2009 B8 Audi S4 Avant Issues
S3JTP
C?ID=205730
Good afternoon all
Just wondered if anyone could shed any light on this for me.
I have 2 warning lights on for the steering and drive.
Have run VCDS a number of times now and tried to clear codes but to no avail.
Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: Release 21.3.0
Dealer/Shop Name:
Workshop Code: 000 00000
Diagnostic Trouble Code Report
Thursday,29,July,2021,17:57:56:23682
Control Module Part Number: 8K0 907 163 HW: 8K0 907 163
Component and/or Version: 4 Wheel Drive H09 0004
Software Coding:
Work Shop Code:
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007 (AU48)
VCID: 6DD1C93DBCCD7CE318-8038
0059 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [137] - -
Reset counter: 77
Mileage: 180780 km
Date: 2021.07.29
Time: 17:56:39
0121 - Please Check Fault Codes in Steering Assist Control Module
U1020 00 [137] - -
Reset counter: 77
Mileage: 180780 km
Date: 2021.07.29
Time: 17:56:39
0122 - Please Check Fault Codes in Steering Assist Control Module
U1020 00 [137] - -
Reset counter: 77
Mileage: 180780 km
Date: 2021.07.29
Time: 17:56:39
Many thanks in anticipation of one of you gurus helping me!
Jef
HQ
You need to post the full Auto-Scan. Those fault codes you show are basically saying:
  • Mario is you and VCDS.
  • Princess is actual issues and fault codes.
  • Castle is other control modules.
S3JTP
C?ID=205730
Thanks for the heads up although I sense someone might be taking the micky out of me :rolleyes: :) OK done that what do I need to do now?
S3JTP
C?ID=205730
Thursday,29,July,2021,18:36:22:23682
VCDS Version: 21.3.0.0
VIN:    License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 1B 20 22 30 36 42 46 52
          53 55 56 5F 62 6D 72
VIN:    Mileage: 180780km-112331miles
Address 01: Engine (J623-CAKA)       Labels:| 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551     HW: 8K0 907 551
   Component: 3.0T SIMOS84  H06 0004
   Revision: --------
   Coding: 010C000C240F0128
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM30TFS8K0907551 A01006
   ROD: EV_ECM30TFS8K0907551_A01.rod
   VCID: 6ED3CE31B1CB87FB21-803A
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 180780 km
                    Date: 2021.07.29
                    Time: 18:31:51
                    Engine RPM: 681.00 /min
                    Normed load value: 18.4 %
                    Coolant temperature: 92 °C
                    Intake air temperature: 57 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 12.796 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 163.41176 mg/stroke
                    Coolant temperature (unfiltered): 92.3 °C
                    Engine: operating status: IS
                    Engine load: 18.359375 %
                    Vehicle speed: actual: 0 km/h
Readiness: 0110 1001
   Part No SW: 8K1 927 156 AC    HW: 0B5 927 156 E
   Component: 0B5 30TFSIRdW H04 0004
   Revision: --H04---    Serial number: 0000000061
   Shop #: WSC 00097 210 106681
   ASAM Dataset: EV_TCMDL501 A02051
   ROD: EV_TCMDL501.rod
   VCID: 76E3E651C99BBF3BE9-8022
   Part No SW: 8K0 907 379 AN    HW: 8K0 907 379 AN
   Component: ESP8 quattro  H04 0100
   Coding: 296D0A
   VCID: 0501919D8C7DA4A3F0-8050
   Part No SW: 8K0 907 064 DQ    HW: 8K0 907 064 DQ
   Component: BCM2 1.1      H02 0321
   Coding: 011200
   VCID: 020B8A819D53939BD5-8056
   Subsystem 1 - Part No SW: 8T0 959 754 AG    HW: 8T0 959 754 AG
   Serial number: 0509000032230012
   Serial number: 0209000049997016
   Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
   Component: KLIMA 3 ZONEN H08 0160
   Revision: D1000000    Serial number: 01130720090660
   Coding: 66140000
   VCID: 77FDEB55C691C633F2-8022
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000428207
   Coding: 260050914074AF313F01000300001D0D0F9DC74A00010141000000
   VCID: 3C773479BF37256BDF-8068
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 140709  H05 0070
   Serial number: SWF09070140107
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10542233
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000612100478
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940919827036
   Coding: 00010D
   VCID: 3E733E71A92B377BF1-806A
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364 A    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0050
   Revision: 00000000    Serial number: 01070904830001
   Coding: 050181
   VCID: 3169154D6875D8037C-8064
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EFD045C1O
   Coding: 30373435363030303030554A3052384B3053
