Audi Q7 engine running.
Dp41n8w
Finland
C?ID=372411
Hi. Audi Q7 is there any coding to get engine running all the time? If you leave the car then it will few min run but then it shuts down. Or if you lock the car from outside then it will be suht down after few minutes.
thanks.
Latest autoscan ATM:
Monday,14,December,2020,19:53:45:19148
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN:    License Plate:
Mileage: 78302km-48654mi   Repair Order: Q7
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 18 19 23 29 36 39 3C 42 44 46
          47 51 52 5F 69 6C 6D 74 81 82 84 8B 8C A5 AC BA BB BC C5 C6
          CA CF D6 D7
VIN: WAUZZZ4M3GD045142   Mileage: 78302km-48654miles
74-Chassis Control -- Status: Malfunction 0010
84-Night Vision -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CVZA)       Labels: Redir Fail!
   Part No SW: 4M0 907 401 A    HW: 059 907 309 F
   Component: 3.0TDI MD1    H21 0006
   Revision: C7H21---
   Coding: 2A2A403A057E050335382B00000000000000000000000000
   Shop #: WSC 52749 002 1048576
   ASAM Dataset: EV_ECM30TDI0114M0907401A 001014
   ROD: EV_ECM30TDI0114M0907401A.rod
   VCID: 270BFB8BBF69B8F3128-8072
   Active accelerator pedal:
   Subsystem 1 - Part No SW: 4M1 723 523     HW: 4M1 723 523
   Component: J1115 - FFP  H16 0007
   Serial number: 123456789ABCDEFGHIJK
   Clutch position electronics:
   Subsystem 2 - Part No SW: 0D7 142 057 D    HW: 0D7 142 057 D
   Component: J1128 CCU  H03 0022
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4M0 927 158 M    HW: 0D7 927 156 B
   Component: AH28N30TDIRdW H03 1006
   Revision: --H03---
   Coding: 100000
   Shop #: WSC 51003 001 1048576
   ASAM Dataset: EV_TCMALX52011 002011
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 3E253EEF40F3193B41E-806A
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 A    HW: 0D7 321 281
   Component:     V552 ATFP  D.4 0000
   Serial number:             00000000
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 P    HW: 4M0 907 379 P
   Component: ESP9 Premium  H09 0649
   Coding: 2C9830B232A60A9BD19F1895187F52AEF6A6DA340C4C508B18184A756F655B
   Shop #: WSC 52744 002 1048576
   ASAM Dataset: EV_ESP9BOSCHAU536P 011013
   ROD: EV_ESP9BOSCHAU536P_AU73.rod
   VCID: 44D14C072E1F73EB17A-8010
   Part No SW: 4M0 959 760 B    HW: 4M0 959 760 B
   Component: MEM-BFS       008 0015
   Serial number: 00000182264989
   Coding: 00183B000001B2A10060210101010000110000171700171700000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 372B2BCB6FC92873828-8062
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4M0 907 182     HW: 4M0 907 182
   Component: N477 VB1 BFSv  H06 0030
   Serial number: SJ800118121501100084
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4M0 907 182 A    HW: 4M0 907 182 A
   Component: N478 VB2 BFSv  H06 0030
   Serial number: SJ80010112150110000F
   Part No SW: 4M0 820 043 AE    HW: 4M0 820 043 AE
   Component: Klima Zone 3  H52 0085
   Coding: 661A48084548410D022C0280820000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 6889B8B772F7778BDB2-803C
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000721373
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 94480B08000000000001
   Rear A/C control head:
   Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
   Component: Klima Heck  H34 0073
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Coding: 07501943C12900CD4103571958BF8CF9130331019000000000000000E00016810A4502AB32B71A
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 005980177A87AFCB732-8054
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 151031  043 0893
   Serial number: 895553?0401530401106
   Coding: 1BC7F7
   Serial number: 61169845
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4M0 941 531 AD    HW: 4M0 941 531 AD
   Component: E1 - LDS  H06 0008
   Serial number: 23 12 2015  00190059
   Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
   Component: Y7_Innenspieg  H08 0002
   Serial number: GX1CE104011611520892
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 AE    HW: 4M0 947 135
   Component: J528-Dachele  H13 0082
   Serial number: Q00083897
   Subsystem 6 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
   Component: J866-EVLS-SG  H03 0060
   Serial number: WA122228000016885366
   Coding: 020100
   Subsystem 7 - Part No SW: 4M0 925 301 H    HW: 4M0 925 301 H
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000001430
   Subsystem 8 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14CF35600550
