- Aug 10, 2016
- 2,051
- 2,453
- Eindhoven, NB, NL
- C?ID=284912
no wonder today's youth is so stupid. they rely on google wikipedia and urban dictionary.
Maybe not stupid but careless - go to any subject on wikipedia that you have personal knowledge of and spot the glaring errors which when you correct them invariably get put wrong again!no wonder today's youth is so stupid. they rely on google wikipedia and urban dictionary.![]()
It is on the legend, but it saysThe A15 in a circle should be described in the legend on that page of the diagram.
Battery positive; i.e. '+' hence 'plus'. With reference to ground.I'm wondering what a plus connection is
Zenerdiode: without intending anything of a negative nature and with my full acknowledgement of your obvious expertise in matters electrical (which is abundantly clear from your previous writings ) - are your sure?Battery positive; i.e. '+' hence 'plus'. With reference to ground.
Jef excellently illustrates how it is physically constructed, they're then insulated and buried deep in the wiring harness.
What a f#^cking good question!!!!Also on page 15 of the PDF that goes with the two videos it shows an A15 in a circle. I'm wondering how this connection with the letter designation differs from the other connections (no letters) described as "weld connections"
Can someone enlighten me?
Me either, but ze Germans, vell, zey do vhat zey do.Having 2 different coloured wires on the same terminal doesn't sound like a good idea to me...
Are you sure you've the correct diagram for your particular car?I've looked at the fuse holder shown and the solid red wire is nowhere to be seen.
You should be able to click EDIT on your own post to see what I did to make that happen.cant for the life of me embed this image either![]()
I'm as sure as I can be!Are you sure you've the correct diagram for your particular car?
I know what you mean about the different model versions highlighted with an asterisk, but there aren't any for those wires. On the fuse assignment pages of the schematic for my car, there are a few which show the black/green and red wires onto the same fuse terminal. The full page below shows some marked with an asterisk but not the black/green and red wires.While not "normal", it is very possible to have 2 wires crimped into a single terminal. But I would find it odd if the wires were different colors.
Some other reasons it was drawn that way... it may be trying to show 2 different possibilities. In other words, if the car has the VR6T engine, then you would find the 2.5mm red wire. But if the car has the W8T engine, then a black/green wire is used. When something like that is done, there tends to be * or maybe # and footnotes about it.
* only with VR6T
# only with W8T
I've can't say I recall any cases of 2 different color type wires in a terminal, but have seen many cases of 2 wire colors shown as and depending on what car you are working with, one or the other, not both.
I think you were right first time with them being from different versions/options.
So I have found what looks to be the same thing in a different version of the wiring diagram, No. 3.
What I think is really going on... the wiring diagram is wrong. And with the way VW/Audi work, mistakes in the factory repair manual WILL NOT BE CORRECTED... EVER.
