    0    999.6    70.5
    169.18    1260    0    1009.8    70.9
    169.35    1218    0    999.6    70.9
    169.5    1218    0    999.6    70.9
    169.68    1218    0    989.4    70.9
    169.83    1197    0    989.4    70.9
    169.99    1176    0    989.4    70.9
    170.15    1176    0    989.4    70.9
    170.34    1155    0    989.4    70.9
    170.5    1155    0    989.4    70.9
    170.66    1134    11.8    989.4    70.9
    170.81    1197    24.2    979.2    80.1
    170.99    1260    24.4    969    77.3
    171.14    1281    24.7    969    77.7
    171.3    1533    25    969    76.1
    171.45    1701    25.3    969    76.1
    171.63    1722    25.8    989.4    76.1
    171.78    1743    26.6    999.6    76.1
    171.94    1785    27.2    1020    75.7
    172.1    1806    27.7    1040.4    75.7
    172.27    1722    26.6    1050.6    72.5
    172.43    1302    27.7    1071    76.1
    172.6    1281    28.3    1071    76.5
    172.77    1302    28.3    1071    76.1
    172.93    1323    28    1060.8    76.1
    173.1    1323    28    1060.8    76.1
    173.27    1344    28    1060.8    76.1
    173.43    1344    27.7    1060.8    76.1
    173.6    1365    27.7    1060.8    76.1
    173.78    1365    27.7    1060.8    76.1
    173.95    1386    27.7    1060.8    76.1
    174.12    1386    28    1060.8    76.1
    174.32    1407    28    1060.8    76.1
    174.47    1407    28    1060.8    76.1
    174.62    1428    28    1060.8    76.1
    174.78    1428    28.3    1060.8    76.1
    174.97    1449    28.3    1071    76.1
    175.14    1449    28.3    1071    76.1
    175.32    1470    28.3    1071    76.1
    175.48    1491    28.3    1071    76.1
    175.64    1491    28.5    1071    76.1
    175.79    1512    2.5    1071    4.8
    175.95    1470    0    1081.2    70.9
    176.12    1491    0    1060.8    70.9
    176.28    1470    0    1040.4    70.9
    176.44    1449    0    1030.2    70.9
    176.6    1407    0    1020    70.9
    176.77    1386    0    1009.8    70.9
    176.92    1344    0    1009.8    70.9
    177.08    1323    0    999.6    70.9
    177.24    1281    0    999.6    70.9
    177.41    1260    0    999.6    70.9
    177.58    1260    0    999.6    70.9
    177.74    1260    0    989.4    70.9
    177.9    1239    0    989.4    70.9
    178.09    1218    0    989.4    70.9
    178.26    1218    0    989.4    70.9
    178.43    1218    0    989.4    70.9
    178.6    1197    0    989.4    70.9
    178.76    1197    0    979.2    70.9
    178.93    1197    4.9    979.2    70.1
    179.11    1197    8    979.2    69.7
    179.27    1197    8.5    979.2    69.7
    179.43    1197    8.5    979.2    69.7
    179.59    1176    8.8    979.2    69.7
    179.78    1176    11    979.2    70.9
    179.94    1176    12.4    979.2    72.5
    180.1    1197    14    979.2    75.7
    180.28    1218    15.4    979.2    80.5
    180.45    1176    15.4    979.2    80.1
    180.62    1176    18.1    979.2    80.5
    180.81    1197    19.2    969    80.9
    180.98    1155    1.4    979.2    69.7
    181.15    1134    0    989.4    71.7
    181.34    1155    0    989.4    70.9
    181.51    1155    0    989.4    70.9
    181.68    1155    0    989.4    70.9
    181.86    1155    12.4    989.4    70.1
    182.03    1197    24.4    979.2    80.1
    182.2    1218    24.4    969    79.7
    182.37    1155    25    979.2    80.9
    182.54    1155    25.3    979.2    80.5
    182.72    1176    25.5    989.4    80.1
    182.89    1197    25.8    989.4    80.1
    183.05    1197    25.8    999.6    79.7
    183.2    1218    25.8    999.6    80.9
    183.36    1218    26.1    999.6    80.5
    183.54    1239    26.1    1009.8    79.7
    183.71    1239    26.4    1009.8    78.5
    183.86    1260    26.4    1009.8    78.1
    184.04    1260    26.6    1020    77.7
    184.19    1218    7.4    1020    76.5
    184.35    1197    7.1    1030.2    69.7
    184.5    1281    8.2    1020    69.7
    184.68    1260    6    1009.8    69.7
    184.83    1218    6.6    1009.8    69.7
    184.99    1239    7.4    1009.8    69.7
    185.14    1281    25    999.6    78.1
    185.33    1323    25.3    979.2    76.1
    185.48    1260    25.5    979.2    77.3
    185.64    1260    25.5    999.6    78.5
    185.8    1260    26.1    999.6    77.7
    185.97    1281    26.1    1009.8    77.3
    186.13    1281    26.4    1009.8    76.5
    186.28    1302    26.4    1020    76.1
    186.44    1323    26.6    1020    76.1
    186.62    1323    26.9    1020    76.1
    186.79    1344    26.9    1030.2    76.1
    186.95    1365    27.2    1030.2    76.1
    187.14    1365    27.2    1040.4    76.1
    187.31    1365    27.2    1040.4    76.1
    187.48    1386    27.5    1050.6    76.1
    187.67    1407    27.7    1050.6    76.1
    187.84    1407    27.7    1050.6    76.1
    188.01    1407    27.7    1060.8    76.1
    188.2    1428    27.7    1060.8    76.1
    188.37    1449    28    1060.8    76.1
    188.54    1449    28    1060.8    76.1
    188.73    1470    28.3    1071    76.1
    188.9    1470    28.3    1071    76.1
    189.07    1491    28.3    1071    76.1
    189.25    1512    28.3    1071    76.1
    189.42    1512    28.5    1071    76.1
    189.59    1533    28.5    1071    76.1
    189.78    1554    28.8    1081.2    76.1
    189.95    1554    28.8    1081.2    76.1
    190.12    1554    28.8    1081.2    76.1
    190.31    1407    28    1091.4    76.1
    190.48    1197    28.8    1091.4    80.9
    190.65    1176    28.8    1091.4    80.1
    190.85    1197    28.5    1071    80.1
    191.01    1197    28.3    1071    80.1
    191.18    1197    28    1060.8    80.5
    191.36    1218    27.7    1050.6    80.5
    191.53    1218    27.7    1050.6    80.1
    191.7    1239    27.5    1050.6    79.7
    191.89    1239    27.5    1040.4    79.3
    192.06    1239    27.5    1040.4    79.3
    192.23    1239    27.5    1040.4    79.3
    192.41    1239    27.5    1040.4    78.9
    192.56    1260    27.5    1040.4    78.5
    192.72    1260    27.5    1040.4    78.5
    192.87    1260    27.5    1040.4    78.1
    193.06    1260    27.5    1040.4    78.1
    193.22    1281    27.5    1040.4    77.3
    193.38    1281    27.5    1040.4    77.3
    193.53    1281    27.5    1040.4    76.9
    193.71    1281    27.5    1040.4    76.9
    193.87    1281    27.5    1040.4    76.9
    194.04    1281    27.5    1040.4    76.5
    194.23    1302    27.5    1050.6    76.1
    194.4    1302    27.5    1050.6    76.1
    194.55    1302    27.5    1050.6    76.1
    194.71    1302    27.7    1050.6    76.1
    194.88    1323    27.7    1050.6    76.1
    195.04    1323    27.7    1050.6    76.1
    195.2    1323    27.7    1050.6    76.1
    195.39    1323    27.7    1050.6    76.1
    195.56    1344    27.7    1050.6    76.1
    195.73    1344    27.7    1060.8    76.1
    195.93    1365    27.7    1060.8    76.1
    196.09    1365    27.7    1060.8    76.1
    196.26    1365    28    1060.8    76.1
    196.45    1365    28    1060.8    76.1
    196.62    1365    28    1060.8    76.1
    196.79    1386    28    1060.8    76.1
    196.97    1386    28    1060.8    76.1
    197.14    1386    28.3    1071    76.1
    197.31    1386    28.3    1071    76.1
    197.5    1407    28.3    1071    76.1
    197.67    1407    28.3    1071    76.1
    197.84    1407    28.3    1071    76.1
    198.03    1407    28.3    1071    76.1
    198.2    1428    28.3    1071    76.1
    198.37    1428    28.5    1071    76.1
    198.56    1428    28.5    1071    76.1
    198.73    1428    28.5    1071    76.1
    198.9    1449    28.5    1081.2    76.1
    199.08    1449    28.5    1081.2    76.1
    199.23    1470    28.5    1081.2    76.1
    199.39    1470    28.5    1081.2    76.1
    199.55    1470    28.8    1081.2    76.1
    199.72    1470    28.8    1081.2    76.1
    199.88    1470    28.8    1081.2    76.1
    200.03    1470    28.8    1081.2    76.1
    200.19    1491    28.8    1081.2    76.1
    200.36    1491    28.8    1081.2    76.1
    200.52    1491    28.8    1081.2    76.1
    200.67    1512    28.8    1081.2    76.1
    200.83    1617    28.8    1081.2    76.1
    201.01    1869    29.9    1081.2    76.1
    201.16    2058    30.2    1081.2    75.7
    201.32    2226    30.7    1091.4    74.9
    201.48    2457    31.3    1101.6    73.3
    201.67    2688    31.8    1132.2    72.1
    201.84    2877    32.7    1183.2    70.9
    202.01    2940    34.3    1234.2    69.3
    202.19    3003    37.1    1326    67.7
    202.34    3045    39.3    1397.4    67.3
    202.5    3087    41.7    1479    64.9
    202.66    3129    44.2    1570.8    61
    202.83    3192    46.4    1672.8    55.8
    202.98    3234    48.3    1764.6    52.6
    203.14    3318    51.1    1856.4    48.6
    203.3    3402    54.4    1968.6    44.6
    203.47    3444    57.6    2091    40.6
    203.63    3507    57.9    2203.2    38.6
    203.79    3549    57.4    2274.6    36.3
    203.94    2688    56.5    2305.2    57.8
    204.12    2520    59.6    2254.2    57
    204.29    2541    59.8    2203.2    57.4
    204.44    2478    56.8    2182.8    59.8
    204.6    1911    60.7    2121.6    64.9
    204.77    1953    59.3    1948.2    76.1
    204.93    1953    55.7    1825.8    76.1
    205.09    1953    51.3    1734    76.1
    205.28    1638    47.2    1642.2    73.3
    205.45    1638    44.5    1550.4    76.1
    205.62    1659    41.5    1468.8    76.1
    205.81    1659    39    1397.4    76.1
    205.98    1659    37.3    1346.4    76.1
    206.15    1680    36    1305.6    76.1
    206.34    1659    34.9    1275    76.1
    206.5    1680    34    1244.4    76.1
    206.66    1680    33.5    1224    76.1
    206.83    1680    32.9    1203.6    76.1
    206.98    1680    32.4    1193.4    76.1
    207.14    1701    32.1    1183.2    76.1
    207.3    1701    31.8    1173    76.1
    207.47    1701    31.6    1162.8    75.7
    207.63    1701    31.6    1162.8    76.1
    207.8    1701    31.3    1152.6    76.1
    207.98    1701    31.3    1152.6    76.1
    208.15    1701    31.3    1152.6    75.7
    208.31    1701    31    1142.4    76.1
    208.5    1722    31    1142.4    76.1
    208.66    1722    31    1142.4    75.7
    208.81    1722    31    1142.4    75.7
    208.97    1722    31    1142.4    76.1
    209.15    1722    31    1142.4    76.1
    209.3    1722    18.9    1142.4    4.8
    209.46    1638    0    1142.4    70.1
    209.61    1701    0    1122    70.9
    209.79    1680    0    1081.2    70.9
    209.94    1680    0    1060.8    70.9
    210.1    1638    0    1040.4    70.9
    210.26    1617    0    1030.2    70.9
    210.43    1575    0    1020    70.9
    210.59    1554    0    1009.8    70.9
    210.76    1512    0    1009.8    70.9
    210.93    1491    0    1009.8    70.9
    211.09    1470    0    999.6    70.9
    211.26    1428    0    999.6    70.9
    211.44    1407    0    989.4    70.9
    211.6    1386    0    989.4    70.9
