HI jeff.
I have Elsawin, which i have slowly learnt, The only part that i cant understand is for some earth circuits it says for example 410. Earth connection 1 in main wiring harness, do you know how to find this earth location,, Where as you know most regular earths on the diagrams such as 605 tells you where it is located,, on top of end of steering column.
but where is the earth when for example it says earth connection 1.
Here pin 19 is number of pin. "31" is "label" or "meaning" what is this pin for.
Interesting, the talk about the 410 connection, and the sender earth from the instument cluster:
When I put the Gold R32 cluster, into the Touran, the outside temp sensor, fuel sender earths and coolant level sensor etc had NO earth - however, does the diagram above, mean that pins 19 AND 31 should be earthed? The Touran ONLY has an earth on pin 19, Does the Golf cluster require one on pin 31 too, and that would provide the earth to these sensors?
I currently have the sender earth connected to a chassis earth, to get these sensors working.
This is the ONLY time, I have seen this on a diagram... though I have found a couple of mistakes in the diagrams I'm using fo the R32 Touran conversion.
I must say, I've worked a LOT with Subaru diagrams too, and they make MUCH more sense to me!
it means "return to battery- or direct to ground"
I've probably spent 300 hours processing them [WD s]... some of them are memorized!
Nah.. DubNurd!
NZDubNurd: 300 hours??? Just remember that contrary to popular belief, the human brain DOES have a finite limit - I can attest to this having reached an advanced level of mental decrepitude, my self. From bitter experience, I can say with certainty that when the brain's memory capacity is reached, it's a LIFO process (Last-In-First-Out)
I only wish that someone had told me this fact when I was young, so I could make-sure that the "lower" memory address locations were filled with important information - as it was, my early interests were focused on useless stuff like girls and fast cars!
So my advice to you (pending the veracity of my assumption of you being "disgustingly young") is don't make the same mistake that I made - Fill those important lower memory address locations in your brain with data that will be useful when you reach my advanced years (hint: WD info isn't a contender)!
We use essential cookies to make this site work, and optional cookies to enhance your experience.