   VCID: 4189458DD0D548838C-8014
   Serial number: 6334MSME48630F02B
   Serial number: 6344MSME48637542D
   Serial number: 6352QSME053309063
   Serial number: 6362QSME232E0C1EQ
   Serial number: 63732SME50325306N
   Serial number: 63832SME7034143E-
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Revision: --------    Serial number: 90319IGE0007S
   Coding: 000037
   Part No SW: 8K0 920 980 P    HW: 8K0 920 980 P
   Component: KOMBIINSTR.   H04 0253
   Revision: 00100000    Serial number: BXZ601D79
   Coding: 2F071100B3002600010000
   VCID: 3F8D4375AE213E73FA-806A
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0101
   Revision: FB800054    Serial number: 5400F09616011C
   Coding: 00C303
   VCID: 000F8089935F818BC3-8054
   Component: J367-BDM  H06 0160
   Serial number: 19085AE3010709
   Part No SW: 8K0 907 144 D    HW: 8K0 907 144 D
   Component: DYNAMIKLENK.  H06 0570
   Revision: 50001005    Serial number: --------------
   Coding: 8C0000
   VCID: 306F1049637FD10B73-8064
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02029164747464545425363E
   VCID: 33651F459269EA130E-8066
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163     HW: 8K0 907 163
   Component: 4 Wheel Drive H09 0004
   Serial number: 001506090001159
          U1017 00 [137] - -
                    Reset counter: 77
                    Mileage: 180780 km
                    Date: 2021.07.29
                    Time: 18:34:12
          U1020 00 [137] - -
                    Reset counter: 77
                    Mileage: 180780 km
                    Date: 2021.07.29
                    Time: 18:34:12
          U1020 00 [137] - -
                    Reset counter: 77
                    Mileage: 180780 km
                    Date: 2021.07.29
                    Time: 18:34:12
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0010
   Revision: S0H04000    Serial number: 00000000006542
   Coding: 01010101000000000000000102
   VCID: 2D51093D744DBCE358-8078
   Component: MEM-FS        H06 0073
   Revision: AA000000    Serial number: 00001001297764
   Coding: 00781300000000000000
   VCID: 3B753765BA392253D6-806E
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009075774
   Coding: 011C02205E21410001
   VCID: 4581519DCCFD64A3B0-8010
   Revision: 00002001    Serial number: 0120026119
   Coding: 013B062220393C940030020000000000
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS133  H06 0041
   Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J394 PS228  H06 0041
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009098295
   VCID: 44874C99C7C75DABA7-8010
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 00000000412956
   VCID: 34671C599767ED2B17-8060
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000005
   Shop #: WSC 06334 000 00000
   VCID: 34671C595767ED2B17-8060
   Part No SW: 4F0 035 061 J    HW: 4F0 035 061
   Component: Radio U DAB   H45 0052
   Revision: AB001007    Serial number: 343G0097525599
   Coding: 010103020100000001
   VCID: 2345EF0522897A93FE-8076
   Part No SW: 8T2 035 666 F    HW: 8T2 035 666 D
   Component: H-BN-EU       H41 0143
   Revision: --------    Serial number: 475GZ097512418
   Coding: 010101010206A1ED45000B1E000000030001
   Shop #: WSC 00097 210 104537
   Subsystem 1 - Part No: 8R0 060 884 E
   Component: EUR 2009/2010  5805
   Component: DU7 High  H43 0306
   Serial number: 9356GT091036356
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000325747
   Subsystem 4 - Part No: 8R0 060 999
   Component: CD-Database  1886
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101520166
   Coding: 010C02204021210001
   VCID: 428B4A81DDD3539B95-8016
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H27 0300
   Revision: --------    Serial number: 8K9827851A
   Revision:             Serial number: 0000101520163
End-------------------------(Elapsed Time: 05:02)--------------------------
Jef
HQ
Thank you for posting the full Auto-Scan. :thumbs:
U1017 00 [137] - -
U1020 00 [137] - -
U1020 00 [137] - -
Well this is odd..... so the other modules (ABS and Steering Assist) do not have fault codes in them. :confused: The extended USD fault details is basically this:
  • ESP control unit not available DRC_CAN_ESP_01_SYS_ST
  • Control unit for active steering Please read out fault memory ---------- --- DTC_CAN_SCU_ANGLE_DES
  • Control unit for active steering Please read out fault memory ---------- --- DTC_CAN_SCU_ADS_DES
Is there some back story on this car? Are all control modules factory original?
