(4G) S6 Engine Mounts - 1294 - Actuator 1 for Drivetrain Mounts
SpeedRacerAZ
C?ID=312337
Replaced both engine mounts and sensors with OE Audi mounts.
Everything is plugged in, how do you reset the code? Clear the fault and it comes right back...
AutoScan:
Friday,30,July,2021,14:28:58:52815
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4544.4
Dealer/Shop Name: AndyS6
VIN: WAUFFAFC7HN001111   License Plate:
Mileage: 71380km-44353mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 1B 22 28 34 36 3B 3C 42 44 46
          52 53 55 5F 62 6C 72 8F 90 A9 BA
VIN: WAUFFAFC7HN001111   Mileage: 71380km-44353miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CTGE)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 D    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0001
   Revision: NCH63---
   Coding: 0A2500326526010E3000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114G0906014D 001001
   ROD: EV_ECM40TFS0114G0906014D.rod
   VCID: 2310E7ECEB591CE36E9-8076
   Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H03 0006
   Revision: --H03---
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 303A18A0AAAFB77BE3B-8064
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 65BED441A67D2B821B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DC4D6411052EF31C5-8014
   Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
   Component: BCM2 2.0      H61 0824
   Coding: 0D886F4E000000000000
   Shop #: WSC 12345 123 61029
   VCID: 005A88605A0FE7FB53B-8054
   Serial number: 3216000043437016
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 11051600041072
   Coding: 688130B8490000
   VCID: 6A8ECAC84CF30DABEDF-803E
   Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0368
   Revision: 21020001    Serial number: 00001355220801
   Coding: 01050097042C9FF0B900488780003800CF9CD208A608022180000814F910170200600034030000
   VCID: 79ACE58439D5B633145-802C
   Component: WWS57X 160330  H38 0080
   Serial number:         160415024538
   Coding: 0045F7
   Serial number: 61790445
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 13 05 2016  00001339
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z0244B951
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA123402000020181586
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: A909862800PAG0MUFU01
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G00035THU
   Coding: 303331343135303334394A55304C34473053
   VCID: 343214B05EB78B5B873-8060
   Component: BF-Gewichtss.  H15 0046
   Serial number: 6940000Y160001GYEU0Q
   Serial number: 3575HRB405L436HUC8Q$
   Serial number: 3585HRB405J436HU29DG
   Serial number: 3515JRB404P3VEM82P93
   Serial number: 3525JRB405N3VEM8BORT
   Serial number: 3554VRB400C570C0R91Y
   Serial number: 3564VRB401I5726KD966
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372PDL0006G
   Coding: 000434
   VCID: 382A2080425F6F3BABB-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 30 03 2016  C0090592
   Part No SW: 4G0 920 982 Q    HW: 4G0 920 982 Q
   Component: TBenUsa   Nv  H14 0225
   Revision: 11001108    Serial number: 658170516596031
   Coding: 03EF0905BB41CF05020200
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 3A2E3A887CD37D2B5DF-806E
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002252742
   Coding: C0ED074814
   VCID: 3D2431946DFD4A1378D-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 5913940104
   Voltage stabilizer:
   Serial number: 1603010000000000078F
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 159
                    Mileage: 71305 km
                    Date: 2021.07.28
                    Time: 22:12:57
                    Voltage terminal 30: 12.3 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 43 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 158
                    Mileage: 71305 km
                    Date: 2021.07.29
                    Time: 01:16:17
                    Control Module temperature: 40 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 0E0100
   VCID: 3A2E3A887C537D2B5DF-806E
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 000305160001019
   VCID: 280AF0C0927FFFBB3BB-807C
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0113
   Serial number: 10051600041411
   Coding: 20
   VCID: 3E26369860FB510B617-806A
   Coding: 008004
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F381BDCB791A883FA1-807A
   Revision: AA000000    Serial number: 00000199073143
   VCID: 77A8E3BC0FC1A043621-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E0268B%
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372823BC4FC16043A21-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0403610009
   Coding: 040211
   VCID: 392C258479D57633545-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0404579479
   Coding: 040211
   Component: TSG FA        H03 0511
   Coding: 011F17015E00628002000012
   VCID: 47C8537C3FA110C3D21-8012
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000895841
   Coding: 011000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   Revision: 00002001    Serial number: 0404425256
   Coding: 0107063A00FA418582B0088002070E400000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000348622
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000YXNQ800000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00020407468
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93820004
   Component: TSG BF        H03 0511
   Coding: 011F17015E00628002000002
   VCID: 46D65E7838AB09CB297-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001848136
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 313C1DA4A1A5BE73EC5-8064
   Coding: 04FA0A1120200400
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025 C    HW: 4G1 035 025 C
   Component: MU-H-LNS-US   052 0671
   Serial number: A741E0G7500035
   Coding: 017551020000000013220002041A00102F0007E5F17001047E
   VCID: 1E66D618C03B310B417-804A
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY8050M9
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349PED000LB
   Compact Disc Database:
   Component: Gracenote2---  --- 3009
          B11CF 53 [009] - Deactivated
                    Reset counter: 115
                    Mileage: 71256 km
                    Date: 2021.07.27
                    Time: 18:06:13
                    Voltage terminal 30: 14.3 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Component: TSG HL        H03 0511
   Coding: 010F17004000628002000002
   VCID: 49CC554429B5E6B3C45-801C
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 027500010A002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001.rod
   VCID: 78AAE080025FAF3B6BB-802C
   Component: TSG HR        H03 0511
   Component: RGS-VL        H16 0080
   Coding: 0006E008031F0300070308014244C8010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   VCID: 323E12A8A4A3856B95F-8066
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 160225200382
   VCID: 2C020CD08687D39BDF3-8078
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813006773401
   ROD: EV_AEMLearAU64X.rod
          C1131 07 [009] - Mechanical Failure
                    Reset counter: 119
                    Mileage: 71380 km
                    Date: 2021.07.30
                    Time: 14:17:49
End----------(Elapsed Time: 02:15, VBatt start/end: 12.8V/12.8V)-----------
SpeedRacerAZ
C?ID=312337
I did a RTFM, how does one do a "basic setting of engine mountings" with VDCS?