    211.76    1365    0    989.4    70.9
    211.93    1344    0    989.4    70.9
    212.09    1323    0    989.4    70.9
    212.26    1323    0    989.4    70.9
    212.45    1281    0    979.2    70.9
    212.62    1260    0    969    70.9
    212.8    1239    0    969    70.9
    212.97    1218    0    969    70.9
    213.13    1218    0    979.2    70.9
    213.3    1197    0    979.2    70.9
    213.45    1176    0    979.2    70.9
    213.63    1176    0    979.2    70.9
    213.79    1155    0    989.4    70.9
    213.95    1155    0    989.4    70.9
    214.14    1134    0    989.4    71.3
    214.31    1113    0    989.4    71.7
    214.47    1113    0    989.4    72.1
    214.63    1113    0    989.4    72.5
    214.8    1092    0    989.4    72.5
    214.96    1092    0    989.4    72.5
    215.11    1134    24.7    979.2    81.3
    215.29    1218    24.7    969    80.1
    215.44    1092    24.7    969    81.3
    215.6    1113    25.3    979.2    81.3
    215.75    1113    25.5    989.4    81.3
    215.93    1113    25.8    999.6    81.3
    216.08    1113    26.1    999.6    81.3
    216.24    1113    26.1    999.6    81.3
    216.39    1113    26.1    999.6    81.3
    216.57    1134    26.4    1009.8    81.3
    216.73    1134    26.4    1009.8    81.3
    216.9    1134    26.4    1009.8    81.3
    217.08    1134    26.6    1020    81.3
    217.25    1134    26.6    1020    81.3
    217.42    1134    26.6    1020    81.3
    217.61    1134    26.6    1020    81.3
    217.78    1134    26.6    1020    81.3
    217.95    1155    0    1020    80.9
    218.13    1071    0    1030.2    73.3
    218.28    1134    0    1020    71.7
    218.44    1113    0    1020    72.5
    218.59    1092    0    1009.8    72.5
    218.77    1071    0    1009.8    73.3
    218.94    1050    0    999.6    74.1
    219.11    1008    0.5    999.6    75.3
    219.29    987    0.5    999.6    76.1
    219.47    945    0.8    999.6    76.1
    219.64    903    1.1    989.4    76.1
    219.83    861    1.1    989.4    76.1
    219.98    819    7.7    989.4    76.1
    220.15    819    8.8    989.4    76.1
    220.31    819    8.8    989.4    76.1
    220.5    819    8.8    989.4    76.1
    220.67    819    9.3    989.4    76.1
    220.83    819    9.6    989.4    76.1
    221    819    9.6    989.4    76.1
    221.16    819    9.6    989.4    76.1
    221.32    819    9.3    989.4    76.1
    221.48    840    9.3    989.4    76.1
    221.66    819    9.3    989.4    76.1
    221.82    819    10.2    989.4    76.1
    221.98    819    10.4    989.4    76.1
    222.17    819    10.4    989.4    76.5
    222.34    840    9.9    989.4    76.1
    222.51    840    10.4    989.4    76.1
    222.68    819    10.7    989.4    76.1
    222.84    840    10.4    989.4    76.1
    223.01    840    10.4    989.4    76.5
    223.16    840    10.4    989.4    76.5
    223.36    945    24.4    989.4    81.3
    223.53    1260    24.7    969    78.5
    223.7    1428    24.4    958.8    76.1
    223.89    1575    25    958.8    76.1
    224.06    1617    25.5    969    75.7
    224.23    1596    26.1    989.4    76.1
    224.42    1596    26.6    1009.8    76.1
    224.59    1617    26.1    1030.2    76.1
    224.76    1575    12.1    1040.4    76.1
    224.94    1428    12.1    1050.6    70.9
    225.11    1428    11.8    1050.6    70.5
    225.27    1470    11.5    1040.4    69.7
    225.44    1512    11.5    1040.4    69.3
    225.6    1533    11.3    1030.2    69.3
    225.75    1512    11.3    1030.2    69.3
    225.91    1491    11.5    1020    69.3
    226.08    1470    11.5    1020    69.7
    226.24    1491    11.5    1009.8    69.7
    226.39    1512    12.1    1009.8    69.3
    226.55    1512    12.1    1009.8    69.3
    226.73    1533    12.4    1009.8    69.3
    226.88    1533    14.5    999.6    76.1
    227.04    1617    18.7    999.6    76.1
    227.19    1659    18.4    999.6    76.1
    227.37    1659    18.7    999.6    76.1
    227.52    1659    18.7    999.6    76.1
    227.68    1680    18.4    999.6    76.1
    227.83    1722    18.4    999.6    76.1
    228.01    1764    18.1    1009.8    76.1
    228.17    1785    17.8    1009.8    75.7
    228.34    1827    17.8    1020    75.7
    228.51    1869    17.6    1030.2    75.3
    228.67    1890    17.3    1030.2    75.7
    228.84    1932    17    1040.4    75.7
    229.03    1974    17    1050.6    75.7
    229.2    1995    16.7    1050.6    75.7
    229.37    2037    18.7    1050.6    76.1
    229.54    2079    18.4    1060.8    75.7
    229.72    2121    18.4    1060.8    74.9
    229.89    2163    18.1    1060.8    75.3
    230.08    2205    18.1    1071    75.3
    230.25    2226    17.8    1071    74.5
    230.42    2247    17.8    1081.2    74.1
    230.61    2289    17.6    1081.2    71.7
    230.78    2331    17.3    1091.4    71.7
    230.95    2352    22    1091.4    74.5
    231.14    2499    31    1091.4    74.1
    231.31    2583    31.3    1101.6    72.1
    231.48    2583    32.7    1142.4    70.9
    231.66    2688    34    1203.6    71.3
    231.83    2772    35.7    1254.6    70.9
    232    2877    37.1    1315.8    70.1
    232.19    3024    39.3    1387.2    68.9
    232.36    3129    41.2    1458.6    65.7
    232.52    3255    43.1    1540.2    60.2
    232.69    3402    1.1    1652.4    4.8
    232.85    3297    0    1734    48.6
    233    3297    0    1672.8    48.2
    233.16    3297    0    1499.4    48.6
    233.32    3192    0    1336.2    49.4
    233.49    3066    0    1234.2    50.6
    233.65    2919    0    1173    53
    233.81    2646    0    1132.2    57.8
    233.99    2205    0    1111.8    70.9
    234.15    1974    0    1101.6    70.9
    234.31    1785    0    1081.2    70.9
    234.49    1680    0    1060.8    70.9
    234.66    1554    0    1040.4    70.9
    234.82    1512    0    1030.2    70.9
    234.98    1491    0    1020    70.9
    235.15    1470    0    1009.8    70.9
    235.31    1449    0    999.6    70.9
    235.48    1428    0    999.6    70.9
    235.66    1407    0    989.4    70.9
    235.83    1386    0    989.4    70.9
    236    1386    0    989.4    70.9
    236.17    1407    23.6    979.2    76.1
    236.35    1491    22.5    979.2    76.1
    236.51    1470    25.5    989.4    76.1
    236.69    1407    26.1    999.6    76.1
    236.86    1449    26.4    1009.8    76.1
    237.03    1470    26.6    1020    76.1
    237.23    1512    27.2    1030.2    76.1
    237.41    1533    27.5    1040.4    76.1
    237.58    1533    16.5    1050.6    76.1
    237.77    1554    16.2    1050.6    76.1
    237.94    1575    15.9    1050.6    76.1
    238.11    1575    15.9    1040.4    76.1
    238.29    1596    15.9    1040.4    76.1
    238.47    1617    15.9    1040.4    76.1
    238.64    1638    15.9    1040.4    76.1
    238.83    1659    26.9    1040.4    76.1
    239    1764    27.7    1030.2    76.1
    239.16    1785    23.9    1040.4    75.7
    239.33    1596    0    1050.6    70.1
    239.49    1596    0    1060.8    70.9
    239.64    1659    0    1050.6    70.9
    239.8    1638    0    1030.2    70.9
    239.98    1617    3.6    1020    70.5
    240.13    1617    7.7    1020    68.5
    240.28    1617    8    1009.8    68.5
    240.44    1596    7.7    1009.8    68.9
    240.61    1596    7.7    1009.8    68.9
    240.76    1575    9.1    999.6    68.9
    240.92    1596    10.4    999.6    68.9
    241.08    1575    11.3    999.6    68.9
    241.25    1575    11.3    999.6    68.9
    241.4    1575    11.5    999.6    68.9
    241.56    1575    12.4    999.6    68.9
    241.71    1596    12.4    999.6    68.9
    241.89    1596    12.4    999.6    68.5
    242.05    1596    12.4    999.6    68.5
    242.2    1617    15.9    999.6    76.1
    242.37    1701    26.4    989.4    76.1
    242.55    1680    26.1    979.2    75.7
    242.71    1659    26.4    999.6    75.7
    242.87    1680    26.9    1020    76.1
    243.05    1701    27.5    1030.2    76.1
    243.22    1743    28    1050.6    76.1
    243.39    1764    28.5    1060.8    76.1
    243.56    1806    29.1    1071    76.1
    243.72    1827    29.6    1081.2    75.7
    243.88    1869    30.2    1091.4    76.1
    244.04    1869    30.7    1111.8    76.1
    244.21    1911    31    1122    76.1
    244.37    1953    31.6    1132.2    76.1
    244.52    1974    31.8    1132.2    75.7
    244.68    1995    32.1    1142.4    75.7
    244.85    2037    32.7    1152.6    75.7
    245.01    2058    33.2    1162.8    75.3
    245.17    2100    33.5    1173    75.3
    245.34    2142    34    1183.2    74.9
    245.51    2163    34.3    1193.4    74.9
    245.67    2205    34.9    1213.8    74.1
    245.84    2205    35.4    1224    74.1
    246.01    1743    33.8    1244.4    68.5
    246.17    1575    33.2    1234.2    76.1
    246.34    1596    32.7    1213.8    76.1
    246.51    1596    32.1    1193.4    76.1
    246.67    1344    30.2    1173    76.1
    246.84    1218    31    1162.8    80.1
    247.01    1218    30.5    1132.2    79.7
    247.17    1239    29.9    1122    79.7
    247.34    1239    29.4    1101.6    78.9
    247.52    1239    28.8    1091.4    78.9
    247.69    1260    28.8    1081.2    78.1
    247.86    1260    28.5    1071    78.1
    248.06    1281    28.3    1071    77.3
    248.23    1281    28.3    1060.8    76.9
    248.39    1281    28    1060.8    77.3
    248.58    1281    28    1060.8    76.5
    248.75    1281    28    1060.8    76.5
    248.92    1302    28    1060.8    76.1
    249.11    1302    28    1060.8    76.1
    249.28    1323    28    1060.8    76.1
    249.45    1323    28    1060.8    76.1
    249.63    1323    28    1060.8    76.1
    249.8    1323    28    1060.8    76.1
    249.96    1344    28    1060.8    76.1
    250.12    1344    28    1060.8    76.1
    250.29    1344    28.3    1060.8    76.1
    250.44    1344    28.3    1060.8    76.1
    250.6    1344    28.3    1060.8    76.1
    250.77    1365    28.3    1060.8    76.1
    250.93    1365    28.3    1060.8    76.1
    251.08    1386    28.3    1071    76.1
    251.25    1386    28.3    1071    76.1
    251.43    1386    28.5    1071    76.1
    251.58    1386    28.5    1071    76.1
    251.74    1386    28.5    1071    76.1
    251.89    1386    28.5    1071    76.1
    252.07    1407    28.5    1071    76.1
    252.22    1407    28.5    1071    76.1
    252.38    1428    28.5    1071    76.1
    252.54    1596    28.5    1071    76.1
    252.71    1827    29.4    1071    76.1
    252.86    1932    29.9    1071    76.1
    253.01    1911    30.2    1091.4    73.7
    253.18    1911    30.7    1111.8    76.1
    253.36    1932    31.3    1122    76.1
    253.52    1953    31.8    1132.2    75.7
    253.68    1953    32.1    1142.4    76.1
    253.86    1974    32.7    1152.6    76.1
    254.03    1995    32.9    1162.8    75.7
    254.2    2016    33.2    1173    75.7
    254.37    2037    33.5    1183.2    75.7
    254.53    2058    33.8    1193.4    75.7
    254.7    2079    34    1193.4    75.3
    254.86    2079    34.6    1203.6    74.9
    255.04    2100    34.9    1213.8    74.9
    255.21    2121    35.1    1224    75.3
    255.37    2121    35.4    1234.2    74.9
    255.52    2142    35.7    1244.4    74.9
    255.7    2163    36    1244.4    75.3
    255.85    2184    36.2    1264.8    74.5
    256.01    2205    36.8    1275    74.9
    256.17    2205    37.3    1285.2    74.5
    256.36    2331    37.9    1295.4    74.1
    256.53    2667    37.6    1305.6    73.3
    256.7    3024    37.3    1326    69.7
    256.87    3255    38.4    1387.2    68.5
    257.03    3297    41.2    1489.2    61
    257.2    3360    44.7    1611.6    53.4
    257.39    3444    48    1774.8    46.6
    257.56    3528    51.6    1897.2    43
    257.73    3612    56.5    2040    38.6
    257.9    3654    57.4    2142    36.3
    258.06    3717    57.1    2213.4    34.3
    258.23    3780    57.1    2254.2    33.1
    258.41    3864    56.8    2274.6    31.9
    258.57    3927    56.5    2264.4    31.5
    258.73    3990    56.5    2254.2    31.1
    258.89    4032    56.3    2233.8    30.3
    259.07    4116    56    2203.2    28.7
    259.23    4179    55.7    2182.8    27.5
    259.39    4221    55.7    2162.4    26.3
    259.58    4263    55.7    2142    26.7
    259.75    3822    49.1    2131.8    51
    259.92    3150    58.5    2162.4    48.6
    260.11    3066    59.3    2223.6    46.6
    260.28    3087    59.6    2274.6    45.4
    260.46    2520    56.8    2315.4    56.2
    260.65    2352    59.8    2223.6    65.7
    260.8    2394    59.6    2152.2    66.9
    260.96    2394    0    2091    4.8
    261.11    1890    0    1989    70.9
    261.28    1953    0    1591.2    70.9
    261.44    1932    0    1428    70.9
    261.6    1890    0    1295.4    70.9
    261.76    1848    0    1213.8    70.9
    261.93    1785    0    1152.6    70.9
    262.09    1764    0    1111.8    70.9
    262.24    1701    0    1081.2    70.9
    262.43    1638    0    1060.8    70.9
    262.59    1596    0    1050.6    70.9
    262.75    1533    0    1030.2    70.9
    262.92    1491    0    1030.2    70.9
    263.11    1428    0    1020    70.9
    263.28    1365    0    1009.8    70.9
    263.45    1323    0    1009.8    70.9
    263.63    1260    0    1009.8    70.9
    263.79    1197    0    999.6    70.9
    263.95    1155    0    999.6    70.9
    264.11    1113    0    999.6    72.1
    264.3    1071    0    999.6    73.7
    264.47    1029    0    999.6    75.3
    264.64    987    0.5    999.6    76.1
    264.83    945    0.8    999.6    76.1
    265    903    0.8    989.4    76.1
    265.17    861    1.1    989.4    76.1
    265.35    861    0.8    989.4    76.1
    265.52    861    6.6    989.4    76.1
    265.69    903    3.3    989.4    76.1
    265.87    945    0.8    989.4    76.1
    266.02    924    1.6    989.4    76.1
    266.18    903    2.5    989.4    76.1
    266.33    882    3    989.4    76.1
    266.51    882    3.3    989.4    76.1
    266.66    861    3.8    989.4    76.1
    266.82    861    6.6    989.4    76.1
    266.98    840    7.4    989.4    76.1
    267.15    819    8.2    989.4    76.1
    267.3    798    9.1    989.4    76.1
    267.46    798    10.2    989.4    76.1
    267.61    798    10.4    989.4    76.1
    267.79    840    8.2    989.4    76.1
    267.94    882    6.9    989.4    76.1
    268.1    882    5.8    989.4    76.1
    268.26    924    24.2    989.4    81.3
    268.43    1134    24.4    969    81.3
    268.59    1281    24.4    958.8    77.7
    268.74    1302    24.7    958.8    76.5
    268.9    1428    25    969    76.1
    269.07    1449    25.3    969    76.1
    269.24    1470    25.5    989.4    76.1
    269.4    1491    26.1    999.6    76.1
    269.55    1533    26.6    1020    76.1
    269.73    1533    26.9    1030.2    76.1
    269.88    1575    27.5    1040.4    75.7
    270.04    1617    27.7    1050.6    76.1
    270.19    1638    28    1060.8    76.1
    270.36    1659    28.5    1071    76.1
    270.52    1659    23.6    1081.2    71.7
    270.69    1659    19.5    1091.4    76.1
    270.88    1659    11    1091.4    68.5
    271.05    1680    10.2    1081.2    68.9
    271.22    1659    10.2    1071    68.9
    271.4    1680    13.7    1050.6    76.1
    271.58    1785    27.2    1040.4    76.1
    271.75    1806    28    1030.2    75.7
    271.94    1785    28    1040.4    74.9
    272.11    1743    28.5    1060.8    76.1
    272.28    1785    29.1    1081.2    76.1
    272.46    1806    29.9    1091.4    76.1
    272.63    1848    30.2    1101.6    76.1
    272.8    1869    30.7    1111.8    76.1
    272.99    1911    31    1122    75.7
    273.16    1932    31.6    1132.2    75.7
    273.33    1974    32.1    1142.4    75.7
    273.52    2016    32.7    1152.6    75.3
    273.69    2058    32.9    1162.8    75.3
    273.86    2100    32.4    1173    4.8
    274.04    2100    24.4    1193.4    5.6
    274.21    2079    3    1193.4    70.9
    274.38    2037    0    1173    70.9
    274.58    1848    0    1122    70.9
    274.75    1722    0    1091.4    70.9
    274.92    1596    0    1071    70.9
    275.09    1491    0    1050.6    70.9
    275.27    1428    0    1040.4    70.9
    275.44    1407    0    1030.2    70.9
    275.62    1386    0    1020    70.9
    275.8    1407    25.8    1009.8    76.1
    275.97    1470    25.3    989.4    76.1
    276.15    1407    25.8    999.6    76.1
    276.33    1407    26.4    1009.8    76.1
    276.5    1428    26.6    1020    76.1
    276.68    1470    27.2    1030.2    76.1
    276.86    1764    27.5    1030.2    76.1
    277.03    2100    28.5    1040.4    75.7
    277.19    2394    29.1    1050.6    74.1
    277.36    2667    29.6    1071    72.9
    277.53    2856    30.5    1111.8    70.5
    277.69    3108    32.1    1162.8    66.5
    277.86    3402    33.2    1234.2    64.9
    278.03    3549    35.4    1336.2    65.3
    278.2    3654    39.8    1468.8    54.2
    278.36    3759    42.5    1601.4    47.8
    278.53    3822    46.4    1744.2    41.8
    278.68    3129    44.7    1876.8    68.5
    278.86    2583    54.9    1887    60.6
    279.03    2646    54.9    1897.2    57.8
    279.18    2667    55.7    1927.8    57
    279.34    2625    54.6    1968.6    61
    279.52    1911    59.6    1958.4    70.9
    279.69    1974    55.7    1836    76.1
    279.86    1953    51.9    1744.2    76.1
    280.05    1491    46.9    1652.4    75.7
    280.22    1512    43.9    1550.4    76.1
    280.39    1533    40.4    1448.4    76.1
    280.58    1554    37.9    1387.2    76.1
    280.75    1554    36.2    1326    76.1
    280.92    1554    35.1    1295.4    76.1
    281.09    1575    4.4    1254.6    4.8
    281.25    1491    0    1224    70.9
    281.41    1575    0    1162.8    70.9
    281.58    1533    0    1122    70.9
    281.77    1512    0    1081.2    70.9
    281.94    1470    0    1060.8    70.9
    282.11    1428    0    1040.4    70.9
    282.3    1407    0    1030.2    70.9
    282.47    1365    0    1020    70.9
    282.64    1323    0    1020    70.9
    282.83    1281    0    1009.8    70.9
    283    1239    0    1009.8    70.9
    283.17    1218    0    999.6    70.9
    283.34    1155    0    999.6    70.9
    283.49    1134    0    999.6    71.3
    283.67    1092    0    999.6    72.9
    283.83    1050    0    999.6    74.1
    284    1008    0.8    999.6    75.3
    284.16    987    0.8    999.6    76.1
    284.34    987    0.5    989.4    76.1
    284.51    987    0    989.4    76.1
    284.67    987    0    989.4    76.1
    284.82    987    0    989.4    76.1
    285.01    987    0    989.4    76.1
    285.19    966    0    989.4    76.1
    285.36    966    0    989.4    76.1
    285.55    1050    0    989.4    74.9
    285.71    1155    0    989.4    71.3
    285.89    1239    0    979.2    70.9
    286.06    1239    0    979.2    70.9
    286.24    1239    0    979.2    70.9
    286.41    1239    0    979.2    70.9
    286.57    1218    0    979.2    70.9
    286.75    1197    0    979.2    70.9
    286.91    1197    0    979.2    70.9
    287.09    1176    0    979.2    70.9
    287.26    1176    0    979.2    70.9
    287.44    1155    0    979.2    70.9
    287.61    1155    24.7    979.2    80.9
    287.77    1344    24.4    969    76.1
    287.93    1218    24.7    958.8    80.1
    288.08    1176    25    969    80.5
    288.25    1197    25.3    979.2    80.1
    288.4    1197    25.5    989.4    79.7
    288.57    1218    25.8    999.6    80.5
    288.72    1218    25.8    999.6    80.1
    288.9    1239    26.1    999.6    79.3
    289.08    1239    26.4    1009.8    78.5
    289.24    1260    26.4    1009.8    78.5
    289.4    1281    26.6    1020    77.7
    289.58    1281    26.6    1020    76.9
    289.75    1302    26.9    1030.2    76.5
    289.94    1302    26.9    1030.2    76.1
    290.11    1323    27.2    1030.2    76.1
    290.26    1323    27.2    1040.4    76.1
    290.43    1323    27.5    1040.4    76.1
    290.59    1344    27.5    1040.4    76.1
    290.76    1344    27.5    1050.6    76.1
    290.91    1365    27.7    1050.6    76.1
    291.1    1386    27.7    1050.6    76.1
    291.25    1386    28    1060.8    76.1
    291.41    1407    28    1060.8    76.1
    291.58    1407    28    1060.8    76.1
    291.74    1428    28.3    1071    76.1
    291.9    1428    28.3    1071    76.1
    292.06    1449    28.3    1071    76.1
    292.23    1470    28.5    1071    76.1
    292.41    1470    28.5    1071    76.1
    292.57    1491    28.5    1081.2    76.1
    292.76    1512    28.8    1081.2    76.1
    292.93    1512    28.8    1081.2    76.1
    293.11    1533    28.8    1091.4    76.1
    293.29    1533    29.1    1091.4    76.1
    293.47    1554    29.1    1091.4    76.1
    293.63    1575    29.1    1091.4    76.1
    293.79    1575    29.4    1101.6    76.1
    293.96    1596    29.4    1101.6    76.1
    294.13    1596    29.4    1101.6    76.1
    294.29    1617    29.6    1111.8    76.1
    294.45    1638    29.6    1111.8    76.1
    294.61    1638    29.9    1111.8    76.1
    294.76    1659    29.9    1111.8    76.1
    294.94    1659    29.9    1122    75.7
    295.09    1680    30.2    1122    76.1
    295.25    1701    30.5    1122    76.1
    295.4    1701    30.5    1132.2    76.1
    295.58    1722    30.7    1132.2    76.1
    295.73    1743    30.7    1132.2    76.1
    295.89    1743    31    1142.4    76.1
    296.05    1764    31    1142.4    76.1
    296.23    1764    31.3    1142.4    76.1
    296.39    1785    31.3    1142.4    76.1
    296.55    1806    31.6    1152.6    76.1
    296.72    1806    31.8    1152.6    75.7
    296.87    1827    31.8    1162.8    76.1
    297.03    1848    32.1    1162.8    76.1
    297.2    1722    0    1162.8    70.9
    297.36    1785    0    1142.4    70.9
    297.52    1911    28.3    1101.6    76.1
    297.67    1911    29.6    1071    76.1