   Subsystem 9 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14CF32500834
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14CF35600544
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14CF32500822
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H10 0220
   Coding: 5477FFFB58FFEC0A949C80E4
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 323D1ADF84ABCD5BB56-8066
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H50 0088
   Serial number: 003L1001E7AE
   Coding: AAFCF0C00CA0000098F600F3C04C00000000
   Shop #: WSC 12300 205 00000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 78A9E8F72257E70B4B2-802C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705D0018Q00780
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706J0014Q00999
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 061 512 15
   Serial number: 3577Y00C71A82882E504
   Subsystem 4 - Part No SW: -----------    HW: 442 061 512 15
   Serial number: 3587Y00C91A828848211
   Subsystem 5 - Part No SW: -----------    HW: 442 0B0 601 16
   Serial number: 3517700B71E673E3C46P
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 601 16
   Serial number: 3527700BF1E4DF24313O
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 612 15
   Serial number: 3557500BF1E9F115529R
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 612 15
   Serial number: 35675009B1D690F2A15M
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 001 16
   Serial number: 2307500C11E2F84692FK
   Subsystem 10 - Part No SW: -----------    HW: 442 422 102 18
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00BF2711E44D1DZ
   Subsystem 11 - Part No SW: -----------    HW: 442 422 102 18
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00C12711E41E1CK
   Central crash sensor X/Y:
   Subsystem 12 - Part No SW: -----------    HW: 410 201 112 15
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800C31DD0CA2210/
   Part No SW: 4M0 907 129 JE    HW: 4M0 907 129 JE
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7CA1F4E7166FCB2B2FA-8028
   Part No SW: 4M0 920 794 B    HW: 4M0 920 794 B
   Component: FHybRDW       H17 0310
   Coding: 040401C07C98000800A669703204600000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU73.rod
16777046 - Charger for HV Battery
          U1139 00 [008] - No Communications
          [BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
                    Reset counter: 89
                    Mileage: 77925 km
                    Date: 2020.12.12
                    Time: 11:42:59
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
   Component: HSG           H09 0060
   Coding: 0D0803
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
   ROD: EV_AuxilParkHeateEBEAU736_AU49.rod
   VCID: 290FFDB3A97D8E8304C-807C
   Part No SW: 8W7 907 468 B    HW: 8W7 907 468
   Component: Gateway       H11 0087
   Revision: 3M130038    Serial number: 3883M004815C08
   Coding: 0201010100020EC08C82010000590032DCD20007180000000175079E00000000
   ASAM Dataset: EV_CGateCONTIAU491 002027
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4ACD623F0C3BA59BED6-801E
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20151228065836 00780
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 1609388803
   Part No SW: 4M0 909 059 C    HW: 4M0 909 059
   Component: J539 EBKV H11 0194
   Serial number:   085430010194
   ASAM Dataset: EV_BrakeBoostBOSCHAU736 001001
   ROD: EV_BrakeBoostBOSCHAU736_AU73.rod
   VCID: 34311CC77EBFC36BA7A-8060
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 4M0 909 057 A    HW: 4M0 909 057
   Component: VX70BrakeAssi  H04 0153
   Serial number: 05802861301115020338
   Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
   Component: LCM_MLBevoH05 0023
   VCID: 79AFEDF3195DFE0334C-802C
   Component: MEM-FS        008 0015
   Serial number: 00000182264987
   Coding: 00183B000001B2A10000210101010000110000171700171700000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H06 0030
   Serial number: SJ8001171215011000EC
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H06 0030
   Serial number: SJ80010112150110000E
9658370 - Motor for Seat Depth Adjustment
          B153C 54 [041] - Missing Calibration / Basic Setting
                    Mileage: 77761 km
                    Date: 2020.12.11
                    Time: 16:33:05
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
   Component: TSG FS        009 0055
   Serial number: 0000181422206
