ERROR - WSC, Importer, Equipment
diogolg
Macaé-RJ, Brazil
C?ID=430154
I'm trying to encode Central-09 from Tiguan Rline 2021, but when entering security code-16 and digital 31347, the error appears: This workshop identification:
WSC 00066 Importer 790 Equipment 00247 was rejected by the control module.
The command will likely fail.
Please change your values.
I've tried changing the values of SC, Importer and Equipment, but nothing worked.
Here are values that I tried.
WSC: 00066 Importer: 790 Equipment: 00247
WSC: 03743 Importer: 444 Equipment: 00001
WSC: 12345 Importer: 123 Equipment: 12345
This is only happening at central-09.
Does anyone have any idea how I solve this?
Friday,30,July,2021,15:32:04:64723
VIN: 3VVJ465N5MM128710
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 42 44 47 4B
          52 5F 65 6C 6D A5 BB BC CA D6 D7
VIN: 3VVJ465N5MM128710   Mileage: 293km-182miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXDA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5N0 906 259     HW: 06K 907 425 B
   Revision: --H13---
   Coding: 092500322466052B3000
   Shop #: WSC 00066 790 00454
   ASAM Dataset: EV_ECM20TFS0205N0906259 001004
   ROD: EV_ECM20TFS0205N0906259.rod
   VCID: 72BC25793420ECAB897-8026
Readiness: 1110 0001
   Part No SW: 0DL 300 013 G    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 2120
   Revision: 00H06V11
   VCID: 2E04F109E098884B2DF-807A
   Part No SW: 5Q0 614 517 GB    HW: 5Q0 614 517 BP
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 50931000000676
   Coding: 0BEE6B9A50221B74477E070162C349D0D60AD8E2E046927538425008522A4A0B00402F641A1B13111435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049.rod
   VCID: 77AA146D5F428983BE9-8022
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0570461792
   Coding: 132C2C0723
   Shop #: WSC 01383 790 50316
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D6AEA5552E2B13FC5-8010
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 25213483
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NN 907 044 AJ    HW: 5NN 907 044 AJ
   Component: AC Automat    H36 4901
   Revision: 20K04000    Serial number: 00000D00728839
   Coding: 00020024200104011105100000101432
   ASAM Dataset: EV_ACClimaPrehVW37X 002030
   VCID: 147043E16EF4429B3BB-8040
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 E    HW: 5Q0 907 659 E
   Component: G238 _AQS  H32 0120
   Serial number: 2621653543
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 084 DP    HW: 5Q0 937 084 DP
   Component: BCM MQBAB M+  H42 0411
   Serial number: 1099019402ÿÿÿÿ
   Shop #: WSC 00066 790 00247
   ASAM Dataset: EV_BCMMQB 021001
   ROD: EV_BCMBOSCH_021_VW26.rod
   VCID: 094E629539B68F73D8D-805C
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 210311  034 0373
   Serial number: 21031021030550
   Subsystem 2 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S6Y21M02D11H06M36S52
   Coding: 0008EE
   Subsystem 3 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL21074B16L
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000001556817
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 KF    HW: 5Q1 953 569 H
   Component: Lenks.Modul  H04 0190
   Serial number: 0300070420210C201339
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0073
   Serial number: 000460609421084
   Coding: 8271563851
   Shop #: WSC 00066 790 00193
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 58E877D1B29CA6FB973-800C
   Part No SW: 2Q0 907 572 T    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H04 0383
   Coding: 320007C358FF8728749C810530408700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   Part No SW: 5Q0 959 655 CG    HW: 5Q0 959 655 CG
   Component: AirbagVW21    008 0421
   Serial number: 003J9M00JTW4
   Coding: 88CCC000000000005C0000CF000800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 074A64AD2FA2F903CE9-8052
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1040
   Serial number: 5NB857705D0042V01051
   Coding: 80000D
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1040
   Serial number: 5NB857706D0035V00133
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 902 21
   Serial number: 35700000000EB229D25U
   Subsystem 4 - Part No SW: -----------    HW: 480 000 803 21
   Serial number: 35800000000FF651515Q
   Subsystem 5 - Part No SW: -----------    HW: 480 401 503 21
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A1016DC72836-
   Subsystem 6 - Part No SW: -----------    HW: 480 401 503 21
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001BB016DC71D268
   Subsystem 7 - Part No SW: -----------    HW: 480 402 602 21
   Component: FrontSensor_D  005 6149
   Serial number: 3550001C8C0CD4B9157M
   Part No SW: 3G0 920 320 B    HW: 3G0 920 320 B
   Component: KOMBI         502 5176
   Coding: 04A42098EE800008018862471001000080001106
   ASAM Dataset: EV_DashBoardVDDMQBA0 001045