    297.83    1848    29.6    1081.2    74.9
    298    2016    30.5    1091.4    75.7
    298.16    2247    31.3    1101.6    74.5
    298.33    2520    31.8    1111.8    72.9
    298.51    2730    32.4    1142.4    71.3
    298.69    2751    34.3    1213.8    70.1
    298.85    2793    36.2    1275    69.7
    299.02    2835    38.4    1356.6    69.3
    299.18    2877    40.6    1417.8    68.9
    299.36    2919    42.8    1489.2    67.3
    299.51    2982    45    1570.8    63.8
    299.68    3045    46.9    1662.6    59.4
    299.85    3108    48.6    1744.2    55.8
    300.01    3171    50.8    1836    51.8
    300.2    3255    54.1    1948.2    47
    300.36    3360    57.9    2050.2    43.4
    300.52    3402    58.2    2172.6    40.2
    300.69    3486    57.9    2264.4    37.9
    300.86    3549    57.9    2305.2    36.7
    301.02    3633    57.6    2335.8    35.5
    301.19    3696    57.4    2335.8    35.1
    301.36    3759    57.1    2335.8    34.3
    301.52    3780    49.7    2325.6    48.2
    301.69    2772    56.8    2315.4    53.8
    301.88    2730    59.8    2284.8    54.2
    302.04    2751    59.8    2274.6    53.4
    302.22    2562    56.8    2274.6    56.6
    302.4    2121    60.1    2182.8    73.3
    302.57    2121    60.1    2040    75.7
    302.74    2142    57.9    1927.8    75.3
    302.9    2163    55.5    1856.4    75.3
    303.06    2163    53.5    1795.2    75.3
    303.24    2184    51.9    1754.4    75.3
    303.39    2205    50.5    1713.6    75.3
    303.58    2268    49.1    1672.8    74.9
    303.73    2100    48    1652.4    75.3
    303.9    1848    46.4    1601.4    76.1
    304.04    1848    44.7    1540.2    76.1
    304.23    1869    42.3    1489.2    76.1
    304.41    1869    40.6    1438.2    4.8
    304.56    1890    39.5    1407.6    76.1
    304.74    1890    38.7    1377    76.1
    304.89    1911    37.6    1346.4    76.1
    305.04    1911    37.1    1326    76.1
    305.21    1911    36.5    1305.6    76.1
    305.4    1932    36.2    1285.2    76.1
    305.57    1932    36    1285.2    76.1
    305.74    1932    35.7    1275    76.1
    305.92    1953    35.4    1264.8    76.1
    306.09    1953    35.4    1264.8    76.1
    306.26    1953    35.4    1254.6    76.1
    306.45    1974    35.4    1254.6    76.1
    306.62    1974    35.1    1254.6    76.1
    306.78    1974    35.1    1254.6    76.1
    306.96    1974    35.1    1254.6    76.1
    307.12    1974    35.1    1254.6    76.1
    307.26    1995    35.1    1254.6    76.1
    307.42    1995    35.4    1254.6    75.7
    307.6    1869    0    1254.6    70.9
    307.75    1932    0    1224    70.9
    307.91    1953    0    1162.8    70.9
    308.07    1932    0    1111.8    70.9
    308.26    1890    0    1081.2    70.9
    308.44    1848    0    1060.8    70.9
    308.6    1806    0    1040.4    70.9
    308.77    1785    0    1030.2    70.9
    308.94    1743    0    1030.2    70.9
    309.1    1722    0    1020    70.9
    309.28    1680    0    1009.8    70.9
    309.44    1638    0    1009.8    70.9
    309.6    1617    0    1009.8    70.9
    309.76    1575    0    999.6    70.9
    309.95    1554    0    999.6    70.9
    310.12    1533    0    999.6    70.9
    310.29    1491    0    999.6    70.9
    310.47    1470    0    989.4    70.9
    310.64    1449    0    979.2    70.9
    310.79    1449    0    969    70.9
    310.95    1428    0    969    70.9
    311.14    1407    0    979.2    70.9
    311.29    1386    0    979.2    70.9
    311.45    1386    0    979.2    70.9
    311.61    1365    0    979.2    70.9
    311.78    1344    0    979.2    70.9
    311.93    1344    0    979.2    70.9
    312.1    1344    0    979.2    70.9
    312.26    1323    0    979.2    70.9
    312.44    1302    0    979.2    70.9
    312.59    1302    0    979.2    70.9
    312.76    1281    0    979.2    70.9
    312.95    1260    0    979.2    70.9
    313.11    1239    0    979.2    70.9
    313.26    1239    0    979.2    70.9
    313.42    1260    24.4    979.2    78.1
    313.59    1344    25    979.2    76.1
    313.75    1260    25.5    979.2    77.3
    313.91    1260    25.8    999.6    78.1
    314.06    1260    26.1    999.6    78.5
    314.24    1260    26.4    1009.8    78.1
    314.39    1260    3.6    1020    4.8
    314.55    1176    0    1020    70.5
    314.7    1260    0    1020    70.9
    314.88    1218    0    1020    70.9
    315.04    1239    26.1    1009.8    79.7
    315.19    1386    25.3    999.6    76.1
    315.34    1302    25.5    989.4    76.1
    315.52    1218    26.1    999.6    79.7
    315.67    1239    26.4    1009.8    79.7
    315.83    1239    26.6    1020    79.3
    315.98    1239    26.6    1020    79.3
    316.16    1239    26.9    1020    78.9
    316.31    1239    26.9    1030.2    78.9
    316.47    1239    26.9    1030.2    78.9
    316.64    1239    26.9    1030.2    78.9
    316.8    1239    0    1030.2    76.5
    316.96    1197    0    1040.4    70.9
    317.11    1218    0    1030.2    70.9
    317.27    1239    25.8    1020    79.3
    317.44    1323    25.8    999.6    76.1
    317.59    1260    26.1    999.6    77.3
    317.75    1218    26.4    1009.8    79.7
    317.91    1218    26.6    1020    79.7
    318.09    1218    26.6    1020    79.7
    318.25    1218    26.9    1030.2    79.7
    318.41    1239    26.9    1030.2    79.3
    318.56    1281    26.9    1030.2    77.3
    318.74    1365    26.9    1030.2    76.1
    318.89    1470    27.2    1030.2    76.1
    319.05    1470    27.2    1030.2    76.1
    319.2    1491    27.7    1040.4    76.1
    319.38    1491    28    1050.6    76.1
    319.53    1491    28.3    1060.8    76.1
    319.69    1491    28.3    1071    76.1
    319.85    1512    28.5    1071    76.1
    320.02    1512    28.8    1081.2    76.1
    320.18    1533    28.8    1081.2    76.1
    320.35    1554    28.8    1091.4    76.1
    320.52    1554    29.1    1091.4    76.1
    320.68    1386    0    1091.4    70.9
    320.85    1470    0    1081.2    70.9
    321.03    1386    0    1060.8    70.9
    321.18    1323    0    1040.4    70.9
    321.34    1281    0    1040.4    70.9
    321.51    1218    0    1030.2    70.9
    321.7    1302    0    1020    70.9
    321.87    1470    0    1009.8    70.9
    322.04    1596    0    999.6    70.9
    322.23    1743    0    999.6    70.9
    322.4    1827    0    989.4    70.9
    322.57    1806    2.7    979.2    70.9
    322.76    1848    11.8    989.4    70.5
    322.93    1806    14.3    989.4    63.4
    323.1    1806    15.1    999.6    66.9
    323.29    1806    15.4    999.6    68.9
    323.45    1806    15.9    999.6    72.1
    323.61    1806    15.9    1009.8    73.7
    323.78    1806    17.6    1009.8    76.1
    323.94    1806    17.6    1020    76.1
    324.1    1764    0    1020    70.9
    324.25    1722    0    1020    70.9
    324.43    1764    0    1009.8    70.9
    324.6    1743    0    999.6    70.9
    324.75    1743    0    999.6    70.9
    324.93    1722    0    999.6    70.9
    325.09    1722    14.5    999.6    70.1
    325.26    1764    13.7    999.6    76.1
    325.45    1680    0    999.6    70.9
    325.62    1659    0    999.6    70.9
    325.79    1680    0    999.6    70.9
    325.98    1680    0    989.4    70.9
    326.15    1659    0    989.4    70.9
    326.32    1638    0    989.4    70.9
    326.5    1617    0    989.4    70.9
    326.67    1617    0    989.4    70.9
    326.84    1596    0    989.4    70.9
    327.02    1575    0    979.2    70.9
    327.18    1575    0    989.4    70.9
    327.35    1554    0    979.2    70.9
    327.51    1554    0    979.2    70.9
    327.7    1533    0    979.2    70.9
    327.87    1512    10.4    979.2    70.9
    328.04    1596    24.2    979.2    76.1
    328.23    1575    25    969    75.7
    328.4    1533    25.5    979.2    76.1
    328.56    1554    26.1    999.6    76.1
    328.76    1554    26.6    1020    76.1
    328.92    1575    27.2    1030.2    76.1
    329.08    1575    27.7    1040.4    76.1
    329.25    1596    28    1050.6    76.1
    329.4    1596    28.3    1060.8    76.1
    329.57    1617    28.5    1071    76.1
    329.76    1617    28.8    1081.2    76.1
    329.93    1638    29.1    1091.4    76.1
    330.1    1638    29.4    1101.6    75.7
    330.28    1659    29.6    1101.6    76.1
    330.45    1659    29.9    1111.8    76.1
    330.62    1680    30.2    1111.8    75.7
    330.81    1701    30.2    1122    76.1
    330.98    1701    30.5    1122    76.1
    331.15    2079    31.6    1122    75.7
    331.34    2478    31.8    1111.8    73.7
    331.51    2793    31.8    1142.4    72.1
    331.69    2562    31.8    1173    70.1
    331.84    2205    33.5    1213.8    74.1
    332    1953    34.6    1224    76.1
    332.16    1911    34    1213.8    75.3
    332.31    1995    34    1203.6    76.1
    332.49    2352    34.6    1193.4    74.9
    332.64    2604    34.3    1193.4    73.3
    332.8    2646    35.1    1234.2    70.5
    332.98    2646    37.3    1295.4    70.1
    333.15    2667    39.3    1356.6    70.5
    333.3    2709    40.9    1417.8    70.1
    333.46    2772    42.5    1468.8    69.7
    333.61    2814    44.2    1530    68.1
    333.8    2877    46.4    1611.6    64.1
    333.96    2940    47.8    1683    60.6
    334.11    3003    49.1    1744.2    57.8
    334.27    3045    51.1    1825.8    54.2
    334.45    3129    53.5    1927.8    50.2
    334.6    3192    57.6    2009.4    46.2
    334.75    3255    58.5    2101.2    43.8
    334.91    3339    58.5    2193    41
    335.08    3423    58.2    2274.6    39
    335.23    3507    57.9    2305.2    37.9
    335.39    3591    57.9    2335.8    37.1
    335.55    3633    57.6    2346    36.3
    335.72    3633    26.1    2346    4.8
    335.88    3654    17.3    2295    9.2
    336.03    3549    0    2121.6    46.2
    336.19    3339    0    1856.4    48.2
    336.36    3213    0    1581    49.4
    336.52    3045    0    1417.8    51
    336.68    2835    0    1305.6    54.6
    336.83    2646    0    1234.2    57.8
    337.01    2436    0    1183.2    63
    337.18    2310    0    1132.2    68.1
    337.35    2436    0    1101.6    64.1
    337.53    2457    0    1060.8    62.6
    337.7    2436    0    1040.4    63.4
    337.87    2415    0    1030.2    64.1
    338.06    2394    0    1030.2    65.7
    338.23    2352    0    1020    66.5
    338.4    2331    0    1020    67.3
    338.59    2310    0    1009.8    68.1
    338.76    2310    0    1009.8    68.9
    338.93    2268    0    1009.8    69.7
    339.13    2268    0    999.6    70.5
    339.28    2247    0    999.6    70.9
    339.44    2226    0    999.6    70.9
    339.6    2226    0    999.6    70.9
    339.77    2205    0    999.6    70.9
    339.92    2184    0    999.6    70.9
    340.08    2184    0    989.4    70.9
    340.23    2184    0    989.4    70.9
    340.41    2163    0    989.4    70.9
    340.56    2142    0    989.4    70.9