3 - Engine mounting and power
unit mounting actuator
❑ Removing and installing
⇒ “2.3 Removing and installing
engine mountings”,
page 69
❑ After installing, perform
mountings ⇒ Vehicle diagnostic
tester
❑ Includes power unit
mounting actuator 1 -
N513- on right side
mounting actuator 2 -
N514- on left side
I don't think that question has ever come up before. I'm looking at the data for that module and I don't see anything super obvious. There is a Basic Setting called:
IDE03343-ENG121194 -- Static calibration (customer service)
... but I really don't know what else might be involved in doing this. Moreover, I don't think that's what it needs. The fact is, your fault code is still for a "Mechanical Failure", not "No Basic Setting".
SpeedRacerAZ
C?ID=312337
Both mounts and sensors were replaced with new ones, does that code point to something else maybe? Before and after it hasn’t changed. The engine mounts were very destroyed.
Here is a Audiworld link , they discuss this same code on a A8. Their consensus is it must be "reset" by the Dealer ?? I'm afraid none of the members who posted elaborated on this very much as most of these folk take it to the dealer for the replacements anyway. So, beware, it might just be "smoke".
Audizine has a similar thread regarding the A6 ; but they were just kicking around warranty and cost issues.
This is a good one SR, I hope you will follow up with a conclusion!
SpeedRacerAZ
C?ID=312337
I hope I find a conclusion!
I can take it to the dealer, but that’s really not any fun or the spirit of the game.
N513- on right side
N514- on left side
According to your scan, N514, actuator 2, is not showing a fault . (a clue?)
But, on your scan , address BA, N513 actuator 1 is .
1 Fault Found: 1294 - Actuator 1 for Drivetrain Mounts C1131 07 [009] - Mechanical Failure Confirmed - Tested Since Memory Clear
I would try to determine which is the left and which is the right side (unplug test) and then focus on that side (ie the one showing on the scan). Check your connections and power and ground to that affected side. Since those mounts are magnetically activated it may be that the fault side has no power ? Or, perhaps something is stuck ,tap on it a few times. (?)
You could also unplug one at a time or both at once and then scan and see what shows up on the Autoscan. It just dawned on me that the scan may not show faults for them separately ???
SpeedRacerAZ
C?ID=312337
So Actuator 1 is on the passenger side from what I can tell. It had the Mechanical failure code and does seem to respond to testing. I don't remember if it was output testing or basic settings, but you can make them buzz and vibrate to simulate the noise cancelling functionality they provide. (btw, very strange.... ) I tested each side and they both work as expected. (Multiple buzzing frequencies.)
SpeedRacerAZ
C?ID=312337
Someone suggested that I ask @Sebastian as well.... Any ideas?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
@Jack@European_Parts Any experience with this issue?
Jack passed away earlier this year. 😔
I agree with Uwe, a mechanical error usually isn't a basic setting issue. With that in mind, you should be able to interchange Actuator 1 and 2. Then perform an output test (IDE07388-MAS01167 (Actuators for assembly mounting)) to force the module to test both sides, followed by checking for faults if the error also moved over from 1 to 2. The full procedure after a replacement would be...
Prerequisites (Basic Setting after Replacement):
- No Charger connected
- Ignition ON, Engine OFF
- Vehicle leveled on the Ground
- All Doors, Lids etc. closed and must NOT be opened during the Procedure
- Maximum of 2 Passengers allowed in the Car during the Procedure
- Make sure to not cause any Vibration etc. during the Procedure
- Either use a wireless interface or run the Diagnostic Cable through the open Window
Procedure (Basic Setting after Replacement):
- Address BA (Motor Mounts (J931))
- Basic Settings - 08
- IDE03343-ENG121194 (Static calibration (Customer Service))
- Follow the Instructions on the Screen
Feedback Appreciated!
SR, I'm sure Jack would be all over this for you, unfortunately his is no longer with us ; as he passed away a few months back. Please see "a sad day" Here.
SpeedRacerAZ
C?ID=312337
OMG.... I had no idea... He was one of the biggest PIAs I've ever met, also one of the most helpful PIAs and the most caring. I called him about an issue early on and he snarled at me for calling him, belittled me a bit... then helped me out for an hour. Jack will be missed. He was a good guy in his own way. I'm so sad to hear this news.
SpeedRacerAZ
C?ID=312337
I’ll try the mechanical swap later this week, but I’m unable to get the basic calibration to work.
The option is available, but when I try to start it I get “ Request out of range”
SpeedRacerAZ
C?ID=312337
@Sebastian
Is this an indication of a hardware fault or am I doing something wrong?
“Request out of range”
Please check your PMs for something to try.
SpeedRacerAZ
C?ID=312337
RESOLVED!!! I'll let Uwe explain if he chooses to.
The procedure below now works.
We tweaked something in VCDS. Thanks for testing it. :thumbs:
This change will of course be incorporated in upcoming publicly available versions.
That said, I'm quite annoyed that VAG flags this fault as a "Mechanical Failure", which is not something that should be fixable via a Basic Setting. :rolleyes:
Anytime VCDS becomes a more powerful tool, thus giving one even more autonomy, is a great day! :thanks:
