Hi,
I had been working on a 2012 Amarok today. I have gone out to the vehicle to supply and code an additional key. Nothing out of the ordinary programmed key directly with Abrites.
I did a VCDS scan while onsite as the customer did mention he had some trouble starting his vehicle recently. An unusual fault popped up under instruments that there was no .ROD file found.
Both new and original keys work perfectly however as you can see in the autoscan the ASAM fault in address 17
VCDS advised to upload a full autoscan when encountering this issue.
I scanned the car on the latest stable SW 21.3.0 and also the Beta SW 21.7.1
The owner is not the original owner of the vehicle and does not know if anything had been replaced previously.
Just looking for some general insight and any useful imformation about the error would be greatly appreciated.
Regards,
Ray
Regards,
Ray
Saturday,31,July,2021,08:47:18:50366
VCDS Version: 21.7.1.0 (x64) HEX-V2 CB: 0.4551.4
Data version: 20210706 DS329.0
VIN: WV1ZZZ2HZCA069312 License Plate: AMAROK LACHLAN AUTOSCAN
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 10 15 17 19 22 25 2E 32 56 69 77
01-Engine -- Status: Not registered 0001
Address 01: Engine (J623-CDCA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FA HW: 03L 907 309 K
Component: R4 2.0l BTD H43 9978
Revision: 26H43--- Serial number: 00000000000000 CVN: F54954FE
Coding: 01194012232600080000
Shop #: WSC 12739 002 1048576
ASAM Dataset: EV_ECM20BTD01103L906019FA 004006
ROD: EV_ECM20BTD01103L906019FA_004.rod
VCID: 6FBB2FDA27114793761-803A
VINID: 9E606AAAA098A934401890C108E256DC73
Readiness: 1010 0000
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 G HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0106
Revision: 00H44001
Coding: C07324B6919A039E24A589A4AF5210
Shop #: WSC 07456 790 49164
VCID: 3431E0B60E37244B4B3-8060
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 2H0 907 040 C HW: 2H0 907 040 C
Component: ClimatronicT5 H18 0404
Revision: 00001002
Coding: 0000000002
Shop #: WSC 07456 000 09999
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 211F19E2A145A1E3B05-8074
9473393 - Motor for Right Temperature Flap
B108D 71 [008] - Actuator Stuck
Reset counter: 97
Mileage: 223293 km
Date: 2104.14.01
Time: 08:29:56
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 K HW: 6R7 937 087 K
Component: PQ25 BCM H27 0532
Revision: -1------ Serial number: 1009009900
Coding: 3C0002380C41040092380810244B84D50080410E60000000300000000000
Shop #: WSC 00137 211 56823
VCID: 4CC1985676C75C8B333-8018
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3321
Coding: 110000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3321
Coding: 110000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 001 001 0103
Subsystem 4 - Part No: 1K8 951 171 A
Subsystem 5 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Serial number: 0025597
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3321
Coding: 100000
Subsystem 7 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3321
Coding: 100000
Reset counter: 57
Mileage: 223293 km
Date: 2040.14.01
Time: 08:29:55
Reset counter: 57
Mileage: 223293 km
Date: 2040.14.01
Time: 08:29:55
Reset counter: 57
Mileage: 223293 km
Date: 2040.14.01
Time: 08:29:55
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 D HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361205801107
Coding: 108003
ASAM Dataset: EV_VW75XParkAssis4K A01006
ROD: EV_VW75XParkAssis4K_A01.rod
VCID: 3333E3AA0BB92373529-8066
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00H H07 0013
Revision: -------- Serial number: 003HN00785DX
Coding: 000000000000000000000000000000003048
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
Serial number: 3495RRB404T0VC0KCPFN
Serial number: 3505RRB406514E7CI16R
Serial number: 3555YRB405F15A9MC86F
Serial number: 3565YRB405T15A9MG0DX
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 2H0 920 863 B HW: 2H0 920 863 B
Component: KOMBI H02 0505
Coding: 150A00
ASAM Dataset: EV_Kombi_cÿ_VDD_RM09 A04114
ROD: N/A
VCID: 280904C6C27F50ABF7B-807C
No ASAM data for: "EV_Kombi_cÿ_VDD_RM09" (VW36 *)
Part No SW: 6N0 909 901 HW: 6R7 937 087 K
Component: GW-K-CAN TP20 H27 0532
Revision: -1------
Coding: 742300
Shop #: WSC 07462 790 50316
VCID: 70B92CA63AAF586B6FB-8024
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 B HW: 2H0 927 755 B
Component: SG offroad VTG 0153
Revision: 00H06000 Serial number: T1IYC36211ROWQ
Coding: 0000013
VCID: 2F3BEFDAEB110793361-807A
Component: IMMO H02 0505
VCID: 6A8D3ECE1CF3A2BB21F-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660497758
VCID: 290F01C2D9F569A3E85-807C
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 57
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 A HW: 2H0 927 771
Component: Quersperre H04 0017
Revision: 11001001 Serial number: 4DG 27.02.12 00
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2C01F8D6D6877C8B133-8078
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: MIB2-S-R-CN 036 0317
Revision: -----001 Serial number: VWZ6Z2T0024014
Coding: 16000440020009
Shop #: WSC 00079 790 00000
VCID: 46D5AA7E68ABA6DBE57-8012
10 Faults Found:
00875 - Treble Speaker Front Right (R22)
Reset counter: 57
Mileage: 27780 km
Date: 2017.14.03
Time: 01:06:07
Reset counter: 57
Mileage: 27780 km
Date: 2017.14.03
Time: 01:06:07
00625 - Vehicle Speed Signal
Reset counter: 97
Mileage: 27780 km
Date: 2017.14.03
Time: 01:06:03
00881 - Connection to Speaker Rear Right
Fault Status: 00101100
Reset counter: 18
Mileage: 27780 km
Date: 2017.14.03
Time: 01:06:01
Reset counter: 221
Mileage: 27780 km
Date: 2017.14.03
Time: 01:06:01
00856 - Radio Antenna
Reset counter: 0
Fault Status: 00101011
Reset counter: 6
Reset counter: 6
00871 - Bass Speaker Front Right (R23)
Reset counter: 18
Reset counter: 18
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000531639257
Coding: 0100000100000000
VCID: 3039ECA6FA2F186B2FB-8064
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662205273
Coding: 0A00010000010101
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270B07FACF615FD3FE1-8072
B104F 13 [009] - Short to GND
Reset counter: 57
Mileage: 223293 km
Date: 2104.14.01
Time: 08:29:56
B104E 13 [009] - Short to GND
Reset counter: 57
Mileage: 223293 km
Date: 2104.14.01
Time: 08:29:56
End----(Elapsed Time: 01:07, VBatt start/end: 11.3V/11.5V. VIgn 11.6V)-----