    340.72    2142    0    989.4    70.9
    340.88    2121    0    989.4    70.9
    341.05    2121    0    989.4    70.9
    341.21    2100    0    989.4    70.9
    341.36    2100    0    989.4    70.9
    341.52    2079    0    989.4    70.9
    341.69    2079    0    989.4    70.9
    341.85    2058    0    989.4    70.9
    342    2058    0    989.4    70.9
    342.16    2058    0    989.4    70.9
    342.34    2037    0    989.4    70.9
    342.51    2037    0    989.4    70.9
    342.68    2016    0    989.4    70.9
    342.85    2016    0    989.4    70.9
    343.01    1995    0    989.4    70.9
    343.18    1974    0    989.4    70.9
    343.36    1869    0    989.4    70.9
    343.53    1764    0    989.4    70.9
    343.7    1701    0    999.6    70.9
    343.89    1617    0    989.4    70.9
    344.06    1533    0    999.6    70.9
    344.23    1470    0    989.4    70.9
    344.43    1428    0    989.4    70.9
    344.59    1428    0    989.4    70.9
    344.76    1428    0    989.4    70.9
    344.95    1428    0    979.2    70.9
    345.11    1428    0    979.2    70.9
    345.26    1407    0    979.2    70.9
    345.42    1407    0    979.2    70.9
    345.6    1407    0    979.2    70.9
    345.75    1407    0    979.2    70.9
    345.91    1386    0    979.2    70.9
    346.06    1386    0    979.2    70.9
    346.24    1365    0    979.2    70.9
    346.39    1365    0    979.2    70.9
    346.55    1365    0    979.2    70.9
    346.71    1365    25.8    979.2    76.1
    346.88    1491    24.7    979.2    76.1
    347.03    1407    25.3    979.2    76.1
    347.19    1365    25.8    999.6    76.1
    347.35    1134    26.4    1009.8    81.3
    347.52    1134    26.9    1020    81.3
    347.68    1155    26.9    1030.2    80.9
    347.83    1155    26.9    1030.2    81.3
    347.99    1155    26.9    1030.2    80.9
    348.17    1134    0    1030.2    80.9
    348.34    1092    0    1030.2    73.3
    348.51    1155    0    1020    70.9
    348.7    1134    0    1020    71.3
    348.87    1113    0    1009.8    71.7
    349.04    1092    0    1009.8    72.5
    349.22    1071    0    999.6    73.3
    349.38    1071    0    999.6    73.7
    349.54    1050    0    999.6    74.5
    349.7    1029    0.3    999.6    75.3
    349.9    1008    0.5    999.6    76.1
    350.06    987    0.3    999.6    76.1
    350.22    966    0    989.4    76.1
    350.4    966    0    989.4    76.1
    350.55    945    0.5    989.4    76.1
    350.71    924    0.5    989.4    76.1
    350.86    882    0.5    989.4    76.1
    351.04    861    0.8    989.4    76.1
    351.19    861    6.6    989.4    76.1
    351.35    882    4.9    989.4    76.1
    351.51    882    5.5    989.4    76.1
    351.7    861    5.8    989.4    76.1
    351.87    861    6.3    989.4    76.1
    352.04    840    7.1    989.4    76.1
    352.21    861    6    989.4    76.1
    352.37    882    4.7    989.4    76.1
    352.54    903    3.3    989.4    76.1
    352.69    945    1.4    989.4    76.1
    352.87    924    1.1    989.4    76.1
    353.04    903    1.9    989.4    76.1
    353.2    861    3.8    989.4    76.1
    353.39    840    6.9    989.4    76.1
    353.56    861    6.6    989.4    76.1
    353.73    840    6.9    989.4    76.1
    353.92    861    6.6    989.4    76.1
    354.09    840    7.4    989.4    76.1
    354.26    840    8    989.4    76.1
    354.45    840    14.3    989.4    76.9
    354.62    903    12.9    989.4    78.9
    354.8    966    11    989.4    76.9
    354.98    1008    10.2    989.4    76.1
    355.14    1092    7.4    979.2    72.9
    355.3    1092    6    979.2    71.3
    355.47    1092    6.3    979.2    72.1
    355.63    1071    6.9    979.2    72.5
    355.78    1071    7.1    979.2    72.9
    355.94    1071    7.1    979.2    72.9
    356.11    1071    6.6    979.2    73.3
    356.27    1050    7.1    989.4    73.7
    356.42    1050    7.4    979.2    74.1
    356.58    1050    7.4    979.2    73.7
    356.75    1050    7.4    989.4    74.1
    356.91    1050    7.7    989.4    74.5
    357.06    1029    13.7    989.4    75.7
    357.22    1176    24.4    979.2    80.5
    357.39    1365    24.4    958.8    76.1
    357.55    1470    24.4    958.8    76.1
    357.71    1554    25    958.8    76.1
    357.87    1554    25.5    979.2    76.1
    358.06    1554    26.4    999.6    76.1
    358.23    1575    26.6    1009.8    75.7
    358.4    1617    27.2    1030.2    76.1
    358.57    1638    27.7    1040.4    76.1
    358.73    1680    28.3    1050.6    76.1
    358.9    1701    28.5    1071    76.1
    359.08    1743    29.1    1081.2    76.1
    359.25    1785    29.6    1091.4    76.1
    359.41    1974    30.5    1091.4    76.1
    359.58    2394    31    1091.4    74.5
    359.74    2814    30.5    1101.6    72.9
    359.89    2919    30.7    1122    70.5
    360.05    3003    32.9    1193.4    68.9
    360.23    3108    35.4    1275    66.9
    360.39    3213    37.6    1356.6    66.1
    360.55    3318    30.2    1438.2    4.8
    360.71    3360    24.2    1519.8    4.8
    360.88    3465    23.3    1560.6    4.8
    361.03    3549    22.8    1550.4    5.2
    361.19    3612    24.7    1540.2    6
    361.35    3738    39.8    1519.8    62.2
    361.52    3885    40.4    1540.2    47.8
    361.68    3969    42.8    1642.2    43.8
    361.83    4032    46.1    1764.6    38.6
    361.99    4179    48.9    1876.8    30.7
    362.16    4284    51.6    1958.4    21.1
    362.32    4431    53.3    1999.2    15.9
    362.47    4368    0    2009.4    41
    362.63    4368    0    1968.6    41
    362.8    4137    0    1785    41.8
    362.96    3927    0    1570.8    43.4
    363.11    3843    31.3    1428    67.3
    363.27    3297    30.2    1336.2    70.9
    363.44    3108    35.4    1295.4    71.3
    363.6    2940    36.8    1326    70.1
    363.75    2898    38.7    1366.8    69.3
    363.91    2919    40.9    1438.2    68.9
    364.08    2961    43.1    1509.6    66.5
    364.24    3024    45    1591.2    63
    364.39    3045    46.9    1662.6    60.2
    364.55    3129    48.6    1744.2    55.4
    364.72    3213    50.8    1836    51.4
    364.88    3234    53.5    1938    47.4
    365.03    3276    58.2    2029.8    44.2
    365.19    3339    58.5    2131.8    42.2
    365.37    3423    58.2    2233.8    39
    365.53    3528    57.6    2284.8    37.5
    365.69    3633    57.6    2315.4    36.3
    365.85    3675    57.6    2315.4    35.5
    366.02    3717    57.4    2325.6    34.7
    366.18    3780    57.1    2315.4    34.3
    366.34    3843    56.8    2305.2    33.9
    366.53    3927    56.5    2284.8    33.5
    366.7    3990    56.3    2254.2    33.1
    366.87    4011    56.3    2233.8    33.5
    367.06    3801    48.9    2203.2    51.4
    367.23    2877    59.6    2223.6    53
    367.4    2898    60.1    2223.6    51.8
    367.58    2940    59.8    2244    51.4
    367.75    2982    59.8    2264.4    50.2
    367.92    3003    59.8    2284.8    49.4
    368.1    3066    59.6    2305.2    47.8
    368.25    3087    59.6    2325.6    47.4
    368.41    3108    59.6    2356.2    47.4
    368.56    3150    59.3    2366.4    46.6
    368.74    3171    59.3    2386.8    46.2
    368.89    3213    59    2397    45.4
    369.05    3234    59    2407.2    45.4
    369.2    3276    58.7    2417.4    45
    369.38    3318    58.7    2417.4    44.6
    369.55    3339    58.5    2427.6    43.8
    369.7    3360    58.5    2437.8    43.8
    369.86    3402    58.2    2437.8    43.8
    370.05    3444    58.2    2437.8    43
    370.2    3486    57.9    2437.8    43
    370.37    3507    57.9    2437.8    42.2
    370.57    3528    57.6    2437.8    42.2
    370.73    3570    57.6    2437.8    41.8
    370.91    3612    57.6    2427.6    41.4
    371.09    3633    57.4    2417.4    41
    371.26    3675    57.4    2407.2    40.2
    371.42    3696    57.4    2407.2    40.2
    371.6    3717    57.1    2397    40.2
    371.75    3759    57.1    2386.8    39.8
    371.91    3780    57.1    2376.6    40.2
    372.06    3801    56.8    2366.4    40.2
    372.24    3822    56.8    2356.2    40.2
    372.4    3864    56.8    2346    40.2
    372.56    3885    56.8    2335.8    40.6
    372.75    3906    56.5    2325.6    40.6
    372.92    3927    56.5    2315.4    40.6
    373.09    3969    56.5    2305.2    40.6
    373.28    3990    56.3    2295    41
    373.45    4011    56.3    2274.6    41
    373.62    4053    56.3    2274.6    40.6
    373.79    4074    56    2264.4    39.8
    373.95    4095    56    2254.2    39.8
    374.12    4116    56    2244    39
    374.31    4137    56    2244    39.4
    374.48    4158    56    2233.8    39
    374.65    4200    55.7    2223.6    39.4
    374.83    4179    55.7    2213.4    39.8
    374.99    3696    49.4    2213.4    51.8
    375.14    3276    57.6    2254.2    57.4
    375.3    3171    59    2305.2    55.8
    375.47    3192    59    2356.2    55.4
    375.63    3213    59    2397    54.2
    375.79    3213    59    2427.6    54.6
    375.94    3234    58.7    2448    53.8
    376.12    3255    58.7    2458.2    53.8
    376.28    3255    58.7    2468.4    53.4
    376.44    3276    58.7    2478.6    53.4
    376.6    3297    58.7    2478.6    53
    376.77    3297    58.7    2488.8    52.6
    376.92    3318    58.5    2488.8    52.6
    377.08    3339    58.5    2488.8    51.8
    377.24    3339    58.5    2488.8    52.2
    377.41    3360    58.5    2488.8    51.4
    377.57    3381    58.5    2499    51
    377.72    3402    58.2    2499    51
    377.88    3402    24.7    2499    4.8
    378.05    3255    0    2427.6    49
    378.21    3318    0    2050.2    48.2
    378.36    3339    0    1723.8    48.2
    378.52    3318    0    1509.6    48.2
    378.69    3297    0    1366.8    48.6
    378.85    3276    0    1275    48.6
    379    3234    0    1213.8    49
    379.16    3192    0    1173    49.4
    379.33    3150    0    1142.4    49.8
    379.49    3108    0    1122    50.2
    379.65    3045    0    1101.6    51
    379.8    3003    0    1091.4    51.4
    379.98    2961    0    1081.2    52.2
    380.13    2898    0    1071    53.4
    380.29    2856    0    1071    54.2
    380.44    2814    0    1060.8    55
    380.62    2751    0    1060.8    55.8
    380.77    2730    0    1050.6    56.6
    380.93    2667    0    1050.6    57.8
    381.08    2625    0    1040.4    58.6
    381.26    2583    0    1040.4    59.4
    381.43    2541    0    1040.4    59.8
    381.59    2499    0    1040.4    60.6
    381.78    2457    0    1030.2    62.6
    381.95    2394    0    1030.2    64.9
    382.12    2352    0    1030.2    67.3
    382.3    2289    0    1030.2    69.3
    382.47    2247    0    1020    70.9
    382.64    2205    0    1020    70.9
    382.83    2142    0    1020    70.9
    383    2100    0    1009.8    70.9
    383.17    2058    0    1009.8    70.9
    383.36    1974    0    1009.8    70.9
    383.53    1932    0    1009.8    70.9
    383.7    1890    0    1009.8    70.9
    383.89    1827    0    1009.8    70.9
    384.05    1764    0    1009.8    70.9
    384.21    1722    0    999.6    70.9
    384.37    1659    0    999.6    70.9
    384.54    1617    0    999.6    70.9
    384.7    1575    0    999.6    70.9
    384.87    1533    0    999.6    70.9
    385.04    1491    0    999.6    70.9
    385.2    1449    0    989.4    70.9
    385.37    1407    0    989.4    70.9
    385.55    1386    0    989.4    70.9
    385.72    1365    0    989.4    70.9
    385.88    1344    0    989.4    70.9
    386.07    1344    13.7    989.4    70.9
    386.23    1386    23.9    989.4    76.1
    386.38    1407    24.4    979.2    76.1
    386.54    1344    25    989.4    76.1
    386.72    1344    25.5    999.6    76.1
    386.88    1512    25.8    1009.8    76.1
    387.04    1701    26.1    1009.8    76.1
    387.21    1932    26.9    1020    76.1
    387.37    1932    25.8    1030.2    75.7
    387.52    1890    27.7    1050.6    76.1
    387.68    2163    28.5    1060.8    75.3
    387.85    2289    29.1    1071    74.1
    388.01    2373    30.2    1091.4    72.9
    388.17    2436    31.6    1132.2    72.1
    388.36    2541    33.2    1173    72.5
    388.53    2625    34.3    1213.8    70.9
    388.7    2667    36    1275    70.9
    388.89    2709    37.6    1336.2    70.1
    389.06    2730    39.5    1397.4    70.9
    389.23    2289    41.5    1458.6    71.7
    389.42    1932    40.9    1458.6    76.1
    389.58    1953    39.8    1417.8    76.1
    389.74    1890    39    1387.2    75.7
    389.89    1491    36.5    1366.8    74.1
    390.07    1470    34.9    1315.8    76.1
    390.23    1491    33.8    1275    76.1
    390.38    1491    32.9    1244.4    76.1
    390.54    1491    32.1    1213.8    76.1
    390.71    1491    31.6    1193.4    76.1
    390.87    1554    31    1173    76.1
    391.03    1407    29.9    1162.8    76.1
    391.2    1260    30.5    1152.6    78.1
    391.37    1239    29.9    1132.2    78.9
    391.53    1260    29.4    1122    78.5
    391.7    1260    29.1    1101.6    78.1
    391.9    1260    28.5    1091.4    78.1
    392.06    1260    28.3    1081.2    78.1
    392.23    1260    28.3    1081.2    78.1
    392.4    1260    28    1071    77.7
    392.58    1260    28    1071    77.7
    392.75    1260    27.7    1060.8    77.7
    392.94    1260    27.7    1060.8    77.7
    393.1    1260    27.7    1060.8    77.7
    393.25    1260    27.5    1060.8    77.7
    393.41    1281    27.5    1060.8    77.3
    393.58    1281    27.5    1050.6    77.3
    393.74    1281    27.5    1050.6    77.3
    393.89    1281    27.5    1050.6    77.3
    394.05    1281    27.5    1050.6    77.3
    394.22    1281    27.5    1050.6    77.3
    394.38    1281    27.5    1050.6    77.3
    394.55    1281    27.5    1050.6    77.3
    394.71    1281    27.5    1050.6    76.9
    394.88    1281    27.5    1050.6    77.3
    395.04    1281    27.5    1050.6    76.9
    395.19    1281    27.5    1050.6    76.9
    395.35    1281    27.5    1050.6    76.9
    395.52    1281    27.5    1050.6    76.5
    395.68    1281    27.5    1050.6    76.9
    395.84    1281    27.5    1050.6    76.5
    396.03    1281    27.5    1050.6    76.5
    396.2    1302    27.5    1050.6    76.5
    396.37    1281    27.5    1050.6    76.5
    396.54    1281    27.5    1050.6    76.5
    396.7    1302    27.5    1050.6    76.5
    396.87    1281    27.5    1050.6    76.1
    397.06    1302    27.5    1050.6    76.1
    397.23    1302    27.5    1050.6    76.1
    397.39    1302    27.5    1050.6    76.1
    397.57    1302    27.5    1050.6    76.1
    397.73    1302    27.5    1050.6    76.1
    397.88    1302    27.7    1060.8    76.1
    398.04    1302    27.7    1060.8    76.1
    398.21    1302    27.7    1060.8    76.1
    398.37    1302    27.7    1060.8    76.1
    398.52    1302    27.7    1060.8    76.1
    398.68    1302    27.7    1060.8    76.1
    398.85    1302    27.7    1060.8    76.1
    399.01    1302    27.7    1060.8    76.1
    399.17    1302    27.7    1060.8    76.1
    399.36    1323    27.7    1060.8    76.1
    399.53    1302    27.7    1060.8    76.1
    399.7    1323    27.7    1060.8    76.1
    399.87    1323    27.7    1060.8    76.1
    400.03    1323    27.7    1060.8    76.1
    400.2    1323    27.7    1060.8    76.1
    400.36    1323    27.7    1060.8    76.1
    400.54    1323    27.7    1060.8    76.1
    400.7    1323    27.7    1060.8    76.1
    400.87    1323    27.7    1060.8    76.1
    401.04    1323    28    1060.8    76.1
    401.2    1323    27.7    1060.8    76.1
    401.37    1323    28    1060.8    76.1
    401.52    1323    28    1060.8    76.1
    401.7    1323    28    1060.8    76.1
    401.87    1323    28    1060.8    76.1
    402.02    1323    28    1060.8    76.1
    402.18    1323    28    1060.8    76.1
    402.36    1323    28    1071    76.1
    402.53    1344    28    1071    76.1
    402.7    1344    28    1071    76.1
    402.87    1344    28    1071    76.1
    403.03    1344    28    1071    76.1
    403.2    1344    28    1071    76.1
    403.37    1344    28    1071    76.1
    403.53    1344    28    1071    76.1
    403.69    1344    28    1071    76.1
    403.85    1344    28.3    1071    76.1
    404.02    1344    28.3    1071    76.1
    404.2    1344    28.3    1071    76.1
    404.35    1344    28.3    1071    76.1
    404.52    1344    28.3    1071    76.1
    404.7    1344    28.3    1071    76.1
    404.87    1344    28.3    1071    76.1
    405.04    1365    28.3    1071    76.1
    405.2    1365    28.3    1071    76.1
    405.36    1365    28.3    1071    76.1
    405.55    1365    28.3    1071    76.1
    405.72    1365    28.3    1071    76.1
    405.89    1365    28.3    1071    76.1
    406.08    1365    28.3    1071    76.1
    406.25    1365    28.3    1071    76.1
    406.42    1365    28.3    1071    76.1
    406.61    1365    28.3    1071    76.1
    406.78    1365    28.3    1071    76.1
    406.95    1365    28.5    1081.2    76.1
    407.14    1365    28.5    1081.2    76.1
    407.31    1365    28.3    1081.2    76.1
    407.47    1365    28.5    1081.2    76.1
    407.67    1365    28.5    1081.2    76.1
    407.84    1386    28.5    1081.2    76.1
    408    1386    28.5    1081.2    76.1
    408.19    1386    28.5    1081.2    76.1
    408.35    1386    28.5    1081.2    76.1
    408.53    1386    28.5    1081.2    76.1
    408.71    1386    28.5    1081.2    76.1
    408.86    1386    28.5    1081.2    76.1
    409.02    1386    28.5    1081.2    76.1
    409.18    1386    28.5    1081.2    76.1
    409.34    1386    28.5    1081.2    76.1
    409.5    1386    28.5    1081.2    76.1
    409.66    1386    28.8    1081.2    76.1
    409.82    1407    28.5    1081.2    76.1
    409.99    1407    28.8    1081.2    76.1
    410.15    1407    28.8    1081.2    76.1
    410.3    1407    28.8    1081.2    76.1
    410.46    1407    28.8    1081.2    76.1
    410.63    1407    28.8    1081.2    76.1
    410.79    1407    28.8    1091.4    76.1
    410.94    1407    28.8    1091.4    76.1
    411.1    1407    28.8    1091.4    76.1
    411.27    1407    28.8    1091.4    76.1
    411.43    1407    28.8    1091.4    76.1
    411.59    1407    28.8    1091.4    76.1
    411.74    1407    28.8    1091.4    76.1
    411.92    1407    28.8    1091.4    76.1
    412.09    1428    28.8    1091.4    76.1
    412.24    1428    28.8    1091.4    76.1
    412.4    1407    28.8    1091.4    76.1
    412.58    1428    28.8    1091.4    76.1
    412.75    1428    28.8    1091.4    76.1
    412.92    1428    28.8    1091.4    76.1
    413.12    1428    28.8    1091.4    76.1
    413.28    1428    28.8    1091.4    76.1
    413.44    1428    28.8    1091.4    76.1
    413.61    1428    29.1    1091.4    76.1
    413.77    1428    29.1    1091.4    76.1
    413.93    1428    28.8    1091.4    76.1
    414.08    1428    29.1    1091.4    76.1
    414.26    1428    29.1    1091.4    76.1
    414.41    1428    29.1    1091.4    76.1
    414.57    1428    1.6    1091.4    4.8
    414.73    1344    3.6    1091.4    70.1
    414.9    1533    27.2    1071    76.1
    415.06    1680    27.5    1050.6    76.1
    415.21    2121    28.8    1050.6    75.7
    415.37    2688    28.3    1040.4    73.7
    415.54    3171    27.2    1050.6    67.3
    415.7    3339    28.8    1111.8    65.7
    415.85    3318    32.1    1193.4    64.9
    416.01    3360    35.4    1305.6    65.3
    416.18    3402    39.3    1448.4    60.2
    416.34    3444    42.5    1560.6    54.6
    416.5    3528    45.3    1693.2    47
    416.69    3528    50    1856.4    43
    416.86    2919    53.5    1989    67.3
    417.03    2520    59.3    2009.4    59.4
    417.22    2541    59.6    2019.6    57.8
    417.39    2562    59.8    2040    57
    417.56    2583    56.8    2070.6    59.4
    417.74    1932    60.1    2070.6    73.7
    417.92    1974    59    1938    76.1
    418.09    1974    55.2    1836    76.1
    418.28    1722    50.8    1744.2    66.9
    418.45    1659    47.2    1652.4    76.1
    418.61    1659    44.7    1560.6    76.1
    418.79    1659    42.3    1489.2    76.1
    418.97    1680    39.8    1428    76.1
    419.14    1680    38.4    1377    76.1
    419.33    1680    36.8    1336.2    76.1
    419.5    1680    36    1305.6    76.1
    419.67    1680    35.1    1285.2    76.1
    419.85    1701    34.3    1254.6    76.1
    420.02    1701    33.8    1234.2    76.1
    420.19    1701    33.5    1224    76.1
    420.38    1701    32.9    1203.6    76.1
    420.55    1722    32.7    1203.6    76.1
    420.72    1701    32.7    1193.4    75.7
    420.91    1722    32.4    1183.2    76.1
    421.08    1722    32.1    1183.2    75.7
    421.25    1722    32.1    1183.2    76.1
    421.44    1722    32.1    1173    75.7
    421.61    1722    32.1    1173    76.1
    421.78    1722    32.1    1173    75.7
    421.97    1722    32.1    1173    76.1
    422.14    1722    32.1    1173    75.7
    422.31    1722    31.8    1173    76.1
    422.49    1743    32.1    1173    75.7
    422.66    1743    32.1    1173    76.1
    422.83    1743    32.1    1173    75.3
    423.02    1743    32.1    1173    76.1
    423.18    1743    32.1    1173    76.1
    423.33    1743    32.1    1173    76.1
    423.49    1743    32.1    1173    76.1
    423.67    1764    32.1    1173    76.1
    423.82    1764    32.1    1183.2    76.1
    423.97    1764    32.1    1183.2    75.7
    424.13    1764    32.1    1183.2    75.7
    424.29    1764    32.4    1183.2    76.1
    424.46    1764    32.4    1183.2    75.7
    424.61    1764    32.4    1183.2    75.7
    424.78    1764    32.4    1183.2    75.7
    424.96    1785    32.4    1183.2    76.1
    425.11    1785    32.7    1183.2    76.1
    425.27    1785    32.7    1183.2    75.7
    425.43    1785    32.7    1183.2    76.1
    425.59    1785    32.7    1183.2    75.7
    425.76    1785    32.7    1193.4    75.7
    425.91    1785    32.7    1193.4    76.1
    426.07    1785    32.7    1193.4    76.1
    426.25    1806    32.7    1193.4    76.1
    426.42    1806    32.9    1193.4    75.3
    426.58    1806    32.9    1193.4    76.1
    426.77    1806    32.9    1193.4    75.7
    426.94    1806    32.9    1193.4    75.7
    427.11    1806    33.2    1193.4    76.1
    427.29    1806    33.2    1203.6    75.7
    427.47    1827    33.2    1203.6    76.1
    427.64    1827    33.2    1203.6    76.1
    427.82    1827    33.2    1203.6    76.1
    428    1827    33.2    1203.6    76.1
    428.17    1827    33.2    1203.6    76.1
    428.35    1827    33.5    1203.6    76.1
    428.5    1827    33.5    1203.6    76.1
    428.66    1848    337    1264.8    76.1
    434.99    1974    35.7    1264.8    75.7
    435.15    1974    35.7    1264.8    76.1
    435.31    1974    35.7    1264.8    75.7
    435.48    1974    36    1264.8    76.1
    435.64    1974    36    1264.8    75.7
    435.81    1974    36    1264.8    76.1
    435.98    1995    36.2    1275    76.1
    436.14    1995    36.2    1275    76.1
    436.29    1995    36.2    1275    75.7
    436.45    1995    36.2    1275    76.1
    436.63    1995    36.5    1285.2    76.1
    436.8    2016    36.5    1285.2    76.1
    436.97    2121    36.8    1285.2    75.7
    437.16    2289    37.3    1285.2    74.1
    437.33    2310    38.2    1295.4    73.7
    437.5    2142    37.9    1315.8    74.9
    437.68    2100    37.9    1315.8    75.7
    437.86    2079    37.6    1315.8    75.7
    438.03    2058    37.6    1315.8    75.7
    438.21    2079    37.6    1315.8    75.7
    438.38    2016    37.6    1315.8    75.7
    438.54    2037    37.9    1326    75.7
    438.71    2037    37.9    1326    75.7
    438.87    2037    37.9    1326    75.7
    439.04    2037    37.9    1326    75.7
    439.19    2058    37.9    1326    75.7
    439.37    2058    37.9    1326    75.7
    439.54    2058    38.2    1326    75.3
    439.69    2058    38.2    1326    75.7
    439.87    2079    38.2    1336.2    75.7
    440.02    2121    38.4    1336.2    75.7
    440.18    2268    38.7    1336.2    74.9
    440.34    2352    39.5    1346.4    73.7
    440.51    2163    39.3    1356.6    74.9
    440.67    2142    39.3    1356.6    75.3
    440.82    2142    39    1356.6    75.3
    440.98    2121    39    1356.6    75.3
    441.15    2100    39    1356.6    74.9
    441.3    2100    39.3    1366.8    75.7
    441.46    2100    39.3    1366.8    75.7
    441.62    2100    39.3    1366.8    75.7
    441.78    2100    39.3    1366.8    75.7
    441.94    2121    39.5    1377    75.7
    442.09    2121    39.5    1377    74.9
    442.26    2184    39.8    1377    75.3
    442.43    2331    39.8    1377    74.9
    442.58    2499    40.1    1387.2    73.3
    442.74    2562    40.9    1417.8    72.1
    442.9    2583    42.5    1468.8    70.5
    443.07    2583    44.7    1540.2    70.1
    443.23    2604    46.4    1601.4    69.7
    443.38    2604    44.2    1662.6    6.8
    443.54    2604    36.5    1713.6    6.8
    443.71    2625    28    1713.6    6.8
    443.89    2604    19.8    1662.6    6.8
    444.04    2625    19.5    1591.2    6.8
    444.2    2646    19.5    1509.6    6.8
    444.36    2646    19.5    1448.4    6.8
    444.53    2625    19.5    1407.6    6.8
    444.68    2625    19.5    1387.2    6.8
    444.83    2604    19.5    1356.6    6.8
    445.01    2625    19.5    1336.2    6.8
    445.18    2541    0    1326    59.8
    445.34    2667    18.7    1285.2    6.8
    445.5    2688    18.9    1244.4    6.8
    445.69    2877    18.1    1234.2    6.8
    445.84    3003    17.3    1234.2    72.1
    446.01    3150    16.7    1234.2    69.7
    446.17    3297    16.2    1244.4    69.7
    446.34    3402    15.6    1254.6    69.7
    446.5    3444    15.6    1264.8    58.2
    446.66    3444    15.6    1275    61
    446.83    3444    15.6    1285.2    60.6
    446.99    3444    15.6    1295.4    57
    447.17    3444    15.6    1295.4    54.6
    447.34    3444    15.6    1305.6    52.6
    447.51    3444    15.6    1305.6    51.4
    447.69    3444    15.6    1305.6    49.8
    447.87    3444    15.6    1305.6    49.4
    448.05    3423    15.6    1305.6    50.2
    448.21    3423    15.6    1305.6    49.8
    448.41    3423    15.6    1305.6    49.4
    448.58    3423    15.6    1305.6    48.6
    448.74    3423    15.6    1295.4    49
    448.93    3423    15.6    1295.4    49.4
    449.1    3423    15.6    1295.4    49.4
    449.27    3402    15.6    1295.4    49.8
    449.43    3402    15.6    1295.4    49.4
    449.6    3402    15.6    1295.4    50.2
    449.77    3402    15.6    1295.4    50.2
    449.96    3402    15.6    1295.4    50.2
    450.1    3402    15.6    1295.4    50.2
    450.26    3402    15.6    1295.4    50.6
    450.42    3402    15.6    1295.4    50.6
    450.62    3381    15.6    1285.2    51.4
    450.78    3402    15.6    1285.2    50.6
    450.93    3402    15.6    1285.2    51.4
    451.12    3381    15.6    1285.2    51.4
    451.28    3381    15.9    1285.2    51.8
    451.44    3381    15.9    1285.2    51.8
    451.59    3381    15.9    1285.2    51.8
    451.78    3381    15.6    1285.2    52.2
    451.92    3381    15.6    1285.2    52.2
    452.08    3381    15.9    1285.2    52.2
    452.24    3381    15.9    1285.2    52.6
    452.41    3381    15.9    1285.2    52.6
    452.57    3360    15.9    1285.2    52.6
    452.72    3381    15.9    1295.4    52.2
    452.87    3381    15.9    1295.4    53
    453.05    3360    15.9    1295.4    53
    453.21    3360    15.9    1295.4    53
    453.36    3360    15.9    1295.4    53.4
    453.51    3360    15.9    1295.4    53.4
    453.69    3360    15.9    1295.4    53.8
    453.84    3360    15.9    1295.4    53.8
    454.01    3360    15.9    1295.4    53.8
    454.16    3360    15.9    1295.4    53.8
    454.33    3360    15.9    1295.4    54.2
    454.49    3360    15.9    1295.4    53.8
    454.65    3360    15.9    1295.4    54.2
    454.85    3360    15.9    1295.4    54.2
    455.01    3339    15.9    1295.4    54.6
    455.18    3339    15.9    1295.4    54.6
    455.37    3339    15.9    1295.4    54.6
    455.54    3339    15.9    1295.4    55
    455.72    3339    15.9    1295.4    55
    455.91    3339    15.9    1295.4    55.4
    456.07    3339    15.9    1295.4    55.4
    456.24    3339    15.9    1295.4    55.4
    456.42    3339    15.9    1295.4    55.8
    456.57    3339    15.9    1295.4    55.4
    456.73    3339    15.9    1295.4    55.8
    456.89    3339    15.9    1295.4    55.4
    457.06    3318    15.9    1295.4    56.2
    457.23    3318    15.9    1295.4    56.2
    457.38    3318    15.9    1295.4    57
    457.53    3318    15.9    1295.4    56.6
    457.7    3318    15.9    1295.4    56.6
    457.87    3318    15.9    1295.4    56.6
    458.02    3318    15.9    1295.4    57
    458.17    3318    15.9    1295.4    57
    458.35    3318    15.9    1295.4    57.4
    458.51    3297    15.9    1295.4    57.4
    458.66    3318    15.9    1295.4    57
    458.83    3318    15.9    1295.4    57.4
    459.01    3297    15.9    1295.4    57
    459.19    3297    15.9    1295.4    57.8
    459.36    3297    15.9    1295.4    57.8
    459.53    3297    16.2    1295.4    57.8
    459.7    3297    15.9    1295.4    58.2
    459.88    3297    16.2    1295.4    58.6
    460.06    3297    15.9    1295.4    58.6
    460.22    3297    16.2    1305.6    58.6
    460.37    3297    16.2    1305.6    58.6
    460.53    3297    16.2    1305.6    58.6
    460.7    3297    15.9    1305.6    58.2
    460.86    3297    16.2    1305.6    58.2
    461.02    3297    16.2    1305.6    58.6
    461.17    3297    16.2    1305.6    58.6
    461.35    3276    16.2    1305.6    58.6
    461.5    3276    16.2    1305.6    59
    461.65    3297    16.2    1305.6    59
    461.81    3276    16.2    1305.6    59
    461.99    3276    16.2    1305.6    59.4
    462.14    3276    16.2    1305.6    59.4
    462.29    3276    16.2    1305.6    59.8
    462.45    3276    16.2    1305.6    59.4
    462.62    3276    16.2    1305.6    59.8
    462.78    3276    16.2    1305.6    59.8
    462.93    3276    16.2    1305.6    59.8
    463.09    3276    16.2    1305.6    60.2
    463.26    3276    16.2    1305.6    59.8
    463.42    3276    16.2    1305.6    60.6
    463.59    3276    16.2    1305.6    60.2
    463.78    3276    16.2    1305.6    60.6
    463.95    3276    16.2    1305.6    61.8
    464.13    3276    16.2    1305.6    61
    464.32    3255    16.2    1305.6    61.4
    464.49    3276    16.2    1305.6    61.4
    464.65    3276    16.2    1305.6    61.8
    464.84    3276    16.2    1305.6    61.4
    465    3276    16.2    1305.6    61.8
    465.17    3234    0    1305.6    48.6
    465.36    3150    0    1285.2    49.8
    465.51    3192    0    1224    49.4
    465.68    3297    15.4    1173    70.9
    465.86    3213    16.2    1152.6    70.9
    466.01    3192    16.5    1173    70.1
    466.17    3192    16.5    1203.6    70.5
    466.33    3108    17    1224    70.5
    466.51    3192    16.5    1244.4    71.3
    466.67    3192    16.5    1254.6    71.3
    466.82    3192    16.5    1264.8    70.9
    467    3192    16.5    1275    57.4
    467.15    3192    16.5    1285.2    61.8
    467.32    3192    16.5    1285.2    63
    467.47    3192    16.5    1295.4    60.6
    467.64    3192    16.5    1295.4    57.8
    467.79    3192    16.5    1295.4    56.2
    467.95    3192    16.5    1295.4    54.2
    468.11    3192    16.5    1295.4    54.2
    468.28    3192    16.5    1295.4    53
    468.44    3192    16.5    1295.4    53.4
    468.6    3192    16.5    1295.4    53
    468.75    3192    16.5    1295.4    53
    468.92    3192    16.5    1305.6    52.2
    469.08    3171    16.5    1305.6    53
    469.23    3192    16.5    1305.6    52.2
    469.39    3171    16.5    1305.6    52.6
    469.57    3171    16.5    1305.6    52.6
    469.74    3171    16.5    1305.6    53
    469.9    3171    16.5    1305.6    52.6
    470.08    3171    16.5    1305.6    53
    470.24    3171    16.5    1305.6    53.4
    470.4    3171    16.5    1305.6    53.4
    470.59    3171    16.5    1305.6    53.4
    470.76    3171    16.7    1305.6    53.4
    470.9    3171    16.5    1305.6    53.4
    471.08    3171    16.5    1305.6    53.8
    471.23    3171    16.7    1305.6    53.8
    471.39    3171    16.7    1305.6
VAGMAN
C?ID=374246
Sorry, I wasn't supposed to copy and paste all of the logging, The error was logged during the logging, it was logged at 2583 rpm (engine speed) so I've filtered the logging for this engine speed.
unfortunately the time is not time stamped, it's captured in seconds, however, I'm confident the limp mode started in the 400 plus seconds, this leaves 3 entries in the log which could be 417.56, 442.9, or 443.07.