   Coding: 005D9B015E000082000930B0
   VCID: 40D940173A076FCB332-8014
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H19 0004
   Serial number: 0000425803
   Coding: B0150101010001
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 33331FDB7BB1C453BE0-8066
   Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   016 0344
   Coding: 01741E00000000E06309A0006E00580203004000004F02502F0400000504803F001F0001000000
   Shop #: WSC 11400 205 00000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   Subsystem 1 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94048722
   Part No SW: 4M0 035 466 A    HW: 4M1 035 466
   Component: 8RF           H10 0586
   Serial number: 2530163481
   Coding: 0135960B00A2AAAAAAAAAA010001
   ASAM Dataset: EV_AMPMst24C1Gen2BAO 001002
   ROD: EV_AMPMst24C1Gen2BAO_AU73.rod
   VCID: 2A0D02BFAC7B859B0D6-807E
6693 - Databus
          [Functional restriction due to missing message]
                    Reset counter: 91
                    Mileage: 78210 km
                    Date: 2020.12.14
                    Time: 08:56:34
                    Voltage terminal 30: 14.9 V
   Part No SW: 4M1 907 080 A    HW: 4M1 907 080 A
   Component: A73P7827S1000 H03 0018
   Revision: --H03---
   Coding: 01000000000000000000
   ASAM Dataset: EV_DMCM08530214M1907080A 001011
   ROD: EV_DMCM08530214M2907080.rod
   VCID: 2B0307BBA3819C93F60-807E
   Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
   Component: TSG BFS       009 0055
   Serial number: 0000182924101
   VCID: 3FDB43EB47F910334A8-806A
   Part No SW: 4M0 035 035 Q    HW: 4M0 035 035 A
   Component: MU-P-LND-EU   051 0442
   Serial number: A649A0GB005558
   Coding: 013796010000000053111102000A00332F001DE5017001009E
   Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
   Component: ECE 2016  --- 0134
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ401EU7
   Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0165
   Serial number: 13011600000000000145
   Compact disc data bank:
   Component: Gracenote2  --- 1011
3086 - Antenna for Telephone Mount
          B1564 01 [008] - Electrical Failure
                    Reset counter: 96
                    Mileage: 78202 km
                    Date: 2020.12.14
                    Time: 07:39:56
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): selected
                    Status of telephone-Handset holder (cradle): connected
7205 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Battery management (0x25) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 89
                    Mileage: 77925 km
                    Date: 2020.12.12
                    Time: 11:42:59
                    BAP-BAP_Function_ID: 02
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 95
                    Mileage: 77786 km
                    Date: 2020.12.12
                    Time: 09:37:32
                    BAP-BAP_Function_ID: 16
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0214
   Revision: 9A001003    Serial number: 0391247615
   Coding: 0110000202010000
   Bend angle sensor for trailer:
   Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
   Component: G820 KNWINSEN  H18 0019
   Serial number: 16510
656394 - Bulb for Left Tail Light on Trailer
          C10F5 15 [008] - Open or Short to Plus
                    Reset counter: 91
                    Mileage: 78210 km
                    Date: 2020.12.14
                    Time: 08:50:51
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [008] - Open or Short to Plus
                    Reset counter: 91
                    Mileage: 78210 km
                    Date: 2020.12.14
                    Time: 08:50:51
   Part No SW: 4M0 907 428 D    HW: 4M0 907 428
   Component: Areaview 2    H11 0311
   Serial number: C854606JG002802
   Coding: 02350601BF0FA10008404500
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 4M0 959 107 A    HW: 4M0 959 107
   Component: HDSG-Modul    H12 0155
   Revision: --------    Serial number: 30447401800000
   Coding: 00F0
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_AU73.rod
   VCID: 313F15D381ADF643CCC-8064
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 E    HW: 4M0 907 777 E
   Component: Fahrwerk-SG   H10 0104
   Serial number: 0501160009
   Coding: 98586880F8
   ASAM Dataset: EV_ChassContrContiAU736 002013
   ROD: EV_ChassContrContiAU736.rod
   VCID: 3B2337FB53E10C13660-806E
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
