Lane Change Malfunction
dejwidsson
Poland
h11-002250
Hi to all,
I'm having trouble with Blind Spot Assist not working. DTCs cannot be cleared. The car had a damaged front left side. Everything is fixed. Any advice? The car is Fabia Mk3, 2019
Friday,30,July,2021,16:35:31:08916
VIN: TMBEP6NJ5LZ007449   License Plate: FABIA III
Mileage: 32750km-20349mi   Repair Order:
Chassis Type: NJ-SK26 (2Q0)
Scan: 01 03 08 09 10 15 17 19 3C 44 5F 69
VIN: TMBEP6NJ5LZ007449   Mileage: 32750km-20349miles
Address 01: Engine (J623-DKLD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 AR    HW: 04C 907 309 BP
   Component: R3 1.0l TFS   H20 7057
   Revision: DGH20000
   Coding: 01110032243415080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM10TFS01104C906025AR 003001
   ROD: EV_ECM10TFS01104C906025AR_003.rod
   VCID: 70B92DDB9A213ECB7F3-8024
7158 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [036] - -
          [Diagnostic interface for data busRead out DTC]
                    Mileage: 32750 km
                    Date: 2021.02.02
                    Time: 00:15:28
                    Engine RPM: 941.50 /min
                    Normed load value: 12.2 %
                    Coolant temperature: 54 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.900 V
                    Outside temperature: 26 °C
                    Absolute intake pressure: 37 kPa abs
                    Engine torque: 18.5 Nm
                    Fuel: tank fill level: 8.0 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08509024190627
   Coding: 41F5247D4A2333C70918106D005A822452CC9008000DCB098F00
   Shop #: WSC 13765 031 00000
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3E25C3E390F598BBBDF-806A
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 D    HW: 6V0 820 045 D
   Component: AC Manuell    H02 0205
   Serial number:  1906281B-0503
   Coding: 100000001100000010
   ASAM Dataset: EV_ACManueKMMValeoPQ26 003001
   ROD: EV_ACManueKMMValeoPQ26_SK26.rod
   VCID: 3333E2D7ABB745D3421-8066
   Part No SW: 2Q0 937 089 B    HW: 2Q0 937 089
   Component: BCM A0 Std    H10 0934
   Serial number: 01101916600951
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205.rod
   VCID: 392FD0FF89DBBF8388D-806C
   Driver door control module:
   Subsystem 1 - Part No SW: 2Q2 959 881 C    HW: 2Q2 959 881 C
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000031411167
   Coding: 110208
   Front passenger door control module:
   Subsystem 2 - Part No SW: 2Q2 959 882     HW: 2Q2 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000031286350
   Coding: 090208
592133 - Window Regulator; Front Passenger Side
          B14D2 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 78
                    Mileage: 32750 km
                    Date: 2021.02.02
                    Time: 00:15:26
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 14.0 V
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 7K  H03 0056
   Revision: --------    Serial number: 39331916503370
   Coding: 0031155141
   Shop #: WSC 73430 790 00000
   ROD: EV_EPHVA18AU3700000_SK26.rod
   VCID: 44D1B10BFE19F26BEBB-8010
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 78
                    Mileage: 32750 km
                    Date: 2021.02.02
                    Time: 00:15:25
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag743 002 0380
   Revision: --------    Serial number: 003TJ00VSD82
   Coding: 88CCC000000000005C5400CF000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3B23CAF783E78D939A1-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 821 006 19
   Component: SideSensor_Df  344 0800
   Serial number: 357D400022C9CCF331CT
   Subsystem 2 - Part No SW: -----------    HW: 410 821 006 19
   Component: SideSensor_Pf  344 0800
   Serial number: 358D4002E2C9A08481DU
   Subsystem 3 - Part No SW: -----------    HW: 442 151 406 19
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A732060D0A34+
   Subsystem 4 - Part No SW: -----------    HW: 442 151 306 19
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A7315BAD3F24P
   Part No SW: 6V0 920 740 D    HW: 6V0 920 740 D
   Component: KOMBI         205 2321
   Coding: 072401002180000807086A085000000000000000
   Shop #: WSC 73430 031 12345
   ROD: EV_DashBoardVDDMQBAB_SK26.rod
   VCID: 3635DBC3B8C550FB65F-8062
   Part No SW: 2Q0 909 901 C    HW: 2Q0 937 089
   Component: GW MQB A0     H10 0934
   Coding: 030100342F0A570000000040000000010001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013026
   ROD: EV_GatewA0_SK25.rod
   VCID: 323DE7D354AD4CDB497-8066
   Generator:
   Component: 2-07-1f-07-1f
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000B2669250619
66567 - Local Databus
          U1030 00 [009] - Electrical Malfunction
          [LIN#1 (LIN-Energie) elektrischer Fehler]
                    Reset counter: 78
                    Mileage: 32750 km
                    Date: 2021.02.02
                    Time: 00:15:26
                    Terminal 30 power supply: 14.1 V
                    Terminal 15: On
8526363 - Crash Shut-Down
          B189C F0 [009] - Active
                    Reset counter: 78
                    Mileage: 32750 km
                    Date: 2021.02.02
                    Time: 00:15:26
                    Terminal 15: On
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
   Component: HRE3_Kl15_Mst H05 0052
   Serial number: 00000518257131
   Coding: 60012500
   ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
   ROD: EV_HREntryHellaGen3Kl15_001_VW37.rod
   VCID: 3829D5FBB2D1A68B773-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 A    HW: 2Q0 907 685 A
   Component: HRE3_Kl15_Slv  H05 0052
   Serial number: 00000518625450
1576962 - Internal Control Module Memory Check Sum Error
          B2000 47 [009] - Watchdog/safety µC failure
          [Control unit - defekt - InternalPowerSupplyError Slave]
                    Mileage: 32750 km
                    Date: 2021.02.02
                    Time: 00:15:26
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AK    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  313 3250
   Serial number: CJ720149
   Coding: 000300
   Shop #: WSC 73430 790 54321
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 71BF28DF912B37C370D-8024
   Part No SW: 565 035 864     HW: 565 035 864
   Component: MU-S-N-ER     H41 0477
   Serial number: SKZAZ2W0461705
   Coding: 03620001BE0000000111000400080A002F0108D4012005004F
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 5AED6F736C9D549BA17-800E
   Subsystem 1 - Part No SW: 6V0 919 604 C    HW: 6V0 919 604 C
   Component: ABTm_Std2_Nav  H42 1041
   Serial number: SKZ8Z9WLY023J7
   Subsystem 2 - Part No SW: 5L0 051 236 BA    HW: -----------
   Component: ECE AS 19/20  --- 1115
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0520540829
   Coding: 0100000202000000
   Shop #: WSC 13765 790 00000
   VCID: 40D9BD1BEA01EE4BCF3-8014
Nie znaleziono kodu błędu.
End----------(Elapsed Time: 00:45, VBatt start/end: 12.4V/12.3V)-----------
3C-Lane Change module is not happy at all:
I'm not aware of any advice that can be given here except, replace that module. :(
dejwidsson
Poland
h11-002250
I suspected so, but I have no idea where he could be in this model.
siLc
Tallinn, Estonia
C?ID=330192
LCA radars are usually in the rear corners of the car, behind the bumper cover.
