Audi A3 2018 Carplay
M75
Norway
C?ID=354228
Hi, I have an Audi A3 2018 that I want retrofit apple carplay ... is it possible?
Monday,19,July,2021,13:12:26:44047
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4544.4
VIN: WAUZZZ8V1JA088650   License Plate: DR43605
Mileage: 46747km-29047mi   Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 23 2B 42 44 51 52 5F
          75 8C BB BC C6
VIN: WAUZZZ8V1JA088650   Mileage: 46747km-29047miles
Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AR    HW: 04E 907 309 F
   Component: R4 1.4l TFS   H22 3440
   Revision: X3H22---
   Coding: 021D0012646401083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906023AR 008003
   ROD: EV_ECM14TFS01104E906023AR_008.rod
   VCID: F0AC5BE62B0F9C0BB3-80A4
20360 - Power Supply Terminal 15
          P3325 00 [032] - Implausible
                    Mileage: 46611 km
                    Date: 2021.06.18
                    Time: 13:07:42
                    Engine RPM: 0.00 /min
                    Coolant temperature: 21 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 14.700 V
                    Unlearning counter according OBD: 35
                    Outside temperature: 21 °C
                    Absolute intake pressure: 100 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 15.00 l
                    Electric drive torque: actual value: -0.3 Nm
                    Operating mode control expanded electrical driving: Correct result
                    Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 1
                    High-volt. battery: charge state: abs. value: 20.04 %
32045 - Engine Coolant Bypass Valve 1
          P26AB 00 [096] - Stuck Open
14533 - EVAP Canister Solenoid Valve 2 (N115)
          P0498 00 [104] - Signal too Low
                    Fault Frequency: 35
                    Mileage: 44505 km
                    Date: 2021.04.18
                    Time: 16:09:47
                    Engine RPM: 902.00 /min
                    Normed load value: 12.5 %
                    Vehicle speed: 55 km/h
                    Coolant temperature: 94 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 14.580 V
                    Unlearning counter according OBD: 15
                    Gasoline tank pressure sensor: offset corrected: 79.96 hPa
                    Ambient air pressure: 102 kPa abs
                    Outside temperature: 23 °C
                    Fuel pump: specified value: 45.561 %
                    Fuel high pressure: control deviation: -0.4880 MPa
                    Fuel level: 22.00 l
                    State of shut-off valve to the gasoline pressure tank: false
                    State of shut-off valve to the gasoline pressure tank-Test_Program_B TRUE UBYTE: 0
14534 - EVAP System Vent Valve/Solenoid (N115)
          P0449 00 [096] - Circuit Malfunction
                    Mileage: 45971 km
                    Date: 2021.06.03
                    Time: 14:50:11
                    Engine RPM: 1345.50 /min
                    Normed load value: 11.4 %
                    Vehicle speed: 19 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 48 °C
                    Unlearning counter according OBD: 11
                    Gasoline tank pressure sensor: offset corrected: 76.90 hPa
                    Fuel pump: specified value: 44.868 %
                    Fuel high pressure: control deviation: 0.0000 MPa
                    Fuel level: 22.00 l
   Part No SW: 0DD 300 046 F    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 1602
   Revision: 00032056    Serial number: TFK01712180139
   Shop #: WSC 00099 780 00200
   ROD: EV_TCMDQ400021_VW37.rod
   VCID: AB168C8AC2A9BFD3C6-80FE
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 63417000001819
   Coding: 12F140A238282274897D0E0561C32848021C44917086147218B15074820802
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003.rod
   VCID: FCB47FD67747E86B1F-80A8
16401 - Tire Pressure Warning
          C102D 00 [044] - -
                    Mileage: 46641 km
                    Date: 2021.06.21
                    Time: 08:41:26
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0466550074
   Coding: 030C0C
   VCID: BC34BFD637C7286B5F-80E8
   Part No HW: 8V0 820 043 R
   Component: AC Automat    H03 0120
   Revision: 20002000    Serial number: 00000001423266
