Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 21.3.0 Data version: 20210226 DS325.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,02,August,2021,14:23:14:23682
VIN: WAUZZZ8K3AA039228 License Plate:
Mileage: 180790km-112337mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 1B 20 22 30 36 42 46 52
53 55 56 5F 62 6D 72
VIN: WAUZZZ8K3AA039228 Mileage: 180790km-112337miles
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CAKA) Labels:| 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 HW: 8K0 907 551
Component: 3.0T SIMOS84 H06 0004
Revision: --------
Coding: 010C000C240F0128
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM30TFS8K0907551 A01006
ROD: EV_ECM30TFS8K0907551_A01.rod
VCID: 6ED3CE31B1CB87FB21-803A
6201 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 180794 km
Date: 2009.04.28
Time: 00:12:55
Engine RPM: 669.00 /min
Normed load value: 11.4 %
Coolant temperature: 71 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.015 V
Engine speed: actual: 640 /min
MAF_ENVD: 125.28235 mg/stroke
Coolant temperature (unfiltered): 71.3 °C
Engine: operating status: IS
Engine load: 11.328125 %
Vehicle speed: actual: 0 km/h
Readiness: 0110 1001
Self-Diagnosis Log
Page 3
Part No SW: 8K1 927 156 AC HW: 0B5 927 156 E
Component: 0B5 30TFSIRdW H04 0004
Revision: --H04--- Serial number: 0000000061
Shop #: WSC 00097 210 106681
ASAM Dataset: EV_TCMDL501 A02051
ROD: EV_TCMDL501.rod
VCID: 76E3E651C99BBF3BE9-8022
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AN HW: 8K0 907 379 AN
Component: ESP8 quattro H04 0100
Coding: 296D0A
VCID: 0501919D8C7DA4A3F0-8050
Part No SW: 8K0 907 064 DQ HW: 8K0 907 064 DQ
Component: BCM2 1.1 H02 0321
Coding: 011200
VCID: 020B8A819D53939BD5-8056
Subsystem 1 - Part No SW: 8T0 959 754 AG HW: 8T0 959 754 AG
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000032230012
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000049997016
Self-Diagnosis Log
Page 4
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Component: KLIMA 3 ZONEN H08 0160
Revision: D1000000 Serial number: 01130720090660
Coding: 66140000
VCID: 77FDEB55C691C633F2-8022
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000428207
Coding: 260050914074AF313F01000300001D0D0F9DC74A00010141000000
VCID: 3C773479BF37256BDF-8068
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 140709 H05 0070
Serial number: SWF09070140107
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10542233
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000612100478
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940919827036
Coding: 00010D
VCID: 3E733E71A92B377BF1-806A
Self-Diagnosis Log
Page 5
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 A HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0050
Revision: 00000000 Serial number: 01070904830001
Coding: 050181
VCID: 3169154D6875D8037C-8064
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H37 0520
Serial number: 003EFD045C1O
Coding: 30373435363030303030554A3052384B3053
VCID: 4189458DD0D548838C-8014
Serial number: 6334MSME48630F02B
Serial number: 6344MSME48637542D
Serial number: 6352QSME053309063
Serial number: 6362QSME232E0C1EQ
Serial number: 63732SME50325306N
Serial number: 63832SME7034143ENo
fault code found.
Self-Diagnosis Log
Page 6
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IGE0007S
Coding: 000037
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 980 P HW: 8K0 920 980 P
Component: KOMBIINSTR. H04 0253
Revision: 00100000 Serial number: BXZ601D79
Coding: 2F071100B3002600010000
VCID: 3F8D4375AE213E73FA-806A
Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0101
Revision: FB800054 Serial number: 5400F09616011C
Coding: 00C303
VCID: 000F8089935F818BC3-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 19085AE3010709
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 D HW: 8K0 907 144 D
Component: DYNAMIKLENK. H06 0570
Revision: 50001005 Serial number: --------------
Coding: 8C0000
VCID: 306F1049637FD10B73-8064
Self-Diagnosis Log
Page 7
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 02029164747464545425363E
VCID: 33651F459269EA130E-8066
Self-Diagnosis Log
Page 8
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 HW: 8K0 907 163
Component: 4 Wheel Drive H09 0004
Serial number: 001506090001159
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
VCID: 6DD1C93DBCCD7CE318-8038
0059 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [137] - -
Reset counter: 79
Mileage: 180794 km
Date: 2009.04.28
Time: 00:12:55
0121 - Please Check Fault Codes in Steering Assist Control Module
U1020 00 [137] - -
Reset counter: 79
Mileage: 180794 km
Date: 2009.04.28
Time: 00:12:55
0122 - Please Check Fault Codes in Steering Assist Control Module
U1020 00 [137] - -
Reset counter: 79
Mileage: 180794 km
Date: 2009.04.28
Time: 00:12:55
Self-Diagnosis Log
Page 9
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0010
Revision: S0H04000 Serial number: 00000000006542
Coding: 01010101000000000000000102
VCID: 2D51093D744DBCE358-8078
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0073
Revision: AA000000 Serial number: 00001001297764
Coding: 00781300000000000000
VCID: 3B753765BA392253D6-806E
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009075774
Coding: 011C02205E21410001
VCID: 4581519DCCFD64A3B0-8010
Self-Diagnosis Log
Page 10
Revision: 00002001 Serial number: 0120026119
Coding: 013B062220393C940030020000000000
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS133 H06 0041
Subsystem 4 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J394 PS228 H06 0041
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009098295
VCID: 44874C99C7C75DABA7-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 00000000412956
VCID: 34671C599767ED2B17-8060
Self-Diagnosis Log
Page 11
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000005
Shop #: WSC 06334 000 00000
VCID: 34671C595767ED2B17-8060
Part No SW: 4F0 035 061 J HW: 4F0 035 061
Component: Radio U DAB H45 0052
Revision: AB001007 Serial number: 343G0097525599
Coding: 010103020100000001
VCID: 2345EF0522897A93FE-8076
Part No SW: 8T2 035 666 F HW: 8T2 035 666 D
Component: H-BN-EU H41 0143
Revision: -------- Serial number: 475GZ097512418
Coding: 010101010206A1ED45000B1E000000030001
Shop #: WSC 00097 210 104537
Subsystem 1 - Part No: 8R0 060 884 E
Component: EUR 2009/2010 5805
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356GT091036356
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000325747
Subsystem 4 - Part No: 8R0 060 999
Component: CD-Database 1886
Self-Diagnosis Log
Page 12
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101520166
Coding: 010C02204021210001
VCID: 428B4A81DDD3539B95-8016
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
Component: J605 Master H27 0300
Revision: -------- Serial number: 8K9827851A
Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
Component: J756 Slave H27 0300
Serial number: 8K9827852A
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101520163
End-------------------------(Elapsed Time: 04:22
