Help please !! new tow bar electrics fault codes???
sainzy70
Peebles, Scotland
C?ID=362860
Saturday,31,July,2021,12:14:46:26536
VIN:    License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 18 19 25 2E 42 44 46 4C 52 53 56 61 62
          69 72
VIN:   Mileage: 74460km-46267miles
69-Trailer -- Status: Not registered 0001
   Part No SW: 03L 906 018 HH    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H28 9980
   Revision: 44H28---    Serial number:
   Coding: 0019001A040501080000
   Shop #: WSC 00706 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HH 003015
   ROD: EV_ECM20TDI01103L906018H_VW36.rod
   VCID: 77ABEAC3FF4B3E33BE9-8022
4891 - EGR Valve (N18)
          P0403 00 [096] - Malfunction
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 P    HW: 7N0 614 109 P
   Component: J104   C3 450M VD38 0030
   Revision: --H07---    Serial number: 00000007425456
   Coding: 0019991
   Shop #: WSC 00020 790 00000
   VCID: 3A2D33F78059E35B817-806E
02214 - Tire Pressure Warning
                    Fault Frequency: 200
                    Reset counter: 91
                    Mileage: 68157 km
                    Date: 2015.08.07
                    Time: 18:29:09
                    Speed: 74.0 km/h
                    Hex Value: 0x0100
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.75 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
                    Reset counter: 83
                    Mileage: 72423 km
                    Date: 2015.11.18
                    Time: 00:03:10
                    Hex Value: 0x0000
                    Voltage: 11.50 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 7N0 907 044 K    HW: 7N0 907 044 K
   Component: Clima-Sharan  H01 0303
   Revision: 00001K01
   Coding: 021000C449
   Shop #: WSC 00020 999 00000
   VCID: 382929FFB2D5F14B773-806C
          B10AB F0 [009] - Too Low
                    Reset counter: 184
                    Mileage: 59413 km
                    Date: 2020.02.01
                    Time: 11:49:00
   Part No SW: 5K0 937 084 K    HW: 5K0 937 084 K
   Component: BCM PQ35 B    122 0173
   Revision: BA122001
   Coding: 40180A3B8125F1C0408000C01000006443811308424D29226480872000C1
   VCID: 3A2D33F78C59E35B817-806E
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    130814  31  0032
   Serial number:         130821171527
   Coding: 004DBD
   Component: RLFS  024 0042
   Serial number: Y13M10D05H16M57S12S1
   Coding: 4208BB
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
   Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
   Component: VW10Airbag00M H12 0014
   Serial number: 003LGPLCTG8M
   Coding: 00304D
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3FDB42E397FBC673B69-806A
   Serial number: 3493ETS609580C5189D.
   Serial number: 3503ETS60BF05BD189D2
   Serial number: 3513ETS60199DC518DD1
   Serial number: 3523ETS6030E19B189DU
   Serial number: 35540TS609317C518DDN
   Part No SW: 5K0 953 521 BJ    HW: 5K0 953 569 C
   Revision: FF010042    Serial number: 20130927100342
   Coding: 5080040000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 75B7E0CBE5474C23AC5-8020
   Part No SW: 7N0 920 960 J    HW: 7N0 920 960 J
   Component: KOMBI         H04 0809
   Coding: 440F01
   VCID: 392F2CFB89DFE84388D-806C
   Part No: 7N0 963 271 E
   Component: Zuheizer        051 2940
   Revision: 00051000    Serial number: 09024297000000
   Coding: 0000041
   VCID: 363527C7B441073B65F-8062
   Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1642
   Revision:   H58       Serial number: 021013F1001572
   Coding: 468003
   VCID: 7AADF3F7CCD9235BC17-802E
                    Mileage: 73905 km
                    Date: 2015.12.09
                    Time: 00:02:05
   Component: IMMO          H04 0809
   VCID: 6A8DC3B7BCF993DB317-803E
   Revision: A1001003    Serial number: 7665347262
   Coding: 010100
   VCID: 2B0306B373034AD30A1-807E
   Part No SW: 7N0 959 793 F    HW: 7N0 959 793 F
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000072171072
   Coding: 011006208001411011
   VCID: 45D7500BF5A79CA3FC5-8010
   Part No: 7N0 909 144 R
   Component: EPS_ZFLS Kl. 272    3501
   Revision: 00H21000
   VCID: 42DD4B17E889AB9BD97-8016
   Part No SW: 7N0 959 792 F    HW: 7N0 959 792 F
   Component: TSG BF        H03 0553
   Revision:             Serial number: 0000073358039
   Coding: 011004208001411011
   VCID: 44D14D0FFE9DA5ABEBB-8010
   Revision:   H19       Serial number: 00000001462601
   Coding: 0024167
   Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
   Component: Radio RCD310  004 0119
   Revision: 01000001    Serial number: VWZ1Z2N1894336
   Coding: 0100040004000D
   VCID: 353720CBA5470C236C5-8060
   Component: Batt.regelung H58 1642
   Coding: 030F7859
   VCID: 71BFD4DB91AF600370D-8024
   Component: J367-BDM  H07 0180
   Serial number: 30276053041491180686
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 G    HW: 7N0 959 794 G
   Component: TSG HL        H04 0553
   Revision:             Serial number: 0000075977357
   Coding: 010004200001411001
   VCID: 47CB5A03CFAB8EB30E9-8012
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 303911DF5A25290B3F3-8064
   Component: TSG HR        H04 0553
   Revision:             Serial number: 0000075983113
End----------(Elapsed Time: 01:37, VBatt start/end: 12.3V/12.3V)-----------
Color me confused. I see no faults here that look to be related to the towbar... :confused:
chillout1983
C?ID=162783
I am no means any expert but does not registered in the can gateway for module 69 mean you haven't added it on the install list , I suppose this is maybe a question or an answer
It does. I missed that looking at the fault codes in the body of the scan. :facepalm:
chillout1983
C?ID=162783
Go into the can gateway and tick module 69 in the installation list and confirm then clear the codes.
sainzy70
Peebles, Scotland
C?ID=362860
Done. Will give it a run a see what happens.
The fault below is worrying. Any ideas?
Intermittent - Not Confirmed - Tested Since Memory Clear?
chillout1983
C?ID=162783
Hi I think I got the same fault when I did an oil change i disconnected the solenoid to make access to the oil filter easier so if you just did an oil change its possible
No, not really. It is flagged "Intermittent - Not Confirmed" and has not been reported to the Gateway, as evidenced by "01-Engine -- Status: OK 0000".
I would not sweat that unless things escalate.
sainzy70
Peebles, Scotland
C?ID=362860
Thanks. I'll run this week and then scan again.