   Coding: 0300000000001000080000000000100001000000
   ASAM Dataset: EV_AirCondiFrontRDWAU37X 001019
   ROD: EV_AirCondiFrontRDWAU37X.rod
   VCID: D5E20A72B4ADD92340-8080
   Subsystem 1 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00103.6V.4B20370100
   Humidity sensor: exterior:
   Serial number: FF505A0900PAG0MUFU02
   A/C compressor sub:
   Subsystem 3 - Part No SW: 5QE 816 803     HW: 5QE 816 803
   Component: J842 eKK  H02 0007
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [040] - -
                    Mileage: 46611 km
                    Date: 2021.06.18
                    Time: 13:47:29
                    Unlearning counter according OBD-OBD Parameter: 39
                    Voltage terminal 30: 14.600 V
                    Compressor shut-off condition: Shut-off from Engine Control Module (ECM) via CAN
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001802300128
   ROD: EV_BCMBOSCH_018.rod
   VCID: 895A16022895CDC314-80DC
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 171223  043 0580
   Serial number:         171228093135
   Coding: 0A47F7
   Serial number: 21164922X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 17 11 2017  00002031
204549 - Remote key 2
          B147A 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 216
                    Mileage: 45742 km
                    Date: 2021.05.24
                    Time: 17:11:03
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419618012
   Coding: 0600040011
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000_009_AU37.rod
   VCID: C9DAD60268158DC3D4-809C
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 5500E78159FF8728949C8055000026
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   VCID: BB36BCCA32C92F5356-80EE
1538 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_SENSOR_BLIND]
                    Reset counter: 254
                    Mileage: 46712 km
                    Date: 2021.07.13
                    Time: 09:31:59
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 14.4 V
                    Velocity_vehicle_reference: 5.63 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.33 m/s²
1396 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_NO_FREE_SIGHT]
                    Reset counter: 254
                    Mileage: 46719 km
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 11.8 V
                    Status_ACC_System: ACC_Init
1542 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_BLIND]
                    Reset counter: 254
                    Mileage: 46712 km
                    Date: 2021.07.13
                    Time: 09:31:59
1397 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_NO_FREE_SIGHT]
                    Reset counter: 254
                    Mileage: 46719 km
   Part No SW: 5Q0 959 655 BE    HW: 5Q0 959 655 BE
   Component: AirbagVW21    005 0336
   Serial number: 003VHR3SE7KL
   Coding: 98CCC0000C2000009C5400CA0048000000C5
   VCID: 844407360FB790AB67-80D0
   Subsystem 1 - Part No SW: -----------    HW: 480 002 301 18
   Serial number: 357000000007D21D0B2L
   Subsystem 2 - Part No SW: -----------    HW: 480 002 301 18
   Serial number: 35800000000D77614B2O
   Subsystem 3 - Part No SW: -----------    HW: 480 402 201 18
   Serial number: 3510001AB28C22E54666
   Subsystem 4 - Part No SW: -----------    HW: 480 402 201 18
   Serial number: 3520001B727CBBA505FL
   Subsystem 5 - Part No SW: -----------    HW: 480 400 401 18
   Serial number: 3550002C9252D874C1AE
   Subsystem 6 - Part No SW: -----------    HW: 480 401 812 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001B7279D01492D5
   Subsystem 7 - Part No SW: -----------    HW: 480 401 812 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001B7279D014528/
   Subsystem 8 - Part No SW: -----------    HW: 480 000 301 18
   Serial number: I0M000000003991D3B25
   Subsystem 9 - Part No SW: -----------    HW: 480 000 301 18
   Serial number: I0N000000005991D3B28
   Part No SW: 8V0 953 521 JT    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 15011804401346
   Coding: 6418
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 95624A72742D192380-80C0
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 794 A    HW: 8V0 920 794 A
   Component: FBenRDW       H16 0066