Eric
HC800000
What I notice is there is no 44 in the GVL, and the gateway doesn't complain about a missing 44. Sounds to me like 44 went offline and someone tried to "fix" it by removing from the GVL.
Jef
HQ
reads Eric's post...hmmm, sounds good... lets see if I can dig up a wiring diagram for this VIN... and the VIN is gone.... :banghead:
Trowbridge, UK
UK guys seem to like removing the VIN from posts. There was a problem with VINs being cloned a while back, but with the VIN visible in the windscreen (windshield) for many years now it seems pointless to me???
S3JTP
C?ID=205730
no back story as far as I'm aware, and, again, as far as I am aware everything is original.
S3JTP
C?ID=205730
I didnt realise the VIN Was relevant, understandably one can be a little bit nervous about broadcasting a VIN on the web for that exact reason, if someone is going to clone your car they are not likely to be local (looking at the windshield) as it would be a bit obvious if 2 S4 Avants are kicking around in the same area, they are mor likely to use the information and clone it a few hundred miles away.
Jef
HQ
OK, looking at wiring diagrams based on VIN, as per the info I have, there doesn't look to be an address 44 (J500). A quick search of other simular VINs shows the same results.
I'm thinking there is some wrong parts installed or some one has played some coding games.
Normally I can match up examples from known good cars.... do some searches "this part number" + "that part number" and get results. Not here. Searching the ABS part number with the AWD part number yields no solid results.... this thread comes up. It is possible the VIN range of this car, an earlier production run, just is "rare" so finding matching results is difficult.
S3JTP
C?ID=205730
Hmmm the plot thickens, thanks for looking Jef, it really is odd and I am really struggling to understand what the issue is and why it has suddenly manifested itself.
S3JTP
C?ID=205730
I even tried disconnecting the battery earlier and then reconnecting it and then running the VCDS and clearing the fault codes, again no cigar:
VCDS Version: Release 21.3.0 Data version: 20210226 DS325.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,02,August,2021,14:23:14:23682
VIN: WAUZZZ8K3AA039228 License Plate:
Mileage: 180790km-112337mi Repair Order:
VIN: WAUZZZ8K3AA039228 Mileage: 180790km-112337miles
Self-Diagnosis Log
Page 2
Revision: --------
U1113 00 [039] - -
Mileage: 180794 km
Date: 2009.04.28
Time: 00:12:55
Engine RPM: 669.00 /min
Normed load value: 11.4 %
Coolant temperature: 71 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.015 V
Engine speed: actual: 640 /min
MAF_ENVD: 125.28235 mg/stroke
Coolant temperature (unfiltered): 71.3 °C
Engine load: 11.328125 %
Self-Diagnosis Log
Page 3
Coding: 296D0A
Coding: 011200
Self-Diagnosis Log
Page 4
Coding: 66140000
Coding: 00FD11
Coding: 025028
Coding: 00010D
Self-Diagnosis Log
Page 5
Coding: 050181
Serial number: 63832SME7034143ENo
fault code found.
Self-Diagnosis Log
Page 6
Coding: 000037
Coding: 00C303
Coding: 8C0000
Self-Diagnosis Log
Page 7
Revision: AA001002
Self-Diagnosis Log
Page 8
U1017 00 [137] - -
Reset counter: 79
Mileage: 180794 km
Date: 2009.04.28
Time: 00:12:55
U1020 00 [137] - -
Reset counter: 79
Mileage: 180794 km
Date: 2009.04.28
Time: 00:12:55
U1020 00 [137] - -
Reset counter: 79
Mileage: 180794 km
Date: 2009.04.28
Time: 00:12:55
Self-Diagnosis Log
Page 9
Self-Diagnosis Log
Page 10
Self-Diagnosis Log
Page 11
Coding: 0000005
Self-Diagnosis Log
Page 12
Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
Component: J756 Slave H27 0300
Serial number: 8K9827852A
End-------------------------(Elapsed Time: 04:22
Jef
HQ
So was this a case of "car working fine, parked it, now it all messed up"?
In doing some more digging, I do find an example online of a car that is similar (built 3 days after this car) with matching ABS and AWD modules. LINK HERE. That example doesn't have a Address 1B: Active Steering (J792).
I'm not sure what direction to go with this. Maybe start with verifying the G85 sensor reports valid data by different control modules. With the steering wheel level and centered, you should get 0 degrees and then full left lock and full right lock, you should get similar values as well.
  • 03-08-005.1
  • 22-Adv Meas Values-IDE00326 Steering wheel angle