   Component: V66LFKompOLV  H06 0012
   Serial number: 00000000004130035417
   Coding: 303030
3178507 - Compressor for Suspension Level Control
          C118D 07 [008] - Mechanical Failure
                    Reset counter: 81
                    Mileage: 77762 km
                    Date: 2020.12.11
                    Time: 17:59:24
   Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20151117001303
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2615F68FB863A1FB29E-8072
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4M0 919 617     HW: 4M0 919 617
   Component: HeadUpDisplay H26 1524
   Coding: 5F00C0
   ASAM Dataset: EV_HudNSEIKAU736 001012
   ROD: EV_HudNSEIKAU736_AU73.rod
   VCID: 72BDDADF442B8D5B756-8026
Address 84: Night Vision (J853)       Labels:* Redir Fail!
   Part No SW: 4M0 907 547 A    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H08 0025
   Serial number: 629228400201602
   Coding: 200111
   ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
   ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Serial number: 623466500F1535200245
16389 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 89
                    Mileage: 78169 km
                    Date: 2020.12.13
                    Time: 15:35:15
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 303910D78AA7FF4BC32-8064
   Part No SW: 4M0 915 233 E    HW: 4M0 915 233 E
   Component: BMC_PHEV_PL73 H07 0195
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU49.rod
   VCID: 2D0709A39D9592A3E84-8078
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4M0 915 253 E    HW: 4M0 915 253 C
   Component: J990  H16 0200
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J991  H07 0105
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J992  H07 0105
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J993  H07 0105
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J994  H07 0105
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J995  H07 0105
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J996  H07 0105
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J997  H07 0105
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J998  H07 0105
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J999  H07 0105
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1000  H07 0105
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1001  H07 0105
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1002  H07 0105
   Cell module control module 13:
   Subsystem 14 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1045  H07 0105
   Cell module control module 14:
   Subsystem 15 - Part No SW: 4M0 915 115 A    HW: 4M0 915 115 A
   Component: J1046  H07 0105
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H12 0042
   Coding: 040703060000040202202397CD0000B4B0F0C020F280
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 2F3B13AB9799E0B3DA8-807A
1123600 - predictive route data
                    Reset counter: 89
                    Mileage: 78169 km
                    Date: 2020.12.13
                    Time: 15:35:16
                    Control Module temperature: 8 °C
                    Voltage terminal 15: 14.70 V
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736_AU49.rod
   VCID: 6E85CEAF5013A9BB91E-803A
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 D    HW: 4M0 907 145 B
   Component: AEMevo        H09 0111
   ASAM Dataset: EV_AEMZFAU736 006012
   ROD: EV_AEMZFAU736_006.rod
   Part No SW: 4M0 959 795 E    HW: 4M0 959 795 C
   Component: TSG HFS       009 0055
   Serial number: 0000181142198
   Coding: 004D990000000082000830A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 42DD4A1F340B7DDB256-8016
   Component: TSG HBFS      009 0055
   Serial number: 0000181142277
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4M0 965 429 D    HW: 4M0 965 429 B
   Component: TME-Max       H04 0021
   Serial number: 0015945
   Coding: 01
   ASAM Dataset: EV_ThermContrVISAU49X 001023
   ROD: EV_ThermContrVISAU49X_VW37.rod
   VCID: 382928F762D7270B8B2-806C
   Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G395 pT-Sens1  H61 0006
   Subsystem 2 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
   Component: J848 HV-PTC  H09 0206
   Serial number: LM153423003807000453
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4M0 816 797 A    HW: 4M0 816 797 A
   Component: J842 EKK es33  H02 0012
   Serial number: 00000000015101500365
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G826 pT-Sens2  H61 0006