   Coding: 04040C502F8000080183E8101200000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: BE30B5DE21DB3A7B71-80EA
   Part No SW: 3Q0 907 530 M    HW: 3Q0 907 530 D
   Component: GW MQB EV     618 6322
   Serial number: 03011810524477
   Coding: 0201001726F200005B001018581000000001010100010000000300000000
   ROD: EV_GatewNF_AU37.rod
   VCID: B93AA6C238F51D4344-80EC
   Subsystem 1 - Part No SW: 8W0 951 523 E    HW: 8W0 951 523 E
   Component: J453 MFL  H04 0002
   Serial number: 20180118141434 00914
   Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
   Serial number: 8638955904
Address 20: High Beam Assist. (J844)       Labels:* None
   Part No SW: 81A 857 511 A    HW: 81A 857 511 A
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0202000700000000000001
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: A6007DBED94B82BB19-80F2
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
   Component: EBKV          H14 0211
   Serial number:   085460012296
   Coding: 03720100331900010002050500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   VCID: D2E8F16E8543CE1BA5-8086
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861121217035104
   Revision: 00000000    Serial number: 18000017040004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: B42497F61F97E02B97-80E0
   Serial number: 020118EA20007A
   Coding: 001C9F204000040000001003
   VCID: C3C6C42A4A3957931E-8096
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: C11E0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: F3A654EA5A19A7134E-80A6
   Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
   Component: LE Gen 3.3H15 1032
   Revision: 00H15000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM08530115G0907080E 001008
   ROD: EV_DMCM08530115G0907080E.rod
   VCID: A91A7682C855ADC334-80FC
   Serial number: 161217ELG22023
   Coding: 001C97204000040000001003
   VCID: C2C8C12E55235E9B15-8096
   Part No SW: 8V1 035 035 D    HW: 8V1 035 035
   Component: MU-P-LND-EU   054 1168
   Serial number: A698A0JS009240
   Coding: 01739301FF0A000011111101000A02332F00296501700100DE
   VCID: B32694EA1A99E7138E-80E6
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y07WC2
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL101121700050602
   Compact disc data bank:
   Component: Gracenote2  --- 1016
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   020 0717
   Coding: 0173930110829A0100F800000000
   ROD: EV_OCULowMQB.rod
   VCID: C4C4C7364F3750AB27-8090
   Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
   Component: BECM          H05 0921
   Serial number: V7120070
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006041
   ROD: EV_BECM06020115C6915182_VW37.rod
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
   Component: BJB  H28 0240
   Cell module control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D1  H14 0481
   Serial number: V013C17C0820495
   Cell module control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D2  H14 0481
   Serial number: V013C17C0820649
   Cell module control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D3  H14 0481
   Serial number: V013C17C0820574
   Cell module control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D4  H14 0481
   Serial number: V013C17C0820581
   Cell module control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D5  H14 0481
   Serial number: V013C17C0820582
   Cell module control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D6  H14 0481
   Serial number: V013C17C0820576
   Cell module control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D7  H14 0481
   Serial number: V013C17C0820676
   Cell module control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D8  H14 0481
   Serial number: V013C17C0820689
   Serial number: 281117EKR21266
   Coding: 000C97204000040000001002
   VCID: C5C2DA32440D69A330-8090
   Serial number: 281117EKR2132B
   Part No SW: 5QE 915 682 AF    HW: 5QE 915 682 AF
   Component: OBC KOSTAL    H40 4013
   Revision: --------    Serial number: 1412170L4000Q6
   Coding: 115068223000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
   ROD: EV_OBCSinglPhaseKLOMQB12P.rod
   VCID: 916A3E6240C5F503DC-80C4
End----------(Elapsed Time: 01:56, VBatt start/end: 12.6V/12.6V)-----------
vastechnics
C?ID=143747
No problem meed add usb and prgramming eeprom