I also noticed the control duty cycle only sitting at 76% at idle,
what controls this parameter?
Sunday
1​
August
2021​
19:21:38:25558-VCID:78F9AE3F0BB09D4BFB-802CVCDS Version: Release 21.3.0 (x64)Data version: 20210226 DS325.0
03G 906 016 DTR4 2.0L EDC 0000AG 7000
Group A:'011Group B:
Engine SpeedCharge PressureBoost PressureCharge Pressure
TIME(G28)Control Status(actual)Control Duty CycleTIME
MarkerSTAMP/minmg/strmbar%STAMP
125.68​
2583​
30.5​
1091.4​
70.9​
153.07​
2583​
0​
1050.6​
59​
231.31​
2583​
31.3​
1101.6​
72.1​
231.48​
2583​
32.7​
1142.4​
70.9​
278.86​
2583​
54.9​
1887​
60.6​
381.26​
2583​
0​
1040.4​
59.4​
417.56​
2583​
56.8​
2070.6​
59.4​
442.9​
2583​
42.5​
1468.8​
70.5​
443.07​
2583​
44.7​
1540.2​
70.1​
Hmm. That's not quite the data I was expecting to see in Group 011. Field 2 is supposed to be specified pressure, not charge pressure control status. So I'm quite confused by the data in field 2. We you fooling around in Basic Settings in that group?
VAGMAN
C?ID=374246
No, I went into group 11 and selected the option to log to file and drove the car.
Hi VM, considering the age and mileage, and also that you have thoroughly checked the compressor side of the plumbing, I would also take a look at the exhaust side of the turbo ; primarily the interface or connection from the exhaust manifold or "up-pipe" to the turbo itself (turbine side). If there is any leak here, it will be difficult to reach or build boost.
Does your exhaust note sound any different when you get into boost?
VAGMAN
C?ID=374246
Hi Stef,
I’ve never listened to the note of the exhaust to be honest, I did inspect the area around the exhaust side of the turbo when I removed the actuator, but I’ll double check again to see if there’s any sign of a leak.
@Uwe, is there any way to configure the values that are displayed in group 11, my understanding is I need to display the actual boost v specified boost?
I believe a chip-tuner can do that. Is your ECU "tuned"?
My documentation says that Group 011 should have both, and that was exactly what was in Group 011 in just about all 4-cylinder TDIs of that approximate vintage, so I'm rather puzzled what's going on with yours.
NEtech
Denmark
C?ID=56995
Please post a screenshot from [Meas. Blocks-08] in Group 011, as Uwe wrote, somehow it must be in Basic Setting.
VAGMAN
C?ID=374246
Hi NEtech, You are correct, in measuring blocks-08, in group 11 there is option which shows boost pressure actual and boost pressure specified.
I will try to replicate the issue and capture the values in the log, i did, log the values at idle, putting my foot on the accelerator and below is what was captured,
are the two columns mixed up? i.e specified always seems to be more than actual?
you will also notice that actual around 5 seconds hits zero, this is the time I revved the car whilst in idle?
let me know if the snapshot below reveals anything or if I need to run it again and capture the values when it goes into limp mode.
the other thing is that I don't get any dash lights, no EML or flashing glow light.
TIA
Monday
2​
August
2021​
09:41:10:25558-VCID:78F9AE3F08B09D4BFB-515AVCDS Version: Release 21.3.0 (x64)Data version: 20210226 DS325.0
Engine SpeedBoost PressureBoost PressureCharge Pressure
TIME(G28)(specified)(actual)Control Duty CycleTIME
MarkerSTAMP/minmbarmbar%STAMP
0.09​
819​
1060.8​
989.4​
76.1​
0.26​
840​
1060.8​
989.4​
76.1​
0.43​
819​
1060.8​
989.4​
76.1​
0.6​
819​
1060.8​
989.4​
76.1​
0.78​
819​
1060.8​
989.4​
76.1​
0.95​
819​
1060.8​
989.4​
76.1​
1.12​
819​
1060.8​
989.4​
76.1​
1.29​
819​
1060.8​
989.4​
76.1​
1.47​
819​
1060.8​
989.4​
76.1​
1.64​
819​
1060.8​
989.4​
76.1​
1.81​
819​
1060.8​
989.4​
76.1​
1.98​
819​
1060.8​
989.4​
76.1​
2.15​
819​
1060.8​
989.4​
76.1​
2.31​
819​
1060.8​
989.4​
76.1​
2.47​
819​
1060.8​
989.4​
76.1​
2.63​
819​
1060.8​
989.4​
76.1​
2.79​
840​
1060.8​
989.4​
76.1​
2.96​
819​
1060.8​
989.4​
76.1​
3.13​
819​
1060.8​
989.4​
76.1​
3.3​
819​
1060.8​
989.4​
76.1​
3.48​
819​
1060.8​
989.4​
76.1​
3.65​
840​
1060.8​
989.4​
76.1​
3.82​
840​
1060.8​
989.4​
76.1​
3.99​
840​
1060.8​
989.4​
76.1​
4.17​
882​
2091​
989.4​
81.3​
4.34​
1239​
2091​
979.2​
71.3​
4.51​
1323​
2091​
969​
69.7​
4.68​
1365​
2091​
969​
69.7​
4.85​
1407​
2091​
979.2​
72.5​
5.03​
1743​
2305.2​
979.2​
76.1​
5.2​
2394​
2499​
948.6​
74.5​
5.37​
3024​
0​
938.4​
51.8​
5.55​
3192​
0​
958.8​
49.8​
5.72​
2982​
0​
999.6​
51.4​
5.89​
2709​
0​
1009.8​
56.2​
6.05​
2457​
0​
1009.8​
61.8​
6.2​
2226​
0​
1009.8​
70.9​
6.36​
1995​
0​
1020​
70.9​
6.51​
1785​
0​
1020​
70.9​
6.67​
1596​
0​
1009.8​
70.9​
6.83​
1386​
0​
1009.8​
70.9​
6.99​
1197​
71.4​
1009.8​
70.9​
7.15​
1008​
326.4​
1009.8​
75.3​
7.32​
882​
550.8​
1009.8​
76.1​
7.49​
840​
693.6​
1009.8​
76.1​
7.66​
819​
795.6​
1009.8​
76.1​
7.83​
798​
887.4​
1009.8​
76.1​
8.01​
819​
928.2​
1009.8​
76.1​
VAGMAN
C?ID=374246
I've captured the log during the car going into limp mode, same error as before, but this time at 2142RPM
If I marry the RPM with the log file and filter it, I get the values in the table below (I've kept some values before this RPM in case there is something relevant here).
i'm guessing that the under boost around where there are a number of 0's in the specified column
OR if the logging columns are incorrect, these 0 values could be the actual values being logged?
1) first question - are the columns the wrong way round?
2) is it correct to say that the under boost occurred at where the RPM is 2142 and 0 value in the boost column?
3) where are these values being read from (what sensor)
4) what should I be looking for next?
TIA
Monday,02,August,2021,11:12:38:25558
VCDS Version: Release 21.3.0 (x64) Running on Windows 10 x64
Address 01: Engine Labels: 03G-906-016-BKD.clb
Control Module Part Number: 03G 906 016 DT HW: 028 101 189 2
Component and/or Version: R4 2,0L EDC 0000AG 7000
Software Coding: 0300078
Work Shop Code: WSC 02629 005 00000
VCID: 78F9AE3F08B09D4BFB-513C
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
RPM: 2142 /min
Torque: 254.0 Nm
Speed: 108.0 km/h
Load: 100.0 %
Voltage: 14.21 V
Bin. Bits: 11000000
Absolute Pres.: 2499.0 mbar
Absolute Pres.: 1356.6 mbar
Monday
2​
August
2021​
10:57:51:25558-VCID:78F9AE3F0BB09D4BFB-802CVCDS Version: Release 21.3.0 (x64)
Group A:'011
22.97​
2100​
683.4​
1030.2​
70.9​
71.1​
2100​
2499​
1081.2​
75.3​
74.5​
2163​
0​
1091.4​
70.9​
203.04​
2100​
2499​
1203.6​
75.7​
204.63​
2121​
0​
1050.6​
70.9​
220.28​
2100​
1377​
1050.6​
73.3​
220.45​
2163​
1377​
1060.8​
72.1​
334.23​
2142​
2499​
1009.8​
70.9​
351.14​
2100​
2499​
1315.8​
75.7​
351.32​
2100​
2499​
1315.8​
75.7​
351.5​
2100​
2499​
1326​
75.7​
351.67​
2100​
2499​
1326​
75.7​
351.85​
2100​
2499​
1326​
74.9​
352.03​
2100​
2499​
1336.2​
75.3​
352.2​
2121​
2499​
1336.2​
75.3​
352.38​
2121​
2499​
1336.2​
75.7​
352.56​
2121​
2499​
1336.2​
75.7​
352.75​
2121​
2499​
1346.4​
75.7​
352.92​
2121​
2499​
1346.4​
75.7​
353.1​
2121​
2499​
1346.4​
75.3​
353.28​
2142​
2499​
1356.6​
75.3​
353.44​
2142​
2499​
1356.6​
75.3​
353.63​
2142​
2499​
1366.8​
74.9​
353.8​
2142​
2499​
1366.8​
75.3​
353.97​
2142​
0​
1366.8​
6.8​
354.16​
2121​
0​
1356.6​
6.8​
354.33​
2142​
0​
1326​
6.8​
354.51​
2142​
0​
1285.2​
6.8​
354.72​
2163​
0​
1254.6​
6.8​
354.91​
2142​
0​
1234.2​
6.8​
355.08​
2142​
0​
1224​
6.8​
355.27​
2142​
0​
1203.6​
6.8​
355.45​
2142​
183.6​
1203.6​
6.8​
355.62​
2142​
612​
1193.4​
6.8​
355.82​
2142​
938.4​
1193.4​
6.8​
355.99​
2142​
1111.8​
1183.2​
6.8​
356.16​
2142​
1264.8​
1183.2​
6.8​
356.35​
2142​
1366.8​
1183.2​
6.8​
356.52​
2142​
1438.2​
1183.2​
6.8​
356.7​
2142​
1479​
1183.2​
6.8​
356.88​
2142​
1519.8​
1183.2​
6.8​
357.05​
2121​
1550.4​
1183.2​
6.8​
357.24​
2121​
1560.6​
1183.2​
6.8​
357.43​
2121​
1581​
1173​
6.8​
357.6​
2121​
1591.2​
1173​
6.8​
357.77​
2121​
1591.2​
1173​
6.8​
357.96​
2121​
1601.4​
1173​
6.8​
358.13​
2121​
1601.4​
1173​
6.8​
358.83​
2100​
2499​
1071​
6.8​
359.03​
2142​
2499​
1050.6​
6.8​
Readiness: 0 0 1 0 1
Actual clearly doesn't rise to meet specified. Actual is topping out under 1350 when specified is at 2499, which confirms what the freeze-frame data for the fault code showed. Since you've already checked pretty much all the mechanical stuff (plumbing and turbo actuator), my next suggestion would be to hook up a mechanical pressure gauge and use it to verify that manifold pressure is indeed as low as the ECU is seeing it.
VAGMAN
C?ID=374246
Hi Uwe, Thanks for the feedback, I've got a pressure gauge however, where would I need to hook this up to in order to get the reading?
sorry for asking details but my knowledge is limited.
TIA
Somewhere on the intake manifold, or to the plumbing just before, but definitely on the pressure side of the turbo.
VAGMAN
C?ID=374246
Thank you, I’ll give it a go and see what I get.
