2009 Audi A3 ABS module Lost Coding (MK60EC1)
robocik74
C?ID=46115
I am writing to you asking for help because my friend changed the instrument panel in his car and forgot to save the logos and when he put on the second instrument dash in the car he lost the coding on the abs pump.
Please help.
Saturday,01,May,2021,16:33:01:17683
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ8P19A026548   License Plate:
Mileage: 162810km-101165mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 47 52 56 62 69 72
VIN: WAUZZZ8P19A026548   Mileage: 162810km-101165miles
47-Sound System -- Status: Cannot be reached 1100
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 8P7 907 115 D    HW: 8P0 907 115 Q
   Component: 1.8l R4/4V TFSI     0020
   Revision: AAH03---    Serial number: AUX7Z0H6FNV0I0
   Coding: 0103000C180F0160
   Shop #: WSC 06314 000 00000
   VCID: 3A7F7F99751A8A5BCD-806E
006439 - Relay for Aux Coolant Pump (J496)
               P1927 - 000 - Open Circuit
                    Mileage: 162790 km
                    Date: 2021.07.28
                    Time: 22:20:02
                    RPM: 767 /min
                    Load: 12.9 %
                    Temperature: 89.0°C
                    Temperature: 40.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.716 V
Readiness: 0110 0000
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 52409 002 1048576
   VCID: 77F9A6ADC6885733F2-8022
03306 - Coding Not Valid
                    Reset counter: 249
                    Mileage: 162814 km
                    Date: 2021.07.29
                    Time: 00:59:35
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 4161
                    Count: 49664
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 249
                    Mileage: 162814 km
                    Date: 2021.07.29
                    Time: 00:17:28
                    Count: 16391
                    Count: 32770
                    Count: 12288
                    Count: 143
                    Count: 44800
                    Reset counter: 249
                    Mileage: 162814 km
                    Date: 2021.07.29
                    Time: 00:17:28
                    Count: 16391
                    Count: 32770
                    Count: 12288
                    Count: 279
                    Count: 44800
                    Reset counter: 249
                    Mileage: 162814 km
                    Date: 2021.07.29
                    Time: 00:17:28
                    Count: 16391
                    Count: 32770
                    Count: 12288
                    Count: 195
                    Count: 44800
01486 - System Function Test Activated
                    Reset counter: 249
                    Mileage: 162814 km
                    Date: 2021.07.29
                    Time: 00:17:28
                    Count: 16391
                    Count: 32770
                    Count: 12288
                    Count: 320
                    Count: 44800
                    Reset counter: 249
                    Mileage: 162814 km
                    Date: 2021.07.29
                    Time: 00:17:28
                    Count: 16391
                    Count: 32770
                    Count: 12288
                    Count: 291
                    Count: 44800
   Part No SW: 8P0 820 043 BH    HW: 8P0 820 043 BH
   Component: KlimavollautomatH09 0100
   Revision: 000168      Serial number: 8P0820043BH
   VCID: 73E192BD12F03B13CE-8026
00716 - Air recirculation Flap Positioning Motor (V113)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 249
                    Mileage: 162802 km
                    Date: 2021.07.28
                    Time: 23:42:55
                    Voltage: 13.90 V
                    Temperature: 34.0°C
                    (no units): 136.0
                    (no units): 150.0
                    Temperature: 26.0°C
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000008751204
   Coding: B1AC2F8194141380EF00001C0000000000094E056401040300A800000000
   Shop #: WSC 21044 141 210441
   VCID: 489B15513BF6E8CB4B-801C
   Subsystem 1 - Part No: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H12 0050
   Coding: 00055568
   Shop #: WSC 21044
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 F    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0102
   Revision: 11001001    Serial number: 52330821212751
   Coding: 010003
   VCID: 418D0875D8CCD9838C-8014
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 303142383038303030354A55304C38503053
   ROD: EV_Airba10AURB4_AU35.rod
   VCID: 499D1055E8FC11C354-801C
   Serial number: 3572DRB4000079D0797
   Serial number: 3582DRB4000079C4C36/
   Serial number: 35128RB400003EA986C.
   Serial number: 35228RB400003EA1F4CZ
   Serial number: 35547RB400003FE1240J
   Serial number: 35647RB400003FE11AC.
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0000042
   VCID: 418D087518CCD9838C-8014
   Part No SW: 8P0 920 931 T    HW: 8P0 920 931 T
   Component: KOMBIINSTR. VDO H15 0830
   Revision: D0H15005    Serial number: 2246H005010756
   Coding: 0005028
   Shop #: WSC 00046 000 00000
   VCID: 4483016107DECCABA7-8010
            014 - Defective
                    Fault Status: 01101110
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K0871801EB
   Coding: E9A27F461002022102
   VCID: 35656CA55C04652320-8060
                    Fault Frequency: 11
                    Reset counter: 249
                    Mileage: 162790 km
                    Date: 2021.07.28
                    Time: 22:20:00
                    Reset counter: 249
                    Mileage: 162790 km
                    Date: 2021.07.28
                    Time: 22:20:05
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 4381027D02D0CB939E-8016
   Revision: D0H15005    Serial number: AUX7Z0H6FNV0I0
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000148
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 233    2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A5F4FD985BA3ADBBD-807E
                    Fault Status: 11100101
                    Mileage: 162790 km
                    Date: 2021.07.28
                    Time: 22:20:02
                    Battery Volts: 13.8 V
                        DU
                    Temperature: 36.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 L
   Component:    KSG          H11 0080
   Coding: 1880200002186D0985054C8F0167
   VCID: 45851C650CE4F5A3B0-8010
Address 47: Sound System
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000148
Address 56: Radio
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0050
   Revision: 3A002002    Serial number: 00000113170995
   Coding: 0100000100000000
   Shop #: WSC 25477 000 00000
   VCID: 2F695ECD7E585FF36A-807A
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000144
   VCID: 428F07791DCAC29B95-8016
End-------------------------(Elapsed Time:
Jef
HQ
Please verify the "VIN Data" is all matching as detailed in the MK60EC1 FAQ. And since this is relevant to how we got here:
<snark>
</snark>
:p
robocik74
C?ID=46115
Trowbridge, UK
But is that the same in 01, 17 & 25?
The MK60EC1 ABS coding has data from the VIN in it, so coding will be specific to the VIN of a car. The following control modules have VIN data stored in them:
  • 01-Engine
  • 17-Instruments
  • 25-Immobilizer
The VIN is shown in the [Advanced ID-1A] function of VCDS while connected to Addresses 01, 17 and 25. If the stored VIN data in those modules do not match each other, it is not possible to code the MK60EC1 ABS module. VCDS can not resolve VIN mismatch issues.
robocik74
C?ID=46115
Yes the VIN number is the same because I put the old instrument cluster.When i did the scan all parts were genuine.