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 1C602BC186240ADB73B-8048
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5423
   Serial number: 05052100840833
   Coding: 030500047F085900FB07225E1E0F00010001070000000000000000000000
   Shop #: WSC 00066 790 00272
   ROD: EV_GatewNF_VW37.rod
   VCID: 74B023614E34E29B9BB-8020
   Generator:
   Component: 4-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29210000296550061061
   Coding: 2CFFFF
   Serial number: 8689318100
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00011.01.21
   Coding: 0101
   VCID: 4CC09B817644DA5B23B-8018
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   Component: ELV-MQBB      H06 0020
   Serial number: 20000287075011
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3332E07D0BBAA5A3421-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 F    HW: 5Q0 959 760 F
   Component: Sitzmemory    H10 0026
   Serial number: Y0007UB837323
   Coding: 0010000000000500018480808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 40D8BFB14A0C0E3BCF3-8014
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Part No SW: 5Q4 959 593 N    HW: 5Q4 959 593 N
   Component: TSG FS        010 0820
   Serial number: 96028110300408
   Coding: 003F1A20D200048000001000
   VCID: 50F88FF19A6CFEBB5F3-8004
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000008437299
   Part No SW: 5QM 909 144 C    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1082
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 51FE8AF59166F7B350D-8004
   Part No SW: 3G0 035 466     HW: 3G0 035 466
   Component: AMPeth16C     H08 3030
   Serial number: A1130A00079022
   Coding: 24000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB 001005
   ROD: EV_AMPEthMQB_VW27.rod
   VCID: 629C5539E4C07C2BF97-8036
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 14052100842711
   Coding: 0000000509001DD200104F010A0000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372AD46D1FC249837E9-8062
   Part No SW: 5Q4 959 592 N    HW: 5Q4 959 592 N
   Component: TSG BFS       010 0820
   Serial number: 97028112000645
   Coding: 003F1020DE00048000001000
   VCID: 4FFA8C8D8752E143469-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000008435378
   Coding: 090000
   Part No SW: 3G5 035 832 C    HW: 3G5 035 832
   Component: MU-O-N-R2     H56 0782
   Serial number: WG8LGM310321000
   Coding: 23260000002000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001002
   ROD: EV_MUOIMQB_VW27.rod
   VCID: 270A042DCF62D903EE9-8072
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  261 8214
   Serial number: VWZ6ZMY1206671
   Subsystem 2 - Part No SW: V03 959 809 KJ    HW: -----------
   Component: MRM 2021       --- 4032
   Component: RDKBERU30     H06 0009
   Serial number: 30000000537507
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3430E3610EB4A29B5BB-8060
   Coding: 0123060122002017000040
   VCID: 392ED25529D65FF388D-806C
   Part No SW: 5Q0 959 107 AA    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0272
   Revision: --------    Serial number: A2-C773-9590-1
   Coding: 0A08
   Part No SW: 3Q0 980 654 S    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H14 0920
   Serial number: 15022112K13609
   Coding: 000307060102010100221344C146490084000E30014000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 47CAA4AD6F2239030E9-8012
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Coding: 60804073260C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B61E65454EFB93AC5-8020
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 00587FB10A8CCE3B8F3-8054
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----(Elapsed Time: 02:00, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Please explain exactly what you are trying to do.
This control module does not use Coding. The Coding string will always be:
Westbury, UK
As Uwe says this is a newer module that doesn't use coding, everything is done using Adaptation Channels so attempts at coding will produce an error.
diogolg
Macaé-RJ, Brazil
C?ID=430154
I understand, but I'm not able to exchange values through channels, see the example below:
I'm trying to change the comfort blinker from 3 to 5 times.
When entering the channel and entering the new value, the software returns this error:
Coding: Central - 09 Electric
16 – Security (31347)
10 - Adaptation
Select: Aussenlicht_bling (Komfortblinken Blinkzykien)
Current value: 3
Change to 5
diogolg
Macaé-RJ, Brazil
C?ID=430154
Below is an image of the error. It was in the channels through adaptation.
https://ibb.co/CPpqjkh
[Apply] won't work for those. You must [Save], then exit and restart VCDS before the values entered there will be used.
diogolg
Macaé-RJ, Brazil
C?ID=430154
I also tried this way, however, when I click on save and exit the Software, it doesn't let me change the field values anymore. And these values that I put did not work. I had to uninstall and install the software again.