   A/C pressure/coolant temperature sensor 3:
   Subsystem 5 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G827 pT-Sens3  H61 0006
   Expansion valve 1 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N636 EV1_KaMi  H10 0102
   Serial number: 00000000000150079135
   Shut-off valve 2 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H10 0102
   Serial number: 00000000000130083942
   Shut-off valve 3 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H10 0102
   Serial number: 00000000000130084106
   Shut-off valve 4 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H10 0102
   Serial number: 00000000000130083958
   Shut-off valve 5 for refrigerant:
   Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H10 0102
   Serial number: 00000000000130083957
60016 - Interior Pre-Conditioning
          P13F1 00 [047] - Not Started
                    Fault Frequency: 8
                    Mileage: 77771 km
                    Date: 2020.12.11
                    Time: 18:20:15
                    Expanded ambient data 1-Voltage terminal 30: 0.000 V
                    Expanded ambient data 1-Vehicle speed: 28 km/h
                    Expanded ambient data 1-System status: Drive readiness
                    Expanded ambient data 1-Power quota setting by energy management: 15
                    Expanded ambient data 1-Status of drive readiness hybrid: Hybrid driving
                    Expanded ambient data 1-Ambient temperature: -1.00 °C
                    Expanded ambient data 1-current state of low temp.circ.: 00
                    Expanded ambient data 1-previous state low-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
                    Expanded ambient data 1-current state of high-temp.circ.: 00
                    Expanded ambient data 1-previous state of high-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
                    Expanded ambient data 1-current state of battery low temp.circ.: 05
                    Expanded ambient data 1-previous state of battery low temp.circ.: 07
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 3A
                    Expanded ambient data 1-current state of battery cold circuit: 02
                    Expanded ambient data 1-previous state of battery cold circuit: 02
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: 3B
Address C6: Batt. Chrg. (AX4)       Labels:* 5QE-915-681.clb
   Part No SW: 5QE 915 681 G    HW: 5QE 915 681 G
   Component: OBC Delta-ES  H55 0721
   Coding: 11508B207004
   Shop #: WSC 02152 823 28888
   ASAM Dataset: EV_OBCTwoPhaseDT2AU736 006011
   ROD: EV_OBCTwoPhaseDT2AU736.rod
   VCID: 50F97057EA679F4BA32-8004
2097152 - Battery Management
          P33EB 00 [008] - Read Event Memory
                    Reset counter: 90
                    Mileage: 78195 km
                    Date: 2020.12.14
                    Time: 07:10:41
12583681 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BapErr_RetryNotSuccessful]
                    Reset counter: 90
                    Mileage: 78195 km
                    Date: 2020.12.14
                    Time: 07:00:03
13705502 - Databus
          [Einheiten_01_TimeOut]
                    Reset counter: 95
                    Mileage: 78273 km
                    Date: 2020.12.14
                    Time: 14:45:09
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 608000053602
   VCID: 73B3DFDB3B3184537E0-8026
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
   Component: LED1L         H10 2003
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 1A6DD27FFC1B151B9D6-804E
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H10 2003
End----------(Elapsed Time: 03:31, VBatt start/end: 12.9V/12.9V)-----------
siLc
Tallinn, Estonia
C?ID=330192
Normal start-stop behaviour? Try disabling SS from the dash button and see if anything changes.
Dp41n8w
Finland
C?ID=372411
If engine is running on hybrid mode then it will shut down few minute after you leave the car. Id like to change that.
NEtech
Denmark
C?ID=56995
I guess a security access is needed, but you can try without.
And test Coding in [46], change Byte 26 from 00 to 02
Dp41n8w
Finland
C?ID=372411
Greate now its working. Thanks. But i have enabled also 46> long coding byte 9 bit 7 to engine run when its locked. But now it shuts down immediatly in hybrid mode when i lock the car. Can that be disabled that i can also lock car when its running hybrid mode?
